device0 是小写的。
Sent from my iPad Mini using Tapatalk HD
device0 是小写的。
额。。。好吧,我的错。![]()
修改了之后提示 “Modes” is not a valid keyword in this section.:
cat Xorg.0.log
76.787]
X.Org X Server 1.13.2
Release Date: 2013-01-24
76.787] X Protocol Version 11, Revision 0
76.787] Build Operating System: openSUSE SUSE LINUX
76.787] Current Operating System: Linux openSUSE.site 3.7.10-1.11-desktop #1 SMP PREEMPT Thu May 16 20:27:27 UTC 2013 (adf31bb) x86_64
76.787] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.7.10-1.11-desktop root=UUID=935330e8-5e6d-4d93-959b-ea4162b6c2f4 video=1600x900 resume=/dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part8 splash=silent quiet showopts
76.787] Build Date: 30 April 2013 08:24:17AM
76.787]
76.787] Current version of pixman: 0.28.2
76.787] Before reporting problems, check http://wiki.x.org
76.787] Markers: (--) probed, (**) from config file, (==) default setting,
76.787] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jun 11 10:52:44 2013
76.787] (==) Using config directory: "/etc/X11/xorg.conf.d"
76.787] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
76.788] Parse error on line 29 of section Device in file /etc/X11/xorg.conf.d/50-device.conf
"Modes" is not a valid keyword in this section.
76.788] (EE) Problem parsing the config file
76.788] (EE) Error parsing the config file
76.788]
Fatal server error:
76.788] no screens found
76.788] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
76.788] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
76.788] (EE)
76.788] Server terminated with error (1). Closing log file.
网上查了下,放到50-screen.conf里,也是同样的提示:
cat Xorg.0.log.screen
79.824]
79.824] X Protocol Version 11, Revision 0
79.824] Build Operating System: openSUSE SUSE LINUX
79.824] Current Operating System: Linux openSUSE.site 3.7.10-1.11-desktop #1 SMP PREEMPT Thu May 16 20:27:27 UTC 2013 (adf31bb) x86_64
79.824] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.7.10-1.11-desktop root=UUID=935330e8-5e6d-4d93-959b-ea4162b6c2f4 video=1600x900 resume=/dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part8 splash=silent quiet showopts
79.824] Build Date: 30 April 2013 08:24:17AM
79.824]
79.824] Current version of pixman: 0.28.2
79.824] Before reporting problems, check http://wiki.x.org
79.824] Markers: (--) probed, (**) from config file, (==) default setting,
79.824] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jun 11 11:12:49 2013
79.825] (==) Using config directory: "/etc/X11/xorg.conf.d"
79.825] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
79.836] Parse error on line 12 of section Screen in file /etc/X11/xorg.conf.d/50-screen.conf
79.836] (EE) Problem parsing the config file
79.836] (EE) Error parsing the config file
79.836]
Fatal server error:
79.836] no screens found
79.836] (EE)
for help.
79.836] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
79.836] (EE)
79.837] Server terminated with error (1). Closing log file.
最后放到了50-screen.conf里的“Display”下:
cat 50-screen.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 310.32 (buildmeister@swio-display-x86-rhel47-01) Mon Jan 14 15:51:51 PST 2013
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "1600x900"
EndSubSection
EndSection
在50-device.conf里加了个Screen 0:
cat 50-device.conf
# Having multiple "Device" sections is known to be problematic. Make
# sure you don't have in use another one laying around e.g. in another
# xorg.conf.d file or even a generic xorg.conf file. More details can
# be found in https://bugs.freedesktop.org/show_bug.cgi?id=32430.
#Section "Device"
# Identifier "device0"
# Driver "nvidia"
# VendorName "Nvidia Corporation"
# BusID "PCI:1:0:0"
# Screen 0
# Identifier "Default Device"
# #Driver "radeon"
# ## Required magic for radeon/radeonhd drivers; output name
# ## (here: "DVI-0") can be figured out via 'xrandr -q'
# #Option "monitor-DVI-0" "Default Monitor"
#EndSection
Section "Device"
# Identifier "Intel Graphics"
Identifier "Device0"
Driver "intel"
BusID "PCI:0:2:0"
Option "UseEDID" "False"
Option "IgnoreEDID" "1"
# Modes "1600x900"
Screen 0
EndSection
50-monitor.conf没有改。
cat 50-monitor.conf
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 63.0
VertRefresh 43.0 - 72.0
Option "DPMS"
# 1600x900 @ 60.00 Hz (GTF) hsync: 55.92 kHz; pclk: 119.00 MHz
Modeline "1600x900_60.00" 119.00 1600 1696 1864 2128 900 901 904 932 -HSync +Vsync
EndSection
结果是 82-125:
77.354] (EE) evdev: PS/2 Generic Mouse: ioctl EVIOCGID failed: Bad file descriptor
77.354] (EE) PreInit returned 8 for "PS/2 Generic Mouse"
77.354] (II) UnloadModule: "evdev"
77.354] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
77.354] (II) No input driver specified, ignoring this device.
77.354] (II) This device may have been added with another device file.
77.355] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event8)
77.355] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
77.355] (**) Dell WMI hotkeys: Applying InputClass "LocalKeyboard"
77.355] (II) Using input driver 'evdev' for 'Dell WMI hotkeys'
77.355] (**) Dell WMI hotkeys: always reports core events
77.355] (**) evdev: Dell WMI hotkeys: Device: "/dev/input/event8"
77.355] (--) evdev: Dell WMI hotkeys: Vendor 0 Product 0
77.355] (--) evdev: Dell WMI hotkeys: Found keys
77.355] (II) evdev: Dell WMI hotkeys: Configuring as keyboard
77.355] (**) Option "config_info" "udev:/sys/devices/virtual/input/input8/event8"
77.355] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 15)
77.355] (**) Option "xkb_rules" "evdev"
77.355] (**) Option "xkb_model" "evdev"
77.355] (**) Option "xkb_layout" "us"
77.359] (II) intel(0): EDID vendor "AUO", prod id 8510
77.359] (II) intel(0): Printing DDC gathered Modelines:
77.359] (II) intel(0): Modeline "1600x900"x0.0 110.00 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (55.7 kHz eP)
77.359] (II) intel(0): Modeline "1600x900"x0.0 73.33 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (37.1 kHz e)
82.340] (II) intel(0): EDID vendor "AUO", prod id 8510
82.340] (II) intel(0): Printing DDC gathered Modelines:
82.340] (II) intel(0): Modeline "1600x900"x0.0 110.00 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (55.7 kHz eP)
82.340] (II) intel(0): Modeline "1600x900"x0.0 73.33 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (37.1 kHz e)
125.297] (II) AIGLX: Suspending AIGLX clients for VT switch
193.129] (II) Open ACPI successful (/var/run/acpid.socket)
193.130] (II) AIGLX: Resuming AIGLX clients after VT switch
193.138] (II) intel(0): EDID vendor "AUO", prod id 8510
193.138] (II) intel(0): Printing DDC gathered Modelines:
193.138] (II) intel(0): Modeline "1600x900"x0.0 110.00 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (55.7 kHz eP)
193.138] (II) intel(0): Modeline "1600x900"x0.0 73.33 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (37.1 kHz e)
206.475] (II) intel(0): EDID vendor "AUO", prod id 8510
206.475] (II) intel(0): Printing DDC gathered Modelines:
206.475] (II) intel(0): Modeline "1600x900"x0.0 110.00 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (55.7 kHz eP)
206.475] (II) intel(0): Modeline "1600x900"x0.0 73.33 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (37.1 kHz e)
208.000] (II) intel(0): EDID vendor "AUO", prod id 8510
208.000] (II) intel(0): Printing DDC gathered Modelines:
208.000] (II) intel(0): Modeline "1600x900"x0.0 110.00 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (55.7 kHz eP)
208.000] (II) intel(0): Modeline "1600x900"x0.0 73.33 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (37.1 kHz e)
216.403] (II) intel(0): EDID vendor "AUO", prod id 8510
216.403] (II) intel(0): Printing DDC gathered Modelines:
216.403] (II) intel(0): Modeline "1600x900"x0.0 110.00 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (55.7 kHz eP)
216.403] (II) intel(0): Modeline "1600x900"x0.0 73.33 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (37.1 kHz e)
Modes不能放在“display“里?
你再看看我给你的那个 link,好像是复制粘贴 xrandr 的结果,那就是 modline 而不是 modes
恩。我按上面说的把xrandr的结果粘在了50-monitor.conf里,把Modes加在了50-screen.conf的“display”里,
这里也参考了下面两个链接中的。
kingcot.eclipse.co.uk/unichrome/xorg.conf.txt
wiki.openelec.tv/index.php?title=Configuring_a_Custom_xorg.conf
openSUSE:/etc/X11/xorg.conf.d # cat 50-device.conf
Section "Device"
Driver "intel"
BusID "PCI:0:2:0"
Screen 0
EndSection
openSUSE:/etc/X11/xorg.conf.d # cat 50-monitor.conf
Section "Monitor"
Option "PreferredMode" "1600x900"
Option "DPMS"
EndSection
openSUSE:/etc/X11/xorg.conf.d # cat 50-screen.conf
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
Modes "1600x900_60.00"
EndSubSection
EndSection
结果。。。。。
84.294] (II) UnloadModule: "evdev"
84.294] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
84.294] (II) No input driver specified, ignoring this device.
84.294] (II) This device may have been added with another device file.
84.296] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event8)
84.296] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
84.296] (**) Dell WMI hotkeys: Applying InputClass "LocalKeyboard"
84.296] (II) Using input driver 'evdev' for 'Dell WMI hotkeys'
84.296] (**) Dell WMI hotkeys: always reports core events
84.296] (**) evdev: Dell WMI hotkeys: Device: "/dev/input/event8"
84.296] (--) evdev: Dell WMI hotkeys: Vendor 0 Product 0
84.296] (--) evdev: Dell WMI hotkeys: Found keys
84.296] (II) evdev: Dell WMI hotkeys: Configuring as keyboard
84.296] (**) Option "config_info" "udev:/sys/devices/virtual/input/input8/event8"
84.296] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 15)
84.296] (**) Option "xkb_rules" "evdev"
84.296] (**) Option "xkb_model" "evdev"
84.296] (**) Option "xkb_layout" "us"
84.300] (II) intel(0): EDID vendor "AUO", prod id 8510
84.300] (II) intel(0): Printing DDC gathered Modelines:
84.300] (II) intel(0): Modeline "1600x900"x0.0 110.00 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (55.7 kHz eP)
84.300] (II) intel(0): Modeline "1600x900"x0.0 73.33 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (37.1 kHz e)
85.512] (II) intel(0): EDID vendor "AUO", prod id 8510
85.512] (II) intel(0): Printing DDC gathered Modelines:
85.512] (II) intel(0): Modeline "1600x900"x0.0 110.00 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (55.7 kHz eP)
85.512] (II) intel(0): Modeline "1600x900"x0.0 73.33 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (37.1 kHz e)
183.284] (II) intel(0): EDID vendor "AUO", prod id 8510
183.284] (II) intel(0): Printing DDC gathered Modelines:
183.284] (II) intel(0): Modeline "1600x900"x0.0 110.00 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (55.7 kHz eP)
183.284] (II) intel(0): Modeline "1600x900"x0.0 73.33 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (37.1 kHz e)
184.802] (II) intel(0): EDID vendor "AUO", prod id 8510
184.802] (II) intel(0): Printing DDC gathered Modelines:
184.802] (II) intel(0): Modeline "1600x900"x0.0 110.00 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (55.7 kHz eP)
184.802] (II) intel(0): Modeline "1600x900"x0.0 73.33 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (37.1 kHz e)
193.301] (II) intel(0): EDID vendor "AUO", prod id 8510
193.306] (II) intel(0): Printing DDC gathered Modelines:
193.306] (II) intel(0): Modeline "1600x900"x0.0 110.00 1600 1664 1706 1974 900 903 906 928 +hsync -vsync (55.7 kHz eP)
