我以前用过 COW 作为代理,当时用完全没有觉得有什么问题,关了代理以后用 wget 和 kget 也不会发生这样的情况。但是今天我用 kget 和 wget 都出现了无法下载的问题,但是 curl 却完全没问题。
Kget 是新建下载以后就不动,速度写着 Stalled。
wget 和 curl 的下载是这样的
➜ ~ wget http://m1.music.126.net/XZYjv5XrJNv8-e9uxKxybA\=\=/6645448279471808.mp3
--2015-04-13 00:15:58-- http://m1.music.126.net/XZYjv5XrJNv8-e9uxKxybA==/6645448279471808.mp3
Resolving 127.0.0.1 10101 (127.0.0.1 10101)... 127.0.0.1
Connecting to 127.0.0.1 10101 (127.0.0.1 10101)|127.0.0.1|:80... failed: Connection refused.
➜ ~ man curl
➜ ~ curl -O -L http://m1.music.126.net/XZYjv5XrJNv8-e9uxKxybA\=\=/6645448279471808.mp3
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 2071k 100 2071k 0 0 3526k 0 --:--:-- --:--:-- --:--:-- 3523k
这是 env 命令的输出
ALSA_CONFIG_PATH=/etc/alsa-pulse.conf
AUDIODRIVER=pulseaudio
COLORFGBG=15;0
COLORTERM=1
CONFIG_SITE=/usr/share/site/x86_64-unknown-linux-gnu
CPU=x86_64
CSHEDIT=emacs
CVS_RSH=ssh
DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-WsSIys5Hbv,guid=ee38c415f4a04f7310fd9c5b552a9275
DESKTOP_SESSION=openbox-kde
DISPLAY=:0
DM_CONTROL=/var/run/xdmctl
FROM_HEADER=
GOBIN=/home/lwhite/go/bin
GOOS=linux
GOPATH=/home/lwhite/go:/usr/share/go/contrib
GOROOT=/usr/lib64/go
GPG_AGENT_INFO=/tmp/gpg-Pxj9E2/S.gpg-agent:1320:1
GPG_TTY=/dev/pts/2
GS_LIB=/home/lwhite/.fonts
GTK2_RC_FILES=/etc/gtk-2.0/gtkrc:/home/lwhite/.gtkrc-2.0:/home/lwhite/.kde4/share/config/gtkrc-2.0
GTK3_IM_MODULE=fcitx
GTK_IM_MODULE=fcitx
GTK_MODULES=canberra-gtk-module
GTK_RC_FILES=/etc/gtk/gtkrc:/home/lwhite/.gtkrc:/home/lwhite/.kde4/share/config/gtkrc
G_BROKEN_FILENAMES=1
G_FILENAME_ENCODING=@locale,UTF-8,ISO-8859-15,CP1252
HISTSIZE=10000
HOME=/home/lwhite
HOST=linux-3ccl
HOSTNAME=linux-3ccl
HOSTTYPE=x86_64
INPUTRC=/home/lwhite/.inputrc
JAVA_BINDIR=/usr/java/latest/bin
JAVA_HOME=/usr/java/latest
JAVA_ROOT=/usr/java/latest
JDK_HOME=/usr/java/latest
JRE_HOME=/usr/lib64/jvm/jre
KDEWM=/usr/bin/openbox
KDE_FULL_SESSION=true
KDE_MULTIHEAD=false
KDE_SESSION_UID=1000
KDE_SESSION_VERSION=4
KONSOLE_DBUS_SERVICE=:1.51
KONSOLE_DBUS_SESSION=/Sessions/1
KONSOLE_DBUS_WINDOW=/Windows/1
KONSOLE_PROFILE_NAME=Shell
LANG=en_US.UTF-8
LANGUAGE=
LC_CTYPE=en_US.UTF-8
LESS=-R
LESSCLOSE=lessclose.sh %s %s
LESSKEY=/etc/lesskey.bin
LESSOPEN=lessopen.sh %s
LESS_ADVANCED_PREPROCESSOR=no
LOGNAME=lwhite
LSCOLORS=Gxfxcxdxbxegedabagacad
LS_COLORS=no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=41;33;01:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.tbz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.lzma=00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*.xz=00;31:*.avi=01;35:*.bmp=01;35:*.fli=01;35:*.gif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;35:*.mpg=01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;35:*.tga=01;35:*.tif=01;35:*.xbm=01;35:*.xpm=01;35:*.dl=01;35:*.gl=01;35:*.wmv=01;35:*.aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.ogg=00;32:*.voc=00;32:*.wav=00;32:
LS_OPTIONS=-N --color=tty -T 0
MACHTYPE=x86_64-suse-linux
MAIL=/var/spool/mail/lwhite
MANPATH=/usr/local/man:/usr/share/man
MINICOM=-c on
MORE=-sl
NNTPSERVER=news
OLDPWD=/home/lwhite
OSTYPE=linux
PAGER=less
PATH=/home/lwhite/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/games
PROFILEHOME=
PROFILEREAD=true
PWD=/home/lwhite
PYTHONSTARTUP=/etc/pythonstart
QEMU_AUDIO_DRV=pa
QT4_IM_MODULE=fcitx
QT_IM_MODULE=fcitx
QT_IM_SWITCHER=imsw-multi
QT_PLUGIN_PATH=/home/lwhite/.kde4/lib64/kde4/plugins/:/usr/lib64/kde4/plugins/
QT_SYSTEM_DIR=/usr/share/desktop-data
SDK_HOME=/usr/java/latest
SDL_AUDIODRIVER=pulse
SESSION_MANAGER=local/linux-3ccl:@/tmp/.ICE-unix/1398,unix/linux-3ccl:/tmp/.ICE-unix/1398
SHELL=/bin/zsh
SHELL_SESSION_ID=e1a3ea41f50f400086a04d0cdfa8846e
SHLVL=3
SSH_ASKPASS=/usr/lib/ssh/ksshaskpass
TERM=screen
TMPDIR=/tmp
TMUX=/tmp/tmux-1000/default,3395,1
TMUX_PANE=%1
USER=lwhite
USE_FAM=
WINDOWID=60817434
WINDOWMANAGER=/usr/bin/openbox-kde-session
WINDOWPATH=7
XAUTHLOCALHOSTNAME=linux-3ccl
XCURSOR_THEME=Oxygen_White
XDG_CONFIG_DIRS=/etc/xdg
XDG_CURRENT_DESKTOP=KDE
XDG_DATA_DIRS=/usr/share:/usr/share
XDG_MENU_PREFIX=kde-4-
XDG_RUNTIME_DIR=/run/user/1000
XDG_SEAT=seat0
XDG_SESSION_ID=1
XDG_VTNR=7
XDM_MANAGED=method=classic
XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB
XMODIFIERS=@im=fcitx
XNLSPATH=/usr/share/X11/nls
XSESSION_IS_UP=yes
ZSH=/home/lwhite/.oh-my-zsh
_=/usr/bin/env
里面连"proxy" 的词都没有。
/etc/wgetrc 整个都是注释。
然后我就不知道该在哪里找有代理设置的地方了。
