[已解决]iPhone通过usb分享的网络不能用
13.2 努力下装好了,当我插上5s的数据线,在手机上选择 “个人热点”“仅通过usb”后,
什么都没有发生,分享网络不可用
请问怎么解决
打开终端
sudo journalctl -f
插入设备,将新产生的输出全部复制贴上来。
查看网络连接管理器(nm-applet 等)中有无出现 ‘Ethernet Network (Apple iPhone)’ 一项。
!](http://images.tapatalk-cdn.com/15/08/23/f51f3180d85be48f1a6d3874dd1694c4.jpg)
!](http://images.tapatalk-cdn.com/15/08/23/1fd0e7d42677dbfa433d31c58466454a.jpg)
!](http://images.tapatalk-cdn.com/15/08/23/90b6450dc8f18fa87190f52bc11fd73e.jpg)
手机插上后就停在这里,在手机上关闭再打开个人热点都没有反应,网络管理里也没有出现有关手机的连接
电脑登不上论坛,不知道为什么密码不对,只能手机拍照出来了,希望能看的清
看看这一篇 能否帮到你: wiki.archlinux.org/index.php/IPhone_Tethering
  1. 安装 usbmuxd, libimobiledevice 和 ifuse
  2. 检测 ipheth 模块是否加载:
    lsmod | grep ipheth
journalctl -f 滚动输出系统日志。一般来说,插入 iPhone 时 usbmuxd 和 ipheth 模块都会有输出。
现在看一个正常的日志,注意 15:02:57 时 ipheth 模块发现新的网卡设备:
Aug 24 15:02:56 localhost kernel: usb 1-1: new high-speed USB device number 5 using ehci-pci
Aug 24 15:02:56 localhost kernel: usb 1-1: New USB device found, idVendor=05ac, idProduct=12ab
Aug 24 15:02:56 localhost kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 24 15:02:56 localhost kernel: usb 1-1: Product: iPad
Aug 24 15:02:56 localhost kernel: usb 1-1: Manufacturer: Apple Inc.
Aug 24 15:02:56 localhost kernel: usb 1-1: SerialNumber: blahblahblah
Aug 24 15:02:56 localhost mtp-probe[3085]: checking bus 1, device 5: "/sys/devices/pci0000:00/0000:00:12.2/usb1/1-1"
Aug 24 15:02:56 localhost mtp-probe[3085]: bus: 1, device: 5 was not an MTP device
Aug 24 15:02:56 localhost systemd-udevd[3084]: Process '/usr/bin/pkill -x -SIGUSR2 usbmux' failed with exit code 1.
Aug 24 15:02:56 localhost systemd[1]: Started iOS USB multiplexing daemon.
Aug 24 15:02:56 localhost org.gtk.Private.GPhoto2VolumeMonitor[1268]: (process:2649): GVFS-GPhoto2-WARNING **: device (null) has no BUSNUM property, ignoring
Aug 24 15:02:56 localhost usbmuxd[3089]: [15:02:56.884][3] usbmuxd v1.0.9 starting up
Aug 24 15:02:56 localhost usbmuxd[3089]: [15:02:56.886][3] Successfully dropped privileges to 'usbmux'
Aug 24 15:02:56 localhost usbmuxd[3089]: [15:02:56.896][3] Could not get old configuration descriptor for device 1-5: -5
Aug 24 15:02:57 localhost usbmuxd[3089]: [15:02:56.999][3] Connecting to new device on location 0x10005 as ID 1
Aug 24 15:02:57 localhost usbmuxd[3089]: [15:02:57.000][3] Initialization complete
Aug 24 15:02:57 localhost usbmuxd[3089]: [15:02:57.000][3] Connected to v2.0 device 1 on location 0x10005 with serial number 4dfed284d20d8f881f2f30b92572afb782b2877a
Aug 24 15:02:57 localhost kernel: ipheth 1-1:4.2: Apple iPhone USB Ethernet device attached
Aug 24 15:02:57 localhost kernel: ipheth 1-1:4.2 enx4e8d790569d7: renamed from eth1
Aug 24 15:02:57 localhost NetworkManager[578]: <info>  (enx4e8d790569d7): carrier is OFF
Aug 24 15:02:57 localhost NetworkManager[578]: <info>  (enx4e8d790569d7): new Ethernet device (driver: 'ipheth' ifindex: 6)
Aug 24 15:02:57 localhost NetworkManager[578]: <info>  (enx4e8d790569d7): exported as /org/freedesktop/NetworkManager/Devices/5
Aug 24 15:02:57 localhost NetworkManager[578]: <info>  (enx4e8d790569d7): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Aug 24 15:02:57 localhost NetworkManager[578]: <info>  (enx4e8d790569d7): preparing device
Aug 24 15:02:57 localhost NetworkManager[578]: <info>  keyfile: add connection in-memory (eb6b5f28-7662-4257-a2a4-4834332112c5,"Wired connection 2")
Aug 24 15:02:57 localhost NetworkManager[578]: <info>  (enx4e8d790569d7): created default wired connection 'Wired connection 2'
谢谢,我晚上回去再试试看
谢谢大神的指点,libimobiledevice原本就自带,我装了usbmuxd和ifuse后插上手机瞬间就ok了
