出现错误如下:
linux:~ # optirun --status
330.156657] [ERROR]The Bumblebee daemon has not been started yet or the socket path /var/run/bumblebee.socket was incorrect.
330.156696] [ERROR]Could not connect to bumblebee daemon - is it running?
后来我想 把 nouveau 加进 blacklist 还是不行。
看其他帖子说要在 kate /etc/bumblebee/bumblebee.conf 配置里设置,可是里面同时有 nouveau 和 nvidia 的配置,我是不是应该禁用其中一个 ?
## Section with nvidia driver specific options, only parsed if Driver=nvidia
[driver-nvidia]
# Module name to load, defaults to Driver if empty or unset
KernelDriver=nvidia
PMMethod=auto
# colon-separated path to the nvidia libraries
LibraryPath=/usr/lib64/nvidia:/usr/lib/nvidia
# comma-separated path of the directory containing nvidia_drv.so and the
# default Xorg modules path
XorgModulePath=/usr/lib64/nvidia/xorg/,/usr/lib64/xorg/modules
XorgConfFile=/etc/bumblebee/xorg.conf.nvidia
## Section with nouveau driver specific options, only parsed if Driver=nouveau
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
XorgConfFile=/etc/bumblebee/xorg.conf.nouveau
openSUSE 开机没事,可是稍微以运行软件就会风扇呼呼转,受不了。独显是 Nvidia GT640M 支持 optimus ,希望得到解答啊,不要让我去找其他答案了,因为我解决这个问题已经一年了,几乎找遍了,
