着急阿, 有没有高手指点一下啊!
清理系统垃圾后,dolphin 无法打开文件夹, 只能用超级用户运行.
普通用户权限运行时输出:
dolphin
Object::connect: No such signal org::freedesktop::UPower::DeviceAdded(QDBusObjectPath)
Object::connect: No such signal org::freedesktop::UPower::DeviceRemoved(QDBusObjectPath)
dolphin(2138) KSambaSharePrivate::findSmbConf: KSambaShare: Could not find smb.conf!
超级用户下:
dolphin
dolphin(2274)/kdeui (kdelibs): Session bus not found
To circumvent this problem try the following command (with Linux and bash)
export $(dbus-launch)
KCrash: Application ‘dolphin’ crashing…
KCrash: Attempting to start /usr/lib/kde4/libexec/drkonqi from kdeinit
sock_file=/root/.kde4/socket-linux-or6k.site/kdeinit4__0
[1]+ Stopped dolphin
这是跳出窗口内开发者信息:
Application: Dolphin (dolphin), signal: Aborted
Using host libthread_db library “/lib/libthread_db.so.1”.
[KCrash Handler]
#6 0xb77bb430 in __kernel_vsyscall ()
#7 0xb7582406 in raise () from /lib/libc.so.6
#8 0xb7583b93 in abort () from /lib/libc.so.6
#9 0xb57b208d in qt_message_output(QtMsgType, char const*) () from /usr/lib/libQtCore.so.4
#10 0xb68ba393 in ?? () from /usr/lib/libkdeui.so.5
#11 0xb69abfab in ?? () from /usr/lib/libkdeui.so.5
#12 0xb69aca9a in KApplication::KApplication(bool) () from /usr/lib/libkdeui.so.5
#13 0xb772da0a in ?? () from /usr/lib/libkdeinit4_dolphin.so
#14 0xb774774e in kdemain () from /usr/lib/libkdeinit4_dolphin.so
#15 0x080485bb in ?? ()
#16 0xb756d9d3 in __libc_start_main () from /lib/libc.so.6
#17 0x080485e1 in _start ()
但是采用菜单中 file manager 代开的超级用户 dolphin 可以正常运行.
