linux-ebjp:~ # lspci -vvv | grep Eth
03:00.0 Ethernet controller: Qualcomm Atheros AR8162 Fast Ethernet (rev 08)
这个帖子。继续求助,我用的 openSUSE13.1.
2 楼的方法不怎么奏效。。。
然后编译,
编译报错:
kosmos@linux-ebjp:~/compat-drivers-2013-03-04-u> make >/dev/null
/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.c: In function ‘alx_dispatch_skb’:
/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.c:700:4: error: too few arguments to function ‘__vlan_hwaccel_put_tag’
__vlan_hwaccel_put_tag(skb, ntohs(tag));
In file included from /home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.c:22:0:
/usr/src/linux-3.11.6-4/include/linux/if_vlan.h:236:31: note: declared here
static inline struct sk_buff *__vlan_hwaccel_put_tag(struct sk_buff *skb,
/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.c: In function ‘alx_set_vlan_mode’:
/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.c:1141:17: error: ‘NETIF_F_HW_VLAN_RX’ undeclared (first use in this function)
if (features & NETIF_F_HW_VLAN_RX)
/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.c:1141:17: note: each undeclared identifier is reported only once for each function it appears in
/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.c: In function ‘alx_fix_features’:
/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.c:1158:17: error: ‘NETIF_F_HW_VLAN_RX’ undeclared (first use in this function)
/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.c:1159:15: error: ‘NETIF_F_HW_VLAN_TX’ undeclared (first use in this function)
features |= NETIF_F_HW_VLAN_TX;
/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.c: In function ‘alx_set_features’:
/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.c:1176:18: error: ‘NETIF_F_HW_VLAN_RX’ undeclared (first use in this function)
if (!(changed & NETIF_F_HW_VLAN_RX))
/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.c: In function ‘alx_probe’:
/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.c:2637:10: error: ‘NETIF_F_HW_VLAN_RX’ undeclared (first use in this function)
NETIF_F_HW_VLAN_RX |
/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.c:2640:43: error: ‘NETIF_F_HW_VLAN_TX’ undeclared (first use in this function)
netdev->features = netdev->hw_features | NETIF_F_HW_VLAN_TX;
make[6]: *** [/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx/alx_main.o] 错误 1
make[5]: *** [/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros/alx] 错误 2
make[4]: *** [/home/kosmos/compat-drivers-2013-03-04-u/drivers/net/ethernet/atheros] 错误 2
make[3]: *** [_module_/home/kosmos/compat-drivers-2013-03-04-u] 错误 2
make[2]: *** [sub-make] 错误 2
make[1]: *** [all] 错误 2
make: *** [modules] 错误 2
我之前用的 Mint,报同样的错,看到 openSUSE 有 rpm 包才来的,结果这个也不行。。。
不知道是什么这个错是什么原因?。。。
