询问一下关于台式机 n 卡驱动的问题
首先说明:我的电脑显示器是直接接在独显上面的,昨天听朋友说台式机如果有独显,集显会被自动屏蔽。
我现在用的驱动是内核自带的驱动,感觉效果不太好。之前直接安装过英伟达官方的驱动,安装完之后第一次重启是正常的,而且桌面效果有很大的提升,但是第二次重启之后在登录界面登录之后,会直接
进入命令行界面,无法进入图形界面。重试了好几次都是这个样子的。
现在我想询问下这个有没有什么解决方法,毕竟买了一块那么好的显卡,结果无法完全应用很浪费啊,而且 linux 的独显永远都是全功率运行的。
有试过使用不了 bumblebee,可能因为上面说的,安装独显后集显被屏蔽,显示器任何系统链接到主板上都是没有任何输出的。
我的显卡是: 华硕 龙骑士 GTX660Ti
贴下 /var/log/Xorg.0.log,方便大家
因为我看不懂这些都是什么,所以都贴上来了。
    11.038]
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
    11.038]
X.Org X Server 1.14.3.901 (1.14.4 RC 1)
Release Date: 2013-10-26
    11.038] X Protocol Version 11, Revision 0
    11.038] Build Operating System: openSUSE SUSE LINUX
    11.038] Current Operating System: Linux linux-4ofj 3.11.10-11-desktop #1 SMP PREEMPT Mon May 12 13:37:06 UTC 2014 (3d22b5f) x86_64
    11.038] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.11.10-11-desktop root=UUID=bd99ca3f-7f8f-4f6d-8e6b-d2d723732782 resume=/dev/disk/by-id/ata-ST2000DM001-1CH164_Z340RWV3-part2 splash=silent quiet showopts
    11.038] Build Date: 17 April 2014  05:37:34AM
    11.038]
    11.038] Current version of pixman: 0.30.2
    11.038] 	Before reporting problems, check http://wiki.x.org
    11.038] Markers: (--) probed, (**) from config file, (==) default setting,
    11.038] (==) Log file: "/var/log/Xorg.0.log", Time: Sat May 24 22:22:49 2014
    11.038] (==) Using config directory: "/etc/X11/xorg.conf.d"
    11.038] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
    11.038] (==) No Layout section.  Using the first Screen section.
    11.038] (==) No screen section available. Using defaults.
    11.038] (**) |-->Screen "Default Screen Section" (0)
    11.038] (**) |   |-->Monitor "<default monitor>"
    11.038] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
    11.038] (==) Automatically adding devices
    11.038] (==) Automatically enabling devices
    11.038] (==) Automatically adding GPU devices
    11.039] (WW) The directory "/usr/share/fonts/misc/sgi" does not exist.
    11.039] 	Entry deleted from font path.
    11.039] (==) FontPath set to:
	/usr/share/fonts/Type1/,
	/usr/share/fonts/truetype/,
	built-ins
    11.039] (==) ModulePath set to "/usr/lib64/xorg/modules/updates,/usr/lib64/xorg/modules"
    11.039] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
    11.039] (II) Loader magic: 0x803c20
    11.039] (II) Module ABI versions:
    11.039] 	X.Org ANSI C Emulation: 0.4
    11.039] 	X.Org Video Driver: 14.1
    11.039] 	X.Org XInput driver : 19.1
    11.039] 	X.Org Server Extension : 7.0
    11.039] (II) xfree86: Adding drm device (/dev/dri/card0)
    11.039] (II) xfree86: Adding drm device (/dev/dri/card1)
    11.040] (--) PCI: (0:0:2:0) 8086:0162:1043:84ca rev 9, Mem @ 0xf7400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64
    11.040] (--) PCI:*(0:1:0:0) 10de:1183:1043:8459 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/134217728, 0xe8000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
    11.040] Initializing built-in extension Generic Event Extension
    11.040] Initializing built-in extension SHAPE
    11.040] Initializing built-in extension MIT-SHM
    11.040] Initializing built-in extension XInputExtension
    11.040] Initializing built-in extension XTEST
    11.040] Initializing built-in extension BIG-REQUESTS
    11.040] Initializing built-in extension SYNC
    11.040] Initializing built-in extension XKEYBOARD
    11.040] Initializing built-in extension XC-MISC
    11.040] Initializing built-in extension SECURITY
    11.040] Initializing built-in extension XINERAMA
    11.040] Initializing built-in extension XFIXES
    11.040] Initializing built-in extension RENDER
    11.040] Initializing built-in extension RANDR
    11.040] Initializing built-in extension COMPOSITE
    11.040] Initializing built-in extension DAMAGE
    11.040] Initializing built-in extension MIT-SCREEN-SAVER
    11.040] Initializing built-in extension DOUBLE-BUFFER
    11.040] Initializing built-in extension RECORD
    11.040] Initializing built-in extension DPMS
    11.040] Initializing built-in extension X-Resource
    11.040] Initializing built-in extension XVideo
    11.040] Initializing built-in extension XVideo-MotionCompensation
    11.040] Initializing built-in extension XFree86-VidModeExtension
    11.040] Initializing built-in extension XFree86-DGA
    11.040] Initializing built-in extension XFree86-DRI
    11.040] Initializing built-in extension DRI2
    11.040] (II) "glx" will be loaded by default.
    11.040] (II) LoadModule: "dri2"
    11.040] (II) Module "dri2" already built-in
    11.040] (II) LoadModule: "glamoregl"
    11.052] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
    11.053] (II) Module glamoregl: vendor="X.Org Foundation"
    11.053] 	compiled for 1.14.3.901, module version = 0.5.1
    11.053] 	ABI class: X.Org ANSI C Emulation, version 0.4
    11.053] (II) LoadModule: "glx"
    11.053] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
    11.053] (II) Module glx: vendor="X.Org Foundation"
    11.053] 	compiled for 1.14.3.901, module version = 1.0.0
    11.053] 	ABI class: X.Org Server Extension, version 7.0
    11.053] (==) AIGLX enabled
    11.053] Loading extension GLX
    11.053] (==) Matched nvidia as autoconfigured driver 0
    11.053] (==) Matched nouveau as autoconfigured driver 1
    11.053] (==) Matched nv as autoconfigured driver 2
    11.053] (==) Matched intel as autoconfigured driver 3
    11.053] (==) Matched nvidia as autoconfigured driver 4
    11.053] (==) Matched nouveau as autoconfigured driver 5
    11.053] (==) Matched nv as autoconfigured driver 6
    11.053] (==) Matched modesetting as autoconfigured driver 7
    11.053] (==) Matched fbdev as autoconfigured driver 8
    11.053] (==) Matched vesa as autoconfigured driver 9
    11.053] (==) Assigned the driver to the xf86ConfigLayout
    11.053] (II) LoadModule: "nvidia"
    11.053] (WW) Warning, couldn't open module nvidia
    11.053] (II) UnloadModule: "nvidia"
    11.053] (II) Unloading nvidia
    11.053] (EE) Failed to load module "nvidia" (module does not exist, 0)
    11.053] (II) LoadModule: "nouveau"
    11.053] (WW) Warning, couldn't open module nouveau
    11.053] (II) UnloadModule: "nouveau"
    11.053] (II) Unloading nouveau
    11.053] (EE) Failed to load module "nouveau" (module does not exist, 0)
    11.053] (II) LoadModule: "nv"
    11.053] (II) UnloadModule: "nv"
    11.053] (EE) Failed to load module "nv" (module does not exist, 0)
    11.053] (II) LoadModule: "intel"
    11.053] (II) Loading /usr/lib64/xorg/modules/drivers/intel_drv.so
    11.054] (II) Module intel: vendor="X.Org Foundation"
    11.054] 	compiled for 1.14.3.901, module version = 2.99.906
    11.054] 	Module class: X.Org Video Driver
    11.054] 	ABI class: X.Org Video Driver, version 14.1
    11.054] (II) LoadModule: "modesetting"
    11.054] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
    11.054] (II) Module modesetting: vendor="X.Org Foundation"
    11.054] 	compiled for 1.14.3.901, module version = 0.8.0
    11.054] (II) LoadModule: "fbdev"
    11.054] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
    11.054] (II) Module fbdev: vendor="X.Org Foundation"
    11.054] 	compiled for 1.14.3, module version = 0.4.3
    11.054] (II) LoadModule: "vesa"
    11.054] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
    11.054] (II) Module vesa: vendor="X.Org Foundation"
    11.054] 	compiled for 1.14.3, module version = 2.3.3
    11.054] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43, HD Graphics,
	HD Graphics 2000, HD Graphics 3000, HD Graphics 2500,
	HD Graphics 4000, HD Graphics P4000, HD Graphics 4600,
	HD Graphics 5000, HD Graphics P4600/P4700, Iris(TM) Graphics 5100,
	HD Graphics 4400, HD Graphics 4200, Iris(TM) Pro Graphics 5200
    11.054] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
    11.054] (II) FBDEV: driver for framebuffer: fbdev
    11.054] (II) VESA: driver for VESA chipsets: vesa
    11.054] (++) using VT number 7
    11.054] (II) modesetting(0): using drv /dev/dri/card0
    11.054] (WW) Falling back to old probe method for fbdev
    11.054] (II) Loading sub module "fbdevhw"
    11.054] (II) LoadModule: "fbdevhw"
    11.055] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
    11.055] (II) Module fbdevhw: vendor="X.Org Foundation"
    11.055] 	compiled for 1.14.3.901, module version = 0.0.2
    11.055] 	ABI class: X.Org Video Driver, version 14.1
    11.055] (WW) Falling back to old probe method for vesa
    11.057] (II) modesetting(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
    11.057] (==) modesetting(0): Depth 24, (==) framebuffer bpp 32
    11.057] (==) modesetting(0): RGB weight 888
    11.057] (==) modesetting(0): Default visual is TrueColor
    11.057] (II) modesetting(0): ShadowFB: preferred YES, enabled YES
    11.087] (II) modesetting(0): Output DVI-0 has no monitor section
    11.089] (II) modesetting(0): Output DVI-0 has no monitor section
    11.091] (II) modesetting(0): Output HDMI-0 has no monitor section
    11.155] (II) modesetting(0): Output DisplayPort-0 has no monitor section
    11.184] (II) modesetting(0): EDID for output DVI-0
    11.184] (II) modesetting(0): Manufacturer: VSC  Model: 3a2c  Serial#: 16843009
    11.184] (II) modesetting(0): Year: 2013  Week: 31
    11.184] (II) modesetting(0): EDID Version: 1.3
    11.184] (II) modesetting(0): Digital Display Input
    11.184] (II) modesetting(0): Max Image Size [cm]: horiz.: 60  vert.: 34
    11.184] (II) modesetting(0): Gamma: 2.20
    11.184] (II) modesetting(0): DPMS capabilities: Off
    11.184] (II) modesetting(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
    11.184] (II) modesetting(0): Default color space is primary color space
    11.184] (II) modesetting(0): First detailed timing is preferred mode
    11.184] (II) modesetting(0): redX: 0.640 redY: 0.338   greenX: 0.315 greenY: 0.623
    11.184] (II) modesetting(0): blueX: 0.151 blueY: 0.063   whiteX: 0.313 whiteY: 0.329
    11.184] (II) modesetting(0): Supported established timings:
    11.184] (II) modesetting(0): 720x400@70Hz
    11.184] (II) modesetting(0): 640x480@60Hz
    11.184] (II) modesetting(0): 640x480@67Hz
    11.184] (II) modesetting(0): 640x480@72Hz
    11.184] (II) modesetting(0): 640x480@75Hz
    11.184] (II) modesetting(0): 800x600@56Hz
    11.184] (II) modesetting(0): 800x600@60Hz
    11.184] (II) modesetting(0): 800x600@72Hz
    11.184] (II) modesetting(0): 800x600@75Hz
    11.184] (II) modesetting(0): 832x624@75Hz
    11.184] (II) modesetting(0): 1024x768@60Hz
    11.184] (II) modesetting(0): 1024x768@70Hz
    11.184] (II) modesetting(0): 1024x768@75Hz
    11.184] (II) modesetting(0): 1280x1024@75Hz
    11.184] (II) modesetting(0): 1152x864@75Hz
    11.184] (II) modesetting(0): Manufacturer's mask: 0
    11.184] (II) modesetting(0): Supported standard timings:
    11.184] (II) modesetting(0): #0: hsize: 1680  vsize 1050  refresh: 60  vid: 179
    11.184] (II) modesetting(0): #1: hsize: 1600  vsize 1200  refresh: 60  vid: 16553
    11.184] (II) modesetting(0): #2: hsize: 1440  vsize 900  refresh: 60  vid: 149
    11.184] (II) modesetting(0): #3: hsize: 1400  vsize 1050  refresh: 60  vid: 16528
    11.184] (II) modesetting(0): #4: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
    11.184] (II) modesetting(0): #5: hsize: 1280  vsize 960  refresh: 60  vid: 16513
    11.184] (II) modesetting(0): #6: hsize: 1152  vsize 864  refresh: 75  vid: 20337
    11.184] (II) modesetting(0): #7: hsize: 640  vsize 400  refresh: 70  vid: 2609
    11.184] (II) modesetting(0): Supported detailed timing:
    11.184] (II) modesetting(0): clock: 148.5 MHz   Image Size:  597 x 336 mm
    11.184] (II) modesetting(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
    11.184] (II) modesetting(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
    11.184] (II) modesetting(0): Serial No: TRJ133100492
    11.184] (II) modesetting(0): Ranges: V min: 50 V max: 76 Hz, H min: 24 H max: 83 kHz, PixClock max 185 MHz
    11.184] (II) modesetting(0): Monitor name: VX2770 SERIES
    11.184] (II) modesetting(0): EDID (in hex):
    11.184] (II) modesetting(0): 	00ffffffffffff005a632c3a01010101
    11.184] (II) modesetting(0): 	1f170103803c22782eeed5a356509f26
    11.184] (II) modesetting(0): 	105054bfef80b300a940950090408180
    11.184] (II) modesetting(0): 	8140714f310a023a801871382d40582c
    11.184] (II) modesetting(0): 	450055502100001e000000ff0054524a
    11.184] (II) modesetting(0): 	3133333130303439320a000000fd0032
    11.184] (II) modesetting(0): 	4c185312000a202020202020000000fc
    11.184] (II) modesetting(0): 	00565832373730205345524945530032
    11.184] (II) modesetting(0): Not using default mode "1600x1200" (bad mode clock/interlace/doublescan)
    11.184] (II) modesetting(0): Printing probed modes for output DVI-0
    11.184] (II) modesetting(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
    11.184] (II) modesetting(0): Modeline "1600x1200"x65.0  175.50  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (81.2 kHz d)
    11.184] (II) modesetting(0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
    11.184] (II) modesetting(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
    11.184] (II) modesetting(0): Modeline "1400x1050"x74.8  155.80  1400 1464 1784 1912  1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
    11.184] (II) modesetting(0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
    11.184] (II) modesetting(0): Modeline "1400x1050"x59.9  101.00  1400 1448 1480 1560  1050 1053 1057 1080 +hsync -vsync (64.7 kHz e)
    11.184] (II) modesetting(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
    11.184] (II) modesetting(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
    11.184] (II) modesetting(0): Modeline "1440x900"x59.9   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
    11.184] (II) modesetting(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
    11.184] (II) modesetting(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
    11.184] (II) modesetting(0): Modeline "1024x768"x75.0  170.24  1024 1108 1220 1416  768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
    11.184] (II) modesetting(0): Modeline "1024x768"x60.0  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
    11.184] (II) modesetting(0): Modeline "1024x768"x75.1   78.80  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.1 kHz e)
    11.185] (II) modesetting(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz d)
    11.185] (II) modesetting(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
    11.185] (II) modesetting(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
    11.185] (II) modesetting(0): Modeline "960x720"x75.0  148.50  960 1032 1144 1320  720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
    11.185] (II) modesetting(0): Modeline "960x720"x60.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
    11.185] (II) modesetting(0): Modeline "928x696"x75.0  144.00  928 992 1104 1280  696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
    11.185] (II) modesetting(0): Modeline "928x696"x60.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
    11.185] (II) modesetting(0): Modeline "896x672"x75.0  130.50  896 944 1052 1228  672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
    11.185] (II) modesetting(0): Modeline "896x672"x60.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
    11.185] (II) modesetting(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
    11.185] (II) modesetting(0): Modeline "800x600"x75.0  101.25  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
    11.185] (II) modesetting(0): Modeline "800x600"x70.0   94.50  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
    11.185] (II) modesetting(0): Modeline "800x600"x65.0   87.75  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
    11.185] (II) modesetting(0): Modeline "800x600"x60.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
    11.185] (II) modesetting(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
    11.185] (II) modesetting(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
    11.185] (II) modesetting(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
    11.185] (II) modesetting(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
    11.185] (II) modesetting(0): Modeline "700x525"x74.8   77.90  700 732 892 956  525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
    11.185] (II) modesetting(0): Modeline "700x525"x60.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
    11.185] (II) modesetting(0): Modeline "640x512"x75.0   67.50  640 648 720 844  512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
    11.185] (II) modesetting(0): Modeline "640x512"x60.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
    11.185] (II) modesetting(0): Modeline "640x480"x60.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
    11.185] (II) modesetting(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
    11.185] (II) modesetting(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 491 520 -hsync -vsync (37.9 kHz e)
    11.185] (II) modesetting(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz d)
    11.185] (II) modesetting(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz d)
    11.185] (II) modesetting(0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
    11.185] (II) modesetting(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
    11.185] (II) modesetting(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
    11.185] (II) modesetting(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
    11.185] (II) modesetting(0): Modeline "576x432"x75.0   54.00  576 608 672 800  432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
    11.185] (II) modesetting(0): Modeline "512x384"x75.0   39.38  512 520 568 656  384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
    11.185] (II) modesetting(0): Modeline "512x384"x70.1   37.50  512 524 592 664  384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
    11.185] (II) modesetting(0): Modeline "512x384"x60.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
    11.185] (II) modesetting(0): Modeline "416x312"x74.7   28.64  416 432 464 576  312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
    11.185] (II) modesetting(0): Modeline "400x300"x72.2   25.00  400 428 488 520  300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
    11.185] (II) modesetting(0): Modeline "400x300"x75.1   24.75  400 408 448 528  300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
    11.185] (II) modesetting(0): Modeline "400x300"x60.3   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
    11.185] (II) modesetting(0): Modeline "400x300"x56.3   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
    11.185] (II) modesetting(0): Modeline "320x240"x72.8   15.75  320 332 352 416  240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
    11.185] (II) modesetting(0): Modeline "320x240"x75.0   15.75  320 328 360 420  240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
    11.185] (II) modesetting(0): Modeline "320x240"x60.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
    11.187] (II) modesetting(0): EDID for output DVI-0
    11.189] (II) modesetting(0): EDID for output HDMI-0
    11.253] (II) modesetting(0): EDID for output DisplayPort-0
    11.253] (II) modesetting(0): Output DVI-0 connected
    11.253] (II) modesetting(0): Output DVI-0 disconnected
    11.253] (II) modesetting(0): Output HDMI-0 disconnected
    11.253] (II) modesetting(0): Output DisplayPort-0 disconnected
    11.253] (II) modesetting(0): Using exact sizes for initial modes
    11.253] (II) modesetting(0): Output DVI-0 using initial mode 1920x1080
    11.253] (II) modesetting(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
    11.253] (==) modesetting(0): DPI set to (96, 96)
    11.253] (II) Loading sub module "fb"
    11.253] (II) LoadModule: "fb"
    11.253] (II) Loading /usr/lib64/xorg/modules/libfb.so
    11.253] (II) Module fb: vendor="X.Org Foundation"
    11.253] 	compiled for 1.14.3.901, module version = 1.0.0
    11.253] 	ABI class: X.Org ANSI C Emulation, version 0.4
    11.253] (II) Loading sub module "shadow"
    11.253] (II) LoadModule: "shadow"
    11.253] (II) Loading /usr/lib64/xorg/modules/libshadow.so
    11.253] (II) Module shadow: vendor="X.Org Foundation"
    11.253] 	compiled for 1.14.3.901, module version = 1.1.0
    11.253] (==) intel(G0): Depth 24, (--) framebuffer bpp 32
    11.253] (==) intel(G0): RGB weight 888
    11.253] (==) intel(G0): Default visual is TrueColor
    11.253] (--) intel(G0): Integrated Graphics Chipset: Intel(R) HD Graphics 4000
    11.253] (--) intel(G0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx
    11.253] (**) intel(G0): Framebuffer tiled
    11.253] (**) intel(G0): Pixmaps tiled
    11.253] (**) intel(G0): "Tear free" disabled
    11.253] (**) intel(G0): Forcing per-crtc-pixmaps? no
    11.253] (II) intel(G0): Output VGA1 has no monitor section
    11.253] (II) intel(G0): Output HDMI2 has no monitor section
    11.253] (II) intel(G0): Output DP2 has no monitor section
    11.253] (II) intel(G0): Output HDMI3 has no monitor section
    11.253] (II) intel(G0): Output HDMI4 has no monitor section
    11.253] (II) intel(G0): Output DP3 has no monitor section
    11.253] (II) intel(G0): Output DP4 has no monitor section
    11.253] (II) intel(G0): Output VIRTUAL1 has no monitor section
    11.253] (==) intel(G0): DPI set to (96, 96)
    11.253] (II) Loading sub module "dri2"
    11.253] (II) LoadModule: "dri2"
    11.253] (II) Module "dri2" already built-in
    11.253] (II) UnloadModule: "fbdev"
    11.253] (II) Unloading fbdev
    11.253] (II) UnloadSubModule: "fbdevhw"
    11.253] (II) Unloading fbdevhw
    11.253] (II) UnloadModule: "vesa"
    11.253] (II) Unloading vesa
    11.253] (==) Depth 24 pixmap format is 32 bpp
    11.254] (II) intel(G0): SNA initialized with Ivybridge (gen7, gt2) backend
    11.254] (==) intel(G0): Backing store disabled
    11.254] (==) intel(G0): Silken mouse enabled
    11.254] (II) intel(G0): HW Cursor enabled
    11.254] (II) intel(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
    11.254] (==) intel(G0): DPMS enabled
    11.254] (II) intel(G0): [DRI2] Setup complete
    11.254] (II) intel(G0): [DRI2]   DRI driver: i965
    11.254] (II) intel(G0): direct rendering: DRI2 Enabled
    11.254] (==) intel(G0): hotplug detection: "enabled"
    11.256] (==) modesetting(0): Backing store disabled
    11.256] (==) modesetting(0): Silken mouse enabled
    11.256] (II) modesetting(0): RandR 1.2 enabled, ignore the following RandR disabled message.
    11.279] (==) modesetting(0): DPMS enabled
    11.329] (--) RandR disabled
    11.331] (II) AIGLX: Screen 0 is not DRI2 capable
    11.331] (II) AIGLX: Screen 0 is not DRI capable
    11.338] (II) AIGLX: Loaded and initialized swrast
    11.338] (II) GLX: Initialized DRISWRAST GL provider for screen 0
    11.338] (II) modesetting(0): Damage tracking initialized
    11.338] (II) modesetting(0): Setting screen physical size to 508 x 285
    11.363] (II) config/udev: Adding input device Power Button (/dev/input/event1)
    11.363] (**) Power Button: Applying InputClass "evdev keyboard catchall"
    11.363] (**) Power Button: Applying InputClass "LocalKeyboard"
    11.363] (II) LoadModule: "evdev"
    11.363] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
    11.363] (II) Module evdev: vendor="X.Org Foundation"
    11.363] 	compiled for 1.14.3, module version = 2.8.2
    11.363] 	Module class: X.Org XInput Driver
    11.363] 	ABI class: X.Org XInput driver, version 19.1
    11.363] (II) Using input driver 'evdev' for 'Power Button'
    11.363] (**) Power Button: always reports core events
    11.363] (**) evdev: Power Button: Device: "/dev/input/event1"
    11.363] (--) evdev: Power Button: Vendor 0 Product 0x1
    11.363] (--) evdev: Power Button: Found keys
    11.363] (II) evdev: Power Button: Configuring as keyboard
    11.363] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
    11.363] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
    11.363] (**) Option "xkb_rules" "evdev"
    11.363] (**) Option "xkb_model" "pc104"
    11.363] (**) Option "xkb_layout" "us"
    11.374] (II) config/udev: Adding input device Video Bus (/dev/input/event2)
    11.374] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
    11.374] (**) Video Bus: Applying InputClass "LocalKeyboard"
    11.374] (II) Using input driver 'evdev' for 'Video Bus'
    11.374] (**) Video Bus: always reports core events
    11.374] (**) evdev: Video Bus: Device: "/dev/input/event2"
    11.374] (--) evdev: Video Bus: Vendor 0 Product 0x6
    11.374] (--) evdev: Video Bus: Found keys
    11.374] (II) evdev: Video Bus: Configuring as keyboard
    11.374] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:00/input/input2/event2"
    11.374] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
    11.374] (**) Option "xkb_rules" "evdev"
    11.374] (**) Option "xkb_model" "pc104"
    11.374] (**) Option "xkb_layout" "us"
    11.374] (II) config/udev: Adding input device Power Button (/dev/input/event0)
    11.374] (**) Power Button: Applying InputClass "evdev keyboard catchall"
    11.374] (**) Power Button: Applying InputClass "LocalKeyboard"
    11.374] (II) Using input driver 'evdev' for 'Power Button'
    11.374] (**) Power Button: always reports core events
    11.374] (**) evdev: Power Button: Device: "/dev/input/event0"
    11.374] (--) evdev: Power Button: Vendor 0 Product 0x1
    11.374] (--) evdev: Power Button: Found keys
    11.374] (II) evdev: Power Button: Configuring as keyboard
    11.374] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0/event0"
    11.374] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
    11.374] (II) config/udev: Adding drm device (/dev/dri/card0)
    11.375] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event19)
    11.375] (II) No input driver specified, ignoring this device.
    11.375] (II) This device may have been added with another device file.
    11.375] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event20)
    11.375] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event21)
    11.375] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event22)
    11.375] (II) config/udev: Adding drm device (/dev/dri/card1)
    11.375] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event3)
    11.375] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
    11.375] (**) Logitech USB Keyboard: Applying InputClass "LocalKeyboard"
    11.375] (II) Using input driver 'evdev' for 'Logitech USB Keyboard'
    11.375] (**) Logitech USB Keyboard: always reports core events
    11.375] (**) evdev: Logitech USB Keyboard: Device: "/dev/input/event3"
    11.375] (--) evdev: Logitech USB Keyboard: Vendor 0x46d Product 0xc31c
    11.375] (--) evdev: Logitech USB Keyboard: Found keys
    11.375] (II) evdev: Logitech USB Keyboard: Configuring as keyboard
    11.375] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5:1.0/input/input3/event3"
    11.375] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 9)
    11.375] (**) Option "xkb_rules" "evdev"
    11.375] (**) Option "xkb_model" "pc104"
    11.375] (**) Option "xkb_layout" "us"
    11.375] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event4)
    11.375] (**) evdev: Logitech USB Keyboard: Device: "/dev/input/event4"
    11.375] (--) evdev: Logitech USB Keyboard: Found absolute axes
    11.375] (II) evdev: Logitech USB Keyboard: Forcing absolute x/y axes to exist.
    11.375] (II) evdev: Logitech USB Keyboard: Forcing relative x/y axes to exist.
    11.375] (II) evdev: Logitech USB Keyboard: Configuring as mouse
    11.375] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5:1.1/input/input4/event4"
    11.375] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 10)
    11.376] (II) evdev: Logitech USB Keyboard: initialized for absolute axes.
    11.376] (**) Logitech USB Keyboard: (accel) keeping acceleration scheme 1
    11.376] (**) Logitech USB Keyboard: (accel) acceleration profile 0
    11.376] (**) Logitech USB Keyboard: (accel) acceleration factor: 2.000
    11.376] (**) Logitech USB Keyboard: (accel) acceleration threshold: 4
    11.376] (II) config/udev: Adding input device Logitech G500s Laser Gaming Mouse (/dev/input/event5)
    11.376] (**) Logitech G500s Laser Gaming Mouse: Applying InputClass "evdev pointer catchall"
    11.376] (II) Using input driver 'evdev' for 'Logitech G500s Laser Gaming Mouse'
    11.376] (**) Logitech G500s Laser Gaming Mouse: always reports core events
    11.376] (**) evdev: Logitech G500s Laser Gaming Mouse: Device: "/dev/input/event5"
    11.376] (--) evdev: Logitech G500s Laser Gaming Mouse: Vendor 0x46d Product 0xc24e
    11.376] (--) evdev: Logitech G500s Laser Gaming Mouse: Found 20 mouse buttons
    11.376] (--) evdev: Logitech G500s Laser Gaming Mouse: Found scroll wheel(s)
    11.376] (--) evdev: Logitech G500s Laser Gaming Mouse: Found relative axes
    11.376] (--) evdev: Logitech G500s Laser Gaming Mouse: Found x and y relative axes
    11.376] (II) evdev: Logitech G500s Laser Gaming Mouse: Configuring as mouse
    11.376] (II) evdev: Logitech G500s Laser Gaming Mouse: Adding scrollwheel support
    11.376] (**) evdev: Logitech G500s Laser Gaming Mouse: YAxisMapping: buttons 4 and 5
    11.376] (**) evdev: Logitech G500s Laser Gaming Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
    11.376] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.0/input/input5/event5"
    11.376] (II) XINPUT: Adding extended input device "Logitech G500s Laser Gaming Mouse" (type: MOUSE, id 11)
    11.376] (II) evdev: Logitech G500s Laser Gaming Mouse: initialized for relative axes.
    11.376] (**) Logitech G500s Laser Gaming Mouse: (accel) keeping acceleration scheme 1
    11.376] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration profile 0
    11.376] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration factor: 2.000
    11.376] (**) Logitech G500s Laser Gaming Mouse: (accel) acceleration threshold: 4
    11.376] (II) config/udev: Adding input device Logitech G500s Laser Gaming Mouse (/dev/input/mouse0)
    11.376] (II) No input driver specified, ignoring this device.
    11.376] (II) This device may have been added with another device file.
    11.376] (II) config/udev: Adding input device Logitech G500s Laser Gaming Mouse (/dev/input/event6)
    11.376] (**) Logitech G500s Laser Gaming Mouse: Applying InputClass "evdev keyboard catchall"
    11.376] (**) Logitech G500s Laser Gaming Mouse: Applying InputClass "LocalKeyboard"
    11.376] (**) evdev: Logitech G500s Laser Gaming Mouse: Device: "/dev/input/event6"
    11.376] (--) evdev: Logitech G500s Laser Gaming Mouse: Found 1 mouse buttons
    11.376] (II) evdev: Logitech G500s Laser Gaming Mouse: Forcing relative x/y axes to exist.
    11.376] (--) evdev: Logitech G500s Laser Gaming Mouse: Found absolute axes
    11.376] (II) evdev: Logitech G500s Laser Gaming Mouse: Forcing absolute x/y axes to exist.
    11.376] (--) evdev: Logitech G500s Laser Gaming Mouse: Found keys
    11.376] (II) evdev: Logitech G500s Laser Gaming Mouse: Configuring as keyboard
    11.376] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.1/input/input6/event6"
    11.376] (II) XINPUT: Adding extended input device "Logitech G500s Laser Gaming Mouse" (type: KEYBOARD, id 12)
    11.376] (**) Option "xkb_rules" "evdev"
    11.376] (**) Option "xkb_model" "pc104"
    11.376] (**) Option "xkb_layout" "us"
    11.376] (WW) evdev: Logitech G500s Laser Gaming Mouse: ignoring absolute axes.
    11.377] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event10)
    11.377] (II) No input driver specified, ignoring this device.
    11.377] (II) This device may have been added with another device file.
    11.377] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event11)
    11.377] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event12)
    11.377] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event13)
    11.377] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event14)
    11.377] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event15)
    11.377] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event16)
    11.377] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event17)
    11.377] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event18)
    11.377] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event9)
    11.378] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event8)
    11.378] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
    11.378] (**) Eee PC WMI hotkeys: Applying InputClass "LocalKeyboard"
    11.378] (II) Using input driver 'evdev' for 'Eee PC WMI hotkeys'
    11.378] (**) Eee PC WMI hotkeys: always reports core events
    11.378] (**) evdev: Eee PC WMI hotkeys: Device: "/dev/input/event8"
    11.378] (--) evdev: Eee PC WMI hotkeys: Vendor 0 Product 0
    11.378] (--) evdev: Eee PC WMI hotkeys: Found keys
    11.378] (II) evdev: Eee PC WMI hotkeys: Configuring as keyboard
    11.378] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input8/event8"
    11.378] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 13)
    11.378] (**) Option "xkb_rules" "evdev"
    11.378] (**) Option "xkb_model" "pc104"
    11.378] (**) Option "xkb_layout" "us"
    11.378] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
    11.378] (II) No input driver specified, ignoring this device.
    11.378] (II) This device may have been added with another device file.
    32.406] (II) modesetting(0): EDID vendor "VSC", prod id 14892
    32.406] (II) modesetting(0): Using EDID range info for horizontal sync
    32.406] (II) modesetting(0): Using EDID range info for vertical refresh
    32.406] (II) modesetting(0): Printing DDC gathered Modelines:
    32.406] (II) modesetting(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
    32.406] (II) modesetting(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
    32.406] (II) modesetting(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
    32.406] (II) modesetting(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
    32.406] (II) modesetting(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
    32.406] (II) modesetting(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
    32.406] (II) modesetting(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
    32.406] (II) modesetting(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
    32.406] (II) modesetting(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
    32.406] (II) modesetting(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
    32.406] (II) modesetting(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
    32.406] (II) modesetting(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
    32.406] (II) modesetting(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
    32.406] (II) modesetting(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
    32.406] (II) modesetting(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
    32.406] (II) modesetting(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
    32.406] (II) modesetting(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
    32.406] (II) modesetting(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
    32.406] (II) modesetting(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
    32.406] (II) modesetting(0): Modeline "1400x1050"x0.0  101.00  1400 1448 1480 1560  1050 1053 1057 1080 +hsync -vsync (64.7 kHz e)
    32.406] (II) modesetting(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
    32.406] (II) modesetting(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
    32.406] (II) modesetting(0): Modeline "640x400"x70.0   23.35  640 656 720 800  400 401 404 417 -hsync +vsync (29.2 kHz e)
    34.308] (II) modesetting(0): EDID vendor "VSC", prod id 14892
    34.308] (II) modesetting(0): Using hsync ranges from config file
    34.308] (II) modesetting(0): Using vrefresh ranges from config file
    34.308] (II) modesetting(0): Printing DDC gathered Modelines:
    34.308] (II) modesetting(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
    34.308] (II) modesetting(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
    34.308] (II) modesetting(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
    34.308] (II) modesetting(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
    34.308] (II) modesetting(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
    34.308] (II) modesetting(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
    34.308] (II) modesetting(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
    34.308] (II) modesetting(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
    34.308] (II) modesetting(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
    34.308] (II) modesetting(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
    34.308] (II) modesetting(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
    34.308] (II) modesetting(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
    34.308] (II) modesetting(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
    34.308] (II) modesetting(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
    34.308] (II) modesetting(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
    34.308] (II) modesetting(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
    34.308] (II) modesetting(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
    34.308] (II) modesetting(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
    34.308] (II) modesetting(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
    34.308] (II) modesetting(0): Modeline "1400x1050"x0.0  101.00  1400 1448 1480 1560  1050 1053 1057 1080 +hsync -vsync (64.7 kHz e)
    34.308] (II) modesetting(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
    34.308] (II) modesetting(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
    34.308] (II) modesetting(0): Modeline "640x400"x70.0   23.35  640 656 720 800  400 401 404 417 -hsync +vsync (29.2 kHz e)
