2.719] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 25 12:20:42 2014
2.719] (==) Using config file: "/etc/X11/xorg.conf"
2.719] (==) Using config directory: "/etc/X11/xorg.conf.d"
2.719] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
2.720] (==) ServerLayout "Layout0"
2.720] (**) |-->Screen "Screen0" (0)
2.720] (**) | |-->Monitor "Monitor0"
2.720] (**) | |-->Device "Device0"
2.720] (**) |-->Input Device "Keyboard0"
2.720] (**) |-->Input Device "Mouse0"
2.720] (==) Automatically adding devices
2.720] (==) Automatically enabling devices
2.720] (==) Automatically adding GPU devices
2.721] (WW) The directory "/usr/share/fonts/misc/sgi" does not exist.
2.721] Entry deleted from font path.
2.721] (==) FontPath set to:
/usr/share/fonts/Type1/,
/usr/share/fonts/truetype/,
built-ins
2.721] (==) ModulePath set to "/usr/lib64/xorg/modules/updates,/usr/lib64/xorg/modules"
2.721] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
2.721] (WW) Disabling Keyboard0
2.721] (WW) Disabling Mouse0
2.721] (II) Loader magic: 0x803c20
2.721] (II) Module ABI versions:
2.721] X.Org ANSI C Emulation: 0.4
2.721] X.Org Video Driver: 14.1
2.721] X.Org XInput driver : 19.1
2.721] X.Org Server Extension : 7.0
2.721] (II) xfree86: Adding drm device (/dev/dri/card0)
2.722] (--) PCI:*(0:1:0:0) 10de:11c6:7377:0000 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
2.722] Initializing built-in extension Generic Event Extension
2.722] Initializing built-in extension SHAPE
2.722] Initializing built-in extension MIT-SHM
2.722] Initializing built-in extension XInputExtension
2.722] Initializing built-in extension XTEST
2.722] Initializing built-in extension BIG-REQUESTS
2.722] Initializing built-in extension SYNC
2.722] Initializing built-in extension XKEYBOARD
2.722] Initializing built-in extension XC-MISC
2.722] Initializing built-in extension SECURITY
2.722] Initializing built-in extension XINERAMA
2.722] Initializing built-in extension XFIXES
2.722] Initializing built-in extension RENDER
2.722] Initializing built-in extension RANDR
2.722] Initializing built-in extension COMPOSITE
2.722] Initializing built-in extension DAMAGE
2.722] Initializing built-in extension MIT-SCREEN-SAVER
2.722] Initializing built-in extension DOUBLE-BUFFER
2.722] Initializing built-in extension RECORD
2.722] Initializing built-in extension DPMS
2.722] Initializing built-in extension X-Resource
2.722] Initializing built-in extension XVideo
2.722] Initializing built-in extension XVideo-MotionCompensation
2.722] Initializing built-in extension XFree86-VidModeExtension
2.722] Initializing built-in extension XFree86-DGA
2.722] Initializing built-in extension XFree86-DRI
2.722] Initializing built-in extension DRI2
2.722] (II) LoadModule: "glx"
2.727] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
2.854] (II) Module glx: vendor="NVIDIA Corporation"
2.854] compiled for 4.0.2, module version = 1.0.0
2.854] Module class: X.Org Server Extension
2.854] (II) NVIDIA GLX Module 331.67 Fri Apr 4 11:43:47 PDT 2014
2.854] Loading extension GLX
2.854] (II) LoadModule: "nvidia"
2.854] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
2.855] (II) Module nvidia: vendor="NVIDIA Corporation"
2.855] compiled for 4.0.2, module version = 1.0.0
2.855] Module class: X.Org Video Driver
2.855] (II) NVIDIA dlloader X Driver 331.67 Fri Apr 4 11:24:40 PDT 2014
2.855] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
2.855] (++) using VT number 7
2.855] (II) Loading sub module "fb"
2.855] (II) LoadModule: "fb"
2.856] (II) Loading /usr/lib64/xorg/modules/libfb.so
2.856] (II) Module fb: vendor="X.Org Foundation"
2.856] compiled for 1.14.3.901, module version = 1.0.0
2.856] ABI class: X.Org ANSI C Emulation, version 0.4
2.856] (WW) Unresolved symbol: fbGetGCPrivateKey
2.856] (II) Loading sub module "wfb"
2.856] (II) LoadModule: "wfb"
2.856] (II) Loading /usr/lib64/xorg/modules/libwfb.so
2.856] (II) Module wfb: vendor="X.Org Foundation"
2.857] (II) Loading sub module "ramdac"
2.857] (II) LoadModule: "ramdac"
2.857] (II) Module "ramdac" already built-in
2.857] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
2.857] (==) NVIDIA(0): RGB weight 888
2.857] (==) NVIDIA(0): Default visual is TrueColor
2.857] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
2.857] (**) NVIDIA(0): Enabling 2D acceleration
3.322] (II) NVIDIA(0): Display (Lenovo Group Limited LXM-WL19AH (CRT-0)) does not
3.322] (II) NVIDIA(0): support NVIDIA 3D Vision stereo.
3.322] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20130102)
3.323] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 650 Ti (GK106) at PCI:1:0:0 (GPU-0)
3.323] (--) NVIDIA(0): Memory: 2097152 kBytes
3.323] (--) NVIDIA(0): VideoBIOS: 80.06.21.00.8d
3.323] (II) NVIDIA(0): Detected PCI Express Link width: 16X
3.326] (--) NVIDIA(0): Valid display device(s) on GeForce GTX 650 Ti at PCI:1:0:0
3.326] (--) NVIDIA(0): Lenovo Group Limited LXM-WL19AH (CRT-0) (boot, connected)
3.326] (--) NVIDIA(0): DFP-0
3.326] (--) NVIDIA(0): DFP-1
3.326] (--) NVIDIA(0): DFP-2
3.326] (--) NVIDIA(0): Lenovo Group Limited LXM-WL19AH (CRT-0): 400.0 MHz maximum pixel clock
3.326] (--) NVIDIA(0): DFP-0: Internal Single Link TMDS
3.326] (--) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
3.326] (--) NVIDIA(0): DFP-1: Internal Single Link TMDS
3.326] (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
3.326] (--) NVIDIA(0): DFP-2: Internal Single Link TMDS
3.326] (--) NVIDIA(0): DFP-2: 330.0 MHz maximum pixel clock
3.326] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
3.326] (**) NVIDIA(0): device Lenovo Group Limited LXM-WL19AH (CRT-0) (Using EDID
3.326] (**) NVIDIA(0): frequencies has been enabled on all display devices.)
3.328] (==) NVIDIA(0):
3.328] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
3.328] (==) NVIDIA(0): will be used as the requested mode.
3.328] (II) NVIDIA(0): Validated MetaModes:
3.328] (II) NVIDIA(0): "CRT-0:nvidia-auto-select"
3.328] (II) NVIDIA(0): Virtual screen size determined to be 1440 x 900
3.351] (--) NVIDIA(0): DPI set to (89, 87); computed from "UseEdidDpi" X config
3.351] (--) NVIDIA(0): option
3.351] (--) Depth 24 pixmap format is 32 bpp
3.351] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
3.351] (II) NVIDIA: access.
3.354] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
3.354] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
3.354] (II) NVIDIA(0): configuration option may not be set correctly. When the
3.354] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
3.354] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
3.354] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
3.354] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
3.354] (II) NVIDIA(0): Config Options in the README.
3.357] (II) NVIDIA(0): Setting mode "CRT-0:nvidia-auto-select"
3.399] Loading extension NV-GLX
3.412] (==) NVIDIA(0): Disabling shared memory pixmaps
3.412] (==) NVIDIA(0): Backing store disabled
3.412] (==) NVIDIA(0): Silken mouse enabled
3.412] (**) NVIDIA(0): DPMS enabled
3.412] Loading extension NV-CONTROL
3.413] Loading extension XINERAMA
3.413] (II) Loading sub module "dri2"
3.413] (II) LoadModule: "dri2"
3.413] (II) Module "dri2" already built-in
3.413] (II) NVIDIA(0): [DRI2] Setup complete
3.413] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
3.413] (--) RandR disabled
3.417] (II) Initializing extension GLX
3.484] (II) config/udev: Adding input device Power Button (/dev/input/event5)
3.484] (**) Power Button: Applying InputClass "evdev keyboard catchall"
3.484] (**) Power Button: Applying InputClass "LocalKeyboard"
3.484] (II) LoadModule: "evdev"
3.484] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
3.485] (II) Module evdev: vendor="X.Org Foundation"
3.485] compiled for 1.14.3, module version = 2.8.2
3.485] Module class: X.Org XInput Driver
3.485] ABI class: X.Org XInput driver, version 19.1
3.485] (II) Using input driver 'evdev' for 'Power Button'
3.485] (**) Power Button: always reports core events
3.485] (**) evdev: Power Button: Device: "/dev/input/event5"
3.485] (--) evdev: Power Button: Vendor 0 Product 0x1
3.485] (--) evdev: Power Button: Found keys
3.485] (II) evdev: Power Button: Configuring as keyboard
3.485] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input8/event5"
3.485] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
3.485] (**) Option "xkb_rules" "evdev"
3.485] (**) Option "xkb_model" "pc104"
3.485] (**) Option "xkb_layout" "us"
3.511] (II) config/udev: Adding input device Power Button (/dev/input/event4)
3.511] (**) Power Button: Applying InputClass "evdev keyboard catchall"
3.511] (**) Power Button: Applying InputClass "LocalKeyboard"
3.511] (II) Using input driver 'evdev' for 'Power Button'
3.511] (**) Power Button: always reports core events
3.511] (**) evdev: Power Button: Device: "/dev/input/event4"
3.511] (--) evdev: Power Button: Vendor 0 Product 0x1
3.511] (--) evdev: Power Button: Found keys
3.511] (II) evdev: Power Button: Configuring as keyboard
3.511] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input7/event4"
3.511] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
3.511] (**) Option "xkb_rules" "evdev"
3.511] (**) Option "xkb_model" "pc104"
3.511] (**) Option "xkb_layout" "us"
3.512] (II) config/udev: Adding drm device (/dev/dri/card0)
3.512] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event17)
3.512] (II) No input driver specified, ignoring this device.
3.512] (II) This device may have been added with another device file.
3.512] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event16)
3.512] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event15)
3.513] (II) config/udev: Adding input device Logitech Gaming Mouse G300 (/dev/input/event0)
3.513] (**) Logitech Gaming Mouse G300: Applying InputClass "evdev pointer catchall"
3.513] (II) Using input driver 'evdev' for 'Logitech Gaming Mouse G300'
3.513] (**) Logitech Gaming Mouse G300: always reports core events
3.513] (**) evdev: Logitech Gaming Mouse G300: Device: "/dev/input/event0"
3.513] (--) evdev: Logitech Gaming Mouse G300: Vendor 0x46d Product 0xc246
3.513] (--) evdev: Logitech Gaming Mouse G300: Found 20 mouse buttons
3.513] (--) evdev: Logitech Gaming Mouse G300: Found scroll wheel(s)
3.513] (--) evdev: Logitech Gaming Mouse G300: Found relative axes
3.513] (--) evdev: Logitech Gaming Mouse G300: Found x and y relative axes
3.513] (II) evdev: Logitech Gaming Mouse G300: Configuring as mouse
3.513] (II) evdev: Logitech Gaming Mouse G300: Adding scrollwheel support
3.513] (**) evdev: Logitech Gaming Mouse G300: YAxisMapping: buttons 4 and 5
3.513] (**) evdev: Logitech Gaming Mouse G300: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
3.513] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C246.0001/input/input3/event0"
3.513] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G300" (type: MOUSE, id 8)
3.513] (II) evdev: Logitech Gaming Mouse G300: initialized for relative axes.
3.513] (**) Logitech Gaming Mouse G300: (accel) keeping acceleration scheme 1
3.513] (**) Logitech Gaming Mouse G300: (accel) acceleration profile 0
3.513] (**) Logitech Gaming Mouse G300: (accel) acceleration factor: 2.000
3.513] (**) Logitech Gaming Mouse G300: (accel) acceleration threshold: 4
3.513] (II) config/udev: Adding input device Logitech Gaming Mouse G300 (/dev/input/mouse0)
3.514] (II) No input driver specified, ignoring this device.
3.514] (II) This device may have been added with another device file.
3.514] (II) config/udev: Adding input device Logitech Gaming Mouse G300 (/dev/input/event1)
3.514] (**) Logitech Gaming Mouse G300: Applying InputClass "evdev keyboard catchall"
3.514] (**) Logitech Gaming Mouse G300: Applying InputClass "LocalKeyboard"
3.514] (II) Using input driver 'evdev' for 'Logitech Gaming Mouse G300'
3.514] (**) Logitech Gaming Mouse G300: always reports core events
3.514] (**) evdev: Logitech Gaming Mouse G300: Device: "/dev/input/event1"
3.514] (--) evdev: Logitech Gaming Mouse G300: Vendor 0x46d Product 0xc246
3.514] (--) evdev: Logitech Gaming Mouse G300: Found absolute axes
3.514] (II) evdev: Logitech Gaming Mouse G300: Forcing absolute x/y axes to exist.
3.514] (--) evdev: Logitech Gaming Mouse G300: Found keys
3.514] (II) evdev: Logitech Gaming Mouse G300: Forcing relative x/y axes to exist.
3.514] (II) evdev: Logitech Gaming Mouse G300: Configuring as mouse
3.514] (II) evdev: Logitech Gaming Mouse G300: Configuring as keyboard
3.514] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C246.0002/input/input4/event1"
3.514] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G300" (type: KEYBOARD, id 9)
3.514] (**) Option "xkb_rules" "evdev"
3.514] (**) Option "xkb_model" "pc104"
3.514] (**) Option "xkb_layout" "us"
3.514] (II) evdev: Logitech Gaming Mouse G300: initialized for absolute axes.
3.514] (**) Logitech Gaming Mouse G300: (accel) keeping acceleration scheme 1
3.514] (**) Logitech Gaming Mouse G300: (accel) acceleration profile 0
3.515] (**) Logitech Gaming Mouse G300: (accel) acceleration factor: 2.000
3.515] (**) Logitech Gaming Mouse G300: (accel) acceleration threshold: 4
3.515] (II) config/udev: Adding input device Logitech Gaming Keyboard G105 (/dev/input/event2)
3.515] (**) Logitech Gaming Keyboard G105: Applying InputClass "evdev keyboard catchall"
3.515] (**) Logitech Gaming Keyboard G105: Applying InputClass "LocalKeyboard"
3.515] (II) Using input driver 'evdev' for 'Logitech Gaming Keyboard G105'
3.515] (**) Logitech Gaming Keyboard G105: always reports core events
3.515] (**) evdev: Logitech Gaming Keyboard G105: Device: "/dev/input/event2"
3.515] (--) evdev: Logitech Gaming Keyboard G105: Vendor 0x46d Product 0xc248
3.515] (--) evdev: Logitech Gaming Keyboard G105: Found keys
3.515] (II) evdev: Logitech Gaming Keyboard G105: Configuring as keyboard
3.515] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C248.0003/input/input5/event2"
3.515] (II) XINPUT: Adding extended input device "Logitech Gaming Keyboard G105" (type: KEYBOARD, id 10)
3.515] (**) Option "xkb_rules" "evdev"
3.515] (**) Option "xkb_model" "pc104"
3.515] (**) Option "xkb_layout" "us"
3.516] (II) config/udev: Adding input device Logitech Gaming Keyboard G105 (/dev/input/event3)
3.516] (**) Logitech Gaming Keyboard G105: Applying InputClass "evdev keyboard catchall"
3.516] (**) Logitech Gaming Keyboard G105: Applying InputClass "LocalKeyboard"
3.516] (II) Using input driver 'evdev' for 'Logitech Gaming Keyboard G105'
3.516] (**) Logitech Gaming Keyboard G105: always reports core events
3.516] (**) evdev: Logitech Gaming Keyboard G105: Device: "/dev/input/event3"
3.516] (--) evdev: Logitech Gaming Keyboard G105: Vendor 0x46d Product 0xc248
3.516] (--) evdev: Logitech Gaming Keyboard G105: Found keys
3.516] (II) evdev: Logitech Gaming Keyboard G105: Configuring as keyboard
3.516] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C248.0004/input/input6/event3"
3.516] (II) XINPUT: Adding extended input device "Logitech Gaming Keyboard G105" (type: KEYBOARD, id 11)
3.516] (**) Option "xkb_rules" "evdev"
3.516] (**) Option "xkb_model" "pc104"
3.516] (**) Option "xkb_layout" "us"
3.516] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event14)
3.516] (II) No input driver specified, ignoring this device.
3.516] (II) This device may have been added with another device file.
3.517] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event13)
3.517] (II) No input driver specified, ignoring this device.
3.517] (II) This device may have been added with another device file.
3.517] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event12)
3.517] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event11)
3.517] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event10)
3.518] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event9)
3.518] (II) No input driver specified, ignoring this device.
3.518] (II) This device may have been added with another device file.
3.518] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event8)
3.518] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event7)
3.518] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
3.519] (II) No input driver specified, ignoring this device.
3.519] (II) This device may have been added with another device file.
6.153] (II) NVIDIA(GPU-0): Display (Lenovo Group Limited LXM-WL19AH (CRT-0)) does not
6.153] (II) NVIDIA(GPU-0): support NVIDIA 3D Vision stereo.
77.781] [Xi] Too many valuators reported for device 'Virtual core pointer'. Ignoring event.
是这个么?
