前言
最近新买了笔记本电脑 Dell Inspiron 15 - 3537。i5 芯片,AMD/Intel 双显卡,750G 机械硬盘,15.6 寸显示屏。预装 Ubuntu 系统。
/sbin/lspci 输出信息如下:
00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 09)
00:03.0 Audio device: Intel Corporation Device 0a0c (rev 09)
00:14.0 USB controller: Intel Corporation Lynx Point-LP USB xHCI HC (rev 04)
00:16.0 Communication controller: Intel Corporation Lynx Point-LP HECI #0 (rev 04)
00:1b.0 Audio device: Intel Corporation Lynx Point-LP HD Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 3 (rev e4)
00:1c.3 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 4 (rev e4)
00:1c.4 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 5 (rev e4)
00:1d.0 USB controller: Intel Corporation Lynx Point-LP USB EHCI #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation Lynx Point-LP LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation Lynx Point-LP SATA Controller 1 [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation Lynx Point-LP SMBus Controller (rev 04)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 07)
02:00.0 Network controller: Broadcom Corporation BCM43142 802.11b/g/n (rev 01)
03:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M] (rev ff)
本文是我在这台电脑上安装 openSUSE 13.1 的过程。这不是教程,而是供我自己参考的“办事清单”,希望也能帮到别人。
事先准备
* 视频: [KDE 等离子桌面介绍(openSUSE 12.3)](http://v.youku.com/v_show/id_XNTIzNjA2OTIw.html)
* 网页: [openSUSE 新手指南 ](https://lug.ustc.edu.cn/sites/opensuse-guide/index.php)
13.1 的 KDE 桌面和 12.3 基本类似,有些细节更漂亮了(比如鼠标移动到屏幕角落时的“绿光”效果,更新软件包的界面等)。所以上述视频依然是很好的入门教程。
安装系统时还会经常参考指南网页。预先读一遍,以后知道上哪儿找答案就行。
下载 DVD 镜像,烧录 U 盘
* 下载 DVD 镜像 ](http://software.opensuse.org/131/en)
* [Windows:烧录 U 盘 ](http://en.opensuse.org/SDB:Create_a_Live_USB_stick_using_Windows)
* [openSUSE:烧录 U 盘 ](http://en.opensuse.org/SDB:Live_USB_stick)
按提示操作。
安装系统
以下建议写给我这样的小白用户:
* 如果不知道怎么做,就采用默认设置
* 尽量在图形界面调整设置
* 调整设置前,必须知道自己在做什么
* 如果不知道在做什么,必须记录下每一次改动
啥都不懂,还要乱改系统,就算 360 也救不了你啊。比如,我用 YaST 删除了虚拟地球仪(Marble)。重启电脑后没法进入图形界面。回忆整个过程,YaST 提示说要删除额外的软件包,其中包括 fglrx 什么的……等等,那不是 AMD 的闭源驱动吗?
呵呵,我真是太机智了。
另外还有两条建议:
* 最好有备用电脑查资料
* 准备一根网线,以免系统无法识别无线网卡
动手前,必须认真读过 最简单的安装教程 ](https://lug.ustc.edu.cn/sites/opensuse-guide/installation.php) 。
我只调整了三个选项。
引导方式:MBR/root/none
安装时可以选择是否启用(enable)从 MBR 和 / 或 root 引导。默认未启用。
三种方式的差别 ](http://forums.opensuse.org/showthread.php/434046-Boot-from-MBR-vs-Root-partition-vs-None) 。
我不打算安装 Windows,所以同时启用了两种引导方式。
调整分区
我想删除 Dell 电脑自带的系统分区(大约几百 M),但是怕出错。进入调整分区的界面,有一个树形图显示当前分区之间的关系。看图操作即可。
开机密码
在新建用户界面,取消开机自动登录的选项。
安装网卡和显卡驱动
装完系统,重启电脑后无法进入图形界面。关机。下次开机时,在引导界面选择 Advanced Mode,顺利进入图形界面。但是无法识别无线网卡。于是插上网线,
* 安装 AMD 显卡驱动 ](https://lug.ustc.edu.cn/sites/opensuse-guide/3d.php)
* 安装 Broadcom 网卡驱动 ](https://lug.ustc.edu.cn/sites/opensuse-guide/wlan.php)
现在可以正常开机了。
按 打开 KRunner,输入 AMD,启动显卡设置程序。选择禁用 AMD 显卡,只启用 Intel 显卡。风扇终于不转了。
安装中文字体和输入法,调整系统设置
现在系统能正常使用了。接下来首先安装以下软件包:
* 文泉驿微米黑
* fcitx 拼音
然后在图形界面里调整系统设置。
KRunner
* 仅选中插件:Applications
桌面部件
* 删除桌面上的 Folder 部件
* 用 Lancelot Launcher 代替原有的 Application Launcher
* 调整 Task Manager 的高度以及部件位置
更改主机名
YaST - Network Devices - Network Settings
在 Configure Desktop 内完成以下设置。
Hardware
Power Management
* 屏幕亮度,关闭屏幕,待机 / 休眠
* 低电量提醒
Input Devices
* 修改 Caps Lock 的键映射
* 从 KRunner 启动 Synaptiks,设置触摸板的功能
Display and Monitor
* 是否锁屏
Common Appearance and Behavior
Account Details
* 头像、密码、是否显示密码长度
* 默认的下载路径
Application Appearance - Fonts
* 默认字体
Application and System Notifications — KDE Workspace
* 登陆 / 登出声音
Locale
* 显示时间的格式
* 桌面部件:数字钟
* 拼音输入法:候选词数量
Shortcuts and Gestures - Global Keyboard Shortcuts
* KWin
* <Ctrl-F5>:窗口最大化
* <Ctrl-F6>:窗口全屏
* <Alt-F1>:Window Operations Menu
Workspace Appearance and Behavior
Desktop Effects
* 关闭部分桌面特效
Window Behavior
* 切换窗口的画面
* <Alt- 滚轮>:最大化 / 还原窗口
Workspace Behavior
* 虚拟桌面的数量和切换方式
* 鼠标移动到屏幕边缘的效果
安装常用软件和插件
* 多媒体编解码器 ](https://lug.ustc.edu.cn/sites/opensuse-guide/codecs.php)
* 火狐插件:Pentadactyl,AdBlock Plus,Flashgot 和 FoxyProxy
* GVim
* SMplayer
* Dropbox
openSUSE 13.1 至此安装完成。玩得开心!
