Intel 驱动在 xorg 日志重复输出 modeline,系统启动关机慢
7.15 ?
好像有这么一说,记不清了。
没2,3分钟进不了图形界面。没个4,5分钟关不了机。 平时还能忍受,关键时刻是真着急啊!
    81.223] (**) evdev: PS/2 Generic Mouse: Device: "/dev/input/mouse0"
    81.223] (EE) PS/2 Generic Mouse: Couldn't open mtdev device
    81.224] (EE) evdev: PS/2 Generic Mouse: ioctl EVIOCGID failed: Bad file descriptor
    81.224] (EE) PreInit returned 8 for "PS/2 Generic Mouse"
    81.224] (II) UnloadModule: "evdev"
    81.224] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
    81.224] (II) No input driver specified, ignoring this device.
    81.224] (II) This device may have been added with another device file.
    81.225] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event10)
    81.225] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
    81.225] (**) Dell WMI hotkeys: Applying InputClass "LocalKeyboard"
    81.225] (II) Using input driver 'evdev' for 'Dell WMI hotkeys'
    81.225] (**) Dell WMI hotkeys: always reports core events
    81.225] (**) evdev: Dell WMI hotkeys: Device: "/dev/input/event10"
    81.225] (--) evdev: Dell WMI hotkeys: Vendor 0 Product 0
    81.225] (--) evdev: Dell WMI hotkeys: Found keys
    81.225] (II) evdev: Dell WMI hotkeys: Configuring as keyboard
    81.225] (**) Option "config_info" "udev:/sys/devices/virtual/input/input10/event10"
    81.225] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 15)
    81.225] (**) Option "xkb_rules" "evdev"
    81.225] (**) Option "xkb_model" "evdev"
    81.225] (**) Option "xkb_layout" "us"
    81.230] (II) intel(0): EDID vendor "AUO", prod id 8510
    81.230] (II) intel(0): Printing DDC gathered Modelines:
    81.230] (II) intel(0): Modeline "1600x900"x0.0  110.00  1600 1664 1706 1974  900 903 906 928 +hsync -vsync (55.7 kHz eP)
    81.230] (II) intel(0): Modeline "1600x900"x0.0   73.33  1600 1664 1706 1974  900 903 906 928 +hsync -vsync (37.1 kHz e)
    82.519] (II) intel(0): EDID vendor "AUO", prod id 8510
    82.519] (II) intel(0): Printing DDC gathered Modelines:
    82.519] (II) intel(0): Modeline "1600x900"x0.0  110.00  1600 1664 1706 1974  900 903 906 928 +hsync -vsync (55.7 kHz eP)
    82.519] (II) intel(0): Modeline "1600x900"x0.0   73.33  1600 1664 1706 1974  900 903 906 928 +hsync -vsync (37.1 kHz e)
   124.332] (II) intel(0): EDID vendor "AUO", prod id 8510
   124.332] (II) intel(0): Printing DDC gathered Modelines:
   124.332] (II) intel(0): Modeline "1600x900"x0.0  110.00  1600 1664 1706 1974  900 903 906 928 +hsync -vsync (55.7 kHz eP)
   124.332] (II) intel(0): Modeline "1600x900"x0.0   73.33  1600 1664 1706 1974  900 903 906 928 +hsync -vsync (37.1 kHz e)
   126.298] (II) intel(0): EDID vendor "AUO", prod id 8510
   126.298] (II) intel(0): Printing DDC gathered Modelines:
   126.298] (II) intel(0): Modeline "1600x900"x0.0  110.00  1600 1664 1706 1974  900 903 906 928 +hsync -vsync (55.7 kHz eP)
   126.298] (II) intel(0): Modeline "1600x900"x0.0   73.33  1600 1664 1706 1974  900 903 906 928 +hsync -vsync (37.1 kHz e)
   137.359] (II) intel(0): EDID vendor "AUO", prod id 8510
   137.359] (II) intel(0): Printing DDC gathered Modelines:
   137.359] (II) intel(0): Modeline "1600x900"x0.0  110.00  1600 1664 1706 1974  900 903 906 928 +hsync -vsync (55.7 kHz eP)
   137.359] (II) intel(0): Modeline "1600x900"x0.0   73.33  1600 1664 1706 1974  900 903 906 928 +hsync -vsync (37.1 kHz e)
"Xorg.0.log" [readonly][ILLEGAL BYTE in line 261] 637L, 40666C
这次卡了40多秒, 82 - 124。 有一次直接80多秒,80-160。。。
Intel 驱动在检测屏幕分辨率。
grep -r “intel” /etc/X11
或者自己挨个看有没有 Device 设置部分贴出来。
Sent from my Desire HD using Tapatalk 2
什么都没搜到。
哪里配置有问题?
ls /etc/X11/xorg.conf.d
有 50-device.conf 没
有, 但是里面的内容都是注释掉的。
 cat 50-device.conf
# Having multiple "Device" sections is known to be problematic. Make
# sure you don't have in use another one laying around e.g. in another
# xorg.conf.d file or even a generic xorg.conf file. More details can
# be found in https://bugs.freedesktop.org/show_bug.cgi?id=32430.
#Section "Device"
#   Identifier "device0"
#   Driver     "nvidia"
#   VendorName  "Nvidia Corporation"
#   BusID       "PCI:1:0:0"
#   Screen      0
#  Identifier "Default Device"
#  #Driver "radeon"
#  ## Required magic for radeon/radeonhd drivers; output name
#  ## (here: "DVI-0") can be figured out via 'xrandr -q'
#  #Option "monitor-DVI-0" "Default Monitor"
#EndSection
你整个 /etc/X11 下的所有文件里就没有一个带 Device 或 Intel 字样的?我没 Intel 还真不知道,/etc/X11/xorg.conf 你有吗?里面啥内容呢?
openSUSE:/etc/X11 # ls
fs        mlterm     qtrc    xdm  xim.d  Xmodmap         xorg.conf.busid  xorg.conf.install  xorg.conf.nvidia-xconfig-original  Xresources
lbxproxy  proxymngr  rstart  xim  xinit  Xmodmap.remote  xorg.conf.d      xorg.conf.nv.back  xorg.conf.old                      xsm
openSUSE:/etc/X11 # grep -irn "Intel" .
./xorg.conf.d/11-mouse.conf:40: Identifier      "Microsoft IntelliMouse Explorer"
./xorg.conf.d/11-mouse.conf:42: MatchProduct    "IntelliMouse Explorer 4.0 (IntelliPoint)"
很奇怪,我的 vbox 里的 12.3 的 /etc/X11 下也没有。
这个是 VBox 里的:
linux-30kb:/home/zhxt # grep -irn "intel" /etc/X11
/etc/X11/xorg.conf.d/11-mouse.conf:40:  Identifier      "Microsoft IntelliMouse Explorer"
/etc/X11/xorg.conf.d/11-mouse.conf:42:  MatchProduct    "IntelliMouse Explorer 4.0 (IntelliPoint)"
linux-30kb:/home/zhxt # ls /etc/X11/
fs  lbxproxy  proxymngr  rstart  xdm  xim  xim.d  xinit  Xmodmap  Xmodmap.remote  xorg.conf.d  xorg.conf.install  Xresources  xsm
好像本来是没有 xorg.conf 的,只有个 xorg.conf.install。装过 N 卡驱动后生成了个(忘了自动生成还是手动生成的了),后来卸载 N 卡驱动后又给删了。
vbox 虚拟机里是没有装过 N 卡驱动的情况。
对了,我的是双显卡。 i+n。
openSUSE:/etc/X11 # lspci | grep -i vga
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
01:00.0 VGA compatible controller: NVIDIA Corporation GK107 [GeForce GT 640M] (rev a1)
openSUSE:/etc/X11 # lsmod | grep -i nouv
nouveau               993062  1
ttm                    91975  1 nouveau
mxm_wmi                13022  1 nouveau
wmi                    19071  3 nouveau,mxm_wmi,dell_wmi
drm_kms_helper         50840  2 nouveau,i915
drm                   293115  6 nouveau,ttm,i915,drm_kms_helper
i2c_algo_bit           13414  2 nouveau,i915
button                 13953  2 nouveau,i915
video                  19401  2 nouveau,i915
openSUSE:/etc/X11 # lsmod | grep -i intel
snd_hda_intel          42034  3
snd_hda_codec         147417  3 snd_hda_codec_hdmi,snd_hda_codec_conexant,snd_hda_intel
snd_pcm               110154  3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd                    91489  15 snd_hda_codec_hdmi,snd_hda_codec_conexant,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_seq,snd_timer,snd_seq_device
snd_page_alloc         18711  2 snd_hda_intel,snd_pcm
kvm_intel             136915  0
kvm                   475491  1 kvm_intel
crc32c_intel           12902  0
ghash_clmulni_intel    13260  0
cryptd                 16307  1 ghash_clmulni_intel
这跟双显卡没关系,甚至都不算 bug(检测分辨率很正常)。就是找到相关的 config 预设一个分辨率就把耗时 40s 这个给消掉了。
也解决不了你说的四五分钟的问题,那个要么你瞎掰要么要去看 sudo journalctl --since today 里还有没有其它 blocker。
但问题现在找不到 xorg.conf.d 下面 intel 相关的,难道逼我在 50-device.conf 里写一个么…
Sent from my iPad Mini using Tapatalk HD
我没有真的拿表来计时啦,只是感觉关机比开机明显要慢一些。
截了个从30号的journal, 3M, 传不上来,Pastebin都停止相应了。等会儿细翻翻。
update: 看得眼都花了,贴个昨天的:
-- Logs begin at Tue, 2012-09-11 22:51:26 CST, end at Mon, 2013-06-10 18:23:14 CST. --
Jun 09 19:31:03 openSUSE.site systemd-journal[257]: Allowing runtime journal files to grow to 292.0M.
Jun 09 19:31:03 openSUSE.site kernel: Initializing cgroup subsys cpuset
Jun 09 19:31:03 openSUSE.site kernel: Linux version 3.7.10-1.11-desktop (geeko@buildhost) (gcc version 4.7.2 20130108 [gcc-4_7-branch revision 195012] (SUSE Linux) ) #1 SMP PREEMPT Thu May 16 20:27:27 UTC 2013 (adf31bb)
Jun 09 19:31:03 openSUSE.site kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-3.7.10-1.11-desktop root=UUID=935330e8-5e6d-4d93-959b-ea4162b6c2f4 video=1600x900 resume=/dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part8 splash=silent quiet showopts
Jun 09 19:31:03 openSUSE.site kernel: e820: BIOS-provided physical RAM map:
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x0000000040005000-0x00000000a90a8fff] usable
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000a90a9000-0x00000000a92aafff] reserved
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000a92ab000-0x00000000b8151fff] usable
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000b8152000-0x00000000baeeefff] reserved
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000baeef000-0x00000000baf9efff] ACPI NVS
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000baf9f000-0x00000000baffefff] ACPI data
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000bafff000-0x00000000baffffff] usable
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000bb000000-0x00000000bf9fffff] reserved
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000fed08000-0x00000000fed08fff] reserved
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x00000000ff980000-0x00000000ffffffff] reserved
Jun 09 19:31:03 openSUSE.site kernel: BIOS-e820: [mem 0x0000000100000000-0x00000001bf5fffff] usable
Jun 09 19:31:03 openSUSE.site kernel: NX (Execute Disable) protection: active
Jun 09 19:31:03 openSUSE.site kernel: SMBIOS 2.7 present.
Jun 09 19:31:03 openSUSE.site kernel: DMI: Dell Inc.          Inspiron 7420/08PPR2, BIOS A09 08/16/2012
Jun 09 19:31:03 openSUSE.site kernel: e820: update [mem 0x00000000-0x0000ffff] usable ==> reserved
Jun 09 19:31:03 openSUSE.site kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Jun 09 19:31:03 openSUSE.site kernel: No AGP bridge found
Jun 09 19:31:03 openSUSE.site kernel: e820: last_pfn = 0x1bf600 max_arch_pfn = 0x400000000
Jun 09 19:31:03 openSUSE.site kernel: MTRR default type: uncachable
Jun 09 19:31:03 openSUSE.site kernel: MTRR fixed ranges enabled:
Jun 09 19:31:03 openSUSE.site kernel:   00000-9FFFF write-back
Jun 09 19:31:03 openSUSE.site kernel:   A0000-BFFFF uncachable
Jun 09 19:31:03 openSUSE.site kernel:   C0000-FFFFF write-protect
Jun 09 19:31:03 openSUSE.site kernel: MTRR variable ranges enabled:
Jun 09 19:31:03 openSUSE.site kernel:   0 base 0FF800000 mask FFF800000 write-protect
Jun 09 19:31:03 openSUSE.site kernel:   1 base 000000000 mask F80000000 write-back
Jun 09 19:31:03 openSUSE.site kernel:   2 base 080000000 mask FC0000000 write-back
Jun 09 19:31:03 openSUSE.site kernel:   3 base 0BC000000 mask FFC000000 uncachable
Jun 09 19:31:03 openSUSE.site kernel:   4 base 0BB000000 mask FFF000000 uncachable
Jun 09 19:31:03 openSUSE.site kernel:   5 base 100000000 mask F80000000 write-back
Jun 09 19:31:03 openSUSE.site kernel:   6 base 180000000 mask FC0000000 write-back
Jun 09 19:31:03 openSUSE.site kernel:   7 base 1BF800000 mask FFF800000 uncachable
Jun 09 19:31:03 openSUSE.site kernel:   8 base 1BF600000 mask FFFE00000 uncachable
Jun 09 19:31:03 openSUSE.site kernel:   9 disabled
Jun 09 19:31:03 openSUSE.site kernel: x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
Jun 09 19:31:03 openSUSE.site kernel: e820: last_pfn = 0xbb000 max_arch_pfn = 0x400000000
Jun 09 19:31:03 openSUSE.site kernel: found SMP MP-table at [mem 0x000f0100-0x000f010f] mapped at [ffff8800000f0100]
Jun 09 19:31:03 openSUSE.site kernel: initial memory mapped: [mem 0x00000000-0x1fffffff]
Jun 09 19:31:03 openSUSE.site kernel: Base memory trampoline at [ffff880000097000] 97000 size 24576
Jun 09 19:31:03 openSUSE.site kernel: init_memory_mapping: [mem 0x00000000-0xbaffffff]
Jun 09 19:31:03 openSUSE.site kernel:  [mem 0x00000000-0xbaffffff] page 2M
Jun 09 19:31:03 openSUSE.site kernel: kernel direct mapping tables up to 0xbaffffff @ [mem 0x1fffc000-0x1fffffff]
Jun 09 19:31:03 openSUSE.site kernel: init_memory_mapping: [mem 0x100000000-0x1bf5fffff]
Jun 09 19:31:03 openSUSE.site kernel:  [mem 0x100000000-0x1bf5fffff] page 2M
Jun 09 19:31:03 openSUSE.site kernel: kernel direct mapping tables up to 0x1bf5fffff @ [mem 0xb814e000-0xb8151fff]
Jun 09 19:31:03 openSUSE.site kernel: RAMDISK: [mem 0x342fa000-0x36174fff]
Jun 09 19:31:03 openSUSE.site kernel: ACPI: RSDP 00000000000f0120 00024 (v02 DELL  )
Jun 09 19:31:03 openSUSE.site kernel: ACPI: XSDT 00000000baffe170 000A4 (v01 DELL    QA09    00000002 LOHR 00000002)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: FACP 00000000bafe4000 0010C (v05 DELL    QA09    00000002 LOHR 00000002)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: DSDT 00000000baff2000 09ECD (v02 DELL    IVB-CPT 00000000 INTL 20061109)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: FACS 00000000baf7c000 00040
Jun 09 19:31:03 openSUSE.site kernel: ACPI: SLIC 00000000baffd000 00176 (v01 DELL    QA09    00000002 LOHR 00000001)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: SSDT 00000000baffc000 00166 (v01 DELL   PtidDevc 00001000 INTL 20061109)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: ASF! 00000000baff1000 000A5 (v32 DELL    QA09    00000002 LOHR 00000002)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: HPET 00000000bafee000 00038 (v01 DELL    QA09    00000002 LOHR 00000002)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: APIC 00000000bafed000 00098 (v01 DELL    QA09    00000002 LOHR 00000002)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: MCFG 00000000bafec000 0003C (v01 DELL    QA09    00000002 LOHR 00000002)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: FPDT 00000000bafeb000 00064 (v01 DELL    QA09    00000002 LOHR 00000002)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: SSDT 00000000bafea000 00968 (v01  PmRef  Cpu0Ist 00003000 INTL 20061109)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: SSDT 00000000bafe9000 00A92 (v01  PmRef    CpuPm 00003000 INTL 20061109)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: UEFI 00000000bafe8000 0003E (v01 DELL    QA09    00000002 LOHR 00000002)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: UEFI 00000000bafe7000 00042 (v01 PTL      COMBUF 00000001 PTL  00000001)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: POAT 00000000bafe6000 00055 (v03 DELL    QA09    00000002 LOHR 00000002)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: SSDT 00000000bafe3000 00DAE (v01 NvORef NvOptTbl 00001000 INTL 20061109)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: UEFI 00000000bafe2000 0027E (v01 DELL    QA09    00000002 LOHR 00000002)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: DBG2 00000000bafe0000 00070 (v00 DELL    QA09    00000002 LOHR 00000002)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: Local APIC address 0xfee00000
Jun 09 19:31:03 openSUSE.site kernel: No NUMA configuration found
Jun 09 19:31:03 openSUSE.site kernel: Faking a node at [mem 0x0000000000000000-0x00000001bf5fffff]
Jun 09 19:31:03 openSUSE.site kernel: Initmem setup node 0 [mem 0x00000000-0x1bf5fffff]
Jun 09 19:31:03 openSUSE.site kernel:   NODE_DATA [mem 0x1bf5ec000-0x1bf5fffff]
Jun 09 19:31:03 openSUSE.site kernel:  [ffffea0000000000-ffffea00061fffff] PMD -> [ffff8801b8c00000-ffff8801bdffffff] on node 0
Jun 09 19:31:03 openSUSE.site kernel: Zone ranges:
Jun 09 19:31:03 openSUSE.site kernel:   DMA      [mem 0x00010000-0x00ffffff]
Jun 09 19:31:03 openSUSE.site kernel:   DMA32    [mem 0x01000000-0xffffffff]
Jun 09 19:31:03 openSUSE.site kernel:   Normal   [mem 0x100000000-0x1bf5fffff]
Jun 09 19:31:03 openSUSE.site kernel: Movable zone start for each node
Jun 09 19:31:03 openSUSE.site kernel: Early memory node ranges
Jun 09 19:31:03 openSUSE.site kernel:   node   0: [mem 0x00010000-0x0009cfff]
Jun 09 19:31:03 openSUSE.site kernel:   node   0: [mem 0x00100000-0x1fffffff]
Jun 09 19:31:03 openSUSE.site kernel:   node   0: [mem 0x20200000-0x40003fff]
Jun 09 19:31:03 openSUSE.site kernel:   node   0: [mem 0x40005000-0xa90a8fff]
Jun 09 19:31:03 openSUSE.site kernel:   node   0: [mem 0xa92ab000-0xb8151fff]
Jun 09 19:31:03 openSUSE.site kernel:   node   0: [mem 0xbafff000-0xbaffffff]
Jun 09 19:31:03 openSUSE.site kernel:   node   0: [mem 0x100000000-0x1bf5fffff]
Jun 09 19:31:03 openSUSE.site kernel: On node 0 totalpages: 1536733
Jun 09 19:31:03 openSUSE.site kernel:   DMA zone: 56 pages used for memmap
Jun 09 19:31:03 openSUSE.site kernel:   DMA zone: 6 pages reserved
Jun 09 19:31:03 openSUSE.site kernel:   DMA zone: 3919 pages, LIFO batch:0
Jun 09 19:31:03 openSUSE.site kernel:   DMA32 zone: 14280 pages used for memmap
Jun 09 19:31:03 openSUSE.site kernel:   DMA32 zone: 734600 pages, LIFO batch:31
Jun 09 19:31:03 openSUSE.site kernel:   Normal zone: 10717 pages used for memmap
Jun 09 19:31:03 openSUSE.site kernel:   Normal zone: 773155 pages, LIFO batch:31
Jun 09 19:31:03 openSUSE.site kernel: ACPI: PM-Timer IO Port: 0x408
Jun 09 19:31:03 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] disabled)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x06] lapic_id[0x00] disabled)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x07] lapic_id[0x00] disabled)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x08] lapic_id[0x00] disabled)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Jun 09 19:31:03 openSUSE.site kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Jun 09 19:31:03 openSUSE.site kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Jun 09 19:31:03 openSUSE.site kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
Jun 09 19:31:03 openSUSE.site kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: IRQ0 used by override.
Jun 09 19:31:03 openSUSE.site kernel: ACPI: IRQ2 used by override.
Jun 09 19:31:03 openSUSE.site kernel: ACPI: IRQ9 used by override.
Jun 09 19:31:03 openSUSE.site kernel: Using ACPI (MADT) for SMP configuration information
Jun 09 19:31:03 openSUSE.site kernel: ACPI: HPET id: 0x8086a301 base: 0xfed00000
Jun 09 19:31:03 openSUSE.site kernel: smpboot: Allowing 8 CPUs, 4 hotplug CPUs
Jun 09 19:31:03 openSUSE.site kernel: nr_irqs_gsi: 40
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 000000000009d000 - 000000000009e000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 0000000020000000 - 0000000020200000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 0000000040004000 - 0000000040005000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000a90a9000 - 00000000a92ab000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000b8152000 - 00000000baeef000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000baeef000 - 00000000baf9f000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000baf9f000 - 00000000bafff000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000bb000000 - 00000000bfa00000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000bfa00000 - 00000000f8000000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000f8000000 - 00000000fc000000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000fc000000 - 00000000fec00000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000fec00000 - 00000000fec01000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000fec01000 - 00000000fed08000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000fed08000 - 00000000fed09000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000fed09000 - 00000000fed10000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000fed10000 - 00000000fed1a000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000fed1a000 - 00000000fed1c000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000fed1c000 - 00000000fed20000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000fed20000 - 00000000fee00000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000fee00000 - 00000000fee01000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000fee01000 - 00000000ff980000
Jun 09 19:31:03 openSUSE.site kernel: PM: Registered nosave memory: 00000000ff980000 - 0000000100000000
Jun 09 19:31:03 openSUSE.site kernel: e820: [mem 0xbfa00000-0xf7ffffff] available for PCI devices
Jun 09 19:31:03 openSUSE.site kernel: Booting paravirtualized kernel on bare hardware
Jun 09 19:31:03 openSUSE.site kernel: setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:8 nr_node_ids:1
Jun 09 19:31:03 openSUSE.site kernel: PERCPU: Embedded 27 pages/cpu @ffff8801bf200000 s81856 r8192 d20544 u262144
Jun 09 19:31:03 openSUSE.site kernel: pcpu-alloc: s81856 r8192 d20544 u262144 alloc=1*2097152
Jun 09 19:31:03 openSUSE.site kernel: pcpu-alloc: [0] 0 1 2 3 4 5 6 7
Jun 09 19:31:03 openSUSE.site kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1511674
Jun 09 19:31:03 openSUSE.site kernel: Policy zone: Normal
Jun 09 19:31:03 openSUSE.site kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.7.10-1.11-desktop root=UUID=935330e8-5e6d-4d93-959b-ea4162b6c2f4 video=1600x900 resume=/dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part8 splash=silent quiet showopts
Jun 09 19:31:03 openSUSE.site kernel: bootsplash: silent mode.
Jun 09 19:31:03 openSUSE.site kernel: PID hash table entries: 4096 (order: 3, 32768 bytes)
Jun 09 19:31:03 openSUSE.site kernel: __ex_table already sorted, skipping sort
Jun 09 19:31:03 openSUSE.site kernel: xsave: enabled xstate_bv 0x7, cntxt size 0x340
Jun 09 19:31:03 openSUSE.site kernel: Checking aperture...
Jun 09 19:31:03 openSUSE.site kernel: Memory: 5948584k/7329792k available (5769k kernel code, 1182860k absent, 198348k reserved, 5184k data, 992k init)
Jun 09 19:31:03 openSUSE.site kernel: Preemptible hierarchical RCU implementation.
Jun 09 19:31:03 openSUSE.site kernel: 	RCU dyntick-idle grace-period acceleration is enabled.
Jun 09 19:31:03 openSUSE.site kernel: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
Jun 09 19:31:03 openSUSE.site kernel: NR_IRQS:33024 nr_irqs:744 16
Jun 09 19:31:03 openSUSE.site kernel: Extended CMOS year: 2000
Jun 09 19:31:03 openSUSE.site kernel: Console: colour dummy device 80x25
Jun 09 19:31:03 openSUSE.site kernel: console [tty0] enabled
Jun 09 19:31:03 openSUSE.site kernel: allocated 25165824 bytes of page_cgroup
Jun 09 19:31:03 openSUSE.site kernel: please try 'cgroup_disable=memory' option if you don't want memory cgroups
Jun 09 19:31:03 openSUSE.site kernel: hpet clockevent registered
Jun 09 19:31:03 openSUSE.site kernel: tsc: Fast TSC calibration using PIT
Jun 09 19:31:03 openSUSE.site kernel: tsc: Detected 2494.296 MHz processor
Jun 09 19:31:03 openSUSE.site kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4988.59 BogoMIPS (lpj=2494296)
Jun 09 19:31:03 openSUSE.site kernel: pid_max: default: 32768 minimum: 301
Jun 09 19:31:03 openSUSE.site kernel: Security Framework initialized
Jun 09 19:31:03 openSUSE.site kernel: AppArmor: AppArmor initialized
Jun 09 19:31:03 openSUSE.site kernel: Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
Jun 09 19:31:03 openSUSE.site kernel: Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
Jun 09 19:31:03 openSUSE.site kernel: Mount-cache hash table entries: 256
Jun 09 19:31:03 openSUSE.site kernel: Initializing cgroup subsys cpuacct
Jun 09 19:31:03 openSUSE.site kernel: Initializing cgroup subsys memory
Jun 09 19:31:03 openSUSE.site kernel: Initializing cgroup subsys devices
Jun 09 19:31:03 openSUSE.site kernel: Initializing cgroup subsys freezer
Jun 09 19:31:03 openSUSE.site kernel: Initializing cgroup subsys net_cls
Jun 09 19:31:03 openSUSE.site kernel: Initializing cgroup subsys blkio
Jun 09 19:31:03 openSUSE.site kernel: Initializing cgroup subsys perf_event
Jun 09 19:31:03 openSUSE.site kernel: Initializing cgroup subsys hugetlb
Jun 09 19:31:03 openSUSE.site kernel: CPU: Physical Processor ID: 0
Jun 09 19:31:03 openSUSE.site kernel: CPU: Processor Core ID: 0
Jun 09 19:31:03 openSUSE.site kernel: [117B blob data]
Jun 09 19:31:03 openSUSE.site kernel: mce: CPU supports 7 MCE banks
Jun 09 19:31:03 openSUSE.site kernel: CPU0: Thermal monitoring handled by SMI
Jun 09 19:31:03 openSUSE.site kernel: process: using mwait in idle threads
Jun 09 19:31:03 openSUSE.site kernel: Freeing SMP alternatives: 20k freed
Jun 09 19:31:03 openSUSE.site kernel: ACPI: Core revision 20120913
Jun 09 19:31:03 openSUSE.site kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Jun 09 19:31:03 openSUSE.site kernel: smpboot: CPU0: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz (fam: 06, model: 3a, stepping: 09)
Jun 09 19:31:03 openSUSE.site kernel: Performance Events: PEBS fmt1+, 16-deep LBR, IvyBridge events, Intel PMU driver.
Jun 09 19:31:03 openSUSE.site kernel: ... version:                3
Jun 09 19:31:03 openSUSE.site kernel: ... bit width:              48
Jun 09 19:31:03 openSUSE.site kernel: ... generic registers:      4
Jun 09 19:31:03 openSUSE.site kernel: ... value mask:             0000ffffffffffff
Jun 09 19:31:03 openSUSE.site kernel: ... max period:             000000007fffffff
Jun 09 19:31:03 openSUSE.site kernel: ... fixed-purpose events:   3
Jun 09 19:31:03 openSUSE.site kernel: ... event mask:             000000070000000f
Jun 09 19:31:03 openSUSE.site kernel: CPU1: Thermal monitoring handled by SMI
Jun 09 19:31:03 openSUSE.site kernel: NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
Jun 09 19:31:03 openSUSE.site kernel: CPU2: Thermal monitoring handled by SMI
Jun 09 19:31:03 openSUSE.site kernel: CPU3: Thermal monitoring handled by SMI
Jun 09 19:31:03 openSUSE.site kernel: smpboot: Booting Node   0, Processors  #1 #2 #3
Jun 09 19:31:03 openSUSE.site kernel: Brought up 4 CPUs
Jun 09 19:31:03 openSUSE.site kernel: smpboot: Total of 4 processors activated (19954.36 BogoMIPS)
Jun 09 19:31:03 openSUSE.site kernel: devtmpfs: initialized
Jun 09 19:31:03 openSUSE.site kernel: PM: Registering ACPI NVS region [mem 0xbaeef000-0xbaf9efff] (720896 bytes)
Jun 09 19:31:03 openSUSE.site kernel: RTC time: 19:30:55, date: 06/09/13
Jun 09 19:31:03 openSUSE.site kernel: NET: Registered protocol family 16
Jun 09 19:31:03 openSUSE.site kernel: ACPI: bus type pci registered
Jun 09 19:31:03 openSUSE.site kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
Jun 09 19:31:03 openSUSE.site kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
Jun 09 19:31:03 openSUSE.site kernel: PCI: Using configuration type 1 for base access
Jun 09 19:31:03 openSUSE.site kernel: mtrr: your CPUs had inconsistent variable MTRR settings
Jun 09 19:31:03 openSUSE.site kernel: mtrr: probably your BIOS does not setup all CPUs.
Jun 09 19:31:03 openSUSE.site kernel: mtrr: corrected configuration.
Jun 09 19:31:03 openSUSE.site kernel: bio: create slab <bio-0> at 0
Jun 09 19:31:03 openSUSE.site kernel: ACPI: Added _OSI(Module Device)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: Added _OSI(Processor Device)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: Added _OSI(Processor Aggregator Device)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: EC: Look up EC in DSDT
Jun 09 19:31:03 openSUSE.site kernel: ACPI: Executed 2 blocks of module-level executable AML code
Jun 09 19:31:03 openSUSE.site kernel: [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
Jun 09 19:31:03 openSUSE.site kernel: ACPI: SSDT 00000000bae8e018 0083B (v01  PmRef  Cpu0Cst 00003001 INTL 20061109)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: Dynamic OEM Table Load:
Jun 09 19:31:03 openSUSE.site kernel: ACPI: SSDT           (null) 0083B (v01  PmRef  Cpu0Cst 00003001 INTL 20061109)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: SSDT 00000000bae8fa98 00303 (v01  PmRef    ApIst 00003000 INTL 20061109)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: SSDT           (null) 00303 (v01  PmRef    ApIst 00003000 INTL 20061109)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: SSDT 00000000bae8dd98 00119 (v01  PmRef    ApCst 00003000 INTL 20061109)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: SSDT           (null) 00119 (v01  PmRef    ApCst 00003000 INTL 20061109)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: Interpreter enabled
Jun 09 19:31:03 openSUSE.site kernel: ACPI: (supports S0 S3 S4 S5)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: Using IOAPIC for interrupt routing
Jun 09 19:31:03 openSUSE.site kernel: ACPI: EC: GPE = 0x17, I/O: command/status = 0x66, data = 0x62
Jun 09 19:31:03 openSUSE.site kernel: ACPI: No dock devices found.
Jun 09 19:31:03 openSUSE.site kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Jun 09 19:31:03 openSUSE.site kernel: \_SB_.PCI0:_OSC invalid UUID
Jun 09 19:31:03 openSUSE.site kernel: _OSC request data:1 8 1f
Jun 09 19:31:03 openSUSE.site kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
Jun 09 19:31:03 openSUSE.site kernel: PCI host bridge to bus 0000:00
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:00: root bus resource [bus 00-3e]
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7]
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff]
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:00: root bus resource [mem 0xbfa00000-0xfeafffff]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:00.0: [8086:0154] type 00 class 0x060000
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:02.0: [8086:0166] type 00 class 0x030000
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:02.0: reg 10: [mem 0xf1000000-0xf13fffff 64bit]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:02.0: reg 20: [io  0x4000-0x403f]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:14.0: reg 10: [mem 0xf1600000-0xf160ffff 64bit]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:16.0: reg 10: [mem 0xf1615000-0xf161500f 64bit]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1a.0: reg 10: [mem 0xf161a000-0xf161a3ff]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1b.0: reg 10: [mem 0xf1610000-0xf1613fff 64bit]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1c.4: [8086:1e18] type 01 class 0x060400
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1d.0: reg 10: [mem 0xf1619000-0xf16193ff]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1f.0: [8086:1e57] type 00 class 0x060100
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1f.2: [8086:1e03] type 00 class 0x010601
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1f.2: reg 10: [io  0x4088-0x408f]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1f.2: reg 14: [io  0x409c-0x409f]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1f.2: reg 18: [io  0x4080-0x4087]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1f.2: reg 1c: [io  0x4098-0x409b]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1f.2: reg 20: [io  0x4060-0x407f]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1f.2: reg 24: [mem 0xf1618000-0xf16187ff]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1f.2: PME# supported from D3hot
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1f.3: reg 10: [mem 0xf1614000-0xf16140ff 64bit]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1f.3: reg 20: [io  0xefa0-0xefbf]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:01:00.0: [10de:0fd2] type 00 class 0x030000
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:01:00.0: reg 10: [mem 0xf0000000-0xf0ffffff]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:01:00.0: reg 14: [mem 0xc0000000-0xcfffffff 64bit pref]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:01:00.0: reg 1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:01:00.0: reg 24: [io  0x3000-0x307f]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:01:00.0: reg 30: [mem 0xfff80000-0xffffffff pref]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:01.0: PCI bridge to [bus 01]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:01.0:   bridge window [io  0x3000-0x3fff]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:01.0:   bridge window [mem 0xf0000000-0xf0ffffff]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:02:00.0: [8086:0887] type 00 class 0x028000
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:02:00.0: reg 10: [mem 0xf1500000-0xf1501fff 64bit]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1c.0: PCI bridge to [bus 02]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1c.0:   bridge window [mem 0xf1500000-0xf15fffff]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:03:00.0: [1969:1091] type 00 class 0x020000
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:03:00.0: reg 10: [mem 0xf1400000-0xf143ffff 64bit]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:03:00.0: reg 18: [io  0x2000-0x207f]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1c.4: PCI bridge to [bus 03]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1c.4:   bridge window [io  0x2000-0x2fff]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:1c.4:   bridge window [mem 0xf1400000-0xf14fffff]
Jun 09 19:31:03 openSUSE.site kernel: ACPI: PCI Interrupt Routing Table \_SB_.PCI0._PRT]
Jun 09 19:31:03 openSUSE.site kernel: ACPI: PCI Interrupt Routing Table \_SB_.PCI0.RP01._PRT]
Jun 09 19:31:03 openSUSE.site kernel: ACPI: PCI Interrupt Routing Table \_SB_.PCI0.RP05._PRT]
Jun 09 19:31:03 openSUSE.site kernel: ACPI: PCI Interrupt Routing Table \_SB_.PCI0.PEG0._PRT]
Jun 09 19:31:03 openSUSE.site kernel: _OSC request data:1 1f 1f
Jun 09 19:31:03 openSUSE.site kernel:  pci0000:00: ACPI _OSC support notification failed, disabling PCIe ASPM
Jun 09 19:31:03 openSUSE.site kernel:  pci0000:00: Unable to request _OSC control (_OSC support mask: 0x08)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 10 *11 12 14 15)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 10 11 12 14 15) *0, disabled.
Jun 09 19:31:03 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 *10 11 12 14 15)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 10 *11 12 14 15)
Jun 09 19:31:03 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 10 11 12 14 15) *0, disabled.
Jun 09 19:31:03 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 10 11 12 14 15) *0, disabled.
Jun 09 19:31:03 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 10 11 12 14 15) *7
Jun 09 19:31:03 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 *10 11 12 14 15)
Jun 09 19:31:03 openSUSE.site kernel: vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
Jun 09 19:31:03 openSUSE.site kernel: vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=none,locks=none
Jun 09 19:31:03 openSUSE.site kernel: vgaarb: loaded
Jun 09 19:31:03 openSUSE.site kernel: vgaarb: bridge control possible 0000:01:00.0
Jun 09 19:31:03 openSUSE.site kernel: vgaarb: no bridge control possible 0000:00:02.0
Jun 09 19:31:03 openSUSE.site kernel: SCSI subsystem initialized
Jun 09 19:31:03 openSUSE.site kernel: ACPI: bus type scsi registered
Jun 09 19:31:03 openSUSE.site kernel: libata version 3.00 loaded.
Jun 09 19:31:03 openSUSE.site kernel: ACPI: bus type usb registered
Jun 09 19:31:03 openSUSE.site kernel: usbcore: registered new interface driver usbfs
Jun 09 19:31:03 openSUSE.site kernel: usbcore: registered new interface driver hub
Jun 09 19:31:03 openSUSE.site kernel: usbcore: registered new device driver usb
Jun 09 19:31:03 openSUSE.site kernel: PCI: Using ACPI for IRQ routing
Jun 09 19:31:03 openSUSE.site kernel: PCI: pci_cache_line_size set to 64 bytes
Jun 09 19:31:03 openSUSE.site kernel: e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
Jun 09 19:31:03 openSUSE.site kernel: e820: reserve RAM buffer [mem 0x40004000-0x43ffffff]
Jun 09 19:31:03 openSUSE.site kernel: e820: reserve RAM buffer [mem 0xa90a9000-0xabffffff]
Jun 09 19:31:03 openSUSE.site kernel: e820: reserve RAM buffer [mem 0xb8152000-0xbbffffff]
Jun 09 19:31:03 openSUSE.site kernel: e820: reserve RAM buffer [mem 0xbb000000-0xbbffffff]
Jun 09 19:31:03 openSUSE.site kernel: e820: reserve RAM buffer [mem 0x1bf600000-0x1bfffffff]
Jun 09 19:31:03 openSUSE.site kernel: NetLabel: Initializing
Jun 09 19:31:03 openSUSE.site kernel: NetLabel:  domain hash size = 128
Jun 09 19:31:03 openSUSE.site kernel: NetLabel:  protocols = UNLABELED CIPSOv4
Jun 09 19:31:03 openSUSE.site kernel: NetLabel:  unlabeled traffic allowed by default
Jun 09 19:31:03 openSUSE.site kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
Jun 09 19:31:03 openSUSE.site kernel: hpet0: 8 comparators, 64-bit 14.318180 MHz counter
Jun 09 19:31:03 openSUSE.site kernel: Switching to clocksource hpet
Jun 09 19:31:03 openSUSE.site kernel: AppArmor: AppArmor Filesystem Enabled
Jun 09 19:31:03 openSUSE.site kernel: pnp: PnP ACPI init
Jun 09 19:31:03 openSUSE.site kernel: ACPI: bus type pnp registered
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [bus 00-3e]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [io  0x0000-0x0cf7 window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [io  0x0cf8-0x0cff]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [io  0x0d00-0xffff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x000a0000-0x000bffff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x000c0000-0x000c3fff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x000c4000-0x000c7fff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x000c8000-0x000cbfff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x000cc000-0x000cffff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x000d0000-0x000d3fff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x000d4000-0x000d7fff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x000d8000-0x000dbfff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x000dc000-0x000dffff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x000e0000-0x000e3fff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x000e4000-0x000e7fff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x000e8000-0x000ebfff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x000ec000-0x000effff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x000f0000-0x000fffff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0xbfa00000-0xfeafffff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: [mem 0x00010000-0x0001ffff window]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:01: [io  0x0000-0x001f]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:01: [io  0x0081-0x0091]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:01: [io  0x0093-0x009f]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:01: [io  0x00c0-0x00df]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:01: [dma 4]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:02: [mem 0xfed00000-0xfed003ff]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:02: Plug and Play ACPI device, IDs PNP0103 (active)
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:03: [io  0x00f0]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:03: [irq 13]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x002e-0x002f]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x004e-0x004f]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x0061]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x0063]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x0065]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x0067]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x0068]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x006c]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x0070]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x0080]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x0092]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x00b2-0x00b3]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x0680-0x069f]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x1000-0x1003]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x1004-0x1013]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0xffff]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x0400-0x0453]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x0458-0x047f]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x0500-0x057f]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:04: [io  0x164e-0x164f]
Jun 09 19:31:03 openSUSE.site kernel: system 00:04: [io  0x0680-0x069f] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:04: [io  0x1000-0x1003] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:04: [io  0x1004-0x1013] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:04: [io  0xffff] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:04: [io  0x0400-0x0453] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:04: [io  0x0458-0x047f] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:04: [io  0x0500-0x057f] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:04: [io  0x164e-0x164f] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:05: [io  0x0070-0x0077]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:05: [irq 8]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:06: [io  0x0454-0x0457]
Jun 09 19:31:03 openSUSE.site kernel: system 00:06: [io  0x0454-0x0457] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:06: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:07: [io  0x0060]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:07: [io  0x0064]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:07: [irq 1]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:08: [irq 12]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:08: Plug and Play ACPI device, IDs DLL055f PNP0f13 (active)
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:09: [mem 0xfed1c000-0xfed1ffff]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:09: [mem 0xfed10000-0xfed17fff]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:09: [mem 0xfed18000-0xfed18fff]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:09: [mem 0xfed19000-0xfed19fff]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:09: [mem 0xf8000000-0xfbffffff]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:09: [mem 0xfed20000-0xfed3ffff]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:09: [mem 0xfed90000-0xfed93fff]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:09: [mem 0xfed45000-0xfed8ffff]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:09: [mem 0xff000000-0xffffffff]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:09: [mem 0xfee00000-0xfeefffff]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:09: [mem 0xfffff000-0xffffffff]
Jun 09 19:31:03 openSUSE.site kernel: pnp 00:09: disabling [mem 0xfffff000-0xffffffff] because it overlaps 0000:01:00.0 BAR 6 [mem 0xfff80000-0xffffffff pref]
Jun 09 19:31:03 openSUSE.site kernel: system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:09: [mem 0xfed10000-0xfed17fff] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:09: [mem 0xfed18000-0xfed18fff] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:09: [mem 0xfed19000-0xfed19fff] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:09: [mem 0xf8000000-0xfbffffff] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:09: [mem 0xfed20000-0xfed3ffff] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:09: [mem 0xfed90000-0xfed93fff] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:09: [mem 0xfed45000-0xfed8ffff] has been reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:09: [mem 0xff000000-0xffffffff] could not be reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:09: [mem 0xfee00000-0xfeefffff] could not be reserved
Jun 09 19:31:03 openSUSE.site kernel: system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
Jun 09 19:31:03 openSUSE.site kernel: pnp: PnP ACPI: found 10 devices
Jun 09 19:31:03 openSUSE.site kernel: ACPI: ACPI bus type pnp unregistered
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:01:00.0: no compatible bridge window for [mem 0xfff80000-0xffffffff pref]
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:01:00.0: BAR 6: can't assign mem pref (size 0x80000)
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7]
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff]
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:00: resource 7 [mem 0xbfa00000-0xfeafffff]
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:01: resource 1 [mem 0xf0000000-0xf0ffffff]
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:02: resource 1 [mem 0xf1500000-0xf15fffff]
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:03: resource 0 [io  0x2000-0x2fff]
Jun 09 19:31:03 openSUSE.site kernel: pci_bus 0000:03: resource 1 [mem 0xf1400000-0xf14fffff]
Jun 09 19:31:03 openSUSE.site kernel: NET: Registered protocol family 2
Jun 09 19:31:03 openSUSE.site kernel: TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
Jun 09 19:31:03 openSUSE.site kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Jun 09 19:31:03 openSUSE.site kernel: TCP: Hash tables configured (established 524288 bind 65536)
Jun 09 19:31:03 openSUSE.site kernel: TCP: reno registered
Jun 09 19:31:03 openSUSE.site kernel: UDP hash table entries: 4096 (order: 5, 131072 bytes)
Jun 09 19:31:03 openSUSE.site kernel: UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
Jun 09 19:31:03 openSUSE.site kernel: pci 0000:00:02.0: Boot video device
Jun 09 19:31:03 openSUSE.site kernel: PCI: CLS 64 bytes, default 64
Jun 09 19:31:03 openSUSE.site kernel: Unpacking initramfs...
Jun 09 19:31:03 openSUSE.site kernel: Freeing initrd memory: 31212k freed
Jun 09 19:31:03 openSUSE.site kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Jun 09 19:31:03 openSUSE.site kernel: software IO TLB [mem 0xb414e000-0xb814dfff] (64MB) mapped at [ffff8800b414e000-ffff8800b814dfff]
Jun 09 19:31:03 openSUSE.site kernel: audit: initializing netlink socket (disabled)
Jun 09 19:31:03 openSUSE.site kernel: type=2000 audit(1370806255.441:1): initialized
Jun 09 19:31:03 openSUSE.site kernel: HugeTLB registered 2 MB page size, pre-allocated 0 pages
Jun 09 19:31:03 openSUSE.site kernel: VFS: Disk quotas dquot_6.5.2
Jun 09 19:31:03 openSUSE.site kernel: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jun 09 19:31:03 openSUSE.site kernel: msgmni has been set to 11679
Jun 09 19:31:03 openSUSE.site kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
Jun 09 19:31:03 openSUSE.site kernel: io scheduler noop registered
Jun 09 19:31:03 openSUSE.site kernel: io scheduler deadline registered
Jun 09 19:31:03 openSUSE.site kernel: io scheduler cfq registered (default)
Jun 09 19:31:03 openSUSE.site kernel: pcieport 0000:00:01.0: irq 40 for MSI/MSI-X
Jun 09 19:31:03 openSUSE.site kernel: vesafb: mode is 1600x900x32, linelength=6400, pages=0
Jun 09 19:31:03 openSUSE.site kernel: vesafb: scrolling: redraw
Jun 09 19:31:03 openSUSE.site kernel: vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
Jun 09 19:31:03 openSUSE.site kernel: vesafb: framebuffer at 0xe0000000, mapped to 0xffffc90005600000, using 5632k, total 5632k
Jun 09 19:31:03 openSUSE.site kernel: Console: switching to colour frame buffer device 200x56
Jun 09 19:31:03 openSUSE.site kernel: fb0: VESA VGA frame buffer device
Jun 09 19:31:03 openSUSE.site kernel: intel_idle: MWAIT substates: 0x21120
Jun 09 19:31:03 openSUSE.site kernel: intel_idle: v0.4 model 0x3A
Jun 09 19:31:03 openSUSE.site kernel: intel_idle: lapic_timer_reliable_states 0xffffffff
Jun 09 19:31:03 openSUSE.site kernel: GHES: HEST is not enabled!
Jun 09 19:31:03 openSUSE.site kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing disabled
Jun 09 19:31:03 openSUSE.site kernel: Non-volatile memory driver v1.3
Jun 09 19:31:03 openSUSE.site kernel: Linux agpgart interface v0.103
Jun 09 19:31:03 openSUSE.site kernel: ahci 0000:00:1f.2: version 3.0
Jun 09 19:31:03 openSUSE.site kernel: ahci 0000:00:1f.2: irq 41 for MSI/MSI-X
Jun 09 19:31:03 openSUSE.site kernel: ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x9 impl SATA mode
Jun 09 19:31:03 openSUSE.site kernel: ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
Jun 09 19:31:03 openSUSE.site kernel: ahci 0000:00:1f.2: setting latency timer to 64
Jun 09 19:31:03 openSUSE.site kernel: scsi0 : ahci
Jun 09 19:31:03 openSUSE.site kernel: scsi1 : ahci
Jun 09 19:31:03 openSUSE.site kernel: scsi2 : ahci
Jun 09 19:31:03 openSUSE.site kernel: scsi3 : ahci
Jun 09 19:31:03 openSUSE.site kernel: scsi4 : ahci
Jun 09 19:31:03 openSUSE.site kernel: scsi5 : ahci
Jun 09 19:31:03 openSUSE.site kernel: ata1: SATA max UDMA/133 abar m2048@0xf1618000 port 0xf1618100 irq 41
Jun 09 19:31:03 openSUSE.site kernel: ata2: DUMMY
Jun 09 19:31:03 openSUSE.site kernel: ata3: DUMMY
Jun 09 19:31:03 openSUSE.site kernel: ata4: SATA max UDMA/133 abar m2048@0xf1618000 port 0xf1618280 irq 41
Jun 09 19:31:03 openSUSE.site kernel: ata5: DUMMY
Jun 09 19:31:03 openSUSE.site kernel: ata6: DUMMY
Jun 09 19:31:03 openSUSE.site kernel: libphy: Fixed MDIO Bus: probed
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd 0000:00:1a.0: setting latency timer to 64
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd 0000:00:1a.0: EHCI Host Controller
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd 0000:00:1a.0: debug port 2
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf161a000
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
Jun 09 19:31:03 openSUSE.site kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jun 09 19:31:03 openSUSE.site kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 09 19:31:03 openSUSE.site kernel: usb usb1: Product: EHCI Host Controller
Jun 09 19:31:03 openSUSE.site kernel: usb usb1: Manufacturer: Linux 3.7.10-1.11-desktop ehci_hcd
Jun 09 19:31:03 openSUSE.site kernel: usb usb1: SerialNumber: 0000:00:1a.0
Jun 09 19:31:03 openSUSE.site kernel: hub 1-0:1.0: USB hub found
Jun 09 19:31:03 openSUSE.site kernel: hub 1-0:1.0: 2 ports detected
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd 0000:00:1d.0: setting latency timer to 64
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd 0000:00:1d.0: EHCI Host Controller
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd 0000:00:1d.0: debug port 2
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf1619000
Jun 09 19:31:03 openSUSE.site kernel: ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
Jun 09 19:31:03 openSUSE.site kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
Jun 09 19:31:03 openSUSE.site kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 09 19:31:03 openSUSE.site kernel: usb usb2: Product: EHCI Host Controller
Jun 09 19:31:03 openSUSE.site kernel: usb usb2: Manufacturer: Linux 3.7.10-1.11-desktop ehci_hcd
Jun 09 19:31:03 openSUSE.site kernel: usb usb2: SerialNumber: 0000:00:1d.0
Jun 09 19:31:03 openSUSE.site kernel: hub 2-0:1.0: USB hub found
Jun 09 19:31:03 openSUSE.site kernel: hub 2-0:1.0: 2 ports detected
Jun 09 19:31:03 openSUSE.site kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jun 09 19:31:03 openSUSE.site kernel: uhci_hcd: USB Universal Host Controller Interface driver
Jun 09 19:31:03 openSUSE.site kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Jun 09 19:31:03 openSUSE.site kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Jun 09 19:31:03 openSUSE.site kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Jun 09 19:31:03 openSUSE.site kernel: mousedev: PS/2 mouse device common for all mice
Jun 09 19:31:03 openSUSE.site kernel: rtc_cmos 00:05: RTC can wake from S4
Jun 09 19:31:03 openSUSE.site kernel: rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
Jun 09 19:31:03 openSUSE.site kernel: rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
Jun 09 19:31:03 openSUSE.site kernel: cpuidle: using governor ladder
Jun 09 19:31:03 openSUSE.site kernel: cpuidle: using governor menu
Jun 09 19:31:03 openSUSE.site kernel: ledtrig-cpu: registered to indicate activity on CPUs
Jun 09 19:31:03 openSUSE.site kernel: EFI Variables Facility v0.08 2004-May-17
Jun 09 19:31:03 openSUSE.site kernel: usbcore: registered new interface driver usbhid
Jun 09 19:31:03 openSUSE.site kernel: usbhid: USB HID core driver
Jun 09 19:31:03 openSUSE.site kernel: TCP: cubic registered
Jun 09 19:31:03 openSUSE.site kernel: NET: Registered protocol family 10
Jun 09 19:31:03 openSUSE.site kernel: lib80211: common routines for IEEE802.11 drivers
Jun 09 19:31:03 openSUSE.site kernel: lib80211_crypt: registered algorithm 'NULL'
Jun 09 19:31:03 openSUSE.site kernel: Key type dns_resolver registered
Jun 09 19:31:03 openSUSE.site kernel: PM: Checking hibernation image partition /dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part8
Jun 09 19:31:03 openSUSE.site kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
Jun 09 19:31:03 openSUSE.site kernel: ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Jun 09 19:31:03 openSUSE.site kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jun 09 19:31:03 openSUSE.site kernel: ata1.00: ATA-8: ST9750420AS, 0002DEM1, max UDMA/133
Jun 09 19:31:03 openSUSE.site kernel: ata1.00: 1465149168 sectors, multi 16: LBA48 NCQ (depth 31/32)
Jun 09 19:31:03 openSUSE.site kernel: ata1.00: configured for UDMA/133
Jun 09 19:31:03 openSUSE.site kernel: scsi 0:0:0:0: Direct-Access     ATA      ST9750420AS      0002 PQ: 0 ANSI: 5
Jun 09 19:31:03 openSUSE.site kernel: sd 0:0:0:0: [sda] 1465149168 512-byte logical blocks: (750 GB/698 GiB)
Jun 09 19:31:03 openSUSE.site kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
Jun 09 19:31:03 openSUSE.site kernel: sd 0:0:0:0: [sda] Write Protect is off
Jun 09 19:31:03 openSUSE.site kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Jun 09 19:31:03 openSUSE.site kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 09 19:31:03 openSUSE.site kernel: usb 1-1: new high-speed USB device number 2 using ehci_hcd
Jun 09 19:31:03 openSUSE.site kernel: ata4.00: ATAPI: MATSHITA DVD+/-RW UJ8D1, D.02, max UDMA/100
Jun 09 19:31:03 openSUSE.site kernel: ata4.00: configured for UDMA/100
Jun 09 19:31:03 openSUSE.site kernel: scsi 3:0:0:0: CD-ROM            MATSHITA DVD+-RW UJ8D1    D.02 PQ: 0 ANSI: 5
Jun 09 19:31:03 openSUSE.site kernel:  sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 sda8 sda9 sda10 >
Jun 09 19:31:03 openSUSE.site kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jun 09 19:31:03 openSUSE.site kernel: usb 1-1: New USB device found, idVendor=8087, idProduct=0024
Jun 09 19:31:03 openSUSE.site kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 09 19:31:03 openSUSE.site kernel: hub 1-1:1.0: USB hub found
Jun 09 19:31:03 openSUSE.site kernel: hub 1-1:1.0: 6 ports detected
Jun 09 19:31:03 openSUSE.site kernel: usb 2-1: new high-speed USB device number 2 using ehci_hcd
Jun 09 19:31:03 openSUSE.site kernel: usb 2-1: New USB device found, idVendor=8087, idProduct=0024
Jun 09 19:31:03 openSUSE.site kernel: usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 09 19:31:03 openSUSE.site kernel: hub 2-1:1.0: USB hub found
Jun 09 19:31:03 openSUSE.site kernel: hub 2-1:1.0: 8 ports detected
Jun 09 19:31:03 openSUSE.site kernel: usb 1-1.3: new high-speed USB device number 3 using ehci_hcd
Jun 09 19:31:03 openSUSE.site kernel: tsc: Refined TSC clocksource calibration: 2494.333 MHz
Jun 09 19:31:03 openSUSE.site kernel: Switching to clocksource tsc
Jun 09 19:31:03 openSUSE.site kernel: usb 1-1.3: New USB device found, idVendor=0bda, idProduct=0129
Jun 09 19:31:03 openSUSE.site kernel: usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun 09 19:31:03 openSUSE.site kernel: usb 1-1.3: Product: USB2.0-CRW
Jun 09 19:31:03 openSUSE.site kernel: usb 1-1.3: Manufacturer: Generic
Jun 09 19:31:03 openSUSE.site kernel: usb 1-1.3: SerialNumber: 20100201396000000
Jun 09 19:31:03 openSUSE.site kernel: usb 1-1.5: new high-speed USB device number 4 using ehci_hcd
Jun 09 19:31:03 openSUSE.site kernel: input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input1
Jun 09 19:31:03 openSUSE.site kernel: PM: Hibernation image not present or could not be loaded.
Jun 09 19:31:03 openSUSE.site kernel: registered taskstats version 1
Jun 09 19:31:03 openSUSE.site kernel:   Magic number: 1:170:546
Jun 09 19:31:03 openSUSE.site kernel: tty ttyS22: hash matches
Jun 09 19:31:03 openSUSE.site kernel: mem null: hash matches
Jun 09 19:31:03 openSUSE.site kernel: rtc_cmos 00:05: setting system clock to 2013-06-09 19:30:57 UTC (1370806257)
Jun 09 19:31:03 openSUSE.site kernel: Freeing unused kernel memory: 992k freed
Jun 09 19:31:03 openSUSE.site kernel: Write protecting the kernel read-only data: 10240k
Jun 09 19:31:03 openSUSE.site kernel: Freeing unused kernel memory: 364k freed
Jun 09 19:31:03 openSUSE.site kernel: Freeing unused kernel memory: 108k freed
Jun 09 19:31:03 openSUSE.site kernel: hp_sw: device handler registered
Jun 09 19:31:03 openSUSE.site kernel: emc: device handler registered
Jun 09 19:31:03 openSUSE.site kernel: alua: device handler registered
Jun 09 19:31:03 openSUSE.site kernel: rdac: device handler registered
Jun 09 19:31:03 openSUSE.site kernel: usb 1-1.5: New USB device found, idVendor=064e, idProduct=8126
Jun 09 19:31:03 openSUSE.site kernel: usb 1-1.5: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Jun 09 19:31:03 openSUSE.site kernel: usb 1-1.5: Product: Laptop_Integrated_Webcam_HD
Jun 09 19:31:03 openSUSE.site kernel: usb 1-1.5: Manufacturer: SuYin
Jun 09 19:31:03 openSUSE.site systemd-udevd[118]: starting version 195
Jun 09 19:31:03 openSUSE.site kernel: ACPI: Requesting acpi_cpufreq
Jun 09 19:31:03 openSUSE.site kernel: xhci_hcd 0000:00:14.0: setting latency timer to 64
Jun 09 19:31:03 openSUSE.site kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
Jun 09 19:31:03 openSUSE.site kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
Jun 09 19:31:03 openSUSE.site kernel: xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
Jun 09 19:31:03 openSUSE.site kernel: xhci_hcd 0000:00:14.0: irq 21, io mem 0xf1600000
Jun 09 19:31:03 openSUSE.site kernel: xhci_hcd 0000:00:14.0: irq 42 for MSI/MSI-X
Jun 09 19:31:03 openSUSE.site kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
Jun 09 19:31:03 openSUSE.site kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 09 19:31:03 openSUSE.site kernel: usb usb3: Product: xHCI Host Controller
Jun 09 19:31:03 openSUSE.site kernel: usb usb3: Manufacturer: Linux 3.7.10-1.11-desktop xhci_hcd
Jun 09 19:31:03 openSUSE.site kernel: usb usb3: SerialNumber: 0000:00:14.0
Jun 09 19:31:03 openSUSE.site kernel: xHCI xhci_add_endpoint called for root hub
Jun 09 19:31:03 openSUSE.site kernel: xHCI xhci_check_bandwidth called for root hub
Jun 09 19:31:03 openSUSE.site kernel: hub 3-0:1.0: USB hub found
Jun 09 19:31:03 openSUSE.site kernel: hub 3-0:1.0: 4 ports detected
Jun 09 19:31:03 openSUSE.site kernel: thermal LNXTHERM:00: registered as thermal_zone0
Jun 09 19:31:03 openSUSE.site kernel: ACPI: Thermal Zone [TZ00] (41 C)
Jun 09 19:31:03 openSUSE.site kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
Jun 09 19:31:03 openSUSE.site kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
Jun 09 19:31:03 openSUSE.site kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 09 19:31:03 openSUSE.site kernel: usb usb4: Product: xHCI Host Controller
Jun 09 19:31:03 openSUSE.site kernel: usb usb4: Manufacturer: Linux 3.7.10-1.11-desktop xhci_hcd
Jun 09 19:31:03 openSUSE.site kernel: usb usb4: SerialNumber: 0000:00:14.0
Jun 09 19:31:03 openSUSE.site kernel: thermal LNXTHERM:01: registered as thermal_zone1
Jun 09 19:31:03 openSUSE.site kernel: ACPI: Thermal Zone [TZ01] (41 C)
Jun 09 19:31:03 openSUSE.site kernel: hub 4-0:1.0: USB hub found
Jun 09 19:31:03 openSUSE.site kernel: hub 4-0:1.0: 4 ports detected
Jun 09 19:31:03 openSUSE.site kernel: usb 2-1.5: new full-speed USB device number 3 using ehci_hcd
Jun 09 19:31:03 openSUSE.site kernel: usb 2-1.5: New USB device found, idVendor=8087, idProduct=07da
Jun 09 19:31:03 openSUSE.site kernel: usb 2-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 09 19:31:03 openSUSE.site kernel: usb 3-4: new low-speed USB device number 2 using xhci_hcd
Jun 09 19:31:03 openSUSE.site kernel: usb 3-4: New USB device found, idVendor=17ef, idProduct=6025
Jun 09 19:31:03 openSUSE.site kernel: usb 3-4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Jun 09 19:31:03 openSUSE.site kernel: usb 3-4: Product: ThinkPad USB Travel Mouse
Jun 09 19:31:03 openSUSE.site kernel: usb 3-4: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
Jun 09 19:31:03 openSUSE.site kernel: input: ThinkPad USB Travel Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.0/input/input2
Jun 09 19:31:03 openSUSE.site kernel: hid-generic 0003:17EF:6025.0001: input,hidraw0: USB HID v11.10 Mouse [ThinkPad USB Travel Mouse] on usb-0000:00:14.0-4/input0
Jun 09 19:31:03 openSUSE.site kernel: PM: Marking nosave pages: [mem 0x0009d000-0x000fffff]
Jun 09 19:31:03 openSUSE.site kernel: PM: Marking nosave pages: [mem 0x20000000-0x201fffff]
Jun 09 19:31:03 openSUSE.site kernel: PM: Marking nosave pages: [mem 0x40004000-0x40004fff]
Jun 09 19:31:03 openSUSE.site kernel: PM: Marking nosave pages: [mem 0xa90a9000-0xa92aafff]
Jun 09 19:31:03 openSUSE.site kernel: PM: Marking nosave pages: [mem 0xb8152000-0xbaffefff]
Jun 09 19:31:03 openSUSE.site kernel: PM: Marking nosave pages: [mem 0xbb000000-0xffffffff]
Jun 09 19:31:03 openSUSE.site kernel: PM: Basic memory bitmaps created
Jun 09 19:31:03 openSUSE.site kernel: PM: Basic memory bitmaps freed
Jun 09 19:31:03 openSUSE.site kernel: PM: Starting manual resume from disk
Jun 09 19:31:03 openSUSE.site kernel: PM: Hibernation image partition 8:8 present
Jun 09 19:31:03 openSUSE.site kernel: PM: Looking for hibernation image.
Jun 09 19:31:03 openSUSE.site kernel: PM: Image not found (code -22)
Jun 09 19:31:03 openSUSE.site kernel: EXT4-fs (sda9): mounted filesystem with ordered data mode. Opts: acl,user_xattr
Jun 09 19:31:03 openSUSE.site kernel: EXT4-fs (sda9): re-mounted. Opts: acl,user_xattr
Jun 09 19:31:03 openSUSE.site systemd[1]: RTC configured in localtime, applying delta of 480 minutes to system time.
Jun 09 19:31:03 openSUSE.site systemd[1]: systemd 195 running in system mode. (+PAM +LIBWRAP +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ; suse)
Jun 09 19:31:03 openSUSE.site systemd[1]: Inserted module 'autofs4'
Jun 09 19:31:03 openSUSE.site systemd[1]: Set hostname to <openSUSE.site>.
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting Replay Read-Ahead Data...
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting Collect Read-Ahead Data...
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
Jun 09 19:31:03 openSUSE.site systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting Syslog Socket.
Jun 09 19:31:03 openSUSE.site systemd[1]: Listening on Syslog Socket.
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting Remote File Systems.
Jun 09 19:31:03 openSUSE.site systemd[1]: Reached target Remote File Systems.
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting Delayed Shutdown Socket.
Jun 09 19:31:03 openSUSE.site systemd[1]: Listening on Delayed Shutdown Socket.
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
Jun 09 19:31:03 openSUSE.site systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting udev Kernel Socket.
Jun 09 19:31:03 openSUSE.site systemd[1]: Listening on udev Kernel Socket.
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting udev Control Socket.
Jun 09 19:31:03 openSUSE.site systemd[1]: Listening on udev Control Socket.
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
Jun 09 19:31:03 openSUSE.site systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting Encrypted Volumes.
Jun 09 19:31:03 openSUSE.site systemd[1]: Reached target Encrypted Volumes.
Jun 09 19:31:03 openSUSE.site systemd[1]: Expecting device dev-disk-by\x2did-ata\x2dST9750420AS_6WS1TZ7Q\x2dpart8.device...
Jun 09 19:31:03 openSUSE.site systemd[1]: Expecting device dev-disk-by\x2did-ata\x2dST9750420AS_6WS1TZ7Q\x2dpart10.device...
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting Journal Socket.
Jun 09 19:31:03 openSUSE.site systemd[1]: Listening on Journal Socket.
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting LSB: iSCSI initiator daemon root-fs support...
Jun 09 19:31:03 openSUSE.site systemd[1]: Mounting POSIX Message Queue File System...
Jun 09 19:31:03 openSUSE.site systemd-readahead[251]: Bumped block_nr parameter of 8:0 to 20480. This is a temporary hack and should be removed one day.
Jun 09 19:31:03 openSUSE.site systemd[1]: Mounting Huge Pages File System...
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting Create dynamic rule for /dev/root link...
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting Journal Service...
Jun 09 19:31:03 openSUSE.site systemd[1]: Started Journal Service.
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting LSB: Set default boot entry if called...
Jun 09 19:31:03 openSUSE.site systemd-journal[257]: Journal started
Jun 09 19:31:03 openSUSE.site systemd[1]: Started Collect Read-Ahead Data.
Jun 09 19:31:03 openSUSE.site systemd[1]: Started Replay Read-Ahead Data.
Jun 09 19:31:03 openSUSE.site systemd[1]: Started Set Up Additional Binary Formats.
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting Setup Virtual Console...
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting Load Kernel Modules...
Jun 09 19:31:03 openSUSE.site systemd[1]: Started File System Check on Root Device.
Jun 09 19:31:03 openSUSE.site systemd[1]: Starting Remount Root and Kernel File Systems...
Jun 09 19:31:03 openSUSE.site systemd-modules-load[261]: libkmod: kmod_config_parse: /etc/modprobe.d/10-unsupported-modules.conf line 10: ignoring bad line starting with 'allow_unsupported_modules'
Jun 09 19:31:03 openSUSE.site kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Jun 09 19:31:04 openSUSE.site systemd-modules-load[261]: Inserted module 'pciehp'
Jun 09 19:31:04 openSUSE.site kernel: pciehp: PCI Express Hot Plug Controller Driver version: 0.4
Jun 09 19:31:04 openSUSE.site systemd[1]: Started Load Kernel Modules.
Jun 09 19:31:04 openSUSE.site systemd[1]: Mounted Configuration File System.
Jun 09 19:31:04 openSUSE.site systemd[1]: Starting Apply Kernel Variables...
Jun 09 19:31:04 openSUSE.site systemd[1]: Mounted FUSE Control File System.
Jun 09 19:31:04 openSUSE.site systemd[1]: Mounted Huge Pages File System.
Jun 09 19:31:04 openSUSE.site systemd[1]: Mounted POSIX Message Queue File System.
Jun 09 19:31:04 openSUSE.site systemd[1]: Started Create dynamic rule for /dev/root link.
Jun 09 19:31:04 openSUSE.site systemd[1]: Starting udev Kernel Device Manager...
Jun 09 19:31:04 openSUSE.site systemd[1]: Started LSB: iSCSI initiator daemon root-fs support.
Jun 09 19:31:05 openSUSE.site kernel: EXT4-fs (sda9): re-mounted. Opts: acl,user_xattr
Jun 09 19:31:05 openSUSE.site systemd[1]: Started Remount Root and Kernel File Systems.
Jun 09 19:31:05 openSUSE.site systemd[1]: Starting Load Random Seed...
Jun 09 19:31:05 openSUSE.site systemd[1]: Started LSB: Set default boot entry if called.
Jun 09 19:31:05 openSUSE.site systemd[1]: Started Apply Kernel Variables.
Jun 09 19:31:05 openSUSE.site systemd[1]: Started udev Kernel Device Manager.
Jun 09 19:31:05 openSUSE.site systemd[1]: Starting Local File Systems (Pre).
Jun 09 19:31:05 openSUSE.site systemd[1]: Reached target Local File Systems (Pre).
Jun 09 19:31:05 openSUSE.site systemd[1]: Mounting Lock Directory...
Jun 09 19:31:05 openSUSE.site systemd-udevd[284]: starting version 195
Jun 09 19:31:05 openSUSE.site systemd[1]: var-lock.mount: Directory /var/lock to mount over is not empty, mounting anyway. (To see the over-mounted files, please manually mount the underlying file system to a secondary location.)
Jun 09 19:31:05 openSUSE.site systemd[1]: Mounting /sys/kernel/debug...
Jun 09 19:31:05 openSUSE.site systemd[1]: Mounting Runtime Directory...
Jun 09 19:31:05 openSUSE.site systemd[1]: var-run.mount: Directory /var/run to mount over is not empty, mounting anyway. (To see the over-mounted files, please manually mount the underlying file system to a secondary location.)
Jun 09 19:31:05 openSUSE.site systemd[1]: Started Load Random Seed.
Jun 09 19:31:05 openSUSE.site systemd[1]: Mounted Lock Directory.
Jun 09 19:31:05 openSUSE.site systemd[1]: Mounted /sys/kernel/debug.
Jun 09 19:31:05 openSUSE.site systemd[1]: Mounted Runtime Directory.
Jun 09 19:31:05 openSUSE.site kernel: BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
Jun 09 19:31:05 openSUSE.site kernel: EDD information not available.
Jun 09 19:31:05 openSUSE.site systemd[1]: Started Setup Virtual Console.
Jun 09 19:31:05 openSUSE.site systemd[1]: Starting udev Coldplug all Devices...
Jun 09 19:31:05 openSUSE.site systemd[1]: Started udev Coldplug all Devices.
Jun 09 19:31:05 openSUSE.site systemd[1]: Starting Show Plymouth Boot Screen...
Jun 09 19:31:05 openSUSE.site systemd-udevd[355]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[357]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[356]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[358]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[359]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[364]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[366]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[367]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[368]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[369]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[370]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[371]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[372]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[373]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[374]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[375]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site systemd-udevd[362]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:05 openSUSE.site kernel: input: PC Speaker as /devices/platform/pcspkr/input/input3
Jun 09 19:31:06 openSUSE.site systemd-udevd[509]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jun 09 19:31:06 openSUSE.site kernel: scsi 3:0:0:0: Attached scsi generic sg1 type 5
Jun 09 19:31:06 openSUSE.site kernel: wmi: Mapper loaded
Jun 09 19:31:06 openSUSE.site systemd-udevd[560]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site kernel: sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
Jun 09 19:31:06 openSUSE.site kernel: cdrom: Uniform CD-ROM driver Revision: 3.20
Jun 09 19:31:06 openSUSE.site kernel: sr 3:0:0:0: Attached scsi CD-ROM sr0
Jun 09 19:31:06 openSUSE.site kernel: ACPI: Invalid Power Resource to register!
Jun 09 19:31:06 openSUSE.site kernel: ACPI Warning:
Jun 09 19:31:06 openSUSE.site kernel: 0x000000000000efa0-0x000000000000efbf SystemIO conflicts with Region \_SB_.PCI0.SBUS.SMBI 1 (20120913/utaddress-251)
Jun 09 19:31:06 openSUSE.site kernel: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Jun 09 19:31:06 openSUSE.site kernel: ACPI Warning: 0x0000000000000428-0x000000000000042f SystemIO conflicts with Region \PMIO 1 (20120913/utaddress-251)
Jun 09 19:31:06 openSUSE.site kernel: ACPI Warning: 0x0000000000000530-0x000000000000053f SystemIO conflicts with Region \GPIO 1 (20120913/utaddress-251)
Jun 09 19:31:06 openSUSE.site kernel: ACPI Warning: 0x0000000000000530-0x000000000000053f SystemIO conflicts with Region \_SB_.PCI0.PEG0.PEGP.GPIO 2 (20120913/utaddress-251)
Jun 09 19:31:06 openSUSE.site kernel: ACPI Warning: 0x0000000000000500-0x000000000000052f SystemIO conflicts with Region \GPIO 1 (20120913/utaddress-251)
Jun 09 19:31:06 openSUSE.site kernel: ACPI Warning: 0x0000000000000500-0x000000000000052f SystemIO conflicts with Region \_SB_.PCI0.PEG0.PEGP.GPIO 2 (20120913/utaddress-251)
Jun 09 19:31:06 openSUSE.site kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Jun 09 19:31:06 openSUSE.site systemd-udevd[563]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[562]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site kernel: microcode: CPU0 sig=0x306a9, pf=0x10, revision=0x12
Jun 09 19:31:06 openSUSE.site kernel: dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
Jun 09 19:31:06 openSUSE.site kernel: ACPI: Deprecated procfs I/F for AC is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
Jun 09 19:31:06 openSUSE.site kernel: mei 0000:00:16.0: setting latency timer to 64
Jun 09 19:31:06 openSUSE.site kernel: mei 0000:00:16.0: irq 43 for MSI/MSI-X
Jun 09 19:31:06 openSUSE.site kernel: mei 0000:00:16.0: wd: failed to find the client
Jun 09 19:31:06 openSUSE.site systemd-udevd[581]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[582]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[583]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[584]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[580]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[587]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[588]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[590]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[597]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[600]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[601]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[603]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site mtp-probe[585]: checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4"
Jun 09 19:31:06 openSUSE.site mtp-probe[604]: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5"
Jun 09 19:31:06 openSUSE.site mtp-probe[602]: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3"
Jun 09 19:31:06 openSUSE.site mtp-probe[585]: bus: 3, device: 2 was not an MTP device
Jun 09 19:31:06 openSUSE.site mtp-probe[604]: bus: 1, device: 4 was not an MTP device
Jun 09 19:31:06 openSUSE.site mtp-probe[602]: bus: 1, device: 3 was not an MTP device
Jun 09 19:31:06 openSUSE.site kernel: ACPI: AC Adapter [ADP0] (on-line)
Jun 09 19:31:06 openSUSE.site kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4
Jun 09 19:31:06 openSUSE.site kernel: ACPI: Power Button [PWRB]
Jun 09 19:31:06 openSUSE.site kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5
Jun 09 19:31:06 openSUSE.site kernel: ACPI: Sleep Button [SLPB]
Jun 09 19:31:06 openSUSE.site kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input6
Jun 09 19:31:06 openSUSE.site kernel: ACPI: Lid Switch [LID0]
Jun 09 19:31:06 openSUSE.site kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input7
Jun 09 19:31:06 openSUSE.site kernel: ACPI: Power Button [PWRF]
Jun 09 19:31:06 openSUSE.site kernel: input: Dell WMI hotkeys as /devices/virtual/input/input8
Jun 09 19:31:06 openSUSE.site systemd-udevd[629]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site kernel: ACPI: Deprecated procfs I/F for battery is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
Jun 09 19:31:06 openSUSE.site kernel: ACPI: Battery Slot [BAT0] (battery present)
Jun 09 19:31:06 openSUSE.site kernel: Registered led device: dell-laptop::touchpad
Jun 09 19:31:06 openSUSE.site kernel: iTCO_vendor_support: vendor-support=0
Jun 09 19:31:06 openSUSE.site kernel: iTCO_wdt: Intel TCO WatchDog Timer Driver v1.10
Jun 09 19:31:06 openSUSE.site kernel: iTCO_wdt: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
Jun 09 19:31:06 openSUSE.site kernel: iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Jun 09 19:31:06 openSUSE.site kernel: cfg80211: Calling CRDA to update world regulatory domain
Jun 09 19:31:06 openSUSE.site kernel: Intel(R) Wireless WiFi driver for Linux, in-tree:d
Jun 09 19:31:06 openSUSE.site kernel: Copyright(c) 2003-2012 Intel Corporation
Jun 09 19:31:06 openSUSE.site kernel: iwlwifi 0000:02:00.0: pci_resource_len = 0x00002000
Jun 09 19:31:06 openSUSE.site kernel: iwlwifi 0000:02:00.0: pci_resource_base = ffffc900055a4000
Jun 09 19:31:06 openSUSE.site kernel: iwlwifi 0000:02:00.0: HW Revision ID = 0xC4
Jun 09 19:31:06 openSUSE.site kernel: iwlwifi 0000:02:00.0: irq 44 for MSI/MSI-X
Jun 09 19:31:06 openSUSE.site systemd-udevd[637]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site kernel: microcode: CPU0 updated to revision 0x17, date = 2013-01-09
Jun 09 19:31:06 openSUSE.site kernel: microcode: CPU1 sig=0x306a9, pf=0x10, revision=0x12
Jun 09 19:31:06 openSUSE.site kernel: microcode: CPU1 updated to revision 0x17, date = 2013-01-09
Jun 09 19:31:06 openSUSE.site kernel: microcode: CPU2 sig=0x306a9, pf=0x10, revision=0x12
Jun 09 19:31:06 openSUSE.site kernel: microcode: CPU2 updated to revision 0x17, date = 2013-01-09
Jun 09 19:31:06 openSUSE.site kernel: microcode: CPU3 sig=0x306a9, pf=0x10, revision=0x12
Jun 09 19:31:06 openSUSE.site kernel: microcode: CPU3 updated to revision 0x17, date = 2013-01-09
Jun 09 19:31:06 openSUSE.site kernel: microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
Jun 09 19:31:06 openSUSE.site kernel: cfg80211: World regulatory domain updated:
Jun 09 19:31:06 openSUSE.site kernel: cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jun 09 19:31:06 openSUSE.site kernel: cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 09 19:31:06 openSUSE.site kernel: cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Jun 09 19:31:06 openSUSE.site kernel: cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Jun 09 19:31:06 openSUSE.site kernel: cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 09 19:31:06 openSUSE.site kernel: cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 09 19:31:06 openSUSE.site systemd-udevd[658]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[662]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[663]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[664]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[665]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:06 openSUSE.site systemd-udevd[666]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:07 openSUSE.site kernel: snd_hda_intel 0000:00:1b.0: irq 45 for MSI/MSI-X
Jun 09 19:31:07 openSUSE.site kernel: hda_codec: CX20590: BIOS auto-probing.
Jun 09 19:31:07 openSUSE.site kernel: ALSA hda_auto_parser.c:318 autoconfig: line_outs=1 (0x1f/0x0/0x0/0x0/0x0) type:speaker
Jun 09 19:31:07 openSUSE.site kernel: ALSA hda_auto_parser.c:322    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Jun 09 19:31:07 openSUSE.site kernel: ALSA hda_auto_parser.c:326    hp_outs=1 (0x19/0x0/0x0/0x0/0x0)
Jun 09 19:31:07 openSUSE.site kernel: ALSA hda_auto_parser.c:327    mono: mono_out=0x0
Jun 09 19:31:07 openSUSE.site kernel: ALSA hda_auto_parser.c:331    inputs:
Jun 09 19:31:07 openSUSE.site kernel: ALSA hda_auto_parser.c:335      Mic=0x1a
Jun 09 19:31:07 openSUSE.site kernel: ALSA hda_auto_parser.c:335      Internal Mic=0x23
Jun 09 19:31:07 openSUSE.site kernel: input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input9
Jun 09 19:31:07 openSUSE.site kernel: ALSA patch_conexant.c:4531 hda_codec: Enable sync_write for stable communication
Jun 09 19:31:07 openSUSE.site kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
Jun 09 19:31:07 openSUSE.site kernel: input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
Jun 09 19:31:07 openSUSE.site kernel: input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
Jun 09 19:31:07 openSUSE.site systemd-udevd[680]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:07 openSUSE.site systemd[1]: Starting Sound Card.
Jun 09 19:31:07 openSUSE.site systemd[1]: Reached target Sound Card.
Jun 09 19:31:07 openSUSE.site kernel: [drm] Initialized drm 1.1.0 20060810
Jun 09 19:31:07 openSUSE.site kernel: pci 0000:00:00.0: Intel Ivybridge Chipset
Jun 09 19:31:07 openSUSE.site kernel: pci 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
Jun 09 19:31:07 openSUSE.site kernel: pci 0000:00:00.0: detected 65536K stolen memory
Jun 09 19:31:07 openSUSE.site kernel: checking generic (e0000000 580000) vs hw (e0000000 10000000)
Jun 09 19:31:07 openSUSE.site kernel: fb: conflicting fb hw usage inteldrmfb vs VESA VGA - removing generic driver
Jun 09 19:31:07 openSUSE.site kernel: Console: switching to colour dummy device 80x25
Jun 09 19:31:07 openSUSE.site kernel: VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.PEG0.PEGP handle
Jun 09 19:31:07 openSUSE.site kernel: i915 0000:00:02.0: setting latency timer to 64
Jun 09 19:31:07 openSUSE.site kernel: nouveau 0000:01:00.0: enabling device (0006 -> 0007)
Jun 09 19:31:07 openSUSE.site kernel: Bluetooth: Core ver 2.16
Jun 09 19:31:07 openSUSE.site kernel: NET: Registered protocol family 31
Jun 09 19:31:07 openSUSE.site kernel: Bluetooth: HCI device and connection manager initialized
Jun 09 19:31:07 openSUSE.site kernel: Bluetooth: HCI socket layer initialized
Jun 09 19:31:07 openSUSE.site kernel: Bluetooth: L2CAP socket layer initialized
Jun 09 19:31:07 openSUSE.site kernel: Bluetooth: SCO socket layer initialized
Jun 09 19:31:07 openSUSE.site systemd-udevd[684]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:07 openSUSE.site systemd-udevd[685]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:07 openSUSE.site kernel: usbcore: registered new interface driver btusb
Jun 09 19:31:07 openSUSE.site kernel: [drm:__gen6_gt_force_wake_mt_get] *ERROR* Timed out waiting for forcewake old ack to clear.
Jun 09 19:31:07 openSUSE.site kernel: i915 0000:00:02.0: irq 46 for MSI/MSI-X
Jun 09 19:31:07 openSUSE.site kernel: [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
Jun 09 19:31:07 openSUSE.site kernel: [drm] Driver supports precise vblank timestamp query.
Jun 09 19:31:07 openSUSE.site kernel: vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=none:owns=io+mem
Jun 09 19:31:07 openSUSE.site kernel: vgaarb: transferring owner from PCI:0000:00:02.0 to PCI:0000:01:00.0
Jun 09 19:31:07 openSUSE.site kernel: Linux video capture interface: v2.00
Jun 09 19:31:07 openSUSE.site kernel: uvcvideo: Found UVC 1.00 device Laptop_Integrated_Webcam_HD (064e:8126)
Jun 09 19:31:07 openSUSE.site kernel: iwlwifi 0000:02:00.0: loaded firmware version 18.168.6.1
Jun 09 19:31:07 openSUSE.site kernel: iwldvm: Intel(R) Wireless WiFi Link AGN driver for Linux, in-tree:d
Jun 09 19:31:07 openSUSE.site kernel: iwldvm: Copyright(c) 2003-2012 Intel Corporation
Jun 09 19:31:07 openSUSE.site kernel: iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUG enabled
Jun 09 19:31:07 openSUSE.site kernel: iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
Jun 09 19:31:07 openSUSE.site kernel: iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEVICE_TRACING disabled
Jun 09 19:31:07 openSUSE.site kernel: iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEVICE_TESTMODE disabled
Jun 09 19:31:07 openSUSE.site kernel: iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_P2P disabled
Jun 09 19:31:07 openSUSE.site kernel: iwlwifi 0000:02:00.0: Detected Intel(R) Centrino(R) Wireless-N 2230 BGN, REV=0xC8
Jun 09 19:31:07 openSUSE.site kernel: iwlwifi 0000:02:00.0: L1 Enabled; Disabling L0S
Jun 09 19:31:07 openSUSE.site systemd-udevd[690]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:07 openSUSE.site kernel: input: Laptop_Integrated_Webcam_HD as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5:1.0/input/input13
Jun 09 19:31:07 openSUSE.site kernel: usbcore: registered new interface driver uvcvideo
Jun 09 19:31:07 openSUSE.site kernel: USB Video Class driver (1.1.1)
Jun 09 19:31:07 openSUSE.site kernel: [drm] Enabling RC6 states: RC6 on, RC6p on, RC6pp off
Jun 09 19:31:07 openSUSE.site kernel: iwlwifi 0000:02:00.0: device EEPROM VER=0x81c, CALIB=0x6
Jun 09 19:31:07 openSUSE.site kernel: iwlwifi 0000:02:00.0: Device SKU: 0x150
Jun 09 19:31:07 openSUSE.site kernel: iwlwifi 0000:02:00.0: Valid Tx ant: 0x3, Valid Rx ant: 0x3
Jun 09 19:31:07 openSUSE.site kernel: Registered led device: phy0-led
Jun 09 19:31:07 openSUSE.site kernel: ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
Jun 09 19:31:07 openSUSE.site kernel: fbcon: inteldrmfb (fb0) is primary device
Jun 09 19:31:07 openSUSE.site kernel: Console: switching to colour frame buffer device 200x56
Jun 09 19:31:07 openSUSE.site kernel: fb0: inteldrmfb frame buffer device
Jun 09 19:31:07 openSUSE.site kernel: drm: registered panic notifier
Jun 09 19:31:07 openSUSE.site kernel: ACPI Exception: AE_NOT_FOUND, Evaluating _DOD (20120913/video-1163)
Jun 09 19:31:07 openSUSE.site kernel: ACPI: Video Device [PEGP] (multi-head: no  rom: yes  post: no)
Jun 09 19:31:07 openSUSE.site kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:2e/LNXVIDEO:00/input/input14
Jun 09 19:31:07 openSUSE.site kernel: acpi device:31: registered as cooling_device4
Jun 09 19:31:07 openSUSE.site kernel: ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
Jun 09 19:31:07 openSUSE.site kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input15
Jun 09 19:31:07 openSUSE.site kernel: [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
Jun 09 19:31:07 openSUSE.site kernel: nouveau    DEVICE][0000:01:00.0] BOOT0  : 0x0e7120a2
Jun 09 19:31:07 openSUSE.site kernel: nouveau    DEVICE][0000:01:00.0] Chipset: GK107 (NVE7)
Jun 09 19:31:07 openSUSE.site kernel: nouveau    DEVICE][0000:01:00.0] Family : NVE0
Jun 09 19:31:07 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] checking PRAMIN for image...
Jun 09 19:31:07 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] ... signature not found
Jun 09 19:31:07 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] checking PROM for image...
Jun 09 19:31:07 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] checking ACPI for image...
Jun 09 19:31:07 openSUSE.site systemd-udevd[703]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:07 openSUSE.site kernel: rts5139: module is from the staging directory, the quality is unknown, you have been warned.
Jun 09 19:31:07 openSUSE.site systemd[1]: Mounted FUSE Control File System.
Jun 09 19:31:07 openSUSE.site systemd[1]: Starting Load Random Seed...
Jun 09 19:31:07 openSUSE.site systemd[1]: Started Set Up Additional Binary Formats.
Jun 09 19:31:07 openSUSE.site systemd[1]: Mounted Configuration File System.
Jun 09 19:31:07 openSUSE.site systemd[1]: Started File System Check on Root Device.
Jun 09 19:31:07 openSUSE.site kernel: scsi6 : SCSI emulation for RTS5139 USB card reader
Jun 09 19:31:07 openSUSE.site kernel: scsi 6:0:0:0: Direct-Access     Generic- xD/SD/M.S.       1.00 PQ: 0 ANSI: 0 CCS
Jun 09 19:31:07 openSUSE.site kernel: sd 6:0:0:0: Attached scsi generic sg2 type 0
Jun 09 19:31:07 openSUSE.site kernel: sd 6:0:0:0: [sdb] Attached SCSI removable disk
Jun 09 19:31:07 openSUSE.site kernel: usbcore: registered new interface driver rts5139
Jun 09 19:31:07 openSUSE.site systemd-udevd[717]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:07 openSUSE.site systemd-udevd[719]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:07 openSUSE.site systemd-udevd[721]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:07 openSUSE.site systemd[1]: Started Load Random Seed.
Jun 09 19:31:07 openSUSE.site systemd-udevd[723]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:07 openSUSE.site systemd[1]: Started Show Plymouth Boot Screen.
Jun 09 19:31:07 openSUSE.site systemd[1]: Starting Forward Password Requests to Plymouth Directory Watch.
Jun 09 19:31:07 openSUSE.site systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Jun 09 19:31:07 openSUSE.site systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Jun 09 19:31:07 openSUSE.site ifup[737]: Service network not started and mode 'auto' -> skipping
Jun 09 19:31:07 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] ... appears to be valid
Jun 09 19:31:07 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] using image from ACPI
Jun 09 19:31:07 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] BIT signature found
Jun 09 19:31:07 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] version 80.07.2f.00
Jun 09 19:31:07 openSUSE.site kernel: nouveau   DEVINIT][0000:01:00.0] adaptor not initialised
Jun 09 19:31:07 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] running init tables
Jun 09 19:31:07 openSUSE.site kernel: nouveau       MXM][0000:01:00.0] no VBIOS data, nothing to do
Jun 09 19:31:07 openSUSE.site kernel: nouveau       PFB][0000:01:00.0] RAM type: DDR3
Jun 09 19:31:07 openSUSE.site kernel: nouveau       PFB][0000:01:00.0] RAM size: 2048 MiB
Jun 09 19:31:07 openSUSE.site kernel: nouveau W  PGRAPH][0000:01:00.0] disabled, PGRAPH=1 to enable
Jun 09 19:31:07 openSUSE.site kernel: vga_switcheroo: enabled
Jun 09 19:31:07 openSUSE.site kernel: [TTM] Zone  kernel: Available graphics memory: 2990640 kiB
Jun 09 19:31:07 openSUSE.site kernel: [TTM] Zone   dma32: Available graphics memory: 2097152 kiB
Jun 09 19:31:07 openSUSE.site kernel: [TTM] Initializing pool allocator
Jun 09 19:31:07 openSUSE.site kernel: [TTM] Initializing DMA pool allocator
Jun 09 19:31:07 openSUSE.site kernel: nouveau       DRM] VRAM: 2048 MiB
Jun 09 19:31:07 openSUSE.site kernel: nouveau       DRM] GART: 512 MiB
Jun 09 19:31:07 openSUSE.site kernel: nouveau       DRM] BIT BIOS found
Jun 09 19:31:07 openSUSE.site kernel: nouveau       DRM] Bios version 80.07.2f.00
Jun 09 19:31:07 openSUSE.site kernel: nouveau       DRM] TMDS table version 2.0
Jun 09 19:31:07 openSUSE.site kernel: nouveau       DRM] DCB version 4.0
Jun 09 19:31:07 openSUSE.site kernel: nouveau       DRM] DCB outp 00: 02000f00 00000000
Jun 09 19:31:07 openSUSE.site kernel: nouveau       DRM] DCB conn 00: 00000000
Jun 09 19:31:07 openSUSE.site kernel: [drm] No driver support for vblank timestamp query.
Jun 09 19:31:07 openSUSE.site kernel: nouveau       DRM] ACPI backlight interface available, not registering our own
Jun 09 19:31:07 openSUSE.site kernel: nouveau W     DRM] voltage table 0x50 unknown
Jun 09 19:31:07 openSUSE.site kernel: nouveau       DRM] 2 available performance level(s)
Jun 09 19:31:07 openSUSE.site kernel: nouveau       DRM] 1: core 202MHz shader 405MHz memory 405MHz voltage 490mV
Jun 09 19:31:07 openSUSE.site kernel: nouveau       DRM] 3: core 450MHz shader 900MHz memory 1080MHz voltage 560mV
Jun 09 19:31:07 openSUSE.site kernel: nouveau       DRM] c:
Jun 09 19:31:07 openSUSE.site kernel: nouveau E     DRM] failed to create kernel channel, -22
Jun 09 19:31:07 openSUSE.site kernel: No connectors reported connected with modes
Jun 09 19:31:07 openSUSE.site kernel: [drm] Cannot find any crtc or sizes - going 1024x768
Jun 09 19:31:07 openSUSE.site kernel: nouveau       DRM] allocated 1024x768 fb: 0x60000, bo ffff8801b5467800
Jun 09 19:31:07 openSUSE.site kernel: fb1: nouveaufb frame buffer device
Jun 09 19:31:07 openSUSE.site kernel: [drm] Initialized nouveau 1.1.0 20120801 for 0000:01:00.0 on minor 1
Jun 09 19:31:07 openSUSE.site systemd-udevd[740]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 19:31:09 openSUSE.site systemd[1]: Found device ST9750420AS.
Jun 09 19:31:09 openSUSE.site systemd[1]: Activating swap /dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part8...
Jun 09 19:31:10 openSUSE.site kernel: Adding 2106364k swap on /dev/sda8.  Priority:-1 extents:1 across:2106364k
Jun 09 19:31:10 openSUSE.site systemd[1]: Activated swap /dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part8.
Jun 09 19:31:10 openSUSE.site systemd[1]: Starting Swap.
Jun 09 19:31:10 openSUSE.site systemd[1]: Reached target Swap.
Jun 09 19:31:10 openSUSE.site systemd[1]: Found device ST9750420AS.
Jun 09 19:31:10 openSUSE.site systemd[1]: Starting File System Check on /dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part10...
Jun 09 19:31:11 openSUSE.site systemd-fsck[743]: /dev/sda10: clean, 1388927/10354688 files, 35134677/41415168 blocks
Jun 09 19:31:11 openSUSE.site systemd[1]: Started File System Check on /dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part10.
Jun 09 19:31:11 openSUSE.site systemd[1]: Mounting /home...
Jun 09 19:31:12 openSUSE.site systemd[1]: Mounted /home.
Jun 09 19:31:12 openSUSE.site systemd[1]: Starting Local File Systems.
Jun 09 19:31:12 openSUSE.site systemd[1]: Reached target Local File Systems.
Jun 09 19:31:12 openSUSE.site systemd[1]: Starting LSB: Supports the direct execution of binary formats....
Jun 09 19:31:12 openSUSE.site systemd[1]: Starting Recreate Volatile Files and Directories...
Jun 09 19:31:12 openSUSE.site systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Jun 09 19:31:12 openSUSE.site systemd[1]: Starting Trigger Flushing of Journal to Persistent Storage...
Jun 09 19:31:12 openSUSE.site systemd[1]: Mounting Arbitrary Executable File Formats File System...
Jun 09 19:31:12 openSUSE.site kernel: EXT4-fs (sda10): mounted filesystem with ordered data mode. Opts: acl,user_xattr
Jun 09 19:31:12 openSUSE.site systemd-journal[257]: Allowing system journal files to grow to 3.9G.
Jun 09 19:31:12 openSUSE.site systemd[1]: Started Trigger Flushing of Journal to Persistent Storage.
Jun 09 19:31:12 openSUSE.site systemd[1]: Mounted Arbitrary Executable File Formats File System.
Jun 09 19:31:12 openSUSE.site systemd[1]: Started LSB: Supports the direct execution of binary formats..
Jun 09 19:31:12 openSUSE.site systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Jun 09 19:31:12 openSUSE.site systemd[1]: Started Recreate Volatile Files and Directories.
Jun 09 19:31:12 openSUSE.site systemd[1]: Starting LSB: AppArmor initialization...
Jun 09 19:31:13 openSUSE.site systemd[1]: Started LSB: AppArmor initialization.
Jun 09 19:31:13 openSUSE.site systemd[1]: Starting System Initialization.
Jun 09 19:31:13 openSUSE.site systemd[1]: Reached target System Initialization.
Jun 09 19:31:13 openSUSE.site systemd[1]: Starting PC/SC Smart Card Daemon Activation Socket.
Jun 09 19:31:13 openSUSE.site systemd[1]: Listening on PC/SC Smart Card Daemon Activation Socket.
Jun 09 19:31:20 openSUSE.site jexec[752]: Starting jexec services
Jun 09 19:31:13 openSUSE.site bluetoothd[921]: Bluetooth daemon 4.101
Jun 09 19:31:13 openSUSE.site avahi-daemon[926]: Found user 'avahi' (UID 115) and group 'avahi' (GID 113).
Jun 09 19:31:13 openSUSE.site avahi-daemon[926]: Successfully dropped root privileges.
Jun 09 19:31:13 openSUSE.site avahi-daemon[926]: avahi-daemon 0.6.31 starting up.
Jun 09 19:31:13 openSUSE.site acpid[943]: starting up with netlink and the input layer
Jun 09 19:31:13 openSUSE.site acpid[943]: 2 rules loaded
Jun 09 19:31:13 openSUSE.site acpid[943]: waiting for events: event logging is off
Jun 09 19:31:13 openSUSE.site bluetoothd[921]: Starting SDP server
Jun 09 19:31:13 openSUSE.site avahi-daemon[926]: Loading service file /etc/avahi/services/sftp-ssh.service.
Jun 09 19:31:13 openSUSE.site avahi-daemon[926]: Loading service file /etc/avahi/services/ssh.service.
Jun 09 19:31:13 openSUSE.site avahi-daemon[926]: Network interface enumeration completed.
Jun 09 19:31:20 openSUSE.site avahi-daemon[926]: Registering HINFO record with values 'X86_64'/'LINUX'.
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: Parsing /etc/bluetooth/input.conf failed: No such file or directory
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: <info> NetworkManager (version 0.9.6.4) is starting...
Jun 09 19:31:21 openSUSE.site avahi-daemon[926]: Server startup complete. Host name is openSUSE.local. Local service cookie is 2268842529.
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: Parsing /etc/bluetooth/audio.conf failed: No such file or directory
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: <info> Read config file /etc/NetworkManager/NetworkManager.conf
Jun 09 19:31:21 openSUSE.site avahi-daemon[926]: Service "openSUSE" (/etc/avahi/services/ssh.service) successfully established.
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: Bluetooth Management interface initialized
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: <info> WEXT support is enabled
Jun 09 19:31:21 openSUSE.site avahi-daemon[926]: Service "openSUSE" (/etc/avahi/services/sftp-ssh.service) successfully established.
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: Parsing /etc/bluetooth/serial.conf failed: No such file or directory
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: <info> VPN: loaded org.freedesktop.NetworkManager.pptp
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: <info> VPN: loaded org.freedesktop.NetworkManager.openvpn
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: <info> VPN: loaded org.freedesktop.NetworkManager.vpnc
Jun 09 19:31:21 openSUSE.site dbus[948]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: input-headset driver probe failed for device 6C:A7:80:7E:5D:E6
Jun 09 19:31:21 openSUSE.site polkitd[999]: Started polkitd version 0.110
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: input-headset driver probe failed for device 40:98:4E:B0:E8:4E
Jun 09 19:31:21 openSUSE.site polkitd[999]: Loading rules from directory /etc/polkit-1/rules.d
Jun 09 19:31:21 openSUSE.site polkitd[999]: Loading rules from directory /usr/share/polkit-1/rules.d
Jun 09 19:31:21 openSUSE.site polkitd[999]: Finished loading, compiling and executing 3 rules
Jun 09 19:31:21 openSUSE.site dbus[948]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Jun 09 19:31:21 openSUSE.site polkitd[999]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: <info> Loaded plugin ifcfg-suse: (C) 2008 Novell, Inc.  To report bugs please use the NetworkManager mailing list.
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: <info> Loaded plugin keyfile: (c) 2007 - 2010 Red Hat, Inc.  To report bugs please use the NetworkManager mailing list.
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile: parsing VPN connection 1 ...
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile:     read connection 'VPN connection 1'
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: Adapter /org/bluez/921/hci0 has been enabled
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile: parsing Qt_Conf_2013 ...
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile:     read connection 'Qt_Conf_2013'
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile: parsing STB_YD0O ...
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile:     read connection 'STB_YD0O'
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile: parsing MobileWiFi-f124 ...
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile:     read connection 'MobileWiFi-f124'
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile: parsing CU_MSaX ...
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile:     read connection 'CU_MSaX'
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile: parsing CU_YD0O ...
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile:     read connection 'CU_YD0O'
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile: parsing New DSL Connection ...
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile:     read connection 'New DSL Connection'
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile: parsing Auto art ...
Jun 09 19:31:21 openSUSE.site kernel: type=1400 audit(1370777472.940:2): apparmor="STATUS" operation="profile_load" name="/{usr/,}bin/ping" pid=790 comm="apparmor_parser"
Jun 09 19:31:21 openSUSE.site systemd[1]: Starting Authorization Manager...
Jun 09 19:31:21 openSUSE.site systemd[1]: Started Authorization Manager.
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile:     read connection 'Auto art'
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile: parsing TP-LINK_7AC772 ...
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile:     read connection 'TP-LINK_7AC772'
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile: parsing AAA-TP-LINK ...
Jun 09 19:31:21 openSUSE.site kernel: type=1400 audit(1370777472.946:3): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm-guest-session-wrapper" pid=797 comm="apparmor_parser"
Jun 09 19:31:21 openSUSE.site boot.apparmor[773]: Starting AppArmor ..done
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile:     read connection 'AAA-TP-LINK'
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile: parsing CMCC ...
Jun 09 19:31:21 openSUSE.site kernel: type=1400 audit(1370777472.952:4): apparmor="STATUS" operation="profile_load" name="/sbin/klogd" pid=803 comm="apparmor_parser"
Jun 09 19:31:21 openSUSE.site kernel: type=1400 audit(1370777472.956:5): apparmor="STATUS" operation="profile_load" name="/sbin/syslog-ng" pid=807 comm="apparmor_parser"
Jun 09 19:31:21 openSUSE.site kernel: type=1400 audit(1370777472.959:6): apparmor="STATUS" operation="profile_load" name="/sbin/syslogd" pid=811 comm="apparmor_parser"
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: bluetoothd[921]: Bluetooth daemon 4.101
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: bluetoothd[921]: Starting SDP server
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: bluetoothd[921]: Parsing /etc/bluetooth/input.conf failed: No such file or directory
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: bluetoothd[921]: Parsing /etc/bluetooth/audio.conf failed: No such file or directory
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: bluetoothd[921]: Bluetooth Management interface initialized
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: bluetoothd[921]: Parsing /etc/bluetooth/serial.conf failed: No such file or directory
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: bluetoothd[921]: input-headset driver probe failed for device 6C:A7:80:7E:5D:E6
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: bluetoothd[921]: input-headset driver probe failed for device 40:98:4E:B0:E8:4E
Jun 09 19:31:21 openSUSE.site bluetoothd[921]: bluetoothd[921]: Adapter /org/bluez/921/hci0 has been enabled
Jun 09 19:31:21 openSUSE.site kernel: type=1400 audit(1370777472.965:7): apparmor="STATUS" operation="profile_load" name="/usr/lib/apache2/mpm-prefork/apache2" pid=816 comm="apparmor_parser"
Jun 09 19:31:21 openSUSE.site kernel: type=1400 audit(1370777472.965:8): apparmor="STATUS" operation="profile_load" name="/usr/lib/apache2/mpm-prefork/apache2//DEFAULT_URI" pid=816 comm="apparmor_parser"
Jun 09 19:31:21 openSUSE.site kernel: type=1400 audit(1370777472.965:9): apparmor="STATUS" operation="profile_load" name="/usr/lib/apache2/mpm-prefork/apache2//HANDLING_UNTRUSTED_INPUT" pid=816 comm="apparmor_parser"
Jun 09 19:31:21 openSUSE.site kernel: type=1400 audit(1370777472.965:10): apparmor="STATUS" operation="profile_load" name="/usr/lib/apache2/mpm-prefork/apache2//phpsysinfo" pid=816 comm="apparmor_parser"
Jun 09 19:31:21 openSUSE.site kernel: type=1400 audit(1370777472.969:11): apparmor="STATUS" operation="profile_load" name="/usr/lib/dovecot/deliver" pid=820 comm="apparmor_parser"
Jun 09 19:31:21 openSUSE.site systemd-logind[928]: Watching system buttons on /dev/input/event7 (Power Button)
Jun 09 19:31:22 openSUSE.site systemd-logind[928]: Watching system buttons on /dev/input/event15 (Video Bus)
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: keyfile:     read connection 'CMCC'
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: <info> trying to start the modem manager...
Jun 09 19:31:21 openSUSE.site dbus[948]: [system] Activating service name='org.freedesktop.ModemManager' (using servicehelper)
Jun 09 19:31:21 openSUSE.site NetworkManager[950]: <info> monitoring kernel firmware directory '/lib/firmware'.
Jun 09 19:31:21 openSUSE.site modem-manager[1006]: <info>  ModemManager (version 0.6.0.0) starting...
Jun 09 19:31:21 openSUSE.site dbus[948]: [system] Successfully activated service 'org.freedesktop.ModemManager'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'AnyData'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Option'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Novatel'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'MotoC'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Huawei'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Linktop'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'X22X'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Wavecom'
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> rfkill1: found WiFi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.0/0000:02:00.0/ieee80211/phy0/rfkill1) (driver iwlwifi)
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Longcheer'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Sierra'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Gobi'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Nokia'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Samsung'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Ericsson MBM'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Option High-Speed'
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> WiFi enabled by radio killswitch; enabled by state file
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'ZTE'
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> WWAN enabled by radio killswitch; enabled by state file
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'SimTech'
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> WiMAX enabled by radio killswitch; enabled by state file
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Cinterion'
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> Networking is enabled by state file
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Iridium'
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Loaded plugin 'Generic'
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> (wlan0): using nl80211 for WiFi device control
Jun 09 19:31:22 openSUSE.site modem-manager[1006]: <info>  Successfully loaded 20 plugins
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <warn> (wlan0): driver supports Access Point (AP) mode
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> (wlan0): new 802.11 WiFi device (driver: 'iwlwifi' ifindex: 2)
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> (wlan0): exported as /org/freedesktop/NetworkManager/Devices/0
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> (wlan0): now managed
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> (wlan0): bringing up device.
Jun 09 19:31:22 openSUSE.site vboxdrv[944]: Starting VirtualBox kernel modules..done
Jun 09 19:31:22 openSUSE.site systemd-logind[928]: Watching system buttons on /dev/input/event14 (Video Bus)
Jun 09 19:31:22 openSUSE.site systemd[1]: Started Network Manager.
Jun 09 19:31:22 openSUSE.site systemd[1]: Starting Network Manager Wait Online...
Jun 09 19:31:22 openSUSE.site systemd[1]: Started Network Manager Wait Online.
Jun 09 19:31:22 openSUSE.site systemd[1]: Starting Network.
Jun 09 19:31:22 openSUSE.site systemd[1]: Reached target Network.
Jun 09 19:31:22 openSUSE.site systemd[1]: Starting Command Scheduler...
Jun 09 19:31:22 openSUSE.site systemd[1]: Started Command Scheduler.
Jun 09 19:31:22 openSUSE.site systemd[1]: Starting Vsftpd ftp daemon...
Jun 09 19:31:22 openSUSE.site systemd[1]: Started Vsftpd ftp daemon.
Jun 09 19:31:22 openSUSE.site systemd[1]: Starting OpenSSH Daemon...
Jun 09 19:31:22 openSUSE.site systemd[1]: Starting /etc/init.d/boot.local Compatibility...
Jun 09 19:31:22 openSUSE.site systemd[1]: Starting Host and Network Name Lookups.
Jun 09 19:31:22 openSUSE.site systemd[1]: Reached target Host and Network Name Lookups.
Jun 09 19:31:22 openSUSE.site systemd[1]: Starting Remote File Systems (Pre).
Jun 09 19:31:22 openSUSE.site systemd[1]: Reached target Remote File Systems (Pre).
Jun 09 19:31:22 openSUSE.site systemd[1]: Started OpenSSH Daemon.
Jun 09 19:31:22 openSUSE.site systemd-logind[928]: Watching system buttons on /dev/input/event4 (Power Button)
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating service name='org.freedesktop.ModemManager' (using servicehelper)
Jun 09 19:31:22 openSUSE.site systemd-logind[928]: Watching system buttons on /dev/input/event6 (Lid Switch)
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  ModemManager (version 0.6.0.0) starting...
Jun 09 19:31:22 openSUSE.site systemd[1]: Started /etc/init.d/boot.local Compatibility.
Jun 09 19:31:22 openSUSE.site /usr/sbin/cron[1012]: (CRON) INFO (running with inotify support)
Jun 09 19:31:22 openSUSE.site systemd-logind[928]: Watching system buttons on /dev/input/event5 (Sleep Button)
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'org.freedesktop.ModemManager'
Jun 09 19:31:22 openSUSE.site kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'AnyData'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Option'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Novatel'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'MotoC'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Huawei'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Linktop'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'X22X'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Wavecom'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Longcheer'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Sierra'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Gobi'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Nokia'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Samsung'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Ericsson MBM'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Option High-Speed'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'ZTE'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'SimTech'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Cinterion'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Iridium'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Loaded plugin 'Generic'
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Successfully loaded 20 plugins
Jun 09 19:31:22 openSUSE.site kernel: Bluetooth: BNEP filters: protocol multicast
Jun 09 19:31:22 openSUSE.site kernel: Bluetooth: BNEP socket layer initialized
Jun 09 19:31:22 openSUSE.site kernel: vboxdrv: Found 4 processor cores.
Jun 09 19:31:22 openSUSE.site kernel: vboxdrv: fAsync=0 offMin=0x132 offMax=0xaa2
Jun 09 19:31:22 openSUSE.site kernel: vboxdrv: TSC mode is 'synchronous', kernel timer mode is 'normal'.
Jun 09 19:31:22 openSUSE.site kernel: vboxdrv: Successfully loaded version 4.2.6_OSE (interface 0x001a0004).
Jun 09 19:31:22 openSUSE.site kernel: vboxpci: IOMMU not found (not registered)
Jun 09 19:31:22 openSUSE.site kernel: Bluetooth: RFCOMM TTY layer initialized
Jun 09 19:31:22 openSUSE.site kernel: Bluetooth: RFCOMM socket layer initialized
Jun 09 19:31:22 openSUSE.site kernel: Bluetooth: RFCOMM ver 1.11
Jun 09 19:31:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: L1 Enabled; Disabling L0S
Jun 09 19:31:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: Radio type=0x2-0x0-0x0
Jun 09 19:31:22 openSUSE.site kernel: IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> (wlan0): preparing device.
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> (wlan0): deactivating device (reason 'managed') [2]
Jun 09 19:31:22 openSUSE.site dbus[948]: [system] Activating service name='fi.w1.wpa_supplicant1' (using servicehelper)
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <warn> /sys/devices/virtual/net/lo: couldn't determine device driver; ignoring...
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating service name='fi.w1.wpa_supplicant1' (using servicehelper)
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> modem-manager is now available
Jun 09 19:31:22 openSUSE.site sshd[1021]: Server listening on 0.0.0.0 port 22.
Jun 09 19:31:22 openSUSE.site sshd[1021]: Server listening on :: port 22.
Jun 09 19:31:22 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Jun 09 19:31:22 openSUSE.site dbus[948]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> wpa_supplicant started
Jun 09 19:31:22 openSUSE.site kernel: NET: Registered protocol family 17
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> (wlan0) supports 5 scan SSIDs
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> (wlan0): supplicant interface state: starting -> ready
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: unavailable -> disconnected (reason 'supplicant-available') [20 30 42]
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <warn> Trying to remove a non-existant call id.
Jun 09 19:31:22 openSUSE.site NetworkManager[950]: <info> (wlan0): supplicant interface state: ready -> inactive
Jun 09 19:32:19 openSUSE.site ntp[1018]: 9 Jun 19:32:19 sntp[1055]: Started sntp
Jun 09 19:32:19 openSUSE.site systemd-journal[257]: Forwarding to syslog missed 109 messages.
Jun 09 19:32:19 openSUSE.site ntp[1018]: 9 Jun 19:32:19 sntp[1055]: Error looking up time.nist.gov: System error
Jun 09 19:32:19 openSUSE.site ntp[1018]: Unable to resolve hostname(s)
Jun 09 19:32:19 openSUSE.site ntp[1018]: Time could not be synchronized
Jun 09 19:32:19 openSUSE.site ntp[1018]: Starting network time protocol daemon (NTPD)..done
Jun 09 19:32:19 openSUSE.site ntpd[1063]: ntpd 4.2.6p5@1.2349-o Fri Mar  1 11:32:34 UTC 2013 (1)
Jun 09 19:32:19 openSUSE.site ntpd[1064]: proto: precision = 0.153 usec
Jun 09 19:32:19 openSUSE.site ntpd[1064]: ntp_io: estimated max descriptors: 1024, initial socket boundary: 16
Jun 09 19:32:19 openSUSE.site ntpd[1064]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Jun 09 19:32:19 openSUSE.site ntpd[1064]: Listen and drop on 1 v6wildcard :: UDP 123
Jun 09 19:32:19 openSUSE.site ntpd[1064]: Listen normally on 2 lo 127.0.0.1 UDP 123
Jun 09 19:32:19 openSUSE.site ntpd[1064]: Listen normally on 3 lo ::1 UDP 123
Jun 09 19:32:19 openSUSE.site ntpd[1064]: peers refreshed
Jun 09 19:32:19 openSUSE.site ntpd[1064]: Listening on routing socket on fd #20 for interface updates
Jun 09 19:32:19 openSUSE.site systemd[1]: Started LSB: Network time protocol daemon (ntpd).
Jun 09 19:32:19 openSUSE.site systemd[1]: Starting System Time Synchronized.
Jun 09 19:32:19 openSUSE.site systemd[1]: Reached target System Time Synchronized.
Jun 09 19:32:19 openSUSE.site systemd[1]: Starting LSB: Starts and stops the Xen management daemon...
Jun 09 19:32:19 openSUSE.site systemd[1]: Starting LSB: X Display Manager...
Jun 09 19:32:19 openSUSE.site systemd[1]: Starting A tool for securing communications between a client and a DNS resolver....
Jun 09 19:32:19 openSUSE.site xend[1065]: xend ..unused
Jun 09 19:32:19 openSUSE.site systemd[1]: Started LSB: Starts and stops the Xen management daemon.
Jun 09 19:32:19 openSUSE.site systemd[1]: Starting LSB: Starts and stops Xen VMs...
Jun 09 19:32:19 openSUSE.site systemd[1]: dnscrypt-proxy.service: Supervising process 1090 which is not our child. We'll most likely not notice when it exits.
Jun 09 19:32:19 openSUSE.site systemd[1]: Started A tool for securing communications between a client and a DNS resolver..
Jun 09 19:32:19 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Rejected send message, 1 matched rules; type="method_call", sender=":1.10" (uid=0 pid=1092 comm="/usr/sbin/gdm ") interface="org.freedesktop.DBus.Properties" member="GetAll" error name="(unset)" requested_reply="0" destination=":1.11" (uid=0 pid=1094 comm="/usr/lib/gdm/gdm-simple-slave --display-id /org/gn")
Jun 09 19:32:19 openSUSE.site dbus[948]: [system] Rejected send message, 1 matched rules; type="method_call", sender=":1.10" (uid=0 pid=1092 comm="/usr/sbin/gdm ") interface="org.freedesktop.DBus.Properties" member="GetAll" error name="(unset)" requested_reply="0" destination=":1.11" (uid=0 pid=1094 comm="/usr/lib/gdm/gdm-simple-slave --display-id /org/gn")
Jun 09 19:32:19 openSUSE.site xendomains[1088]: xendomains ..unused
Jun 09 19:32:19 openSUSE.site systemd[1]: Started LSB: Starts and stops Xen VMs.
Jun 09 19:32:19 openSUSE.site systemd[1]: Starting Multi-User.
Jun 09 19:32:19 openSUSE.site systemd[1]: Reached target Multi-User.
Jun 09 19:32:19 openSUSE.site acpid[943]: client connected from 1107[0:0]
Jun 09 19:32:19 openSUSE.site acpid[943]: 1 client rule loaded
Jun 09 19:32:19 openSUSE.site kernel: nouveau W  PGRAPH][0000:01:00.0] disabled, PGRAPH=1 to enable
Jun 09 19:32:19 openSUSE.site gdm-simple-slave[1094]: WARNING: Failed to give slave programs access to the display. Trying to proceed.
Jun 09 19:32:19 openSUSE.site xdm[1066]: Starting service gdm..done
Jun 09 19:32:19 openSUSE.site systemd[1]: Started LSB: X Display Manager.
Jun 09 19:32:19 openSUSE.site systemd[1]: Starting Graphical Interface.
Jun 09 19:32:19 openSUSE.site systemd[1]: Reached target Graphical Interface.
Jun 09 19:32:19 openSUSE.site systemd[1]: Starting Stop Read-Ahead Data Collection 10s After Completed Startup.
Jun 09 19:32:19 openSUSE.site systemd[1]: Started Stop Read-Ahead Data Collection 10s After Completed Startup.
Jun 09 19:32:19 openSUSE.site systemd[1]: Starting Update UTMP about System Runlevel Changes...
Jun 09 19:32:19 openSUSE.site systemd[1]: Started Update UTMP about System Runlevel Changes.
Jun 09 19:32:19 openSUSE.site systemd[1]: Startup finished in 5s 636ms 11us (kernel) + 1min 18s 499ms 143us (userspace) = 1min 24s 135ms 154us.
Jun 09 19:32:20 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service'
Jun 09 19:32:20 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'org.freedesktop.Accounts'
Jun 09 19:32:20 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating via systemd: service name='org.freedesktop.ConsoleKit' unit='console-kit-daemon.service'
Jun 09 19:32:20 openSUSE.site dbus[948]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service'
Jun 09 19:32:20 openSUSE.site accounts-daemon[1134]: started daemon version 0.6.30
Jun 09 19:32:20 openSUSE.site dbus[948]: [system] Successfully activated service 'org.freedesktop.Accounts'
Jun 09 19:32:20 openSUSE.site dbus[948]: [system] Activating via systemd: service name='org.freedesktop.ConsoleKit' unit='console-kit-daemon.service'
Jun 09 19:32:20 openSUSE.site systemd[1]: Starting Accounts Service...
Jun 09 19:32:20 openSUSE.site systemd[1]: Started Accounts Service.
Jun 09 19:32:20 openSUSE.site systemd[1]: Starting Console Manager...
Jun 09 19:32:20 openSUSE.site accounts-daemon[1134]: (accounts-daemon:1134): GLib-GObject-WARNING **: g_object_notify: object class `User' has no property named `x-session'
Jun 09 19:32:20 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'org.freedesktop.ConsoleKit'
Jun 09 19:32:20 openSUSE.site dbus[948]: [system] Successfully activated service 'org.freedesktop.ConsoleKit'
Jun 09 19:32:20 openSUSE.site systemd[1]: Started Console Manager.
Jun 09 19:32:21 openSUSE.site systemd-logind[928]: New session 1 of user gdm.
Jun 09 19:32:21 openSUSE.site systemd-logind[928]: Linked /tmp/.X11-unix/X0 to /run/user/124/X11-display.
Jun 09 19:32:21 openSUSE.site gdm-launch-environment][1132]: GLib-CRITICAL: g_variant_compare: assertion `!g_variant_is_container (a)' failed
Jun 09 19:32:21 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service'
Jun 09 19:32:21 openSUSE.site dbus[948]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service'
Jun 09 19:32:21 openSUSE.site systemd[1]: Starting Daemon for power management...
Jun 09 19:32:21 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'org.freedesktop.UPower'
Jun 09 19:32:21 openSUSE.site dbus[948]: [system] Successfully activated service 'org.freedesktop.UPower'
Jun 09 19:32:21 openSUSE.site systemd[1]: Started Daemon for power management.
Jun 09 19:32:23 openSUSE.site kernel: EXT4-fs (sda9): re-mounted. Opts: acl,user_xattr,commit=0
Jun 09 19:32:24 openSUSE.site kernel: EXT4-fs (sda10): re-mounted. Opts: acl,user_xattr,commit=0
Jun 09 19:32:24 openSUSE.site pulseaudio[1291]: [pulseaudio] authkey.c: Failed to open cookie file '/var/lib/gdm/.config/pulse/cookie': No such file or directory
Jun 09 19:32:24 openSUSE.site pulseaudio[1291]: [pulseaudio] authkey.c: Failed to load authorization key '/var/lib/gdm/.config/pulse/cookie': No such file or directory
Jun 09 19:32:24 openSUSE.site dbus[948]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service'
Jun 09 19:32:24 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service'
Jun 09 19:32:24 openSUSE.site systemd[1]: Starting RealtimeKit Scheduling Policy Service...
Jun 09 19:32:24 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
Jun 09 19:32:24 openSUSE.site dbus[948]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
Jun 09 19:32:24 openSUSE.site systemd[1]: Started RealtimeKit Scheduling Policy Service.
Jun 09 19:32:24 openSUSE.site rtkit-daemon[1295]: Successfully called chroot.
Jun 09 19:32:24 openSUSE.site rtkit-daemon[1295]: Successfully dropped privileges.
Jun 09 19:32:24 openSUSE.site rtkit-daemon[1295]: Successfully limited resources.
Jun 09 19:32:24 openSUSE.site rtkit-daemon[1295]: Running.
Jun 09 19:32:24 openSUSE.site rtkit-daemon[1295]: Watchdog thread running.
Jun 09 19:32:24 openSUSE.site rtkit-daemon[1295]: Canary thread running.
Jun 09 19:32:24 openSUSE.site rtkit-daemon[1295]: Successfully made thread 1294 of process 1294 (/usr/bin/pulseaudio) owned by '124' high priority at nice level -11.
Jun 09 19:32:24 openSUSE.site rtkit-daemon[1295]: Supervising 1 threads of 1 processes of 1 users.
Jun 09 19:32:24 openSUSE.site bluetoothd[921]: bluetoothd[921]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/HFPAG
Jun 09 19:32:24 openSUSE.site bluetoothd[921]: bluetoothd[921]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/HFPHS
Jun 09 19:32:24 openSUSE.site bluetoothd[921]: bluetoothd[921]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource
Jun 09 19:32:24 openSUSE.site bluetoothd[921]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/HFPAG
Jun 09 19:32:24 openSUSE.site bluetoothd[921]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/HFPHS
Jun 09 19:32:24 openSUSE.site bluetoothd[921]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource
Jun 09 19:32:24 openSUSE.site pulseaudio[1294]: [pulseaudio] bluetooth-util.c: org.bluez.HandsfreeGateway.GetProperties() failed: org.freedesktop.DBus.Error.UnknownMethod: Method "GetProperties" with signature "" on interface "org.bluez.HandsfreeGateway" doesn't exist
Jun 09 19:32:24 openSUSE.site pulseaudio[1294]: [pulseaudio] bluetooth-util.c: org.bluez.AudioSource.GetProperties() failed: org.freedesktop.DBus.Error.UnknownMethod: Method "GetProperties" with signature "" on interface "org.bluez.AudioSource" doesn't exist
Jun 09 19:32:24 openSUSE.site pulseaudio[1294]: [pulseaudio] authkey.c: Failed to open cookie file '/var/lib/gdm/.config/pulse/cookie': No such file or directory
Jun 09 19:32:24 openSUSE.site pulseaudio[1294]: [pulseaudio] authkey.c: Failed to load authorization key '/var/lib/gdm/.config/pulse/cookie': No such file or directory
Jun 09 19:32:25 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Jun 09 19:32:25 openSUSE.site dbus[948]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Jun 09 19:32:25 openSUSE.site systemd[1]: Starting Disk Manager...
Jun 09 19:32:25 openSUSE.site udisksd[1320]: udisks daemon version 2.0.0 starting
Jun 09 19:32:25 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Jun 09 19:32:25 openSUSE.site dbus[948]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Jun 09 19:32:25 openSUSE.site udisksd[1320]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jun 09 19:32:25 openSUSE.site systemd[1]: Started Disk Manager.
Jun 09 19:32:25 openSUSE.site polkitd[999]: Registered Authentication Agent for unix-session:1 (system bus name :1.37 [gnome-shell --mode=gdm], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Jun 09 19:32:25 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.37" (uid=124 pid=1305 comm="gnome-shell --mode=gdm ") interface="org.freedesktop.DBus.Properties" member="GetAll" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1137 comm="/usr/sbin/console-kit-daemon --no-daemon ")
Jun 09 19:32:25 openSUSE.site dbus[948]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.37" (uid=124 pid=1305 comm="gnome-shell --mode=gdm ") interface="org.freedesktop.DBus.Properties" member="GetAll" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1137 comm="/usr/sbin/console-kit-daemon --no-daemon ")
Jun 09 19:32:29 openSUSE.site systemd[1]: Starting Stop Read-Ahead Data Collection...
Jun 09 19:32:29 openSUSE.site systemd[1]: Started Stop Read-Ahead Data Collection.
Jun 09 19:33:25 openSUSE.site systemd-logind[928]: New session 2 of user zhxt.
Jun 09 19:33:25 openSUSE.site systemd-logind[928]: Linked /tmp/.X11-unix/X0 to /run/user/1000/X11-display.
Jun 09 19:33:25 openSUSE.site systemd-journal[257]: Forwarding to syslog missed 2 messages.
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> Auto-activating connection 'TP-LINK_7AC772'.
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) starting connection 'TP-LINK_7AC772'
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: prepare -> config (reason 'none') [40 50 0]
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> Activation (wlan0/wireless): access point 'TP-LINK_7AC772' has security, but secrets are required.
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: config -> need-auth (reason 'none') [50 60 0]
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <warn> No agents were available for this request.
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: need-auth -> failed (reason 'no-secrets') [60 120 7]
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> Marking connection 'TP-LINK_7AC772' invalid.
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <warn> Activation (wlan0) failed for connection 'TP-LINK_7AC772'
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: failed -> disconnected (reason 'none') [120 30 0]
Jun 09 19:33:25 openSUSE.site NetworkManager[950]: <info> (wlan0): deactivating device (reason 'none') [0]
Jun 09 19:33:25 openSUSE.site gnome-session[1202]: WARNING: Detected that screensaver has left the bus
Jun 09 19:33:25 openSUSE.site gnome-session[1202]: CRITICAL: gsm_manager_set_phase: assertion `GSM_IS_MANAGER (manager)' failed
Jun 09 19:33:25 openSUSE.site polkitd[999]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.37, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Jun 09 19:33:25 openSUSE.site gdm-simple-slave[1094]: WARNING: Failed to remove slave program access to the display. Trying to proceed.
Jun 09 19:33:27 openSUSE.site checkproc[1457]: checkproc: can not get session id for process 1722!
Jun 09 19:33:29 openSUSE.site kernel: fuse init (API version 7.20)
Jun 09 19:33:27 openSUSE.site systemd[1]: Mounting FUSE Control File System...
Jun 09 19:33:27 openSUSE.site systemd[1]: Mounted FUSE Control File System.
Jun 09 19:33:39 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.46" (uid=1000 pid=1538 comm="kdeinit4: kded4 [kdeinit]                       ") interface="org.freedesktop.login1.Manager" member="CanHybridSleep" error name="(unset)" requested_reply="0" destination="org.freedesktop.login1" (uid=0 pid=928 comm="/usr/lib/systemd/systemd-logind ")
Jun 09 19:33:39 openSUSE.site dbus[948]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.46" (uid=1000 pid=1538 comm="kdeinit4: kded4 [kdeinit]                       ") interface="org.freedesktop.login1.Manager" member="CanHybridSleep" error name="(unset)" requested_reply="0" destination="org.freedesktop.login1" (uid=0 pid=928 comm="/usr/lib/systemd/systemd-logind ")
Jun 09 19:33:45 openSUSE.site bluetoothd[921]: bluetoothd[921]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/HFPAG
Jun 09 19:33:45 openSUSE.site bluetoothd[921]: bluetoothd[921]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/HFPHS
Jun 09 19:33:45 openSUSE.site bluetoothd[921]: bluetoothd[921]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource
Jun 09 19:33:45 openSUSE.site bluetoothd[921]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/HFPAG
Jun 09 19:33:45 openSUSE.site bluetoothd[921]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/HFPHS
Jun 09 19:33:45 openSUSE.site bluetoothd[921]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource
Jun 09 19:33:48 openSUSE.site NetworkManager[950]: <info> Auto-activating connection 'TP-LINK_7AC772'.
Jun 09 19:33:48 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) starting connection 'TP-LINK_7AC772'
Jun 09 19:33:48 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
Jun 09 19:33:48 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Jun 09 19:33:48 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Jun 09 19:33:48 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Jun 09 19:33:48 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Jun 09 19:33:48 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Jun 09 19:33:48 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: prepare -> config (reason 'none') [40 50 0]
Jun 09 19:33:48 openSUSE.site NetworkManager[950]: <info> Activation (wlan0/wireless): access point 'TP-LINK_7AC772' has security, but secrets are required.
Jun 09 19:33:48 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: config -> need-auth (reason 'none') [50 60 0]
Jun 09 19:33:48 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: need-auth -> prepare (reason 'none') [60 40 0]
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: prepare -> config (reason 'none') [40 50 0]
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Activation (wlan0/wireless): connection 'TP-LINK_7AC772' has security, and secrets exist.  No new secrets needed.
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Config: added 'ssid' value 'TP-LINK_7AC772'
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Config: added 'scan_ssid' value '1'
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Config: added 'key_mgmt' value 'WPA-PSK'
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Config: added 'psk' value '<omitted>'
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Config: set interface ap_scan to 1
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> (wlan0): supplicant interface state: inactive -> scanning
Jun 09 19:33:49 openSUSE.site kernel: wlan0: authenticate with 40:16:9f:7a:c7:72
Jun 09 19:33:49 openSUSE.site kernel: wlan0: send auth to 40:16:9f:7a:c7:72 (try 1/3)
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> (wlan0): supplicant interface state: scanning -> authenticating
Jun 09 19:33:49 openSUSE.site kernel: wlan0: authenticated
Jun 09 19:33:49 openSUSE.site kernel: wlan0: associate with 40:16:9f:7a:c7:72 (try 1/3)
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> (wlan0): supplicant interface state: authenticating -> associating
Jun 09 19:33:49 openSUSE.site kernel: wlan0: RX AssocResp from 40:16:9f:7a:c7:72 (capab=0x431 status=0 aid=4)
Jun 09 19:33:49 openSUSE.site kernel: wlan0: associated
Jun 09 19:33:49 openSUSE.site kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Jun 09 19:33:49 openSUSE.site kernel: cfg80211: Calling CRDA for country: US
Jun 09 19:33:49 openSUSE.site kernel: cfg80211: Regulatory domain changed to country: US
Jun 09 19:33:49 openSUSE.site kernel: cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jun 09 19:33:49 openSUSE.site kernel: cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
Jun 09 19:33:49 openSUSE.site kernel: cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
Jun 09 19:33:49 openSUSE.site kernel: cfg80211:   (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 09 19:33:49 openSUSE.site kernel: cfg80211:   (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 09 19:33:49 openSUSE.site kernel: cfg80211:   (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 09 19:33:49 openSUSE.site kernel: cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> (wlan0): supplicant interface state: associating -> associated
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> (wlan0): supplicant interface state: associated -> 4-way handshake
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> (wlan0): supplicant interface state: 4-way handshake -> completed
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Activation (wlan0/wireless) Stage 2 of 5 (Device Configure) successful.  Connected to wireless network 'TP-LINK_7AC772'.
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) scheduled.
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) started...
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: config -> ip-config (reason 'none') [50 70 0]
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Beginning DHCPv4 transaction (timeout in 45 seconds)
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> dhclient started with pid 1599
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) complete.
Jun 09 19:33:49 openSUSE.site dhclient[1599]: Internet Systems Consortium DHCP Client 4.2.5-P1
Jun 09 19:33:49 openSUSE.site dhclient[1599]: Copyright 2004-2013 Internet Systems Consortium.
Jun 09 19:33:49 openSUSE.site dhclient[1599]: All rights reserved.
Jun 09 19:33:49 openSUSE.site dhclient[1599]: For info, please visit https://www.isc.org/software/dhcp/
Jun 09 19:33:49 openSUSE.site NetworkManager[950]: <info> (wlan0): DHCPv4 state changed nbi -> preinit
Jun 09 19:33:49 openSUSE.site dhclient[1599]: Listening on LPF/wlan0/68:5d:43:f8:1f:1f
Jun 09 19:33:49 openSUSE.site dhclient[1599]: Sending on   LPF/wlan0/68:5d:43:f8:1f:1f
Jun 09 19:33:49 openSUSE.site dhclient[1599]: Sending on   Socket/fallback
Jun 09 19:33:49 openSUSE.site dhclient[1599]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3
Jun 09 19:33:50 openSUSE.site dhclient[1599]: DHCPOFFER from 192.168.1.1
Jun 09 19:33:50 openSUSE.site rtkit-daemon[1295]: Successfully made thread 1619 of process 1619 (/usr/bin/pulseaudio) owned by '1000' high priority at nice level -11.
Jun 09 19:33:50 openSUSE.site rtkit-daemon[1295]: Supervising 1 threads of 1 processes of 1 users.
Jun 09 19:33:50 openSUSE.site bluetoothd[921]: bluetoothd[921]: Endpoint registered: sender=:1.67 path=/MediaEndpoint/HFPAG
Jun 09 19:33:50 openSUSE.site bluetoothd[921]: bluetoothd[921]: Endpoint registered: sender=:1.67 path=/MediaEndpoint/HFPHS
Jun 09 19:33:50 openSUSE.site bluetoothd[921]: bluetoothd[921]: Endpoint registered: sender=:1.67 path=/MediaEndpoint/A2DPSource
Jun 09 19:33:50 openSUSE.site bluetoothd[921]: Endpoint registered: sender=:1.67 path=/MediaEndpoint/HFPAG
Jun 09 19:33:50 openSUSE.site bluetoothd[921]: Endpoint registered: sender=:1.67 path=/MediaEndpoint/HFPHS
Jun 09 19:33:50 openSUSE.site bluetoothd[921]: Endpoint registered: sender=:1.67 path=/MediaEndpoint/A2DPSource
Jun 09 19:33:50 openSUSE.site pulseaudio[1619]: [pulseaudio] bluetooth-util.c: org.bluez.HandsfreeGateway.GetProperties() failed: org.freedesktop.DBus.Error.UnknownMethod: Method "GetProperties" with signature "" on interface "org.bluez.HandsfreeGateway" doesn't exist
Jun 09 19:33:50 openSUSE.site pulseaudio[1619]: [pulseaudio] bluetooth-util.c: org.bluez.AudioSource.GetProperties() failed: org.freedesktop.DBus.Error.UnknownMethod: Method "GetProperties" with signature "" on interface "org.bluez.AudioSource" doesn't exist
Jun 09 19:33:51 openSUSE.site avahi-daemon[926]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::6a5d:43ff:fef8:1f1f.
Jun 09 19:33:51 openSUSE.site avahi-daemon[926]: New relevant interface wlan0.IPv6 for mDNS.
Jun 09 19:33:51 openSUSE.site avahi-daemon[926]: Registering new address record for fe80::6a5d:43ff:fef8:1f1f on wlan0.*.
Jun 09 19:33:51 openSUSE.site rtkit-daemon[1295]: Successfully made thread 1643 of process 1643 (/usr/bin/pulseaudio) owned by '1000' high priority at nice level -11.
Jun 09 19:33:51 openSUSE.site rtkit-daemon[1295]: Supervising 4 threads of 2 processes of 1 users.
Jun 09 19:33:51 openSUSE.site pulseaudio[1643]: [pulseaudio] pid.c: Daemon already running.
Jun 09 19:33:51 openSUSE.site rtkit-daemon[1295]: Successfully made thread 1651 of process 1651 (/usr/bin/pulseaudio) owned by '1000' high priority at nice level -11.
Jun 09 19:33:51 openSUSE.site pulseaudio[1651]: [pulseaudio] pid.c: Daemon already running.
Jun 09 19:33:52 openSUSE.site polkitd[999]: Registered Authentication Agent for unix-session:2 (system bus name :1.71 [/usr/lib64/kde4/libexec/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.utf8)
Jun 09 19:33:54 openSUSE.site dhclient[1599]: DHCPREQUEST on wlan0 to 255.255.255.255 port 67
Jun 09 19:33:54 openSUSE.site dhclient[1599]: DHCPACK from 192.168.1.1
Jun 09 19:33:54 openSUSE.site dhclient[1599]: bound to 192.168.1.103 -- renewal in 3097 seconds.
Jun 09 19:33:54 openSUSE.site NetworkManager[950]: <info> (wlan0): DHCPv4 state changed preinit -> bound
Jun 09 19:33:54 openSUSE.site NetworkManager[950]: <info>   address 192.168.1.103
Jun 09 19:33:54 openSUSE.site NetworkManager[950]: <info>   prefix 24 (255.255.255.0)
Jun 09 19:33:54 openSUSE.site NetworkManager[950]: <info>   gateway 192.168.1.1
Jun 09 19:33:54 openSUSE.site NetworkManager[950]: <info>   nameserver '219.239.26.42'
Jun 09 19:33:54 openSUSE.site NetworkManager[950]: <info>   nameserver '124.207.160.106'
Jun 09 19:33:54 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
Jun 09 19:33:54 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) started...
Jun 09 19:33:54 openSUSE.site avahi-daemon[926]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.103.
Jun 09 19:33:54 openSUSE.site avahi-daemon[926]: New relevant interface wlan0.IPv4 for mDNS.
Jun 09 19:33:54 openSUSE.site avahi-daemon[926]: Registering new address record for 192.168.1.103 on wlan0.IPv4.
Jun 09 19:33:55 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: ip-config -> activated (reason 'none') [70 100 0]
Jun 09 19:33:55 openSUSE.site NetworkManager[950]: <info> Clearing nscd hosts cache.
Jun 09 19:33:55 openSUSE.site NetworkManager[950]: <info> Policy set 'TP-LINK_7AC772' (wlan0) as default for IPv4 routing and DNS.
Jun 09 19:33:55 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) successful, device activated.
Jun 09 19:33:55 openSUSE.site NetworkManager[950]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) complete.
Jun 09 19:33:55 openSUSE.site dbus[948]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 09 19:33:55 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 09 19:33:55 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 09 19:33:55 openSUSE.site dbus[948]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 09 19:33:56 openSUSE.site nm-dispatcher.action[1721]: Script '/etc/NetworkManager/dispatcher.d/nfs' exited with error status 2.
Jun 09 19:34:01 openSUSE.site systemd[1]: Starting CUPS Printing Service...
Jun 09 19:34:01 openSUSE.site systemd[1]: Started CUPS Printing Service.
Jun 09 19:34:01 openSUSE.site cupsd[1870]: No limit for Validate-Job defined in policy allowallforanybody and no suitable template found.
Jun 09 19:34:01 openSUSE.site cupsd[1870]: No limit for Cancel-Jobs defined in policy allowallforanybody and no suitable template found.
Jun 09 19:34:01 openSUSE.site cupsd[1870]: No limit for Cancel-My-Jobs defined in policy allowallforanybody and no suitable template found.
Jun 09 19:34:01 openSUSE.site cupsd[1870]: No limit for Close-Job defined in policy allowallforanybody and no suitable template found.
Jun 09 19:34:01 openSUSE.site cupsd[1870]: No limit for CUPS-Get-Document defined in policy allowallforanybody and no suitable template found.
Jun 09 19:34:01 openSUSE.site cupsd[1870]: No JobPrivateAccess defined in policy allowallforanybody - using defaults.
Jun 09 19:34:01 openSUSE.site cupsd[1870]: No JobPrivateValues defined in policy allowallforanybody - using defaults.
Jun 09 19:34:01 openSUSE.site cupsd[1870]: No SubscriptionPrivateAccess defined in policy allowallforanybody - using defaults.
Jun 09 19:34:01 openSUSE.site cupsd[1870]: No SubscriptionPrivateValues defined in policy allowallforanybody - using defaults.
Jun 09 19:35:04 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating service name='org.freedesktop.PackageKit' (using servicehelper)
Jun 09 19:35:04 openSUSE.site dbus[948]: [system] Activating service name='org.freedesktop.PackageKit' (using servicehelper)
Jun 09 19:35:05 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Jun 09 19:35:05 openSUSE.site dbus[948]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Jun 09 19:37:17 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating service name='org.freedesktop.PackageKit' (using servicehelper)
Jun 09 19:37:17 openSUSE.site dbus[948]: [system] Activating service name='org.freedesktop.PackageKit' (using servicehelper)
Jun 09 19:37:17 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Jun 09 19:37:17 openSUSE.site dbus[948]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Jun 09 19:37:20 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-32bit;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:38:07 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:38:53 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --libOSMesa9;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:38:56 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libIndirectGL1;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:38:59 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libglapi0-32bit;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:01 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libglapi0;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:01 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --libOSMesa9-32bit;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:04 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --libgbm1;0.0.0-34.16.1;x86_64;repo-update
Jun 09 19:39:05 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --libgbm1-32bit;0.0.0-34.16.1;x86_64;repo-update
Jun 09 19:39:05 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --libxatracker1;1.0.0-34.16.1;x86_64;repo-update
Jun 09 19:39:12 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --libOSMesa-devel;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:13 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libIndirectGL-devel;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:14 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libGL1-32bit;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:14 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libglapi-devel;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:15 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libGLESv2-2;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:15 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libGLESv1_CM1;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:16 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libGL1;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:16 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --libgbm-devel;0.0.0-34.16.1;x86_64;repo-update
Jun 09 19:39:17 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libEGL1;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:17 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libEGL1-32bit;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:18 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libGL-devel;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:19 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libEGL-devel;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:19 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libGLESv2-devel;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:20 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-libGLESv1_CM-devel;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:39:20 openSUSE.site dbus-daemon[948]: DownloadProgressReportReceiver::start():http://download.opensuse.org/update/12.3/ --Mesa-devel;9.0.2-34.16.1;x86_64;repo-update
Jun 09 19:45:47 openSUSE.site su[7491]: (to cyrus) root on none
Jun 09 19:45:47 openSUSE.site ctl_mboxlist[7492]: DBERROR: reading /var/lib/imap/db/skipstamp, assuming the worst: No such file or directory
Jun 09 19:45:47 openSUSE.site ctl_mboxlist[7492]: skiplist: checkpointed /var/lib/imap/mailboxes.db (0 records, 144 bytes) in 0 seconds
Jun 09 19:45:55 openSUSE.site systemd[1]: Starting Cleanup of Temporary Directories...
Jun 09 19:45:57 openSUSE.site systemd-tmpfiles[7552]: stat(/run/user/1000/gvfs) failed: Permission denied
Jun 09 19:45:58 openSUSE.site systemd[1]: Started Cleanup of Temporary Directories.
Jun 09 20:25:39 openSUSE.site dhclient[1599]: DHCPREQUEST on wlan0 to 192.168.1.1 port 67
Jun 09 20:25:39 openSUSE.site dhclient[1599]: DHCPACK from 192.168.1.1
Jun 09 20:25:39 openSUSE.site dhclient[1599]: bound to 192.168.1.103 -- renewal in 3320 seconds.
Jun 09 20:25:39 openSUSE.site NetworkManager[950]: <info> (wlan0): DHCPv4 state changed bound -> renew
Jun 09 20:25:39 openSUSE.site NetworkManager[950]: <info>   address 192.168.1.103
Jun 09 20:25:39 openSUSE.site NetworkManager[950]: <info>   prefix 24 (255.255.255.0)
Jun 09 20:25:39 openSUSE.site NetworkManager[950]: <info>   gateway 192.168.1.1
Jun 09 20:25:39 openSUSE.site NetworkManager[950]: <info>   nameserver '219.239.26.42'
Jun 09 20:25:39 openSUSE.site NetworkManager[950]: <info>   nameserver '124.207.160.106'
Jun 09 20:25:39 openSUSE.site dbus[948]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 09 20:25:39 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 09 20:25:39 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 09 20:25:39 openSUSE.site dbus[948]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 09 20:52:37 openSUSE.site gnome-keyring-daemon[8553]: Gkm: using old keyring directory: /home/zhxt/.gnome2/keyrings
Jun 09 20:52:37 openSUSE.site gnome-keyring-daemon[8553]: couldn't set environment variable in session: The name org.gnome.SessionManager was not provided by any .service files
Jun 09 20:52:37 openSUSE.site gnome-keyring-daemon[8553]: keyring alias directory: /home/zhxt/.gnome2/keyrings
Jun 09 21:20:59 openSUSE.site dhclient[1599]: DHCPREQUEST on wlan0 to 192.168.1.1 port 67
Jun 09 21:20:59 openSUSE.site dhclient[1599]: DHCPACK from 192.168.1.1
Jun 09 21:20:59 openSUSE.site NetworkManager[950]: <info> (wlan0): DHCPv4 state changed renew -> renew
Jun 09 21:20:59 openSUSE.site NetworkManager[950]: <info>   address 192.168.1.103
Jun 09 21:20:59 openSUSE.site NetworkManager[950]: <info>   prefix 24 (255.255.255.0)
Jun 09 21:20:59 openSUSE.site NetworkManager[950]: <info>   gateway 192.168.1.1
Jun 09 21:20:59 openSUSE.site NetworkManager[950]: <info>   nameserver '219.239.26.42'
Jun 09 21:20:59 openSUSE.site NetworkManager[950]: <info>   nameserver '124.207.160.106'
Jun 09 21:20:59 openSUSE.site dhclient[1599]: bound to 192.168.1.103 -- renewal in 3432 seconds.
Jun 09 21:20:59 openSUSE.site dbus[948]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 09 21:20:59 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 09 21:20:59 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 09 21:20:59 openSUSE.site dbus[948]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 09 22:18:11 openSUSE.site dhclient[1599]: DHCPREQUEST on wlan0 to 192.168.1.1 port 67
Jun 09 22:18:11 openSUSE.site dhclient[1599]: DHCPACK from 192.168.1.1
Jun 09 22:18:11 openSUSE.site dhclient[1599]: bound to 192.168.1.103 -- renewal in 2855 seconds.
Jun 09 22:18:11 openSUSE.site NetworkManager[950]: <info> (wlan0): DHCPv4 state changed renew -> renew
Jun 09 22:18:11 openSUSE.site NetworkManager[950]: <info>   address 192.168.1.103
Jun 09 22:18:11 openSUSE.site NetworkManager[950]: <info>   prefix 24 (255.255.255.0)
Jun 09 22:18:11 openSUSE.site NetworkManager[950]: <info>   gateway 192.168.1.1
Jun 09 22:18:11 openSUSE.site NetworkManager[950]: <info>   nameserver '219.239.26.42'
Jun 09 22:18:11 openSUSE.site NetworkManager[950]: <info>   nameserver '124.207.160.106'
Jun 09 22:18:11 openSUSE.site dbus[948]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 09 22:18:11 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 09 22:18:11 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 09 22:18:11 openSUSE.site dbus[948]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 09 22:49:53 openSUSE.site kernel: warning: `VirtualBox' uses 32-bit capabilities (legacy support in use)
Jun 09 23:05:46 openSUSE.site dhclient[1599]: DHCPREQUEST on wlan0 to 192.168.1.1 port 67
Jun 09 23:05:46 openSUSE.site dhclient[1599]: DHCPACK from 192.168.1.1
Jun 09 23:05:46 openSUSE.site NetworkManager[950]: <info> (wlan0): DHCPv4 state changed renew -> renew
Jun 09 23:05:46 openSUSE.site NetworkManager[950]: <info>   address 192.168.1.103
Jun 09 23:05:46 openSUSE.site NetworkManager[950]: <info>   prefix 24 (255.255.255.0)
Jun 09 23:05:46 openSUSE.site NetworkManager[950]: <info>   gateway 192.168.1.1
Jun 09 23:05:46 openSUSE.site NetworkManager[950]: <info>   nameserver '219.239.26.42'
Jun 09 23:05:46 openSUSE.site NetworkManager[950]: <info>   nameserver '124.207.160.106'
Jun 09 23:05:46 openSUSE.site dbus[948]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 09 23:05:47 openSUSE.site dhclient[1599]: bound to 192.168.1.103 -- renewal in 3137 seconds.
Jun 09 23:05:47 openSUSE.site dbus[948]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 09 23:05:48 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 09 23:05:48 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 09 23:45:52 openSUSE.site polkitd[999]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.71, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.utf8)
Jun 09 23:45:55 openSUSE.site systemd-logind[928]: System is powering down.
Jun 09 23:45:56 openSUSE.site systemd[1]: Deactivating swap /dev/sda8...
Jun 09 23:45:56 openSUSE.site systemd[1]: Unmounting /sys/kernel/debug...
Jun 09 23:45:56 openSUSE.site systemd[1]: Unmounting /var/run/user/1000/gvfs...
Jun 09 23:45:56 openSUSE.site systemd[1]: Stopping Bluetooth.
Jun 09 23:45:56 openSUSE.site systemd[1]: Stopped target Bluetooth.
Jun 09 23:45:56 openSUSE.site systemd[1]: Stopping Sound Card.
Jun 09 23:45:56 openSUSE.site systemd[1]: Stopped target Sound Card.
Jun 09 23:45:56 openSUSE.site systemd[1]: Stopping Remote File Systems (Pre).
Jun 09 23:46:02 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activating via systemd: service name='org.freedesktop.ConsoleKit' unit='console-kit-daemon.service'
Jun 09 23:46:02 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Activation via systemd failed for unit 'console-kit-daemon.service': Refusing activation, D-Bus is shutting down.
Jun 09 23:46:02 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Rejected send message, 3 matched rules; type="error", sender=":1.67" (uid=1000 pid=1619 comm="/usr/bin/pulseaudio --start --log-target=syslog ") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.0" (uid=0 pid=921 comm="/usr/sbin/bluetoothd -n ")
Jun 09 23:46:02 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Caught signal 15, shutting down...
Jun 09 23:46:02 openSUSE.site systemd-journal[257]: Forwarding to syslog missed 4 messages.
Jun 09 23:45:56 openSUSE.site dbus[948]: [system] Activating via systemd: service name='org.freedesktop.ConsoleKit' unit='console-kit-daemon.service'
Jun 09 23:45:56 openSUSE.site avahi-daemon[926]: Got SIGTERM, quitting.
Jun 09 23:45:56 openSUSE.site avahi-daemon[926]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::6a5d:43ff:fef8:1f1f.
Jun 09 23:45:56 openSUSE.site avahi-daemon[926]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.103.
Jun 09 23:45:56 openSUSE.site avahi-daemon[926]: avahi-daemon 0.6.31 exiting.
Jun 09 23:45:56 openSUSE.site dbus[948]: [system] Activation via systemd failed for unit 'console-kit-daemon.service': Refusing activation, D-Bus is shutting down.
Jun 09 23:45:56 openSUSE.site bluetoothd[921]: Terminating
Jun 09 23:45:56 openSUSE.site sshd[1021]: Received signal 15; terminating.
Jun 09 23:45:56 openSUSE.site bluetoothd[921]: Endpoint unregistered: sender=:1.67 path=/MediaEndpoint/A2DPSource
Jun 09 23:45:56 openSUSE.site bluetoothd[921]: Endpoint unregistered: sender=:1.67 path=/MediaEndpoint/HFPAG
Jun 09 23:45:56 openSUSE.site bluetoothd[921]: Endpoint unregistered: sender=:1.67 path=/MediaEndpoint/HFPHS
Jun 09 23:46:02 openSUSE.site bluetoothd[921]: Stopping SDP server
Jun 09 23:46:02 openSUSE.site dbus[948]: [system] Rejected send message, 3 matched rules; type="error", sender=":1.67" (uid=1000 pid=1619 comm="/usr/bin/pulseaudio --start --log-target=syslog ") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.0" (uid=0 pid=921 comm="/usr/sbin/bluetoothd -n ")
Jun 09 23:46:02 openSUSE.site modem-manager[1006]: <info>  Caught signal 15, shutting down...
Jun 09 23:46:02 openSUSE.site NetworkManager[950]: <info> (wlan0): roamed from BSSID 40:16:9F:7A:C7:72 (TP-LINK_7AC772) to (none) ((none))
Jun 09 23:46:02 openSUSE.site bluetoothd[921]: Exit
Jun 09 23:46:02 openSUSE.site NetworkManager[950]: <info> caught signal 15, shutting down normally.
Jun 09 23:46:02 openSUSE.site NetworkManager[950]: <info> (wlan0): DHCPv4 client pid 1599 exited with status -1
Jun 09 23:46:02 openSUSE.site NetworkManager[950]: <warn> DHCP client died abnormally
Jun 09 23:46:02 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: activated -> failed (reason 'ip-config-expired') [100 120 6]
Jun 09 23:46:03 openSUSE.site haveged[924]: haveged Stopping due to signal 15
Jun 09 23:46:03 openSUSE.site haveged[924]: haveged starting up
Jun 09 23:46:03 openSUSE.site bluetoothd[921]: bluetoothd[921]: Terminating
Jun 09 23:46:03 openSUSE.site bluetoothd[921]: bluetoothd[921]: Endpoint unregistered: sender=:1.67 path=/MediaEndpoint/A2DPSource
Jun 09 23:46:03 openSUSE.site bluetoothd[921]: bluetoothd[921]: Endpoint unregistered: sender=:1.67 path=/MediaEndpoint/HFPAG
Jun 09 23:46:03 openSUSE.site bluetoothd[921]: bluetoothd[921]: Endpoint unregistered: sender=:1.67 path=/MediaEndpoint/HFPHS
Jun 09 23:46:03 openSUSE.site bluetoothd[921]: bluetoothd[921]: Stopping SDP server
Jun 09 23:46:03 openSUSE.site bluetoothd[921]: bluetoothd[921]: Exit
Jun 09 23:46:03 openSUSE.site kernel: wlan0: deauthenticating from 40:16:9f:7a:c7:72 by local choice (reason=3)
Jun 09 23:46:03 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Rejected send message, 3 matched rules; type="error", sender=":1.67" (uid=1000 pid=1619 comm="/usr/bin/pulseaudio --start --log-target=syslog ") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.0" (uid=0 pid=921 comm="/usr/sbin/bluetoothd -n ")
Jun 09 23:46:03 openSUSE.site dbus-daemon[948]: modem-manager[1006]: <info>  Caught signal 15, shutting down...
Jun 09 23:46:02 openSUSE.site systemd[1]: Started Store Sound Card State.
Jun 09 23:46:02 openSUSE.site systemd[1]: Stopped LSB: VirtualBox Linux kernel module.
Jun 09 23:46:02 openSUSE.site systemd[1]: Stopped Permit User Sessions.
Jun 09 23:46:02 openSUSE.site systemd[1]: Stopped LSB: Network time protocol daemon (ntpd).
Jun 09 23:46:02 openSUSE.site systemd[1]: Stopping Host and Network Name Lookups.
Jun 09 23:46:02 openSUSE.site systemd[1]: Stopped target Host and Network Name Lookups.
Jun 09 23:46:02 openSUSE.site systemd[1]: Stopping Network.
Jun 09 23:46:02 openSUSE.site systemd[1]: Stopped target Network.
Jun 09 23:46:02 openSUSE.site systemd[1]: Stopping Network Manager...
Jun 09 23:46:02 openSUSE.site systemd[1]: Stopping Remote File Systems.
Jun 09 23:46:02 openSUSE.site systemd[1]: Stopped target Remote File Systems.
Jun 09 23:46:03 openSUSE.site systemd[1]: Stopped D-Bus System Message Bus.
Jun 09 23:46:03 openSUSE.site modem-manager[1006]: <info>  Caught signal 15, shutting down...
Jun 09 23:46:03 openSUSE.site kernel: cfg80211: Calling CRDA to update world regulatory domain
Jun 09 23:46:03 openSUSE.site kernel: cfg80211: World regulatory domain updated:
Jun 09 23:46:03 openSUSE.site kernel: cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jun 09 23:46:03 openSUSE.site kernel: cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 09 23:46:03 openSUSE.site xdm[11526]: Shutting down service gdm..done
Jun 09 23:46:03 openSUSE.site kernel: cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Jun 09 23:46:03 openSUSE.site xendomains[11529]: xendomains ..done
Jun 09 23:46:03 openSUSE.site kernel: cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Jun 09 23:46:03 openSUSE.site kernel: cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 09 23:46:03 openSUSE.site kernel: cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 09 23:46:03 openSUSE.site vboxdrv[11600]: Stopping VirtualBox kernel modules..done
Jun 09 23:46:03 openSUSE.site xend[11602]: xend ..done
Jun 09 23:46:03 openSUSE.site ntp[11623]: Shutting down network time protocol daemon (NTPD)..done
Jun 09 23:46:03 openSUSE.site NetworkManager[950]: <warn> Activation (wlan0) failed for connection 'TP-LINK_7AC772'
Jun 09 23:46:03 openSUSE.site NetworkManager[950]: <info> (wlan0): now unmanaged
Jun 09 23:46:03 openSUSE.site NetworkManager[950]: <info> (wlan0): device state change: failed -> unmanaged (reason 'removed') [120 10 36]
Jun 09 23:46:03 openSUSE.site NetworkManager[950]: <info> (wlan0): deactivating device (reason 'removed') [36]
Jun 09 23:46:03 openSUSE.site NetworkManager[950]: <info> (wlan0): cleaning up...
Jun 09 23:46:04 openSUSE.site NetworkManager[950]: <info> exiting (success)
Jun 09 23:46:04 openSUSE.site systemd[1]: Stopped Network Manager.
Jun 09 23:46:04 openSUSE.site gdm-simple-slave[1094]: WARNING: Freeing conversation 'gdm-password' with active job
Jun 09 23:46:04 openSUSE.site gdm-simple-slave[1094]: GLib-GObject-CRITICAL: g_object_ref: assertion `object->ref_count > 0' failed
Jun 09 23:46:04 openSUSE.site gdm-simple-slave[1094]: GLib-GObject-CRITICAL: g_object_unref: assertion `object->ref_count > 0' failed
Jun 09 23:46:04 openSUSE.site kernel: usb 3-4: USB disconnect, device number 2
Jun 09 23:46:04 openSUSE.site systemd-udevd[11685]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 23:46:04 openSUSE.site systemd-udevd[11692]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 09 23:47:28 openSUSE.site systemd[1]: acpid.service stopping timed out. Killing.
Jun 09 23:47:29 openSUSE.site systemd[1]: acpid.service: main process exited, code=killed, status=9/KILL
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopped ACPI Event Daemon.
Jun 09 23:47:29 openSUSE.site systemd[1]: Unit acpid.service entered failed state
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopping Basic System.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopped target Basic System.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopping Forward Password Requests to Plymouth Directory Watch.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopped Forward Password Requests to Plymouth Directory Watch.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopping CUPS Printer Service Spool.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopped CUPS Printer Service Spool.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopping Forward Password Requests to Wall Directory Watch.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopping Daily Cleanup of Temporary Directories.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopping Sockets.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopped target Sockets.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopping PC/SC Smart Card Daemon Activation Socket.
Jun 09 23:47:29 openSUSE.site systemd[1]: Closed CUPS Printing Service Sockets.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopping LSB: Set default boot entry if called...
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopping LSB: AppArmor initialization...
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopping LSB: iSCSI initiator daemon root-fs support...
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopping Encrypted Volumes.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopped Setup Virtual Console.
Jun 09 23:47:29 openSUSE.site systemd[1]: Started Console System Shutdown Logging.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopped LSB: Set default boot entry if called.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopped LSB: iSCSI initiator daemon root-fs support.
Jun 09 23:47:29 openSUSE.site kernel: audit_printk_skb: 75 callbacks suppressed
Jun 09 23:47:29 openSUSE.site kernel: type=1400 audit(1370792849.675:37): apparmor="STATUS" operation="profile_remove" name="/sbin/klogd" pid=11727 comm="boot.apparmor"
Jun 09 23:47:29 openSUSE.site kernel: type=1400 audit(1370792849.675:38): apparmor="STATUS" operation="profile_remove" name="/sbin/syslog-ng" pid=11727 comm="boot.apparmor"
Jun 09 23:47:29 openSUSE.site kernel: type=1400 audit(1370792849.675:39): apparmor="STATUS" operation="profile_remove" name="/sbin/syslogd" pid=11727 comm="boot.apparmor"
Jun 09 23:47:29 openSUSE.site kernel: type=1400 audit(1370792849.675:40): apparmor="STATUS" operation="profile_remove" name="/usr/lib/apache2/mpm-prefork/apache2" pid=11727 comm="boot.apparmor"
Jun 09 23:47:29 openSUSE.site kernel: type=1400 audit(1370792849.675:41): apparmor="STATUS" operation="profile_remove" name="/usr/lib/dovecot/deliver" pid=11727 comm="boot.apparmor"
Jun 09 23:47:29 openSUSE.site kernel: type=1400 audit(1370792849.675:42): apparmor="STATUS" operation="profile_remove" name="/usr/lib/dovecot/dovecot-auth" pid=11727 comm="boot.apparmor"
Jun 09 23:47:29 openSUSE.site kernel: type=1400 audit(1370792849.675:43): apparmor="STATUS" operation="profile_remove" name="/usr/lib/dovecot/imap" pid=11727 comm="boot.apparmor"
Jun 09 23:47:29 openSUSE.site kernel: type=1400 audit(1370792849.675:44): apparmor="STATUS" operation="profile_remove" name="/usr/lib/dovecot/imap-login" pid=11727 comm="boot.apparmor"
Jun 09 23:47:29 openSUSE.site kernel: type=1400 audit(1370792849.675:45): apparmor="STATUS" operation="profile_remove" name="/usr/lib/dovecot/managesieve-login" pid=11727 comm="boot.apparmor"
Jun 09 23:47:29 openSUSE.site kernel: type=1400 audit(1370792849.676:46): apparmor="STATUS" operation="profile_remove" name="/usr/lib/dovecot/pop3" pid=11727 comm="boot.apparmor"
Jun 09 23:47:29 openSUSE.site boot.apparmor[11696]: Unloading AppArmor profiles  ..done
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopped LSB: AppArmor initialization.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopping Local File Systems.
Jun 09 23:47:29 openSUSE.site systemd[1]: Stopped target Local File Systems.
Jun 09 23:47:29 openSUSE.site systemd[1]: Unmounting /home...
Jun 09 23:47:29 openSUSE.site systemd[1]: Unmounting Lock Directory...
Jun 09 23:47:29 openSUSE.site systemd[1]: Unmounting Runtime Directory...
Jun 09 23:47:29 openSUSE.site systemd[1]: Unmounted Lock Directory.
Jun 09 23:47:29 openSUSE.site systemd[1]: Unmounted Runtime Directory.
Jun 09 23:47:30 openSUSE.site systemd[1]: Unmounted /home.
Jun 09 23:47:30 openSUSE.site systemd[1]: Starting Unmount All Filesystems.
Jun 09 23:47:30 openSUSE.site systemd[1]: Reached target Unmount All Filesystems.
Jun 09 23:47:30 openSUSE.site systemd[1]: Stopping Local File Systems (Pre).
Jun 09 23:47:30 openSUSE.site systemd[1]: Stopped target Local File Systems (Pre).
Jun 09 23:47:30 openSUSE.site systemd[1]: Stopping Remount Root and Kernel File Systems...
Jun 09 23:47:30 openSUSE.site systemd[1]: Stopped Remount Root and Kernel File Systems.
Jun 09 23:47:30 openSUSE.site systemd[1]: Starting Save Random Seed...
Jun 09 23:47:30 openSUSE.site systemd[1]: Starting Update UTMP about System Shutdown...
Jun 09 23:47:30 openSUSE.site systemd[1]: Stopping Replay Read-Ahead Data...
Jun 09 23:47:30 openSUSE.site systemd[1]: Stopped Replay Read-Ahead Data.
Jun 09 23:47:30 openSUSE.site systemd[1]: Stopping Collect Read-Ahead Data...
Jun 09 23:47:30 openSUSE.site systemd[1]: Stopped Collect Read-Ahead Data.
Jun 09 23:47:30 openSUSE.site systemd[1]: Shutting down.
Jun 09 23:47:30 openSUSE.site systemd-journal[257]: Journal stopped
e[1;39m-- Reboot --e[0m
Jun 10 10:38:19 openSUSE.site systemd-journal[271]: Allowing runtime journal files to grow to 292.0M.
Jun 10 10:38:19 openSUSE.site kernel: Initializing cgroup subsys cpuset
Jun 10 10:38:19 openSUSE.site kernel: Linux version 3.7.10-1.11-desktop (geeko@buildhost) (gcc version 4.7.2 20130108 [gcc-4_7-branch revision 195012] (SUSE Linux) ) #1 SMP PREEMPT Thu May 16 20:27:27 UTC 2013 (adf31bb)
Jun 10 10:38:19 openSUSE.site kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-3.7.10-1.11-desktop root=UUID=935330e8-5e6d-4d93-959b-ea4162b6c2f4 video=1600x900 resume=/dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part8 splash=silent quiet showopts
Jun 10 10:38:19 openSUSE.site kernel: e820: BIOS-provided physical RAM map:
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x0000000040005000-0x00000000a90a8fff] usable
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000a90a9000-0x00000000a92aafff] reserved
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000a92ab000-0x00000000b8151fff] usable
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000b8152000-0x00000000baeeefff] reserved
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000baeef000-0x00000000baf9efff] ACPI NVS
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000baf9f000-0x00000000baffefff] ACPI data
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000bafff000-0x00000000baffffff] usable
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000bb000000-0x00000000bf9fffff] reserved
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000fed08000-0x00000000fed08fff] reserved
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x00000000ff980000-0x00000000ffffffff] reserved
Jun 10 10:38:19 openSUSE.site kernel: BIOS-e820: [mem 0x0000000100000000-0x00000001bf5fffff] usable
Jun 10 10:38:19 openSUSE.site kernel: NX (Execute Disable) protection: active
Jun 10 10:38:19 openSUSE.site kernel: SMBIOS 2.7 present.
Jun 10 10:38:19 openSUSE.site kernel: DMI: Dell Inc.          Inspiron 7420/08PPR2, BIOS A09 08/16/2012
Jun 10 10:38:19 openSUSE.site kernel: e820: update [mem 0x00000000-0x0000ffff] usable ==> reserved
Jun 10 10:38:19 openSUSE.site kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Jun 10 10:38:19 openSUSE.site kernel: No AGP bridge found
Jun 10 10:38:19 openSUSE.site kernel: e820: last_pfn = 0x1bf600 max_arch_pfn = 0x400000000
Jun 10 10:38:19 openSUSE.site kernel: MTRR default type: uncachable
Jun 10 10:38:19 openSUSE.site kernel: MTRR fixed ranges enabled:
Jun 10 10:38:19 openSUSE.site kernel:   00000-9FFFF write-back
Jun 10 10:38:19 openSUSE.site kernel:   A0000-BFFFF uncachable
Jun 10 10:38:19 openSUSE.site kernel:   C0000-FFFFF write-protect
Jun 10 10:38:19 openSUSE.site kernel: MTRR variable ranges enabled:
Jun 10 10:38:19 openSUSE.site kernel:   0 base 0FF800000 mask FFF800000 write-protect
Jun 10 10:38:19 openSUSE.site kernel:   1 base 000000000 mask F80000000 write-back
Jun 10 10:38:19 openSUSE.site kernel:   2 base 080000000 mask FC0000000 write-back
Jun 10 10:38:19 openSUSE.site kernel:   3 base 0BC000000 mask FFC000000 uncachable
Jun 10 10:38:19 openSUSE.site kernel:   4 base 0BB000000 mask FFF000000 uncachable
Jun 10 10:38:19 openSUSE.site kernel:   5 base 100000000 mask F80000000 write-back
Jun 10 10:38:19 openSUSE.site kernel:   6 base 180000000 mask FC0000000 write-back
Jun 10 10:38:19 openSUSE.site kernel:   7 base 1BF800000 mask FFF800000 uncachable
Jun 10 10:38:19 openSUSE.site kernel:   8 base 1BF600000 mask FFFE00000 uncachable
Jun 10 10:38:19 openSUSE.site kernel:   9 disabled
Jun 10 10:38:19 openSUSE.site kernel: x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
Jun 10 10:38:19 openSUSE.site kernel: e820: last_pfn = 0xbb000 max_arch_pfn = 0x400000000
Jun 10 10:38:19 openSUSE.site kernel: found SMP MP-table at [mem 0x000f0100-0x000f010f] mapped at [ffff8800000f0100]
Jun 10 10:38:19 openSUSE.site kernel: initial memory mapped: [mem 0x00000000-0x1fffffff]
Jun 10 10:38:19 openSUSE.site kernel: Base memory trampoline at [ffff880000097000] 97000 size 24576
Jun 10 10:38:19 openSUSE.site kernel: init_memory_mapping: [mem 0x00000000-0xbaffffff]
Jun 10 10:38:19 openSUSE.site kernel:  [mem 0x00000000-0xbaffffff] page 2M
Jun 10 10:38:19 openSUSE.site kernel: kernel direct mapping tables up to 0xbaffffff @ [mem 0x1fffc000-0x1fffffff]
Jun 10 10:38:19 openSUSE.site kernel: init_memory_mapping: [mem 0x100000000-0x1bf5fffff]
Jun 10 10:38:19 openSUSE.site kernel:  [mem 0x100000000-0x1bf5fffff] page 2M
Jun 10 10:38:19 openSUSE.site kernel: kernel direct mapping tables up to 0x1bf5fffff @ [mem 0xb814e000-0xb8151fff]
Jun 10 10:38:19 openSUSE.site kernel: RAMDISK: [mem 0x342fa000-0x36174fff]
Jun 10 10:38:19 openSUSE.site kernel: ACPI: RSDP 00000000000f0120 00024 (v02 DELL  )
Jun 10 10:38:19 openSUSE.site kernel: ACPI: XSDT 00000000baffe170 000A4 (v01 DELL    QA09    00000002 LOHR 00000002)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: FACP 00000000bafe4000 0010C (v05 DELL    QA09    00000002 LOHR 00000002)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: DSDT 00000000baff2000 09ECD (v02 DELL    IVB-CPT 00000000 INTL 20061109)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: FACS 00000000baf7c000 00040
Jun 10 10:38:19 openSUSE.site kernel: ACPI: SLIC 00000000baffd000 00176 (v01 DELL    QA09    00000002 LOHR 00000001)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: SSDT 00000000baffc000 00166 (v01 DELL   PtidDevc 00001000 INTL 20061109)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: ASF! 00000000baff1000 000A5 (v32 DELL    QA09    00000002 LOHR 00000002)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: HPET 00000000bafee000 00038 (v01 DELL    QA09    00000002 LOHR 00000002)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: APIC 00000000bafed000 00098 (v01 DELL    QA09    00000002 LOHR 00000002)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: MCFG 00000000bafec000 0003C (v01 DELL    QA09    00000002 LOHR 00000002)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: FPDT 00000000bafeb000 00064 (v01 DELL    QA09    00000002 LOHR 00000002)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: SSDT 00000000bafea000 00968 (v01  PmRef  Cpu0Ist 00003000 INTL 20061109)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: SSDT 00000000bafe9000 00A92 (v01  PmRef    CpuPm 00003000 INTL 20061109)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: UEFI 00000000bafe8000 0003E (v01 DELL    QA09    00000002 LOHR 00000002)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: UEFI 00000000bafe7000 00042 (v01 PTL      COMBUF 00000001 PTL  00000001)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: POAT 00000000bafe6000 00055 (v03 DELL    QA09    00000002 LOHR 00000002)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: SSDT 00000000bafe3000 00DAE (v01 NvORef NvOptTbl 00001000 INTL 20061109)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: UEFI 00000000bafe2000 0027E (v01 DELL    QA09    00000002 LOHR 00000002)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: DBG2 00000000bafe0000 00070 (v00 DELL    QA09    00000002 LOHR 00000002)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: Local APIC address 0xfee00000
Jun 10 10:38:19 openSUSE.site kernel: No NUMA configuration found
Jun 10 10:38:19 openSUSE.site kernel: Faking a node at [mem 0x0000000000000000-0x00000001bf5fffff]
Jun 10 10:38:19 openSUSE.site kernel: Initmem setup node 0 [mem 0x00000000-0x1bf5fffff]
Jun 10 10:38:19 openSUSE.site kernel:   NODE_DATA [mem 0x1bf5ec000-0x1bf5fffff]
Jun 10 10:38:19 openSUSE.site kernel:  [ffffea0000000000-ffffea00061fffff] PMD -> [ffff8801b8c00000-ffff8801bdffffff] on node 0
Jun 10 10:38:19 openSUSE.site kernel: Zone ranges:
Jun 10 10:38:19 openSUSE.site kernel:   DMA      [mem 0x00010000-0x00ffffff]
Jun 10 10:38:19 openSUSE.site kernel:   DMA32    [mem 0x01000000-0xffffffff]
Jun 10 10:38:19 openSUSE.site kernel:   Normal   [mem 0x100000000-0x1bf5fffff]
Jun 10 10:38:19 openSUSE.site kernel: Movable zone start for each node
Jun 10 10:38:19 openSUSE.site kernel: Early memory node ranges
Jun 10 10:38:19 openSUSE.site kernel:   node   0: [mem 0x00010000-0x0009cfff]
Jun 10 10:38:19 openSUSE.site kernel:   node   0: [mem 0x00100000-0x1fffffff]
Jun 10 10:38:19 openSUSE.site kernel:   node   0: [mem 0x20200000-0x40003fff]
Jun 10 10:38:19 openSUSE.site kernel:   node   0: [mem 0x40005000-0xa90a8fff]
Jun 10 10:38:19 openSUSE.site kernel:   node   0: [mem 0xa92ab000-0xb8151fff]
Jun 10 10:38:19 openSUSE.site kernel:   node   0: [mem 0xbafff000-0xbaffffff]
Jun 10 10:38:19 openSUSE.site kernel:   node   0: [mem 0x100000000-0x1bf5fffff]
Jun 10 10:38:19 openSUSE.site kernel: On node 0 totalpages: 1536733
Jun 10 10:38:19 openSUSE.site kernel:   DMA zone: 56 pages used for memmap
Jun 10 10:38:19 openSUSE.site kernel:   DMA zone: 6 pages reserved
Jun 10 10:38:19 openSUSE.site kernel:   DMA zone: 3919 pages, LIFO batch:0
Jun 10 10:38:19 openSUSE.site kernel:   DMA32 zone: 14280 pages used for memmap
Jun 10 10:38:19 openSUSE.site kernel:   DMA32 zone: 734600 pages, LIFO batch:31
Jun 10 10:38:19 openSUSE.site kernel:   Normal zone: 10717 pages used for memmap
Jun 10 10:38:19 openSUSE.site kernel:   Normal zone: 773155 pages, LIFO batch:31
Jun 10 10:38:19 openSUSE.site kernel: ACPI: PM-Timer IO Port: 0x408
Jun 10 10:38:19 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] disabled)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x06] lapic_id[0x00] disabled)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x07] lapic_id[0x00] disabled)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: LAPIC (acpi_id[0x08] lapic_id[0x00] disabled)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Jun 10 10:38:19 openSUSE.site kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Jun 10 10:38:19 openSUSE.site kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Jun 10 10:38:19 openSUSE.site kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
Jun 10 10:38:19 openSUSE.site kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: IRQ0 used by override.
Jun 10 10:38:19 openSUSE.site kernel: ACPI: IRQ2 used by override.
Jun 10 10:38:19 openSUSE.site kernel: ACPI: IRQ9 used by override.
Jun 10 10:38:19 openSUSE.site kernel: Using ACPI (MADT) for SMP configuration information
Jun 10 10:38:19 openSUSE.site kernel: ACPI: HPET id: 0x8086a301 base: 0xfed00000
Jun 10 10:38:19 openSUSE.site kernel: smpboot: Allowing 8 CPUs, 4 hotplug CPUs
Jun 10 10:38:19 openSUSE.site kernel: nr_irqs_gsi: 40
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 000000000009d000 - 000000000009e000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 0000000020000000 - 0000000020200000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 0000000040004000 - 0000000040005000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000a90a9000 - 00000000a92ab000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000b8152000 - 00000000baeef000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000baeef000 - 00000000baf9f000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000baf9f000 - 00000000bafff000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000bb000000 - 00000000bfa00000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000bfa00000 - 00000000f8000000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000f8000000 - 00000000fc000000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000fc000000 - 00000000fec00000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000fec00000 - 00000000fec01000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000fec01000 - 00000000fed08000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000fed08000 - 00000000fed09000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000fed09000 - 00000000fed10000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000fed10000 - 00000000fed1a000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000fed1a000 - 00000000fed1c000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000fed1c000 - 00000000fed20000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000fed20000 - 00000000fee00000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000fee00000 - 00000000fee01000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000fee01000 - 00000000ff980000
Jun 10 10:38:19 openSUSE.site kernel: PM: Registered nosave memory: 00000000ff980000 - 0000000100000000
Jun 10 10:38:19 openSUSE.site kernel: e820: [mem 0xbfa00000-0xf7ffffff] available for PCI devices
Jun 10 10:38:19 openSUSE.site kernel: Booting paravirtualized kernel on bare hardware
Jun 10 10:38:19 openSUSE.site kernel: setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:8 nr_node_ids:1
Jun 10 10:38:19 openSUSE.site kernel: PERCPU: Embedded 27 pages/cpu @ffff8801bf200000 s81856 r8192 d20544 u262144
Jun 10 10:38:19 openSUSE.site kernel: pcpu-alloc: s81856 r8192 d20544 u262144 alloc=1*2097152
Jun 10 10:38:19 openSUSE.site kernel: pcpu-alloc: [0] 0 1 2 3 4 5 6 7
Jun 10 10:38:19 openSUSE.site kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1511674
Jun 10 10:38:19 openSUSE.site kernel: Policy zone: Normal
Jun 10 10:38:19 openSUSE.site kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.7.10-1.11-desktop root=UUID=935330e8-5e6d-4d93-959b-ea4162b6c2f4 video=1600x900 resume=/dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part8 splash=silent quiet showopts
Jun 10 10:38:19 openSUSE.site kernel: bootsplash: silent mode.
Jun 10 10:38:19 openSUSE.site kernel: PID hash table entries: 4096 (order: 3, 32768 bytes)
Jun 10 10:38:19 openSUSE.site kernel: __ex_table already sorted, skipping sort
Jun 10 10:38:19 openSUSE.site kernel: xsave: enabled xstate_bv 0x7, cntxt size 0x340
Jun 10 10:38:19 openSUSE.site kernel: Checking aperture...
Jun 10 10:38:19 openSUSE.site kernel: Memory: 5948584k/7329792k available (5769k kernel code, 1182860k absent, 198348k reserved, 5184k data, 992k init)
Jun 10 10:38:19 openSUSE.site kernel: Preemptible hierarchical RCU implementation.
Jun 10 10:38:19 openSUSE.site kernel: 	RCU dyntick-idle grace-period acceleration is enabled.
Jun 10 10:38:19 openSUSE.site kernel: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
Jun 10 10:38:19 openSUSE.site kernel: NR_IRQS:33024 nr_irqs:744 16
Jun 10 10:38:19 openSUSE.site kernel: Extended CMOS year: 2000
Jun 10 10:38:19 openSUSE.site kernel: Console: colour dummy device 80x25
Jun 10 10:38:19 openSUSE.site kernel: console [tty0] enabled
Jun 10 10:38:19 openSUSE.site kernel: allocated 25165824 bytes of page_cgroup
Jun 10 10:38:19 openSUSE.site kernel: please try 'cgroup_disable=memory' option if you don't want memory cgroups
Jun 10 10:38:19 openSUSE.site kernel: hpet clockevent registered
Jun 10 10:38:19 openSUSE.site kernel: tsc: Fast TSC calibration using PIT
Jun 10 10:38:19 openSUSE.site kernel: tsc: Detected 2494.415 MHz processor
Jun 10 10:38:19 openSUSE.site kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4988.83 BogoMIPS (lpj=2494415)
Jun 10 10:38:19 openSUSE.site kernel: pid_max: default: 32768 minimum: 301
Jun 10 10:38:19 openSUSE.site kernel: Security Framework initialized
Jun 10 10:38:19 openSUSE.site kernel: AppArmor: AppArmor initialized
Jun 10 10:38:19 openSUSE.site kernel: Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
Jun 10 10:38:19 openSUSE.site kernel: Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
Jun 10 10:38:19 openSUSE.site kernel: Mount-cache hash table entries: 256
Jun 10 10:38:19 openSUSE.site kernel: Initializing cgroup subsys cpuacct
Jun 10 10:38:19 openSUSE.site kernel: Initializing cgroup subsys memory
Jun 10 10:38:19 openSUSE.site kernel: Initializing cgroup subsys devices
Jun 10 10:38:19 openSUSE.site kernel: Initializing cgroup subsys freezer
Jun 10 10:38:19 openSUSE.site kernel: Initializing cgroup subsys net_cls
Jun 10 10:38:19 openSUSE.site kernel: Initializing cgroup subsys blkio
Jun 10 10:38:19 openSUSE.site kernel: Initializing cgroup subsys perf_event
Jun 10 10:38:19 openSUSE.site kernel: Initializing cgroup subsys hugetlb
Jun 10 10:38:19 openSUSE.site kernel: CPU: Physical Processor ID: 0
Jun 10 10:38:19 openSUSE.site kernel: CPU: Processor Core ID: 0
Jun 10 10:38:19 openSUSE.site kernel: [117B blob data]
Jun 10 10:38:19 openSUSE.site kernel: mce: CPU supports 7 MCE banks
Jun 10 10:38:19 openSUSE.site kernel: CPU0: Thermal monitoring handled by SMI
Jun 10 10:38:19 openSUSE.site kernel: process: using mwait in idle threads
Jun 10 10:38:19 openSUSE.site kernel: Freeing SMP alternatives: 20k freed
Jun 10 10:38:19 openSUSE.site kernel: ACPI: Core revision 20120913
Jun 10 10:38:19 openSUSE.site kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Jun 10 10:38:19 openSUSE.site kernel: smpboot: CPU0: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz (fam: 06, model: 3a, stepping: 09)
Jun 10 10:38:19 openSUSE.site kernel: Performance Events: PEBS fmt1+, 16-deep LBR, IvyBridge events, Intel PMU driver.
Jun 10 10:38:19 openSUSE.site kernel: ... version:                3
Jun 10 10:38:19 openSUSE.site kernel: ... bit width:              48
Jun 10 10:38:19 openSUSE.site kernel: ... generic registers:      4
Jun 10 10:38:19 openSUSE.site kernel: ... value mask:             0000ffffffffffff
Jun 10 10:38:19 openSUSE.site kernel: ... max period:             000000007fffffff
Jun 10 10:38:19 openSUSE.site kernel: ... fixed-purpose events:   3
Jun 10 10:38:19 openSUSE.site kernel: ... event mask:             000000070000000f
Jun 10 10:38:19 openSUSE.site kernel: CPU1: Thermal monitoring handled by SMI
Jun 10 10:38:19 openSUSE.site kernel: NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
Jun 10 10:38:19 openSUSE.site kernel: CPU2: Thermal monitoring handled by SMI
Jun 10 10:38:19 openSUSE.site kernel: CPU3: Thermal monitoring handled by SMI
Jun 10 10:38:19 openSUSE.site kernel: smpboot: Booting Node   0, Processors  #1 #2 #3
Jun 10 10:38:19 openSUSE.site kernel: Brought up 4 CPUs
Jun 10 10:38:19 openSUSE.site kernel: smpboot: Total of 4 processors activated (19955.32 BogoMIPS)
Jun 10 10:38:19 openSUSE.site kernel: devtmpfs: initialized
Jun 10 10:38:19 openSUSE.site kernel: PM: Registering ACPI NVS region [mem 0xbaeef000-0xbaf9efff] (720896 bytes)
Jun 10 10:38:19 openSUSE.site kernel: RTC time: 10:38:11, date: 06/10/13
Jun 10 10:38:19 openSUSE.site kernel: NET: Registered protocol family 16
Jun 10 10:38:19 openSUSE.site kernel: ACPI: bus type pci registered
Jun 10 10:38:19 openSUSE.site kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
Jun 10 10:38:19 openSUSE.site kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
Jun 10 10:38:19 openSUSE.site kernel: PCI: Using configuration type 1 for base access
Jun 10 10:38:19 openSUSE.site kernel: mtrr: your CPUs had inconsistent variable MTRR settings
Jun 10 10:38:19 openSUSE.site kernel: mtrr: probably your BIOS does not setup all CPUs.
Jun 10 10:38:19 openSUSE.site kernel: mtrr: corrected configuration.
Jun 10 10:38:19 openSUSE.site kernel: bio: create slab <bio-0> at 0
Jun 10 10:38:19 openSUSE.site kernel: ACPI: Added _OSI(Module Device)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: Added _OSI(Processor Device)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: Added _OSI(Processor Aggregator Device)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: EC: Look up EC in DSDT
Jun 10 10:38:19 openSUSE.site kernel: ACPI: Executed 2 blocks of module-level executable AML code
Jun 10 10:38:19 openSUSE.site kernel: [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
Jun 10 10:38:19 openSUSE.site kernel: ACPI: SSDT 00000000bae8e018 0083B (v01  PmRef  Cpu0Cst 00003001 INTL 20061109)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: Dynamic OEM Table Load:
Jun 10 10:38:19 openSUSE.site kernel: ACPI: SSDT           (null) 0083B (v01  PmRef  Cpu0Cst 00003001 INTL 20061109)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: SSDT 00000000bae8fa98 00303 (v01  PmRef    ApIst 00003000 INTL 20061109)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: SSDT           (null) 00303 (v01  PmRef    ApIst 00003000 INTL 20061109)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: SSDT 00000000bae8dd98 00119 (v01  PmRef    ApCst 00003000 INTL 20061109)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: SSDT           (null) 00119 (v01  PmRef    ApCst 00003000 INTL 20061109)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: Interpreter enabled
Jun 10 10:38:19 openSUSE.site kernel: ACPI: (supports S0 S3 S4 S5)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: Using IOAPIC for interrupt routing
Jun 10 10:38:19 openSUSE.site kernel: ACPI: EC: GPE = 0x17, I/O: command/status = 0x66, data = 0x62
Jun 10 10:38:19 openSUSE.site kernel: ACPI: No dock devices found.
Jun 10 10:38:19 openSUSE.site kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Jun 10 10:38:19 openSUSE.site kernel: \_SB_.PCI0:_OSC invalid UUID
Jun 10 10:38:19 openSUSE.site kernel: _OSC request data:1 8 1f
Jun 10 10:38:19 openSUSE.site kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
Jun 10 10:38:19 openSUSE.site kernel: PCI host bridge to bus 0000:00
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:00: root bus resource [bus 00-3e]
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7]
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff]
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:00: root bus resource [mem 0xbfa00000-0xfeafffff]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:00.0: [8086:0154] type 00 class 0x060000
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:02.0: [8086:0166] type 00 class 0x030000
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:02.0: reg 10: [mem 0xf1000000-0xf13fffff 64bit]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:02.0: reg 20: [io  0x4000-0x403f]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:14.0: reg 10: [mem 0xf1600000-0xf160ffff 64bit]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:16.0: reg 10: [mem 0xf1615000-0xf161500f 64bit]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1a.0: reg 10: [mem 0xf161a000-0xf161a3ff]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1b.0: reg 10: [mem 0xf1610000-0xf1613fff 64bit]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1c.4: [8086:1e18] type 01 class 0x060400
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1d.0: reg 10: [mem 0xf1619000-0xf16193ff]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1f.0: [8086:1e57] type 00 class 0x060100
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1f.2: [8086:1e03] type 00 class 0x010601
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1f.2: reg 10: [io  0x4088-0x408f]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1f.2: reg 14: [io  0x409c-0x409f]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1f.2: reg 18: [io  0x4080-0x4087]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1f.2: reg 1c: [io  0x4098-0x409b]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1f.2: reg 20: [io  0x4060-0x407f]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1f.2: reg 24: [mem 0xf1618000-0xf16187ff]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1f.2: PME# supported from D3hot
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1f.3: reg 10: [mem 0xf1614000-0xf16140ff 64bit]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1f.3: reg 20: [io  0xefa0-0xefbf]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:01:00.0: [10de:0fd2] type 00 class 0x030000
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:01:00.0: reg 10: [mem 0xf0000000-0xf0ffffff]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:01:00.0: reg 14: [mem 0xc0000000-0xcfffffff 64bit pref]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:01:00.0: reg 1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:01:00.0: reg 24: [io  0x3000-0x307f]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:01:00.0: reg 30: [mem 0xfff80000-0xffffffff pref]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:01.0: PCI bridge to [bus 01]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:01.0:   bridge window [io  0x3000-0x3fff]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:01.0:   bridge window [mem 0xf0000000-0xf0ffffff]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:02:00.0: [8086:0887] type 00 class 0x028000
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:02:00.0: reg 10: [mem 0xf1500000-0xf1501fff 64bit]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1c.0: PCI bridge to [bus 02]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1c.0:   bridge window [mem 0xf1500000-0xf15fffff]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:03:00.0: [1969:1091] type 00 class 0x020000
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:03:00.0: reg 10: [mem 0xf1400000-0xf143ffff 64bit]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:03:00.0: reg 18: [io  0x2000-0x207f]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1c.4: PCI bridge to [bus 03]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1c.4:   bridge window [io  0x2000-0x2fff]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:1c.4:   bridge window [mem 0xf1400000-0xf14fffff]
Jun 10 10:38:19 openSUSE.site kernel: ACPI: PCI Interrupt Routing Table \_SB_.PCI0._PRT]
Jun 10 10:38:19 openSUSE.site kernel: ACPI: PCI Interrupt Routing Table \_SB_.PCI0.RP01._PRT]
Jun 10 10:38:19 openSUSE.site kernel: ACPI: PCI Interrupt Routing Table \_SB_.PCI0.RP05._PRT]
Jun 10 10:38:19 openSUSE.site kernel: ACPI: PCI Interrupt Routing Table \_SB_.PCI0.PEG0._PRT]
Jun 10 10:38:19 openSUSE.site kernel: _OSC request data:1 1f 1f
Jun 10 10:38:19 openSUSE.site kernel:  pci0000:00: ACPI _OSC support notification failed, disabling PCIe ASPM
Jun 10 10:38:19 openSUSE.site kernel:  pci0000:00: Unable to request _OSC control (_OSC support mask: 0x08)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 10 *11 12 14 15)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 10 11 12 14 15) *0, disabled.
Jun 10 10:38:19 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 *10 11 12 14 15)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 10 *11 12 14 15)
Jun 10 10:38:19 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 10 11 12 14 15) *0, disabled.
Jun 10 10:38:19 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 10 11 12 14 15) *0, disabled.
Jun 10 10:38:19 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 10 11 12 14 15) *7
Jun 10 10:38:19 openSUSE.site kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 *10 11 12 14 15)
Jun 10 10:38:19 openSUSE.site kernel: vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
Jun 10 10:38:19 openSUSE.site kernel: vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=none,locks=none
Jun 10 10:38:19 openSUSE.site kernel: vgaarb: loaded
Jun 10 10:38:19 openSUSE.site kernel: vgaarb: bridge control possible 0000:01:00.0
Jun 10 10:38:19 openSUSE.site kernel: vgaarb: no bridge control possible 0000:00:02.0
Jun 10 10:38:19 openSUSE.site kernel: SCSI subsystem initialized
Jun 10 10:38:19 openSUSE.site kernel: ACPI: bus type scsi registered
Jun 10 10:38:19 openSUSE.site kernel: libata version 3.00 loaded.
Jun 10 10:38:19 openSUSE.site kernel: ACPI: bus type usb registered
Jun 10 10:38:19 openSUSE.site kernel: usbcore: registered new interface driver usbfs
Jun 10 10:38:19 openSUSE.site kernel: usbcore: registered new interface driver hub
Jun 10 10:38:19 openSUSE.site kernel: usbcore: registered new device driver usb
Jun 10 10:38:19 openSUSE.site kernel: PCI: Using ACPI for IRQ routing
Jun 10 10:38:19 openSUSE.site kernel: PCI: pci_cache_line_size set to 64 bytes
Jun 10 10:38:19 openSUSE.site kernel: e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
Jun 10 10:38:19 openSUSE.site kernel: e820: reserve RAM buffer [mem 0x40004000-0x43ffffff]
Jun 10 10:38:19 openSUSE.site kernel: e820: reserve RAM buffer [mem 0xa90a9000-0xabffffff]
Jun 10 10:38:19 openSUSE.site kernel: e820: reserve RAM buffer [mem 0xb8152000-0xbbffffff]
Jun 10 10:38:19 openSUSE.site kernel: e820: reserve RAM buffer [mem 0xbb000000-0xbbffffff]
Jun 10 10:38:19 openSUSE.site kernel: e820: reserve RAM buffer [mem 0x1bf600000-0x1bfffffff]
Jun 10 10:38:19 openSUSE.site kernel: NetLabel: Initializing
Jun 10 10:38:19 openSUSE.site kernel: NetLabel:  domain hash size = 128
Jun 10 10:38:19 openSUSE.site kernel: NetLabel:  protocols = UNLABELED CIPSOv4
Jun 10 10:38:19 openSUSE.site kernel: NetLabel:  unlabeled traffic allowed by default
Jun 10 10:38:19 openSUSE.site kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
Jun 10 10:38:19 openSUSE.site kernel: hpet0: 8 comparators, 64-bit 14.318180 MHz counter
Jun 10 10:38:19 openSUSE.site kernel: Switching to clocksource hpet
Jun 10 10:38:19 openSUSE.site kernel: AppArmor: AppArmor Filesystem Enabled
Jun 10 10:38:19 openSUSE.site kernel: pnp: PnP ACPI init
Jun 10 10:38:19 openSUSE.site kernel: ACPI: bus type pnp registered
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [bus 00-3e]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [io  0x0000-0x0cf7 window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [io  0x0cf8-0x0cff]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [io  0x0d00-0xffff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x000a0000-0x000bffff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x000c0000-0x000c3fff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x000c4000-0x000c7fff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x000c8000-0x000cbfff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x000cc000-0x000cffff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x000d0000-0x000d3fff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x000d4000-0x000d7fff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x000d8000-0x000dbfff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x000dc000-0x000dffff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x000e0000-0x000e3fff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x000e4000-0x000e7fff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x000e8000-0x000ebfff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x000ec000-0x000effff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x000f0000-0x000fffff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0xbfa00000-0xfeafffff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: [mem 0x00010000-0x0001ffff window]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:01: [io  0x0000-0x001f]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:01: [io  0x0081-0x0091]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:01: [io  0x0093-0x009f]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:01: [io  0x00c0-0x00df]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:01: [dma 4]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:02: [mem 0xfed00000-0xfed003ff]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:02: Plug and Play ACPI device, IDs PNP0103 (active)
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:03: [io  0x00f0]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:03: [irq 13]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x002e-0x002f]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x004e-0x004f]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x0061]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x0063]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x0065]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x0067]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x0068]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x006c]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x0070]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x0080]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x0092]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x00b2-0x00b3]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x0680-0x069f]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x1000-0x1003]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x1004-0x1013]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0xffff]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x0400-0x0453]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x0458-0x047f]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x0500-0x057f]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:04: [io  0x164e-0x164f]
Jun 10 10:38:19 openSUSE.site kernel: system 00:04: [io  0x0680-0x069f] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:04: [io  0x1000-0x1003] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:04: [io  0x1004-0x1013] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:04: [io  0xffff] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:04: [io  0x0400-0x0453] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:04: [io  0x0458-0x047f] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:04: [io  0x0500-0x057f] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:04: [io  0x164e-0x164f] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:05: [io  0x0070-0x0077]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:05: [irq 8]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:06: [io  0x0454-0x0457]
Jun 10 10:38:19 openSUSE.site kernel: system 00:06: [io  0x0454-0x0457] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:06: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:07: [io  0x0060]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:07: [io  0x0064]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:07: [irq 1]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:08: [irq 12]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:08: Plug and Play ACPI device, IDs DLL055f PNP0f13 (active)
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:09: [mem 0xfed1c000-0xfed1ffff]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:09: [mem 0xfed10000-0xfed17fff]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:09: [mem 0xfed18000-0xfed18fff]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:09: [mem 0xfed19000-0xfed19fff]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:09: [mem 0xf8000000-0xfbffffff]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:09: [mem 0xfed20000-0xfed3ffff]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:09: [mem 0xfed90000-0xfed93fff]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:09: [mem 0xfed45000-0xfed8ffff]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:09: [mem 0xff000000-0xffffffff]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:09: [mem 0xfee00000-0xfeefffff]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:09: [mem 0xfffff000-0xffffffff]
Jun 10 10:38:19 openSUSE.site kernel: pnp 00:09: disabling [mem 0xfffff000-0xffffffff] because it overlaps 0000:01:00.0 BAR 6 [mem 0xfff80000-0xffffffff pref]
Jun 10 10:38:19 openSUSE.site kernel: system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:09: [mem 0xfed10000-0xfed17fff] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:09: [mem 0xfed18000-0xfed18fff] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:09: [mem 0xfed19000-0xfed19fff] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:09: [mem 0xf8000000-0xfbffffff] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:09: [mem 0xfed20000-0xfed3ffff] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:09: [mem 0xfed90000-0xfed93fff] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:09: [mem 0xfed45000-0xfed8ffff] has been reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:09: [mem 0xff000000-0xffffffff] could not be reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:09: [mem 0xfee00000-0xfeefffff] could not be reserved
Jun 10 10:38:19 openSUSE.site kernel: system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
Jun 10 10:38:19 openSUSE.site kernel: pnp: PnP ACPI: found 10 devices
Jun 10 10:38:19 openSUSE.site kernel: ACPI: ACPI bus type pnp unregistered
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:01:00.0: no compatible bridge window for [mem 0xfff80000-0xffffffff pref]
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:01:00.0: BAR 6: can't assign mem pref (size 0x80000)
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7]
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff]
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:00: resource 7 [mem 0xbfa00000-0xfeafffff]
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:01: resource 1 [mem 0xf0000000-0xf0ffffff]
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:02: resource 1 [mem 0xf1500000-0xf15fffff]
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:03: resource 0 [io  0x2000-0x2fff]
Jun 10 10:38:19 openSUSE.site kernel: pci_bus 0000:03: resource 1 [mem 0xf1400000-0xf14fffff]
Jun 10 10:38:19 openSUSE.site kernel: NET: Registered protocol family 2
Jun 10 10:38:19 openSUSE.site kernel: TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
Jun 10 10:38:19 openSUSE.site kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Jun 10 10:38:19 openSUSE.site kernel: TCP: Hash tables configured (established 524288 bind 65536)
Jun 10 10:38:19 openSUSE.site kernel: TCP: reno registered
Jun 10 10:38:19 openSUSE.site kernel: UDP hash table entries: 4096 (order: 5, 131072 bytes)
Jun 10 10:38:19 openSUSE.site kernel: UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
Jun 10 10:38:19 openSUSE.site kernel: pci 0000:00:02.0: Boot video device
Jun 10 10:38:19 openSUSE.site kernel: PCI: CLS 64 bytes, default 64
Jun 10 10:38:19 openSUSE.site kernel: Unpacking initramfs...
Jun 10 10:38:19 openSUSE.site kernel: Freeing initrd memory: 31212k freed
Jun 10 10:38:19 openSUSE.site kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Jun 10 10:38:19 openSUSE.site kernel: software IO TLB [mem 0xb414e000-0xb814dfff] (64MB) mapped at [ffff8800b414e000-ffff8800b814dfff]
Jun 10 10:38:19 openSUSE.site kernel: audit: initializing netlink socket (disabled)
Jun 10 10:38:19 openSUSE.site kernel: type=2000 audit(1370860691.440:1): initialized
Jun 10 10:38:19 openSUSE.site kernel: HugeTLB registered 2 MB page size, pre-allocated 0 pages
Jun 10 10:38:19 openSUSE.site kernel: VFS: Disk quotas dquot_6.5.2
Jun 10 10:38:19 openSUSE.site kernel: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jun 10 10:38:19 openSUSE.site kernel: msgmni has been set to 11679
Jun 10 10:38:19 openSUSE.site kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
Jun 10 10:38:19 openSUSE.site kernel: io scheduler noop registered
Jun 10 10:38:19 openSUSE.site kernel: io scheduler deadline registered
Jun 10 10:38:19 openSUSE.site kernel: io scheduler cfq registered (default)
Jun 10 10:38:19 openSUSE.site kernel: pcieport 0000:00:01.0: irq 40 for MSI/MSI-X
Jun 10 10:38:19 openSUSE.site kernel: vesafb: mode is 1600x900x32, linelength=6400, pages=0
Jun 10 10:38:19 openSUSE.site kernel: vesafb: scrolling: redraw
Jun 10 10:38:19 openSUSE.site kernel: vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
Jun 10 10:38:19 openSUSE.site kernel: vesafb: framebuffer at 0xe0000000, mapped to 0xffffc90005600000, using 5632k, total 5632k
Jun 10 10:38:19 openSUSE.site kernel: Console: switching to colour frame buffer device 200x56
Jun 10 10:38:19 openSUSE.site kernel: fb0: VESA VGA frame buffer device
Jun 10 10:38:19 openSUSE.site kernel: intel_idle: MWAIT substates: 0x21120
Jun 10 10:38:19 openSUSE.site kernel: intel_idle: v0.4 model 0x3A
Jun 10 10:38:19 openSUSE.site kernel: intel_idle: lapic_timer_reliable_states 0xffffffff
Jun 10 10:38:19 openSUSE.site kernel: GHES: HEST is not enabled!
Jun 10 10:38:19 openSUSE.site kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing disabled
Jun 10 10:38:19 openSUSE.site kernel: Non-volatile memory driver v1.3
Jun 10 10:38:19 openSUSE.site kernel: Linux agpgart interface v0.103
Jun 10 10:38:19 openSUSE.site kernel: ahci 0000:00:1f.2: version 3.0
Jun 10 10:38:19 openSUSE.site kernel: ahci 0000:00:1f.2: irq 41 for MSI/MSI-X
Jun 10 10:38:19 openSUSE.site kernel: ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x9 impl SATA mode
Jun 10 10:38:19 openSUSE.site kernel: ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
Jun 10 10:38:19 openSUSE.site kernel: ahci 0000:00:1f.2: setting latency timer to 64
Jun 10 10:38:19 openSUSE.site kernel: scsi0 : ahci
Jun 10 10:38:19 openSUSE.site kernel: scsi1 : ahci
Jun 10 10:38:19 openSUSE.site kernel: scsi2 : ahci
Jun 10 10:38:19 openSUSE.site kernel: scsi3 : ahci
Jun 10 10:38:19 openSUSE.site kernel: scsi4 : ahci
Jun 10 10:38:19 openSUSE.site kernel: scsi5 : ahci
Jun 10 10:38:19 openSUSE.site kernel: ata1: SATA max UDMA/133 abar m2048@0xf1618000 port 0xf1618100 irq 41
Jun 10 10:38:19 openSUSE.site kernel: ata2: DUMMY
Jun 10 10:38:19 openSUSE.site kernel: ata3: DUMMY
Jun 10 10:38:19 openSUSE.site kernel: ata4: SATA max UDMA/133 abar m2048@0xf1618000 port 0xf1618280 irq 41
Jun 10 10:38:19 openSUSE.site kernel: ata5: DUMMY
Jun 10 10:38:19 openSUSE.site kernel: ata6: DUMMY
Jun 10 10:38:19 openSUSE.site kernel: libphy: Fixed MDIO Bus: probed
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd 0000:00:1a.0: setting latency timer to 64
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd 0000:00:1a.0: EHCI Host Controller
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd 0000:00:1a.0: debug port 2
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf161a000
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
Jun 10 10:38:19 openSUSE.site kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jun 10 10:38:19 openSUSE.site kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 10 10:38:19 openSUSE.site kernel: usb usb1: Product: EHCI Host Controller
Jun 10 10:38:19 openSUSE.site kernel: usb usb1: Manufacturer: Linux 3.7.10-1.11-desktop ehci_hcd
Jun 10 10:38:19 openSUSE.site kernel: usb usb1: SerialNumber: 0000:00:1a.0
Jun 10 10:38:19 openSUSE.site kernel: hub 1-0:1.0: USB hub found
Jun 10 10:38:19 openSUSE.site kernel: hub 1-0:1.0: 2 ports detected
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd 0000:00:1d.0: setting latency timer to 64
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd 0000:00:1d.0: EHCI Host Controller
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd 0000:00:1d.0: debug port 2
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf1619000
Jun 10 10:38:19 openSUSE.site kernel: ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
Jun 10 10:38:19 openSUSE.site kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
Jun 10 10:38:19 openSUSE.site kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 10 10:38:19 openSUSE.site kernel: usb usb2: Product: EHCI Host Controller
Jun 10 10:38:19 openSUSE.site kernel: usb usb2: Manufacturer: Linux 3.7.10-1.11-desktop ehci_hcd
Jun 10 10:38:19 openSUSE.site kernel: usb usb2: SerialNumber: 0000:00:1d.0
Jun 10 10:38:19 openSUSE.site kernel: hub 2-0:1.0: USB hub found
Jun 10 10:38:19 openSUSE.site kernel: hub 2-0:1.0: 2 ports detected
Jun 10 10:38:19 openSUSE.site kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jun 10 10:38:19 openSUSE.site kernel: uhci_hcd: USB Universal Host Controller Interface driver
Jun 10 10:38:19 openSUSE.site kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Jun 10 10:38:19 openSUSE.site kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Jun 10 10:38:19 openSUSE.site kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Jun 10 10:38:19 openSUSE.site kernel: mousedev: PS/2 mouse device common for all mice
Jun 10 10:38:19 openSUSE.site kernel: rtc_cmos 00:05: RTC can wake from S4
Jun 10 10:38:19 openSUSE.site kernel: rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
Jun 10 10:38:19 openSUSE.site kernel: rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
Jun 10 10:38:19 openSUSE.site kernel: cpuidle: using governor ladder
Jun 10 10:38:19 openSUSE.site kernel: cpuidle: using governor menu
Jun 10 10:38:19 openSUSE.site kernel: ledtrig-cpu: registered to indicate activity on CPUs
Jun 10 10:38:19 openSUSE.site kernel: EFI Variables Facility v0.08 2004-May-17
Jun 10 10:38:19 openSUSE.site kernel: usbcore: registered new interface driver usbhid
Jun 10 10:38:19 openSUSE.site kernel: usbhid: USB HID core driver
Jun 10 10:38:19 openSUSE.site kernel: TCP: cubic registered
Jun 10 10:38:19 openSUSE.site kernel: NET: Registered protocol family 10
Jun 10 10:38:19 openSUSE.site kernel: lib80211: common routines for IEEE802.11 drivers
Jun 10 10:38:19 openSUSE.site kernel: lib80211_crypt: registered algorithm 'NULL'
Jun 10 10:38:19 openSUSE.site kernel: Key type dns_resolver registered
Jun 10 10:38:19 openSUSE.site kernel: PM: Checking hibernation image partition /dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part8
Jun 10 10:38:19 openSUSE.site kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
Jun 10 10:38:19 openSUSE.site kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jun 10 10:38:19 openSUSE.site kernel: ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Jun 10 10:38:19 openSUSE.site kernel: ata1.00: ATA-8: ST9750420AS, 0002DEM1, max UDMA/133
Jun 10 10:38:19 openSUSE.site kernel: ata1.00: 1465149168 sectors, multi 16: LBA48 NCQ (depth 31/32)
Jun 10 10:38:19 openSUSE.site kernel: ata1.00: configured for UDMA/133
Jun 10 10:38:19 openSUSE.site kernel: scsi 0:0:0:0: Direct-Access     ATA      ST9750420AS      0002 PQ: 0 ANSI: 5
Jun 10 10:38:19 openSUSE.site kernel: sd 0:0:0:0: [sda] 1465149168 512-byte logical blocks: (750 GB/698 GiB)
Jun 10 10:38:19 openSUSE.site kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
Jun 10 10:38:19 openSUSE.site kernel: sd 0:0:0:0: [sda] Write Protect is off
Jun 10 10:38:19 openSUSE.site kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Jun 10 10:38:19 openSUSE.site kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 10 10:38:19 openSUSE.site kernel: usb 1-1: new high-speed USB device number 2 using ehci_hcd
Jun 10 10:38:19 openSUSE.site kernel: ata4.00: ATAPI: MATSHITA DVD+/-RW UJ8D1, D.02, max UDMA/100
Jun 10 10:38:19 openSUSE.site kernel: ata4.00: configured for UDMA/100
Jun 10 10:38:19 openSUSE.site kernel: scsi 3:0:0:0: CD-ROM            MATSHITA DVD+-RW UJ8D1    D.02 PQ: 0 ANSI: 5
Jun 10 10:38:19 openSUSE.site kernel:  sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 sda8 sda9 sda10 >
Jun 10 10:38:19 openSUSE.site kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jun 10 10:38:19 openSUSE.site kernel: usb 1-1: New USB device found, idVendor=8087, idProduct=0024
Jun 10 10:38:19 openSUSE.site kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 10 10:38:19 openSUSE.site kernel: hub 1-1:1.0: USB hub found
Jun 10 10:38:19 openSUSE.site kernel: hub 1-1:1.0: 6 ports detected
Jun 10 10:38:19 openSUSE.site kernel: usb 2-1: new high-speed USB device number 2 using ehci_hcd
Jun 10 10:38:19 openSUSE.site kernel: usb 2-1: New USB device found, idVendor=8087, idProduct=0024
Jun 10 10:38:19 openSUSE.site kernel: usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 10 10:38:19 openSUSE.site kernel: hub 2-1:1.0: USB hub found
Jun 10 10:38:19 openSUSE.site kernel: hub 2-1:1.0: 8 ports detected
Jun 10 10:38:19 openSUSE.site kernel: usb 1-1.3: new high-speed USB device number 3 using ehci_hcd
Jun 10 10:38:19 openSUSE.site kernel: tsc: Refined TSC clocksource calibration: 2494.332 MHz
Jun 10 10:38:19 openSUSE.site kernel: Switching to clocksource tsc
Jun 10 10:38:19 openSUSE.site kernel: usb 1-1.3: New USB device found, idVendor=0bda, idProduct=0129
Jun 10 10:38:19 openSUSE.site kernel: usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun 10 10:38:19 openSUSE.site kernel: usb 1-1.3: Product: USB2.0-CRW
Jun 10 10:38:19 openSUSE.site kernel: usb 1-1.3: Manufacturer: Generic
Jun 10 10:38:19 openSUSE.site kernel: usb 1-1.3: SerialNumber: 20100201396000000
Jun 10 10:38:19 openSUSE.site kernel: usb 1-1.5: new high-speed USB device number 4 using ehci_hcd
Jun 10 10:38:19 openSUSE.site kernel: input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input1
Jun 10 10:38:19 openSUSE.site kernel: PM: Hibernation image not present or could not be loaded.
Jun 10 10:38:19 openSUSE.site kernel: registered taskstats version 1
Jun 10 10:38:19 openSUSE.site kernel:   Magic number: 1:391:628
Jun 10 10:38:19 openSUSE.site kernel: rtc_cmos 00:05: setting system clock to 2013-06-10 10:38:13 UTC (1370860693)
Jun 10 10:38:19 openSUSE.site kernel: Freeing unused kernel memory: 992k freed
Jun 10 10:38:19 openSUSE.site kernel: Write protecting the kernel read-only data: 10240k
Jun 10 10:38:19 openSUSE.site kernel: Freeing unused kernel memory: 364k freed
Jun 10 10:38:19 openSUSE.site kernel: Freeing unused kernel memory: 108k freed
Jun 10 10:38:19 openSUSE.site kernel: usb 1-1.5: New USB device found, idVendor=064e, idProduct=8126
Jun 10 10:38:19 openSUSE.site kernel: usb 1-1.5: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Jun 10 10:38:19 openSUSE.site kernel: usb 1-1.5: Product: Laptop_Integrated_Webcam_HD
Jun 10 10:38:19 openSUSE.site kernel: usb 1-1.5: Manufacturer: SuYin
Jun 10 10:38:19 openSUSE.site kernel: hp_sw: device handler registered
Jun 10 10:38:19 openSUSE.site kernel: emc: device handler registered
Jun 10 10:38:19 openSUSE.site kernel: alua: device handler registered
Jun 10 10:38:19 openSUSE.site kernel: rdac: device handler registered
Jun 10 10:38:19 openSUSE.site systemd-udevd[118]: starting version 195
Jun 10 10:38:19 openSUSE.site kernel: ACPI: Requesting acpi_cpufreq
Jun 10 10:38:19 openSUSE.site kernel: xhci_hcd 0000:00:14.0: setting latency timer to 64
Jun 10 10:38:19 openSUSE.site kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
Jun 10 10:38:19 openSUSE.site kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
Jun 10 10:38:19 openSUSE.site kernel: xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
Jun 10 10:38:19 openSUSE.site kernel: xhci_hcd 0000:00:14.0: irq 21, io mem 0xf1600000
Jun 10 10:38:19 openSUSE.site kernel: xhci_hcd 0000:00:14.0: irq 42 for MSI/MSI-X
Jun 10 10:38:19 openSUSE.site kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
Jun 10 10:38:19 openSUSE.site kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 10 10:38:19 openSUSE.site kernel: usb usb3: Product: xHCI Host Controller
Jun 10 10:38:19 openSUSE.site kernel: usb usb3: Manufacturer: Linux 3.7.10-1.11-desktop xhci_hcd
Jun 10 10:38:19 openSUSE.site kernel: usb usb3: SerialNumber: 0000:00:14.0
Jun 10 10:38:19 openSUSE.site kernel: xHCI xhci_add_endpoint called for root hub
Jun 10 10:38:19 openSUSE.site kernel: xHCI xhci_check_bandwidth called for root hub
Jun 10 10:38:19 openSUSE.site kernel: hub 3-0:1.0: USB hub found
Jun 10 10:38:19 openSUSE.site kernel: thermal LNXTHERM:00: registered as thermal_zone0
Jun 10 10:38:19 openSUSE.site kernel: hub 3-0:1.0: 4 ports detected
Jun 10 10:38:19 openSUSE.site kernel: ACPI: Thermal Zone [TZ00] (29 C)
Jun 10 10:38:19 openSUSE.site kernel: thermal LNXTHERM:01: registered as thermal_zone1
Jun 10 10:38:19 openSUSE.site kernel: ACPI: Thermal Zone [TZ01] (29 C)
Jun 10 10:38:19 openSUSE.site kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
Jun 10 10:38:19 openSUSE.site kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
Jun 10 10:38:19 openSUSE.site kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 10 10:38:19 openSUSE.site kernel: usb usb4: Product: xHCI Host Controller
Jun 10 10:38:19 openSUSE.site kernel: usb usb4: Manufacturer: Linux 3.7.10-1.11-desktop xhci_hcd
Jun 10 10:38:19 openSUSE.site kernel: usb usb4: SerialNumber: 0000:00:14.0
Jun 10 10:38:19 openSUSE.site kernel: hub 4-0:1.0: USB hub found
Jun 10 10:38:19 openSUSE.site kernel: hub 4-0:1.0: 4 ports detected
Jun 10 10:38:19 openSUSE.site kernel: usb 2-1.5: new full-speed USB device number 3 using ehci_hcd
Jun 10 10:38:19 openSUSE.site kernel: usb 2-1.5: New USB device found, idVendor=8087, idProduct=07da
Jun 10 10:38:19 openSUSE.site kernel: usb 2-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 10 10:38:19 openSUSE.site kernel: usb 3-4: new low-speed USB device number 2 using xhci_hcd
Jun 10 10:38:19 openSUSE.site kernel: usb 3-4: New USB device found, idVendor=17ef, idProduct=6025
Jun 10 10:38:19 openSUSE.site kernel: usb 3-4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Jun 10 10:38:19 openSUSE.site kernel: usb 3-4: Product: ThinkPad USB Travel Mouse
Jun 10 10:38:19 openSUSE.site kernel: usb 3-4: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
Jun 10 10:38:19 openSUSE.site kernel: input: ThinkPad USB Travel Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.0/input/input2
Jun 10 10:38:19 openSUSE.site kernel: hid-generic 0003:17EF:6025.0001: input,hidraw0: USB HID v11.10 Mouse [ThinkPad USB Travel Mouse] on usb-0000:00:14.0-4/input0
Jun 10 10:38:19 openSUSE.site kernel: PM: Marking nosave pages: [mem 0x0009d000-0x000fffff]
Jun 10 10:38:19 openSUSE.site kernel: PM: Marking nosave pages: [mem 0x20000000-0x201fffff]
Jun 10 10:38:19 openSUSE.site kernel: PM: Marking nosave pages: [mem 0x40004000-0x40004fff]
Jun 10 10:38:19 openSUSE.site kernel: PM: Marking nosave pages: [mem 0xa90a9000-0xa92aafff]
Jun 10 10:38:19 openSUSE.site kernel: PM: Marking nosave pages: [mem 0xb8152000-0xbaffefff]
Jun 10 10:38:19 openSUSE.site kernel: PM: Marking nosave pages: [mem 0xbb000000-0xffffffff]
Jun 10 10:38:19 openSUSE.site kernel: PM: Basic memory bitmaps created
Jun 10 10:38:19 openSUSE.site kernel: PM: Basic memory bitmaps freed
Jun 10 10:38:19 openSUSE.site kernel: PM: Starting manual resume from disk
Jun 10 10:38:19 openSUSE.site kernel: PM: Hibernation image partition 8:8 present
Jun 10 10:38:19 openSUSE.site kernel: PM: Looking for hibernation image.
Jun 10 10:38:19 openSUSE.site kernel: PM: Image not found (code -22)
Jun 10 10:38:19 openSUSE.site kernel: EXT4-fs (sda9): mounted filesystem with ordered data mode. Opts: acl,user_xattr
Jun 10 10:38:19 openSUSE.site kernel: EXT4-fs (sda9): re-mounted. Opts: acl,user_xattr
Jun 10 10:38:19 openSUSE.site systemd[1]: RTC configured in localtime, applying delta of 480 minutes to system time.
Jun 10 10:38:19 openSUSE.site systemd[1]: systemd 195 running in system mode. (+PAM +LIBWRAP +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ; suse)
Jun 10 10:38:19 openSUSE.site systemd[1]: Inserted module 'autofs4'
Jun 10 10:38:19 openSUSE.site systemd[1]: Set hostname to <openSUSE.site>.
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Replay Read-Ahead Data...
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Collect Read-Ahead Data...
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
Jun 10 10:38:19 openSUSE.site systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Syslog Socket.
Jun 10 10:38:19 openSUSE.site systemd[1]: Listening on Syslog Socket.
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Remote File Systems.
Jun 10 10:38:19 openSUSE.site systemd[1]: Reached target Remote File Systems.
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Delayed Shutdown Socket.
Jun 10 10:38:19 openSUSE.site systemd[1]: Listening on Delayed Shutdown Socket.
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
Jun 10 10:38:19 openSUSE.site systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting udev Kernel Socket.
Jun 10 10:38:19 openSUSE.site systemd[1]: Listening on udev Kernel Socket.
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting udev Control Socket.
Jun 10 10:38:19 openSUSE.site systemd[1]: Listening on udev Control Socket.
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
Jun 10 10:38:19 openSUSE.site systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Encrypted Volumes.
Jun 10 10:38:19 openSUSE.site systemd[1]: Reached target Encrypted Volumes.
Jun 10 10:38:19 openSUSE.site systemd[1]: Expecting device dev-disk-by\x2did-ata\x2dST9750420AS_6WS1TZ7Q\x2dpart8.device...
Jun 10 10:38:19 openSUSE.site systemd[1]: Expecting device dev-disk-by\x2did-ata\x2dST9750420AS_6WS1TZ7Q\x2dpart10.device...
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Journal Socket.
Jun 10 10:38:19 openSUSE.site systemd[1]: Listening on Journal Socket.
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting LSB: iSCSI initiator daemon root-fs support...
Jun 10 10:38:19 openSUSE.site systemd-readahead[265]: Bumped block_nr parameter of 8:0 to 20480. This is a temporary hack and should be removed one day.
Jun 10 10:38:19 openSUSE.site systemd[1]: Mounting POSIX Message Queue File System...
Jun 10 10:38:19 openSUSE.site systemd[1]: Mounting Huge Pages File System...
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Create dynamic rule for /dev/root link...
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Journal Service...
Jun 10 10:38:19 openSUSE.site systemd[1]: Started Journal Service.
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting LSB: Set default boot entry if called...
Jun 10 10:38:19 openSUSE.site kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Jun 10 10:38:19 openSUSE.site kernel: pciehp: PCI Express Hot Plug Controller Driver version: 0.4
Jun 10 10:38:19 openSUSE.site systemd-journal[271]: Journal started
Jun 10 10:38:19 openSUSE.site systemd[1]: Started Collect Read-Ahead Data.
Jun 10 10:38:19 openSUSE.site systemd[1]: Started Replay Read-Ahead Data.
Jun 10 10:38:19 openSUSE.site systemd[1]: Started Set Up Additional Binary Formats.
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Setup Virtual Console...
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Load Kernel Modules...
Jun 10 10:38:19 openSUSE.site systemd[1]: Started File System Check on Root Device.
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Remount Root and Kernel File Systems...
Jun 10 10:38:19 openSUSE.site systemd-modules-load[275]: Inserted module 'pciehp'
Jun 10 10:38:19 openSUSE.site systemd[1]: Started Load Kernel Modules.
Jun 10 10:38:19 openSUSE.site systemd[1]: Mounted Configuration File System.
Jun 10 10:38:19 openSUSE.site systemd[1]: Starting Apply Kernel Variables...
Jun 10 10:38:19 openSUSE.site systemd-modules-load[275]: libkmod: kmod_config_parse: /etc/modprobe.d/10-unsupported-modules.conf line 10: ignoring bad line starting with 'allow_unsupported_modules'
Jun 10 10:38:19 openSUSE.site systemd[1]: Mounted Huge Pages File System.
Jun 10 10:38:19 openSUSE.site systemd[1]: Mounted POSIX Message Queue File System.
Jun 10 10:38:19 openSUSE.site systemd[1]: Started Apply Kernel Variables.
Jun 10 10:38:20 openSUSE.site kernel: EXT4-fs (sda9): re-mounted. Opts: acl,user_xattr
Jun 10 10:38:20 openSUSE.site systemd[1]: Started Remount Root and Kernel File Systems.
Jun 10 10:38:20 openSUSE.site systemd[1]: Starting Load Random Seed...
Jun 10 10:38:20 openSUSE.site systemd[1]: Started Load Random Seed.
Jun 10 10:38:20 openSUSE.site systemd[1]: Started Create dynamic rule for /dev/root link.
Jun 10 10:38:20 openSUSE.site systemd[1]: Starting udev Kernel Device Manager...
Jun 10 10:38:20 openSUSE.site systemd-udevd[303]: starting version 195
Jun 10 10:38:20 openSUSE.site systemd[1]: Started LSB: iSCSI initiator daemon root-fs support.
Jun 10 10:38:20 openSUSE.site systemd[1]: Started udev Kernel Device Manager.
Jun 10 10:38:20 openSUSE.site systemd[1]: Starting Local File Systems (Pre).
Jun 10 10:38:20 openSUSE.site systemd[1]: Reached target Local File Systems (Pre).
Jun 10 10:38:20 openSUSE.site systemd[1]: Mounting Lock Directory...
Jun 10 10:38:20 openSUSE.site systemd[1]: var-lock.mount: Directory /var/lock to mount over is not empty, mounting anyway. (To see the over-mounted files, please manually mount the underlying file system to a secondary location.)
Jun 10 10:38:20 openSUSE.site systemd[1]: Mounting /sys/kernel/debug...
Jun 10 10:38:20 openSUSE.site systemd[1]: Mounting Runtime Directory...
Jun 10 10:38:20 openSUSE.site systemd[1]: var-run.mount: Directory /var/run to mount over is not empty, mounting anyway. (To see the over-mounted files, please manually mount the underlying file system to a secondary location.)
Jun 10 10:38:20 openSUSE.site systemd[1]: Mounted Lock Directory.
Jun 10 10:38:20 openSUSE.site systemd[1]: Mounted /sys/kernel/debug.
Jun 10 10:38:20 openSUSE.site kernel: BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
Jun 10 10:38:20 openSUSE.site kernel: EDD information not available.
Jun 10 10:38:20 openSUSE.site systemd[1]: Mounted Runtime Directory.
Jun 10 10:38:20 openSUSE.site systemd[1]: Started LSB: Set default boot entry if called.
Jun 10 10:38:20 openSUSE.site systemd[1]: Started Setup Virtual Console.
Jun 10 10:38:20 openSUSE.site systemd[1]: Starting udev Coldplug all Devices...
Jun 10 10:38:20 openSUSE.site systemd[1]: Started udev Coldplug all Devices.
Jun 10 10:38:20 openSUSE.site systemd[1]: Starting Show Plymouth Boot Screen...
Jun 10 10:38:21 openSUSE.site systemd-udevd[362]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[360]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[361]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[364]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[363]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[365]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[369]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[366]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[371]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[387]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[397]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[413]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[411]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[422]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[421]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[423]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[424]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[425]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[432]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[456]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[427]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[516]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[524]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[566]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[572]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[574]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site kernel: microcode: CPU0 sig=0x306a9, pf=0x10, revision=0x12
Jun 10 10:38:21 openSUSE.site systemd-udevd[586]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[595]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[616]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[621]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site mtp-probe[426]: checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4"
Jun 10 10:38:21 openSUSE.site mtp-probe[426]: bus: 3, device: 2 was not an MTP device
Jun 10 10:38:21 openSUSE.site mtp-probe[614]: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5"
Jun 10 10:38:21 openSUSE.site mtp-probe[610]: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3"
Jun 10 10:38:21 openSUSE.site mtp-probe[614]: bus: 1, device: 4 was not an MTP device
Jun 10 10:38:21 openSUSE.site mtp-probe[610]: bus: 1, device: 3 was not an MTP device
Jun 10 10:38:21 openSUSE.site systemd-udevd[650]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[653]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[656]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[658]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[659]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site kernel: input: PC Speaker as /devices/platform/pcspkr/input/input3
Jun 10 10:38:21 openSUSE.site kernel: dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
Jun 10 10:38:21 openSUSE.site kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4
Jun 10 10:38:21 openSUSE.site kernel: ACPI: Power Button [PWRB]
Jun 10 10:38:21 openSUSE.site kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5
Jun 10 10:38:21 openSUSE.site kernel: ACPI: Sleep Button [SLPB]
Jun 10 10:38:21 openSUSE.site kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input6
Jun 10 10:38:21 openSUSE.site kernel: ACPI: Lid Switch [LID0]
Jun 10 10:38:21 openSUSE.site kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input7
Jun 10 10:38:21 openSUSE.site kernel: ACPI: Power Button [PWRF]
Jun 10 10:38:21 openSUSE.site kernel: [drm] Initialized drm 1.1.0 20060810
Jun 10 10:38:21 openSUSE.site kernel: pci 0000:00:00.0: Intel Ivybridge Chipset
Jun 10 10:38:21 openSUSE.site kernel: pci 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
Jun 10 10:38:21 openSUSE.site kernel: pci 0000:00:00.0: detected 65536K stolen memory
Jun 10 10:38:21 openSUSE.site kernel: checking generic (e0000000 580000) vs hw (e0000000 10000000)
Jun 10 10:38:21 openSUSE.site kernel: fb: conflicting fb hw usage inteldrmfb vs VESA VGA - removing generic driver
Jun 10 10:38:21 openSUSE.site kernel: ACPI: Invalid Power Resource to register!
Jun 10 10:38:21 openSUSE.site kernel: Console: switching
Jun 10 10:38:21 openSUSE.site kernel: to colour dummy device 80x25
Jun 10 10:38:21 openSUSE.site kernel: i915 0000:00:02.0: setting latency timer to 64
Jun 10 10:38:21 openSUSE.site kernel: [drm:__gen6_gt_force_wake_mt_get] *ERROR* Timed out waiting for forcewake old ack to clear.
Jun 10 10:38:21 openSUSE.site kernel: i915 0000:00:02.0: irq 43 for MSI/MSI-X
Jun 10 10:38:21 openSUSE.site kernel: [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
Jun 10 10:38:21 openSUSE.site kernel: [drm] Driver supports precise vblank timestamp query.
Jun 10 10:38:21 openSUSE.site kernel: vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=none:owns=io+mem
Jun 10 10:38:21 openSUSE.site kernel: vgaarb: transferring owner from PCI:0000:00:02.0 to PCI:0000:01:00.0
Jun 10 10:38:21 openSUSE.site kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jun 10 10:38:21 openSUSE.site kernel: scsi 3:0:0:0: Attached scsi generic sg1 type 5
Jun 10 10:38:21 openSUSE.site kernel: [drm] Enabling RC6 states: RC6 on, RC6p on, RC6pp off
Jun 10 10:38:21 openSUSE.site kernel: ACPI: Deprecated procfs I/F for AC is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
Jun 10 10:38:21 openSUSE.site kernel: fbcon: inteldrmfb (fb0) is primary device
Jun 10 10:38:21 openSUSE.site kernel: Console: switching to colour frame buffer device 200x56
Jun 10 10:38:21 openSUSE.site kernel: fb0: inteldrmfb frame buffer device
Jun 10 10:38:21 openSUSE.site kernel: drm: registered panic notifier
Jun 10 10:38:21 openSUSE.site kernel: ACPI Exception: AE_NOT_FOUND, Evaluating _DOD (20120913/video-1163)
Jun 10 10:38:21 openSUSE.site kernel: ACPI: Video Device [PEGP] (multi-head: no  rom: yes  post: no)
Jun 10 10:38:21 openSUSE.site kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:2e/LNXVIDEO:00/input/input8
Jun 10 10:38:21 openSUSE.site kernel: Registered led device: dell-laptop::touchpad
Jun 10 10:38:21 openSUSE.site kernel: acpi device:31: registered as cooling_device4
Jun 10 10:38:21 openSUSE.site kernel: ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
Jun 10 10:38:21 openSUSE.site kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input9
Jun 10 10:38:21 openSUSE.site kernel: [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
Jun 10 10:38:21 openSUSE.site kernel: microcode: CPU0 updated to revision 0x17, date = 2013-01-09
Jun 10 10:38:21 openSUSE.site kernel: microcode: CPU1 sig=0x306a9, pf=0x10, revision=0x12
Jun 10 10:38:21 openSUSE.site kernel: microcode: CPU1 updated to revision 0x17, date = 2013-01-09
Jun 10 10:38:21 openSUSE.site kernel: microcode: CPU2 sig=0x306a9, pf=0x10, revision=0x12
Jun 10 10:38:21 openSUSE.site kernel: microcode: CPU2 updated to revision 0x17, date = 2013-01-09
Jun 10 10:38:21 openSUSE.site kernel: microcode: CPU3 sig=0x306a9, pf=0x10, revision=0x12
Jun 10 10:38:21 openSUSE.site kernel: microcode: CPU3 updated to revision 0x17, date = 2013-01-09
Jun 10 10:38:21 openSUSE.site kernel: microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
Jun 10 10:38:21 openSUSE.site kernel: ACPI: AC Adapter [ADP0] (off-line)
Jun 10 10:38:21 openSUSE.site kernel: ACPI: Deprecated procfs I/F for battery is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
Jun 10 10:38:21 openSUSE.site kernel: ACPI: Battery Slot [BAT0] (battery present)
Jun 10 10:38:21 openSUSE.site kernel: wmi: Mapper loaded
Jun 10 10:38:21 openSUSE.site systemd-udevd[667]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[671]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[673]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site systemd-udevd[676]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site kernel: input: Dell WMI hotkeys as /devices/virtual/input/input10
Jun 10 10:38:21 openSUSE.site kernel: Linux video capture interface: v2.00
Jun 10 10:38:21 openSUSE.site kernel: uvcvideo: Found UVC 1.00 device Laptop_Integrated_Webcam_HD (064e:8126)
Jun 10 10:38:21 openSUSE.site kernel: sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
Jun 10 10:38:21 openSUSE.site kernel: cdrom: Uniform CD-ROM driver Revision: 3.20
Jun 10 10:38:21 openSUSE.site kernel: sr 3:0:0:0: Attached scsi CD-ROM sr0
Jun 10 10:38:21 openSUSE.site kernel: VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.PEG0.PEGP handle
Jun 10 10:38:21 openSUSE.site kernel: nouveau 0000:01:00.0: enabling device (0006 -> 0007)
Jun 10 10:38:21 openSUSE.site kernel: nouveau    DEVICE][0000:01:00.0] BOOT0  : 0x0e7120a2
Jun 10 10:38:21 openSUSE.site kernel: nouveau    DEVICE][0000:01:00.0] Chipset: GK107 (NVE7)
Jun 10 10:38:21 openSUSE.site kernel: nouveau    DEVICE][0000:01:00.0] Family : NVE0
Jun 10 10:38:21 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] checking PRAMIN for image...
Jun 10 10:38:21 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] ... signature not found
Jun 10 10:38:21 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] checking PROM for image...
Jun 10 10:38:21 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] checking ACPI for image...
Jun 10 10:38:21 openSUSE.site kernel: ACPI Warning: 0x0000000000000428-0x000000000000042f SystemIO conflicts with Region \PMIO 1 (20120913/utaddress-251)
Jun 10 10:38:21 openSUSE.site kernel: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Jun 10 10:38:21 openSUSE.site kernel: ACPI Warning: 0x0000000000000530-0x000000000000053f SystemIO conflicts with Region \GPIO 1 (20120913/utaddress-251)
Jun 10 10:38:21 openSUSE.site kernel: ACPI Warning: 0x0000000000000530-0x000000000000053f SystemIO conflicts with Region \_SB_.PCI0.PEG0.PEGP.GPIO 2 (20120913/utaddress-251)
Jun 10 10:38:21 openSUSE.site kernel: ACPI Warning: 0x0000000000000500-0x000000000000052f SystemIO conflicts with Region \GPIO 1 (20120913/utaddress-251)
Jun 10 10:38:21 openSUSE.site kernel: ACPI Warning: 0x0000000000000500-0x000000000000052f SystemIO conflicts with Region \_SB_.PCI0.PEG0.PEGP.GPIO 2 (20120913/utaddress-251)
Jun 10 10:38:21 openSUSE.site kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Jun 10 10:38:21 openSUSE.site kernel: mei 0000:00:16.0: setting latency timer to 64
Jun 10 10:38:21 openSUSE.site kernel: mei 0000:00:16.0: irq 44 for MSI/MSI-X
Jun 10 10:38:21 openSUSE.site systemd-udevd[677]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site kernel: mei 0000:00:16.0: wd: failed to find the client
Jun 10 10:38:21 openSUSE.site systemd-udevd[678]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:21 openSUSE.site kernel: input: Laptop_Integrated_Webcam_HD as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5:1.0/input/input11
Jun 10 10:38:21 openSUSE.site kernel: usbcore: registered new interface driver uvcvideo
Jun 10 10:38:21 openSUSE.site kernel: USB Video Class driver (1.1.1)
Jun 10 10:38:22 openSUSE.site systemd-udevd[679]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:22 openSUSE.site kernel: ACPI Warning: 0x000000000000efa0-0x000000000000efbf SystemIO conflicts with Region \_SB_.PCI0.SBUS.SMBI 1 (20120913/utaddress-251)
Jun 10 10:38:22 openSUSE.site kernel: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Jun 10 10:38:22 openSUSE.site kernel: cfg80211: Calling CRDA to update world regulatory domain
Jun 10 10:38:22 openSUSE.site kernel: Bluetooth: Core ver 2.16
Jun 10 10:38:22 openSUSE.site kernel: NET: Registered protocol family 31
Jun 10 10:38:22 openSUSE.site kernel: Bluetooth: HCI device and connection manager initialized
Jun 10 10:38:22 openSUSE.site kernel: Bluetooth: HCI socket layer initialized
Jun 10 10:38:22 openSUSE.site kernel: Bluetooth: L2CAP socket layer initialized
Jun 10 10:38:22 openSUSE.site kernel: Bluetooth: SCO socket layer initialized
Jun 10 10:38:22 openSUSE.site kernel: Intel(R) Wireless WiFi driver for Linux, in-tree:d
Jun 10 10:38:22 openSUSE.site kernel: Copyright(c) 2003-2012 Intel Corporation
Jun 10 10:38:22 openSUSE.site kernel: usbcore: registered new interface driver btusb
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: pci_resource_len = 0x00002000
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: pci_resource_base = ffffc900055a4000
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: HW Revision ID = 0xC4
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: irq 45 for MSI/MSI-X
Jun 10 10:38:22 openSUSE.site systemd-udevd[684]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:22 openSUSE.site systemd-udevd[685]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:22 openSUSE.site systemd-udevd[686]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:22 openSUSE.site kernel: iTCO_vendor_support: vendor-support=0
Jun 10 10:38:22 openSUSE.site kernel: iTCO_wdt: Intel TCO WatchDog Timer Driver v1.10
Jun 10 10:38:22 openSUSE.site kernel: iTCO_wdt: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
Jun 10 10:38:22 openSUSE.site kernel: iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Jun 10 10:38:22 openSUSE.site kernel: rts5139: module is from the staging directory, the quality is unknown, you have been warned.
Jun 10 10:38:22 openSUSE.site kernel: scsi6 : SCSI emulation for RTS5139 USB card reader
Jun 10 10:38:22 openSUSE.site kernel: scsi 6:0:0:0: Direct-Access     Generic- xD/SD/M.S.       1.00 PQ: 0 ANSI: 0 CCS
Jun 10 10:38:22 openSUSE.site kernel: sd 6:0:0:0: Attached scsi generic sg2 type 0
Jun 10 10:38:22 openSUSE.site kernel: sd 6:0:0:0: [sdb] Attached SCSI removable disk
Jun 10 10:38:22 openSUSE.site kernel: usbcore: registered new interface driver rts5139
Jun 10 10:38:22 openSUSE.site systemd-udevd[705]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:22 openSUSE.site systemd-udevd[707]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:22 openSUSE.site systemd-udevd[708]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:22 openSUSE.site systemd-udevd[710]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:22 openSUSE.site kernel: snd_hda_intel 0000:00:1b.0: irq 46 for MSI/MSI-X
Jun 10 10:38:22 openSUSE.site kernel: hda_codec: CX20590: BIOS auto-probing.
Jun 10 10:38:22 openSUSE.site kernel: ALSA hda_auto_parser.c:318 autoconfig: line_outs=1 (0x1f/0x0/0x0/0x0/0x0) type:speaker
Jun 10 10:38:22 openSUSE.site kernel: ALSA hda_auto_parser.c:322    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Jun 10 10:38:22 openSUSE.site kernel: ALSA hda_auto_parser.c:326    hp_outs=1 (0x19/0x0/0x0/0x0/0x0)
Jun 10 10:38:22 openSUSE.site kernel: ALSA hda_auto_parser.c:327    mono: mono_out=0x0
Jun 10 10:38:22 openSUSE.site kernel: ALSA hda_auto_parser.c:331    inputs:
Jun 10 10:38:22 openSUSE.site kernel: ALSA hda_auto_parser.c:335      Mic=0x1a
Jun 10 10:38:22 openSUSE.site kernel: ALSA hda_auto_parser.c:335      Internal Mic=0x23
Jun 10 10:38:22 openSUSE.site kernel: input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input12
Jun 10 10:38:22 openSUSE.site kernel: ALSA patch_conexant.c:4531 hda_codec: Enable sync_write for stable communication
Jun 10 10:38:22 openSUSE.site systemd-udevd[718]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:22 openSUSE.site kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
Jun 10 10:38:22 openSUSE.site kernel: input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
Jun 10 10:38:22 openSUSE.site kernel: input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
Jun 10 10:38:22 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] ... appears to be valid
Jun 10 10:38:22 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] using image from ACPI
Jun 10 10:38:22 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] BIT signature found
Jun 10 10:38:22 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] version 80.07.2f.00
Jun 10 10:38:22 openSUSE.site kernel: nouveau   DEVINIT][0000:01:00.0] adaptor not initialised
Jun 10 10:38:22 openSUSE.site kernel: nouveau     VBIOS][0000:01:00.0] running init tables
Jun 10 10:38:22 openSUSE.site kernel: cfg80211: World regulatory domain updated:
Jun 10 10:38:22 openSUSE.site kernel: cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jun 10 10:38:22 openSUSE.site kernel: cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:38:22 openSUSE.site kernel: cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:38:22 openSUSE.site kernel: cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:38:22 openSUSE.site kernel: cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:38:22 openSUSE.site kernel: cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:38:22 openSUSE.site systemd[1]: Mounted FUSE Control File System.
Jun 10 10:38:22 openSUSE.site systemd[1]: Starting Load Random Seed...
Jun 10 10:38:22 openSUSE.site systemd[1]: Started Set Up Additional Binary Formats.
Jun 10 10:38:22 openSUSE.site systemd[1]: Mounted Configuration File System.
Jun 10 10:38:22 openSUSE.site systemd[1]: Started File System Check on Root Device.
Jun 10 10:38:22 openSUSE.site systemd[1]: Starting Sound Card.
Jun 10 10:38:22 openSUSE.site systemd[1]: Reached target Sound Card.
Jun 10 10:38:22 openSUSE.site systemd[1]: Started Load Random Seed.
Jun 10 10:38:22 openSUSE.site systemd[1]: Started Show Plymouth Boot Screen.
Jun 10 10:38:22 openSUSE.site systemd[1]: Starting Forward Password Requests to Plymouth Directory Watch.
Jun 10 10:38:22 openSUSE.site systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Jun 10 10:38:22 openSUSE.site systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: loaded firmware version 18.168.6.1
Jun 10 10:38:22 openSUSE.site kernel: iwldvm: Intel(R) Wireless WiFi Link AGN driver for Linux, in-tree:d
Jun 10 10:38:22 openSUSE.site kernel: iwldvm: Copyright(c) 2003-2012 Intel Corporation
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUG enabled
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEVICE_TRACING disabled
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEVICE_TESTMODE disabled
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_P2P disabled
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: Detected Intel(R) Centrino(R) Wireless-N 2230 BGN, REV=0xC8
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: L1 Enabled; Disabling L0S
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: device EEPROM VER=0x81c, CALIB=0x6
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: Device SKU: 0x150
Jun 10 10:38:22 openSUSE.site kernel: iwlwifi 0000:02:00.0: Valid Tx ant: 0x3, Valid Rx ant: 0x3
Jun 10 10:38:22 openSUSE.site kernel: Registered led device: phy0-led
Jun 10 10:38:22 openSUSE.site kernel: ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
Jun 10 10:38:22 openSUSE.site kernel: nouveau       MXM][0000:01:00.0] no VBIOS data, nothing to do
Jun 10 10:38:22 openSUSE.site kernel: nouveau       PFB][0000:01:00.0] RAM type: DDR3
Jun 10 10:38:22 openSUSE.site kernel: nouveau       PFB][0000:01:00.0] RAM size: 2048 MiB
Jun 10 10:38:22 openSUSE.site kernel: nouveau W  PGRAPH][0000:01:00.0] disabled, PGRAPH=1 to enable
Jun 10 10:38:22 openSUSE.site kernel: vga_switcheroo: enabled
Jun 10 10:38:22 openSUSE.site kernel: [TTM] Zone  kernel: Available graphics memory: 2990640 kiB
Jun 10 10:38:22 openSUSE.site kernel: [TTM] Zone   dma32: Available graphics memory: 2097152 kiB
Jun 10 10:38:22 openSUSE.site kernel: [TTM] Initializing pool allocator
Jun 10 10:38:22 openSUSE.site kernel: [TTM] Initializing DMA pool allocator
Jun 10 10:38:22 openSUSE.site kernel: nouveau       DRM] VRAM: 2048 MiB
Jun 10 10:38:22 openSUSE.site kernel: nouveau       DRM] GART: 512 MiB
Jun 10 10:38:22 openSUSE.site kernel: nouveau       DRM] BIT BIOS found
Jun 10 10:38:22 openSUSE.site kernel: nouveau       DRM] Bios version 80.07.2f.00
Jun 10 10:38:22 openSUSE.site kernel: nouveau       DRM] TMDS table version 2.0
Jun 10 10:38:22 openSUSE.site kernel: nouveau       DRM] DCB version 4.0
Jun 10 10:38:22 openSUSE.site kernel: nouveau       DRM] DCB outp 00: 02000f00 00000000
Jun 10 10:38:22 openSUSE.site kernel: nouveau       DRM] DCB conn 00: 00000000
Jun 10 10:38:22 openSUSE.site kernel: [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
Jun 10 10:38:22 openSUSE.site kernel: [drm] No driver support for vblank timestamp query.
Jun 10 10:38:22 openSUSE.site kernel: nouveau       DRM] ACPI backlight interface available, not registering our own
Jun 10 10:38:22 openSUSE.site kernel: nouveau W     DRM] voltage table 0x50 unknown
Jun 10 10:38:22 openSUSE.site kernel: nouveau       DRM] 2 available performance level(s)
Jun 10 10:38:22 openSUSE.site kernel: nouveau       DRM] 1: core 202MHz shader 405MHz memory 405MHz voltage 490mV
Jun 10 10:38:22 openSUSE.site kernel: nouveau       DRM] 3: core 450MHz shader 900MHz memory 1080MHz voltage 560mV
Jun 10 10:38:22 openSUSE.site kernel: nouveau       DRM] c:
Jun 10 10:38:22 openSUSE.site kernel: nouveau E     DRM] failed to create kernel channel, -22
Jun 10 10:38:22 openSUSE.site ifup[750]: Service network not started and mode 'auto' -> skipping
Jun 10 10:38:22 openSUSE.site kernel: No connectors reported connected with modes
Jun 10 10:38:22 openSUSE.site kernel: [drm] Cannot find any crtc or sizes - going 1024x768
Jun 10 10:38:22 openSUSE.site systemd-udevd[752]: failed to execute '/usr/lib/udev/socket:/org/xen/xend/udev_event' 'socket:/org/xen/xend/udev_event': No such file or directory
Jun 10 10:38:22 openSUSE.site kernel: nouveau       DRM] allocated 1024x768 fb: 0x60000, bo ffff8801b0d14400
Jun 10 10:38:22 openSUSE.site kernel: fb1: nouveaufb frame buffer device
Jun 10 10:38:22 openSUSE.site kernel: [drm] Initialized nouveau 1.1.0 20120801 for 0000:01:00.0 on minor 1
Jun 10 10:38:23 openSUSE.site systemd[1]: Found device ST9750420AS.
Jun 10 10:38:23 openSUSE.site systemd[1]: Starting File System Check on /dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part10...
Jun 10 10:38:24 openSUSE.site systemd-fsck[753]: /dev/sda10: clean, 1387689/10354688 files, 35328500/41415168 blocks
Jun 10 10:38:24 openSUSE.site systemd[1]: Started File System Check on /dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part10.
Jun 10 10:38:24 openSUSE.site systemd[1]: Mounting /home...
Jun 10 10:38:24 openSUSE.site systemd[1]: Found device ST9750420AS.
Jun 10 10:38:24 openSUSE.site systemd[1]: Activating swap /dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part8...
Jun 10 10:38:24 openSUSE.site kernel: Adding 2106364k swap on /dev/sda8.  Priority:-1 extents:1 across:2106364k
Jun 10 10:38:24 openSUSE.site systemd[1]: Activated swap /dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part8.
Jun 10 10:38:24 openSUSE.site systemd[1]: Starting Swap.
Jun 10 10:38:24 openSUSE.site systemd[1]: Reached target Swap.
Jun 10 10:38:25 openSUSE.site kernel: EXT4-fs (sda10): mounted filesystem with ordered data mode. Opts: acl,user_xattr
Jun 10 10:38:25 openSUSE.site systemd[1]: Mounted /home.
Jun 10 10:38:25 openSUSE.site systemd[1]: Starting Local File Systems.
Jun 10 10:38:25 openSUSE.site systemd[1]: Reached target Local File Systems.
Jun 10 10:38:25 openSUSE.site systemd[1]: Starting LSB: Supports the direct execution of binary formats....
Jun 10 10:38:25 openSUSE.site systemd[1]: Starting Recreate Volatile Files and Directories...
Jun 10 10:38:25 openSUSE.site systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Jun 10 10:38:25 openSUSE.site systemd[1]: Starting Trigger Flushing of Journal to Persistent Storage...
Jun 10 10:38:25 openSUSE.site systemd[1]: Mounting Arbitrary Executable File Formats File System...
Jun 10 10:38:26 openSUSE.site systemd-journal[271]: Allowing system journal files to grow to 3.9G.
Jun 10 10:38:25 openSUSE.site systemd[1]: Started Trigger Flushing of Journal to Persistent Storage.
Jun 10 10:38:25 openSUSE.site systemd[1]: Mounted Arbitrary Executable File Formats File System.
Jun 10 10:38:25 openSUSE.site systemd[1]: Started LSB: Supports the direct execution of binary formats..
Jun 10 10:38:25 openSUSE.site systemd[1]: Started Recreate Volatile Files and Directories.
Jun 10 10:38:25 openSUSE.site systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Jun 10 10:38:25 openSUSE.site systemd[1]: Starting LSB: AppArmor initialization...
Jun 10 10:38:26 openSUSE.site systemd[1]: Started LSB: AppArmor initialization.
Jun 10 10:38:26 openSUSE.site systemd[1]: Starting System Initialization.
Jun 10 10:38:26 openSUSE.site systemd[1]: Reached target System Initialization.
Jun 10 10:38:26 openSUSE.site systemd[1]: Starting PC/SC Smart Card Daemon Activation Socket.
Jun 10 10:38:26 openSUSE.site systemd[1]: Listening on PC/SC Smart Card Daemon Activation Socket.
Jun 10 10:38:35 openSUSE.site jexec[764]: Starting jexec services
Jun 10 10:38:26 openSUSE.site bluetoothd[933]: Bluetooth daemon 4.101
Jun 10 10:38:26 openSUSE.site avahi-daemon[938]: Found user 'avahi' (UID 115) and group 'avahi' (GID 113).
Jun 10 10:38:26 openSUSE.site avahi-daemon[938]: Successfully dropped root privileges.
Jun 10 10:38:26 openSUSE.site avahi-daemon[938]: avahi-daemon 0.6.31 starting up.
Jun 10 10:38:26 openSUSE.site acpid[951]: starting up with netlink and the input layer
Jun 10 10:38:26 openSUSE.site acpid[951]: 2 rules loaded
Jun 10 10:38:26 openSUSE.site acpid[951]: waiting for events: event logging is off
Jun 10 10:38:26 openSUSE.site bluetoothd[933]: Starting SDP server
Jun 10 10:38:26 openSUSE.site bluetoothd[933]: Parsing /etc/bluetooth/input.conf failed: No such file or directory
Jun 10 10:38:26 openSUSE.site bluetoothd[933]: Parsing /etc/bluetooth/audio.conf failed: No such file or directory
Jun 10 10:38:26 openSUSE.site bluetoothd[933]: Bluetooth Management interface initialized
Jun 10 10:38:35 openSUSE.site bluetoothd[933]: Parsing /etc/bluetooth/serial.conf failed: No such file or directory
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: <info> NetworkManager (version 0.9.6.4) is starting...
Jun 10 10:38:35 openSUSE.site avahi-daemon[938]: Loading service file /etc/avahi/services/sftp-ssh.service.
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: <info> Read config file /etc/NetworkManager/NetworkManager.conf
Jun 10 10:38:35 openSUSE.site avahi-daemon[938]: Loading service file /etc/avahi/services/ssh.service.
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: <info> WEXT support is enabled
Jun 10 10:38:35 openSUSE.site avahi-daemon[938]: Network interface enumeration completed.
Jun 10 10:38:35 openSUSE.site avahi-daemon[938]: Registering HINFO record with values 'X86_64'/'LINUX'.
Jun 10 10:38:35 openSUSE.site avahi-daemon[938]: Server startup complete. Host name is openSUSE.local. Local service cookie is 1298452951.
Jun 10 10:38:35 openSUSE.site avahi-daemon[938]: Service "openSUSE" (/etc/avahi/services/ssh.service) successfully established.
Jun 10 10:38:35 openSUSE.site avahi-daemon[938]: Service "openSUSE" (/etc/avahi/services/sftp-ssh.service) successfully established.
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: <info> VPN: loaded org.freedesktop.NetworkManager.pptp
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: <info> VPN: loaded org.freedesktop.NetworkManager.openvpn
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: <info> VPN: loaded org.freedesktop.NetworkManager.vpnc
Jun 10 10:38:35 openSUSE.site bluetoothd[933]: input-headset driver probe failed for device 6C:A7:80:7E:5D:E6
Jun 10 10:38:35 openSUSE.site dbus[956]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Jun 10 10:38:35 openSUSE.site bluetoothd[933]: input-headset driver probe failed for device 40:98:4E:B0:E8:4E
Jun 10 10:38:35 openSUSE.site polkitd[1011]: Started polkitd version 0.110
Jun 10 10:38:35 openSUSE.site polkitd[1011]: Loading rules from directory /etc/polkit-1/rules.d
Jun 10 10:38:35 openSUSE.site polkitd[1011]: Loading rules from directory /usr/share/polkit-1/rules.d
Jun 10 10:38:35 openSUSE.site polkitd[1011]: Finished loading, compiling and executing 3 rules
Jun 10 10:38:35 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Jun 10 10:38:35 openSUSE.site polkitd[1011]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: <info> Loaded plugin ifcfg-suse: (C) 2008 Novell, Inc.  To report bugs please use the NetworkManager mailing list.
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: <info> Loaded plugin keyfile: (c) 2007 - 2010 Red Hat, Inc.  To report bugs please use the NetworkManager mailing list.
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile: parsing VPN connection 1 ...
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile:     read connection 'VPN connection 1'
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile: parsing Qt_Conf_2013 ...
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile:     read connection 'Qt_Conf_2013'
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile: parsing STB_YD0O ...
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile:     read connection 'STB_YD0O'
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile: parsing MobileWiFi-f124 ...
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile:     read connection 'MobileWiFi-f124'
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile: parsing CU_MSaX ...
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile:     read connection 'CU_MSaX'
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile: parsing CU_YD0O ...
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile:     read connection 'CU_YD0O'
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile: parsing New DSL Connection ...
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile:     read connection 'New DSL Connection'
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile: parsing Auto art ...
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile:     read connection 'Auto art'
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile: parsing TP-LINK_7AC772 ...
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile:     read connection 'TP-LINK_7AC772'
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile: parsing AAA-TP-LINK ...
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile:     read connection 'AAA-TP-LINK'
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile: parsing CMCC ...
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: keyfile:     read connection 'CMCC'
Jun 10 10:38:35 openSUSE.site kernel: type=1400 audit(1370831906.191:2): apparmor="STATUS" operation="profile_load" name="/{usr/,}bin/ping" pid=802 comm="apparmor_parser"
Jun 10 10:38:35 openSUSE.site systemd[1]: Starting Authorization Manager...
Jun 10 10:38:35 openSUSE.site systemd[1]: Started Authorization Manager.
Jun 10 10:38:35 openSUSE.site kernel: type=1400 audit(1370831906.198:3): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm-guest-session-wrapper" pid=809 comm="apparmor_parser"
Jun 10 10:38:35 openSUSE.site boot.apparmor[785]: Starting AppArmor ..done
Jun 10 10:38:35 openSUSE.site kernel: type=1400 audit(1370831906.204:4): apparmor="STATUS" operation="profile_load" name="/sbin/klogd" pid=815 comm="apparmor_parser"
Jun 10 10:38:35 openSUSE.site kernel: type=1400 audit(1370831906.207:5): apparmor="STATUS" operation="profile_load" name="/sbin/syslog-ng" pid=819 comm="apparmor_parser"
Jun 10 10:38:35 openSUSE.site kernel: type=1400 audit(1370831906.211:6): apparmor="STATUS" operation="profile_load" name="/sbin/syslogd" pid=823 comm="apparmor_parser"
Jun 10 10:38:35 openSUSE.site bluetoothd[933]: bluetoothd[933]: Bluetooth daemon 4.101
Jun 10 10:38:35 openSUSE.site bluetoothd[933]: bluetoothd[933]: Starting SDP server
Jun 10 10:38:35 openSUSE.site bluetoothd[933]: bluetoothd[933]: Parsing /etc/bluetooth/input.conf failed: No such file or directory
Jun 10 10:38:35 openSUSE.site bluetoothd[933]: bluetoothd[933]: Parsing /etc/bluetooth/audio.conf failed: No such file or directory
Jun 10 10:38:35 openSUSE.site bluetoothd[933]: bluetoothd[933]: Bluetooth Management interface initialized
Jun 10 10:38:35 openSUSE.site bluetoothd[933]: bluetoothd[933]: Parsing /etc/bluetooth/serial.conf failed: No such file or directory
Jun 10 10:38:35 openSUSE.site bluetoothd[933]: bluetoothd[933]: input-headset driver probe failed for device 6C:A7:80:7E:5D:E6
Jun 10 10:38:35 openSUSE.site bluetoothd[933]: bluetoothd[933]: input-headset driver probe failed for device 40:98:4E:B0:E8:4E
Jun 10 10:38:35 openSUSE.site kernel: type=1400 audit(1370831906.218:7): apparmor="STATUS" operation="profile_load" name="/usr/lib/apache2/mpm-prefork/apache2" pid=828 comm="apparmor_parser"
Jun 10 10:38:35 openSUSE.site kernel: type=1400 audit(1370831906.218:8): apparmor="STATUS" operation="profile_load" name="/usr/lib/apache2/mpm-prefork/apache2//DEFAULT_URI" pid=828 comm="apparmor_parser"
Jun 10 10:38:35 openSUSE.site kernel: type=1400 audit(1370831906.218:9): apparmor="STATUS" operation="profile_load" name="/usr/lib/apache2/mpm-prefork/apache2//HANDLING_UNTRUSTED_INPUT" pid=828 comm="apparmor_parser"
Jun 10 10:38:35 openSUSE.site kernel: type=1400 audit(1370831906.218:10): apparmor="STATUS" operation="profile_load" name="/usr/lib/apache2/mpm-prefork/apache2//phpsysinfo" pid=828 comm="apparmor_parser"
Jun 10 10:38:35 openSUSE.site kernel: type=1400 audit(1370831906.223:11): apparmor="STATUS" operation="profile_load" name="/usr/lib/dovecot/deliver" pid=832 comm="apparmor_parser"
Jun 10 10:38:35 openSUSE.site systemd-logind[940]: Watching system buttons on /dev/input/event7 (Power Button)
Jun 10 10:38:35 openSUSE.site systemd-logind[940]: Watching system buttons on /dev/input/event9 (Video Bus)
Jun 10 10:38:35 openSUSE.site vboxdrv[952]: Starting VirtualBox kernel modules..done
Jun 10 10:38:35 openSUSE.site systemd-logind[940]: Watching system buttons on /dev/input/event8 (Video Bus)
Jun 10 10:38:35 openSUSE.site systemd-logind[940]: Watching system buttons on /dev/input/event4 (Power Button)
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Jun 10 10:38:35 openSUSE.site systemd-logind[940]: Watching system buttons on /dev/input/event6 (Lid Switch)
Jun 10 10:38:35 openSUSE.site systemd-logind[940]: Watching system buttons on /dev/input/event5 (Sleep Button)
Jun 10 10:38:35 openSUSE.site kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jun 10 10:38:35 openSUSE.site kernel: Bluetooth: BNEP filters: protocol multicast
Jun 10 10:38:35 openSUSE.site kernel: Bluetooth: BNEP socket layer initialized
Jun 10 10:38:35 openSUSE.site kernel: vboxdrv: Found 4 processor cores.
Jun 10 10:38:35 openSUSE.site kernel: vboxdrv: fAsync=0 offMin=0x141 offMax=0xae3
Jun 10 10:38:35 openSUSE.site kernel: vboxdrv: TSC mode is 'synchronous', kernel timer mode is 'normal'.
Jun 10 10:38:35 openSUSE.site kernel: vboxdrv: Successfully loaded version 4.2.6_OSE (interface 0x001a0004).
Jun 10 10:38:35 openSUSE.site kernel: vboxpci: IOMMU not found (not registered)
Jun 10 10:38:35 openSUSE.site kernel: Bluetooth: RFCOMM TTY layer initialized
Jun 10 10:38:35 openSUSE.site kernel: Bluetooth: RFCOMM socket layer initialized
Jun 10 10:38:35 openSUSE.site kernel: Bluetooth: RFCOMM ver 1.11
Jun 10 10:38:35 openSUSE.site bluetoothd[933]: bluetoothd[933]: Adapter /org/bluez/933/hci0 has been enabled
Jun 10 10:38:35 openSUSE.site bluetoothd[933]: Adapter /org/bluez/933/hci0 has been enabled
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: <info> trying to start the modem manager...
Jun 10 10:38:35 openSUSE.site dbus[956]: [system] Activating service name='org.freedesktop.ModemManager' (using servicehelper)
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating service name='org.freedesktop.ModemManager' (using servicehelper)
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  ModemManager (version 0.6.0.0) starting...
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  ModemManager (version 0.6.0.0) starting...
Jun 10 10:38:35 openSUSE.site NetworkManager[962]: <info> monitoring kernel firmware directory '/lib/firmware'.
Jun 10 10:38:35 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.ModemManager'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'AnyData'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Option'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Novatel'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'MotoC'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Huawei'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Linktop'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'X22X'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Wavecom'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Longcheer'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Sierra'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Gobi'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Nokia'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Samsung'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Ericsson MBM'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Option High-Speed'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'ZTE'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'SimTech'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Cinterion'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Iridium'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Loaded plugin 'Generic'
Jun 10 10:38:35 openSUSE.site modem-manager[1018]: <info>  Successfully loaded 20 plugins
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.ModemManager'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'AnyData'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Option'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Novatel'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'MotoC'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Huawei'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Linktop'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'X22X'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Wavecom'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Longcheer'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Sierra'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Gobi'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Nokia'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Samsung'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Ericsson MBM'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Option High-Speed'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'ZTE'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'SimTech'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Cinterion'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Iridium'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Loaded plugin 'Generic'
Jun 10 10:38:35 openSUSE.site dbus-daemon[956]: modem-manager[1018]: <info>  Successfully loaded 20 plugins
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> rfkill1: found WiFi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.0/0000:02:00.0/ieee80211/phy0/rfkill1) (driver iwlwifi)
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> WiFi enabled by radio killswitch; enabled by state file
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> WWAN enabled by radio killswitch; enabled by state file
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> WiMAX enabled by radio killswitch; enabled by state file
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> Networking is enabled by state file
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> (wlan0): using nl80211 for WiFi device control
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <warn> (wlan0): driver supports Access Point (AP) mode
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> (wlan0): new 802.11 WiFi device (driver: 'iwlwifi' ifindex: 2)
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> (wlan0): exported as /org/freedesktop/NetworkManager/Devices/0
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> (wlan0): now managed
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> (wlan0): bringing up device.
Jun 10 10:38:36 openSUSE.site systemd[1]: Started Network Manager.
Jun 10 10:38:36 openSUSE.site systemd[1]: Starting Network Manager Wait Online...
Jun 10 10:38:36 openSUSE.site kernel: iwlwifi 0000:02:00.0: L1 Enabled; Disabling L0S
Jun 10 10:38:36 openSUSE.site kernel: iwlwifi 0000:02:00.0: Radio type=0x2-0x0-0x0
Jun 10 10:38:36 openSUSE.site systemd[1]: Started Network Manager Wait Online.
Jun 10 10:38:36 openSUSE.site systemd[1]: Starting Network.
Jun 10 10:38:36 openSUSE.site systemd[1]: Reached target Network.
Jun 10 10:38:36 openSUSE.site systemd[1]: Starting Command Scheduler...
Jun 10 10:38:36 openSUSE.site systemd[1]: Started Command Scheduler.
Jun 10 10:38:36 openSUSE.site systemd[1]: Starting Vsftpd ftp daemon...
Jun 10 10:38:36 openSUSE.site systemd[1]: Started Vsftpd ftp daemon.
Jun 10 10:38:36 openSUSE.site systemd[1]: Starting OpenSSH Daemon...
Jun 10 10:38:36 openSUSE.site systemd[1]: Starting /etc/init.d/boot.local Compatibility...
Jun 10 10:38:36 openSUSE.site systemd[1]: Starting Host and Network Name Lookups.
Jun 10 10:38:36 openSUSE.site systemd[1]: Reached target Host and Network Name Lookups.
Jun 10 10:38:36 openSUSE.site systemd[1]: Starting Remote File Systems (Pre).
Jun 10 10:38:36 openSUSE.site systemd[1]: Reached target Remote File Systems (Pre).
Jun 10 10:38:36 openSUSE.site systemd[1]: Starting LSB: Network time protocol daemon (ntpd)...
Jun 10 10:38:36 openSUSE.site systemd[1]: Started OpenSSH Daemon.
Jun 10 10:38:36 openSUSE.site systemd[1]: Started /etc/init.d/boot.local Compatibility.
Jun 10 10:38:36 openSUSE.site /usr/sbin/cron[1023]: (CRON) INFO (running with inotify support)
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> (wlan0): preparing device.
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> (wlan0): deactivating device (reason 'managed') [2]
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <warn> /sys/devices/virtual/net/lo: couldn't determine device driver; ignoring...
Jun 10 10:38:36 openSUSE.site dbus[956]: [system] Activating service name='fi.w1.wpa_supplicant1' (using servicehelper)
Jun 10 10:38:36 openSUSE.site sshd[1036]: Server listening on 0.0.0.0 port 22.
Jun 10 10:38:36 openSUSE.site sshd[1036]: Server listening on :: port 22.
Jun 10 10:38:36 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating service name='fi.w1.wpa_supplicant1' (using servicehelper)
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> modem-manager is now available
Jun 10 10:38:36 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Jun 10 10:38:36 openSUSE.site dbus[956]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> wpa_supplicant started
Jun 10 10:38:36 openSUSE.site kernel: IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jun 10 10:38:36 openSUSE.site kernel: NET: Registered protocol family 17
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> (wlan0) supports 5 scan SSIDs
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: starting -> ready
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: unavailable -> disconnected (reason 'supplicant-available') [20 30 42]
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <warn> Trying to remove a non-existant call id.
Jun 10 10:38:36 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: ready -> inactive
Jun 10 10:39:27 openSUSE.site login[944]: FAILED LOGIN 1 FROM tty1 FOR root, Authentication failure
Jun 10 10:39:27 openSUSE.site systemd-journal[271]: Forwarding to syslog missed 114 messages.
Jun 10 10:39:31 openSUSE.site login[944]: gkr-pam: error looking up user information
Jun 10 10:39:32 openSUSE.site ntp[1029]: 10 Jun 10:39:32 sntp[1067]: Started sntp
Jun 10 10:39:32 openSUSE.site ntp[1029]: 10 Jun 10:39:32 sntp[1067]: Error looking up time.nist.gov: System error
Jun 10 10:39:32 openSUSE.site ntp[1029]: Unable to resolve hostname(s)
Jun 10 10:39:32 openSUSE.site ntp[1029]: Time could not be synchronized
Jun 10 10:39:32 openSUSE.site ntpd[1075]: ntpd 4.2.6p5@1.2349-o Fri Mar  1 11:32:34 UTC 2013 (1)
Jun 10 10:39:32 openSUSE.site ntpd[1076]: proto: precision = 0.182 usec
Jun 10 10:39:32 openSUSE.site ntpd[1076]: ntp_io: estimated max descriptors: 1024, initial socket boundary: 16
Jun 10 10:39:32 openSUSE.site ntpd[1076]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Jun 10 10:39:32 openSUSE.site ntpd[1076]: Listen and drop on 1 v6wildcard :: UDP 123
Jun 10 10:39:32 openSUSE.site ntpd[1076]: Listen normally on 2 lo 127.0.0.1 UDP 123
Jun 10 10:39:32 openSUSE.site ntpd[1076]: Listen normally on 3 lo ::1 UDP 123
Jun 10 10:39:32 openSUSE.site ntpd[1076]: peers refreshed
Jun 10 10:39:32 openSUSE.site ntpd[1076]: Listening on routing socket on fd #20 for interface updates
Jun 10 10:39:32 openSUSE.site ntp[1029]: Starting network time protocol daemon (NTPD)..done
Jun 10 10:39:32 openSUSE.site systemd[1]: Started LSB: Network time protocol daemon (ntpd).
Jun 10 10:39:32 openSUSE.site systemd[1]: Starting System Time Synchronized.
Jun 10 10:39:32 openSUSE.site systemd[1]: Reached target System Time Synchronized.
Jun 10 10:39:32 openSUSE.site systemd[1]: Starting LSB: Starts and stops the Xen management daemon...
Jun 10 10:39:32 openSUSE.site systemd[1]: Starting LSB: X Display Manager...
Jun 10 10:39:32 openSUSE.site systemd[1]: Starting A tool for securing communications between a client and a DNS resolver....
Jun 10 10:39:32 openSUSE.site xend[1077]: xend ..unused
Jun 10 10:39:32 openSUSE.site systemd[1]: Started LSB: Starts and stops the Xen management daemon.
Jun 10 10:39:32 openSUSE.site systemd[1]: dnscrypt-proxy.service: Supervising process 1102 which is not our child. We'll most likely not notice when it exits.
Jun 10 10:39:32 openSUSE.site systemd[1]: Started A tool for securing communications between a client and a DNS resolver..
Jun 10 10:39:32 openSUSE.site systemd[1]: Starting LSB: Starts and stops Xen VMs...
Jun 10 10:39:32 openSUSE.site xendomains[1103]: xendomains ..unused
Jun 10 10:39:32 openSUSE.site systemd[1]: Started LSB: Starts and stops Xen VMs.
Jun 10 10:39:32 openSUSE.site systemd[1]: Starting Multi-User.
Jun 10 10:39:32 openSUSE.site systemd[1]: Reached target Multi-User.
Jun 10 10:39:32 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Rejected send message, 1 matched rules; type="method_call", sender=":1.10" (uid=0 pid=1113 comm="/usr/sbin/gdm ") interface="org.freedesktop.DBus.Properties" member="GetAll" error name="(unset)" requested_reply="0" destination=":1.11" (uid=0 pid=1115 comm="/usr/lib/gdm/gdm-simple-slave --display-id /org/gn")
Jun 10 10:39:32 openSUSE.site dbus[956]: [system] Rejected send message, 1 matched rules; type="method_call", sender=":1.10" (uid=0 pid=1113 comm="/usr/sbin/gdm ") interface="org.freedesktop.DBus.Properties" member="GetAll" error name="(unset)" requested_reply="0" destination=":1.11" (uid=0 pid=1115 comm="/usr/lib/gdm/gdm-simple-slave --display-id /org/gn")
Jun 10 10:39:32 openSUSE.site acpid[951]: client connected from 1120[0:0]
Jun 10 10:39:32 openSUSE.site acpid[951]: 1 client rule loaded
Jun 10 10:39:32 openSUSE.site kernel: nouveau W  PGRAPH][0000:01:00.0] disabled, PGRAPH=1 to enable
Jun 10 10:39:32 openSUSE.site xdm[1079]: Starting service gdm..done
Jun 10 10:39:32 openSUSE.site systemd[1]: Started LSB: X Display Manager.
Jun 10 10:39:32 openSUSE.site systemd[1]: Starting Graphical Interface.
Jun 10 10:39:32 openSUSE.site systemd[1]: Reached target Graphical Interface.
Jun 10 10:39:32 openSUSE.site systemd[1]: Starting Stop Read-Ahead Data Collection 10s After Completed Startup.
Jun 10 10:39:32 openSUSE.site systemd[1]: Started Stop Read-Ahead Data Collection 10s After Completed Startup.
Jun 10 10:39:32 openSUSE.site systemd[1]: Starting Update UTMP about System Runlevel Changes...
Jun 10 10:39:32 openSUSE.site systemd[1]: Started Update UTMP about System Runlevel Changes.
Jun 10 10:39:32 openSUSE.site systemd[1]: Startup finished in 5s 528ms 457us (kernel) + 1min 15s 628ms 727us (userspace) = 1min 21s 157ms 184us.
Jun 10 10:39:33 openSUSE.site gdm-simple-slave[1115]: WARNING: Failed to give slave programs access to the display. Trying to proceed.
Jun 10 10:39:33 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service'
Jun 10 10:39:33 openSUSE.site dbus[956]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service'
Jun 10 10:39:33 openSUSE.site systemd[1]: Starting Accounts Service...
Jun 10 10:39:33 openSUSE.site accounts-daemon[1147]: started daemon version 0.6.30
Jun 10 10:39:33 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.Accounts'
Jun 10 10:39:33 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.Accounts'
Jun 10 10:39:33 openSUSE.site systemd[1]: Started Accounts Service.
Jun 10 10:39:33 openSUSE.site accounts-daemon[1147]: (accounts-daemon:1147): GLib-GObject-WARNING **: g_object_notify: object class `User' has no property named `x-session'
Jun 10 10:39:33 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating via systemd: service name='org.freedesktop.ConsoleKit' unit='console-kit-daemon.service'
Jun 10 10:39:33 openSUSE.site dbus[956]: [system] Activating via systemd: service name='org.freedesktop.ConsoleKit' unit='console-kit-daemon.service'
Jun 10 10:39:33 openSUSE.site systemd[1]: Starting Console Manager...
Jun 10 10:39:33 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.ConsoleKit'
Jun 10 10:39:33 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.ConsoleKit'
Jun 10 10:39:33 openSUSE.site systemd[1]: Started Console Manager.
Jun 10 10:39:33 openSUSE.site systemd-logind[940]: New session 1 of user gdm.
Jun 10 10:39:33 openSUSE.site systemd-logind[940]: Linked /tmp/.X11-unix/X0 to /run/user/124/X11-display.
Jun 10 10:39:33 openSUSE.site gdm-launch-environment][1145]: GLib-CRITICAL: g_variant_compare: assertion `!g_variant_is_container (a)' failed
Jun 10 10:39:34 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service'
Jun 10 10:39:34 openSUSE.site dbus[956]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service'
Jun 10 10:39:34 openSUSE.site systemd[1]: Starting Daemon for power management...
Jun 10 10:39:34 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.UPower'
Jun 10 10:39:34 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.UPower'
Jun 10 10:39:34 openSUSE.site systemd[1]: Started Daemon for power management.
Jun 10 10:39:35 openSUSE.site kernel: EXT4-fs (sda9): re-mounted. Opts: acl,user_xattr,commit=600
Jun 10 10:39:35 openSUSE.site kernel: EXT4-fs (sda10): re-mounted. Opts: acl,user_xattr,commit=600
Jun 10 10:39:35 openSUSE.site pulseaudio[1311]: [pulseaudio] authkey.c: Failed to open cookie file '/var/lib/gdm/.config/pulse/cookie': No such file or directory
Jun 10 10:39:35 openSUSE.site pulseaudio[1311]: [pulseaudio] authkey.c: Failed to load authorization key '/var/lib/gdm/.config/pulse/cookie': No such file or directory
Jun 10 10:39:35 openSUSE.site dbus[956]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service'
Jun 10 10:39:35 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service'
Jun 10 10:39:35 openSUSE.site systemd[1]: Starting RealtimeKit Scheduling Policy Service...
Jun 10 10:39:35 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
Jun 10 10:39:35 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
Jun 10 10:39:35 openSUSE.site rtkit-daemon[1315]: Successfully called chroot.
Jun 10 10:39:35 openSUSE.site rtkit-daemon[1315]: Successfully dropped privileges.
Jun 10 10:39:35 openSUSE.site rtkit-daemon[1315]: Successfully limited resources.
Jun 10 10:39:35 openSUSE.site rtkit-daemon[1315]: Running.
Jun 10 10:39:35 openSUSE.site rtkit-daemon[1315]: Watchdog thread running.
Jun 10 10:39:35 openSUSE.site rtkit-daemon[1315]: Canary thread running.
Jun 10 10:39:35 openSUSE.site systemd[1]: Started RealtimeKit Scheduling Policy Service.
Jun 10 10:39:35 openSUSE.site rtkit-daemon[1315]: Successfully made thread 1314 of process 1314 (/usr/bin/pulseaudio) owned by '124' high priority at nice level -11.
Jun 10 10:39:35 openSUSE.site rtkit-daemon[1315]: Supervising 1 threads of 1 processes of 1 users.
Jun 10 10:39:36 openSUSE.site bluetoothd[933]: bluetoothd[933]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/HFPAG
Jun 10 10:39:36 openSUSE.site bluetoothd[933]: bluetoothd[933]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/HFPHS
Jun 10 10:39:36 openSUSE.site bluetoothd[933]: bluetoothd[933]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource
Jun 10 10:39:36 openSUSE.site bluetoothd[933]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/HFPAG
Jun 10 10:39:36 openSUSE.site bluetoothd[933]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/HFPHS
Jun 10 10:39:36 openSUSE.site bluetoothd[933]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource
Jun 10 10:39:36 openSUSE.site pulseaudio[1314]: [pulseaudio] bluetooth-util.c: org.bluez.HandsfreeGateway.GetProperties() failed: org.freedesktop.DBus.Error.UnknownMethod: Method "GetProperties" with signature "" on interface "org.bluez.HandsfreeGateway" doesn't exist
Jun 10 10:39:36 openSUSE.site pulseaudio[1314]: [pulseaudio] bluetooth-util.c: org.bluez.AudioSource.GetProperties() failed: org.freedesktop.DBus.Error.UnknownMethod: Method "GetProperties" with signature "" on interface "org.bluez.AudioSource" doesn't exist
Jun 10 10:39:36 openSUSE.site pulseaudio[1314]: [pulseaudio] authkey.c: Failed to open cookie file '/var/lib/gdm/.config/pulse/cookie': No such file or directory
Jun 10 10:39:36 openSUSE.site pulseaudio[1314]: [pulseaudio] authkey.c: Failed to load authorization key '/var/lib/gdm/.config/pulse/cookie': No such file or directory
Jun 10 10:39:36 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Jun 10 10:39:36 openSUSE.site dbus[956]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Jun 10 10:39:36 openSUSE.site systemd[1]: Starting Disk Manager...
Jun 10 10:39:36 openSUSE.site udisksd[1339]: udisks daemon version 2.0.0 starting
Jun 10 10:39:36 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Jun 10 10:39:36 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Jun 10 10:39:36 openSUSE.site udisksd[1339]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jun 10 10:39:36 openSUSE.site systemd[1]: Started Disk Manager.
Jun 10 10:39:37 openSUSE.site polkitd[1011]: Registered Authentication Agent for unix-session:1 (system bus name :1.37 [gnome-shell --mode=gdm], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Jun 10 10:39:37 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.37" (uid=124 pid=1324 comm="gnome-shell --mode=gdm ") interface="org.freedesktop.DBus.Properties" member="GetAll" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1150 comm="/usr/sbin/console-kit-daemon --no-daemon ")
Jun 10 10:39:37 openSUSE.site dbus[956]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.37" (uid=124 pid=1324 comm="gnome-shell --mode=gdm ") interface="org.freedesktop.DBus.Properties" member="GetAll" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1150 comm="/usr/sbin/console-kit-daemon --no-daemon ")
Jun 10 10:39:42 openSUSE.site systemd[1]: Starting Stop Read-Ahead Data Collection...
Jun 10 10:39:42 openSUSE.site systemd[1]: Started Stop Read-Ahead Data Collection.
Jun 10 10:40:04 openSUSE.site systemd-logind[940]: New session 2 of user zhxt.
Jun 10 10:40:04 openSUSE.site systemd-logind[940]: Linked /tmp/.X11-unix/X0 to /run/user/1000/X11-display.
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> Auto-activating connection 'TP-LINK_7AC772'.
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) starting connection 'TP-LINK_7AC772'
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: prepare -> config (reason 'none') [40 50 0]
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> Activation (wlan0/wireless): access point 'TP-LINK_7AC772' has security, but secrets are required.
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: config -> need-auth (reason 'none') [50 60 0]
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <warn> No agents were available for this request.
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: need-auth -> failed (reason 'no-secrets') [60 120 7]
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> Marking connection 'TP-LINK_7AC772' invalid.
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <warn> Activation (wlan0) failed for connection 'TP-LINK_7AC772'
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: failed -> disconnected (reason 'none') [120 30 0]
Jun 10 10:40:04 openSUSE.site NetworkManager[962]: <info> (wlan0): deactivating device (reason 'none') [0]
Jun 10 10:40:04 openSUSE.site gnome-session[1215]: WARNING: Detected that screensaver has left the bus
Jun 10 10:40:04 openSUSE.site gnome-session[1215]: CRITICAL: gsm_manager_set_phase: assertion `GSM_IS_MANAGER (manager)' failed
Jun 10 10:40:04 openSUSE.site polkitd[1011]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.37, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Jun 10 10:40:04 openSUSE.site gdm-simple-slave[1115]: WARNING: Failed to remove slave program access to the display. Trying to proceed.
Jun 10 10:40:04 openSUSE.site gdm-simple-slave[1115]: WARNING: Child process -1215 was already dead.
Jun 10 10:40:06 openSUSE.site checkproc[1470]: checkproc: can not get session id for process 1488!
Jun 10 10:40:06 openSUSE.site systemd[1]: Mounting FUSE Control File System...
Jun 10 10:40:06 openSUSE.site systemd[1]: Mounted FUSE Control File System.
Jun 10 10:40:07 openSUSE.site kernel: fuse init (API version 7.20)
Jun 10 10:40:16 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.46" (uid=1000 pid=1556 comm="kdeinit4: kded4 [kdeinit]                       ") interface="org.freedesktop.login1.Manager" member="CanHybridSleep" error name="(unset)" requested_reply="0" destination="org.freedesktop.login1" (uid=0 pid=940 comm="/usr/lib/systemd/systemd-logind ")
Jun 10 10:40:16 openSUSE.site dbus[956]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.46" (uid=1000 pid=1556 comm="kdeinit4: kded4 [kdeinit]                       ") interface="org.freedesktop.login1.Manager" member="CanHybridSleep" error name="(unset)" requested_reply="0" destination="org.freedesktop.login1" (uid=0 pid=940 comm="/usr/lib/systemd/systemd-logind ")
Jun 10 10:40:23 openSUSE.site kernel: EXT4-fs (sda9): re-mounted. Opts: acl,user_xattr,commit=0
Jun 10 10:40:24 openSUSE.site bluetoothd[933]: bluetoothd[933]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/HFPAG
Jun 10 10:40:24 openSUSE.site bluetoothd[933]: bluetoothd[933]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/HFPHS
Jun 10 10:40:24 openSUSE.site bluetoothd[933]: bluetoothd[933]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource
Jun 10 10:40:24 openSUSE.site bluetoothd[933]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/HFPAG
Jun 10 10:40:24 openSUSE.site bluetoothd[933]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/HFPHS
Jun 10 10:40:24 openSUSE.site bluetoothd[933]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource
Jun 10 10:40:24 openSUSE.site systemd-logind[940]: Removed session 1.
Jun 10 10:40:24 openSUSE.site kernel: EXT4-fs (sda10): re-mounted. Opts: acl,user_xattr,commit=0
Jun 10 10:40:24 openSUSE.site systemd[1]: getty@tty1.service holdoff time over, scheduling restart.
Jun 10 10:40:24 openSUSE.site systemd[1]: Stopping Getty on tty1...
Jun 10 10:40:24 openSUSE.site systemd[1]: Starting Getty on tty1...
Jun 10 10:40:24 openSUSE.site systemd[1]: Started Getty on tty1.
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Auto-activating connection 'TP-LINK_7AC772'.
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) starting connection 'TP-LINK_7AC772'
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: prepare -> config (reason 'none') [40 50 0]
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Activation (wlan0/wireless): access point 'TP-LINK_7AC772' has security, but secrets are required.
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: config -> need-auth (reason 'none') [50 60 0]
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: need-auth -> prepare (reason 'none') [60 40 0]
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Activation (wlan0/wireless): connection 'TP-LINK_7AC772' has security, and secrets exist.  No new secrets needed.
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Config: added 'ssid' value 'TP-LINK_7AC772'
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Config: added 'scan_ssid' value '1'
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Config: added 'key_mgmt' value 'WPA-PSK'
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Config: added 'psk' value '<omitted>'
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> Config: set interface ap_scan to 1
Jun 10 10:40:25 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: inactive -> scanning
Jun 10 10:40:26 openSUSE.site kernel: wlan0: authenticate with 40:16:9f:7a:c7:72
Jun 10 10:40:26 openSUSE.site kernel: wlan0: send auth to 40:16:9f:7a:c7:72 (try 1/3)
Jun 10 10:40:26 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: scanning -> authenticating
Jun 10 10:40:26 openSUSE.site kernel: wlan0: authenticated
Jun 10 10:40:26 openSUSE.site kernel: wlan0: associate with 40:16:9f:7a:c7:72 (try 1/3)
Jun 10 10:40:26 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: authenticating -> associating
Jun 10 10:40:26 openSUSE.site kernel: wlan0: RX AssocResp from 40:16:9f:7a:c7:72 (capab=0x431 status=0 aid=1)
Jun 10 10:40:26 openSUSE.site kernel: wlan0: associated
Jun 10 10:40:26 openSUSE.site kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Jun 10 10:40:26 openSUSE.site kernel: cfg80211: Calling CRDA for country: US
Jun 10 10:40:26 openSUSE.site kernel: cfg80211: Regulatory domain changed to country: US
Jun 10 10:40:26 openSUSE.site kernel: cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jun 10 10:40:26 openSUSE.site kernel: cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
Jun 10 10:40:26 openSUSE.site kernel: cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
Jun 10 10:40:26 openSUSE.site kernel: cfg80211:   (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:40:26 openSUSE.site kernel: cfg80211:   (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:40:26 openSUSE.site kernel: cfg80211:   (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:40:26 openSUSE.site kernel: cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
Jun 10 10:40:26 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: associating -> associated
Jun 10 10:40:26 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: associated -> 4-way handshake
Jun 10 10:40:26 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: 4-way handshake -> completed
Jun 10 10:40:26 openSUSE.site NetworkManager[962]: <info> Activation (wlan0/wireless) Stage 2 of 5 (Device Configure) successful.  Connected to wireless network 'TP-LINK_7AC772'.
Jun 10 10:40:26 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) scheduled.
Jun 10 10:40:26 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) started...
Jun 10 10:40:26 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: config -> ip-config (reason 'none') [50 70 0]
Jun 10 10:40:26 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Beginning DHCPv4 transaction (timeout in 45 seconds)
Jun 10 10:40:26 openSUSE.site NetworkManager[962]: <info> dhclient started with pid 1664
Jun 10 10:40:26 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) complete.
Jun 10 10:40:26 openSUSE.site dhclient[1664]: Internet Systems Consortium DHCP Client 4.2.5-P1
Jun 10 10:40:26 openSUSE.site dhclient[1664]: Copyright 2004-2013 Internet Systems Consortium.
Jun 10 10:40:26 openSUSE.site dhclient[1664]: All rights reserved.
Jun 10 10:40:26 openSUSE.site dhclient[1664]: For info, please visit https://www.isc.org/software/dhcp/
Jun 10 10:40:26 openSUSE.site NetworkManager[962]: <info> (wlan0): DHCPv4 state changed nbi -> preinit
Jun 10 10:40:26 openSUSE.site dhclient[1664]: Listening on LPF/wlan0/68:5d:43:f8:1f:1f
Jun 10 10:40:26 openSUSE.site dhclient[1664]: Sending on   LPF/wlan0/68:5d:43:f8:1f:1f
Jun 10 10:40:26 openSUSE.site dhclient[1664]: Sending on   Socket/fallback
Jun 10 10:40:26 openSUSE.site dhclient[1664]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 5
Jun 10 10:40:26 openSUSE.site dhclient[1664]: DHCPOFFER from 192.168.1.1
Jun 10 10:40:27 openSUSE.site avahi-daemon[938]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::6a5d:43ff:fef8:1f1f.
Jun 10 10:40:27 openSUSE.site avahi-daemon[938]: New relevant interface wlan0.IPv6 for mDNS.
Jun 10 10:40:27 openSUSE.site avahi-daemon[938]: Registering new address record for fe80::6a5d:43ff:fef8:1f1f on wlan0.*.
Jun 10 10:40:27 openSUSE.site rtkit-daemon[1315]: Successfully made thread 1682 of process 1682 (/usr/bin/pulseaudio) owned by '1000' high priority at nice level -11.
Jun 10 10:40:27 openSUSE.site rtkit-daemon[1315]: Supervising 1 threads of 1 processes of 1 users.
Jun 10 10:40:27 openSUSE.site bluetoothd[933]: bluetoothd[933]: Endpoint registered: sender=:1.67 path=/MediaEndpoint/HFPAG
Jun 10 10:40:27 openSUSE.site bluetoothd[933]: bluetoothd[933]: Endpoint registered: sender=:1.67 path=/MediaEndpoint/HFPHS
Jun 10 10:40:27 openSUSE.site bluetoothd[933]: bluetoothd[933]: Endpoint registered: sender=:1.67 path=/MediaEndpoint/A2DPSource
Jun 10 10:40:27 openSUSE.site bluetoothd[933]: Endpoint registered: sender=:1.67 path=/MediaEndpoint/HFPAG
Jun 10 10:40:27 openSUSE.site bluetoothd[933]: Endpoint registered: sender=:1.67 path=/MediaEndpoint/HFPHS
Jun 10 10:40:27 openSUSE.site bluetoothd[933]: Endpoint registered: sender=:1.67 path=/MediaEndpoint/A2DPSource
Jun 10 10:40:27 openSUSE.site pulseaudio[1682]: [pulseaudio] bluetooth-util.c: org.bluez.HandsfreeGateway.GetProperties() failed: org.freedesktop.DBus.Error.UnknownMethod: Method "GetProperties" with signature "" on interface "org.bluez.HandsfreeGateway" doesn't exist
Jun 10 10:40:27 openSUSE.site pulseaudio[1682]: [pulseaudio] bluetooth-util.c: org.bluez.AudioSource.GetProperties() failed: org.freedesktop.DBus.Error.UnknownMethod: Method "GetProperties" with signature "" on interface "org.bluez.AudioSource" doesn't exist
Jun 10 10:40:28 openSUSE.site rtkit-daemon[1315]: Successfully made thread 1707 of process 1707 (/usr/bin/pulseaudio) owned by '1000' high priority at nice level -11.
Jun 10 10:40:28 openSUSE.site rtkit-daemon[1315]: Supervising 4 threads of 2 processes of 1 users.
Jun 10 10:40:28 openSUSE.site pulseaudio[1707]: [pulseaudio] pid.c: Daemon already running.
Jun 10 10:40:29 openSUSE.site rtkit-daemon[1315]: Successfully made thread 1717 of process 1717 (/usr/bin/pulseaudio) owned by '1000' high priority at nice level -11.
Jun 10 10:40:29 openSUSE.site rtkit-daemon[1315]: Supervising 4 threads of 2 processes of 1 users.
Jun 10 10:40:29 openSUSE.site pulseaudio[1717]: [pulseaudio] pid.c: Daemon already running.
Jun 10 10:40:31 openSUSE.site dhclient[1664]: DHCPREQUEST on wlan0 to 255.255.255.255 port 67
Jun 10 10:40:31 openSUSE.site dhclient[1664]: DHCPACK from 192.168.1.1
Jun 10 10:40:31 openSUSE.site dhclient[1664]: bound to 192.168.1.103 -- renewal in 2869 seconds.
Jun 10 10:40:31 openSUSE.site NetworkManager[962]: <info> (wlan0): DHCPv4 state changed preinit -> bound
Jun 10 10:40:31 openSUSE.site NetworkManager[962]: <info>   address 192.168.1.103
Jun 10 10:40:31 openSUSE.site NetworkManager[962]: <info>   prefix 24 (255.255.255.0)
Jun 10 10:40:31 openSUSE.site NetworkManager[962]: <info>   gateway 192.168.1.1
Jun 10 10:40:31 openSUSE.site NetworkManager[962]: <info>   nameserver '219.239.26.42'
Jun 10 10:40:31 openSUSE.site NetworkManager[962]: <info>   nameserver '124.207.160.106'
Jun 10 10:40:31 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
Jun 10 10:40:31 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) started...
Jun 10 10:40:31 openSUSE.site avahi-daemon[938]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.103.
Jun 10 10:40:32 openSUSE.site avahi-daemon[938]: New relevant interface wlan0.IPv4 for mDNS.
Jun 10 10:40:32 openSUSE.site avahi-daemon[938]: Registering new address record for 192.168.1.103 on wlan0.IPv4.
Jun 10 10:40:32 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: ip-config -> activated (reason 'none') [70 100 0]
Jun 10 10:40:33 openSUSE.site NetworkManager[962]: <info> Clearing nscd hosts cache.
Jun 10 10:40:33 openSUSE.site NetworkManager[962]: <info> Policy set 'TP-LINK_7AC772' (wlan0) as default for IPv4 routing and DNS.
Jun 10 10:40:33 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) successful, device activated.
Jun 10 10:40:33 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) complete.
Jun 10 10:40:33 openSUSE.site dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 10:40:33 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 10:40:33 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 10:40:33 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 10:40:33 openSUSE.site nm-dispatcher.action[1781]: Script '/etc/NetworkManager/dispatcher.d/nfs' exited with error status 2.
Jun 10 10:40:39 openSUSE.site systemd[1]: Starting CUPS Printing Service...
Jun 10 10:40:39 openSUSE.site systemd[1]: Started CUPS Printing Service.
Jun 10 10:40:39 openSUSE.site cupsd[1891]: No limit for Validate-Job defined in policy allowallforanybody and no suitable template found.
Jun 10 10:40:39 openSUSE.site cupsd[1891]: No limit for Cancel-Jobs defined in policy allowallforanybody and no suitable template found.
Jun 10 10:40:39 openSUSE.site cupsd[1891]: No limit for Cancel-My-Jobs defined in policy allowallforanybody and no suitable template found.
Jun 10 10:40:39 openSUSE.site cupsd[1891]: No limit for Close-Job defined in policy allowallforanybody and no suitable template found.
Jun 10 10:40:39 openSUSE.site cupsd[1891]: No limit for CUPS-Get-Document defined in policy allowallforanybody and no suitable template found.
Jun 10 10:40:39 openSUSE.site cupsd[1891]: No JobPrivateAccess defined in policy allowallforanybody - using defaults.
Jun 10 10:40:39 openSUSE.site cupsd[1891]: No JobPrivateValues defined in policy allowallforanybody - using defaults.
Jun 10 10:40:39 openSUSE.site cupsd[1891]: No SubscriptionPrivateAccess defined in policy allowallforanybody - using defaults.
Jun 10 10:40:39 openSUSE.site cupsd[1891]: No SubscriptionPrivateValues defined in policy allowallforanybody - using defaults.
Jun 10 10:40:54 openSUSE.site polkitd[1011]: Registered Authentication Agent for unix-session:2 (system bus name :1.77 [/usr/lib64/kde4/libexec/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.utf8)
Jun 10 10:42:05 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: activated -> disconnected (reason 'user-requested') [100 30 39]
Jun 10 10:42:05 openSUSE.site NetworkManager[962]: <info> (wlan0): deactivating device (reason 'user-requested') [39]
Jun 10 10:42:05 openSUSE.site NetworkManager[962]: <info> (wlan0): canceled DHCP transaction, DHCP client pid 1664
Jun 10 10:42:05 openSUSE.site kernel: wlan0: deauthenticating from 40:16:9f:7a:c7:72 by local choice (reason=3)
Jun 10 10:42:05 openSUSE.site kernel: cfg80211: Calling CRDA to update world regulatory domain
Jun 10 10:42:05 openSUSE.site avahi-daemon[938]: Withdrawing address record for 192.168.1.103 on wlan0.
Jun 10 10:42:05 openSUSE.site avahi-daemon[938]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.103.
Jun 10 10:42:05 openSUSE.site avahi-daemon[938]: Interface wlan0.IPv4 no longer relevant for mDNS.
Jun 10 10:42:05 openSUSE.site NetworkManager[962]: <info> Clearing nscd hosts cache.
Jun 10 10:42:05 openSUSE.site kernel: cfg80211: World regulatory domain updated:
Jun 10 10:42:05 openSUSE.site kernel: cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jun 10 10:42:05 openSUSE.site kernel: cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:42:05 openSUSE.site kernel: cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:42:05 openSUSE.site kernel: cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:42:05 openSUSE.site kernel: cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:42:05 openSUSE.site kernel: cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:42:05 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: completed -> disconnected
Jun 10 10:42:05 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 10:42:05 openSUSE.site dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 10:42:05 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 10:42:05 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 10:42:06 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating service name='org.freedesktop.PackageKit' (using servicehelper)
Jun 10 10:42:06 openSUSE.site dbus[956]: [system] Activating service name='org.freedesktop.PackageKit' (using servicehelper)
Jun 10 10:42:09 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Jun 10 10:42:09 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) starting connection 'TP-LINK_7AC772'
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: prepare -> config (reason 'none') [40 50 0]
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> Activation (wlan0/wireless): access point 'TP-LINK_7AC772' has security, but secrets are required.
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: config -> need-auth (reason 'none') [50 60 0]
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: need-auth -> prepare (reason 'none') [60 40 0]
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> Activation (wlan0/wireless): connection 'TP-LINK_7AC772' has security, and secrets exist.  No new secrets needed.
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> Config: added 'ssid' value 'TP-LINK_7AC772'
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> Config: added 'scan_ssid' value '1'
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> Config: added 'key_mgmt' value 'WPA-PSK'
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> Config: added 'psk' value '<omitted>'
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> Config: set interface ap_scan to 1
Jun 10 10:42:09 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: disconnected -> scanning
Jun 10 10:42:10 openSUSE.site kernel: wlan0: authenticate with 40:16:9f:7a:c7:72
Jun 10 10:42:10 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: scanning -> authenticating
Jun 10 10:42:10 openSUSE.site kernel: wlan0: send auth to 40:16:9f:7a:c7:72 (try 1/3)
Jun 10 10:42:10 openSUSE.site kernel: wlan0: authenticated
Jun 10 10:42:10 openSUSE.site kernel: wlan0: associate with 40:16:9f:7a:c7:72 (try 1/3)
Jun 10 10:42:10 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: authenticating -> associating
Jun 10 10:42:10 openSUSE.site kernel: wlan0: RX AssocResp from 40:16:9f:7a:c7:72 (capab=0x431 status=0 aid=1)
Jun 10 10:42:10 openSUSE.site kernel: wlan0: associated
Jun 10 10:42:10 openSUSE.site kernel: cfg80211: Calling CRDA for country: US
Jun 10 10:42:10 openSUSE.site kernel: cfg80211: Regulatory domain changed to country: US
Jun 10 10:42:10 openSUSE.site kernel: cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jun 10 10:42:10 openSUSE.site kernel: cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
Jun 10 10:42:10 openSUSE.site kernel: cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
Jun 10 10:42:10 openSUSE.site kernel: cfg80211:   (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:42:10 openSUSE.site kernel: cfg80211:   (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:42:10 openSUSE.site kernel: cfg80211:   (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jun 10 10:42:10 openSUSE.site kernel: cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
Jun 10 10:42:10 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: associating -> associated
Jun 10 10:42:10 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: associated -> 4-way handshake
Jun 10 10:42:10 openSUSE.site NetworkManager[962]: <info> (wlan0): supplicant interface state: 4-way handshake -> completed
Jun 10 10:42:10 openSUSE.site NetworkManager[962]: <info> Activation (wlan0/wireless) Stage 2 of 5 (Device Configure) successful.  Connected to wireless network 'TP-LINK_7AC772'.
Jun 10 10:42:10 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) scheduled.
Jun 10 10:42:10 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) started...
Jun 10 10:42:10 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: config -> ip-config (reason 'none') [50 70 0]
Jun 10 10:42:10 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Beginning DHCPv4 transaction (timeout in 45 seconds)
Jun 10 10:42:10 openSUSE.site NetworkManager[962]: <info> dhclient started with pid 2184
Jun 10 10:42:10 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) complete.
Jun 10 10:42:10 openSUSE.site dhclient[2184]: Internet Systems Consortium DHCP Client 4.2.5-P1
Jun 10 10:42:10 openSUSE.site dhclient[2184]: Copyright 2004-2013 Internet Systems Consortium.
Jun 10 10:42:10 openSUSE.site dhclient[2184]: All rights reserved.
Jun 10 10:42:10 openSUSE.site dhclient[2184]: For info, please visit https://www.isc.org/software/dhcp/
Jun 10 10:42:10 openSUSE.site NetworkManager[962]: <info> (wlan0): DHCPv4 state changed nbi -> preinit
Jun 10 10:42:10 openSUSE.site dhclient[2184]: Listening on LPF/wlan0/68:5d:43:f8:1f:1f
Jun 10 10:42:10 openSUSE.site dhclient[2184]: Sending on   LPF/wlan0/68:5d:43:f8:1f:1f
Jun 10 10:42:10 openSUSE.site dhclient[2184]: Sending on   Socket/fallback
Jun 10 10:42:10 openSUSE.site dhclient[2184]: DHCPREQUEST on wlan0 to 255.255.255.255 port 67
Jun 10 10:42:14 openSUSE.site dhclient[2184]: DHCPREQUEST on wlan0 to 255.255.255.255 port 67
Jun 10 10:42:14 openSUSE.site dhclient[2184]: DHCPACK from 192.168.1.1
Jun 10 10:42:14 openSUSE.site dhclient[2184]: bound to 192.168.1.103 -- renewal in 3000 seconds.
Jun 10 10:42:14 openSUSE.site NetworkManager[962]: <info> (wlan0): DHCPv4 state changed preinit -> reboot
Jun 10 10:42:14 openSUSE.site NetworkManager[962]: <info>   address 192.168.1.103
Jun 10 10:42:14 openSUSE.site NetworkManager[962]: <info>   prefix 24 (255.255.255.0)
Jun 10 10:42:14 openSUSE.site NetworkManager[962]: <info>   gateway 192.168.1.1
Jun 10 10:42:14 openSUSE.site NetworkManager[962]: <info>   nameserver '219.239.26.42'
Jun 10 10:42:14 openSUSE.site NetworkManager[962]: <info>   nameserver '124.207.160.106'
Jun 10 10:42:14 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
Jun 10 10:42:14 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) started...
Jun 10 10:42:14 openSUSE.site avahi-daemon[938]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.103.
Jun 10 10:42:14 openSUSE.site avahi-daemon[938]: New relevant interface wlan0.IPv4 for mDNS.
Jun 10 10:42:14 openSUSE.site avahi-daemon[938]: Registering new address record for 192.168.1.103 on wlan0.IPv4.
Jun 10 10:42:15 openSUSE.site NetworkManager[962]: <info> (wlan0): device state change: ip-config -> activated (reason 'none') [70 100 0]
Jun 10 10:42:15 openSUSE.site NetworkManager[962]: <info> Clearing nscd hosts cache.
Jun 10 10:42:15 openSUSE.site NetworkManager[962]: <info> Policy set 'TP-LINK_7AC772' (wlan0) as default for IPv4 routing and DNS.
Jun 10 10:42:15 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) successful, device activated.
Jun 10 10:42:15 openSUSE.site NetworkManager[962]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) complete.
Jun 10 10:42:15 openSUSE.site nm-dispatcher.action[2059]: Script '/etc/NetworkManager/dispatcher.d/nfs' exited with error status 2.
Jun 10 10:53:11 openSUSE.site systemd[1]: Starting Cleanup of Temporary Directories...
Jun 10 10:53:12 openSUSE.site systemd-tmpfiles[2776]: stat(/run/user/1000/gvfs) failed: Permission denied
Jun 10 10:53:14 openSUSE.site systemd[1]: Started Cleanup of Temporary Directories.
Jun 10 11:32:14 openSUSE.site dhclient[2184]: DHCPREQUEST on wlan0 to 192.168.1.1 port 67
Jun 10 11:32:14 openSUSE.site dhclient[2184]: DHCPACK from 192.168.1.1
Jun 10 11:32:14 openSUSE.site dhclient[2184]: bound to 192.168.1.103 -- renewal in 2964 seconds.
Jun 10 11:32:14 openSUSE.site NetworkManager[962]: <info> (wlan0): DHCPv4 state changed reboot -> renew
Jun 10 11:32:14 openSUSE.site NetworkManager[962]: <info>   address 192.168.1.103
Jun 10 11:32:14 openSUSE.site NetworkManager[962]: <info>   prefix 24 (255.255.255.0)
Jun 10 11:32:14 openSUSE.site NetworkManager[962]: <info>   gateway 192.168.1.1
Jun 10 11:32:14 openSUSE.site NetworkManager[962]: <info>   nameserver '219.239.26.42'
Jun 10 11:32:14 openSUSE.site NetworkManager[962]: <info>   nameserver '124.207.160.106'
Jun 10 11:32:14 openSUSE.site dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 11:32:14 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 11:32:14 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 11:32:14 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 12:20:40 openSUSE.site su[4046]: (to root) zhxt on /dev/pts/2
Jun 10 12:21:38 openSUSE.site dhclient[2184]: DHCPREQUEST on wlan0 to 192.168.1.1 port 67
Jun 10 12:21:39 openSUSE.site dhclient[2184]: DHCPACK from 192.168.1.1
Jun 10 12:21:39 openSUSE.site dhclient[2184]: bound to 192.168.1.103 -- renewal in 3222 seconds.
Jun 10 12:21:39 openSUSE.site NetworkManager[962]: <info> (wlan0): DHCPv4 state changed renew -> renew
Jun 10 12:21:39 openSUSE.site NetworkManager[962]: <info>   address 192.168.1.103
Jun 10 12:21:39 openSUSE.site NetworkManager[962]: <info>   prefix 24 (255.255.255.0)
Jun 10 12:21:39 openSUSE.site NetworkManager[962]: <info>   gateway 192.168.1.1
Jun 10 12:21:39 openSUSE.site NetworkManager[962]: <info>   nameserver '219.239.26.42'
Jun 10 12:21:39 openSUSE.site NetworkManager[962]: <info>   nameserver '124.207.160.106'
Jun 10 12:21:39 openSUSE.site dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 12:21:39 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 12:21:39 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 12:21:39 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 12:30:08 openSUSE.site kernel: warning: `VirtualBox' uses 32-bit capabilities (legacy support in use)
Jun 10 12:30:20 openSUSE.site kernel: EXT4-fs (sda10): Unaligned AIO/DIO on inode 3556985 by AioMgr0-N; performance will be poor.
Jun 10 13:15:21 openSUSE.site dhclient[2184]: DHCPREQUEST on wlan0 to 192.168.1.1 port 67
Jun 10 13:15:21 openSUSE.site dhclient[2184]: DHCPACK from 192.168.1.1
Jun 10 13:15:21 openSUSE.site dhclient[2184]: bound to 192.168.1.103 -- renewal in 3006 seconds.
Jun 10 13:15:21 openSUSE.site NetworkManager[962]: <info> (wlan0): DHCPv4 state changed renew -> renew
Jun 10 13:15:21 openSUSE.site NetworkManager[962]: <info>   address 192.168.1.103
Jun 10 13:15:21 openSUSE.site NetworkManager[962]: <info>   prefix 24 (255.255.255.0)
Jun 10 13:15:21 openSUSE.site NetworkManager[962]: <info>   gateway 192.168.1.1
Jun 10 13:15:21 openSUSE.site NetworkManager[962]: <info>   nameserver '219.239.26.42'
Jun 10 13:15:21 openSUSE.site NetworkManager[962]: <info>   nameserver '124.207.160.106'
Jun 10 13:15:21 openSUSE.site dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 13:15:21 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 13:15:21 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 13:15:21 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 14:05:27 openSUSE.site dhclient[2184]: DHCPREQUEST on wlan0 to 192.168.1.1 port 67
Jun 10 14:05:27 openSUSE.site dhclient[2184]: DHCPACK from 192.168.1.1
Jun 10 14:05:27 openSUSE.site dhclient[2184]: bound to 192.168.1.103 -- renewal in 3124 seconds.
Jun 10 14:05:27 openSUSE.site NetworkManager[962]: <info> (wlan0): DHCPv4 state changed renew -> renew
Jun 10 14:05:27 openSUSE.site NetworkManager[962]: <info>   address 192.168.1.103
Jun 10 14:05:27 openSUSE.site NetworkManager[962]: <info>   prefix 24 (255.255.255.0)
Jun 10 14:05:27 openSUSE.site NetworkManager[962]: <info>   gateway 192.168.1.1
Jun 10 14:05:27 openSUSE.site NetworkManager[962]: <info>   nameserver '219.239.26.42'
Jun 10 14:05:27 openSUSE.site NetworkManager[962]: <info>   nameserver '124.207.160.106'
Jun 10 14:05:27 openSUSE.site dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 14:05:27 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 14:05:28 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 14:05:28 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 14:27:04 openSUSE.site su[6044]: (to root) zhxt on /dev/pts/2
Jun 10 14:29:20 openSUSE.site avahi-daemon[938]: Invalid legacy unicast query packet.
Jun 10 14:29:20 openSUSE.site avahi-daemon[938]: Received response from host 192.168.1.103 with invalid source port 34516 on interface 'wlan0.0'
Jun 10 14:29:21 openSUSE.site avahi-daemon[938]: Invalid legacy unicast query packet.
Jun 10 14:29:21 openSUSE.site avahi-daemon[938]: Received response from host 192.168.1.103 with invalid source port 34516 on interface 'wlan0.0'
Jun 10 14:29:22 openSUSE.site avahi-daemon[938]: Invalid legacy unicast query packet.
Jun 10 14:29:22 openSUSE.site avahi-daemon[938]: Received response from host 192.168.1.103 with invalid source port 34516 on interface 'wlan0.0'
Jun 10 14:29:23 openSUSE.site avahi-daemon[938]: Received response from host 192.168.1.103 with invalid source port 34516 on interface 'wlan0.0'
Jun 10 14:29:24 openSUSE.site avahi-daemon[938]: Received response from host 192.168.1.103 with invalid source port 34516 on interface 'wlan0.0'
Jun 10 14:29:25 openSUSE.site avahi-daemon[938]: Received response from host 192.168.1.103 with invalid source port 34516 on interface 'wlan0.0'
Jun 10 14:57:31 openSUSE.site dhclient[2184]: DHCPREQUEST on wlan0 to 192.168.1.1 port 67
Jun 10 14:57:31 openSUSE.site dhclient[2184]: DHCPACK from 192.168.1.1
Jun 10 14:57:31 openSUSE.site NetworkManager[962]: <info> (wlan0): DHCPv4 state changed renew -> renew
Jun 10 14:57:31 openSUSE.site NetworkManager[962]: <info>   address 192.168.1.103
Jun 10 14:57:31 openSUSE.site NetworkManager[962]: <info>   prefix 24 (255.255.255.0)
Jun 10 14:57:31 openSUSE.site NetworkManager[962]: <info>   gateway 192.168.1.1
Jun 10 14:57:31 openSUSE.site NetworkManager[962]: <info>   nameserver '219.239.26.42'
Jun 10 14:57:31 openSUSE.site NetworkManager[962]: <info>   nameserver '124.207.160.106'
Jun 10 14:57:31 openSUSE.site dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 14:57:31 openSUSE.site dhclient[2184]: bound to 192.168.1.103 -- renewal in 3168 seconds.
Jun 10 14:57:31 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 14:57:31 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 14:57:31 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 15:50:19 openSUSE.site dhclient[2184]: DHCPREQUEST on wlan0 to 192.168.1.1 port 67
Jun 10 15:50:19 openSUSE.site dhclient[2184]: DHCPACK from 192.168.1.1
Jun 10 15:50:19 openSUSE.site dhclient[2184]: bound to 192.168.1.103 -- renewal in 3500 seconds.
Jun 10 15:50:19 openSUSE.site NetworkManager[962]: <info> (wlan0): DHCPv4 state changed renew -> renew
Jun 10 15:50:19 openSUSE.site NetworkManager[962]: <info>   address 192.168.1.103
Jun 10 15:50:19 openSUSE.site NetworkManager[962]: <info>   prefix 24 (255.255.255.0)
Jun 10 15:50:19 openSUSE.site NetworkManager[962]: <info>   gateway 192.168.1.1
Jun 10 15:50:19 openSUSE.site NetworkManager[962]: <info>   nameserver '219.239.26.42'
Jun 10 15:50:19 openSUSE.site NetworkManager[962]: <info>   nameserver '124.207.160.106'
Jun 10 15:50:19 openSUSE.site dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 15:50:19 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 15:50:19 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 15:50:19 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 16:40:31 openSUSE.site su[8372]: (to root) zhxt on /dev/pts/3
Jun 10 16:48:19 openSUSE.site avahi-daemon[938]: Invalid legacy unicast query packet.
Jun 10 16:48:19 openSUSE.site avahi-daemon[938]: Received response from host 192.168.1.103 with invalid source port 48214 on interface 'wlan0.0'
Jun 10 16:48:20 openSUSE.site avahi-daemon[938]: Received response from host 192.168.1.103 with invalid source port 48214 on interface 'wlan0.0'
Jun 10 16:48:20 openSUSE.site avahi-daemon[938]: Invalid legacy unicast query packet.
Jun 10 16:48:21 openSUSE.site avahi-daemon[938]: Invalid legacy unicast query packet.
Jun 10 16:48:21 openSUSE.site avahi-daemon[938]: Received response from host 192.168.1.103 with invalid source port 48214 on interface 'wlan0.0'
Jun 10 16:48:22 openSUSE.site avahi-daemon[938]: Received response from host 192.168.1.103 with invalid source port 48214 on interface 'wlan0.0'
Jun 10 16:48:23 openSUSE.site avahi-daemon[938]: Received response from host 192.168.1.103 with invalid source port 48214 on interface 'wlan0.0'
Jun 10 16:48:24 openSUSE.site avahi-daemon[938]: Received response from host 192.168.1.103 with invalid source port 48214 on interface 'wlan0.0'
Jun 10 16:48:39 openSUSE.site dhclient[2184]: DHCPREQUEST on wlan0 to 192.168.1.1 port 67
Jun 10 16:48:39 openSUSE.site dhclient[2184]: DHCPACK from 192.168.1.1
Jun 10 16:48:40 openSUSE.site dhclient[2184]: bound to 192.168.1.103 -- renewal in 2863 seconds.
Jun 10 16:48:40 openSUSE.site NetworkManager[962]: <info> (wlan0): DHCPv4 state changed renew -> renew
Jun 10 16:48:40 openSUSE.site NetworkManager[962]: <info>   address 192.168.1.103
Jun 10 16:48:40 openSUSE.site NetworkManager[962]: <info>   prefix 24 (255.255.255.0)
Jun 10 16:48:40 openSUSE.site NetworkManager[962]: <info>   gateway 192.168.1.1
Jun 10 16:48:40 openSUSE.site NetworkManager[962]: <info>   nameserver '219.239.26.42'
Jun 10 16:48:40 openSUSE.site NetworkManager[962]: <info>   nameserver '124.207.160.106'
Jun 10 16:48:40 openSUSE.site dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 16:48:40 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 16:48:40 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 16:48:40 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 17:25:54 openSUSE.site gnome-keyring-daemon[9417]: Gkm: using old keyring directory: /home/zhxt/.gnome2/keyrings
Jun 10 17:25:55 openSUSE.site gnome-keyring-daemon[9417]: couldn't set environment variable in session: The name org.gnome.SessionManager was not provided by any .service files
Jun 10 17:25:55 openSUSE.site gnome-keyring-daemon[9417]: keyring alias directory: /home/zhxt/.gnome2/keyrings
Jun 10 17:36:23 openSUSE.site dhclient[2184]: DHCPREQUEST on wlan0 to 192.168.1.1 port 67
Jun 10 17:36:23 openSUSE.site dhclient[2184]: DHCPACK from 192.168.1.1
Jun 10 17:36:23 openSUSE.site NetworkManager[962]: <info> (wlan0): DHCPv4 state changed renew -> renew
Jun 10 17:36:23 openSUSE.site NetworkManager[962]: <info>   address 192.168.1.103
Jun 10 17:36:23 openSUSE.site NetworkManager[962]: <info>   prefix 24 (255.255.255.0)
Jun 10 17:36:23 openSUSE.site NetworkManager[962]: <info>   gateway 192.168.1.1
Jun 10 17:36:23 openSUSE.site NetworkManager[962]: <info>   nameserver '219.239.26.42'
Jun 10 17:36:23 openSUSE.site NetworkManager[962]: <info>   nameserver '124.207.160.106'
Jun 10 17:36:23 openSUSE.site dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 17:36:23 openSUSE.site dhclient[2184]: bound to 192.168.1.103 -- renewal in 2810 seconds.
Jun 10 17:36:23 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 17:36:24 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 17:36:24 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 17:45:53 openSUSE.site sudo[9853]: zhxt : TTY=pts/3 ; PWD=/home/zhxt ; USER=root ; COMMAND=/usr/bin/journalctl --since today
Jun 10 17:47:15 openSUSE.site sudo[9874]: zhxt : TTY=pts/3 ; PWD=/home/zhxt ; USER=root ; COMMAND=/usr/bin/journalctl --since today
Jun 10 17:49:28 openSUSE.site sudo[9938]: zhxt : TTY=pts/3 ; PWD=/home/zhxt ; USER=root ; COMMAND=/usr/bin/journalctl --since today
Jun 10 17:49:44 openSUSE.site sudo[9963]: zhxt : TTY=pts/3 ; PWD=/home/zhxt ; USER=root ; COMMAND=/usr/bin/journalctl --since yestoday
Jun 10 17:50:16 openSUSE.site sudo[9991]: zhxt : TTY=pts/3 ; PWD=/home/zhxt ; USER=root ; COMMAND=/usr/bin/journalctl --since yesterday
Jun 10 17:55:55 openSUSE.site sudo[10098]: zhxt : TTY=pts/3 ; PWD=/home/zhxt ; USER=root ; COMMAND=/usr/bin/journalctl --since 2013-05-30 08:00:00
Jun 10 17:56:00 openSUSE.site sudo[10120]: zhxt : TTY=pts/3 ; PWD=/home/zhxt ; USER=root ; COMMAND=/usr/bin/journalctl --since 2013-05-30 8:00:00
Jun 10 17:56:08 openSUSE.site sudo[10124]: zhxt : TTY=pts/3 ; PWD=/home/zhxt ; USER=root ; COMMAND=/usr/bin/journalctl --since 2013-05-30 8:00:00
Jun 10 18:23:13 openSUSE.site dhclient[2184]: DHCPREQUEST on wlan0 to 192.168.1.1 port 67
Jun 10 18:23:13 openSUSE.site dhclient[2184]: DHCPACK from 192.168.1.1
Jun 10 18:23:13 openSUSE.site NetworkManager[962]: <info> (wlan0): DHCPv4 state changed renew -> renew
Jun 10 18:23:13 openSUSE.site NetworkManager[962]: <info>   address 192.168.1.103
Jun 10 18:23:13 openSUSE.site NetworkManager[962]: <info>   prefix 24 (255.255.255.0)
Jun 10 18:23:13 openSUSE.site NetworkManager[962]: <info>   gateway 192.168.1.1
Jun 10 18:23:13 openSUSE.site NetworkManager[962]: <info>   nameserver '219.239.26.42'
Jun 10 18:23:13 openSUSE.site NetworkManager[962]: <info>   nameserver '124.207.160.106'
Jun 10 18:23:13 openSUSE.site dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 18:23:13 openSUSE.site dhclient[2184]: bound to 192.168.1.103 -- renewal in 2935 seconds.
Jun 10 18:23:13 openSUSE.site dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 18:23:14 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun 10 18:23:14 openSUSE.site dbus-daemon[956]: dbus[956]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 18:55:13 openSUSE.site sudo[10909]: zhxt : TTY=pts/3 ; PWD=/home/zhxt ; USER=root ; COMMAND=/usr/bin/journalctl --since yesterday
Jun 09 19:31:03 openSUSE.site systemd-journal[257]: Allowing runtime journal files to grow to 292.0M.
Jun 09 19:31:03 openSUSE.site kernel: Initializing cgroup subsys cpuset
这个记录是从上电开始么?
到这里应该是登录了。
Jun 09 19:33:39 openSUSE.site dbus-daemon[948]: dbus[948]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.46" (uid=1000 pid=1538 comm="kdeinit4: kded4 [kdeinit]                       ") interface="org.freedesktop.login1.Manager" member="CanHybridSleep" error name="(unset)" requested_reply="0" destination="org.freedesktop.login1" (uid=0 pid=928 comm="/usr/lib/systemd/systemd-logind ")
Jun 09 19:33:39 openSUSE.site dbus[948]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.46" (uid=1000 pid=1538 comm="kdeinit4: kded4 [kdeinit]                       ") interface="org.freedesktop.login1.Manager" member="CanHybridSleep" error name="(unset)" requested_reply="0" destination="org.freedesktop.login1" (uid=0 pid=928 comm="/usr/lib/systemd/systemd-logind ")
这里应该是关机开始:
Jun 09 23:45:52 openSUSE.site polkitd[999]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.71, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.utf8)
Jun 09 23:45:55 openSUSE.site systemd-logind[928]: System is powering down.
关机结束:
Jun 09 23:47:30 openSUSE.site systemd[1]: Shutting down.
Jun 09 23:47:30 openSUSE.site systemd-journal[257]: Journal stopped
这个时间不准吧? 感觉比这个长多了!
这样:
sudo Xorg -configure
然后打开 /etc/X11/xorg.conf,把里面带 Intel 的那个 Device 部分抄出来,然后再把它删掉。
我拿那个部分给你改下。
亲,你不能贴 log 让我给你看。
是你从 log 里找到卡顿的位置,我大概告诉你那个时候它在干嘛。
Fatal server error:
Server is already active for display 0
        If this server is no longer running, remove /tmp/.X0-lock
        and start again.
(EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
(EE)
生成失败,我要删掉 /tmp/.X0-lock,重新执行一次么?
额。:stuck_out_tongue: 好吧。这个我后面慢慢找。以后开机和关机时我留意下大概停在哪里,然后再去对照着看。
> sudo Xorg :1 -configure
X.Org X Server 1.13.2
Release Date: 2013-01-24
X Protocol Version 11, Revision 0
Build Operating System: openSUSE SUSE LINUX
Current Operating System: Linux openSUSE.site 3.7.10-1.11-desktop #1 SMP PREEMPT Thu May 16 20:27:27 UTC 2013 (adf31bb) x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.7.10-1.11-desktop root=UUID=935330e8-5e6d-4d93-959b-ea4162b6c2f4 video=1600x900 resume=/dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part8 splash=silent quiet showopts
Build Date: 30 April 2013  08:24:17AM
Current version of pixman: 0.28.2
        Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.1.log", Time: Mon Jun 10 21:44:31 2013
setversion 1.4 failed
List of video drivers:
        v4l
        chips
        i128
        nouveau
        tga
        mach64
        dummy
        ark
        vmware
        savage
        intel
        sis
        neomagic
        modesetting
        glint
        mga
        nv
        tdfx
        ast
        qxl
        ati
        cirrus
        sisusb
        radeon
        voodoo
        r128
        siliconmotion
        fbdev
        vesa
(++) Using config file: "/root/xorg.conf.new"
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Number of created screens does not match number of detected devices.
  Configuration failed.
Server terminated with error (2). Closing log file.
结尾处显示失败了。但还是在 /root 下找到了个 xorg.config:
Section "ServerLayout"
	Identifier     "X.org Configured"
	Screen      0  "Screen0" 0 0
	Screen      1  "Screen1" RightOf "Screen0"
	Screen      2  "Screen2" RightOf "Screen1"
	Screen      3  "Screen3" RightOf "Screen2"
	Screen      4  "Screen4" RightOf "Screen3"
	Screen      5  "Screen5" RightOf "Screen4"
	Screen      6  "Screen6" RightOf "Screen5"
	Screen      7  "Screen7" RightOf "Screen6"
	Screen      8  "Screen8" RightOf "Screen7"
	InputDevice    "Mouse0" "CorePointer"
	InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
	ModulePath   "/usr/lib64/xorg/modules/updates"
	ModulePath   "/usr/lib64/xorg/modules"
	FontPath     "/usr/share/fonts/misc:unscaled"
	FontPath     "/usr/share/fonts/Type1/"
	FontPath     "/usr/share/fonts/100dpi:unscaled"
	FontPath     "/usr/share/fonts/75dpi:unscaled"
	FontPath     "/usr/share/fonts/ghostscript/"
	FontPath     "/usr/share/fonts/cyrillic:unscaled"
	FontPath     "/usr/share/fonts/misc/sgi:unscaled"
	FontPath     "/usr/share/fonts/truetype/"
	FontPath     "built-ins"
EndSection
Section "Module"
	Load  "glx"
EndSection
Section "InputDevice"
	Identifier  "Keyboard0"
	Driver      "kbd"
EndSection
	Identifier  "Mouse0"
	Driver      "mouse"
	Option	    "Protocol" "auto"
	Option	    "Device" "/dev/input/mice"
	Option	    "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
	Identifier   "Monitor0"
	VendorName   "Monitor Vendor"
	ModelName    "Monitor Model"
EndSection
Section "Monitor"
	Identifier   "Monitor1"
EndSection
Section "Monitor"
	Identifier   "Monitor2"
EndSection
Section "Monitor"
	Identifier   "Monitor3"
EndSection
Section "Monitor"
	Identifier   "Monitor4"
EndSection
Section "Monitor"
	Identifier   "Monitor5"
EndSection
Section "Monitor"
	Identifier   "Monitor6"
EndSection
Section "Monitor"
	Identifier   "Monitor7"
EndSection
Section "Monitor"
	Identifier   "Monitor8"
EndSection
Section "Device"
        ### Available Driver options are:-
        ### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
        ### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
        ### <percent>: "<f>%"
        ### [arg]: arg optional
        #Option     "SWcursor"           	# <bool>]
        #Option     "HWcursor"           	# <bool>]
        #Option     "NoAccel"            	# <bool>]
        #Option     "ShadowFB"           	# <bool>]
        #Option     "VideoKey"           	# <i>
        #Option     "WrappedFB"          	# <bool>]
        #Option     "GLXVBlank"          	# <bool>]
        #Option     "ZaphodHeads"        	# <str>
        #Option     "PageFlip"           	# <bool>]
        #Option     "SwapLimit"          	# <i>
        #Option     "AsyncUTSDFS"        	# <bool>]
	Identifier  "Card0"
	Driver      "nouveau"
	BusID       "PCI:1:0:0"
EndSection
Section "Device"
        #Option     "AccelMethod"        	# <str>
        #Option     "Backlight"          	# <str>
        #Option     "DRI"                	# <str>
        #Option     "ColorKey"           	# <i>
        #Option     "Tiling"             	# <bool>]
        #Option     "LinearFramebuffer"  	# <bool>]
        #Option     "SwapbuffersWait"    	# <bool>]
        #Option     "TripleBuffer"       	# <bool>]
        #Option     "XvPreferOverlay"    	# <bool>]
        #Option     "HotPlug"            	# <bool>]
        #Option     "RelaxedFencing"     	# <bool>]
        #Option     "XvMC"               	# <bool>]
        #Option     "TearFree"           	# <bool>]
        #Option     "PerCrtcPixmaps"     	# <bool>]
        #Option     "FallbackDebug"      	# <bool>]
        #Option     "DebugFlushBatches"  	# <bool>]
        #Option     "DebugFlushCaches"   	# <bool>]
        #Option     "DebugWait"          	# <bool>]
        #Option     "BufferCache"        	# <bool>]
	Identifier  "Card1"
	Driver      "intel"
	BusID       "PCI:0:2:0"
EndSection
Section "Device"
        #Option     "kmsdev"             	# <str>
	Identifier  "Card2"
	Driver      "modesetting"
	BusID       "PCI:0:2:0"
EndSection
Section "Device"
	Identifier  "Card3"
	BusID       "PCI:1:0:0"
EndSection
Section "Device"
	Identifier  "Card4"
	Driver      "nouveau"
	BusID       "PCI:1:0:0"
EndSection
Section "Device"
        #Option     "Rotate"             	# <str>
        #Option     "fbdev"              	# <str>
        #Option     "debug"              	# <bool>]
	Identifier  "Card5"
	Driver      "fbdev"
	BusID       "PCI:0:2:0"
EndSection
Section "Device"
	Identifier  "Card6"
	Driver      "fbdev"
	BusID       "PCI:1:0:0"
EndSection
Section "Device"
        #Option     "DefaultRefresh"     	# <bool>]
        #Option     "ModeSetClearScreen" 	# <bool>]
	Identifier  "Card7"
	Driver      "vesa"
	BusID       "PCI:0:2:0"
EndSection
Section "Device"
	Identifier  "Card8"
	Driver      "vesa"
	BusID       "PCI:1:0:0"
EndSection
Section "Screen"
	Identifier "Screen0"
	Device     "Card0"
	Monitor    "Monitor0"
	SubSection "Display"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Section "Screen"
	Identifier "Screen1"
	Device     "Card1"
	Monitor    "Monitor1"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Section "Screen"
	Identifier "Screen2"
	Device     "Card2"
	Monitor    "Monitor2"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Section "Screen"
	Identifier "Screen3"
	Device     "Card3"
	Monitor    "Monitor3"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Section "Screen"
	Identifier "Screen4"
	Device     "Card4"
	Monitor    "Monitor4"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Section "Screen"
	Identifier "Screen5"
	Device     "Card5"
	Monitor    "Monitor5"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Section "Screen"
	Identifier "Screen6"
	Device     "Card6"
	Monitor    "Monitor6"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Section "Screen"
	Identifier "Screen7"
	Device     "Card7"
	Monitor    "Monitor7"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Section "Screen"
	Identifier "Screen8"
	Device     "Card8"
	Monitor    "Monitor8"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
好的,你可以把 root 下面 xorg 那一堆东西都删了。
Section "Device"
   Identifier  "Intel Graphics"
   Driver      "intel"
   BusID     "PCI:0:2:0"
   Option    "UseEDID" "False"
   Option    "IgnoreEDID" "1"
   Modes    "1600x900“
EndSection
放到 /etc/X11/xorg.conf.d/50-device.conf 里。
重开机试试看你的 modeline 还重复么。
复制了上面那段到 50-device.conf 里,修改了最后那个引号。重启,停在这个位置:
[ok] Reached target Multi–User.
[ok] Started LSB: X Display Manager.
然后就一直停在这里了。
    72.809]
    72.809] X Protocol Version 11, Revision 0
    72.809] Build Operating System: openSUSE SUSE LINUX
    72.809] Current Operating System: Linux openSUSE.site 3.7.10-1.11-desktop #1 SMP PREEMPT Thu May 16 20:27:27 UTC 2013 (adf31bb) x86_64
    72.809] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.7.10-1.11-desktop root=UUID=935330e8-5e6d-4d93-959b-ea4162b6c2f4 video=1600x900 resume=/dev/disk/by-id/ata-ST9750420AS_6WS1TZ7Q-part8 splash=silent quiet showopts
    72.809] Build Date: 30 April 2013  08:24:17AM
    72.809]
    72.809] Current version of pixman: 0.28.2
    72.809]    Before reporting problems, check http://wiki.x.org
    72.809] Markers: (--) probed, (**) from config file, (==) default setting,
    72.809] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jun 10 22:22:30 2013
    72.809] (==) Using config directory: "/etc/X11/xorg.conf.d"
    72.809] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
    72.817] Parse error on line 28 of section Device in file /etc/X11/xorg.conf.d/50-device.conf
        "Modes" is not a valid keyword in this section.
    72.817] (EE) Problem parsing the config file
    72.817] (EE) Error parsing the config file
    72.817]
Fatal server error:
    72.817] no screens found
    72.817] (EE)
 for help.
    72.817] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
    72.817] (EE)
    72.817] Server terminated with error (1). Closing log file.
要改 50-screen.conf ?
嗯,大概是,要改 [Monitor] 和 [Screen]
forums.fedoraforum.org/showthread.php?t=207228
Monitor 里的 HorizSync 和 VertRefresh 范围是从那里找到的?
xrandr -q:
~> xrandr -q
Screen 0: minimum 320 x 200, current 1600 x 900, maximum 8192 x 8192
LVDS1 connected 1600x900+0+0 (normal left inverted right x axis y axis) 309mm x 174mm
   1600x900       60.0*+   40.0
   1024x768       60.0
   800x600        60.3     56.2
   640x480        59.9
VGA1 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
DP1 disconnected (normal left inverted right x axis y axis)
gtf 1600 900 60:
 gtf 1600 900 60
  # 1600x900 @ 60.00 Hz (GTF) hsync: 55.92 kHz; pclk: 119.00 MHz
  Modeline "1600x900_60.00"  119.00  1600 1696 1864 2128  900 901 904 932  -HSync +Vsync
这里只有一个值 hsync: 55.92 kHz。
范围是自己任意写的么?
50-monitor.conf:
Section "Monitor"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       40.0 - 60.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
EndSection
50-screen.conf:
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
        Depth       24
    EndSubSection
EndSection
最终是这样,
> cat 50-device.conf.new2
# Having multiple "Device" sections is known to be problematic. Make
# sure you don't have in use another one laying around e.g. in another
# xorg.conf.d file or even a generic xorg.conf file. More details can
# be found in https://bugs.freedesktop.org/show_bug.cgi?id=32430.
#Section "Device"
#   Identifier "device0"
#   Driver     "nvidia"
#   VendorName  "Nvidia Corporation"
#   BusID       "PCI:1:0:0"
#   Screen      0
#  Identifier "Default Device"
#  #Driver "radeon"
#  ## Required magic for radeon/radeonhd drivers; output name
#  ## (here: "DVI-0") can be figured out via 'xrandr -q'
#  #Option "monitor-DVI-0" "Default Monitor"
#EndSection
Section "Device"
#   Identifier  "Intel Graphics"
   Driver      "intel"
   BusID     "PCI:0:2:0"
   Modes    "1600x900"
EndSection
> cat 50-screen.conf.new2
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 310.32  (buildmeister@swio-display-x86-rhel47-01)  Mon Jan 14 15:51:51 PST 2013
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
        Depth       24
    EndSubSection
EndSection
cat 50-monitor.conf.new2
Section "Monitor"
    ModelName      "Unknown"
    HorizSync       28.0 - 63.0
    Option         "DPMS"
EndSection
结果是仍然进不了图形,Xorg.0.log提示找不到Screen,但看了screen.conf,没觉得哪里不对。
