我下了个 aptana studio3,可是每次都是运行不了几分钟就崩溃,有时候刚打开就崩溃。刚开始提示是 java 的原因,于是就换了 oracle-java, 修改了环境变量,但问题依旧,在网上搜了下,有不少人也有同样的问题,试了下他们的解决方法还是不行。
我是从终端启动的,崩溃后有如下输出:
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007ff7bb7a1d39, pid=1811, tid=140703613646592
# JRE version: 7.0_25-b15
# Java VM: Java HotSpot(TM) 64-Bit Server VM (23.25-b01 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C [libsoup-2.4.so.1+0x72d39] soup_session_feature_detach+0x19
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/gmg/hs_err_pid1811.log
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
另外还有一个日志文件,内容如下:
--------------- T H R E A D ---------------
Current thread (0x00007ff814007000): JavaThread "main" [_thread_in_native, id=1812, stack(0x00007ff81cd8f000,0x00007ff81ce90000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0x0000000000000000
Registers:
RAX=0x00007ff815654210, RBX=0x0000000000000000, RCX=0x00007ff815349690, RDX=0x0000000000000000
RSP=0x00007ff81ce8d610, RBP=0x00007ff815349690, RSI=0x00007ff815349690, RDI=0x0000000000000000
R8 =0x00007ff81c277760, R9 =0x0000000000000002, R10=0x00007ff81ce8d3d0, R11=0x00007ff7bb7a1d20
R12=0x0000000000000000, R13=0x00000000d452b098, R14=0x00007ff81ce8d6d8, R15=0x00007ff814007000
RIP=0x00007ff7bb7a1d39, EFLAGS=0x0000000000010202, CSGSFS=0x0000000000000033, ERR=0x0000000000000004
TRAPNO=0x000000000000000e
Top of Stack: (sp=0x00007ff81ce8d610)
0x00007ff81ce8d610: 0000000000000002 00000000d452b098
0x00007ff81ce8d620: 00007ff81ce8d6a0 00007ff7bd898ea5
0x00007ff81ce8d630: 0000000000000000 00007ff811011f90
0x00007ff81ce8d640: 00007ff814007000 0000000000000000
0x00007ff81ce8d650: 00007ff814007000 00000000d452ac60
0x00007ff81ce8d660: 00007ff81ce8d660 00000000d452b098
0x00007ff81ce8d670: 00007ff81ce8d6d8 00000000d45318a0
0x00007ff81ce8d680: 0000000000000000 00000000d452b098
0x00007ff81ce8d690: 0000000000000000 00007ff81ce8d6c0
0x00007ff81ce8d6a0: 00007ff81ce8d720 00007ff811006158
0x00007ff81ce8d6b0: 00000000f62961d8 00007ff81100edd8
0x00007ff81ce8d6c0: 00007ff815349690 00007ff8110062d4
0x00007ff81ce8d6d0: 0000000000000000 0000000000000001
0x00007ff81ce8d6e0: 00007ff81ce8d6e0 00000000d452b1a1
0x00007ff81ce8d6f0: 00007ff81ce8d750 00000000d45318a0
0x00007ff81ce8d700: 0000000000000000 00000000d452b1e0
0x00007ff81ce8d710: 00007ff81ce8d6c0 00007ff81ce8d738
0x00007ff81ce8d720: 00007ff81ce8d798 00007ff811006158
0x00007ff81ce8d730: 0000000000000000 00007ff815349690
0x00007ff81ce8d740: 0000000000000000 0000000000000000
0x00007ff81ce8d750: 0000000000000000 00007ff81ce8d758
0x00007ff81ce8d760: 00000000d4514e7e 00007ff81ce8d820
0x00007ff81ce8d770: 00000000d451d088 0000000000000000
0x00007ff81ce8d780: 00000000d45150a0 00007ff81ce8d738
0x00007ff81ce8d790: 00007ff81ce8d810 00007ff81ce8d868
0x00007ff81ce8d7a0: 00007ff811006158 0000000000000000
0x00007ff81ce8d7b0: 0000000000000000 0000000000000000
0x00007ff81ce8d7c0: 0000000000000000 0000000000000000
0x00007ff81ce8d7d0: 0000000000000000 0000000000000000
0x00007ff81ce8d7e0: 00007ff815349690 0000000000000000
0x00007ff81ce8d7f0: 00000000f62e9da0 00000000f62e8410
0x00007ff81ce8d800: 00007ff7d447ee60 00000000f62e7e80
Instructions: (pc=0x00007ff7bb7a1d39)
0x00007ff7bb7a1d19: 83 c4 18 ff e0 66 90 48 89 5c 24 f0 48 89 6c 24
0x00007ff7bb7a1d29: f8 48 89 fb 48 83 ec 18 48 89 f5 e8 57 aa fc ff
0x00007ff7bb7a1d39: 48 8b 3b 48 89 c6 e8 2c 7b fc ff 48 89 ee 48 8b
0x00007ff7bb7a1d49: 40 18 48 89 df 48 8b 6c 24 10 48 8b 5c 24 08 48
Register to memory mapping:
RAX=0x00007ff815654210 is an unknown value
RBX=0x0000000000000000 is an unknown value
RCX=0x00007ff815349690 is an unknown value
RDX=0x0000000000000000 is an unknown value
RSP=0x00007ff81ce8d610 is pointing into the stack for thread: 0x00007ff814007000
RBP=0x00007ff815349690 is an unknown value
RSI=0x00007ff815349690 is an unknown value
RDI=0x0000000000000000 is an unknown value
R8 =0x00007ff81c277760: <offset 0xcef760> in /usr/java/jdk1.7.0_25/jre/lib/amd64/server/libjvm.so at 0x00007ff81b588000
R9 =0x0000000000000002 is an unknown value
R10=0x00007ff81ce8d3d0 is pointing into the stack for thread: 0x00007ff814007000
R11=0x00007ff7bb7a1d20: soup_session_feature_detach+0 in /usr/lib64/libsoup-2.4.so.1 at 0x00007ff7bb72f000
R12=0x0000000000000000 is an unknown value
R13=0x00000000d452b098 is an oop
{method}
- klass: {other class}
R14=0x00007ff81ce8d6d8 is pointing into the stack for thread: 0x00007ff814007000
R15=0x00007ff814007000 is a thread
Stack: [0x00007ff81cd8f000,0x00007ff81ce90000], sp=0x00007ff81ce8d610, free space=1017k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.eclipse.swt.internal.webkit.WebKitGTK._soup_session_feature_detach(JJ)V+0
j org.eclipse.swt.internal.webkit.WebKitGTK.soup_session_feature_detach(JJ)V+9
j org.eclipse.swt.browser.WebKit.create(Lorg/eclipse/swt/widgets/Composite;I)V+830
j org.eclipse.swt.browser.Browser.<init>(Lorg/eclipse/swt/widgets/Composite;I)V+81
j com.aptana.editor.common.hover.CustomBrowserInformationControl.isAvailable(Lorg/eclipse/swt/widgets/Composite;)Z+12
j com.aptana.editor.common.hover.AbstractDocumentationHover$1.run()V+17
j org.eclipse.swt.widgets.RunnableLock.run()V+11
j org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Z)Z+29
J org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widgets/Display;)V
j org.eclipse.ui.internal.Workbench.runUI()I+555
j org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
j org.eclipse.ui.internal.Workbench$7.run()V+73
j org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/Runnable;)V+12
j org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
j org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+2
j com.aptana.rcp.IDEApplication.start(Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Object;+137
j org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Object;+135
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Ljava/lang/Object;+29
j org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object;+149
j org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
v ~StubRoutines::call_stub
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+87
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+57
j org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+211
j org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+126
j org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
j org.eclipse.equinox.launcher.Main.main([Ljava/lang/String;)V+10
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x00007ff81555d800 JavaThread "Text Viewer Hover Presenter" daemon [_thread_blocked, id=2044, stack(0x00007ff7bdb9d000,0x00007ff7bdc9e000)]
0x00007ff7f854a800 JavaThread "PHP Debugger Daemon Thread - Port: 9000" daemon [_thread_in_native, id=1953, stack(0x00007ff7bdc9e000,0x00007ff7bdd9f000)]
0x00007ff7f8116800 JavaThread "PHP Debugger Daemon Thread - Port: 10000" daemon [_thread_in_native, id=1952, stack(0x00007ff7bdd9f000,0x00007ff7bdea0000)]
0x00007ff814f01000 JavaThread "Thread-23" [_thread_blocked, id=1951, stack(0x00007ff7bdea0000,0x00007ff7bdfa1000)]
0x00007ff814efe800 JavaThread "Thread-22" [_thread_blocked, id=1950, stack(0x00007ff7be477000,0x00007ff7be578000)]
0x00007ff815493800 JavaThread "com.aptana.editor.common.text.reconciler.CommonReconciler" daemon [_thread_blocked, id=1948, stack(0x00007ff7be77a000,0x00007ff7be87b000)]
0x00007ff7f8986000 JavaThread "PHPGlobalIndexer saver" daemon [_thread_blocked, id=1947, stack(0x00007ff7be34e000,0x00007ff7be44f000)]
0x00007ff7f81f7800 JavaThread "MultiThreadedHttpConnectionManager cleanup" daemon [_thread_blocked, id=1909, stack(0x00007ff7be24d000,0x00007ff7be34e000)]
0x00007ff7f8780800 JavaThread "Provisioning Event Dispatcher" daemon [_thread_blocked, id=1908, stack(0x00007ff7be578000,0x00007ff7be679000)]
0x00007ff80402b000 JavaThread "Worker-12" [_thread_blocked, id=1896, stack(0x00007ff7be679000,0x00007ff7be77a000)]
0x00007ff7c8041000 JavaThread "pool-1-thread-3" [_thread_blocked, id=1886, stack(0x00007ff7be87b000,0x00007ff7be97c000)]
0x00007ff7c8040000 JavaThread "pool-1-thread-2" [_thread_blocked, id=1884, stack(0x00007ff7bee6d000,0x00007ff7bef6e000)]
0x00007ff7c8048000 JavaThread "pool-1-thread-1" [_thread_blocked, id=1883, stack(0x00007ff7bef6e000,0x00007ff7bf06f000)]
0x00007ff814dbf800 JavaThread "CommandLineArgsServer" [_thread_in_native, id=1877, stack(0x00007ff7bf06f000,0x00007ff7bf170000)]
0x00007ff7c800c800 JavaThread "Worker-11" [_thread_blocked, id=1876, stack(0x00007ff7bf170000,0x00007ff7bf271000)]
0x00007ff7e400a800 JavaThread "Worker-10" [_thread_blocked, id=1875, stack(0x00007ff7bf271000,0x00007ff7bf372000)]
0x00007ff7f011c800 JavaThread "Worker-9" [_thread_blocked, id=1874, stack(0x00007ff7bf372000,0x00007ff7bf473000)]
0x00007ff804024800 JavaThread "Worker-8" [_thread_blocked, id=1873, stack(0x00007ff7bf473000,0x00007ff7bf574000)]
0x00007ff80c030800 JavaThread "Worker-7" [_thread_blocked, id=1872, stack(0x00007ff7bf574000,0x00007ff7bf675000)]
0x00007ff7f4004800 JavaThread "Worker-6" [_thread_blocked, id=1871, stack(0x00007ff7bf675000,0x00007ff7bf776000)]
0x00007ff7ec663800 JavaThread "Worker-5" [_thread_blocked, id=1870, stack(0x00007ff7cdb4f000,0x00007ff7cdc50000)]
0x00007ff7f4003800 JavaThread "Worker-4" [_thread_blocked, id=1869, stack(0x00007ff7ce36d000,0x00007ff7ce46e000)]
0x00007ff7f89a3000 JavaThread "INotify thread" daemon [_thread_in_native, id=1860, stack(0x00007ff7cda4e000,0x00007ff7cdb4f000)]
0x00007ff7f833c800 JavaThread "Worker-3" [_thread_blocked, id=1839, stack(0x00007ff7ce06a000,0x00007ff7ce16b000)]
0x00007ff7ec3fa800 JavaThread "Worker-2" [_thread_blocked, id=1838, stack(0x00007ff7ce16b000,0x00007ff7ce26c000)]
0x00007ff7d8005800 JavaThread "Worker-1" [_thread_blocked, id=1837, stack(0x00007ff7ce26c000,0x00007ff7ce36d000)]
0x00007ff814891800 JavaThread "Worker-0" [_thread_blocked, id=1835, stack(0x00007ff7ce46e000,0x00007ff7ce56f000)]
0x00007ff7d409b800 JavaThread "[ThreadPool Manager] - Idle Thread" daemon [_thread_blocked, id=1831, stack(0x00007ff7de4c1000,0x00007ff7de5c2000)]
0x00007ff7d409f000 JavaThread "Worker-JM" [_thread_blocked, id=1830, stack(0x00007ff7de2bf000,0x00007ff7de3c0000)]
0x000000000149f800 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=1829, stack(0x00007ff7de3c0000,0x00007ff7de4c1000)]
0x00007ff7d4012000 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=1827, stack(0x00007ff7de5c2000,0x00007ff7de6c3000)]
0x00007ff8144b5000 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=1826, stack(0x00007ff7de6c3000,0x00007ff7de7c4000)]
0x00007ff8146a5800 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=1825, stack(0x00007ff7de7c4000,0x00007ff7de8c5000)]
0x00007ff814435800 JavaThread "Framework Active Thread" [_thread_blocked, id=1824, stack(0x00007ff7de9ed000,0x00007ff7deaee000)]
0x00007ff814175000 JavaThread "Service Thread" daemon [_thread_blocked, id=1821, stack(0x00007ff810352000,0x00007ff810453000)]
0x00007ff814172800 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=1820, stack(0x00007ff810453000,0x00007ff810554000)]
0x00007ff81416f800 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=1819, stack(0x00007ff810554000,0x00007ff810655000)]
0x00007ff81416d800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1818, stack(0x00007ff810655000,0x00007ff810756000)]
0x00007ff81411d800 JavaThread "Finalizer" daemon [_thread_blocked, id=1817, stack(0x00007ff8108f9000,0x00007ff8109fa000)]
0x00007ff81411b000 JavaThread "Reference Handler" daemon [_thread_blocked, id=1816, stack(0x00007ff8109fa000,0x00007ff810afb000)]
=>0x00007ff814007000 JavaThread "main" [_thread_in_native, id=1812, stack(0x00007ff81cd8f000,0x00007ff81ce90000)]
Other Threads:
0x00007ff814113800 VMThread [stack: 0x00007ff810afb000,0x00007ff810bfc000] [id=1815]
0x00007ff81417f800 WatcherThread [stack: 0x00007ff810251000,0x00007ff810352000] [id=1822]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 130880K, used 14143K [0x00000000f5560000, 0x0000000100000000, 0x0000000100000000)
eden space 111360K, 12% used [0x00000000f5560000,0x00000000f632fe00,0x00000000fc220000)
from space 19520K, 0% used [0x00000000fc220000,0x00000000fc220000,0x00000000fd530000)
to space 31872K, 0% used [0x00000000fe0e0000,0x00000000fe0e0000,0x0000000100000000)
ParOldGen total 188736K, used 144769K [0x00000000e0000000, 0x00000000eb850000, 0x00000000f5560000)
object space 188736K, 76% used [0x00000000e0000000,0x00000000e8d605e8,0x00000000eb850000)
PSPermGen total 103744K, used 71057K [0x00000000d0000000, 0x00000000d6550000, 0x00000000e0000000)
object space 103744K, 68% used [0x00000000d0000000,0x00000000d4564430,0x00000000d6550000)
Card table byte_map: [0x00007ff81a7ed000,0x00007ff81a96e000] byte_map_base: 0x00007ff81a16d000
Polling page: 0x00007ff81ceab000
Code Cache [0x00007ff811000000, 0x00007ff8114a0000, 0x00007ff814000000)
total_blobs=2001 nmethods=1375 adapters=577 free_code_cache=44494Kb largest_free_block=45484800
Compilation events (10 events):
Event: 237.317 Thread 0x00007ff81416f800 1465 org.eclipse.core.internal.resources.Resource::getResourceInfo (14 bytes)
Event: 237.327 Thread 0x00007ff81416f800 nmethod 1465 0x00007ff811490b10 code [0x00007ff811490cc0, 0x00007ff811491368]
Event: 242.137 Thread 0x00007ff814172800 1466 com.aptana.editor.php.internal.parser.HeredocRule::evaluate (68 bytes)
Event: 242.141 Thread 0x00007ff81416f800 1467 com.aptana.editor.php.internal.parser.HeredocRule::startsWith (101 bytes)
Event: 242.150 Thread 0x00007ff81416f800 nmethod 1467 0x00007ff81148fd10 code [0x00007ff81148ff00, 0x00007ff811490490]
Event: 242.154 Thread 0x00007ff814172800 nmethod 1466 0x00007ff811492450 code [0x00007ff811492660, 0x00007ff811492d80]
Event: 242.820 Thread 0x00007ff81416f800 1468 org.eclipse.jface.text.rules.PatternRule::doEvaluate (70 bytes)
Event: 242.822 Thread 0x00007ff814172800 1469 org.eclipse.jface.text.AbstractDocument::getChar (31 bytes)
Event: 242.825 Thread 0x00007ff81416f800 nmethod 1468 0x00007ff811402510 code [0x00007ff811402680, 0x00007ff811402828]
Event: 242.828 Thread 0x00007ff814172800 nmethod 1469 0x00007ff81148d410 code [0x00007ff81148d5e0, 0x00007ff81148d9d8]
GC Heap History (10 events):
Event: 114.947 GC heap before
{Heap before GC invocations=36 (full 6):
PSYoungGen total 137344K, used 137309K [0x00000000f5560000, 0x0000000100000000, 0x0000000100000000)
eden space 119424K, 100% used [0x00000000f5560000,0x00000000fca00000,0x00000000fca00000)
from space 17920K, 99% used [0x00000000fca00000,0x00000000fdb77560,0x00000000fdb80000)
to space 28224K, 0% used [0x00000000fe470000,0x00000000fe470000,0x0000000100000000)
ParOldGen total 188736K, used 126083K [0x00000000e0000000, 0x00000000eb850000, 0x00000000f5560000)
object space 188736K, 66% used [0x00000000e0000000,0x00000000e7b20c78,0x00000000eb850000)
PSPermGen total 93376K, used 68009K [0x00000000d0000000, 0x00000000d5b30000, 0x00000000e0000000)
object space 93376K, 72% used [0x00000000d0000000,0x00000000d426a6c8,0x00000000d5b30000)
Event: 115.000 GC heap after
Heap after GC invocations=36 (full 6):
PSYoungGen total 144576K, used 18764K [0x00000000f5560000, 0x0000000100000000, 0x0000000100000000)
eden space 116352K, 0% used [0x00000000f5560000,0x00000000f5560000,0x00000000fc700000)
from space 28224K, 66% used [0x00000000fe470000,0x00000000ff6c3390,0x0000000100000000)
to space 29184K, 0% used [0x00000000fc700000,0x00000000fc700000,0x00000000fe380000)
Event: 115.454 GC heap before
{Heap before GC invocations=37 (full 6):
PSYoungGen total 144576K, used 135116K [0x00000000f5560000, 0x0000000100000000, 0x0000000100000000)
eden space 116352K, 100% used [0x00000000f5560000,0x00000000fc700000,0x00000000fc700000)
PSPermGen total 93376K, used 68019K [0x00000000d0000000, 0x00000000d5b30000, 0x00000000e0000000)
object space 93376K, 72% used [0x00000000d0000000,0x00000000d426cc78,0x00000000d5b30000)
Event: 115.501 GC heap after
Heap after GC invocations=37 (full 6):
PSYoungGen total 136128K, used 19728K [0x00000000f5560000, 0x0000000100000000, 0x0000000100000000)
from space 19776K, 99% used [0x00000000fc700000,0x00000000fda44120,0x00000000fda50000)
to space 30208K, 0% used [0x00000000fe280000,0x00000000fe280000,0x0000000100000000)
Event: 192.036 GC heap before
{Heap before GC invocations=38 (full 6):
PSYoungGen total 136128K, used 136080K [0x00000000f5560000, 0x0000000100000000, 0x0000000100000000)
PSPermGen total 93376K, used 70498K [0x00000000d0000000, 0x00000000d5b30000, 0x00000000e0000000)
object space 93376K, 75% used [0x00000000d0000000,0x00000000d44d8b20,0x00000000d5b30000)
Event: 192.091 GC heap after
Heap after GC invocations=38 (full 6):
PSYoungGen total 141568K, used 21739K [0x00000000f5560000, 0x0000000100000000, 0x0000000100000000)
eden space 111360K, 0% used [0x00000000f5560000,0x00000000f5560000,0x00000000fc220000)
from space 30208K, 71% used [0x00000000fe280000,0x00000000ff7bac28,0x0000000100000000)
to space 31680K, 0% used [0x00000000fc220000,0x00000000fc220000,0x00000000fe110000)
ParOldGen total 188736K, used 126091K [0x00000000e0000000, 0x00000000eb850000, 0x00000000f5560000)
object space 188736K, 66% used [0x00000000e0000000,0x00000000e7b22c78,0x00000000eb850000)
Event: 222.725 GC heap before
{Heap before GC invocations=39 (full 6):
PSYoungGen total 141568K, used 55296K [0x00000000f5560000, 0x0000000100000000, 0x0000000100000000)
eden space 111360K, 30% used [0x00000000f5560000,0x00000000f7625748,0x00000000fc220000)
PSPermGen total 93376K, used 70532K [0x00000000d0000000, 0x00000000d5b30000, 0x00000000e0000000)
object space 93376K, 75% used [0x00000000d0000000,0x00000000d44e1048,0x00000000d5b30000)
Event: 222.773 GC heap after
Heap after GC invocations=39 (full 6):
PSYoungGen total 130880K, used 19460K [0x00000000f5560000, 0x0000000100000000, 0x0000000100000000)
from space 19520K, 99% used [0x00000000fc220000,0x00000000fd521398,0x00000000fd530000)
Event: 222.773 GC heap before
{Heap before GC invocations=40 (full 7):
Event: 223.303 GC heap after
Heap after GC invocations=40 (full 7):
PSYoungGen total 130880K, used 0K [0x00000000f5560000, 0x0000000100000000, 0x0000000100000000)
PSPermGen total 103744K, used 70527K [0x00000000d0000000, 0x00000000d6550000, 0x00000000e0000000)
object space 103744K, 67% used [0x00000000d0000000,0x00000000d44dfcd0,0x00000000d6550000)
Deoptimization events (10 events):
Event: 156.491 Thread 0x00007ff815493800 Uncommon trap -34 fr.pc 0x00007ff811243968
Event: 156.491 Thread 0x00007ff815493800 Uncommon trap -34 fr.pc 0x00007ff8113e176c
Event: 157.994 Thread 0x00007ff815493800 Uncommon trap -58 fr.pc 0x00007ff8112bcd60
Event: 162.000 Thread 0x00007ff815493800 Uncommon trap -34 fr.pc 0x00007ff811098dec
Event: 162.001 Thread 0x00007ff815493800 Uncommon trap -58 fr.pc 0x00007ff8112bcd60
Event: 176.279 Thread 0x00007ff814007000 Uncommon trap -34 fr.pc 0x00007ff81140c598
Event: 176.283 Thread 0x00007ff814007000 Uncommon trap -83 fr.pc 0x00007ff8113d00bc
Event: 179.347 Thread 0x00007ff814007000 Uncommon trap -34 fr.pc 0x00007ff81140c598
Event: 180.286 Thread 0x00007ff814007000 Uncommon trap -34 fr.pc 0x00007ff81140c598
Event: 180.802 Thread 0x00007ff814007000 Uncommon trap -34 fr.pc 0x00007ff81140c598
Internal exceptions (10 events):
Event: 111.046 Thread 0x00007ff814007000 Threw 0x00000000f67deda8 at /HUDSON/workspace/jdk7u25-2-build-linux-amd64-product/jdk7u25/hotspot/src/share/vm/prims/jni.cpp:716
Event: 111.724 Thread 0x00007ff80402b000 Implicit null exception at 0x00007ff8113845f8 to 0x00007ff811384f8d
Event: 111.953 Thread 0x00007ff7ec3fa800 Threw 0x00000000f7976bf8 at /HUDSON/workspace/jdk7u25-2-build-linux-amd64-product/jdk7u25/hotspot/src/share/vm/prims/jni.cpp:716
Event: 111.968 Thread 0x00007ff7ec3fa800 Threw 0x00000000f798c660 at /HUDSON/workspace/jdk7u25-2-build-linux-amd64-product/jdk7u25/hotspot/src/share/vm/prims/jni.cpp:716
Event: 113.079 Thread 0x00007ff7c800c800 Implicit null exception at 0x00007ff81134cf9c to 0x00007ff81134d949
Event: 136.661 Thread 0x00007ff814007000 Threw 0x00000000f80dca80 at /HUDSON/workspace/jdk7u25-2-build-linux-amd64-product/jdk7u25/hotspot/src/share/vm/prims/jni.cpp:716
Event: 263.276 Thread 0x00007ff814007000 Threw 0x00000000f6278798 at /HUDSON/workspace/jdk7u25-2-build-linux-amd64-product/jdk7u25/hotspot/src/share/vm/prims/jvm.cpp:3718
Event: 263.276 Thread 0x00007ff814007000 Threw 0x00000000f6278798 at /HUDSON/workspace/jdk7u25-2-build-linux-amd64-product/jdk7u25/hotspot/src/share/vm/prims/jni.cpp:716
Event: 263.287 Thread 0x00007ff814007000 Threw 0x00000000f627d9c0 at /HUDSON/workspace/jdk7u25-2-build-linux-amd64-product/jdk7u25/hotspot/src/share/vm/prims/jvm.cpp:3718
Event: 263.287 Thread 0x00007ff814007000 Threw 0x00000000f627d9c0 at /HUDSON/workspace/jdk7u25-2-build-linux-amd64-product/jdk7u25/hotspot/src/share/vm/prims/jni.cpp:716
Events (10 events):
Event: 251.575 Thread 0x00007ff81555d800 Thread exited: 0x00007ff81555d800
Event: 262.967 Thread 0x00007ff81555d800 Thread added: 0x00007ff81555d800
Event: 262.972 Executing VM operation: Deoptimize
Event: 262.973 Executing VM operation: Deoptimize done
Event: 262.974 loading class 0x00007ff81551efd0
Event: 262.974 loading class 0x00007ff81551efd0 done
Event: 263.276 loading class 0x00007ff814084810
Event: 263.276 loading class 0x00007ff814084810 done
Event: 263.897 loading class 0x00007ff8156bed40
Event: 263.897 loading class 0x00007ff8156bed40 done
Dynamic libraries:
00400000-00401000 r-xp 00000000 00:13 355675 /usr/java/jdk1.7.0_25/bin/java
00600000-00601000 rw-p 00000000 00:13 355675 /usr/java/jdk1.7.0_25/bin/java
0149a000-0154b000 rw-p 00000000 00:00 0 [heap]
d0000000-d6550000 rw-p 00000000 00:00 0
d6550000-e0000000 rw-p 00000000 00:00 0
e0000000-eb850000 rw-p 00000000 00:00 0
eb850000-f5560000 rw-p 00000000 00:00 0
f5560000-100000000 rw-p 00000000 00:00 0
7ff7749d2000-7ff7749dd000 r-xp 00000000 00:13 312396 /usr/lib64/gio/modules/libdconfsettings.so
7ff7749dd000-7ff774bdc000 ---p 0000b000 00:13 312396 /usr/lib64/gio/modules/libdconfsettings.so
7ff774bdc000-7ff774bdd000 r--p 0000a000 00:13 312396 /usr/lib64/gio/modules/libdconfsettings.so
7ff774bdd000-7ff774bde000 rw-p 0000b000 00:13 312396 /usr/lib64/gio/modules/libdconfsettings.so
7ff774bde000-7ff774be1000 r-xp 00000000 00:13 257263 /usr/lib64/gio/modules/libgiognomeproxy.so
7ff774be1000-7ff774de1000 ---p 00003000 00:13 257263 /usr/lib64/gio/modules/libgiognomeproxy.so
7ff774de1000-7ff774de2000 r--p 00003000 00:13 257263 /usr/lib64/gio/modules/libgiognomeproxy.so
7ff774de2000-7ff774de3000 rw-p 00004000 00:13 257263 /usr/lib64/gio/modules/libgiognomeproxy.so
7ff774de3000-7ff774e33000 r-xp 00000000 00:13 31954 /usr/lib64/libhunspell-1.3.so.0.0.0
7ff774e33000-7ff775032000 ---p 00050000 00:13 31954 /usr/lib64/libhunspell-1.3.so.0.0.0
7ff775032000-7ff775033000 r--p 0004f000 00:13 31954 /usr/lib64/libhunspell-1.3.so.0.0.0
7ff775033000-7ff775037000 rw-p 00050000 00:13 31954 /usr/lib64/libhunspell-1.3.so.0.0.0
7ff775037000-7ff77503c000 r-xp 00000000 00:13 32150 /usr/lib64/enchant/libenchant_myspell.so
7ff77503c000-7ff77523b000 ---p 00005000 00:13 32150 /usr/lib64/enchant/libenchant_myspell.so
7ff77523b000-7ff77523c000 r--p 00004000 00:13 32150 /usr/lib64/enchant/libenchant_myspell.so
7ff77523c000-7ff77523d000 rw-p 00005000 00:13 32150 /usr/lib64/enchant/libenchant_myspell.so
7ff77523d000-7ff775249000 r-xp 00000000 00:13 32149 /usr/lib64/enchant/libenchant_ispell.so
7ff775249000-7ff775448000 ---p 0000c000 00:13 32149 /usr/lib64/enchant/libenchant_ispell.so
7ff775448000-7ff775449000 r--p 0000b000 00:13 32149 /usr/lib64/enchant/libenchant_ispell.so
7ff775449000-7ff77544a000 rw-p 0000c000 00:13 32149 /usr/lib64/enchant/libenchant_ispell.so
7ff77544a000-7ff775502000 r-xp 00000000 00:13 32674 /usr/lib64/libaspell.so.15.1.5
7ff775502000-7ff775701000 ---p 000b8000 00:13 32674 /usr/lib64/libaspell.so.15.1.5
7ff775701000-7ff775707000 r--p 000b7000 00:13 32674 /usr/lib64/libaspell.so.15.1.5
7ff775707000-7ff775709000 rw-p 000bd000 00:13 32674 /usr/lib64/libaspell.so.15.1.5
7ff775709000-7ff775710000 rw-p 00000000 00:00 0
7ff775710000-7ff775712000 r-xp 00000000 00:13 32148 /usr/lib64/enchant/libenchant_aspell.so
7ff775712000-7ff775911000 ---p 00002000 00:13 32148 /usr/lib64/enchant/libenchant_aspell.so
7ff775911000-7ff775912000 r--p 00001000 00:13 32148 /usr/lib64/enchant/libenchant_aspell.so
7ff775912000-7ff775913000 rw-p 00002000 00:13 32148 /usr/lib64/enchant/libenchant_aspell.so
7ff775913000-7ff7b5915000 ---p 00000000 00:00 0
7ff7b5915000-7ff7b5a15000 rw-p 00000000 00:00 0
7ff7b5a15000-7ff7b5a1c000 r-xp 00000000 00:24 1109382 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-xpcominit-gtk-3740.so
7ff7b5a1c000-7ff7b5b1c000 ---p 00007000 00:24 1109382 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-xpcominit-gtk-3740.so
7ff7b5b1c000-7ff7b5b1e000 rw-p 00007000 00:24 1109382 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-xpcominit-gtk-3740.so
7ff7b5b1e000-7ff7b5b22000 r-xp 00000000 00:13 22119 /usr/lib64/libuuid.so.1.3.0
7ff7b5b22000-7ff7b5d21000 ---p 00004000 00:13 22119 /usr/lib64/libuuid.so.1.3.0
7ff7b5d21000-7ff7b5d22000 r--p 00003000 00:13 22119 /usr/lib64/libuuid.so.1.3.0
7ff7b5d22000-7ff7b5d23000 rw-p 00004000 00:13 22119 /usr/lib64/libuuid.so.1.3.0
7ff7b5d23000-7ff7b5d26000 r-xp 00000000 00:13 22034 /usr/lib64/libgpg-error.so.0.8.0
7ff7b5d26000-7ff7b5f25000 ---p 00003000 00:13 22034 /usr/lib64/libgpg-error.so.0.8.0
7ff7b5f25000-7ff7b5f26000 r--p 00002000 00:13 22034 /usr/lib64/libgpg-error.so.0.8.0
7ff7b5f26000-7ff7b5f27000 rw-p 00003000 00:13 22034 /usr/lib64/libgpg-error.so.0.8.0
7ff7b5f27000-7ff7b5f3e000 r-xp 00000000 00:13 22440 /usr/lib64/libICE.so.6.3.0
7ff7b5f3e000-7ff7b613d000 ---p 00017000 00:13 22440 /usr/lib64/libICE.so.6.3.0
7ff7b613d000-7ff7b613e000 r--p 00016000 00:13 22440 /usr/lib64/libICE.so.6.3.0
7ff7b613e000-7ff7b613f000 rw-p 00017000 00:13 22440 /usr/lib64/libICE.so.6.3.0
7ff7b613f000-7ff7b6143000 rw-p 00000000 00:00 0
7ff7b6143000-7ff7b614a000 r-xp 00000000 00:13 22129 /usr/lib64/libSM.so.6.0.1
7ff7b614a000-7ff7b6349000 ---p 00007000 00:13 22129 /usr/lib64/libSM.so.6.0.1
7ff7b6349000-7ff7b634a000 r--p 00006000 00:13 22129 /usr/lib64/libSM.so.6.0.1
7ff7b634a000-7ff7b634b000 rw-p 00007000 00:13 22129 /usr/lib64/libSM.so.6.0.1
7ff7b634b000-7ff7b6350000 r-xp 00000000 00:13 179367 /usr/lib64/libgbm.so.1.0.0
7ff7b6350000-7ff7b654f000 ---p 00005000 00:13 179367 /usr/lib64/libgbm.so.1.0.0
7ff7b654f000-7ff7b6550000 r--p 00004000 00:13 179367 /usr/lib64/libgbm.so.1.0.0
7ff7b6550000-7ff7b6551000 rw-p 00005000 00:13 179367 /usr/lib64/libgbm.so.1.0.0
7ff7b6551000-7ff7b6556000 r-xp 00000000 00:13 178767 /usr/lib64/libxcb-xfixes.so.0.0.0
7ff7b6556000-7ff7b6756000 ---p 00005000 00:13 178767 /usr/lib64/libxcb-xfixes.so.0.0.0
7ff7b6756000-7ff7b6757000 r--p 00005000 00:13 178767 /usr/lib64/libxcb-xfixes.so.0.0.0
7ff7b6757000-7ff7b6758000 rw-p 00006000 00:13 178767 /usr/lib64/libxcb-xfixes.so.0.0.0
7ff7b6758000-7ff7b675c000 r-xp 00000000 00:13 178803 /usr/lib64/libxcb-dri2.so.0.0.0
7ff7b675c000-7ff7b695b000 ---p 00004000 00:13 178803 /usr/lib64/libxcb-dri2.so.0.0.0
7ff7b695b000-7ff7b695c000 r--p 00003000 00:13 178803 /usr/lib64/libxcb-dri2.so.0.0.0
7ff7b695c000-7ff7b695d000 rw-p 00004000 00:13 178803 /usr/lib64/libxcb-dri2.so.0.0.0
7ff7b695d000-7ff7b6968000 r-xp 00000000 00:13 22441 /usr/lib64/libdrm.so.2.4.0
7ff7b6968000-7ff7b6b67000 ---p 0000b000 00:13 22441 /usr/lib64/libdrm.so.2.4.0
7ff7b6b67000-7ff7b6b68000 r--p 0000a000 00:13 22441 /usr/lib64/libdrm.so.2.4.0
7ff7b6b68000-7ff7b6b69000 rw-p 0000b000 00:13 22441 /usr/lib64/libdrm.so.2.4.0
7ff7b6b69000-7ff7b6b6e000 r-xp 00000000 00:13 180774 /usr/lib64/libXxf86vm.so.1.0.0
7ff7b6b6e000-7ff7b6d6d000 ---p 00005000 00:13 180774 /usr/lib64/libXxf86vm.so.1.0.0
7ff7b6d6d000-7ff7b6d6e000 r--p 00004000 00:13 180774 /usr/lib64/libXxf86vm.so.1.0.0
7ff7b6d6e000-7ff7b6d6f000 rw-p 00005000 00:13 180774 /usr/lib64/libXxf86vm.so.1.0.0
7ff7b6d6f000-7ff7b6d85000 r-xp 00000000 00:13 178797 /usr/lib64/libxcb-glx.so.0.0.0
7ff7b6d85000-7ff7b6f84000 ---p 00016000 00:13 178797 /usr/lib64/libxcb-glx.so.0.0.0
7ff7b6f84000-7ff7b6f86000 r--p 00015000 00:13 178797 /usr/lib64/libxcb-glx.so.0.0.0
7ff7b6f86000-7ff7b6f87000 rw-p 00017000 00:13 178797 /usr/lib64/libxcb-glx.so.0.0.0
7ff7b6f87000-7ff7b6f88000 r-xp 00000000 00:13 175101 /usr/lib64/libX11-xcb.so.1.0.0
7ff7b6f88000-7ff7b7187000 ---p 00001000 00:13 175101 /usr/lib64/libX11-xcb.so.1.0.0
7ff7b7187000-7ff7b7188000 r--p 00000000 00:13 175101 /usr/lib64/libX11-xcb.so.1.0.0
7ff7b7188000-7ff7b7189000 rw-p 00001000 00:13 175101 /usr/lib64/libX11-xcb.so.1.0.0
7ff7b7189000-7ff7b71aa000 r-xp 00000000 00:13 174178 /usr/lib64/libglapi.so.0.0.0
7ff7b71aa000-7ff7b73aa000 ---p 00021000 00:13 174178 /usr/lib64/libglapi.so.0.0.0
7ff7b73aa000-7ff7b73ad000 r--p 00021000 00:13 174178 /usr/lib64/libglapi.so.0.0.0
7ff7b73ad000-7ff7b73ae000 rw-p 00024000 00:13 174178 /usr/lib64/libglapi.so.0.0.0
7ff7b73ae000-7ff7b73af000 rw-p 00000000 00:00 0
7ff7b73af000-7ff7b73d4000 r-xp 00000000 00:13 19887 /usr/lib64/liblzma.so.5.0.4
7ff7b73d4000-7ff7b75d3000 ---p 00025000 00:13 19887 /usr/lib64/liblzma.so.5.0.4
7ff7b75d3000-7ff7b75d4000 r--p 00024000 00:13 19887 /usr/lib64/liblzma.so.5.0.4
7ff7b75d4000-7ff7b75d5000 rw-p 00025000 00:13 19887 /usr/lib64/liblzma.so.5.0.4
7ff7b75d5000-7ff7b7650000 r-xp 00000000 00:13 22049 /usr/lib64/libgcrypt.so.11.7.0
7ff7b7650000-7ff7b7850000 ---p 0007b000 00:13 22049 /usr/lib64/libgcrypt.so.11.7.0
7ff7b7850000-7ff7b7851000 r--p 0007b000 00:13 22049 /usr/lib64/libgcrypt.so.11.7.0
7ff7b7851000-7ff7b7854000 rw-p 0007c000 00:13 22049 /usr/lib64/libgcrypt.so.11.7.0
7ff7b7854000-7ff7b78ca000 r-xp 00000000 00:13 32345 /usr/lib64/liborc-0.4.so.0.16.0
7ff7b78ca000-7ff7b7ac9000 ---p 00076000 00:13 32345 /usr/lib64/liborc-0.4.so.0.16.0
7ff7b7ac9000-7ff7b7acb000 r--p 00075000 00:13 32345 /usr/lib64/liborc-0.4.so.0.16.0
7ff7b7acb000-7ff7b7ad0000 rw-p 00077000 00:13 32345 /usr/lib64/liborc-0.4.so.0.16.0
7ff7b7ad0000-7ff7b7b04000 r-xp 00000000 00:13 358063 /usr/lib64/libgsttag-1.0.so.0.7.0
7ff7b7b04000-7ff7b7d04000 ---p 00034000 00:13 358063 /usr/lib64/libgsttag-1.0.so.0.7.0
7ff7b7d04000-7ff7b7d06000 r--p 00034000 00:13 358063 /usr/lib64/libgsttag-1.0.so.0.7.0
7ff7b7d06000-7ff7b7d07000 rw-p 00036000 00:13 358063 /usr/lib64/libgsttag-1.0.so.0.7.0
7ff7b7d07000-7ff7b7d2d000 r-xp 00000000 00:13 21765 /usr/lib64/libdbus-glib-1.so.2.2.2
7ff7b7d2d000-7ff7b7f2c000 ---p 00026000 00:13 21765 /usr/lib64/libdbus-glib-1.so.2.2.2
7ff7b7f2c000-7ff7b7f2d000 r--p 00025000 00:13 21765 /usr/lib64/libdbus-glib-1.so.2.2.2
7ff7b7f2d000-7ff7b7f2e000 rw-p 00026000 00:13 21765 /usr/lib64/libdbus-glib-1.so.2.2.2
7ff7b7f2e000-7ff7b7f8e000 r-xp 00000000 00:13 179529 /usr/lib64/libXt.so.6.0.0
7ff7b7f8e000-7ff7b818e000 ---p 00060000 00:13 179529 /usr/lib64/libXt.so.6.0.0
7ff7b818e000-7ff7b818f000 r--p 00060000 00:13 179529 /usr/lib64/libXt.so.6.0.0
7ff7b818f000-7ff7b8194000 rw-p 00061000 00:13 179529 /usr/lib64/libXt.so.6.0.0
7ff7b8194000-7ff7b8195000 rw-p 00000000 00:00 0
7ff7b8195000-7ff7b81de000 r-xp 00000000 00:13 93936 /usr/lib64/libwebp.so.4.0.1
7ff7b81de000-7ff7b83dd000 ---p 00049000 00:13 93936 /usr/lib64/libwebp.so.4.0.1
7ff7b83dd000-7ff7b83de000 r--p 00048000 00:13 93936 /usr/lib64/libwebp.so.4.0.1
7ff7b83de000-7ff7b83df000 rw-p 00049000 00:13 93936 /usr/lib64/libwebp.so.4.0.1
7ff7b83df000-7ff7b83e2000 rw-p 00000000 00:00 0
7ff7b83e2000-7ff7b85da000 r-xp 00000000 00:13 22068 /usr/lib64/libicui18n.so.49.1
7ff7b85da000-7ff7b87da000 ---p 001f8000 00:13 22068 /usr/lib64/libicui18n.so.49.1
7ff7b87da000-7ff7b87e6000 r--p 001f8000 00:13 22068 /usr/lib64/libicui18n.so.49.1
7ff7b87e6000-7ff7b87e8000 rw-p 00204000 00:13 22068 /usr/lib64/libicui18n.so.49.1
7ff7b87e8000-7ff7b88b5000 r-xp 00000000 00:13 21842 /usr/lib64/libsqlite3.so.0.8.6
7ff7b88b5000-7ff7b8ab4000 ---p 000cd000 00:13 21842 /usr/lib64/libsqlite3.so.0.8.6
7ff7b8ab4000-7ff7b8ab6000 r--p 000cc000 00:13 21842 /usr/lib64/libsqlite3.so.0.8.6
7ff7b8ab6000-7ff7b8ab9000 rw-p 000ce000 00:13 21842 /usr/lib64/libsqlite3.so.0.8.6
7ff7b8ab9000-7ff7b8ad5000 r-xp 00000000 00:13 179669 /usr/lib64/libEGL.so.1.0.0
7ff7b8ad5000-7ff7b8cd5000 ---p 0001c000 00:13 179669 /usr/lib64/libEGL.so.1.0.0
7ff7b8cd5000-7ff7b8cd6000 r--p 0001c000 00:13 179669 /usr/lib64/libEGL.so.1.0.0
7ff7b8cd6000-7ff7b8cd7000 rw-p 0001d000 00:13 179669 /usr/lib64/libEGL.so.1.0.0
7ff7b8cd7000-7ff7b8d37000 r-xp 00000000 00:13 181187 /usr/lib64/libGL.so.1.2.0
7ff7b8d37000-7ff7b8f37000 ---p 00060000 00:13 181187 /usr/lib64/libGL.so.1.2.0
7ff7b8f37000-7ff7b8f39000 r--p 00060000 00:13 181187 /usr/lib64/libGL.so.1.2.0
7ff7b8f39000-7ff7b8f3a000 rw-p 00062000 00:13 181187 /usr/lib64/libGL.so.1.2.0
7ff7b8f3a000-7ff7b8f3b000 rw-p 00000000 00:00 0
7ff7b8f3b000-7ff7b9097000 r-xp 00000000 00:13 319005 /usr/lib64/libxml2.so.2.9.0
7ff7b9097000-7ff7b9296000 ---p 0015c000 00:13 319005 /usr/lib64/libxml2.so.2.9.0
7ff7b9296000-7ff7b929e000 r--p 0015b000 00:13 319005 /usr/lib64/libxml2.so.2.9.0
7ff7b929e000-7ff7b92a0000 rw-p 00163000 00:13 319005 /usr/lib64/libxml2.so.2.9.0
7ff7b92a0000-7ff7b92a2000 rw-p 00000000 00:00 0
7ff7b92a2000-7ff7b92df000 r-xp 00000000 00:13 175379 /usr/lib64/libxslt.so.1.1.28
7ff7b92df000-7ff7b94de000 ---p 0003d000 00:13 175379 /usr/lib64/libxslt.so.1.1.28
7ff7b94de000-7ff7b94df000 r--p 0003c000 00:13 175379 /usr/lib64/libxslt.so.1.1.28
7ff7b94df000-7ff7b94e0000 rw-p 0003d000 00:13 175379 /usr/lib64/libxslt.so.1.1.28
7ff7b94e0000-7ff7b94e1000 rw-p 00000000 00:00 0
7ff7b94e1000-7ff7b952e000 r-xp 00000000 00:13 256680 /usr/lib64/libsecret-1.so.0.0.0
7ff7b952e000-7ff7b972d000 ---p 0004d000 00:13 256680 /usr/lib64/libsecret-1.so.0.0.0
7ff7b972d000-7ff7b9730000 r--p 0004c000 00:13 256680 /usr/lib64/libsecret-1.so.0.0.0
7ff7b9730000-7ff7b9731000 rw-p 0004f000 00:13 256680 /usr/lib64/libsecret-1.so.0.0.0
7ff7b9731000-7ff7b9732000 rw-p 00000000 00:00 0
7ff7b9732000-7ff7b9771000 r-xp 00000000 00:13 169833 /usr/lib64/libjpeg.so.8.0.2
7ff7b9771000-7ff7b9971000 ---p 0003f000 00:13 169833 /usr/lib64/libjpeg.so.8.0.2
7ff7b9971000-7ff7b9972000 r--p 0003f000 00:13 169833 /usr/lib64/libjpeg.so.8.0.2
7ff7b9972000-7ff7b9973000 rw-p 00040000 00:13 169833 /usr/lib64/libjpeg.so.8.0.2
7ff7b9973000-7ff7b9983000 rw-p 00000000 00:00 0
7ff7b9983000-7ff7b9a71000 r-xp 00000000 00:13 320696 /usr/lib64/libgstreamer-1.0.so.0.7.0
7ff7b9a71000-7ff7b9c70000 ---p 000ee000 00:13 320696 /usr/lib64/libgstreamer-1.0.so.0.7.0
7ff7b9c70000-7ff7b9c75000 r--p 000ed000 00:13 320696 /usr/lib64/libgstreamer-1.0.so.0.7.0
7ff7b9c75000-7ff7b9c77000 rw-p 000f2000 00:13 320696 /usr/lib64/libgstreamer-1.0.so.0.7.0
7ff7b9c77000-7ff7b9c79000 rw-p 00000000 00:00 0
7ff7b9c79000-7ff7b9cca000 r-xp 00000000 00:13 320688 /usr/lib64/libgstbase-1.0.so.0.7.0
7ff7b9cca000-7ff7b9ec9000 ---p 00051000 00:13 320688 /usr/lib64/libgstbase-1.0.so.0.7.0
7ff7b9ec9000-7ff7b9eca000 r--p 00050000 00:13 320688 /usr/lib64/libgstbase-1.0.so.0.7.0
7ff7b9eca000-7ff7b9ecb000 rw-p 00051000 00:13 320688 /usr/lib64/libgstbase-1.0.so.0.7.0
7ff7b9ecb000-7ff7b9f08000 r-xp 00000000 00:13 357621 /usr/lib64/libgstvideo-1.0.so.0.7.0
7ff7b9f08000-7ff7ba107000 ---p 0003d000 00:13 357621 /usr/lib64/libgstvideo-1.0.so.0.7.0
7ff7ba107000-7ff7ba109000 r--p 0003c000 00:13 357621 /usr/lib64/libgstvideo-1.0.so.0.7.0
7ff7ba109000-7ff7ba10d000 rw-p 0003e000 00:13 357621 /usr/lib64/libgstvideo-1.0.so.0.7.0
7ff7ba10d000-7ff7ba12f000 r-xp 00000000 00:13 358154 /usr/lib64/libgstpbutils-1.0.so.0.7.0
7ff7ba12f000-7ff7ba32f000 ---p 00022000 00:13 358154 /usr/lib64/libgstpbutils-1.0.so.0.7.0
7ff7ba32f000-7ff7ba331000 r--p 00022000 00:13 358154 /usr/lib64/libgstpbutils-1.0.so.0.7.0
7ff7ba331000-7ff7ba332000 rw-p 00024000 00:13 358154 /usr/lib64/libgstpbutils-1.0.so.0.7.0
7ff7ba332000-7ff7ba378000 r-xp 00000000 00:13 358131 /usr/lib64/libgstaudio-1.0.so.0.7.0
7ff7ba378000-7ff7ba578000 ---p 00046000 00:13 358131 /usr/lib64/libgstaudio-1.0.so.0.7.0
7ff7ba578000-7ff7ba57a000 r--p 00046000 00:13 358131 /usr/lib64/libgstaudio-1.0.so.0.7.0
7ff7ba57a000-7ff7ba57c000 rw-p 00048000 00:13 358131 /usr/lib64/libgstaudio-1.0.so.0.7.0
7ff7ba57c000-7ff7ba587000 r-xp 00000000 00:13 358248 /usr/lib64/libgstapp-1.0.so.0.7.0
7ff7ba587000-7ff7ba787000 ---p 0000b000 00:13 358248 /usr/lib64/libgstapp-1.0.so.0.7.0
7ff7ba787000-7ff7ba788000 r--p 0000b000 00:13 358248 /usr/lib64/libgstapp-1.0.so.0.7.0
7ff7ba788000-7ff7ba789000 rw-p 0000c000 00:13 358248 /usr/lib64/libgstapp-1.0.so.0.7.0
7ff7ba789000-7ff7ba79e000 r-xp 00000000 00:13 53804 /usr/lib64/libgeoclue.so.0.0.0
7ff7ba79e000-7ff7ba99d000 ---p 00015000 00:13 53804 /usr/lib64/libgeoclue.so.0.0.0
7ff7ba99d000-7ff7ba99e000 r--p 00014000 00:13 53804 /usr/lib64/libgeoclue.so.0.0.0
7ff7ba99e000-7ff7ba9a0000 rw-p 00015000 00:13 53804 /usr/lib64/libgeoclue.so.0.0.0
7ff7ba9a0000-7ff7ba9a7000 r-xp 00000000 00:13 293655 /usr/lib64/libgailutil.so.18.0.1
7ff7ba9a7000-7ff7baba6000 ---p 00007000 00:13 293655 /usr/lib64/libgailutil.so.18.0.1
7ff7baba6000-7ff7baba7000 r--p 00006000 00:13 293655 /usr/lib64/libgailutil.so.18.0.1
7ff7baba7000-7ff7baba8000 rw-p 00007000 00:13 293655 /usr/lib64/libgailutil.so.18.0.1
7ff7baba8000-7ff7babb3000 r-xp 00000000 00:13 32193 /usr/lib64/libenchant.so.1.6.0
7ff7babb3000-7ff7badb2000 ---p 0000b000 00:13 32193 /usr/lib64/libenchant.so.1.6.0
7ff7badb2000-7ff7badb3000 r--p 0000a000 00:13 32193 /usr/lib64/libenchant.so.1.6.0
7ff7badb3000-7ff7badb4000 rw-p 0000b000 00:13 32193 /usr/lib64/libenchant.so.1.6.0
7ff7badb4000-7ff7bb2c5000 r-xp 00000000 00:13 256304 /usr/lib64/libjavascriptcoregtk-1.0.so.0.13.15
7ff7bb2c5000-7ff7bb4c5000 ---p 00511000 00:13 256304 /usr/lib64/libjavascriptcoregtk-1.0.so.0.13.15
7ff7bb4c5000-7ff7bb4d4000 r--p 00511000 00:13 256304 /usr/lib64/libjavascriptcoregtk-1.0.so.0.13.15
7ff7bb4d4000-7ff7bb4df000 rw-p 00520000 00:13 256304 /usr/lib64/libjavascriptcoregtk-1.0.so.0.13.15
7ff7bb4df000-7ff7bb505000 rw-p 00000000 00:00 0
7ff7bb505000-7ff7bb52d000 r-xp 00000000 00:13 307905 /usr/lib64/libpng12.so.0.50.0
7ff7bb52d000-7ff7bb72d000 ---p 00028000 00:13 307905 /usr/lib64/libpng12.so.0.50.0
7ff7bb72d000-7ff7bb72e000 r--p 00028000 00:13 307905 /usr/lib64/libpng12.so.0.50.0
7ff7bb72e000-7ff7bb72f000 rw-p 00029000 00:13 307905 /usr/lib64/libpng12.so.0.50.0
7ff7bb72f000-7ff7bb7d6000 r-xp 00000000 00:13 258249 /usr/lib64/libsoup-2.4.so.1.6.0
7ff7bb7d6000-7ff7bb9d5000 ---p 000a7000 00:13 258249 /usr/lib64/libsoup-2.4.so.1.6.0
7ff7bb9d5000-7ff7bb9d7000 r--p 000a6000 00:13 258249 /usr/lib64/libsoup-2.4.so.1.6.0
7ff7bb9d7000-7ff7bb9f1000 rw-p 000a8000 00:13 258249 /usr/lib64/libsoup-2.4.so.1.6.0
7ff7bb9f1000-7ff7bd4ec000 r-xp 00000000 00:13 258624 /usr/lib64/libwebkitgtk-1.0.so.0.18.8
7ff7bd4ec000-7ff7bd6eb000 ---p 01afb000 00:13 258624 /usr/lib64/libwebkitgtk-1.0.so.0.18.8
7ff7bd6eb000-7ff7bd877000 r--p 01afa000 00:13 258624 /usr/lib64/libwebkitgtk-1.0.so.0.18.8
7ff7bd877000-7ff7bd88a000 rw-p 01c86000 00:13 258624 /usr/lib64/libwebkitgtk-1.0.so.0.18.8
7ff7bd88a000-7ff7bd893000 rw-p 00000000 00:00 0
7ff7bd893000-7ff7bd89b000 r-xp 00000000 00:24 1109376 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-webkit-gtk-3740.so
7ff7bd89b000-7ff7bda9b000 ---p 00008000 00:24 1109376 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-webkit-gtk-3740.so
7ff7bda9b000-7ff7bda9c000 rw-p 00008000 00:24 1109376 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-webkit-gtk-3740.so
7ff7bda9c000-7ff7bda9f000 ---p 00000000 00:00 0
7ff7bda9f000-7ff7bdb9d000 rw-p 00000000 00:00 0
7ff7bdb9d000-7ff7bdba0000 ---p 00000000 00:00 0
7ff7bdba0000-7ff7bdc9e000 rw-p 00000000 00:00 0 [stack:2044]
7ff7bdc9e000-7ff7bdca1000 ---p 00000000 00:00 0
7ff7bdca1000-7ff7bdd9f000 rw-p 00000000 00:00 0 [stack:1953]
7ff7bdd9f000-7ff7bdda2000 ---p 00000000 00:00 0
7ff7bdda2000-7ff7bdea0000 rw-p 00000000 00:00 0 [stack:1952]
7ff7bdea0000-7ff7bdea3000 ---p 00000000 00:00 0
7ff7bdea3000-7ff7bdfa1000 rw-p 00000000 00:00 0 [stack:1951]
7ff7bdfa1000-7ff7bdfc7000 r--s 00240000 00:24 1107822 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.php.libraries_3.0.0.2/trove-3.0.0rc1.jar
7ff7bdfc7000-7ff7bdffc000 r--s 00000000 00:10 10440 /var/run/nscd/group
7ff7be006000-7ff7be038000 r-xp 00000000 00:13 355845 /usr/java/jdk1.7.0_25/jre/lib/amd64/libsunec.so
7ff7be038000-7ff7be237000 ---p 00032000 00:13 355845 /usr/java/jdk1.7.0_25/jre/lib/amd64/libsunec.so
7ff7be237000-7ff7be23d000 rw-p 00031000 00:13 355845 /usr/java/jdk1.7.0_25/jre/lib/amd64/libsunec.so
7ff7be23d000-7ff7be24d000 rw-p 00000000 00:00 0
7ff7be24d000-7ff7be250000 ---p 00000000 00:00 0
7ff7be250000-7ff7be34e000 rw-p 00000000 00:00 0 [stack:1909]
7ff7be34e000-7ff7be351000 ---p 00000000 00:00 0
7ff7be351000-7ff7be44f000 rw-p 00000000 00:00 0 [stack:1947]
7ff7be44f000-7ff7be452000 ---p 00000000 00:00 0
7ff7be452000-7ff7be477000 rw-p 00000000 00:00 0
7ff7be477000-7ff7be47a000 ---p 00000000 00:00 0
7ff7be47a000-7ff7be578000 rw-p 00000000 00:00 0 [stack:1950]
7ff7be578000-7ff7be57b000 ---p 00000000 00:00 0
7ff7be57b000-7ff7be679000 rw-p 00000000 00:00 0 [stack:1908]
7ff7be679000-7ff7be67c000 ---p 00000000 00:00 0
7ff7be67c000-7ff7be77a000 rw-p 00000000 00:00 0 [stack:1896]
7ff7be77a000-7ff7be77d000 ---p 00000000 00:00 0
7ff7be77d000-7ff7be87b000 rw-p 00000000 00:00 0 [stack:1948]
7ff7be87b000-7ff7be87e000 ---p 00000000 00:00 0
7ff7be87e000-7ff7be97c000 rw-p 00000000 00:00 0 [stack:1886]
7ff7be97c000-7ff7bee6d000 r--p 00000000 00:13 86855 /usr/share/fonts/truetype/wqy-microhei.ttc
7ff7bee6d000-7ff7bee70000 ---p 00000000 00:00 0
7ff7bee70000-7ff7bef6e000 rw-p 00000000 00:00 0 [stack:1884]
7ff7bef6e000-7ff7bef71000 ---p 00000000 00:00 0
7ff7bef71000-7ff7bf06f000 rw-p 00000000 00:00 0 [stack:1883]
7ff7bf06f000-7ff7bf072000 ---p 00000000 00:00 0
7ff7bf072000-7ff7bf170000 rw-p 00000000 00:00 0 [stack:1877]
7ff7bf170000-7ff7bf173000 ---p 00000000 00:00 0
7ff7bf173000-7ff7bf271000 rw-p 00000000 00:00 0 [stack:1876]
7ff7bf271000-7ff7bf274000 ---p 00000000 00:00 0
7ff7bf274000-7ff7bf372000 rw-p 00000000 00:00 0 [stack:1875]
7ff7bf372000-7ff7bf375000 ---p 00000000 00:00 0
7ff7bf375000-7ff7bf473000 rw-p 00000000 00:00 0 [stack:1874]
7ff7bf473000-7ff7bf476000 ---p 00000000 00:00 0
7ff7bf476000-7ff7bf574000 rw-p 00000000 00:00 0 [stack:1873]
7ff7bf574000-7ff7bf577000 ---p 00000000 00:00 0
7ff7bf577000-7ff7bf675000 rw-p 00000000 00:00 0 [stack:1872]
7ff7bf675000-7ff7bf678000 ---p 00000000 00:00 0
7ff7bf678000-7ff7bf776000 rw-p 00000000 00:00 0 [stack:1871]
7ff7bf776000-7ff7c3598000 r--p 00000000 00:13 348303 /usr/share/icons/hicolor/icon-theme.cache
7ff7c3598000-7ff7c8000000 r--p 00000000 00:13 293377 /usr/share/icons/gnome/icon-theme.cache
7ff7c8000000-7ff7c808d000 rw-p 00000000 00:00 0
7ff7c808d000-7ff7cc000000 ---p 00000000 00:00 0
7ff7cc000000-7ff7cc100000 rw-s 00000000 00:04 622600 /SYSV00000000 (deleted)
7ff7cc100000-7ff7cc160000 rw-s 00000000 00:04 589826 /SYSV00000000 (deleted)
7ff7cc160000-7ff7cc192000 r--s 00244000 00:24 1107783 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.debug.ui_3.7.102.v20111129-1423_r372.jar
7ff7cc192000-7ff7cc193000 ---p 00000000 00:00 0
7ff7cc193000-7ff7cc993000 rw-p 00000000 00:00 0 [stack:2047]
7ff7cc9eb000-7ff7cc9f3000 r--p 00000000 00:24 1125525 /home/gmg/.config/dconf/user
7ff7cc9f3000-7ff7cca1f000 r--p 00000000 00:13 355303 /usr/share/glib-2.0/schemas/gschemas.compiled
7ff7cca1f000-7ff7cca2f000 rw-p 00000000 00:00 0
7ff7cca2f000-7ff7cca4c000 r--s 001ba000 00:24 1107839 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant.jar
7ff7cca4c000-7ff7cca4d000 ---p 00000000 00:00 0
7ff7cca4d000-7ff7cd24d000 rw-p 00000000 00:00 0 [stack:2045]
7ff7cd24d000-7ff7cd24e000 ---p 00000000 00:00 0
7ff7cd24e000-7ff7cda4e000 rw-p 00000000 00:00 0
7ff7cda4e000-7ff7cda51000 ---p 00000000 00:00 0
7ff7cda51000-7ff7cdb4f000 rw-p 00000000 00:00 0 [stack:1860]
7ff7cdb4f000-7ff7cdb52000 ---p 00000000 00:00 0
7ff7cdb52000-7ff7cdc50000 rw-p 00000000 00:00 0 [stack:1870]
7ff7cdc50000-7ff7cdc53000 ---p 00000000 00:00 0
7ff7cdc53000-7ff7cdc80000 rw-p 00000000 00:00 0
7ff7cdc80000-7ff7cdc9a000 r--s 0011b000 00:24 1107781 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.php.debug.epl_3.3.0.1345228196.jar
7ff7cdc9a000-7ff7cdcb2000 r--s 001b6000 00:24 1110362 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/295/1/.cp/css-validator.jar
7ff7cdcb2000-7ff7cdcbf000 r--s 000a7000 00:24 1107023 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.editor.common_3.0.3.1367525200.jar
7ff7cdcc0000-7ff7cdcc7000 r--s 0004b000 00:24 1107908 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.ui.io_3.0.0.1366120396.jar
7ff7cdccd000-7ff7cdcd9000 r--s 000ba000 00:24 1105753 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.core.resources_3.7.101.v20120125-1505.jar
7ff7cdcd9000-7ff7cdcdf000 r--s 0003f000 00:24 1105756 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.ui.epl_3.0.0.1368752364.jar
7ff7cdce2000-7ff7cdcf2000 rw-p 00000000 00:00 0
7ff7cdcf2000-7ff7cdd05000 r--s 000dd000 00:24 1105847 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.jface.text_3.7.2.v20111213-1208.jar
7ff7cdd05000-7ff7cdd0a000 r--s 00038000 00:24 1107818 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.text_3.5.101.v20110928-1504.jar
7ff7cdd0a000-7ff7cdd19000 r--s 002dd000 00:24 1107158 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.scripting_3.1.0.1367525200.jar
7ff7cdd19000-7ff7cdd25000 r--s 00081000 00:24 1105842 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.ui.editors_3.7.0.v20110928-1504.jar
7ff7cdd25000-7ff7cdd31000 r--s 00083000 00:24 1107194 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.ui.workbench.texteditor_3.7.0.v20110928-1504.jar
7ff7cdd38000-7ff7cdd41000 r--s 0005a000 00:24 1105789 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.ui.navigator_3.5.101.v20120106-1355.jar
7ff7cdd41000-7ff7cdd45000 r--s 00017000 00:24 1107780 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.core.commands_3.6.0.I20110111-0800.jar
7ff7cdd45000-7ff7cdd49000 r--s 0001d000 00:24 1107906 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.formatter.epl_3.2.0.1341615906.jar
7ff7cdd49000-7ff7cdd4e000 r--s 00035000 00:24 1107371 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.ui_3.1.4.1370053012.jar
7ff7cdd4e000-7ff7cdd5a000 r-xp 00000000 00:24 1108087 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-cairo-gtk-3740.so
7ff7cdd5a000-7ff7cde5a000 ---p 0000c000 00:24 1108087 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-cairo-gtk-3740.so
7ff7cde5a000-7ff7cde5b000 rw-p 0000c000 00:24 1108087 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-cairo-gtk-3740.so
7ff7cde5c000-7ff7cde60000 r--s 0001e000 00:24 1107105 /home/gmg/ 应用 /Aptana_Studio_3/plugins/beaver_3.0.0.1346444146.jar
7ff7cde60000-7ff7cde67000 r--s 000a0000 00:24 1107421 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.js.core_3.0.0.1369795575.jar
7ff7cde67000-7ff7cde69000 r-xp 00000000 00:24 1109334 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/61/1/.cp/os/linux/x86_64/libjnotify.so
7ff7cde69000-7ff7ce068000 ---p 00002000 00:24 1109334 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/61/1/.cp/os/linux/x86_64/libjnotify.so
7ff7ce068000-7ff7ce069000 r--p 00001000 00:24 1109334 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/61/1/.cp/os/linux/x86_64/libjnotify.so
7ff7ce069000-7ff7ce06a000 rw-p 00002000 00:24 1109334 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/61/1/.cp/os/linux/x86_64/libjnotify.so
7ff7ce06a000-7ff7ce06d000 ---p 00000000 00:00 0
7ff7ce06d000-7ff7ce16b000 rw-p 00000000 00:00 0 [stack:1839]
7ff7ce16b000-7ff7ce16e000 ---p 00000000 00:00 0
7ff7ce16e000-7ff7ce26c000 rw-p 00000000 00:00 0 [stack:1838]
7ff7ce26c000-7ff7ce26f000 ---p 00000000 00:00 0
7ff7ce26f000-7ff7ce36d000 rw-p 00000000 00:00 0 [stack:1837]
7ff7ce36d000-7ff7ce370000 ---p 00000000 00:00 0
7ff7ce370000-7ff7ce46e000 rw-p 00000000 00:00 0 [stack:1869]
7ff7ce46e000-7ff7ce471000 ---p 00000000 00:00 0
7ff7ce471000-7ff7ce56f000 rw-p 00000000 00:00 0 [stack:1835]
7ff7ce56f000-7ff7ce571000 r-xp 00000000 00:24 1110247 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/159/1/.cp/os/linux/x86_64/libunixfile_1_0_0.so
7ff7ce571000-7ff7ce670000 ---p 00002000 00:24 1110247 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/159/1/.cp/os/linux/x86_64/libunixfile_1_0_0.so
7ff7ce670000-7ff7ce671000 rw-p 00001000 00:24 1110247 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/159/1/.cp/os/linux/x86_64/libunixfile_1_0_0.so
7ff7ce671000-7ff7ce675000 r--s 0003a000 00:24 1107426 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.css.core_1.0.0.1364100898.jar
7ff7ce675000-7ff7ce678000 ---p 00000000 00:00 0
7ff7ce678000-7ff7ce69d000 rw-p 00000000 00:00 0
7ff7ce69e000-7ff7ce6b4000 r--s 0020f000 00:24 1107027 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.editor.php.epl_3.3.0.1358460206.jar
7ff7ce6b4000-7ff7ce6bc000 r--s 00000000 00:24 1086568 /home/gmg/.local/share/gvfs-metadata/root-d288929f.log
7ff7ce6bc000-7ff7ce6c3000 r--s 00052000 00:24 1106716 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.editor.html_3.0.3.1367525200.jar
7ff7ce6c4000-7ff7ce6d3000 r--s 000e0000 00:24 1107212 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.editor.php_3.3.0.1365773524.jar
7ff7ce6d4000-7ff7ce6d6000 r--s 0000e000 00:24 1107753 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.compare.core_3.5.200.I20110208-0800.jar
7ff7ce6d6000-7ff7ce6e0000 r--s 00069000 00:24 1107130 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.search_3.7.0.v20110928-1504.jar
7ff7ce6e0000-7ff7ce6e9000 r--s 00058000 00:24 1103984 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.team.core_3.6.0.I20110525-0800.jar
7ff7ce6e9000-7ff7ce6f1000 r--s 0004d000 00:24 1107944 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.debug.core_3.7.1.v20111129-2031.jar
7ff7ce6f1000-7ff7ce6f2000 ---p 00000000 00:00 0
7ff7ce6f2000-7ff7ceef2000 rw-p 00000000 00:00 0 [stack:2046]
7ff7ceef2000-7ff7ceefd000 r-xp 00000000 00:24 1108036 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-atk-gtk-3740.so
7ff7ceefd000-7ff7ceffd000 ---p 0000b000 00:24 1108036 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-atk-gtk-3740.so
7ff7ceffd000-7ff7ceffe000 rw-p 0000b000 00:24 1108036 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-atk-gtk-3740.so
7ff7ceffe000-7ff7cefff000 ---p 00000000 00:00 0
7ff7cefff000-7ff7cf7ff000 rw-p 00000000 00:00 0 [stack:1912]
7ff7cf7ff000-7ff7cf800000 ---p 00000000 00:00 0
7ff7cf800000-7ff7d0000000 rw-p 00000000 00:00 0 [stack:1832]
7ff7d0000000-7ff7d00be000 rw-p 00000000 00:00 0
7ff7d00be000-7ff7d4000000 ---p 00000000 00:00 0
7ff7d4000000-7ff7d4718000 rw-p 00000000 00:00 0
7ff7d4718000-7ff7d8000000 ---p 00000000 00:00 0
7ff7d8000000-7ff7d80f3000 rw-p 00000000 00:00 0
7ff7d80f3000-7ff7dc000000 ---p 00000000 00:00 0
7ff7dc000000-7ff7dc004000 r--s 00013000 00:24 1107350 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.ui.views_3.6.0.v20110928-1505.jar
7ff7dc004000-7ff7dc00c000 r--s 00070000 00:24 1107031 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.syncing.ui_3.0.3.1367525200.jar
7ff7dc00c000-7ff7dc012000 r--s 00036000 00:24 1107232 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.parsing_3.0.0.1353527087/libs/jaxen-1.1.2.jar
7ff7dc018000-7ff7dc01b000 r--s 00018000 00:13 356022 /usr/java/jdk1.7.0_25/jre/lib/jce.jar
7ff7dc01c000-7ff7dc01e000 r--s 0000f000 00:24 1107833 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.jetty.util.epl_3.0.0.1337703431.jar
7ff7dc01e000-7ff7dc022000 r--s 0002b000 00:24 1105854 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.editor.css_3.1.0.1357340380.jar
7ff7dc022000-7ff7dc028000 r-xp 00000000 00:13 256808 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-gif.so
7ff7dc028000-7ff7dc227000 ---p 00006000 00:13 256808 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-gif.so
7ff7dc227000-7ff7dc228000 r--p 00005000 00:13 256808 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-gif.so
7ff7dc228000-7ff7dc229000 rw-p 00006000 00:13 256808 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-gif.so
7ff7dc229000-7ff7dc238000 r-xp 00000000 00:13 168611 /usr/lib64/libudev.so.1.1.6
7ff7dc238000-7ff7dc437000 ---p 0000f000 00:13 168611 /usr/lib64/libudev.so.1.1.6
7ff7dc437000-7ff7dc438000 r--p 0000e000 00:13 168611 /usr/lib64/libudev.so.1.1.6
7ff7dc438000-7ff7dc439000 rw-p 0000f000 00:13 168611 /usr/lib64/libudev.so.1.1.6
7ff7dc439000-7ff7dc470000 r-xp 00000000 00:13 256897 /usr/lib64/libgvfscommon.so.0.0.0
7ff7dc470000-7ff7dc66f000 ---p 00037000 00:13 256897 /usr/lib64/libgvfscommon.so.0.0.0
7ff7dc66f000-7ff7dc674000 r--p 00036000 00:13 256897 /usr/lib64/libgvfscommon.so.0.0.0
7ff7dc674000-7ff7dc675000 rw-p 0003b000 00:13 256897 /usr/lib64/libgvfscommon.so.0.0.0
7ff7dc675000-7ff7dc6a5000 r-xp 00000000 00:13 263637 /usr/lib64/gio/modules/libgvfsdbus.so
7ff7dc6a5000-7ff7dc8a5000 ---p 00030000 00:13 263637 /usr/lib64/gio/modules/libgvfsdbus.so
7ff7dc8a5000-7ff7dc8a6000 r--p 00030000 00:13 263637 /usr/lib64/gio/modules/libgvfsdbus.so
7ff7dc8a6000-7ff7dc8a8000 rw-p 00031000 00:13 263637 /usr/lib64/gio/modules/libgvfsdbus.so
7ff7dc8a8000-7ff7dc8ec000 r-xp 00000000 00:13 174138 /lib64/libdbus-1.so.3.7.2
7ff7dc8ec000-7ff7dcaec000 ---p 00044000 00:13 174138 /lib64/libdbus-1.so.3.7.2
7ff7dcaec000-7ff7dcaed000 r--p 00044000 00:13 174138 /lib64/libdbus-1.so.3.7.2
7ff7dcaed000-7ff7dcaee000 rw-p 00045000 00:13 174138 /lib64/libdbus-1.so.3.7.2
7ff7dcaee000-7ff7dcaf9000 r-xp 00000000 00:13 184539 /usr/lib64/libfcitx-gclient.so.0.1
7ff7dcaf9000-7ff7dccf8000 ---p 0000b000 00:13 184539 /usr/lib64/libfcitx-gclient.so.0.1
7ff7dccf8000-7ff7dccf9000 r--p 0000a000 00:13 184539 /usr/lib64/libfcitx-gclient.so.0.1
7ff7dccf9000-7ff7dccfa000 rw-p 0000b000 00:13 184539 /usr/lib64/libfcitx-gclient.so.0.1
7ff7dccfa000-7ff7dcd0a000 r-xp 00000000 00:13 184545 /usr/lib64/libfcitx-utils.so.0.1
7ff7dcd0a000-7ff7dcf09000 ---p 00010000 00:13 184545 /usr/lib64/libfcitx-utils.so.0.1
7ff7dcf09000-7ff7dcf0a000 r--p 0000f000 00:13 184545 /usr/lib64/libfcitx-utils.so.0.1
7ff7dcf0a000-7ff7dcf0b000 rw-p 00010000 00:13 184545 /usr/lib64/libfcitx-utils.so.0.1
7ff7dcf0e000-7ff7dcf23000 r--p 00000000 00:13 58493 /usr/share/locale-bundle/zh_CN/LC_MESSAGES/glib20.mo
7ff7dcf23000-7ff7dcf2a000 r-xp 00000000 00:13 188226 /usr/lib64/gtk-2.0/2.10.0/immodules/im-fcitx.so
7ff7dcf2a000-7ff7dd129000 ---p 00007000 00:13 188226 /usr/lib64/gtk-2.0/2.10.0/immodules/im-fcitx.so
7ff7dd129000-7ff7dd12a000 r--p 00006000 00:13 188226 /usr/lib64/gtk-2.0/2.10.0/immodules/im-fcitx.so
7ff7dd12a000-7ff7dd12b000 rw-p 00007000 00:13 188226 /usr/lib64/gtk-2.0/2.10.0/immodules/im-fcitx.so
7ff7dd12b000-7ff7dd153000 r--s 00214000 00:24 1103982 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.ui.ide_3.7.0.v20110928-1505.jar
7ff7dd153000-7ff7dd158000 r-xp 00000000 00:13 256814 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-png.so
7ff7dd158000-7ff7dd357000 ---p 00005000 00:13 256814 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-png.so
7ff7dd357000-7ff7dd358000 r--p 00004000 00:13 256814 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-png.so
7ff7dd358000-7ff7dd359000 rw-p 00005000 00:13 256814 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-png.so
7ff7dd359000-7ff7dd84a000 r--p 00000000 00:13 86855 /usr/share/fonts/truetype/wqy-microhei.ttc
7ff7dd84a000-7ff7dd84d000 r-xp 00000000 00:13 256603 /usr/lib64/pango/1.8.0/modules/pango-basic-fc.so
7ff7dd84d000-7ff7dda4c000 ---p 00003000 00:13 256603 /usr/lib64/pango/1.8.0/modules/pango-basic-fc.so
7ff7dda4c000-7ff7dda4d000 r--p 00002000 00:13 256603 /usr/lib64/pango/1.8.0/modules/pango-basic-fc.so
7ff7dda4d000-7ff7dda4e000 rw-p 00003000 00:13 256603 /usr/lib64/pango/1.8.0/modules/pango-basic-fc.so
7ff7dda4e000-7ff7dda81000 r--s 00000000 00:13 290130 /var/cache/fontconfig/7ef2298fde41cc6eeb7af42e48b7d293-x86_64.cache-4
7ff7dda81000-7ff7ddab8000 r--s 00000000 00:13 290128 /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-x86_64.cache-4
7ff7ddab8000-7ff7ddb2c000 r--s 00000000 00:13 290114 /var/cache/fontconfig/17090aa38d5c6f09fb8c5c354938f1d7-x86_64.cache-4
7ff7ddb2c000-7ff7ddba0000 r--s 00000000 00:13 290112 /var/cache/fontconfig/df311e82a1a24c41a75c2c930223552e-x86_64.cache-4
7ff7ddba0000-7ff7ddba5000 r-xp 00000000 00:13 180800 /usr/lib64/libXtst.so.6.1.0
7ff7ddba5000-7ff7ddda4000 ---p 00005000 00:13 180800 /usr/lib64/libXtst.so.6.1.0
7ff7ddda4000-7ff7ddda5000 r--p 00004000 00:13 180800 /usr/lib64/libXtst.so.6.1.0
7ff7ddda5000-7ff7ddda6000 rw-p 00005000 00:13 180800 /usr/lib64/libXtst.so.6.1.0
7ff7ddda6000-7ff7ddda7000 r-xp 00000000 00:13 256298 /usr/lib64/libgthread-2.0.so.0.3600.3
7ff7ddda7000-7ff7ddfa6000 ---p 00001000 00:13 256298 /usr/lib64/libgthread-2.0.so.0.3600.3
7ff7ddfa6000-7ff7ddfa7000 r--p 00000000 00:13 256298 /usr/lib64/libgthread-2.0.so.0.3600.3
7ff7ddfa7000-7ff7ddfa8000 rw-p 00001000 00:13 256298 /usr/lib64/libgthread-2.0.so.0.3600.3
7ff7ddfa9000-7ff7ddfae000 r--s 0004d000 00:24 1107778 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.core_3.3.0.1369977306.jar
7ff7ddfaf000-7ff7ddfb1000 r--s 00001000 00:24 1110199 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.search.nl_zh_3.6.0.v20121120125106.jar
7ff7ddfb1000-7ff7ddfc0000 r--s 00000000 00:13 290126 /var/cache/fontconfig/d42e465d3d703735db7577b46e8d64be-x86_64.cache-4
7ff7ddfc0000-7ff7de034000 r-xp 00000000 00:24 1108017 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-pi-gtk-3740.so
7ff7de034000-7ff7de133000 ---p 00074000 00:24 1108017 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-pi-gtk-3740.so
7ff7de133000-7ff7de136000 rw-p 00073000 00:24 1108017 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-pi-gtk-3740.so
7ff7de136000-7ff7de138000 rw-p 00000000 00:00 0
7ff7de138000-7ff7de1b6000 r-xp 00000000 00:24 1108016 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-gtk-3740.so
7ff7de1b6000-7ff7de2b5000 ---p 0007e000 00:24 1108016 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-gtk-3740.so
7ff7de2b5000-7ff7de2bc000 rw-p 0007d000 00:24 1108016 /home/gmg/ 应用 /Aptana_Studio_3/configuration/org.eclipse.osgi/bundles/246/1/.cp/libswt-gtk-3740.so
7ff7de2bc000-7ff7de2bf000 rw-p 00000000 00:00 0
7ff7de2bf000-7ff7de2c2000 ---p 00000000 00:00 0
7ff7de2c2000-7ff7de3c0000 rw-p 00000000 00:00 0 [stack:1830]
7ff7de3c0000-7ff7de3c3000 ---p 00000000 00:00 0
7ff7de3c3000-7ff7de4c1000 rw-p 00000000 00:00 0 [stack:1829]
7ff7de4c1000-7ff7de4c4000 ---p 00000000 00:00 0
7ff7de4c4000-7ff7de5c2000 rw-p 00000000 00:00 0 [stack:1831]
7ff7de5c2000-7ff7de5c5000 ---p 00000000 00:00 0
7ff7de5c5000-7ff7de6c3000 rw-p 00000000 00:00 0 [stack:1827]
7ff7de6c3000-7ff7de6c6000 ---p 00000000 00:00 0
7ff7de6c6000-7ff7de7c4000 rw-p 00000000 00:00 0 [stack:1826]
7ff7de7c4000-7ff7de7c7000 ---p 00000000 00:00 0
7ff7de7c7000-7ff7de8c5000 rw-p 00000000 00:00 0 [stack:1825]
7ff7de8c7000-7ff7de8c9000 r--s 00009000 00:24 1107930 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.xml.core_1.0.0.1355240900.jar
7ff7de8c9000-7ff7de8d0000 r--s 00047000 00:24 1107151 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.editor.js_3.0.3.1367525200.jar
7ff7de8d0000-7ff7de8d3000 r--s 00023000 00:24 1107931 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.editor.findbar_3.0.0.1363999525.jar
7ff7de8d3000-7ff7de8dc000 r--s 00000000 00:13 290118 /var/cache/fontconfig/d62e99ef547d1d24cdb1bd22ec1a2976-x86_64.cache-4
7ff7de8dc000-7ff7de918000 r--s 00629000 00:24 1107738 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.ibm.icu_4.4.2.v20110823.jar
7ff7de918000-7ff7de92c000 r--s 000f3000 00:24 1107030 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.jface_3.7.0.v20110928-1505.jar
7ff7de92c000-7ff7de940000 r--s 0024b000 00:24 1107739 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.swt.gtk.linux.x86_64_3.7.2.v3740f.jar
7ff7de940000-7ff7de987000 r--s 003b3000 00:24 1106257 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.ui.workbench_3.7.1.v20120104-1859.jar
7ff7de989000-7ff7de98a000 r--s 00000000 00:24 1110131 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.equinox.common.nl_zh_3.6.0.v20121120125106.jar
7ff7de98a000-7ff7de98d000 r--s 00000000 00:13 290132 /var/cache/fontconfig/d458be102e54cf534d1eef0dcbb02d07-x86_64.cache-4
7ff7de98d000-7ff7de990000 r--s 00000000 00:24 910255 /home/gmg/.cache/fontconfig/ebe3d3c2238f52f0c749cbb7a8b42d72-x86_64.cache-4
7ff7de990000-7ff7de991000 r--s 00014000 00:24 1107823 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.php.libraries_3.0.0.2/java_cup.jar
7ff7de991000-7ff7de993000 r--s 00007000 00:24 1110129 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.debug.ui.nl_zh_3.6.0.v20121120125106.jar
7ff7de997000-7ff7de99c000 r--s 00031000 00:24 1107211 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.scripting.ui_3.0.0.1363994809.jar
7ff7de99c000-7ff7de99f000 r--s 00019000 00:24 1107058 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.core.filebuffers_3.5.200.v20110928-1504.jar
7ff7de99f000-7ff7de9a2000 r--s 0002d000 00:13 355979 /usr/java/jdk1.7.0_25/jre/lib/ext/sunjce_provider.jar
7ff7de9a2000-7ff7de9a6000 r--s 00029000 00:24 1107055 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.equinox.registry_3.5.101.R37x_v20110810-1611.jar
7ff7de9a6000-7ff7de9b2000 r--s 000b0000 00:13 356089 /usr/java/jdk1.7.0_25/jre/lib/resources.jar
7ff7de9b6000-7ff7de9b8000 r--s 00018000 00:24 1105798 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.equinox.common_3.6.0.v20110523.jar
7ff7de9b8000-7ff7de9ba000 r--s 00000000 00:24 1110203 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.text.nl_zh_3.6.0.v20121120125106.jar
7ff7de9bb000-7ff7de9c0000 r--p 00000000 00:13 261906 /usr/share/locale/zh_CN/LC_MESSAGES/WebKitGTK-2.0.mo
7ff7de9c0000-7ff7de9c2000 r--s 0000b000 00:24 1107949 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.editor.epl_3.0.0.1363886503.jar
7ff7de9c2000-7ff7de9c4000 r--s 00002000 00:24 1110182 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.jface.text.nl_zh_3.6.0.v20121120125106.jar
7ff7de9c4000-7ff7de9c7000 r--s 00016000 00:24 1107759 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.index.core_3.0.0.1366033959.jar
7ff7de9c7000-7ff7de9cb000 r--s 00024000 00:24 1107189 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.explorer_3.0.0.1367440240.jar
7ff7de9cb000-7ff7de9ce000 rw-s 00000000 00:04 524294 /SYSV00000000 (deleted)
7ff7de9d0000-7ff7de9d5000 r--s 00021000 00:24 1105793 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.ui_3.7.0.v20110928-1505.jar
7ff7de9d5000-7ff7de9d7000 r--s 0000c000 00:24 1107832 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.editor.svg_3.0.3.1357571277.jar
7ff7de9d7000-7ff7de9d9000 r--s 00002000 00:24 1110207 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.ui.editors.nl_zh_3.6.0.v20121120125106.jar
7ff7de9d9000-7ff7de9db000 r--s 00002000 00:24 1107854 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-launcher.jar
7ff7de9db000-7ff7de9dd000 r--s 00017000 00:24 1107856 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-junit.jar
7ff7de9dd000-7ff7de9de000 r--s 0025f000 00:24 1107756 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.w3c.css_3.0.0.1308864319.jar
7ff7de9df000-7ff7de9e1000 r--s 00001000 00:24 1107838 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-jdepend.jar
7ff7de9e1000-7ff7de9e6000 r--s 00047000 00:24 1105843 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.portal.ui_3.0.0.1367525200.jar
7ff7de9e6000-7ff7de9e8000 r--s 00010000 00:24 1107184 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.core.runtime_3.7.0.v20110110.jar
7ff7de9e8000-7ff7de9ea000 r--s 00000000 00:24 1110118 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.core.filebuffers.nl_zh_3.6.0.v20121120125106.jar
7ff7de9eb000-7ff7de9ed000 r--s 00004000 00:24 1107843 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-jai.jar
7ff7de9ed000-7ff7de9f0000 ---p 00000000 00:00 0
7ff7de9f0000-7ff7deaee000 rw-p 00000000 00:00 0 [stack:1824]
7ff7deaee000-7ff7deaf3000 r-xp 00000000 00:13 1142 /lib64/libnss_dns-2.17.so
7ff7deaf3000-7ff7decf2000 ---p 00005000 00:13 1142 /lib64/libnss_dns-2.17.so
7ff7decf2000-7ff7decf3000 r--p 00004000 00:13 1142 /lib64/libnss_dns-2.17.so
7ff7decf3000-7ff7decf4000 rw-p 00005000 00:13 1142 /lib64/libnss_dns-2.17.so
7ff7decf4000-7ff7decf6000 r-xp 00000000 00:13 28113 /lib64/libnss_mdns_minimal.so.2
7ff7decf6000-7ff7deef6000 ---p 00002000 00:13 28113 /lib64/libnss_mdns_minimal.so.2
7ff7deef6000-7ff7deef7000 r--p 00002000 00:13 28113 /lib64/libnss_mdns_minimal.so.2
7ff7deef7000-7ff7deef8000 rw-p 00003000 00:13 28113 /lib64/libnss_mdns_minimal.so.2
7ff7deef8000-7ff7def04000 r-xp 00000000 00:13 1153 /lib64/libnss_files-2.17.so
7ff7def04000-7ff7df103000 ---p 0000c000 00:13 1153 /lib64/libnss_files-2.17.so
7ff7df103000-7ff7df104000 r--p 0000b000 00:13 1153 /lib64/libnss_files-2.17.so
7ff7df104000-7ff7df105000 rw-p 0000c000 00:13 1153 /lib64/libnss_files-2.17.so
7ff7df105000-7ff7df107000 r--s 00013000 00:24 1107837 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-commons-net.jar
7ff7df107000-7ff7df108000 r--s 00000000 00:24 1110126 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.core.runtime.nl_zh_3.6.0.v20121120125106.jar
7ff7df109000-7ff7df10b000 r--s 00000000 00:24 1107840 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-commons-logging.jar
7ff7df10b000-7ff7df10e000 r--s 0001c000 00:24 1107388 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.core.io_3.0.3.1366554463.jar
7ff7df10e000-7ff7df10f000 r--s 00000000 00:13 293246 /var/cache/fontconfig/6ba42ae0000f58711b5caaf10d690066-x86_64.cache-4
7ff7df10f000-7ff7df110000 r--s 00001000 00:24 1107842 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-junit4.jar
7ff7df110000-7ff7df112000 r--s 0000d000 00:24 1105853 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.buildpath.core_3.1.0.1358388195.jar
7ff7df112000-7ff7df114000 r--s 00011000 00:24 1105794 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.preview_3.0.0.1369877848.jar
7ff7df114000-7ff7df115000 r--s 00002000 00:24 1107852 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-netrexx.jar
7ff7df115000-7ff7df116000 r--s 00004000 00:24 1107384 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.swt_3.7.2.v3740f.jar
7ff7df116000-7ff7df118000 r--s 00001000 00:24 1107121 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.ui.workbench.compatibility_3.2.100.I20110413-1600/compatibility.jar
7ff7df118000-7ff7df119000 r--s 00009000 00:24 1107845 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-jsch.jar
7ff7df119000-7ff7df11b000 r--s 00000000 00:24 1107855 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-apache-resolver.jar
7ff7df11b000-7ff7df11d000 r--s 00008000 00:24 1107844 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-apache-oro.jar
7ff7df11d000-7ff7df152000 r--s 00000000 00:10 10441 /var/run/nscd/db6MDRCb (deleted)
7ff7df152000-7ff7df162000 r-xp 00000000 00:13 355837 /usr/java/jdk1.7.0_25/jre/lib/amd64/libnio.so
7ff7df162000-7ff7df362000 ---p 00010000 00:13 355837 /usr/java/jdk1.7.0_25/jre/lib/amd64/libnio.so
7ff7df362000-7ff7df363000 rw-p 00010000 00:13 355837 /usr/java/jdk1.7.0_25/jre/lib/amd64/libnio.so
7ff7df363000-7ff7df378000 r-xp 00000000 00:13 355836 /usr/java/jdk1.7.0_25/jre/lib/amd64/libnet.so
7ff7df378000-7ff7df578000 ---p 00015000 00:13 355836 /usr/java/jdk1.7.0_25/jre/lib/amd64/libnet.so
7ff7df578000-7ff7df579000 rw-p 00015000 00:13 355836 /usr/java/jdk1.7.0_25/jre/lib/amd64/libnet.so
7ff7df579000-7ff7df57c000 r-xp 00000000 00:13 256807 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7ff7df57c000-7ff7df77c000 ---p 00003000 00:13 256807 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7ff7df77c000-7ff7df77d000 r--p 00003000 00:13 256807 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7ff7df77d000-7ff7df77e000 rw-p 00004000 00:13 256807 /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7ff7df77e000-7ff7df781000 r-xp 00000000 00:13 258577 /usr/lib64/gtk-2.0/2.10.0/engines/libadwaita.so
7ff7df781000-7ff7df980000 ---p 00003000 00:13 258577 /usr/lib64/gtk-2.0/2.10.0/engines/libadwaita.so
7ff7df980000-7ff7df981000 r--p 00002000 00:13 258577 /usr/lib64/gtk-2.0/2.10.0/engines/libadwaita.so
7ff7df981000-7ff7df982000 rw-p 00003000 00:13 258577 /usr/lib64/gtk-2.0/2.10.0/engines/libadwaita.so
7ff7df982000-7ff7df98b000 r-xp 00000000 00:13 293646 /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7ff7df98b000-7ff7dfb8b000 ---p 00009000 00:13 293646 /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7ff7dfb8b000-7ff7dfb8c000 r--p 00009000 00:13 293646 /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7ff7dfb8c000-7ff7dfb8d000 rw-p 0000a000 00:13 293646 /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7ff7dfb8d000-7ff7dfb93000 r-xp 00000000 00:13 32741 /usr/lib64/libogg.so.0.8.0
7ff7dfb93000-7ff7dfd92000 ---p 00006000 00:13 32741 /usr/lib64/libogg.so.0.8.0
7ff7dfd92000-7ff7dfd93000 r--p 00005000 00:13 32741 /usr/lib64/libogg.so.0.8.0
7ff7dfd93000-7ff7dfd94000 rw-p 00006000 00:13 32741 /usr/lib64/libogg.so.0.8.0
7ff7dfd94000-7ff7dfdc0000 r-xp 00000000 00:13 32159 /usr/lib64/libvorbis.so.0.4.6
7ff7dfdc0000-7ff7dffc0000 ---p 0002c000 00:13 32159 /usr/lib64/libvorbis.so.0.4.6
7ff7dffc0000-7ff7dffc1000 r--p 0002c000 00:13 32159 /usr/lib64/libvorbis.so.0.4.6
7ff7dffc1000-7ff7dffc2000 rw-p 0002d000 00:13 32159 /usr/lib64/libvorbis.so.0.4.6
7ff7dffc2000-7ff7dffcb000 r-xp 00000000 00:13 32679 /usr/lib64/libltdl.so.7.3.0
7ff7dffcb000-7ff7e01ca000 ---p 00009000 00:13 32679 /usr/lib64/libltdl.so.7.3.0
7ff7e01ca000-7ff7e01cb000 r--p 00008000 00:13 32679 /usr/lib64/libltdl.so.7.3.0
7ff7e01cb000-7ff7e01cc000 rw-p 00009000 00:13 32679 /usr/lib64/libltdl.so.7.3.0
7ff7e01cc000-7ff7e01d4000 r-xp 00000000 00:13 32680 /usr/lib64/libvorbisfile.so.3.3.5
7ff7e01d4000-7ff7e03d3000 ---p 00008000 00:13 32680 /usr/lib64/libvorbisfile.so.3.3.5
7ff7e03d3000-7ff7e03d4000 r--p 00007000 00:13 32680 /usr/lib64/libvorbisfile.so.3.3.5
7ff7e03d4000-7ff7e03d5000 rw-p 00008000 00:13 32680 /usr/lib64/libvorbisfile.so.3.3.5
7ff7e03d5000-7ff7e03e3000 r-xp 00000000 00:13 32590 /usr/lib64/libcanberra.so.0.2.5
7ff7e03e3000-7ff7e05e2000 ---p 0000e000 00:13 32590 /usr/lib64/libcanberra.so.0.2.5
7ff7e05e2000-7ff7e05e3000 r--p 0000d000 00:13 32590 /usr/lib64/libcanberra.so.0.2.5
7ff7e05e3000-7ff7e05e4000 rw-p 0000e000 00:13 32590 /usr/lib64/libcanberra.so.0.2.5
7ff7e05e4000-7ff7e05e8000 r-xp 00000000 00:13 32631 /usr/lib64/libcanberra-gtk.so.0.1.9
7ff7e05e8000-7ff7e07e7000 ---p 00004000 00:13 32631 /usr/lib64/libcanberra-gtk.so.0.1.9
7ff7e07e7000-7ff7e07e8000 r--p 00003000 00:13 32631 /usr/lib64/libcanberra-gtk.so.0.1.9
7ff7e07e8000-7ff7e07e9000 rw-p 00004000 00:13 32631 /usr/lib64/libcanberra-gtk.so.0.1.9
7ff7e07e9000-7ff7e07ee000 r-xp 00000000 00:13 32242 /usr/lib64/gtk-2.0/modules/libcanberra-gtk-module.so
7ff7e07ee000-7ff7e09ed000 ---p 00005000 00:13 32242 /usr/lib64/gtk-2.0/modules/libcanberra-gtk-module.so
7ff7e09ed000-7ff7e09ee000 r--p 00004000 00:13 32242 /usr/lib64/gtk-2.0/modules/libcanberra-gtk-module.so
7ff7e09ee000-7ff7e09ef000 rw-p 00005000 00:13 32242 /usr/lib64/gtk-2.0/modules/libcanberra-gtk-module.so
7ff7e09ef000-7ff7e0a10000 r-xp 00000000 00:13 256448 /usr/lib64/libatk-1.0.so.0.20809.1
7ff7e0a10000-7ff7e0c10000 ---p 00021000 00:13 256448 /usr/lib64/libatk-1.0.so.0.20809.1
7ff7e0c10000-7ff7e0c12000 r--p 00021000 00:13 256448 /usr/lib64/libatk-1.0.so.0.20809.1
7ff7e0c12000-7ff7e0c13000 rw-p 00023000 00:13 256448 /usr/lib64/libatk-1.0.so.0.20809.1
7ff7e0c13000-7ff7e103f000 r-xp 00000000 00:13 293659 /usr/lib64/libgtk-x11-2.0.so.0.2400.18
7ff7e103f000-7ff7e123f000 ---p 0042c000 00:13 293659 /usr/lib64/libgtk-x11-2.0.so.0.2400.18
7ff7e123f000-7ff7e1246000 r--p 0042c000 00:13 293659 /usr/lib64/libgtk-x11-2.0.so.0.2400.18
7ff7e1246000-7ff7e124a000 rw-p 00433000 00:13 293659 /usr/lib64/libgtk-x11-2.0.so.0.2400.18
7ff7e124a000-7ff7e124c000 rw-p 00000000 00:00 0
7ff7e124c000-7ff7e236c000 r--p 00000000 00:13 21853 /usr/lib64/libicudata.so.49.1
7ff7e236c000-7ff7e256b000 ---p 01120000 00:13 21853 /usr/lib64/libicudata.so.49.1
7ff7e256b000-7ff7e256c000 r--p 0111f000 00:13 21853 /usr/lib64/libicudata.so.49.1
7ff7e256c000-7ff7e2581000 r-xp 00000000 00:13 1144 /lib64/libgcc_s.so.1
7ff7e2581000-7ff7e2780000 ---p 00015000 00:13 1144 /lib64/libgcc_s.so.1
7ff7e2780000-7ff7e2781000 r--p 00014000 00:13 1144 /lib64/libgcc_s.so.1
7ff7e2781000-7ff7e2782000 rw-p 00015000 00:13 1144 /lib64/libgcc_s.so.1
7ff7e2782000-7ff7e286a000 r-xp 00000000 00:13 19905 /usr/lib64/libstdc++.so.6.0.17
7ff7e286a000-7ff7e2a69000 ---p 000e8000 00:13 19905 /usr/lib64/libstdc++.so.6.0.17
7ff7e2a69000-7ff7e2a71000 r--p 000e7000 00:13 19905 /usr/lib64/libstdc++.so.6.0.17
7ff7e2a71000-7ff7e2a73000 rw-p 000ef000 00:13 19905 /usr/lib64/libstdc++.so.6.0.17
7ff7e2a73000-7ff7e2a88000 rw-p 00000000 00:00 0
7ff7e2a88000-7ff7e2bf0000 r-xp 00000000 00:13 21873 /usr/lib64/libicuuc.so.49.1
7ff7e2bf0000-7ff7e2def000 ---p 00168000 00:13 21873 /usr/lib64/libicuuc.so.49.1
7ff7e2def000-7ff7e2e00000 r--p 00167000 00:13 21873 /usr/lib64/libicuuc.so.49.1
7ff7e2e00000-7ff7e2e01000 rw-p 00178000 00:13 21873 /usr/lib64/libicuuc.so.49.1
7ff7e2e01000-7ff7e2e05000 rw-p 00000000 00:00 0
7ff7e2e05000-7ff7e2e45000 r-xp 00000000 00:13 22074 /usr/lib64/libicule.so.49.1
7ff7e2e45000-7ff7e3045000 ---p 00040000 00:13 22074 /usr/lib64/libicule.so.49.1
7ff7e3045000-7ff7e3047000 r--p 00040000 00:13 22074 /usr/lib64/libicule.so.49.1
7ff7e3047000-7ff7e3048000 rw-p 00042000 00:13 22074 /usr/lib64/libicule.so.49.1
7ff7e3048000-7ff7e304b000 r-xp 00000000 00:13 21871 /usr/lib64/libXau.so.6.0.0
7ff7e304b000-7ff7e324a000 ---p 00003000 00:13 21871 /usr/lib64/libXau.so.6.0.0
7ff7e324a000-7ff7e324b000 r--p 00002000 00:13 21871 /usr/lib64/libXau.so.6.0.0
7ff7e324b000-7ff7e324c000 rw-p 00003000 00:13 21871 /usr/lib64/libXau.so.6.0.0
7ff7e324c000-7ff7e32e4000 r-xp 00000000 00:13 256420 /usr/lib64/libharfbuzz.so.0.914.0
7ff7e32e4000-7ff7e34e3000 ---p 00098000 00:13 256420 /usr/lib64/libharfbuzz.so.0.914.0
7ff7e34e3000-7ff7e34e5000 r--p 00097000 00:13 256420 /usr/lib64/libharfbuzz.so.0.914.0
7ff7e34e5000-7ff7e34e6000 rw-p 00099000 00:13 256420 /usr/lib64/libharfbuzz.so.0.914.0
7ff7e34e6000-7ff7e3504000 r-xp 00000000 00:13 169806 /usr/lib64/libxcb.so.1.1.0
7ff7e3504000-7ff7e3704000 ---p 0001e000 00:13 169806 /usr/lib64/libxcb.so.1.1.0
7ff7e3704000-7ff7e3705000 r--p 0001e000 00:13 169806 /usr/lib64/libxcb.so.1.1.0
7ff7e3705000-7ff7e3706000 rw-p 0001f000 00:13 169806 /usr/lib64/libxcb.so.1.1.0
7ff7e3706000-7ff7e370e000 r-xp 00000000 00:13 178785 /usr/lib64/libxcb-render.so.0.0.0
7ff7e370e000-7ff7e390e000 ---p 00008000 00:13 178785 /usr/lib64/libxcb-render.so.0.0.0
7ff7e390e000-7ff7e390f000 r--p 00008000 00:13 178785 /usr/lib64/libxcb-render.so.0.0.0
7ff7e390f000-7ff7e3910000 rw-p 00009000 00:13 178785 /usr/lib64/libxcb-render.so.0.0.0
7ff7e3910000-7ff7e393e000 r-xp 00000000 00:13 21872 /usr/lib64/libpng15.so.15.13.0
7ff7e393e000-7ff7e3b3d000 ---p 0002e000 00:13 21872 /usr/lib64/libpng15.so.15.13.0
7ff7e3b3d000-7ff7e3b3e000 r--p 0002d000 00:13 21872 /usr/lib64/libpng15.so.15.13.0
7ff7e3b3e000-7ff7e3b3f000 rw-p 0002e000 00:13 21872 /usr/lib64/libpng15.so.15.13.0
7ff7e3b3f000-7ff7e3bd0000 r-xp 00000000 00:13 21848 /usr/lib64/libpixman-1.so.0.28.2
7ff7e3bd0000-7ff7e3dcf000 ---p 00091000 00:13 21848 /usr/lib64/libpixman-1.so.0.28.2
7ff7e3dcf000-7ff7e3dd6000 r--p 00090000 00:13 21848 /usr/lib64/libpixman-1.so.0.28.2
7ff7e3dd6000-7ff7e3dd7000 rw-p 00097000 00:13 21848 /usr/lib64/libpixman-1.so.0.28.2
7ff7e3dd7000-7ff7e3dfd000 r-xp 00000000 00:13 21868 /usr/lib64/libexpat.so.1.6.0
7ff7e3dfd000-7ff7e3ffd000 ---p 00026000 00:13 21868 /usr/lib64/libexpat.so.1.6.0
7ff7e3ffd000-7ff7e3fff000 r--p 00026000 00:13 21868 /usr/lib64/libexpat.so.1.6.0
7ff7e3fff000-7ff7e4000000 rw-p 00028000 00:13 21868 /usr/lib64/libexpat.so.1.6.0
7ff7e4000000-7ff7e4021000 rw-p 00000000 00:00 0
7ff7e4021000-7ff7e8000000 ---p 00000000 00:00 0
7ff7e8000000-7ff7e8001000 r--s 00001000 00:24 1107848 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-jmf.jar
7ff7e8001000-7ff7e8002000 r--s 00003000 00:13 355978 /usr/java/jdk1.7.0_25/jre/lib/ext/sunec.jar
7ff7e8002000-7ff7e8003000 r--s 00003000 00:24 1110222 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.ui.workbench.texteditor.nl_zh_3.6.0.v20121120125106.jar
7ff7e8003000-7ff7e8004000 r--s 00000000 00:24 1107851 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-apache-log4j.jar
7ff7e8004000-7ff7e8005000 r--s 00001000 00:24 1107857 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-javamail.jar
7ff7e8005000-7ff7e8006000 r--s 00000000 00:24 1107836 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-apache-xalan2.jar
7ff7e8006000-7ff7e8008000 r--s 00000000 00:24 1107847 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-apache-bsf.jar
7ff7e8008000-7ff7e800a000 r-xp 00000000 00:13 178773 /usr/lib64/libxcb-shm.so.0.0.0
7ff7e800a000-7ff7e8209000 ---p 00002000 00:13 178773 /usr/lib64/libxcb-shm.so.0.0.0
7ff7e8209000-7ff7e820a000 r--p 00001000 00:13 178773 /usr/lib64/libxcb-shm.so.0.0.0
7ff7e820a000-7ff7e820b000 rw-p 00002000 00:13 178773 /usr/lib64/libxcb-shm.so.0.0.0
7ff7e820b000-7ff7e821e000 r-xp 00000000 00:13 1150 /lib64/libresolv-2.17.so
7ff7e821e000-7ff7e841e000 ---p 00013000 00:13 1150 /lib64/libresolv-2.17.so
7ff7e841e000-7ff7e841f000 r--p 00013000 00:13 1150 /lib64/libresolv-2.17.so
7ff7e841f000-7ff7e8420000 rw-p 00014000 00:13 1150 /lib64/libresolv-2.17.so
7ff7e8420000-7ff7e8422000 rw-p 00000000 00:00 0
7ff7e8422000-7ff7e8440000 r-xp 00000000 00:13 1177 /lib64/libselinux.so.1
7ff7e8440000-7ff7e863f000 ---p 0001e000 00:13 1177 /lib64/libselinux.so.1
7ff7e863f000-7ff7e8640000 r--p 0001d000 00:13 1177 /lib64/libselinux.so.1
7ff7e8640000-7ff7e8641000 rw-p 0001e000 00:13 1177 /lib64/libselinux.so.1
7ff7e8641000-7ff7e8642000 rw-p 00000000 00:00 0
7ff7e8642000-7ff7e8657000 r-xp 00000000 00:13 1178 /lib64/libz.so.1.2.7
7ff7e8657000-7ff7e8856000 ---p 00015000 00:13 1178 /lib64/libz.so.1.2.7
7ff7e8856000-7ff7e8857000 r--p 00014000 00:13 1178 /lib64/libz.so.1.2.7
7ff7e8857000-7ff7e8858000 rw-p 00015000 00:13 1178 /lib64/libz.so.1.2.7
7ff7e8858000-7ff7e885b000 r-xp 00000000 00:13 256329 /usr/lib64/libgmodule-2.0.so.0.3600.3
7ff7e885b000-7ff7e8a5a000 ---p 00003000 00:13 256329 /usr/lib64/libgmodule-2.0.so.0.3600.3
7ff7e8a5a000-7ff7e8a5b000 r--p 00002000 00:13 256329 /usr/lib64/libgmodule-2.0.so.0.3600.3
7ff7e8a5b000-7ff7e8a5c000 rw-p 00003000 00:13 256329 /usr/lib64/libgmodule-2.0.so.0.3600.3
7ff7e8a5c000-7ff7e8ae4000 r-xp 00000000 00:13 22127 /usr/lib64/libfreetype.so.6.10.0
7ff7e8ae4000-7ff7e8ce4000 ---p 00088000 00:13 22127 /usr/lib64/libfreetype.so.6.10.0
7ff7e8ce4000-7ff7e8ce9000 r--p 00088000 00:13 22127 /usr/lib64/libfreetype.so.6.10.0
7ff7e8ce9000-7ff7e8cea000 rw-p 0008d000 00:13 22127 /usr/lib64/libfreetype.so.6.10.0
7ff7e8cea000-7ff7e8cfd000 r-xp 00000000 00:13 256599 /usr/lib64/libpangoft2-1.0.so.0.3400.1
7ff7e8cfd000-7ff7e8efc000 ---p 00013000 00:13 256599 /usr/lib64/libpangoft2-1.0.so.0.3400.1
7ff7e8efc000-7ff7e8efd000 r--p 00012000 00:13 256599 /usr/lib64/libpangoft2-1.0.so.0.3400.1
7ff7e8efd000-7ff7e8efe000 rw-p 00013000 00:13 256599 /usr/lib64/libpangoft2-1.0.so.0.3400.1
7ff7e8efe000-7ff7e8f0f000 r-xp 00000000 00:13 179549 /usr/lib64/libXext.so.6.4.0
7ff7e8f0f000-7ff7e910e000 ---p 00011000 00:13 179549 /usr/lib64/libXext.so.6.4.0
7ff7e910e000-7ff7e910f000 r--p 00010000 00:13 179549 /usr/lib64/libXext.so.6.4.0
7ff7e910f000-7ff7e9110000 rw-p 00011000 00:13 179549 /usr/lib64/libXext.so.6.4.0
7ff7e9110000-7ff7e9246000 r-xp 00000000 00:13 178761 /usr/lib64/libX11.so.6.3.0
7ff7e9246000-7ff7e9446000 ---p 00136000 00:13 178761 /usr/lib64/libX11.so.6.3.0
7ff7e9446000-7ff7e9447000 r--p 00136000 00:13 178761 /usr/lib64/libX11.so.6.3.0
7ff7e9447000-7ff7e944c000 rw-p 00137000 00:13 178761 /usr/lib64/libX11.so.6.3.0
7ff7e944c000-7ff7e9546000 r-xp 00000000 00:13 180761 /usr/lib64/libcairo.so.2.11200.8
7ff7e9546000-7ff7e9745000 ---p 000fa000 00:13 180761 /usr/lib64/libcairo.so.2.11200.8
7ff7e9745000-7ff7e9748000 r--p 000f9000 00:13 180761 /usr/lib64/libcairo.so.2.11200.8
7ff7e9748000-7ff7e9749000 rw-p 000fc000 00:13 180761 /usr/lib64/libcairo.so.2.11200.8
7ff7e9749000-7ff7e974b000 rw-p 00000000 00:00 0
7ff7e974b000-7ff7e976a000 r-xp 00000000 00:13 256824 /usr/lib64/libgdk_pixbuf-2.0.so.0.2800.2
7ff7e976a000-7ff7e9969000 ---p 0001f000 00:13 256824 /usr/lib64/libgdk_pixbuf-2.0.so.0.2800.2
7ff7e9969000-7ff7e996a000 r--p 0001e000 00:13 256824 /usr/lib64/libgdk_pixbuf-2.0.so.0.2800.2
7ff7e996a000-7ff7e996b000 rw-p 0001f000 00:13 256824 /usr/lib64/libgdk_pixbuf-2.0.so.0.2800.2
7ff7e996b000-7ff7e9970000 r-xp 00000000 00:13 179541 /usr/lib64/libXfixes.so.3.1.0
7ff7e9970000-7ff7e9b6f000 ---p 00005000 00:13 179541 /usr/lib64/libXfixes.so.3.1.0
7ff7e9b6f000-7ff7e9b70000 r--p 00004000 00:13 179541 /usr/lib64/libXfixes.so.3.1.0
7ff7e9b70000-7ff7e9b71000 rw-p 00005000 00:13 179541 /usr/lib64/libXfixes.so.3.1.0
7ff7e9b71000-7ff7e9b73000 r-xp 00000000 00:13 27652 /usr/lib64/libXdamage.so.1.1.0
7ff7e9b73000-7ff7e9d72000 ---p 00002000 00:13 27652 /usr/lib64/libXdamage.so.1.1.0
7ff7e9d72000-7ff7e9d73000 r--p 00001000 00:13 27652 /usr/lib64/libXdamage.so.1.1.0
7ff7e9d73000-7ff7e9d74000 rw-p 00002000 00:13 27652 /usr/lib64/libXdamage.so.1.1.0
7ff7e9d74000-7ff7e9d76000 r-xp 00000000 00:13 27657 /usr/lib64/libXcomposite.so.1.0.0
7ff7e9d76000-7ff7e9f75000 ---p 00002000 00:13 27657 /usr/lib64/libXcomposite.so.1.0.0
7ff7e9f75000-7ff7e9f76000 r--p 00001000 00:13 27657 /usr/lib64/libXcomposite.so.1.0.0
7ff7e9f76000-7ff7e9f77000 rw-p 00002000 00:13 27657 /usr/lib64/libXcomposite.so.1.0.0
7ff7e9f77000-7ff7e9f81000 r-xp 00000000 00:13 180755 /usr/lib64/libXcursor.so.1.0.2
7ff7e9f81000-7ff7ea180000 ---p 0000a000 00:13 180755 /usr/lib64/libXcursor.so.1.0.2
7ff7ea180000-7ff7ea181000 r--p 00009000 00:13 180755 /usr/lib64/libXcursor.so.1.0.2
7ff7ea181000-7ff7ea182000 rw-p 0000a000 00:13 180755 /usr/lib64/libXcursor.so.1.0.2
7ff7ea182000-7ff7ea18b000 r-xp 00000000 00:13 180812 /usr/lib64/libXrandr.so.2.2.0
7ff7ea18b000-7ff7ea38a000 ---p 00009000 00:13 180812 /usr/lib64/libXrandr.so.2.2.0
7ff7ea38a000-7ff7ea38b000 r--p 00008000 00:13 180812 /usr/lib64/libXrandr.so.2.2.0
7ff7ea38b000-7ff7ea38c000 rw-p 00009000 00:13 180812 /usr/lib64/libXrandr.so.2.2.0
7ff7ea38c000-7ff7ea39b000 r-xp 00000000 00:13 180824 /usr/lib64/libXi.so.6.1.0
7ff7ea39b000-7ff7ea59a000 ---p 0000f000 00:13 180824 /usr/lib64/libXi.so.6.1.0
7ff7ea59a000-7ff7ea59b000 r--p 0000e000 00:13 180824 /usr/lib64/libXi.so.6.1.0
7ff7ea59b000-7ff7ea59c000 rw-p 0000f000 00:13 180824 /usr/lib64/libXi.so.6.1.0
7ff7ea59c000-7ff7ea59e000 r-xp 00000000 00:13 180818 /usr/lib64/libXinerama.so.1.0.0
7ff7ea59e000-7ff7ea79d000 ---p 00002000 00:13 180818 /usr/lib64/libXinerama.so.1.0.0
7ff7ea79d000-7ff7ea79e000 r--p 00001000 00:13 180818 /usr/lib64/libXinerama.so.1.0.0
7ff7ea79e000-7ff7ea79f000 rw-p 00002000 00:13 180818 /usr/lib64/libXinerama.so.1.0.0
7ff7ea79f000-7ff7ea7a8000 r-xp 00000000 00:13 179535 /usr/lib64/libXrender.so.1.3.0
7ff7ea7a8000-7ff7ea9a7000 ---p 00009000 00:13 179535 /usr/lib64/libXrender.so.1.3.0
7ff7ea9a7000-7ff7ea9a8000 r--p 00008000 00:13 179535 /usr/lib64/libXrender.so.1.3.0
7ff7ea9a8000-7ff7ea9a9000 rw-p 00009000 00:13 179535 /usr/lib64/libXrender.so.1.3.0
7ff7ea9a9000-7ff7ea9e3000 r-xp 00000000 00:13 256017 /usr/lib64/libfontconfig.so.1.7.0
7ff7ea9e3000-7ff7eabe2000 ---p 0003a000 00:13 256017 /usr/lib64/libfontconfig.so.1.7.0
7ff7eabe2000-7ff7eabe4000 r--p 00039000 00:13 256017 /usr/lib64/libfontconfig.so.1.7.0
7ff7eabe4000-7ff7eabe5000 rw-p 0003b000 00:13 256017 /usr/lib64/libfontconfig.so.1.7.0
7ff7eabe5000-7ff7ead3b000 r-xp 00000000 00:13 256620 /usr/lib64/libgio-2.0.so.0.3600.3
7ff7ead3b000-7ff7eaf3a000 ---p 00156000 00:13 256620 /usr/lib64/libgio-2.0.so.0.3600.3
7ff7eaf3a000-7ff7eaf3e000 r--p 00155000 00:13 256620 /usr/lib64/libgio-2.0.so.0.3600.3
7ff7eaf3e000-7ff7eaf40000 rw-p 00159000 00:13 256620 /usr/lib64/libgio-2.0.so.0.3600.3
7ff7eaf40000-7ff7eaf42000 rw-p 00000000 00:00 0
7ff7eaf42000-7ff7eaf8b000 r-xp 00000000 00:13 256595 /usr/lib64/libpango-1.0.so.0.3400.1
7ff7eaf8b000-7ff7eb18a000 ---p 00049000 00:13 256595 /usr/lib64/libpango-1.0.so.0.3400.1
7ff7eb18a000-7ff7eb18c000 r--p 00048000 00:13 256595 /usr/lib64/libpango-1.0.so.0.3400.1
7ff7eb18c000-7ff7eb18d000 rw-p 0004a000 00:13 256595 /usr/lib64/libpango-1.0.so.0.3400.1
7ff7eb18d000-7ff7eb199000 r-xp 00000000 00:13 256597 /usr/lib64/libpangocairo-1.0.so.0.3400.1
7ff7eb199000-7ff7eb398000 ---p 0000c000 00:13 256597 /usr/lib64/libpangocairo-1.0.so.0.3400.1
7ff7eb398000-7ff7eb399000 r--p 0000b000 00:13 256597 /usr/lib64/libpangocairo-1.0.so.0.3400.1
7ff7eb399000-7ff7eb39a000 rw-p 0000c000 00:13 256597 /usr/lib64/libpangocairo-1.0.so.0.3400.1
7ff7eb39a000-7ff7eb449000 r-xp 00000000 00:13 293657 /usr/lib64/libgdk-x11-2.0.so.0.2400.18
7ff7eb449000-7ff7eb648000 ---p 000af000 00:13 293657 /usr/lib64/libgdk-x11-2.0.so.0.2400.18
7ff7eb648000-7ff7eb64c000 r--p 000ae000 00:13 293657 /usr/lib64/libgdk-x11-2.0.so.0.2400.18
7ff7eb64c000-7ff7eb64e000 rw-p 000b2000 00:13 293657 /usr/lib64/libgdk-x11-2.0.so.0.2400.18
7ff7eb64e000-7ff7eb6a9000 r-xp 00000000 00:13 21865 /usr/lib64/libpcre.so.1.0.1
7ff7eb6a9000-7ff7eb8a9000 ---p 0005b000 00:13 21865 /usr/lib64/libpcre.so.1.0.1
7ff7eb8a9000-7ff7eb8aa000 r--p 0005b000 00:13 21865 /usr/lib64/libpcre.so.1.0.1
7ff7eb8aa000-7ff7eb8ab000 rw-p 0005c000 00:13 21865 /usr/lib64/libpcre.so.1.0.1
7ff7eb8ab000-7ff7eb8b2000 r-xp 00000000 00:13 19900 /usr/lib64/libffi.so.4.0.1
7ff7eb8b2000-7ff7ebab1000 ---p 00007000 00:13 19900 /usr/lib64/libffi.so.4.0.1
7ff7ebab1000-7ff7ebab2000 r--p 00006000 00:13 19900 /usr/lib64/libffi.so.4.0.1
7ff7ebab2000-7ff7ebab3000 rw-p 00007000 00:13 19900 /usr/lib64/libffi.so.4.0.1
7ff7ebab3000-7ff7ebbaf000 r-xp 00000000 00:13 256123 /usr/lib64/libglib-2.0.so.0.3600.3
7ff7ebbaf000-7ff7ebdae000 ---p 000fc000 00:13 256123 /usr/lib64/libglib-2.0.so.0.3600.3
7ff7ebdae000-7ff7ebdaf000 r--p 000fb000 00:13 256123 /usr/lib64/libglib-2.0.so.0.3600.3
7ff7ebdaf000-7ff7ebdb0000 rw-p 000fc000 00:13 256123 /usr/lib64/libglib-2.0.so.0.3600.3
7ff7ebdb0000-7ff7ebdb1000 rw-p 00000000 00:00 0
7ff7ebdb1000-7ff7ebdfe000 r-xp 00000000 00:13 256323 /usr/lib64/libgobject-2.0.so.0.3600.3
7ff7ebdfe000-7ff7ebffe000 ---p 0004d000 00:13 256323 /usr/lib64/libgobject-2.0.so.0.3600.3
7ff7ebffe000-7ff7ebfff000 r--p 0004d000 00:13 256323 /usr/lib64/libgobject-2.0.so.0.3600.3
7ff7ebfff000-7ff7ec000000 rw-p 0004e000 00:13 256323 /usr/lib64/libgobject-2.0.so.0.3600.3
7ff7ec000000-7ff7ee91c000 rw-p 00000000 00:00 0
7ff7ee91c000-7ff7f0000000 ---p 00000000 00:00 0
7ff7f0000000-7ff7f0140000 rw-p 00000000 00:00 0
7ff7f0140000-7ff7f4000000 ---p 00000000 00:00 0
7ff7f4000000-7ff7f448b000 rw-p 00000000 00:00 0
7ff7f448b000-7ff7f8000000 ---p 00000000 00:00 0
7ff7f8000000-7ff7f94d1000 rw-p 00000000 00:00 0
7ff7f94d1000-7ff7fc000000 ---p 00000000 00:00 0
7ff7fc000000-7ff7fc07c000 rw-p 00000000 00:00 0
7ff7fc07c000-7ff800000000 ---p 00000000 00:00 0
7ff800000000-7ff800021000 rw-p 00000000 00:00 0
7ff800021000-7ff804000000 ---p 00000000 00:00 0
7ff804000000-7ff8040bd000 rw-p 00000000 00:00 0
7ff8040bd000-7ff808000000 ---p 00000000 00:00 0
7ff808000000-7ff8080d1000 rw-p 00000000 00:00 0
7ff8080d1000-7ff80c000000 ---p 00000000 00:00 0
7ff80c000000-7ff80c142000 rw-p 00000000 00:00 0
7ff80c142000-7ff810000000 ---p 00000000 00:00 0
7ff810000000-7ff810001000 r--s 00001000 00:24 1107119 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.ui.override_1.0.0.1362523908.jar
7ff810001000-7ff810002000 r--s 0000d000 00:24 1107053 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.core.epl_3.0.0.1344341997.jar
7ff810002000-7ff810003000 r--s 00003000 00:24 1107850 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-testutil.jar
7ff810003000-7ff810004000 r--s 00001000 00:24 1107846 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-swing.jar
7ff810004000-7ff810006000 r--s 00006000 00:24 1110221 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.ui.workbench.nl_zh_3.6.0.v20121120125106.jar
7ff810006000-7ff810008000 r--s 00001000 00:24 1107841 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-apache-bcel.jar
7ff810008000-7ff81000c000 r--s 0002e000 00:24 1106963 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.theme_3.0.0.1364595254.jar
7ff81000c000-7ff81000d000 r--s 00001000 00:24 1105784 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.editor.common.override_1.0.0.1351531287.jar
7ff81000d000-7ff810010000 r--s 0001c000 00:24 1107391 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.projects_3.0.0.1368601846.jar
7ff810011000-7ff810012000 r--s 00000000 00:10 17309 /run/user/1000/dconf/user
7ff810012000-7ff810014000 r--s 00000000 00:24 1107853 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-apache-regexp.jar
7ff810014000-7ff810015000 r--s 00000000 00:24 1110200 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.swt.nl_zh_3.6.0.v20121120125106.jar
7ff810015000-7ff810016000 r--s 00000000 00:24 1110095 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.compare.core.nl_zh_3.6.0.v20121120125106.jar
7ff810016000-7ff81002a000 r--s 0013a000 00:24 1107754 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.osgi_3.7.2.v20120110-1415.jar
7ff81002a000-7ff81008a000 rw-s 00000000 00:04 458756 /SYSV00000000 (deleted)
7ff81008a000-7ff810101000 rw-p 00000000 00:00 0
7ff810101000-7ff81011d000 r--s 00000000 00:13 348300 /usr/share/mime/mime.cache
7ff81011d000-7ff810141000 r--p 00000000 00:13 58500 /usr/share/locale-bundle/zh_CN/LC_MESSAGES/gtk20-properties.mo
7ff810141000-7ff810150000 r-xp 00000000 00:24 1107101 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.100.v20110505/eclipse_1407.so
7ff810150000-7ff81024f000 ---p 0000f000 00:24 1107101 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.100.v20110505/eclipse_1407.so
7ff81024f000-7ff810251000 rw-p 0000e000 00:24 1107101 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.100.v20110505/eclipse_1407.so
7ff810251000-7ff810252000 ---p 00000000 00:00 0
7ff810252000-7ff810352000 rw-p 00000000 00:00 0 [stack:1822]
7ff810352000-7ff810355000 ---p 00000000 00:00 0
7ff810355000-7ff810453000 rw-p 00000000 00:00 0 [stack:1821]
7ff810453000-7ff810456000 ---p 00000000 00:00 0
7ff810456000-7ff810554000 rw-p 00000000 00:00 0 [stack:1820]
7ff810554000-7ff810557000 ---p 00000000 00:00 0
7ff810557000-7ff810655000 rw-p 00000000 00:00 0 [stack:1819]
7ff810655000-7ff810658000 ---p 00000000 00:00 0
7ff810658000-7ff810756000 rw-p 00000000 00:00 0 [stack:1818]
7ff810756000-7ff810795000 r--p 00000000 00:13 16797 /usr/lib/locale/zh_CN.utf8/LC_CTYPE
7ff810795000-7ff8108f9000 r--p 00000000 00:13 17642 /usr/lib/locale/zh_CN.utf8/LC_COLLATE
7ff8108f9000-7ff8108fc000 ---p 00000000 00:00 0
7ff8108fc000-7ff8109fa000 rw-p 00000000 00:00 0 [stack:1817]
7ff8109fa000-7ff8109fd000 ---p 00000000 00:00 0
7ff8109fd000-7ff810afb000 rw-p 00000000 00:00 0 [stack:1816]
7ff810afb000-7ff810afc000 ---p 00000000 00:00 0
7ff810afc000-7ff811000000 rw-p 00000000 00:00 0 [stack:1815]
7ff811000000-7ff8114a0000 rwxp 00000000 00:00 0
7ff8114a0000-7ff815704000 rw-p 00000000 00:00 0
7ff815704000-7ff818000000 ---p 00000000 00:00 0
7ff818000000-7ff818001000 r--s 00000000 00:24 1110169 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.equinox.registry.nl_zh_3.6.0.v20121120125106.jar
7ff818001000-7ff818004000 r--s 00012000 00:24 1107118 /home/gmg/ 应用 /Aptana_Studio_3/plugins/com.aptana.editor.xml_3.0.0.1364002257.jar
7ff818004000-7ff818008000 r--s 000f7000 00:13 357197 /usr/java/jdk1.7.0_25/jre/lib/ext/localedata.jar
7ff818008000-7ff81800d000 r--p 00000000 00:13 257245 /usr/share/locale/zh_CN/LC_MESSAGES/gdk-pixbuf.mo
7ff81800d000-7ff81800e000 r--s 00002000 00:24 1107110 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.core.runtime.compatibility.registry_3.5.0.v20110505/runtime_registry_compatibility.jar
7ff81800e000-7ff818022000 r--p 00000000 00:13 10184 /usr/share/locale/zh_CN/LC_MESSAGES/libc.mo
7ff818022000-7ff818030000 r--p 00000000 00:13 58501 /usr/share/locale-bundle/zh_CN/LC_MESSAGES/gtk20.mo
7ff818030000-7ff818031000 r--s 00001000 00:24 1107849 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.apache.ant_1.8.2.v20120109-1030/lib/ant-antlr.jar
7ff818031000-7ff818032000 r--s 00000000 00:24 1086567 /home/gmg/.local/share/gvfs-metadata/root
7ff818032000-7ff818033000 r--s 00003000 00:24 1110193 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.osgi.nl_zh_3.6.0.v20121120125106.jar
7ff818033000-7ff818037000 r--s 0008a000 00:13 357194 /usr/java/jdk1.7.0_25/jre/lib/jsse.jar
7ff818037000-7ff818038000 r--s 0000b000 00:24 1107152 /home/gmg/ 应用 /Aptana_Studio_3/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
7ff818038000-7ff818039000 r--p 00000000 00:13 15838 /usr/lib/locale/zh_CN.utf8/LC_NUMERIC
7ff818039000-7ff8185ae000 rw-p 00000000 00:00 0
7ff8185ae000-7ff81876b000 r--s 039f9000 00:13 357193 /usr/java/jdk1.7.0_25/jre/lib/rt.jar
7ff81876b000-7ff81a56b000 rw-p 00000000 00:00 0
7ff81a56b000-7ff81a56c000 ---p 00000000 00:00 0
7ff81a56c000-7ff81a66c000 rw-p 00000000 00:00 0 [stack:1814]
7ff81a66c000-7ff81a66d000 ---p 00000000 00:00 0
7ff81a66d000-7ff81a7a0000 rw-p 00000000 00:00 0 [stack:1813]
7ff81a7a0000-7ff81a7ed000 rw-p 00000000 00:00 0
7ff81a7ed000-7ff81a820000 rw-p 00000000 00:00 0
7ff81a820000-7ff81a86d000 rw-p 00000000 00:00 0
7ff81a86d000-7ff81a8ca000 rw-p 00000000 00:00 0
7ff81a8ca000-7ff81a917000 rw-p 00000000 00:00 0
7ff81a917000-7ff81a96d000 rw-p 00000000 00:00 0
7ff81a96d000-7ff81a981000 rw-p 00000000 00:00 0
7ff81a981000-7ff81aa2e000 rw-p 00000000 00:00 0
7ff81aa2e000-7ff81aa49000 r-xp 00000000 00:13 355849 /usr/java/jdk1.7.0_25/jre/lib/amd64/libzip.so
7ff81aa49000-7ff81ac48000 ---p 0001b000 00:13 355849 /usr/java/jdk1.7.0_25/jre/lib/amd64/libzip.so
7ff81ac48000-7ff81ac49000 rw-p 0001a000 00:13 355849 /usr/java/jdk1.7.0_25/jre/lib/amd64/libzip.so
7ff81ac49000-7ff81ac72000 r-xp 00000000 00:13 355818 /usr/java/jdk1.7.0_25/jre/lib/amd64/libjava.so
7ff81ac72000-7ff81ae72000 ---p 00029000 00:13 355818 /usr/java/jdk1.7.0_25/jre/lib/amd64/libjava.so
7ff81ae72000-7ff81ae74000 rw-p 00029000 00:13 355818 /usr/java/jdk1.7.0_25/jre/lib/amd64/libjava.so
7ff81ae74000-7ff81ae81000 r-xp 00000000 00:13 355848 /usr/java/jdk1.7.0_25/jre/lib/amd64/libverify.so
7ff81ae81000-7ff81b080000 ---p 0000d000 00:13 355848 /usr/java/jdk1.7.0_25/jre/lib/amd64/libverify.so
7ff81b080000-7ff81b082000 rw-p 0000c000 00:13 355848 /usr/java/jdk1.7.0_25/jre/lib/amd64/libverify.so
7ff81b082000-7ff81b089000 r-xp 00000000 00:13 1134 /lib64/librt-2.17.so
7ff81b089000-7ff81b288000 ---p 00007000 00:13 1134 /lib64/librt-2.17.so
7ff81b288000-7ff81b289000 r--p 00006000 00:13 1134 /lib64/librt-2.17.so
7ff81b289000-7ff81b28a000 rw-p 00007000 00:13 1134 /lib64/librt-2.17.so
7ff81b28a000-7ff81b387000 r-xp 00000000 00:13 1180 /lib64/libm-2.17.so
7ff81b387000-7ff81b586000 ---p 000fd000 00:13 1180 /lib64/libm-2.17.so
7ff81b586000-7ff81b587000 r--p 000fc000 00:13 1180 /lib64/libm-2.17.so
7ff81b587000-7ff81b588000 rw-p 000fd000 00:13 1180 /lib64/libm-2.17.so
7ff81b588000-7ff81bfc9000 r-xp 00000000 00:13 355853 /usr/java/jdk1.7.0_25/jre/lib/amd64/server/libjvm.so
7ff81bfc9000-7ff81c1c9000 ---p 00a41000 00:13 355853 /usr/java/jdk1.7.0_25/jre/lib/amd64/server/libjvm.so
7ff81c1c9000-7ff81c26c000 rw-p 00a41000 00:13 355853 /usr/java/jdk1.7.0_25/jre/lib/amd64/server/libjvm.so
7ff81c26c000-7ff81c2a8000 rw-p 00000000 00:00 0
7ff81c2a8000-7ff81c44b000 r-xp 00000000 00:13 1158 /lib64/libc-2.17.so
7ff81c44b000-7ff81c64b000 ---p 001a3000 00:13 1158 /lib64/libc-2.17.so
7ff81c64b000-7ff81c64f000 r--p 001a3000 00:13 1158 /lib64/libc-2.17.so
7ff81c64f000-7ff81c651000 rw-p 001a7000 00:13 1158 /lib64/libc-2.17.so
7ff81c651000-7ff81c655000 rw-p 00000000 00:00 0
7ff81c655000-7ff81c658000 r-xp 00000000 00:13 1181 /lib64/libdl-2.17.so
7ff81c658000-7ff81c857000 ---p 00003000 00:13 1181 /lib64/libdl-2.17.so
7ff81c857000-7ff81c858000 r--p 00002000 00:13 1181 /lib64/libdl-2.17.so
7ff81c858000-7ff81c859000 rw-p 00003000 00:13 1181 /lib64/libdl-2.17.so
7ff81c859000-7ff81c86f000 r-xp 00000000 00:13 355800 /usr/java/jdk1.7.0_25/jre/lib/amd64/jli/libjli.so
7ff81c86f000-7ff81ca6f000 ---p 00016000 00:13 355800 /usr/java/jdk1.7.0_25/jre/lib/amd64/jli/libjli.so
7ff81ca6f000-7ff81ca70000 rw-p 00016000 00:13 355800 /usr/java/jdk1.7.0_25/jre/lib/amd64/jli/libjli.so
7ff81ca70000-7ff81ca87000 r-xp 00000000 00:13 1149 /lib64/libpthread-2.17.so
7ff81ca87000-7ff81cc86000 ---p 00017000 00:13 1149 /lib64/libpthread-2.17.so
7ff81cc86000-7ff81cc87000 r--p 00016000 00:13 1149 /lib64/libpthread-2.17.so
7ff81cc87000-7ff81cc88000 rw-p 00017000 00:13 1149 /lib64/libpthread-2.17.so
7ff81cc88000-7ff81cc8c000 rw-p 00000000 00:00 0
7ff81cc8c000-7ff81ccad000 r-xp 00000000 00:13 1164 /lib64/ld-2.17.so
7ff81ccad000-7ff81ccae000 r--p 00000000 00:13 17641 /usr/lib/locale/zh_CN.utf8/LC_TIME
7ff81ccae000-7ff81ccaf000 r--p 00000000 00:13 17583 /usr/lib/locale/zh_CN.utf8/LC_MONETARY
7ff81ccaf000-7ff81cd0c000 rw-p 00000000 00:00 0
7ff81cd0c000-7ff81cd5a000 rw-p 00000000 00:00 0
7ff81cd5a000-7ff81cd8f000 r--s 00000000 00:10 10439 /var/run/nscd/passwd
7ff81cd8f000-7ff81cd92000 ---p 00000000 00:00 0
7ff81cd92000-7ff81ce94000 rw-p 00000000 00:00 0 [stack:1812]
7ff81ce94000-7ff81ce95000 r--p 00000000 00:13 17425 /usr/lib/locale/zh_CN.utf8/LC_MESSAGES/SYS_LC_MESSAGES
7ff81ce95000-7ff81ce96000 r--p 00000000 00:13 15768 /usr/lib/locale/zh_CN.utf8/LC_PAPER
7ff81ce96000-7ff81ce97000 r--p 00000000 00:13 16799 /usr/lib/locale/zh_CN.utf8/LC_NAME
7ff81ce97000-7ff81ce98000 r--p 00000000 00:13 17582 /usr/lib/locale/zh_CN.utf8/LC_ADDRESS
7ff81ce98000-7ff81ce99000 r--p 00000000 00:13 17581 /usr/lib/locale/zh_CN.utf8/LC_TELEPHONE
7ff81ce99000-7ff81ce9a000 r--p 00000000 00:13 15770 /usr/lib/locale/zh_CN.utf8/LC_MEASUREMENT
7ff81ce9a000-7ff81cea1000 r--s 00000000 00:13 22334 /usr/lib64/gconv/gconv-modules.cache
7ff81cea1000-7ff81cea2000 r--p 00000000 00:13 17643 /usr/lib/locale/zh_CN.utf8/LC_IDENTIFICATION
7ff81cea2000-7ff81ceaa000 rw-s 00000000 00:25 24601 /tmp/hsperfdata_gmg/1811
7ff81ceaa000-7ff81ceab000 rw-p 00000000 00:00 0
7ff81ceab000-7ff81ceac000 r--p 00000000 00:00 0
7ff81ceac000-7ff81cead000 rw-p 00000000 00:00 0
7ff81cead000-7ff81ceae000 r--p 00021000 00:13 1164 /lib64/ld-2.17.so
7ff81ceae000-7ff81ceaf000 rw-p 00022000 00:13 1164 /lib64/ld-2.17.so
7ff81ceaf000-7ff81ceb0000 rw-p 00000000 00:00 0
7fff926e7000-7fff92709000 rw-p 00000000 00:00 0 [stack]
7fff927fe000-7fff92800000 r-xp 00000000 00:00 0 [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
VM Arguments:
jvm_args: -Xms40m -Xmx512m -Declipse.p2.unsignedPolicy=allow -Declipse.log.size.max=10000 -Declipse.log.backup.max=5 -Djava.awt.headless=true -XX:MaxPermSize=256m
java_command: /home/gmg/ 应用 /Aptana_Studio_3//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar -os linux -ws gtk -arch x86_64 -showsplash -launcher /home/gmg/ 应用 /Aptana_Studio_3/AptanaStudio3 -name Aptana Studio 3 --launcher.library /home/gmg/ 应用 /Aptana_Studio_3//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.100.v20110505/eclipse_1407.so -startup /home/gmg/ 应用 /Aptana_Studio_3//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar --launcher.overrideVmargs -exitdata 58003 -vm /usr/bin/java -vmargs -Xms40m -Xmx512m -Declipse.p2.unsignedPolicy=allow -Declipse.log.size.max=10000 -Declipse.log.backup.max=5 -Djava.awt.headless=true -XX:MaxPermSize=256m -jar /home/gmg/ 应用 /Aptana_Studio_3//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=/usr/java/default
JRE_HOME=/usr/java/default/jre
PATH=/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/home/gmg/.bin/
USERNAME=gmg
SHELL=/bin/bash
DISPLAY=:0
HOSTTYPE=x86_64
OSTYPE=linux
MACHTYPE=x86_64-suse-linux
Signal Handlers:
SIGSEGV: [libjvm.so+0x8a26a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x8a26a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x73f3d0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: SIG_IGN, sa_mask[0]=0x00001000, sa_flags=0x10000000
SIGXFSZ: [libjvm.so+0x73f3d0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x73f3d0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x73ed20], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x7410b0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: [libjvm.so+0x7410b0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGTERM: [libjvm.so+0x7410b0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x7410b0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
--------------- S Y S T E M ---------------
OS:openSUSE 12.3 (x86_64)
VERSION = 12.3
CODENAME = Dartmouth
uname:Linux 3.10.2-1.g89066c3-desktop #1 SMP PREEMPT Mon Jul 22 10:29:38 UTC 2013 (89066c3) x86_64
libc:glibc 2.17 NPTL 2.17
rlimit: STACK 8192k, CORE 0k, NPROC 14512, NOFILE 4096, AS infinity
load average:0.41 1.30 0.81
/proc/meminfo:
MemTotal: 1895028 kB
MemFree: 103552 kB
Buffers: 908 kB
Cached: 767292 kB
SwapCached: 0 kB
Active: 779456 kB
Inactive: 870552 kB
Active(anon): 580696 kB
Inactive(anon): 387752 kB
Active(file): 198760 kB
Inactive(file): 482800 kB
Unevictable: 72 kB
Mlocked: 72 kB
SwapTotal: 5243900 kB
SwapFree: 5243900 kB
Dirty: 2184 kB
Writeback: 0 kB
AnonPages: 882048 kB
Mapped: 117908 kB
Shmem: 86468 kB
Slab: 78336 kB
SReclaimable: 45816 kB
SUnreclaim: 32520 kB
KernelStack: 3232 kB
PageTables: 18064 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 6191412 kB
Committed_AS: 2666596 kB
VmallocTotal: 34359738367 kB
VmallocUsed: 355988 kB
VmallocChunk: 34359377128 kB
HardwareCorrupted: 0 kB
AnonHugePages: 475136 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
DirectMap4k: 79488 kB
DirectMap2M: 1927168 kB
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 42 stepping 7, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, tsc, tscinvbit
/proc/cpuinfo:
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 42
model name : Intel(R) Pentium(R) CPU B950 @ 2.10GHz
stepping : 7
microcode : 0x28
cpu MHz : 2100.000
cache size : 2048 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer xsave lahf_lm arat epb xsaveopt pln pts dtherm
bogomips : 4190.77
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 42
stepping : 7
microcode : 0x28
cpu MHz : 2100.000
physical id : 0
siblings : 2
core id : 1
cpu cores : 2
apicid : 2
initial apicid : 2
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bogomips : 4190.77
clflush size : 64
power management:
Memory: 4k page, physical 1895028k(103552k free), swap 5243900k(5243900k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (23.25-b01) for linux-amd64 JRE (1.7.0_25-b15), built on Jun 5 2013 20:48:36 by "java_re" with gcc 4.3.0 20080428 (Red Hat 4.3.0-8)
time: Wed Jul 24 09:29:22 2013
elapsed time: 264 seconds
