[ 求助 ] 安装 Bumblebee 时那人源里的 DKMS 报错
linux-c3vi:/proc # modprobe bbswitch
linux-c3vi:/proc # lsmod | grep bbswitch
bbswitch               13932  0
linux-c3vi:/proc # cat /proc/acpi/bbswitch
0000:02:00.0 ON
接下去做什么?
继续前面出错的 primus 跑分啊
Sent from my iPad Mini using Tapatalk HD
还是出错. 什么情况.
linux-c3vi:/proc # optirun glxinfo | grep render
[12373.710089] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:2:0:0.  Please
[12373.710133] [ERROR]Aborting because fallback start is disabled.
linux-c3vi:/proc # primusrun glxinfo | grep render
primus: fatal: Bumblebee daemon reported: error: [XORG] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:2:0:0.  Please
重启了一下
linux-c3vi:/tmp # primusrun glxinfo | grep render
primus: fatal: Bumblebee daemon reported: error: Could not load GPU driver
linux-c3vi:/tmp # optirun glxinfo | grep render
  228.886700] [ERROR]Cannot access secondary GPU - error: Could not load GPU driver
  228.886761] [ERROR]Aborting because fallback start is disabled.
linux-c3vi:/tmp # cat /proc/acpi/bbswitch
0000:02:00.0 ON
重启 bumblebeed.service。把之前的 start 换成 restart
怎么做? 之前没有 start 啊
只有
sudo systemctl enable bumblebeed.service
sudo systemctl enable dkms.service
是不是
~> sudo restart bumblebeed.service
我执行了
还是
~> optirun glxinfo | grep render
 2228.647907] [ERROR]Cannot access secondary GPU - error: Could not load GPU driver
 2228.647958] [ERROR]Aborting because fallback start is disabled.
报告个情况: 您 69 楼让我执行一条命令 lsmod | grep nvidia
当时 70 楼执行是有输出的
现在执行没输出了
~> lsmod | grep nvidia
没有输出了
嗯哪,这回再给 bumblebeed.service 的 status 和 xorg.0.log。
总之侦错的前提就是,确保 bbswitch 挂载,然后看 bumblebeed 的 service 的运行状态,和 xorg.0.log 的日志。
~> sudo systemctl status bumblebee.service
root's password:
bumblebee.service
          Loaded: error (Reason: No such file or directory)
          Active: inactive (dead)
~> cat /var/log/Xorg.0.log
    22.634]
X.Org X Server 1.13.2
Release Date: 2013-01-24
    22.635] X Protocol Version 11, Revision 0
    22.635] Build Operating System: openSUSE SUSE LINUX
    22.635] Current Operating System: Linux linux-c3vi.site 3.7.10-1.11-desktop #1 SMP PREEMPT Thu May 16 20:27:27 UTC 2013 (adf31bb) x86_64
    22.635] Kernel command line: BOOT_IMAGE=/vmlinuz-3.7.10-1.11-desktop root=UUID=73dcb74e-471b-4520-91c5-a7471bdb8d07 resume=/dev/disk/by-id/ata-Hitachi_HTS545050B9A300_101126PBN4031711HEBE-part5 splash=silent quiet showopts
    22.635] Build Date: 30 April 2013  08:24:17AM
    22.635]
    22.635] Current version of pixman: 0.28.2
    22.635]    Before reporting problems, check http://wiki.x.org
    22.635] Markers: (--) probed, (**) from config file, (==) default setting,
    22.635] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jun 10 14:21:56 2013
    22.635] (==) Using config directory: "/etc/X11/xorg.conf.d"
    22.635] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
    22.636] (==) No Layout section.  Using the first Screen section.
    22.636] (==) No screen section available. Using defaults.
    22.636] (**) |-->Screen "Default Screen Section" (0)
    22.636] (**) |   |-->Monitor "<default monitor>"
    22.636] (==) No monitor specified for screen "Default Screen Section".
        Using a default monitor configuration.
    22.636] (==) Automatically adding devices
    22.636] (==) Automatically enabling devices
    22.636] (==) Automatically adding GPU devices
    22.636] (WW) The directory "/usr/share/fonts/misc/sgi" does not exist.
    22.636]    Entry deleted from font path.
    22.636] (==) FontPath set to:
        /usr/share/fonts/Type1/,
        /usr/share/fonts/truetype/,
        built-ins
    22.636] (==) ModulePath set to "/usr/lib64/xorg/modules/updates,/usr/lib64/xorg/modules"
    22.636] (II) The server relies on udev to provide the list of input devices.
        If no devices become available, reconfigure udev or disable AutoAddDevices.
    22.636] (II) Loader magic: 0x801c20
    22.636] (II) Module ABI versions:
    22.636]    X.Org ANSI C Emulation: 0.4
    22.636]    X.Org Video Driver: 13.1
    22.636]    X.Org XInput driver : 18.0
    22.636]    X.Org Server Extension : 7.0
    22.636] (II) config/udev: Adding drm device (/dev/dri/card0)
    22.637] (--) PCI:*(0:0:2:0) 8086:0046:1025:0371 rev 24, Mem @ 0xf0000000/4194304, 0xd0000000/268435456, I/O @ 0x00001800/8
    22.637] (--) PCI: (0:2:0:0) 10de:0df4:1025:0371 rev 161, Mem @ 0xac000000/16777216, 0xb0000000/268435456, 0xae000000/33554432, I/O @ 0x00002000/128
    22.638] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
    22.638] Initializing built-in extension Generic Event Extension
    22.638] Initializing built-in extension SHAPE
    22.638] Initializing built-in extension MIT-SHM
    22.638] Initializing built-in extension XInputExtension
    22.638] Initializing built-in extension XTEST
    22.638] Initializing built-in extension BIG-REQUESTS
    22.638] Initializing built-in extension SYNC
    22.638] Initializing built-in extension XKEYBOARD
    22.638] Initializing built-in extension XC-MISC
    22.638] Initializing built-in extension SECURITY
    22.638] Initializing built-in extension XINERAMA
    22.638] Initializing built-in extension XFIXES
    22.638] Initializing built-in extension RENDER
    22.638] Initializing built-in extension RANDR
    22.638] Initializing built-in extension COMPOSITE
    22.638] Initializing built-in extension DAMAGE
    22.638] Initializing built-in extension MIT-SCREEN-SAVER
    22.638] Initializing built-in extension DOUBLE-BUFFER
    22.638] Initializing built-in extension RECORD
    22.638] Initializing built-in extension DPMS
    22.638] Initializing built-in extension X-Resource
    22.638] Initializing built-in extension XVideo
    22.638] Initializing built-in extension XVideo-MotionCompensation
    22.638] Initializing built-in extension XFree86-VidModeExtension
    22.638] Initializing built-in extension XFree86-DGA
    22.638] Initializing built-in extension XFree86-DRI
    22.638] Initializing built-in extension DRI2
    22.638] (II) "glx" will be loaded by default.
    22.638] (II) LoadModule: "dri2"
    22.638] (II) Module "dri2" already built-in
    22.638] (II) LoadModule: "glamoregl"
    22.670] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
    22.671] (II) Module glamoregl: vendor="X.Org Foundation"
    22.671]    compiled for 1.13.2, module version = 0.5.0
    22.671]    ABI class: X.Org ANSI C Emulation, version 0.4
    22.672] (II) LoadModule: "glx"
    22.672] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
    22.672] (II) Module glx: vendor="X.Org Foundation"
    22.672]    compiled for 1.13.2, module version = 1.0.0
    22.672]    ABI class: X.Org Server Extension, version 7.0
    22.672] (==) AIGLX enabled
    22.672] Loading extension GLX
    22.672] (==) Matched intel as autoconfigured driver 0
    22.672] (==) Matched intel as autoconfigured driver 1
    22.672] (==) Matched modesetting as autoconfigured driver 2
    22.672] (==) Matched fbdev as autoconfigured driver 3
    22.672] (==) Matched vesa as autoconfigured driver 4
    22.672] (==) Assigned the driver to the xf86ConfigLayout
    22.672] (II) LoadModule: "intel"
    22.673] (II) Loading /usr/lib64/xorg/modules/drivers/intel_drv.so
    22.673] (II) Module intel: vendor="X.Org Foundation"
    22.673]    compiled for 1.13.1, module version = 2.20.19
    22.673]    Module class: X.Org Video Driver
    22.673]    ABI class: X.Org Video Driver, version 13.1
    22.673] (II) LoadModule: "modesetting"
    22.673] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
    22.673] (II) Module modesetting: vendor="X.Org Foundation"
    22.673]    compiled for 1.13.1, module version = 0.6.0
    22.673] (II) LoadModule: "fbdev"
    22.673] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
    22.673] (II) Module fbdev: vendor="X.Org Foundation"
    22.674]    compiled for 1.13.1, module version = 0.4.3
    22.674]    Module class: X.Org Video Driver
    22.674]    ABI class: X.Org Video Driver, version 13.1
    22.674] (II) LoadModule: "vesa"
    22.674] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
    22.674] (II) Module vesa: vendor="X.Org Foundation"
    22.674]    compiled for 1.13.1, module version = 2.3.2
    22.674] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
        i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
        E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
        965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
        4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
        Sandybridge Desktop (GT1), Sandybridge Desktop (GT2),
        Sandybridge Desktop (GT2+), Sandybridge Mobile (GT1),
        Sandybridge Mobile (GT2), Sandybridge Mobile (GT2+),
        Sandybridge Server, Ivybridge Mobile (GT1), Ivybridge Mobile (GT2),
        Ivybridge Desktop (GT1), Ivybridge Desktop (GT2), Ivybridge Server,
        Ivybridge Server (GT2), Haswell Desktop (GT1), Haswell Desktop (GT2),
        Haswell Desktop (GT2+), Haswell Mobile (GT1), Haswell Mobile (GT2),
        Haswell Mobile (GT2+), Haswell Server (GT1), Haswell Server (GT2),
        Haswell Server (GT2+), Haswell SDV Desktop (GT1),
        Haswell SDV Desktop (GT2), Haswell SDV Desktop (GT2+),
        Haswell SDV Mobile (GT1), Haswell SDV Mobile (GT2),
        Haswell SDV Mobile (GT2+), Haswell SDV Server (GT1),
        Haswell SDV Server (GT2), Haswell SDV Server (GT2+),
        Haswell ULT Desktop (GT1), Haswell ULT Desktop (GT2),
        Haswell ULT Desktop (GT2+), Haswell ULT Mobile (GT1),
        Haswell ULT Mobile (GT2), Haswell ULT Mobile (GT2+),
        Haswell ULT Server (GT1), Haswell ULT Server (GT2),
        Haswell ULT Server (GT2+), Haswell CRW Desktop (GT1),
        Haswell CRW Desktop (GT2), Haswell CRW Desktop (GT2+),
        Haswell CRW Mobile (GT1), Haswell CRW Mobile (GT2),
        Haswell CRW Mobile (GT2+), Haswell CRW Server (GT1),
        Haswell CRW Server (GT2), Haswell CRW Server (GT2+),
        ValleyView PO board
    22.674] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
    22.674] (II) FBDEV: driver for framebuffer: fbdev
    22.674] (II) VESA: driver for VESA chipsets: vesa
    22.674] (++) using VT number 7
    22.674] (WW) Falling back to old probe method for modesetting
    22.675] (WW) Falling back to old probe method for fbdev
    22.675] (II) Loading sub module "fbdevhw"
    22.675] (II) LoadModule: "fbdevhw"
    22.675] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
    22.675] (II) Module fbdevhw: vendor="X.Org Foundation"
    22.675]    compiled for 1.13.2, module version = 0.0.2
    22.675]    ABI class: X.Org Video Driver, version 13.1
    22.675] (WW) Falling back to old probe method for vesa
    22.675] (II) intel(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
    22.675] (==) intel(0): Depth 24, (--) framebuffer bpp 32
    22.675] (==) intel(0): RGB weight 888
    22.675] (==) intel(0): Default visual is TrueColor
    22.675] (--) intel(0): Integrated Graphics Chipset: Intel(R) Arrandale
    22.675] (**) intel(0): Relaxed fencing enabled
    22.675] (**) intel(0): Wait on SwapBuffers? enabled
    22.675] (**) intel(0): Triple buffering? enabled
    22.675] (**) intel(0): Framebuffer tiled
    22.675] (**) intel(0): Pixmaps tiled
    22.675] (**) intel(0): 3D buffers tiled
    22.675] (**) intel(0): SwapBuffers wait enabled
    22.675] (==) intel(0): video overlay key set to 0x101fe
    22.675] (II) intel(0): Output LVDS1 has no monitor section
    22.678] (--) intel(0): found backlight control interface /sys/class/backlight/acpi_video1
    22.683] (II) intel(0): Output VGA1 has no monitor section
    22.684] (II) intel(0): Output HDMI1 has no monitor section
    22.708] (II) intel(0): Output DP1 has no monitor section
    22.708] (II) intel(0): EDID for output LVDS1
    22.708] (II) intel(0): Manufacturer: AUO  Model: 183c  Serial#: 0
    22.708] (II) intel(0): Year: 2009  Week: 1
    22.708] (II) intel(0): EDID Version: 1.3
    22.708] (II) intel(0): Digital Display Input
    22.708] (II) intel(0): Max Image Size [cm]: horiz.: 31  vert.: 17
    22.708] (II) intel(0): Gamma: 2.20
    22.708] (II) intel(0): No DPMS capabilities specified
    22.708] (II) intel(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
    22.708] (II) intel(0): First detailed timing is preferred mode
    22.708] (II) intel(0): redX: 0.620 redY: 0.340   greenX: 0.330 greenY: 0.570
    22.708] (II) intel(0): blueX: 0.150 blueY: 0.600   whiteX: 0.313 whiteY: 0.329
    22.708] (II) intel(0): Manufacturer's mask: 0
    22.708] (II) intel(0): Supported detailed timing:
    22.708] (II) intel(0): clock: 69.3 MHz   Image Size:  309 x 173 mm
    22.708] (II) intel(0): h_active: 1366  h_sync: 1404  h_sync_end 1426 h_blank_end 1436 h_border: 0
    22.708] (II) intel(0): v_active: 768  v_sync: 771  v_sync_end 777 v_blanking: 803 v_border: 0
    22.708] (II) intel(0): Unknown vendor-specific block f
    22.708] (II) intel(0):  AUO
    22.708] (II) intel(0):  B140XW01 V8
    22.708] (II) intel(0): EDID (in hex):
    22.708] (II) intel(0):     00ffffffffffff0006af3c1800000000
    22.708] (II) intel(0):     01130103801f11780ac8a59e57549226
    22.708] (II) intel(0):     99505400000001010101010101010101
    22.708] (II) intel(0):     010101010101121b5646500023302616
    22.708] (II) intel(0):     360035ad100000180000000f00000000
    22.708] (II) intel(0):     00000000000000000020000000fe0041
    22.708] (II) intel(0):     554f0a202020202020202020000000fe
    22.708] (II) intel(0):     004231343058573031205638200a0017
    22.708] (II) intel(0): Not using default mode "320x240" (doublescan mode not supported)
    22.708] (II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
    22.708] (II) intel(0): Not using default mode "512x384" (doublescan mode not supported)
    22.708] (II) intel(0): Not using default mode "640x480" (doublescan mode not supported)
    22.708] (II) intel(0): Not using default mode "640x512" (doublescan mode not supported)
    22.708] (II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
    22.708] (II) intel(0): Not using default mode "896x672" (doublescan mode not supported)
    22.708] (II) intel(0): Not using default mode "928x696" (doublescan mode not supported)
    22.708] (II) intel(0): Not using default mode "960x720" (doublescan mode not supported)
    22.708] (II) intel(0): Not using default mode "700x525" (doublescan mode not supported)
    22.708] (II) intel(0): Not using default mode "1024x768" (doublescan mode not supported)
    22.708] (II) intel(0): Printing probed modes for output LVDS1
    22.708] (II) intel(0): Modeline "1366x768"x60.1   69.30  1366 1404 1426 1436  768 771 777 803 -hsync -vsync (48.3 kHz eP)
    22.708] (II) intel(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
    22.708] (II) intel(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
    22.708] (II) intel(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
    22.708] (II) intel(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
    22.712] (II) intel(0): EDID for output VGA1
    22.712] (II) intel(0): EDID for output HDMI1
    22.737] (II) intel(0): EDID for output DP1
    22.737] (II) intel(0): Output LVDS1 connected
    22.737] (II) intel(0): Output VGA1 disconnected
    22.737] (II) intel(0): Output HDMI1 disconnected
    22.737] (II) intel(0): Output DP1 disconnected
    22.737] (II) intel(0): Using exact sizes for initial modes
    22.737] (II) intel(0): Output LVDS1 using initial mode 1366x768
    22.737] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
    22.737] (II) intel(0): Kernel page flipping support detected, enabling
    22.737] (==) intel(0): DPI set to (96, 96)
    22.737] (II) Loading sub module "fb"
    22.737] (II) LoadModule: "fb"
    22.737] (II) Loading /usr/lib64/xorg/modules/libfb.so
    22.737] (II) Module fb: vendor="X.Org Foundation"
    22.737]    compiled for 1.13.2, module version = 1.0.0
    22.737]    ABI class: X.Org ANSI C Emulation, version 0.4
    22.737] (II) Loading sub module "glamoregl"
    22.737] (II) LoadModule: "glamoregl"
    22.737] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
    22.737] (II) Module glamoregl: vendor="X.Org Foundation"
    22.737]    compiled for 1.13.2, module version = 0.5.0
    22.737] (II) glamor: OpenGL accelerated X.org driver based.
    22.768] (II) glamor: EGL version 1.4 (DRI2):
    22.771] (II) intel(0): glamor detected, initialising egl layer.
    22.771] (II) Loading sub module "dri2"
    22.771] (II) LoadModule: "dri2"
    22.771] (II) Module "dri2" already built-in
    22.771] (II) UnloadModule: "modesetting"
    22.771] (II) Unloading modesetting
    22.771] (II) UnloadModule: "fbdev"
    22.771] (II) Unloading fbdev
    22.771] (II) UnloadSubModule: "fbdevhw"
    22.771] (II) Unloading fbdevhw
    22.771] (II) UnloadModule: "vesa"
    22.771] (II) Unloading vesa
    22.771] (==) Depth 24 pixmap format is 32 bpp
    22.771] (II) intel(0): [DRI2] Setup complete
    22.771] (II) intel(0): [DRI2]   DRI driver: i965
    22.771] (II) intel(0): Allocated new frame buffer 1408x768 stride 5632, tiled
    22.778] (II) UXA(0): Driver registered support for the following operations:
    22.778] (II)         solid
    22.778] (II)         copy
    22.778] (II)         composite (RENDER acceleration)
    22.778] (II)         put_image
    22.778] (II)         get_image
    22.778] (==) intel(0): Backing store disabled
    22.778] (==) intel(0): Silken mouse enabled
    22.778] (II) intel(0): Initializing HW Cursor
    22.778] (II) intel(0): Use standard UXA acceleration.
    22.778] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
    22.790] (==) intel(0): DPMS enabled
    22.790] (==) intel(0): Intel XvMC decoder enabled
    22.790] (II) intel(0): Set up textured video
    22.791] (II) intel(0): [XvMC] xvmc_vld driver initialized.
    22.791] (II) intel(0): direct rendering: DRI2 Enabled
    22.791] (==) intel(0): hotplug detection: "enabled"
    22.817] (--) RandR disabled
    22.822] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
    22.822] (II) AIGLX: enabled GLX_INTEL_swap_event
    22.822] (II) AIGLX: enabled GLX_ARB_create_context
    22.822] (II) AIGLX: enabled GLX_ARB_create_context_profile
    22.822] (II) AIGLX: enabled GLX_EXT_create_context_es2_profile
    22.822] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
    22.822] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
    22.822] (II) AIGLX: Loaded and initialized i965
    22.822] (II) GLX: Initialized DRI2 GL provider for screen 0
    22.822] (II) intel(0): Setting screen physical size to 361 x 203
    22.924] (II) config/udev: Adding input device Power Button (/dev/input/event4)
    22.924] (**) Power Button: Applying InputClass "evdev keyboard catchall"
    22.924] (**) Power Button: Applying InputClass "LocalKeyboard"
    22.924] (II) LoadModule: "evdev"
    22.924] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
    22.925] (II) Module evdev: vendor="X.Org Foundation"
    22.925]    compiled for 1.13.1, module version = 2.7.3
    22.925]    Module class: X.Org XInput Driver
    22.925]    ABI class: X.Org XInput driver, version 18.0
    22.925] (II) Using input driver 'evdev' for 'Power Button'
    22.925] (**) Power Button: always reports core events
    22.925] (**) evdev: Power Button: Device: "/dev/input/event4"
    22.925] (--) evdev: Power Button: Vendor 0 Product 0x1
    22.925] (--) evdev: Power Button: Found keys
    22.925] (II) evdev: Power Button: Configuring as keyboard
    22.925] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input4/event4"
    22.925] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
    22.925] (**) Option "xkb_rules" "evdev"
    22.925] (**) Option "xkb_model" "evdev"
    22.925] (**) Option "xkb_layout" "us"
    22.946] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
    22.946] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
    22.946] (**) Video Bus: Applying InputClass "LocalKeyboard"
    22.946] (II) Using input driver 'evdev' for 'Video Bus'
    22.946] (**) Video Bus: always reports core events
    22.946] (**) evdev: Video Bus: Device: "/dev/input/event6"
    22.946] (--) evdev: Video Bus: Vendor 0 Product 0x6
    22.946] (--) evdev: Video Bus: Found keys
    22.946] (II) evdev: Video Bus: Configuring as keyboard
    22.946] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input6/event6"
    22.946] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
    22.946] (**) Option "xkb_rules" "evdev"
    22.946] (**) Option "xkb_model" "evdev"
    22.946] (**) Option "xkb_layout" "us"
    22.946] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
    22.946] (**) evdev: Video Bus: Device: "/dev/input/event5"
    22.946] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input5/event5"
    22.946] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
    22.947] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
    22.947] (II) No input driver specified, ignoring this device.
    22.947] (II) This device may have been added with another device file.
    22.947] (II) config/udev: Adding input device Sleep Button (/dev/input/event3)
    22.947] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
    22.947] (**) Sleep Button: Applying InputClass "LocalKeyboard"
    22.947] (II) Using input driver 'evdev' for 'Sleep Button'
    22.947] (**) Sleep Button: always reports core events
    22.947] (**) evdev: Sleep Button: Device: "/dev/input/event3"
    22.947] (--) evdev: Sleep Button: Vendor 0 Product 0x3
    22.947] (--) evdev: Sleep Button: Found keys
    22.947] (II) evdev: Sleep Button: Configuring as keyboard
    22.947] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input3/event3"
    22.947] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
    22.947] (**) Option "xkb_rules" "evdev"
    22.947] (**) Option "xkb_model" "evdev"
    22.947] (**) Option "xkb_layout" "us"
    22.947] (II) config/udev: Adding drm device (/dev/dri/card0)
    22.948] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event11)
    22.948] (II) No input driver specified, ignoring this device.
    22.948] (II) This device may have been added with another device file.
    22.948] (II) config/udev: Adding input device HDA Intel MID HDMI/DP,pcm=3 (/dev/input/event12)
    22.948] (II) config/udev: Adding input device HDA Intel MID Mic (/dev/input/event13)
    22.948] (II) config/udev: Adding input device HDA Intel MID Headphone (/dev/input/event14)
    22.949] (II) config/udev: Adding input device 1.3M WebCam (/dev/input/event8)
    22.949] (**) 1.3M WebCam: Applying InputClass "evdev keyboard catchall"
    22.949] (**) 1.3M WebCam: Applying InputClass "LocalKeyboard"
    22.949] (II) Using input driver 'evdev' for '1.3M WebCam'
    22.949] (**) 1.3M WebCam: always reports core events
    22.949] (**) evdev: 1.3M WebCam: Device: "/dev/input/event8"
    22.949] (--) evdev: 1.3M WebCam: Vendor 0x402 Product 0x9665
    22.949] (--) evdev: 1.3M WebCam: Found keys
    22.949] (II) evdev: 1.3M WebCam: Configuring as keyboard
    22.949] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/input/input8/event8"
    22.949] (II) XINPUT: Adding extended input device "1.3M WebCam" (type: KEYBOARD, id 10)
    22.949] (**) Option "xkb_rules" "evdev"
    22.949] (**) Option "xkb_model" "evdev"
    22.949] (**) Option "xkb_layout" "us"
    22.949] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
    22.949] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
    22.949] (**) AT Translated Set 2 keyboard: Applying InputClass "LocalKeyboard"
    22.949] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
    22.949] (**) AT Translated Set 2 keyboard: always reports core events
    22.949] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
    22.949] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
    22.949] (--) evdev: AT Translated Set 2 keyboard: Found keys
    22.949] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
    22.949] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
    22.949] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 11)
    22.950] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event1)
    22.950] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
    22.950] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
    22.950] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Default clickpad buttons"
    22.950] (II) LoadModule: "synaptics"
    22.950] (II) Loading /usr/lib64/xorg/modules/input/synaptics_drv.so
    22.950] (II) Module synaptics: vendor="X.Org Foundation"
    22.950]    compiled for 1.13.2, module version = 1.6.3
    22.950]    Module class: X.Org XInput Driver
    22.950]    ABI class: X.Org XInput driver, version 18.0
    22.950] (II) Using input driver 'synaptics' for 'SynPS/2 Synaptics TouchPad'
    22.950] (**) SynPS/2 Synaptics TouchPad: always reports core events
    22.950] (**) Option "Device" "/dev/input/event1"
    22.959] (II) synaptics: SynPS/2 Synaptics TouchPad: ignoring touch events for semi-multitouch device
    22.959] (--) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5576
    22.959] (--) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4880
    22.959] (--) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
    22.959] (--) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
    22.959] (--) synaptics: SynPS/2 Synaptics TouchPad: buttons: left right double triple
    22.959] (--) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
    22.959] (**) Option "HorizScrollDelta" "0"
    22.959] (**) Option "TapButton1" "1"
    22.959] (**) Option "TapButton2" "3"
    22.959] (**) Option "TapButton3" "2"
    22.959] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
    22.959] (**) SynPS/2 Synaptics TouchPad: always reports core events
    22.961] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input1/event1"
    22.961] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 12)
    22.961] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
    22.961] (**) synaptics: SynPS/2 Synaptics TouchPad: MaxSpeed is now 1.75
    22.961] (**) synaptics: SynPS/2 Synaptics TouchPad: AccelFactor is now 0.037
    22.961] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
    22.961] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
    22.961] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
    22.961] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
    22.961] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
    22.961] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
    22.961] (**) SynPS/2 Synaptics TouchPad: Ignoring device from InputClass "touchpad ignore duplicates"
    22.962] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
    22.962] (II) No input driver specified, ignoring this device.
    22.962] (II) This device may have been added with another device file.
    22.963] (II) config/udev: Adding input device Acer BMA150 accelerometer (/dev/input/event10)
    22.963] (II) No input driver specified, ignoring this device.
    22.963] (II) This device may have been added with another device file.
    22.963] (II) config/udev: Adding input device Acer BMA150 accelerometer (/dev/input/js0)
    22.963] (II) config/udev: Adding input device Acer WMI hotkeys (/dev/input/event9)
    22.963] (**) Acer WMI hotkeys: Applying InputClass "evdev keyboard catchall"
    22.963] (**) Acer WMI hotkeys: Applying InputClass "LocalKeyboard"
    22.963] (II) Using input driver 'evdev' for 'Acer WMI hotkeys'
    22.963] (**) Acer WMI hotkeys: always reports core events
    22.963] (**) evdev: Acer WMI hotkeys: Device: "/dev/input/event9"
    22.963] (--) evdev: Acer WMI hotkeys: Vendor 0 Product 0
    22.963] (--) evdev: Acer WMI hotkeys: Found keys
    22.963] (II) evdev: Acer WMI hotkeys: Configuring as keyboard
    22.963] (**) Option "config_info" "udev:/sys/devices/virtual/input/input9/event9"
    22.963] (II) XINPUT: Adding extended input device "Acer WMI hotkeys" (type: KEYBOARD, id 13)
    22.963] (**) Option "xkb_rules" "evdev"
    22.963] (**) Option "xkb_model" "evdev"
    22.963] (**) Option "xkb_layout" "us"
    36.791] (II) intel(0): EDID vendor "AUO", prod id 6204
    36.791] (II) intel(0): Printing DDC gathered Modelines:
    36.791] (II) intel(0): Modeline "1366x768"x0.0   69.30  1366 1404 1426 1436  768 771 777 803 -hsync -vsync (48.3 kHz eP)
    38.394] (II) intel(0): EDID vendor "AUO", prod id 6204
    38.394] (II) intel(0): Printing DDC gathered Modelines:
    38.394] (II) intel(0): Modeline "1366x768"x0.0   69.30  1366 1404 1426 1436  768 771 777 803 -hsync -vsync (48.3 kHz eP)
    49.473] (II) intel(0): EDID vendor "AUO", prod id 6204
    49.473] (II) intel(0): Printing DDC gathered Modelines:
    49.473] (II) intel(0): Modeline "1366x768"x0.0   69.30  1366 1404 1426 1436  768 771 777 803 -hsync -vsync (48.3 kHz eP)
现在执行
~> cat /proc/acpi/bbswitch
0000:02:00.0 OFF
OFF 是否表示独显关闭了啊?
第一次是我的错,第二次就是你的错了。bumblebeed.service。
sorry
~> sudo systemctl status bumblebeed.service
root's password:
bumblebeed.service - Bumblebee C Daemon
          Loaded: loaded (/usr/lib/systemd/system/bumblebeed.service; enabled)
          Active: active (running) since Mon, 2013-06-10 18:47:47 CST; 2min 25s ago
        Main PID: 528 (bumblebeed)
          CGroup: name=systemd:/system/bumblebeed.service
                  └ 528 /usr/sbin/bumblebeed
Jun 10 18:47:47 linux-c3vi.site systemd[1]: Starting Bumblebee C Daemon...
Jun 10 18:47:47 linux-c3vi.site systemd[1]: Started Bumblebee C Daemon.
Jun 10 18:48:02 linux-c3vi.site bumblebeed[528]:    37.086032] [INFO]/usr/sbin/bumblebeed 3.2.1 started
0000:02:00.0 OFF
su
echo ON > /proc/acpi/bbswitch
modprobe nvidia
exit
# echo ON > /proc/acpi/bbswitch
# modprobe nvidia
# exit
exit
[10339.774206] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:2:0:0.  Please
[10339.774250] [ERROR]Aborting because fallback start is disabled.
> lsmod | grep nvidia
nvidia               9429239  0
0000:02:00.0 ON
报告个情况:
现在开机一上来
cat: /proc/acpi/bbswitch: No such file or directory
然后
~> sudo systemctl restart bumblebeed.service
0000:02:00.0 OFF
重启后一上来, 又是
93 楼之前, 启动后一上来, 还是
感觉 OFF 表示独显关闭吧! 因为在这个状态, 独显的风扇都挺安静的, 温度也不高.
如果是这样, 回到每次开机执行 cat /proc/acpi/bbswitch 都是显示 cat /proc/acpi/bbswitch 就好了.
亲,凑合不是胜利。
你把刚才我说的那些都做完然后再贴 Xorg.0.log。
又有新情况
刚才又重启了一次
又没有输出了
于是
# modprobe nvidia
FATAL: Error inserting nvidia (/lib/modules/3.7.10-1.11-desktop/updates/nvidia.ko): No such device
奇怪,93 楼执行这条命令没有这条输出的啊!
亲呐,您要消化吸收的啊,不然就一直别重启(这不现实),很明显你的 bbswitch 和 nvidia 一起掉了啊。你这问题之前出现过的。我们不能都 10 页了还在翻来覆去的解决出现过的问题摸不到问题的实质啊,我现在都无法确定你的 Can‘t load secondary GPU 是你有东西没启动还是真的是问题,前面每次要摸到的时候都发现其实是你操作失误…
modprobe nvidia 这个命令我 93 楼执行的好好的
怎么现在不行了提示:FATAL: Error inserting nvidia (/lib/modules/3.7.10-1.11-desktop/updates/nvidia.ko): No such device 了?
我从 93 楼向上回溯了一下:
86 楼的时候 “lsmod | grep nvidia” 就没有输出 , 然后一直搁置着.
直到 93 楼执行了你 92 楼给的命令 :“modprobe nvidia” 就有输出了 " nvidia 9429239 0 “.
这样看来解决"lsmod | grep nvidia” 没输出的办法是且只是"modprobe nvidia" 啊
现在这个办法不能用了啊, 叫我怎么办?
我认真从头看完了整个帖子,我安 bumblebee 的时候也遇到了 lz 的一些问题,最大问题是软件包里闭源独显驱动在软件管理里显示安装上了,但实际在下载驱动包安装的时候出错了,所以在启动 bumblebee 会报错,错误就忘了。然后我又把相关包卸载,安开源驱动重新来过。。刚开始能关掉独显,后来安装了个 laptop-mode-tools 在开机时独显又开始工作了,我又配置 laptop-mode-tools 但总是效果不好,同时我在爬帖子的时候看到说在安装系统前禁用独显然后装好系统后再开启双显,独显就不会工作也不会发热,所以才有了下面这种方法,既然 lz 就是想把独显关掉,和我是一种心态。。。那就这么操作。。。其实不折腾 bumblebee 也能关掉独显。先移除独显的闭源和开源驱动,我全部把他卸了,不卸不知道结果怎样,在 /etc/modprobe.d 文件夹下新建 50-nvidia.conf 内容 blacklist nvidia,终端命令我就写了,然后新建 50-nouveau.conf,内容 blacklist nouveau。然后重建 initrd ,命令 sudo mkinitrd,重启 lspci | grep VGA 看看效果。但我之前安装的 bumblebee 和 bbswitch 没删,因为这几天考试所以没折腾。。。改天删了试试。。。我亲测有效。。。这帖子给了我很多启发,也学到了很多,我也是这么一步步折腾过来的。。。苏女王也辛苦了
