openSUSE 13.1 64bit 每次运行 MyEclipse 10 64bit 都会莫名其妙地崩溃。
修改 myeclipse.ini,修改 jdk 都无法解决,求解。
我的系统配置如下:
Intel Core i5
6G RAM
终端提示:
Architecture: Linux/amd64
Redirecting System.out and System.err to /opt/MyEclipse/Common/logs/profile-rmb-6839664-console.log
A fatal error has been detected by the Java Runtime Environment:
SIGSEGV (0xb) at pc=0x00007f51589776b8, pid=5362, tid=139987674089216
JRE version: Java™ SE Runtime Environment (7.0_45-b18) (build 1.7.0_45-b18)
Java VM: Java HotSpot™ 64-Bit Server VM (24.45-b08 mixed mode linux-amd64 compressed oops)
Problematic frame:
C [libgobject-2.0.so.0+0x1a6b8] g_object_get_qdata+0x18
Failed to write core dump. Core dumps have been disabled. To enable core dumping, try “ulimit -c unlimited” before starting Java again
An error report file with more information is saved as:
/opt/MyEclipse/MyEclipse 10/hs_err_pid5362.log
Compiled method (nm) 183634 1954 n org.eclipse.swt.internal.gtk.OS::_g_object_get_qdata (native)
total in heap [0x00007f515c4ec410,0x00007f515c4ec790] = 896
relocation [0x00007f515c4ec530,0x00007f515c4ec590] = 96
main code [0x00007f515c4ec5a0,0x00007f515c4ec790] = 496
