$ zypper search -t application "Search and Indexing"
Loading repository data...
Reading installed packages...
S | Name | Summary | Type
| Search and Indexing | Configure file indexing with Tracker | application
$ zypper in -t application "Search and Indexing"
Resolving package dependencies...
The following 2 applications are going to be installed:
"Desktop Search" "Search and Indexing"
The following 17 NEW packages are going to be installed:
libcue1 libenca0 libexempi3 libgsf-1-114 libgxps2 libiptcdata libiptcdata0 libmediaart-1_0-0 libosinfo libosinfo-1_0-0 libtracker-common-1_0 libtracker-control-1_0-0 libtracker-miner-1_0-0
libtracker-sparql-1_0-0 tracker tracker-gui tracker-miner-files
The following 2 recommended packages were automatically selected:
tracker tracker-miner-files
17 new packages to install.
Overall download size: 3.0 MiB. Already cached: 0 B After the operation, additional 8.7 MiB will be used.
sudo zypper in -t application "Search and Indexing"
'application:Search and Indexing' is already installed.
Package 'Search and Indexing' is not available in your repositories. Cannot reinstall, upgrade, or downgrade.
The following application is going to be REMOVED:
No additional space will be used or freed after the operation.
Nothing to do.
sudo zypper rm -u -t application "Search and Indexing"
root's password:
Nothing to do.
