chih
(chih)
2014 年12 月 28 日 09:20
deadbeef 是 packman 源里的,解码器当然已经装了,还有 gstreamer-0_10-fluendo-mp3 也装了,amarok 和 cmus 都已经可以播放 mp3 了。
但 deadbeef 就是无法播放 mp3(只有 mp3,其他格式都没什么问题,mp3 直接无法识别,打开文件夹看不到 mp3,拖进去也没反应)。
尝试过换其他源的 deadbeef,也放狗搜过,问题照旧,用了几天 cmus 觉得还是喜欢 deadbeef,所以来问一下大家有什么办法?
「更新」 zypper 安装这个 deadbeef-restricted-plugins
deadbeef-restricted-plugins - Restricted plugins Support for deadbeef
/usr/lib64/deadbeef/aac.so
/usr/lib64/deadbeef/ffmpeg.so
/usr/lib64/deadbeef/mpgmad.so
3 files total
chih
(chih)
2014 年12 月 28 日 10:10
官网上的更新日志有一行
added “mpga” extension support (mp3)
但 opensuse 上的 deadbeef 好像没有这个 plugin
loading plugin /usr/lib64/deadbeef/adplug.so
loading plugin /usr/lib64/deadbeef/alac.so
loading plugin /usr/lib64/deadbeef/alsa.so
loading plugin /usr/lib64/deadbeef/artwork.so
loading plugin /usr/lib64/deadbeef/cdda.so
loading plugin /usr/lib64/deadbeef/converter.so
loading plugin /usr/lib64/deadbeef/converter_gtk3.so
loading plugin /usr/lib64/deadbeef/dca.so
loading plugin /usr/lib64/deadbeef/ddb_ao.so
loading plugin /usr/lib64/deadbeef/ddb_dumb.so
loading plugin /usr/lib64/deadbeef/ddb_mono2stereo.so
loading plugin /usr/lib64/deadbeef/ddb_shn.so
loading plugin /usr/lib64/deadbeef/dsp_libsrc.so
loading plugin /usr/lib64/deadbeef/ffap.so
loading plugin /usr/lib64/deadbeef/flac.so
loading plugin /usr/lib64/deadbeef/gme.so
loading plugin /usr/lib64/deadbeef/hotkeys.so
loading plugin /usr/lib64/deadbeef/lastfm.so
loading plugin /usr/lib64/deadbeef/m3u.so
loading plugin /usr/lib64/deadbeef/mms.so
loading plugin /usr/lib64/deadbeef/musepack.so
loading plugin /usr/lib64/deadbeef/notify.so
loading plugin /usr/lib64/deadbeef/nullout.so
loading plugin /usr/lib64/deadbeef/oss.so
loading plugin /usr/lib64/deadbeef/pltbrowser_gtk3.so
loading plugin /usr/lib64/deadbeef/pulse.so
loading plugin /usr/lib64/deadbeef/shellexec.so
loading plugin /usr/lib64/deadbeef/shellexecui_gtk3.so
loading plugin /usr/lib64/deadbeef/sid.so
loading plugin /usr/lib64/deadbeef/sndfile.so
loading plugin /usr/lib64/deadbeef/supereq.so
loading plugin /usr/lib64/deadbeef/tta.so
loading plugin /usr/lib64/deadbeef/vfs_curl.so
loading plugin /usr/lib64/deadbeef/vfs_zip.so
loading plugin /usr/lib64/deadbeef/vorbis.so
loading plugin /usr/lib64/deadbeef/vtx.so
loading plugin /usr/lib64/deadbeef/wavpack.so
loading plugin /usr/lib64/deadbeef/wildmidi.so
loading plugin /usr/lib64/deadbeef/wma.so
github 的源码中也有 mpgmad 的部分,难道我需要自己编译一个 deadbeef。。。
