如题,之前从 42.2 升级到 42.3,然后 sudo zypper update 的时候出错了,如下:
( 1/1160) 正在安装:kernel-default-4.4.92-31.1.x86_64 ........................................................................................................................ 错误]
安装 kernel-default-4.4.92-31.1.x86_64 失败:
错误: Subprocess failed. Error: RPM 失败: error: rpmdb: Packages page 36838 is on free list with type 7
error: rpmdb: PANIC: Invalid argument
error: db4 error(-30974) from dbcursor->c_put: DB_RUNRECOVERY: Fatal error, run database recovery
error: error(-30974) adding header #17510 record
error: rpmdb: PANIC: fatal region error detected; run recovery
error: db4 error(-30974) from dbcursor->c_close: DB_RUNRECOVERY: Fatal error, run database recovery
error: db4 error(-30974) from db->sync: DB_RUNRECOVERY: Fatal error, run database recovery
error: kernel-default-4.4.92-31.1.x86_64: install failed
error: db4 error(-30974) from db->close: DB_RUNRECOVERY: Fatal error, run database recovery
error: rpmdb: File handles still open at environment close
error: rpmdb: Open file handle: /var/lib/rpm/Packages
error: rpmdb: Open file handle: /var/lib/rpm/Name
error: rpmdb: Open file handle: /var/lib/rpm/Basenames
error: rpmdb: Open file handle: /var/lib/rpm/Group
error: rpmdb: Open file handle: /var/lib/rpm/Requirename
error: rpmdb: Open file handle: /var/lib/rpm/Providename
error: rpmdb: Open file handle: /var/lib/rpm/Conflictname
error: rpmdb: Open file handle: /var/lib/rpm/Obsoletename
error: rpmdb: Open file handle: /var/lib/rpm/Triggername
error: rpmdb: Open file handle: /var/lib/rpm/Dirnames
error: rpmdb: Open file handle: /var/lib/rpm/Installtid
error: rpmdb: Open file handle: /var/lib/rpm/Sigmd5
error: rpmdb: Open file handle: /var/lib/rpm/Sha1header
error: db4 error(-30974) from dbenv->close: DB_RUNRECOVERY: Fatal error, run database recovery
中止、重试、还是忽略呢? [a/r/i] (a): a
安装 / 移除以下软件包期间或之后发生问题:
Installation aborted by user
请参考以上错误消息汲取灵感。
