说说 Macbook Air 2015 安装 Leap 42.1 的情况
cpu:
                       Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz, 2425 MHz
                       Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz, 2080 MHz
                       Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz, 2119 MHz
                       Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz, 1620 MHz
keyboard:
                       Apple Internal Keyboard / Trackpad
  /dev/input/event6    Bluetooth Mouse M557
mouse:
  /dev/input/mice      Apple Internal Keyboard / Trackpad
monitor:
                       Apple Color LCD
graphics card:
                       Intel Broadwell-U Integrated Graphics
sound:
                       Intel Broadwell-U Audio Controller
                       Intel Wildcat Point-LP High Definition Audio Controller
storage:
                       Samsung Electronics SATA controller
network:
  eth1                 Broadcom BCM4360 802.11ac Wireless Network Adapter
network interface:
  lo                   Loopback network interface
  eth1                 Ethernet network interface
disk:
  /dev/sda             APPLE SSD SM0128
  /dev/sdb             SanDisk Ultra
  /dev/sdc             APPLE SD Card Reader
  /dev/sdd             Seagate Expansion
partition:
  /dev/sda1            Partition
  /dev/sda2            Partition
  /dev/sda3            Partition
  /dev/sda4            Partition
  /dev/sdb1            Partition
  /dev/sdb2            Partition
  /dev/sdd1            Partition
usb controller:
                       Intel Wildcat Point-LP USB xHCI Controller
bios:
                       BIOS
bridge:
                       Intel Broadwell-U Host Bridge -OPI
                       Intel Wildcat Point-LP PCI Express Root Port #1
                       Intel Wildcat Point-LP PCI Express Root Port #2
                       Intel Wildcat Point-LP PCI Express Root Port #3
                       Intel Wildcat Point-LP PCI Express Root Port #5
                       Intel Wildcat Point-LP PCI Express Root Port #6
                       Intel Wildcat Point-LP LPC Controller
                       Intel PCI bridge
                       Intel PCI bridge
                       Intel PCI bridge
                       Intel PCI bridge
                       Intel PCI bridge
                       Intel PCI bridge
hub:
                       Linux Foundation 2.0 root hub
                       Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth)
                       Linux Foundation 3.0 root hub
memory:
                       Main Memory
unknown:
                       FPU
                       DMA controller
                       PIC
                       Timer
                       Keyboard controller
  /dev/lp0             Parallel controller
                       PS/2 Controller
                       Intel Wildcat Point-LP Serial IO DMA Controller
                       Intel Wildcat Point-LP Serial IO GSPI Controller #1
                       Intel Wildcat Point-LP MEI Controller #1
                       Intel Wildcat Point-LP SMBus Controller
                       Intel Wildcat Point-LP Thermal Management Controller
                       Broadcom 720p FaceTime HD Camera
                       Intel System peripheral
                       Apple Bluetooth USB Host Controller
显卡 --Intel,爽
声音 – 没问题,未测试麦克风
Broadcom 无线网卡 --Packman 解决
杂牌 USB 有线网卡 – 没问题
内置读卡器 – 没问题
触摸板 – 不是每次都能按出右键菜单
键盘 – 有背景灯
雷电接口 – 没测试
蓝牙 – 可以连接鼠标,可以连接手机并用手机 4G 流量上网
赞,希望楼主进一步分享啊,用的42.1么
来自我的 CHM-CL00 上的 Tapatalk
是的,我的主力机,完全删除 Mac OS 装的稳定版。
补充一下,触摸板双手指同时按可以按出右键,但是经常按不出来。。。
蓝牙目前连鼠标正常,没连过别的设备。
嗯,以后在自己的 rmbp 上妆 opensuse 就请教你了。你折腾完了可以写篇教程分享给大家啊。 :1:
今天发现了一个很牛逼的功能!
手指在触摸板最右侧上下滑动,可以滚动页面!
支持这种高级功能是不是跟桌面系统有关?我目前在用 Cinnamon 桌面。
高级个毛线,我用过的桌面似乎没有不支持的。
你这个设置叫什么? 我要装一个。
2014 年 Mac pro ,安装了 suse leap 42.1,yast2 里面也加入 packman 的社区源,但是显卡驱动怎么都驱动不上。求安装方法啊!!!!!
