我又来求助了……
系统是 42.1 64 位。
现在只能启动到 tty1 界面。
如图:
!](http://uploads.tapatalk-cdn.com/20160930/291bc082da933b192ade8fef3f798d1e.jpg)
N 卡驱动卸载重装也不管用
回去把 log 发一下,还有 startx 启动报错也同时发来。
能看懂得麻烦帮忙看一下,谢谢啦。
通过我的 CM810 上的 Tapatalk 发言\
google 搜出来了我之前在论坛发的同样的问题 我竟然又发了一次
现在进 WIN 系统发帖了 呃~
这个是在 tty1 启动 startx 后屏幕的内容
hostname: Name or service not known
xauth: file /root/.serverauth.1673 does not exist
X.Org X Server 1.17.2
Release Date: 2015-06-16
X Protocol Version 11, Revision 0
Build Operating System: openSUSE SUSE LINUX
Current Operating System: Linux suse 4.1.31-30-default #1 SMP PREEMPT Wed Aug 24 06:20:09 UTC 2016 (de9ddf8) x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.1.31-30-default root=UUID=5ca95aa2 ro resume=/dev/disk/by-uuid/135d3e66-1380-4970-aa99-cc5aa7b2f7f6 splash=silent quiet showopts
Build Date: 07 March 2016 08:22:28AM
Current version of pixman: 0.32.6
Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Sep 30 12:32:11 2016
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
VGA Arbitration: Cannot restore default device.
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to X server: Network is unreachable
xinit: server error
xinit failed. /usr/bin/Xorg is not setuid, maybe that's the reason?
If so either use a display manager (strongly recommended) or adjust /etc/permissions.local and run "chkstat --system --set" afterwards
这个是 /var/log/Xorg.0.log 里面的 内容
75.128]
75.128] X Protocol Version 11, Revision 0
75.128] Build Operating System: openSUSE SUSE LINUX
75.128] Current Operating System: Linux suse 4.1.31-30-default #1 SMP PREEMPT Wed Aug 24 06:20:09 UTC 2016 (de9ddf8) x86_64
75.128] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.1.31-30-default root=UUID=v5aa2 ro resume=/dev/disk/by-uuid/135d3e66-1380-4970-aa99-cc5aa7b2f7f6 splash=silent quiet showopts
75.129] Build Date: 07 March 2016 08:22:28AM
75.129]
75.129] Current version of pixman: 0.32.6
75.129] Before reporting problems, check http://wiki.x.org
75.129] Markers: (--) probed, (**) from config file, (==) default setting,
75.129] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Sep 30 14:15:03 2016
75.129] (==) Using config file: "/etc/X11/xorg.conf"
75.129] (==) Using config directory: "/etc/X11/xorg.conf.d"
75.129] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
75.130] (==) ServerLayout "Layout0"
75.130] (**) |-->Screen "Screen0" (0)
75.130] (**) | |-->Monitor "Monitor0"
75.130] (**) | |-->Device "Device0"
75.130] (**) |-->Input Device "Keyboard0"
75.130] (**) |-->Input Device "Mouse0"
75.130] (==) Automatically adding devices
75.130] (==) Automatically enabling devices
75.130] (==) Automatically adding GPU devices
75.130] (WW) The directory "/usr/share/fonts/misc/sgi" does not exist.
75.130] Entry deleted from font path.
75.130] (==) FontPath set to:
/usr/share/fonts/Type1/,
/usr/share/fonts/truetype/,
built-ins
75.130] (==) ModulePath set to "/usr/lib64/xorg/modules"
75.130] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
75.130] (WW) Disabling Keyboard0
75.130] (WW) Disabling Mouse0
75.130] (II) Loader magic: 0x80dd00
75.130] (II) Module ABI versions:
75.130] X.Org ANSI C Emulation: 0.4
75.130] X.Org Video Driver: 19.0
75.130] X.Org XInput driver : 21.0
75.130] X.Org Server Extension : 9.0
75.132] (++) using VT number 1
75.132] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
75.132] (II) xfree86: Adding drm device (/dev/dri/card1)
75.133] (II) xfree86: Adding drm device (/dev/dri/card0)
75.135] (--) PCI:*(0:0:2:0) 8086:0116:1043:1537 rev 9, Mem @ d4, 0xd0000000/268435456, I/O @ 0x0000f000/64
75.135] (--) PCI: (0:1:0:0) 10de:1058:1043:1537 rev 161, Mem @ 0xf6000000/16777216, 0xe0
75.135] (II) LoadModule: "glx"
75.135] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
75.137] (II) Module glx: vendor="X.Org Foundation"
75.137] compiled for 1.17.2, module version = 1.0.0
75.137] ABI class: X.Org Server Extension, version 9.0
75.137] (==) AIGLX enabled
75.137] (II) LoadModule: "nvidia"
75.137] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
75.138] (II) Module nvidia: vendor="NVIDIA Corporation"
75.138] compiled for 4.0.2, module version = 1.0.0
75.138] Module class: X.Org Video Driver
75.138] (II) NVIDIA dlloader X Driver 340.98 Mon Sep 19 17:02:58 PDT 2016
75.138] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
75.138] (EE) No devices detected.
75.138] (EE)
Fatal server error:
75.138] (EE) no screens found(EE)
75.138] (EE)
for help.
75.138] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
75.138] (EE)
bbswitch 禁用 N 卡
在 /etc/X11/xorg.conf 中加入
Section "Device"
Identifier "Device0"
Driver "intel"
VendorName "Intel Corporation"
EndSection
搞定了
