先说下过程,机器先是睡眠了,然后唤醒,电源启动,屏幕无显示,唤醒失败,重启,进入系统,睡眠,进入睡眠后(电源灯灭了,电池灯闪),2 秒左右进行唤醒,可以正常唤醒,再次进行睡眠,15 分钟后,唤醒失败,这次情况是,唤醒屏幕这起,显示到 KDM,鼠标键盘无法操作,过两秒后 KDM 挂了,自动跳到 tty 显示下面的图
然后 CapsLK 灯不断闪,再过几秒后自动重启。重新开机后查看日志没有看到相关的错误信息下面附件是导出的日志
sudo journalctl --since "2014-11-07 14:50:00" > ~/sleep_bad.log
这是其中唤醒那一段
11 月 07 15:11:47 openSUSE.linux NetworkManager[841]: <info> sleep requested (sleeping: no enabled: yes)
11 月 07 15:11:47 openSUSE.linux NetworkManager[841]: <info> sleeping...
11 月 07 15:11:47 openSUSE.linux NetworkManager[841]: <info> (wlp2s0): device state change: activated -> unmanaged (reason 'sleeping') [100 10 37]
11 月 07 15:11:47 openSUSE.linux NetworkManager[841]: <info> (wlp2s0): deactivating device (reason 'sleeping') [37]
11 月 07 15:11:47 openSUSE.linux dhclient[2190]: Received signal 15, initiating shutdown.
11 月 07 15:11:47 openSUSE.linux NetworkManager[841]: Received signal 15, initiating shutdown.
11 月 07 15:11:47 openSUSE.linux dhclient[2190]: DHCPRELEASE on wlp2s0 to 192.168.1.1 port 67 (xid=0x43aab824)
11 月 07 15:11:47 openSUSE.linux NetworkManager[841]: DHCPRELEASE on wlp2s0 to 192.168.1.1 port 67 (xid=0x43aab824)
11 月 07 15:11:48 openSUSE.linux NetworkManager[841]: <warn> (wlp2s0): DHCP client pid 2190 didn't exit, will kill it.
11 月 07 15:11:48 openSUSE.linux NetworkManager[841]: <info> (wlp2s0): canceled DHCP transaction, DHCP client pid 2190
11 月 07 15:11:48 openSUSE.linux avahi-daemon[758]: Withdrawing address record for fe80::9ed2:1eff:fe58:348b on wlp2s0.
11 月 07 15:11:48 openSUSE.linux avahi-daemon[758]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address fe80::9ed2:1eff:fe58:348b.
11 月 07 15:11:48 openSUSE.linux avahi-daemon[758]: Interface wlp2s0.IPv6 no longer relevant for mDNS.
11 月 07 15:11:48 openSUSE.linux avahi-daemon[758]: Withdrawing address record for 192.168.1.251 on wlp2s0.
11 月 07 15:11:48 openSUSE.linux avahi-daemon[758]: Leaving mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.1.251.
11 月 07 15:11:48 openSUSE.linux avahi-daemon[758]: Interface wlp2s0.IPv4 no longer relevant for mDNS.
11 月 07 15:11:48 openSUSE.linux kernel: wlp2s0: deauthenticating from 78:a1:06:87:8a:36 by local choice (Reason: 3=DEAUTH_LEAVING)
11 月 07 15:11:48 openSUSE.linux kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
11 月 07 15:11:48 openSUSE.linux kernel: cfg80211: Calling CRDA to update world regulatory domain
11 月 07 15:11:48 openSUSE.linux NetworkManager[841]: <info> NetworkManager state is now ASLEEP
11 月 07 15:11:48 openSUSE.linux kernel: cfg80211: World regulatory domain updated:
11 月 07 15:11:48 openSUSE.linux kernel: cfg80211: DFS Master region: unset
11 月 07 15:11:48 openSUSE.linux kernel: cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
11 月 07 15:11:48 openSUSE.linux kernel: cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
11 月 07 15:11:48 openSUSE.linux kernel: cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
11 月 07 15:11:48 openSUSE.linux kernel: cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
11 月 07 15:11:48 openSUSE.linux kernel: cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
11 月 07 15:11:48 openSUSE.linux kernel: cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
11 月 07 15:11:48 openSUSE.linux kernel: cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
11 月 07 15:11:48 openSUSE.linux kernel: cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
11 月 07 15:11:48 openSUSE.linux kernel: cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
11 月 07 15:11:48 openSUSE.linux nm-dispatcher[2198]: Dispatching action 'down' for wlp2s0
-- Reboot --
sleep_bad.log (332 KB)
