[已解决]求指点,openSUSE 13.1 装 virtualbox 提示错误
ERROR: Kernel configuration is invalid.
         include/generated/autoconf.h or include/config/auto.conf are missing.
         Run 'make oldconfig && make prepare' on kernel src to fix it.
mkdir -p /tmp/vbox.0/.tmp_versions ; rm -f /tmp/vbox.0/.tmp_versions/*
  WARNING: Symbol version dump /usr/src/linux-3.11.10-21/Module.symvers
           is missing; modules will have no dependencies and modversions.
make -f scripts/Makefile.build obj=/tmp/vbox.0
/tmp/vbox.0/Makefile:186: Warning: using /usr/src/linux as the source directory of your Linux kernel. If this is not correct, specify KERN_DIR=<directory> and run Make again.
  gcc -Wp,-MD,/tmp/vbox.0/linux/.SUPDrv-linux.o.d  -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.8/include -I/usr/src/linux-3.11.10-21/arch/x86/include -Iarch/x86/include/generated  -Iinclude -I/usr/src/linux-3.11.10-21/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.11.10-21/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.11.10-21/include/linux/kconfig.h -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mno-sse -mpreferred-stack-boundary=3 -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -include /tmp/vbox.0/include/VBox/SUPDrvMangling.h -I/usr/src/linux/include -I/tmp/vbox.0/ -I/tmp/vbox.0/include -I/tmp/vbox.0/r0drv/linux -I/tmp/vbox.0/vboxdrv/ -I/tmp/vbox.0/vboxdrv/include -I/tmp/vbox.0/vboxdrv/r0drv/linux -D__KERNEL__ -DMODULE -DRT_OS_LINUX -DIN_RING0 -DIN_RT_R0 -DIN_SUP_R0 -DVBOX -DRT_WITH_VBOX -DVBOX_WITH_HARDENING -Wno-declaration-after-statement -DCONFIG_VBOXDRV_AS_MISC -DRT_ARCH_AMD64 -DVBOX_WITH_64_BITS_GUESTS  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(SUPDrv_linux)"  -D"KBUILD_MODNAME=KBUILD_STR(vboxdrv)" -c -o /tmp/vbox.0/linux/SUPDrv-linux.o /tmp/vbox.0/linux/SUPDrv-linux.c
In file included from <command-line>:0:0:
/usr/src/linux-3.11.10-21/include/linux/kconfig.h:4:32: fatal error: generated/autoconf.h: 没有那个文件或目录
 #include <generated/autoconf.h>
compilation terminated.
make[2]: *** [/tmp/vbox.0/linux/SUPDrv-linux.o] 错误 1
make[1]: *** [_module_/tmp/vbox.0] Error 2
make: *** [vboxdrv] Error 2
sudo zypper in kernel-devel kernel-source
