我只发现在 software.opensuse.org 中,有一个老的版本 v6.1 的,如何安装最新的 v7.0 版本,我通过源代码安装一直安装不上,有人装过吗?有的话,请写个过程给我,非常感谢。
有人在 opensuse 12.3 上安装过 openERP 吗,有安装教程吗?
我找了好多篇教程都没安装成功,如果有安装成功的朋友麻烦发下安装的教程,谢谢各位!
输出了啥错误?
2013-07-05 07:55:57,939 22255 ERROR ? openerp.service: Failed to load server-wide module web.
The web module is provided by the addons found in the openerp-web project.
Maybe you forgot to add those addons in your addons_path configuration.
File “/home/openerp/server/openerp/service/init.py”, line 60, in load_server_wide_modules
openerp.modules.module.load_openerp_module(m)
File “/home/openerp/server/openerp/modules/module.py”, line 415, in load_openerp_module
getattr(sys.modules’openerp.addons.’ + module_name], info’post_load’])()
File “/home/openerp/web/addons/web/http.py”, line 628, in wsgi_postload
openerp.wsgi.register_wsgi_handler(Root())
File “/home/openerp/web/addons/web/http.py”, line 517, in init
self.load_addons()
File “/home/openerp/web/addons/web/http.py”, line 580, in load_addons
m = import(‘openerp.addons.’ + module)
File “/home/openerp/server/openerp/modules/module.py”, line 133, in load_module
mod = imp.load_module(‘openerp.addons.’ + module_part, f, path, descr)
File “/home/openerp/addons/crm/init.py”, line 24, in
import crm_lead
File “/home/openerp/addons/crm/crm_lead.py”, line 33, in
from base.res.res_partner import format_address
File “/home/openerp/server/openerp/addons/base/init.py”, line 23, in
import module
File “/home/openerp/server/openerp/addons/base/module/init.py”, line 22, in
import module
File “/home/openerp/server/openerp/addons/base/module/module.py”, line 21, in
from docutils import nodes
ImportError: No module named docutils
2013-07-05 07:55:57,944 22255 DEBUG ? openerp.service.cron: cron0 started!
2013-07-05 07:55:57,944 22255 DEBUG ? openerp.service.cron: cron1 started!
2013-07-05 07:55:57,944 22255 INFO ? openerp.service.wsgi_server: HTTP service (werkzeug) running on 0.0.0.0:8069
2013-07-05 07:55:57,944 22255 INFO ? openerp: OpenERP server is running, waiting for connections…
好像缺少web插件包吧,但是我已经下载了。不知道怎么配置那个web工程目录。
好像是要安装 docutils 模块。
谢谢,搞定了,ImportError: No module named docutils,的确是这个错误引起的。
