[已解决]Bumblebee 安装后,optirun 命令无效
lspci | grep -i vga:
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 630M] (rev a1)
optirun:
[17618.279941] [ERROR]The Bumblebee daemon has not been started yet or the socket path /var/run/bumblebee.socket was incorrect.
[17618.279967] [ERROR]Could not connect to bumblebee daemon - is it running?
it has already told you what happened:
sudo systemctl enable bumblebeed.service
sudo systemctl start bumblebeed.service
