已经安装了 fcitx-qt5,环境变量也已经添加。
另外,fcitx-diagnose 结果如下:
# 系统信息:
1. `uname -a`:
Linux localhost 3.11.10-7-desktop #1 SMP PREEMPT Mon Feb 3 09:41:24 UTC 2014 (750023e) x86_64 x86_64 x86_64 GNU/Linux
2. `lsb_release -a`:
LSB Version: n/a
Distributor ID: openSUSE project
Description: openSUSE 13.1 (Bottle) (x86_64)
Release: 13.1
Codename: Bottle
3. `lsb_release -d`:
4. `/etc/lsb-release`:
`/etc/lsb-release` 未找到.
5. `/etc/os-release`:
NAME=openSUSE
VERSION="13.1 (Bottle)"
VERSION_ID="13.1"
PRETTY_NAME="openSUSE 13.1 (Bottle) (x86_64)"
ID=opensuse
ANSI_COLOR="0;32"
CPE_NAME="cpe:/opensusepensuse:13.1"
BUG_REPORT_URL="https://bugs.opensuse.org"
HOME_URL="https://opensuse.org/"
ID_LIKE="suse"
6. 桌面环境:
桌面环境为 `kde`。
# 环境:
1. DISPLAY:
DISPLAY=':0.0'
2. 键盘布局:
1. `setxkbmap`:
xkb_keymap {
xkb_keycodes { include "evdev+aliases(qwerty)" };
xkb_types { include "complete" };
xkb_compat { include "complete" };
xkb_symbols { include "pc+us+inet(evdev)+terminate(ctrl_alt_bksp)" };
xkb_geometry { include "pc(pc104)" };
2. `xprop`:
_XKB_RULES_NAMES(STRING) = "evdev", "pc104", "us", "", ""
3. Locale:
1. 全部可用 locale:
(这里省略掉)
4. Current user:
The script is run as root (0).
**You are probably logging in as `root` or using `sudo` to run this script. This either means you have security problems or the result of this script may not be accurate. See [Why is it bad to run as root](https://www.google.com/search?q=Why+is+it+bad+to+run+as+root) or [sudo environment variables](https://www.google.com/search?q=sudo+environment+variables) for more information.**
# Fcitx 状态:
1. 可执行文件:
在 `/usr/bin/fcitx` 找到了 fcitx.
2. 版本:
Fcitx 版本: `4.2.8.3`
3. 进程:
找到了 2 个 fcitx 进程:
3266 fcitx
3289 fcitx-dbus-watc
4. `fcitx-remote`:
`fcitx-remote` 工作正常.
# Fcitx 配置界面:
1. 配置工具封装:
在 `/usr/bin/fcitx-configtool` 找到了 fcitx-configtool。
2. 用于 GTK+-2.0 的配置界面:
** 未找到 gtk2 的配置界面.**
3. 用于 GTK+-3.0 的配置界面:
在 `/usr/bin/fcitx-config-gtk3` 找到了 `fcitx-config-gtk3`。
4. KDE 的配置界面:
找到了 fcitx 的 kcm 模块。
kcm_fcitx - 配置输入法
# 前端设置:
## Xim:
1. `${XMODIFIERS}`:
环境变量 XMODIFIERS 已经正确地设为了 "@im=fcitx".
从环境变量中获取的 Xim 服务名称为 fcitx.
2. 根窗口上的 XIM_SERVERS:
Xim 服务的名称与环境变量中设置的相同.
## Qt:
1. `${QT_IM_MODULE}`:
环境变量 QT_IM_MODULE 已经正确地设为了 "fcitx".
2. Qt 输入法模块文件:
找到了 Qt4 的输入法模块: `/usr/lib/qt4/plugins/inputmethods/qtim-fcitx.so`.
找到了 Qt4 的输入法模块: `/usr/lib64/qt4/plugins/inputmethods/qtim-fcitx.so`.
找到了 fcitx 的 qt 模块: `/usr/lib64/fcitx/qt/libfcitx-libpinyin-dictmanager.so`.
找到了 fcitx 的 qt 模块: `/usr/lib64/fcitx/qt/libfcitx-quickphrase-editor.so`.
找到了 Qt5 的输入法模块: `/usr/lib64/qt5/plugins/platforminputcontexts/libfcitxplatforminputcontextplugin.so`.
## Gtk:
1. `${GTK_IM_MODULE}`:
环境变量 GTK_IM_MODULE 已经正确地设为了 "fcitx".
2. `gtk-query-immodules`:
1. gtk 2:
在 `/usr/bin/gtk-query-immodules-2.0` 找到了 gtk `2.24.22` 的 `gtk-query-immodules`.
版本行:
# Created by /usr/bin/gtk-query-immodules-2.0 from gtk+-2.24.22
已找到 gtk `2.24.22` 的 fcitx 输入法模块.
"/usr/lib/gtk-2.0/2.10.0/immodules/im-fcitx.so"
"fcitx" "Fcitx (Flexible Input Method Framework)" "fcitx" "/usr/share/locale" "ja:ko:zh:*"
在 `/usr/bin/gtk-query-immodules-2.0-64` 找到了 gtk `2.24.22` 的 `gtk-query-immodules`.
版本行:
# Created by /usr/bin/gtk-query-immodules-2.0-64 from gtk+-2.24.22
"/usr/lib64/gtk-2.0/2.10.0/immodules/im-fcitx.so"
2. gtk 3:
在 `/usr/bin/gtk-query-immodules-3.0` 找到了 gtk `3.10.4` 的 `gtk-query-immodules`.
版本行:
# Created by /usr/bin/gtk-query-immodules-3.0 from gtk+-3.10.4
已找到 gtk `3.10.4` 的 fcitx 输入法模块.
"/usr/lib/gtk-3.0/3.0.0/immodules/im-fcitx.so"
在 `/usr/bin/gtk-query-immodules-3.0-64` 找到了 gtk `3.10.4` 的 `gtk-query-immodules`.
版本行:
# Created by /usr/bin/gtk-query-immodules-3.0-64 from gtk+-3.10.4
"/usr/lib64/gtk-3.0/3.0.0/immodules/im-fcitx.so"
2. gtk 3:
版本行:
版本行:
3. Gtk 输入法模块缓存:
1. gtk 2:
在 `/usr/lib/vmware-tools/lib64/libconf/etc/gtk-2.0/gtk.immodules` 找到了 gtk `2.20.0` 的输入法模块缓存.
版本行:
# Created by gtk-query-immodules-2.0 from gtk+-2.20.0
** 无法输入法模块缓存 `/usr/lib/vmware-tools/lib64/libconf/etc/gtk-2.0/gtk.immodules` 中找到 fcitx**
在 `/usr/lib/vmware-tools/lib32/libconf/etc/gtk-2.0/gtk.immodules` 找到了 gtk `2.20.0` 的输入法模块缓存.
版本行:
** 无法输入法模块缓存 `/usr/lib/vmware-tools/lib32/libconf/etc/gtk-2.0/gtk.immodules` 中找到 fcitx**
在 `/usr/lib/gtk-2.0/2.10.0/immodules.cache` 找到了 gtk `2.24.22` 的输入法模块缓存.
版本行:
在 `/usr/lib64/gtk-2.0/2.10.0/immodules.cache` 找到了 gtk `2.24.22` 的输入法模块缓存.
版本行:
在 `/etc/gtk-2.0/gtk.immodules` 找到了 gtk `2.24.22` 的输入法模块缓存.
版本行:
** 无法输入法模块缓存 `/etc/gtk-2.0/gtk.immodules` 中找到 fcitx**
2. gtk 3:
在 `/usr/lib/gtk-3.0/3.0.0/immodules.cache` 找到了 gtk `3.10.4` 的输入法模块缓存.
版本行:
在 `/usr/lib64/gtk-3.0/3.0.0/immodules.cache` 找到了 gtk `3.10.4` 的输入法模块缓存.
版本行:
4. Gtk 输入法模块文件:
1. gtk 2:
找到的全部 Gtk 2 输入法模块文件均存在.
2. gtk 3:
找到的全部 Gtk 3 输入法模块文件均存在.
# 配置:
## Fcitx 插件:
1. 插件配置文件目录:
找到了 fcitx 插件配置目录: `/usr/share/fcitx/addon`.
2. 插件列表:
1. 找到了 32 个已启用的插件:
fcitx-autoeng
fcitx-chttrans
fcitx-classic-ui
fcitx-clipboard
fcitx-cloudpinyin
fcitx-dbus
fcitx-freedesktop-notify
fcitx-fullwidth-char
fcitx-googlepinyin
fcitx-imselector
fcitx-ipc
fcitx-keyboard
fcitx-kimpanel-ui
fcitx-libpinyin
fcitx-lua
fcitx-mozc
fcitx-notificationitem
fcitx-pinyin
fcitx-pinyin-enhance
fcitx-punc
fcitx-quickphrase
fcitx-remote
fcitx-sogoupinyin
fcitx-spell
fcitx-sunpinyin
fcitx-table
fcitx-unicode
fcitx-vk
fcitx-x11
fcitx-xim
fcitx-xkb
fcitx-xkbdbus
2. 找到了 0 个被禁用的插件:
3. Addon Libraries:
All libraries for all addons are found.
4. 用户界面:
找到了 2 个已启用的用户界面插件:
fcitx-classic-ui
fcitx-kimpanel-ui
## 输入法:
1. 找到了 4 个启用的输入法:
fcitx-keyboard-us
pinyin
sogou-pinyin
googlepinyin
2. 默认输入法:
您已经正确的将一个键盘输入法 "fcitx-keyboard-us" 设为默认.
# 日志:
1. `date`:
2014 年 04 月 23 日 星期三 18:01:58 CST
2. `~/.config/fcitx/log/`:
总用量 0
3. `~/.config/fcitx/log/crash.log`:
`~/.config/fcitx/log/crash.log` 未找到.
求各位提供解决办法。另外,尝试使用自带的 Qt 4.8.5 下没有问题。
可以的话,最好不更换 Qt 版本,因为合作商使用的是这个版本的 Qt,更换代价有点大。
