系统是 32 位
openSUSE 13.1
显卡驱动按照官方的 en.opensuse.org/SDB:AMD_fglrx 做法安装之后,还是有问题。
具体表现就是,屏幕上不时地有小片或者大片的画屏,就是颜色很乱,桌面背景不能正常显示。
硬件应该没问题。因为在 centos 和 win 下面没有出现这样的问题
系统是 32 位
openSUSE 13.1
lsmod | grep fglrx
your meaning is that I did not load the fglrx ?
So I run it, I got this:
linux-cjel:~ # lsmod | grep fglrx
fglrx 8266743 131
button 13664 1 fglrx
It show that fglrx is loaded. isn’t it?
lsmod | grep radeon
I got nothing when I enter this command.
But why I have to install radeon driver? I have fglrx now. Could you explain it more precisely?
不需要。只是看看你显卡装对没有
emm. And my screen is fine now. Maybe just because I reinstall the driver last night. I do not know why those errors occurs however.
Thank you very much.
