不好意思上夜班几天没用这台有问题的电脑,不知道这样回复对不对
    15.999]
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
    15.999]
X.Org X Server 1.14.3.901 (1.14.4 RC 1)
Release Date: 2013-10-26
    15.999] X Protocol Version 11, Revision 0
    15.999] Build Operating System: openSUSE SUSE LINUX
    15.999] Current Operating System: Linux linux-a78s 3.11.6-4-desktop #1 SMP PREEMPT Wed Oct 30 18:04:56 UTC 2013 (e6d4a27) x86_64
    15.999] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.11.6-4-desktop root=UUID=9cfb9168-365e-41e2-8a84-d68ee74aa389 showopts apm=off noresume edd=off powersaved=off nohz=off highres=off processor.max_cstate=1 nomodeset x11failsafe
    15.999] Build Date: 06 November 2013  10:07:38AM
    15.999]
    15.999] Current version of pixman: 0.30.2
    15.999] 	Before reporting problems, check http://wiki.x.org
    15.999] Markers: (--) probed, (**) from config file, (==) default setting,
    15.999] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Dec 12 21:17:06 2013
    15.999] (==) Using config file: "/etc/X11/xorg.conf.install"
    15.999] (==) Using config directory: "/etc/X11/xorg.conf.d"
    15.999] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
    16.052] (==) ServerLayout "Layout"
    16.052] (**) |-->Screen "vboxvideo" (0)
    16.052] (**) |   |-->Monitor "<default monitor>"
    16.052] (**) |   |-->Device "vboxvideo"
    16.052] (==) No monitor specified for screen "vboxvideo".
	Using a default monitor configuration.
    16.052] (**) |-->Screen "vmware" (1)
    16.052] (**) |   |-->Device "vmware"
    16.052] (==) No monitor specified for screen "vmware".
    16.052] (**) |-->Screen "modesetting" (2)
    16.052] (**) |   |-->Device "modesetting"
    16.052] (==) No monitor specified for screen "modesetting".
    16.052] (**) |-->Screen "fbdev" (3)
    16.053] (**) |   |-->Device "fbdev"
    16.053] (==) No monitor specified for screen "fbdev".
    16.053] (**) |-->Screen "vesa" (4)
    16.053] (**) |   |-->Monitor "<default monitor>"
    16.053] (**) |   |-->Device "vesa"
    16.053] (==) No monitor specified for screen "vesa".
    16.053] (==) Automatically adding devices
    16.053] (==) Automatically enabling devices
    16.053] (==) Automatically adding GPU devices
    16.505] (WW) The directory "/usr/share/fonts/misc/sgi" does not exist.
    16.505] 	Entry deleted from font path.
    16.542] (==) FontPath set to:
	/usr/share/fonts/Type1/,
	/usr/share/fonts/truetype/,
	built-ins
    16.542] (==) ModulePath set to "/usr/lib64/xorg/modules/updates,/usr/lib64/xorg/modules"
    16.542] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
    16.542] (II) Loader magic: 0x803c20
    16.542] (II) Module ABI versions:
    16.542] 	X.Org ANSI C Emulation: 0.4
    16.542] 	X.Org Video Driver: 14.1
    16.542] 	X.Org XInput driver : 19.1
    16.542] 	X.Org Server Extension : 7.0
    16.544] (--) PCI:*(0:1:0:0) 1002:68f9:1642:3983 rev 0, Mem @ 0xd0000000/268435456, 0xfeae0000/131072, I/O @ 0x0000d000/256, BIOS @ 0x????????/131072
    16.544] Initializing built-in extension Generic Event Extension
    16.544] Initializing built-in extension SHAPE
    16.544] Initializing built-in extension MIT-SHM
    16.544] Initializing built-in extension XInputExtension
    16.544] Initializing built-in extension XTEST
    16.544] Initializing built-in extension BIG-REQUESTS
    16.544] Initializing built-in extension SYNC
    16.544] Initializing built-in extension XKEYBOARD
    16.544] Initializing built-in extension XC-MISC
    16.544] Initializing built-in extension SECURITY
    16.544] Initializing built-in extension XINERAMA
    16.544] Initializing built-in extension XFIXES
    16.544] Initializing built-in extension RENDER
    16.544] Initializing built-in extension RANDR
    16.544] Initializing built-in extension COMPOSITE
    16.544] Initializing built-in extension DAMAGE
    16.544] Initializing built-in extension MIT-SCREEN-SAVER
    16.544] Initializing built-in extension DOUBLE-BUFFER
    16.544] Initializing built-in extension RECORD
    16.544] Initializing built-in extension DPMS
    16.544] Initializing built-in extension X-Resource
    16.544] Initializing built-in extension XVideo
    16.544] Initializing built-in extension XVideo-MotionCompensation
    16.544] Initializing built-in extension XFree86-VidModeExtension
    16.544] Initializing built-in extension XFree86-DGA
    16.544] Initializing built-in extension XFree86-DRI
    16.544] Initializing built-in extension DRI2
    16.544] (II) "glx" will be loaded by default.
    16.544] (II) LoadModule: "dri2"
    16.544] (II) Module "dri2" already built-in
    16.544] (II) LoadModule: "glamoregl"
    16.565] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
    16.812] (EE) Failed to load /usr/lib64/xorg/modules/libglamoregl.so: /usr/lib64/xorg/modules/libglamoregl.so: undefined symbol: _glapi_tls_Context
    16.812] (II) UnloadModule: "glamoregl"
    16.812] (II) Unloading glamoregl
    16.812] (EE) Failed to load module "glamoregl" (loader failed, 7)
    16.812] (II) LoadModule: "glx"
    16.813] (II) Loading /usr/lib64/xorg/modules/updates/extensions/libglx.so
    16.817] (II) Module glx: vendor="Advanced Micro Devices, Inc."
    16.817] 	compiled for 6.9.0, module version = 1.0.0
    16.817] Loading extension GLX
    16.817] (II) LoadModule: "vboxvideo"
    16.862] (WW) Warning, couldn't open module vboxvideo
    16.863] (II) UnloadModule: "vboxvideo"
    16.863] (II) Unloading vboxvideo
    16.863] (EE) Failed to load module "vboxvideo" (module does not exist, 0)
    16.863] (II) LoadModule: "vmware"
    16.864] (WW) Warning, couldn't open module vmware
    16.864] (II) UnloadModule: "vmware"
    16.864] (II) Unloading vmware
    16.864] (EE) Failed to load module "vmware" (module does not exist, 0)
    16.864] (II) LoadModule: "modesetting"
    16.867] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
    16.878] (II) Module modesetting: vendor="X.Org Foundation"
    16.878] 	compiled for 1.14.3, module version = 0.8.0
    16.878] 	Module class: X.Org Video Driver
    16.878] 	ABI class: X.Org Video Driver, version 14.1
    16.878] (II) LoadModule: "fbdev"
    16.878] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
    16.879] (II) Module fbdev: vendor="X.Org Foundation"
    16.879] 	compiled for 1.14.3, module version = 0.4.3
    16.879] 	Module class: X.Org Video Driver
    16.879] 	ABI class: X.Org Video Driver, version 14.1
    16.879] (II) LoadModule: "vesa"
    16.880] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
    16.880] (II) Module vesa: vendor="X.Org Foundation"
    16.880] 	compiled for 1.14.3, module version = 2.3.3
    16.880] 	Module class: X.Org Video Driver
    16.881] 	ABI class: X.Org Video Driver, version 14.1
    16.881] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
    16.881] (II) FBDEV: driver for framebuffer: fbdev
    16.881] (II) VESA: driver for VESA chipsets: vesa
    16.881] (++) using VT number 7
    16.883] (EE) open /dev/dri/card0: No such file or directory
    16.883] (WW) Falling back to old probe method for modesetting
    16.883] (II) Loading sub module "fbdevhw"
    16.883] (II) LoadModule: "fbdevhw"
    16.883] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
    16.885] (II) Module fbdevhw: vendor="X.Org Foundation"
    16.885] 	compiled for 1.14.3.901, module version = 0.0.2
    16.885] 	ABI class: X.Org Video Driver, version 14.1
    16.885] (**) FBDEV(1): claimed PCI slot 1@0:0:0
    16.885] (II) FBDEV(1): using default device
    16.885] (WW) Falling back to old probe method for vesa
    16.885] (EE) Screen 0 deleted because of no matching config section.
    16.885] (II) UnloadModule: "modesetting"
    16.886] (II) FBDEV(0): Creating default Display subsection in Screen section
	"fbdev" for depth/fbbpp 24/32
    16.886] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
    16.886] (==) FBDEV(0): RGB weight 888
    16.886] (==) FBDEV(0): Default visual is TrueColor
    16.886] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
    16.886] (II) FBDEV(0): hardware: VESA VGA (video memory: 3904kB)
    16.886] (II) FBDEV(0): checking modes against framebuffer device...
    16.886] (II) FBDEV(0): checking modes against monitor...
    16.886] (--) FBDEV(0): Virtual size is 1152x864 (pitch 1152)
    16.886] (**) FBDEV(0):  Built-in mode "current": 99.5 MHz, 67.6 kHz, 76.2 Hz
    16.886] (II) FBDEV(0): Modeline "current"x0.0   99.54  1152 1184 1328 1472  864 868 872 888 -hsync -vsync -csync (67.6 kHz b)
    16.886] (==) FBDEV(0): DPI set to (96, 96)
    16.886] (II) Loading sub module "fb"
    16.886] (II) LoadModule: "fb"
    16.886] (II) Loading /usr/lib64/xorg/modules/libfb.so
    16.887] (II) Module fb: vendor="X.Org Foundation"
    16.887] 	compiled for 1.14.3.901, module version = 1.0.0
    16.887] 	ABI class: X.Org ANSI C Emulation, version 0.4
    16.887] (**) FBDEV(0): using shadow framebuffer
    16.887] (II) Loading sub module "shadow"
    16.887] (II) LoadModule: "shadow"
    16.888] (II) Loading /usr/lib64/xorg/modules/libshadow.so
    16.913] (II) Module shadow: vendor="X.Org Foundation"
    16.913] 	compiled for 1.14.3.901, module version = 1.1.0
    16.913] 	ABI class: X.Org ANSI C Emulation, version 0.4
    16.913] (II) UnloadModule: "vesa"
    16.913] (II) Unloading vesa
    16.913] (==) Depth 24 pixmap format is 32 bpp
    16.913] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by vesafb of Linux Kernel)
    16.913] (==) FBDEV(0): Backing store disabled
    16.913] (==) FBDEV(0): DPMS enabled
    16.913] (==) RandR enabled
    16.920] (EE) GLX error: Can not get required symbols.
    17.370] (II) config/udev: Adding input device Power Button (/dev/input/event3)
    17.370] (**) Power Button: Applying InputClass "evdev keyboard catchall"
    17.370] (**) Power Button: Applying InputClass "LocalKeyboard"
    17.370] (II) LoadModule: "evdev"
    17.370] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
    17.388] (II) Module evdev: vendor="X.Org Foundation"
    17.388] 	compiled for 1.14.3, module version = 2.8.2
    17.388] 	Module class: X.Org XInput Driver
    17.388] 	ABI class: X.Org XInput driver, version 19.1
    17.388] (II) Using input driver 'evdev' for 'Power Button'
    17.388] (**) Power Button: always reports core events
    17.388] (**) evdev: Power Button: Device: "/dev/input/event3"
    17.388] (--) evdev: Power Button: Vendor 0 Product 0x1
    17.388] (--) evdev: Power Button: Found keys
    17.388] (II) evdev: Power Button: Configuring as keyboard
    17.388] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
    17.388] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
    17.388] (**) Option "xkb_rules" "evdev"
    17.388] (**) Option "xkb_model" "pc104"
    17.388] (**) Option "xkb_layout" "us"
    17.433] (II) config/udev: Adding input device Power Button (/dev/input/event2)
    17.433] (**) Power Button: Applying InputClass "evdev keyboard catchall"
    17.433] (**) Power Button: Applying InputClass "LocalKeyboard"
    17.433] (II) Using input driver 'evdev' for 'Power Button'
    17.433] (**) Power Button: always reports core events
    17.433] (**) evdev: Power Button: Device: "/dev/input/event2"
    17.433] (--) evdev: Power Button: Vendor 0 Product 0x1
    17.433] (--) evdev: Power Button: Found keys
    17.433] (II) evdev: Power Button: Configuring as keyboard
    17.433] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input2/event2"
    17.433] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
    17.433] (**) Option "xkb_rules" "evdev"
    17.433] (**) Option "xkb_model" "pc104"
    17.433] (**) Option "xkb_layout" "us"
    17.433] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event14)
    17.433] (II) No input driver specified, ignoring this device.
    17.434] (II) This device may have been added with another device file.
    17.434] (II) config/udev: Adding input device Lenovo Optical USB Mouse (/dev/input/event1)
    17.434] (**) Lenovo Optical USB Mouse: Applying InputClass "evdev pointer catchall"
    17.434] (II) Using input driver 'evdev' for 'Lenovo Optical USB Mouse'
    17.434] (**) Lenovo Optical USB Mouse: always reports core events
    17.434] (**) evdev: Lenovo Optical USB Mouse: Device: "/dev/input/event1"
    17.434] (--) evdev: Lenovo Optical USB Mouse: Vendor 0x17ef Product 0x6019
    17.434] (--) evdev: Lenovo Optical USB Mouse: Found 3 mouse buttons
    17.434] (--) evdev: Lenovo Optical USB Mouse: Found scroll wheel(s)
    17.434] (--) evdev: Lenovo Optical USB Mouse: Found relative axes
    17.434] (--) evdev: Lenovo Optical USB Mouse: Found x and y relative axes
    17.434] (II) evdev: Lenovo Optical USB Mouse: Configuring as mouse
    17.434] (II) evdev: Lenovo Optical USB Mouse: Adding scrollwheel support
    17.434] (**) evdev: Lenovo Optical USB Mouse: YAxisMapping: buttons 4 and 5
    17.434] (**) evdev: Lenovo Optical USB Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
    17.434] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.0/input/input1/event1"
    17.434] (II) XINPUT: Adding extended input device "Lenovo Optical USB Mouse" (type: MOUSE, id 8)
    17.434] (II) evdev: Lenovo Optical USB Mouse: initialized for relative axes.
    17.435] (**) Lenovo Optical USB Mouse: (accel) keeping acceleration scheme 1
    17.435] (**) Lenovo Optical USB Mouse: (accel) acceleration profile 0
    17.435] (**) Lenovo Optical USB Mouse: (accel) acceleration factor: 2.000
    17.435] (**) Lenovo Optical USB Mouse: (accel) acceleration threshold: 4
    17.435] (II) config/udev: Adding input device Lenovo Optical USB Mouse (/dev/input/mouse0)
    17.435] (II) No input driver specified, ignoring this device.
    17.435] (II) This device may have been added with another device file.
    17.435] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event5)
    17.436] (II) config/udev: Adding input device HDA ATI SB Speaker Front (/dev/input/event10)
    17.436] (II) No input driver specified, ignoring this device.
    17.436] (II) This device may have been added with another device file.
    17.436] (II) config/udev: Adding input device HDA ATI SB Line (/dev/input/event11)
    17.436] (II) config/udev: Adding input device HDA ATI SB Rear Mic (/dev/input/event12)
    17.437] (II) config/udev: Adding input device HDA ATI SB Front Mic (/dev/input/event13)
    17.437] (II) No input driver specified, ignoring this device.
    17.437] (II) This device may have been added with another device file.
    17.437] (II) config/udev: Adding input device HDA ATI SB Front Headphone (/dev/input/event6)
    17.437] (II) config/udev: Adding input device HDA ATI SB Speaker Side (/dev/input/event7)
    17.437] (II) config/udev: Adding input device HDA ATI SB Speaker CLFE (/dev/input/event8)
    17.438] (II) No input driver specified, ignoring this device.
    17.438] (II) This device may have been added with another device file.
    17.438] (II) config/udev: Adding input device HDA ATI SB Speaker Surround (/dev/input/event9)
    17.438] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
    17.438] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
    17.438] (**) AT Translated Set 2 keyboard: Applying InputClass "LocalKeyboard"
    17.438] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
    17.438] (**) AT Translated Set 2 keyboard: always reports core events
    17.438] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
    17.438] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
    17.438] (--) evdev: AT Translated Set 2 keyboard: Found keys
    17.438] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
    17.438] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
    17.438] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 9)
    17.438] (**) Option "xkb_rules" "evdev"
    17.438] (**) Option "xkb_model" "pc104"
    17.438] (**) Option "xkb_layout" "us"
    17.439] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
    17.439] (II) No input driver specified, ignoring this device.
    17.439] (II) This device may have been added with another device file.
    17.446] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by vesafb of Linux Kernel)
    32.649] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by vesafb of Linux Kernel)
    32.733] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by vesafb of Linux Kernel)
