openSUSE 42.1 Lantern 编译出错
npm WARN package.json lantern-ui@0.0.10-0 license should be a valid SPDX license expression
# github.com/getlantern/flashlight/main
/usr/lib64/go/pkg/tool/linux_amd64/link: running gcc failed: exit status 1
/tmp/go-link-515019909/go.o: In function `runtime.raceinit':
/usr/lib64/go/src/runtime/race.go:199: undefined reference to `__tsan_init'
/usr/lib64/go/src/runtime/race.go:229: undefined reference to `__tsan_map_shadow'
/tmp/go-link-515019909/go.o: In function `runtime.racefini':
/usr/lib64/go/src/runtime/race.go:238: undefined reference to `__tsan_fini'
/tmp/go-link-515019909/go.o: In function `runtime.racemapshadow':
/usr/lib64/go/src/runtime/race.go:249: undefined reference to `__tsan_map_shadow'
/tmp/go-link-515019909/go.o: In function `runtime.racemalloc':
/usr/lib64/go/src/runtime/race.go:254: undefined reference to `__tsan_malloc'
/tmp/go-link-515019909/go.o: In function `runtime.racegostart':
/usr/lib64/go/src/runtime/race.go:268: undefined reference to `__tsan_go_start'
/tmp/go-link-515019909/go.o: In function `runtime.racegoend':
/usr/lib64/go/src/runtime/race.go:274: undefined reference to `__tsan_go_end'
/tmp/go-link-515019909/go.o: In function `runtime.raceacquireg':
/usr/lib64/go/src/runtime/race.go:321: undefined reference to `__tsan_acquire'
/tmp/go-link-515019909/go.o: In function `runtime.racereleaseg':
/usr/lib64/go/src/runtime/race.go:338: undefined reference to `__tsan_release'
/tmp/go-link-515019909/go.o: In function `runtime.racereleasemergeg':
/usr/lib64/go/src/runtime/race.go:351: undefined reference to `__tsan_release_merge'
/tmp/go-link-515019909/go.o: In function `runtime.racefingo':
/usr/lib64/go/src/runtime/race.go:356: undefined reference to `__tsan_finalizer_goroutine'
/tmp/go-link-515019909/go.o: In function `runtime.RaceDisable':
/usr/lib64/go/src/runtime/race.go:383: undefined reference to `__tsan_go_ignore_sync_begin'
/tmp/go-link-515019909/go.o: In function `runtime.RaceEnable':
/usr/lib64/go/src/runtime/race.go:395: undefined reference to `__tsan_go_ignore_sync_end'
/tmp/go-link-515019909/go.o: In function `runtime.raceread':
/usr/lib64/go/src/runtime/race_amd64.s:48: undefined reference to `__tsan_read'
/tmp/go-link-515019909/go.o: In function `runtime.racereadpc':
/usr/lib64/go/src/runtime/race_amd64.s:63: undefined reference to `__tsan_read_pc'
/tmp/go-link-515019909/go.o: In function `runtime.racewrite':
/usr/lib64/go/src/runtime/race_amd64.s:72: undefined reference to `__tsan_write'
/tmp/go-link-515019909/go.o: In function `runtime.racewritepc':
/usr/lib64/go/src/runtime/race_amd64.s:87: undefined reference to `__tsan_write_pc'
/tmp/go-link-515019909/go.o: In function `runtime.racereadrange':
/usr/lib64/go/src/runtime/race_amd64.s:97: undefined reference to `__tsan_read_range'
/tmp/go-link-515019909/go.o: In function `runtime.racereadrangepc1':
/usr/lib64/go/src/runtime/race_amd64.s:112: undefined reference to `__tsan_read_range'
/tmp/go-link-515019909/go.o: In function `runtime.racewriterange':
/usr/lib64/go/src/runtime/race_amd64.s:122: undefined reference to `__tsan_write_range'
/tmp/go-link-515019909/go.o: In function `runtime.racewriterangepc1':
/usr/lib64/go/src/runtime/race_amd64.s:137: undefined reference to `__tsan_write_range'
/tmp/go-link-515019909/go.o: In function `runtime.racefuncenter':
/usr/lib64/go/src/runtime/race_amd64.s:171: undefined reference to `__tsan_func_enter'
/tmp/go-link-515019909/go.o: In function `runtime.racefuncexit':
/usr/lib64/go/src/runtime/race_amd64.s:184: undefined reference to `__tsan_func_exit'
/tmp/go-link-515019909/go.o: In function `sync/atomic.LoadInt32':
/usr/lib64/go/src/runtime/race_amd64.s:191: undefined reference to `__tsan_go_atomic32_load'
/tmp/go-link-515019909/go.o: In function `sync/atomic.LoadInt64':
/usr/lib64/go/src/runtime/race_amd64.s:196: undefined reference to `__tsan_go_atomic64_load'
/tmp/go-link-515019909/go.o: In function `sync/atomic.StoreInt32':
/usr/lib64/go/src/runtime/race_amd64.s:214: undefined reference to `__tsan_go_atomic32_store'
/tmp/go-link-515019909/go.o: In function `sync/atomic.StoreInt64':
/usr/lib64/go/src/runtime/race_amd64.s:219: undefined reference to `__tsan_go_atomic64_store'
/tmp/go-link-515019909/go.o: In function `sync/atomic.AddInt32':
/usr/lib64/go/src/runtime/race_amd64.s:254: undefined reference to `__tsan_go_atomic32_fetch_add'
/tmp/go-link-515019909/go.o: In function `sync/atomic.AddInt64':
/usr/lib64/go/src/runtime/race_amd64.s:261: undefined reference to `__tsan_go_atomic64_fetch_add'
/tmp/go-link-515019909/go.o: In function `sync/atomic.CompareAndSwapInt32':
/usr/lib64/go/src/runtime/race_amd64.s:278: undefined reference to `__tsan_go_atomic32_compare_exchange'
/tmp/go-link-515019909/go.o: In function `sync/atomic.CompareAndSwapInt64':
/usr/lib64/go/src/runtime/race_amd64.s:283: undefined reference to `__tsan_go_atomic64_compare_exchange'
/tmp/go-link-515019909/go.o: In function `racecallatomic':
/usr/lib64/go/src/runtime/race_amd64.s:326: undefined reference to `__tsan_go_ignore_sync_begin'
/usr/lib64/go/src/runtime/race_amd64.s:338: undefined reference to `__tsan_go_ignore_sync_end'
collect2: error: ld returned 1 exit status
这是因为缺少什么库导致的错误吗?
你可能没装 gcc
@marguerite gcc 已经安装了,gcc5-go 也已经安装了~
为啥自己编译,不是有Linux通用的静态编译包吗,解压即用
通过我的 HUAWEI MT7-TL00 上的 Tapatalk发言
回头我编译下看看吧,不过我是风滚草
把deb包转成rpm安装,结果电脑开不了机了,也是醉了
