openSUSE12.3 64位
显卡 ATI HD 3470
1、先按照的这个放下安装驱动,https://zh.opensuse.org/SDB:ATI_显卡驱动的安装
输入sh 驱动程序名,开始安装提示缺少必要的工具。
然后放弃此法。
官方驱动下有个说明,是否表示内核只支持到3.4
Description:
Automated installer and Display Drivers for Xorg 6.9 to Xserver 1.12 and Kernel version up to 3.4
2、按照 这个方法安装 en.opensuse.org/SDB:AMD_fglrx_legacy
Start a terminal or console of your choice and become to root:
# su
Download the script:
# wget [sebastian-siebert.de/downloads/makerpm-amd-13.1-legacy.sh](http://www.sebastian-siebert.de/downloads/makerpm-amd-13.1-legacy.sh)
Download the checksum file:
# wget [sebastian-siebert.de/downloads/makerpm-amd-13.1-legacy.sh.sha1](http://www.sebastian-siebert.de/downloads/makerpm-amd-13.1-legacy.sh.sha1)
Let's validate against the script:
# sha1sum -c makerpm-amd-13.1-legacy.sh.sha1
The output should be:
# makerpm-amd-13.1-legacy.sh: OK
Change the permission of the script:
# chown root:root makerpm-amd-13.1-legacy.sh && chmod 744 makerpm-amd-13.1-legacy.sh
Run the script with the parameter -i. The script generate the RPM package and install/update automatically it.
# ./makerpm-amd-13.1-legacy.sh -i
安装完成后重启,卡在开机画面,只显示背景画面,其他全部显示。tty也不能进入。
