。。。我给你 google 完的解决方案您好歹试试成嘛
nomodeset 选项已经加上,启动正常
还是会黑。该不会真的是温度过高了吧。低的时候 50 多,一般 60 多,最高可以上 70(都是摄氏度)
还有那个 12.104 的好像真是 13.4 lizards.opensuse.org/2013/04/29/proprietary-amdati-fglrx-12-104-catalyst-13-4-rpm-released/
怪异的命名
等等,源里有新版的驱动了。装下试试看
还是会黑
kdm.log 是每次开机都更新一点儿吗?如果是,那我给出的错误就实际上是猴年马月以前的错误了。那我再给一个发生过黑屏的片段吧(这次是在看 1080p 的电影时发生的)
X.Org X Server 1.13.2
Release Date: 2013-01-24
X Protocol Version 11, Revision 0
Build Operating System: openSUSE SUSE LINUX
Current Operating System: Linux linux-d8st.site 3.7.10-1.1-desktop #1 SMP PREEMPT Thu Feb 28 15:06:29 UTC 2013 (82d3f21) x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.7.10-1.1-desktop root=UUID=6c7be7ef-bd2a-4dc3-9f40-1d1a0ab82b99 resume=/dev/disk/by-id/ata-WDC_WD5000BPVT-24HXZT3_WD-WX11E61CW810-part5 splash=silent quiet showopts nomodeset
Build Date: 21 February 2013 10:01:18AM
Current version of pixman: 0.28.2
Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Jul 20 13:18:15 2013
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Initializing built-in extension Generic Event Extension
Initializing built-in extension SHAPE
Initializing built-in extension MIT-SHM
Initializing built-in extension XInputExtension
Initializing built-in extension XTEST
Initializing built-in extension BIG-REQUESTS
Initializing built-in extension SYNC
Initializing built-in extension XKEYBOARD
Initializing built-in extension XC-MISC
Initializing built-in extension SECURITY
Initializing built-in extension XINERAMA
Initializing built-in extension XFIXES
Initializing built-in extension RENDER
Initializing built-in extension RANDR
Initializing built-in extension COMPOSITE
Initializing built-in extension DAMAGE
Initializing built-in extension MIT-SCREEN-SAVER
Initializing built-in extension DOUBLE-BUFFER
Initializing built-in extension RECORD
Initializing built-in extension DPMS
Initializing built-in extension X-Resource
Initializing built-in extension XVideo
Initializing built-in extension XVideo-MotionCompensation
Initializing built-in extension XFree86-VidModeExtension
Initializing built-in extension XFree86-DGA
Initializing built-in extension XFree86-DRI
Initializing built-in extension DRI2
Loading extension GLX
(WW) fglrx: No matching Device section for instance (BusID PCI:0@1:0:1) found
Loading extension ATIFGLRXDRI
Loading extension FGLRXEXTENSION
Loading extension GLESX
Loading extension AMDXVOPL
Loading extension AMDXVBA
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Compat map for group 2 redefined
> Using new definition
> Warning: Compat map for group 3 redefined
> Warning: Compat map for group 4 redefined
Errors from xkbcomp are not fatal to the X server
我完全没感觉出来有什么问题。如果没黑屏,正常关机,仅仅多一句
Server terminated successfully (0). Closing log file.
Xorg.0.log 新的旧的内容都一样。dmesg 里也没有有用的信息
晕了
一天黑屏 n 次,怀疑是否是过热
@marguerite
姐姐,我这问题该不会是因为导热硅脂干了这样的原因导致的吧
前一阵儿给风扇清了清灰,黑屏的频率一下子就降低了。
@tonghuix
请问你的系统版本、内核版本、Xorg 版本和驱动版本都是什么呢?
我的是:
openSUSE 12.3
3.7.10-1.1-desktop
fglrx64_xpic_SUSE123 12.104-4-x86_64 (geeko.ioda.net/mirror/amd-fglrx/openSUSE_12.3/ 源)
遇到过几次亮度突然下降,但是几秒后会自动恢复,不知道为什么。还真没遇到过黑屏,我的 cpu 温度上过 70+ 呢
同问,我的也是 A 卡 4000 系列的,不过是 KDE 的桌面,从睡眠状态 唤醒的时候 会闪屏,头疼,一直解决不了这个问题……
最终确定是硬件问题,软件上怎么该都没有用
