请问如何编译 bespin
我在运行./configure 时候报错
==================== Bespin interactive configuration ====================
Seems you have cmake.
In addition to the style, you can have a KWin decoration,
a mac-like menu plasmoid and config plugins IFF you have KDE....
–> Do you want to compile with KDE support? [Y/n]
– WARNING: *** ARGB windows are experimental, performance might suffer ***
– WARNING: *** Variable shadow pixmap sizes will cause glitches on KWin < 4.7.4 and OpenGL ***
– WARNING: *** KDE4 not found, just the style will be built ***
– Found Qt4: /usr/bin/qmake (found suitable version “4.8.5”, minimum required is “4.4.0”)
CMake Error at blib/CMakeLists.txt:47 (install):
install TARGETS given no LIBRARY DESTINATION for shared library target
"QtBespin".
– QtDbus available - Style will support XBar
CMake Warning (dev) at config/CMakeLists.txt:31 (add_executable):
Policy CMP0002 is not set: Logical target names must be globally unique.
Run “cmake --help-policy CMP0002” for policy details. Use the cmake_policy
command to set the policy and suppress this warning.
This warning is for project developers. Use -Wno-dev to suppress it.
