13.2 Win8.1 双系统
现在的问题是 openSUSE 无法关机,关机之后会出会断电个 2–4 秒吧,以为是关了,结果又重新开机(主机比较远。没法去确定主机是否也断电了),目前是能确定 usb-hub 是断电几秒(一般就是主机一供电这里就亮灯的)
看 “sudo journalctl --since 你关机的时间”
其实我发现 13.1 在晚上 1 点多关机几乎每次都会出这个毛病。别的时候我还没发现
抱歉回复晚了这两天不怎么在家呆着,拜个晚年,新年快乐,身体健康万事如意~~~~
以下是 log… 看了一会儿… 实在看不太懂了, 我把今天凌晨 1:30:01 秒 --1:30:07 秒的关机前记录也复制过来了
2 月 21 01:30:01 linux-50zl systemd[28160]: pam_unix(systemd-user:session): session opened for user root by (uid=0)
2 月 21 01:30:01 linux-50zl CRON[28159]: pam_unix(crond:session): session closed for user root
2 月 21 01:30:01 linux-50zl systemd[28161]: pam_unix(systemd-user:session): session closed for user root
2 月 21 01:30:06 linux-50zl polkitd[1055]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.27, object path /org
2 月 21 01:30:06 linux-50zl org.kde.kuiserver[1572]: kuiserver: Fatal IO error: client killed
2 月 21 01:30:06 linux-50zl org.freedesktop.FileManager1[1572]: Warning: ktorrent: Fatal IO error: client killed
2 月 21 01:30:06 linux-50zl ca.desrt.dconf[1572]: g_dbus_connection_real_closed: Remote peer vanished with error: Underlying GIOStream r
2 月 21 01:30:06 linux-50zl org.a11y.atspi.Registry[18757]: XIO: fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
2 月 21 01:30:06 linux-50zl org.a11y.atspi.Registry[18757]: after 35505 requests (35505 known processed) with 0 events remaining.
2 月 21 01:30:06 linux-50zl org.a11y.Bus[1572]: g_dbus_connection_real_closed: Remote peer vanished with error: Underlying GIOStream ret
2 月 21 01:30:06 linux-50zl org.gtk.vfs.Daemon[1572]: A connection to the bus can't be made
2 月 21 01:30:06 linux-50zl org.gtk.vfs.Daemon[1572]: g_dbus_connection_real_closed: Remote peer vanished with error: Underlying GIOStre
2 月 21 01:30:06 linux-50zl org.freedesktop.Tracker1[1572]: Received signal:15->'已终止'
2 月 21 01:30:06 linux-50zl org.freedesktop.Tracker1[1572]: OK
2 月 21 01:30:06 linux-50zl org.freedesktop.Tracker1[1572]: g_dbus_connection_real_closed: Remote peer vanished with error: Underlying G
2 月 21 01:30:06 linux-50zl org.gtk.Private.UDisks2VolumeMonitor[1572]: g_dbus_connection_real_closed: Remote peer vanished with error:
2 月 21 01:30:06 linux-50zl org.gtk.Private.MTPVolumeMonitor[1572]: g_dbus_connection_real_closed: Remote peer vanished with error: Unde
2 月 21 01:30:06 linux-50zl org.gtk.Private.GoaVolumeMonitor[1572]: g_dbus_connection_real_closed: Remote peer vanished with error: Unde
2 月 21 01:30:06 linux-50zl org.gnome.OnlineAccounts[1572]: g_dbus_connection_real_closed: Remote peer vanished with error: Underlying G
2 月 21 01:30:06 linux-50zl org.gtk.Private.GPhoto2VolumeMonitor[1572]: g_dbus_connection_real_closed: Remote peer vanished with error:
2 月 21 01:30:06 linux-50zl org.gtk.Private.AfcVolumeMonitor[1572]: g_dbus_connection_real_closed: Remote peer vanished with error: Unde
2 月 21 01:30:06 linux-50zl kernel: SFW2-INext-DROP-DEFLT IN=enp4s0 OUT= MAC= SRC=fe80:0000:0000:0000:02e0:09ff:fe06:2e0c DST=ff02:0000:
2 月 21 01:30:06 linux-50zl kdm[1364]: :0[1364]: pam_unix(xdm:session): session closed for user R6l
2 月 21 01:30:07 linux-50zl bluetoothd[1754]: Terminating
2 月 21 01:30:07 linux-50zl bluetoothd[1754]: Stopping SDP server
2 月 21 01:30:07 linux-50zl bluetoothd[1754]: Exit
2 月 21 01:30:07 linux-50zl systemd[1511]: pam_unix(systemd-user:session): session closed for user R6l
2 月 21 01:30:07 linux-50zl avahi-daemon[1023]: Got SIGTERM, quitting.
2 月 21 01:30:07 linux-50zl ModemManager[1025]: <info> Caught signal, shutting down...
2 月 21 01:30:07 linux-50zl avahi-daemon[1023]: Leaving mDNS multicast group on interface enp4s0.IPv6 with address fe80::2e0:9ff:fe06:2e
2 月 21 01:30:07 linux-50zl avahi-daemon[1023]: Leaving mDNS multicast group on interface enp4s0.IPv4 with address 192.168.3.5.
2 月 21 01:30:07 linux-50zl avahi-daemon[1023]: avahi-daemon 0.6.31 exiting.
2 月 21 01:30:07 linux-50zl NetworkManager[1149]: <info> ModemManager disappeared from bus
2 月 21 01:30:07 linux-50zl ModemManager[1025]: <info> ModemManager is shut down
2 月 21 01:30:07 linux-50zl NetworkManager[1149]: <info> wpa_supplicant stopped
2 月 21 01:30:07 linux-50zl NetworkManager[1149]: <warn> disconnected by the system bus.
2 月 21 01:30:07 linux-50zl ntfs-3g[23890]: Unmounting /dev/sdb2 (Entertainment)
2 月 21 01:30:07 linux-50zl ntfs-3g[23421]: Unmounting /dev/sdf (新加卷)
2 月 21 01:30:07 linux-50zl ntfs-3g[20687]: Unmounting /dev/sdd1 ()
2 月 21 01:30:07 linux-50zl kernel: SFW2-INext-DROP-DEFLT IN=enp4s0 OUT= MAC= SRC=fe80:0000:0000:0000:02e0:09ff:fe06:2e0c DST=ff02:0000:
2 月 21 01:30:07 linux-50zl kernel: sdf: unknown partition table
2 月 21 01:30:07 linux-50zl NetworkManager[1149]: g_dbus_connection_real_closed: Remote peer vanished with error: Error sending message:
2 月 21 01:30:07 linux-50zl iscsiadm[28239]: iscsiadm: No matching sessions found
2 月 21 01:30:07 linux-50zl SuSEfirewall2[28280]: Not unloading firewall rules at system shutdown
2 月 21 01:30:07 linux-50zl postfix/postfix-script[28291]: stopping the Postfix mail system
2 月 21 01:30:07 linux-50zl postfix/master[19759]: terminating on signal 15
2 月 21 01:30:07 linux-50zl NetworkManager[1149]: <info> caught signal 15, shutting down normally.
2 月 21 01:30:07 linux-50zl NetworkManager[1149]: <info> (eno1): device state change: unavailable -> unmanaged (reason 'removed') [20 10
2 月 21 01:30:07 linux-50zl display-manager[28246]: Shutting down service kdm..done
2 月 21 01:30:07 linux-50zl kernel: e1000e: eno1 NIC Link is Down
2 月 21 01:30:07 linux-50zl NetworkManager[1149]: (NetworkManager:1149): GLib-CRITICAL **: Source ID 21 was not found when attempting to
2 月 21 01:30:07 linux-50zl NetworkManager[1149]: <info> exiting (success)
2 月 21 01:30:12 linux-50zl haveged[460]: haveged: Stopping due to signal 15
2 月 21 01:30:12 linux-50zl haveged[460]: haveged starting up
2 月 21 01:30:12 linux-50zl auditd[834]: The audit daemon is exiting.
2 月 21 01:30:12 linux-50zl kernel: audit: type=1300 audit(1424453412.310:780): arch=c000003e syscall=1 success=yes exit=21 a0=1 a1=7f93
2 月 21 01:30:12 linux-50zl kernel: audit: type=1400 audit(1424453412.310:780): apparmor="STATUS" operation="profile_remove" name="/usr/
2 月 21 01:30:12 linux-50zl kernel: audit: type=1305 audit(1424453412.310:779): audit_pid=0 old=834 auid=4294967295 ses=4294967295 res=1
2 月 21 01:30:12 linux-50zl kernel: audit: type=1327 audit(1424453412.310:780): proctitle=2F62696E2F7368002F6574632F696E69742E642F626F6F
2 月 21 01:30:12 linux-50zl kernel: audit: type=1400 audit(1424453412.310:781): apparmor="STATUS" operation="profile_remove" name="/usr/
2 月 21 01:30:12 linux-50zl kernel: audit: type=1300 audit(1424453412.310:781): arch=c000003e syscall=1 success=yes exit=23 a0=1 a1=7f93
2 月 21 01:30:12 linux-50zl kernel: audit: type=1327 audit(1424453412.310:781): proctitle=2F62696E2F7368002F6574632F696E69742E642F626F6F
2 月 21 01:30:12 linux-50zl kernel: audit: type=1400 audit(1424453412.310:782): apparmor="STATUS" operation="profile_remove" name="/usr/
2 月 21 01:30:12 linux-50zl kernel: audit: type=1300 audit(1424453412.310:782): arch=c000003e syscall=1 success=yes exit=24 a0=1 a1=7f93
2 月 21 01:30:12 linux-50zl kernel: audit: type=1327 audit(1424453412.310:782): proctitle=2F62696E2F7368002F6574632F696E69742E642F626F6F
2 月 21 01:30:12 linux-50zl boot.apparmor[28323]: Unloading AppArmor profiles ..done
2 月 21 01:30:12 linux-50zl systemd-journal[428]: Journal stopped
-- Reboot --
2 月 21 10:21:54 linux-50zl systemd-journal[176]: Runtime journal is using 8.0M (max allowed 396.8M, trying to leave 595.2M free of 3.8G
2 月 21 10:21:54 linux-50zl kernel: CPU0 microcode updated early to revision 0x1c, date = 2014-07-03
2 月 21 10:21:54 linux-50zl kernel: Initializing cgroup subsys cpuset
2 月 21 10:21:54 linux-50zl kernel: Initializing cgroup subsys cpuacct
2 月 21 10:21:54 linux-50zl kernel: Linux version 3.16.7-7-desktop (geeko@buildhost) (gcc version 4.8.3 20140627 [gcc-4_8-branch revisio
2 月 21 10:21:54 linux-50zl kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-3.16.7-7-desktop root=UUID=da625858-43b9-413a-b151-943cfc1640
2 月 21 10:21:54 linux-50zl kernel: e820: BIOS-provided physical RAM map:
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x0000000000059000-0x000000000009efff] usable
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000bb153fff] usable
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x00000000bb154000-0x00000000bb15afff] ACPI NVS
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x00000000bb15b000-0x00000000bc169fff] usable
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x00000000bc16a000-0x00000000bc66ffff] reserved
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x00000000bc670000-0x00000000ce792fff] usable
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x00000000ce793000-0x00000000ce9a6fff] reserved
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x00000000ce9a7000-0x00000000cea92fff] ACPI NVS
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x00000000cea93000-0x00000000cf7fefff] reserved
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x00000000cf7ff000-0x00000000cf7fffff] usable
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
2 月 21 10:21:54 linux-50zl kernel: BIOS-e820: [mem 0x0000000100000000-0x000000022dffffff] usable
2 月 21 10:21:54 linux-50zl kernel: NX (Execute Disable) protection: active
2 月 21 10:21:54 linux-50zl kernel: e820: update [mem 0xbae4e018-0xbae6da57] usable ==> usable
2 月 21 10:21:54 linux-50zl kernel: e820: update [mem 0xbae3d018-0xbae4d457] usable ==> usable
2 月 21 10:21:54 linux-50zl kernel: extended physical RAM map:
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x0000000000000000-0x0000000000057fff] usable
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x0000000000058000-0x0000000000058fff] reserved
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x0000000000059000-0x000000000009efff] usable
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x000000000009f000-0x000000000009ffff] reserved
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x0000000000100000-0x00000000bae3d017] usable
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000bae3d018-0x00000000bae4d457] usable
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000bae4d458-0x00000000bae4e017] usable
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000bae4e018-0x00000000bae6da57] usable
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000bae6da58-0x00000000bb153fff] usable
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000bb154000-0x00000000bb15afff] ACPI NVS
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000bb15b000-0x00000000bc169fff] usable
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000bc16a000-0x00000000bc66ffff] reserved
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000bc670000-0x00000000ce792fff] usable
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000ce793000-0x00000000ce9a6fff] reserved
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000ce9a7000-0x00000000cea92fff] ACPI NVS
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000cea93000-0x00000000cf7fefff] reserved
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000cf7ff000-0x00000000cf7fffff] usable
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
2 月 21 10:21:54 linux-50zl kernel: reserve setup_data: [mem 0x0000000100000000-0x000000022dffffff] usable
2 月 21 10:21:54 linux-50zl kernel: efi: EFI v2.31 by American Megatrends
2 月 21 10:21:54 linux-50zl kernel: efi: ACPI=0xcea6b000 ACPI 2.0=0xcea6b000 SMBIOS=0xf04c0 MPS=0xfd450
2 月 21 10:21:54 linux-50zl kernel: efi: mem00: type=3, attr=0xf, range=[0x0000000000000000-0x0000000000008000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem01: type=2, attr=0xf, range=[0x0000000000008000-0x0000000000009000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem02: type=7, attr=0xf, range=[0x0000000000009000-0x0000000000058000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem03: type=0, attr=0xf, range=[0x0000000000058000-0x0000000000059000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem04: type=7, attr=0xf, range=[0x0000000000059000-0x000000000005f000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem05: type=4, attr=0xf, range=[0x000000000005f000-0x0000000000060000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem06: type=3, attr=0xf, range=[0x0000000000060000-0x000000000009f000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem07: type=6, attr=0x800000000000000f, range=[0x000000000009f000-0x00000000000a0000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem08: type=7, attr=0xf, range=[0x0000000000100000-0x0000000001000000) (15MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem09: type=2, attr=0xf, range=[0x0000000001000000-0x00000000024b9000) (20MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem10: type=7, attr=0xf, range=[0x00000000024b9000-0x000000003f86b000) (979MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem11: type=2, attr=0xf, range=[0x000000003f86b000-0x0000000040000000) (7MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem12: type=7, attr=0xf, range=[0x0000000040000000-0x0000000088907000) (1161MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem13: type=2, attr=0xf, range=[0x0000000088907000-0x00000000b87bb000) (766MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem14: type=7, attr=0xf, range=[0x00000000b87bb000-0x00000000bae3d000) (38MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem15: type=2, attr=0xf, range=[0x00000000bae3d000-0x00000000bb02f000) (1MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem16: type=1, attr=0xf, range=[0x00000000bb02f000-0x00000000bb154000) (1MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem17: type=10, attr=0xf, range=[0x00000000bb154000-0x00000000bb15b000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem18: type=4, attr=0xf, range=[0x00000000bb15b000-0x00000000bb2eb000) (1MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem19: type=3, attr=0xf, range=[0x00000000bb2eb000-0x00000000bc13b000) (14MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem20: type=4, attr=0xf, range=[0x00000000bc13b000-0x00000000bc14c000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem21: type=3, attr=0xf, range=[0x00000000bc14c000-0x00000000bc15e000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem22: type=4, attr=0xf, range=[0x00000000bc15e000-0x00000000bc168000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem23: type=3, attr=0xf, range=[0x00000000bc168000-0x00000000bc16a000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem24: type=6, attr=0x800000000000000f, range=[0x00000000bc16a000-0x00000000bc670000) (5MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem25: type=4, attr=0xf, range=[0x00000000bc670000-0x00000000bc6ab000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem26: type=7, attr=0xf, range=[0x00000000bc6ab000-0x00000000bc6b6000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem27: type=2, attr=0xf, range=[0x00000000bc6b6000-0x00000000bc6ba000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem28: type=7, attr=0xf, range=[0x00000000bc6ba000-0x00000000bfad6000) (52MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem29: type=4, attr=0xf, range=[0x00000000bfad6000-0x00000000bfaea000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem30: type=7, attr=0xf, range=[0x00000000bfaea000-0x00000000bfaef000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem31: type=4, attr=0xf, range=[0x00000000bfaef000-0x00000000bfb03000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem32: type=7, attr=0xf, range=[0x00000000bfb03000-0x00000000bfb08000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem33: type=4, attr=0xf, range=[0x00000000bfb08000-0x00000000bfb1d000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem34: type=7, attr=0xf, range=[0x00000000bfb1d000-0x00000000bfb23000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem35: type=4, attr=0xf, range=[0x00000000bfb23000-0x00000000bfb30000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem36: type=7, attr=0xf, range=[0x00000000bfb30000-0x00000000bfb34000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem37: type=4, attr=0xf, range=[0x00000000bfb34000-0x00000000bfb47000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem38: type=7, attr=0xf, range=[0x00000000bfb47000-0x00000000bfb52000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem39: type=4, attr=0xf, range=[0x00000000bfb52000-0x00000000bfb78000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem40: type=7, attr=0xf, range=[0x00000000bfb78000-0x00000000bfb83000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem41: type=4, attr=0xf, range=[0x00000000bfb83000-0x00000000bfc19000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem42: type=7, attr=0xf, range=[0x00000000bfc19000-0x00000000bfc84000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem43: type=4, attr=0xf, range=[0x00000000bfc84000-0x00000000bfc87000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem44: type=7, attr=0xf, range=[0x00000000bfc87000-0x00000000bfcb9000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem45: type=4, attr=0xf, range=[0x00000000bfcb9000-0x00000000bfcba000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem46: type=7, attr=0xf, range=[0x00000000bfcba000-0x00000000bfce7000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem47: type=4, attr=0xf, range=[0x00000000bfce7000-0x00000000bfce9000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem48: type=7, attr=0xf, range=[0x00000000bfce9000-0x00000000bfd02000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem49: type=4, attr=0xf, range=[0x00000000bfd02000-0x00000000bfd17000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem50: type=7, attr=0xf, range=[0x00000000bfd17000-0x00000000bfd47000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem51: type=4, attr=0xf, range=[0x00000000bfd47000-0x00000000bfd48000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem52: type=7, attr=0xf, range=[0x00000000bfd48000-0x00000000bfd83000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem53: type=4, attr=0xf, range=[0x00000000bfd83000-0x00000000bfdee000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem54: type=7, attr=0xf, range=[0x00000000bfdee000-0x00000000bfe33000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem55: type=4, attr=0xf, range=[0x00000000bfe33000-0x00000000bfe36000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem56: type=7, attr=0xf, range=[0x00000000bfe36000-0x00000000bfe37000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem57: type=4, attr=0xf, range=[0x00000000bfe37000-0x00000000bfe38000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem58: type=7, attr=0xf, range=[0x00000000bfe38000-0x00000000bfe6b000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem59: type=4, attr=0xf, range=[0x00000000bfe6b000-0x00000000bfec5000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem60: type=7, attr=0xf, range=[0x00000000bfec5000-0x00000000bff02000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem61: type=4, attr=0xf, range=[0x00000000bff02000-0x00000000bff4c000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem62: type=7, attr=0xf, range=[0x00000000bff4c000-0x00000000bff6c000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem63: type=4, attr=0xf, range=[0x00000000bff6c000-0x00000000bfff9000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem64: type=7, attr=0xf, range=[0x00000000bfff9000-0x00000000bfffe000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem65: type=4, attr=0xf, range=[0x00000000bfffe000-0x00000000c0013000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem66: type=7, attr=0xf, range=[0x00000000c0013000-0x00000000c0018000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem67: type=4, attr=0xf, range=[0x00000000c0018000-0x00000000c002b000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem68: type=7, attr=0xf, range=[0x00000000c002b000-0x00000000c0031000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem69: type=4, attr=0xf, range=[0x00000000c0031000-0x00000000c003f000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem70: type=7, attr=0xf, range=[0x00000000c003f000-0x00000000c0043000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem71: type=4, attr=0xf, range=[0x00000000c0043000-0x00000000c0056000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem72: type=7, attr=0xf, range=[0x00000000c0056000-0x00000000c0061000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem73: type=4, attr=0xf, range=[0x00000000c0061000-0x00000000c0086000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem74: type=7, attr=0xf, range=[0x00000000c0086000-0x00000000c0091000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem75: type=4, attr=0xf, range=[0x00000000c0091000-0x00000000c012c000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem76: type=7, attr=0xf, range=[0x00000000c012c000-0x00000000c012e000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem77: type=4, attr=0xf, range=[0x00000000c012e000-0x00000000c01b0000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem78: type=7, attr=0xf, range=[0x00000000c01b0000-0x00000000c01b5000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem79: type=4, attr=0xf, range=[0x00000000c01b5000-0x00000000c01c8000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem80: type=7, attr=0xf, range=[0x00000000c01c8000-0x00000000c01cd000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem81: type=4, attr=0xf, range=[0x00000000c01cd000-0x00000000c01e2000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem82: type=7, attr=0xf, range=[0x00000000c01e2000-0x00000000c01e8000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem83: type=4, attr=0xf, range=[0x00000000c01e8000-0x00000000c01f5000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem84: type=7, attr=0xf, range=[0x00000000c01f5000-0x00000000c01f9000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem85: type=4, attr=0xf, range=[0x00000000c01f9000-0x00000000c020d000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem86: type=7, attr=0xf, range=[0x00000000c020d000-0x00000000c0218000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem87: type=4, attr=0xf, range=[0x00000000c0218000-0x00000000c023e000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem88: type=7, attr=0xf, range=[0x00000000c023e000-0x00000000c0249000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem89: type=4, attr=0xf, range=[0x00000000c0249000-0x00000000c0301000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem90: type=7, attr=0xf, range=[0x00000000c0301000-0x00000000c030a000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem91: type=4, attr=0xf, range=[0x00000000c030a000-0x00000000c0363000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem92: type=7, attr=0xf, range=[0x00000000c0363000-0x00000000c0368000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem93: type=4, attr=0xf, range=[0x00000000c0368000-0x00000000c037e000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem94: type=7, attr=0xf, range=[0x00000000c037e000-0x00000000c0383000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem95: type=4, attr=0xf, range=[0x00000000c0383000-0x00000000c0396000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem96: type=7, attr=0xf, range=[0x00000000c0396000-0x00000000c039c000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem97: type=4, attr=0xf, range=[0x00000000c039c000-0x00000000c03c1000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem98: type=7, attr=0xf, range=[0x00000000c03c1000-0x00000000c03cc000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem99: type=4, attr=0xf, range=[0x00000000c03cc000-0x00000000c03f2000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem100: type=7, attr=0xf, range=[0x00000000c03f2000-0x00000000c03fd000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem101: type=4, attr=0xf, range=[0x00000000c03fd000-0x00000000c0517000) (1MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem102: type=7, attr=0xf, range=[0x00000000c0517000-0x00000000c051c000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem103: type=4, attr=0xf, range=[0x00000000c051c000-0x00000000c0530000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem104: type=7, attr=0xf, range=[0x00000000c0530000-0x00000000c0535000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem105: type=4, attr=0xf, range=[0x00000000c0535000-0x00000000c0549000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem106: type=7, attr=0xf, range=[0x00000000c0549000-0x00000000c054f000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem107: type=4, attr=0xf, range=[0x00000000c054f000-0x00000000c055c000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem108: type=7, attr=0xf, range=[0x00000000c055c000-0x00000000c0560000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem109: type=4, attr=0xf, range=[0x00000000c0560000-0x00000000c0575000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem110: type=7, attr=0xf, range=[0x00000000c0575000-0x00000000c0580000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem111: type=4, attr=0xf, range=[0x00000000c0580000-0x00000000c05a5000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem112: type=7, attr=0xf, range=[0x00000000c05a5000-0x00000000c05b0000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem113: type=4, attr=0xf, range=[0x00000000c05b0000-0x00000000c064c000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem114: type=7, attr=0xf, range=[0x00000000c064c000-0x00000000c064f000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem115: type=4, attr=0xf, range=[0x00000000c064f000-0x00000000c0754000) (1MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem116: type=7, attr=0xf, range=[0x00000000c0754000-0x00000000c0755000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem117: type=4, attr=0xf, range=[0x00000000c0755000-0x00000000c07b0000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem118: type=7, attr=0xf, range=[0x00000000c07b0000-0x00000000c07b2000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem119: type=4, attr=0xf, range=[0x00000000c07b2000-0x00000000c0c4c000) (4MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem120: type=7, attr=0xf, range=[0x00000000c0c4c000-0x00000000c0c59000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem121: type=4, attr=0xf, range=[0x00000000c0c59000-0x00000000c0cad000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem122: type=7, attr=0xf, range=[0x00000000c0cad000-0x00000000c0caf000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem123: type=4, attr=0xf, range=[0x00000000c0caf000-0x00000000c0ce6000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem124: type=7, attr=0xf, range=[0x00000000c0ce6000-0x00000000c0ce8000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem125: type=4, attr=0xf, range=[0x00000000c0ce8000-0x00000000c0e58000) (1MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem126: type=7, attr=0xf, range=[0x00000000c0e58000-0x00000000c0e59000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem127: type=4, attr=0xf, range=[0x00000000c0e59000-0x00000000c0e60000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem128: type=7, attr=0xf, range=[0x00000000c0e60000-0x00000000c0e62000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem129: type=4, attr=0xf, range=[0x00000000c0e62000-0x00000000c0e6f000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem130: type=7, attr=0xf, range=[0x00000000c0e6f000-0x00000000c0e72000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem131: type=4, attr=0xf, range=[0x00000000c0e72000-0x00000000c0e7e000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem132: type=7, attr=0xf, range=[0x00000000c0e7e000-0x00000000c0e7f000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem133: type=4, attr=0xf, range=[0x00000000c0e7f000-0x00000000cd14c000) (194MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem134: type=7, attr=0xf, range=[0x00000000cd14c000-0x00000000ce46b000) (19MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem135: type=3, attr=0xf, range=[0x00000000ce46b000-0x00000000ce793000) (3MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem136: type=0, attr=0xf, range=[0x00000000ce793000-0x00000000ce7fe000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem137: type=0, attr=0xf, range=[0x00000000ce7fe000-0x00000000ce9a7000) (1MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem138: type=10, attr=0xf, range=[0x00000000ce9a7000-0x00000000ce9d8000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem139: type=10, attr=0xf, range=[0x00000000ce9d8000-0x00000000cea83000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem140: type=10, attr=0xf, range=[0x00000000cea83000-0x00000000cea88000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem141: type=10, attr=0xf, range=[0x00000000cea88000-0x00000000cea93000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem142: type=6, attr=0x800000000000000f, range=[0x00000000cea93000-0x00000000cf21d000) (7MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem143: type=6, attr=0x800000000000000f, range=[0x00000000cf21d000-0x00000000cf50f000) (2MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem144: type=6, attr=0x800000000000000f, range=[0x00000000cf50f000-0x00000000cf512000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem145: type=6, attr=0x800000000000000f, range=[0x00000000cf512000-0x00000000cf732000) (2MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem146: type=5, attr=0x800000000000000f, range=[0x00000000cf732000-0x00000000cf75b000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem147: type=5, attr=0x800000000000000f, range=[0x00000000cf75b000-0x00000000cf7ff000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem148: type=4, attr=0xf, range=[0x00000000cf7ff000-0x00000000cf800000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem149: type=7, attr=0xf, range=[0x0000000100000000-0x000000022e000000) (4832MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem150: type=11, attr=0x8000000000000001, range=[0x00000000f8000000-0x00000000fc000000) (64MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem151: type=11, attr=0x8000000000000001, range=[0x00000000fec00000-0x00000000fec01000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem152: type=11, attr=0x8000000000000001, range=[0x00000000fed00000-0x00000000fed04000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem153: type=11, attr=0x8000000000000001, range=[0x00000000fed1c000-0x00000000fed20000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem154: type=11, attr=0x8000000000000001, range=[0x00000000fee00000-0x00000000fee01000) (0MB)
2 月 21 10:21:54 linux-50zl kernel: efi: mem155: type=11, attr=0x8000000000000001, range=[0x00000000ff000000-0x0000000100000000) (16MB)
2 月 21 10:21:54 linux-50zl kernel: SMBIOS 2.7 present.
2 月 21 10:21:54 linux-50zl kernel: DMI: Gigabyte Technology Co., Ltd. G1.Sniper B5/G1.Sniper B5-CF, BIOS F5 08/03/2013
2 月 21 10:21:54 linux-50zl kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
2 月 21 10:21:54 linux-50zl kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
2 月 21 10:21:54 linux-50zl kernel: AGP: No AGP bridge found
2 月 21 10:21:54 linux-50zl kernel: e820: last_pfn = 0x22e000 max_arch_pfn = 0x400000000
2 月 21 10:21:54 linux-50zl kernel: MTRR default type: uncachable
2 月 21 10:21:54 linux-50zl kernel: MTRR fixed ranges enabled:
2 月 21 10:21:54 linux-50zl kernel: 00000-9FFFF write-back
2 月 21 10:21:54 linux-50zl kernel: A0000-BFFFF uncachable
2 月 21 10:21:54 linux-50zl kernel: C0000-CFFFF write-protect
2 月 21 10:21:54 linux-50zl kernel: D0000-DFFFF uncachable
2 月 21 10:21:54 linux-50zl kernel: E0000-FFFFF write-protect
2 月 21 10:21:54 linux-50zl kernel: MTRR variable ranges enabled:
2 月 21 10:21:54 linux-50zl kernel: 0 base 0000000000 mask 7E00000000 write-back
2 月 21 10:21:54 linux-50zl kernel: 1 base 0200000000 mask 7FE0000000 write-back
2 月 21 10:21:54 linux-50zl kernel: 2 base 0220000000 mask 7FF8000000 write-back
2 月 21 10:21:54 linux-50zl kernel: 3 base 0228000000 mask 7FFC000000 write-back
2 月 21 10:21:54 linux-50zl kernel: 4 base 022C000000 mask 7FFE000000 write-back
2 月 21 10:21:54 linux-50zl kernel: 5 base 00E0000000 mask 7FE0000000 uncachable
2 月 21 10:21:54 linux-50zl kernel: 6 base 00D0000000 mask 7FF0000000 uncachable
2 月 21 10:21:54 linux-50zl kernel: 7 disabled
2 月 21 10:21:54 linux-50zl kernel: 8 disabled
2 月 21 10:21:54 linux-50zl kernel: 9 disabled
2 月 21 10:21:54 linux-50zl kernel: x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
2 月 21 10:21:54 linux-50zl kernel: e820: update [mem 0xd0000000-0xffffffff] usable ==> reserved
2 月 21 10:21:54 linux-50zl kernel: e820: last_pfn = 0xcf800 max_arch_pfn = 0x400000000
2 月 21 10:21:54 linux-50zl kernel: found SMP MP-table at [mem 0x000fd710-0x000fd71f] mapped at [ffff8800000fd710]
2 月 21 10:21:54 linux-50zl kernel: Scanning 1 areas for low memory corruption
2 月 21 10:21:54 linux-50zl kernel: Base memory trampoline at [ffff880000097000] 97000 size 24576
2 月 21 10:21:54 linux-50zl kernel: Using GB pages for direct mapping
2 月 21 10:21:54 linux-50zl kernel: init_memory_mapping: [mem 0x00000000-0x000fffff]
2 月 21 10:21:54 linux-50zl kernel: [mem 0x00000000-0x000fffff] page 4k
2 月 21 10:21:54 linux-50zl kernel: BRK [0x0220b000, 0x0220bfff] PGTABLE
2 月 21 10:21:54 linux-50zl kernel: BRK [0x0220c000, 0x0220cfff] PGTABLE
2 月 21 10:21:54 linux-50zl kernel: BRK [0x0220d000, 0x0220dfff] PGTABLE
2 月 21 10:21:54 linux-50zl kernel: init_memory_mapping: [mem 0x22de00000-0x22dffffff]
2 月 21 10:21:54 linux-50zl kernel: [mem 0x22de00000-0x22dffffff] page 2M
2 月 21 10:21:54 linux-50zl kernel: BRK [0x0220e000, 0x0220efff] PGTABLE
2 月 21 10:21:54 linux-50zl kernel: init_memory_mapping: [mem 0x22c000000-0x22ddfffff]
2 月 21 10:21:54 linux-50zl kernel: [mem 0x22c000000-0x22ddfffff] page 2M
2 月 21 10:21:54 linux-50zl kernel: init_memory_mapping: [mem 0x200000000-0x22bffffff]
2 月 21 10:21:54 linux-50zl kernel: [mem 0x200000000-0x22bffffff] page 2M
2 月 21 10:21:54 linux-50zl kernel: init_memory_mapping: [mem 0x00100000-0xbb153fff]
2 月 21 10:21:54 linux-50zl kernel: [mem 0x00100000-0x001fffff] page 4k
2 月 21 10:21:54 linux-50zl kernel: [mem 0x00200000-0x3fffffff] page 2M
2 月 21 10:21:54 linux-50zl kernel: [mem 0x40000000-0x7fffffff] page 1G
2 月 21 10:21:54 linux-50zl kernel: [mem 0x80000000-0xbaffffff] page 2M
2 月 21 10:21:54 linux-50zl kernel: [mem 0xbb000000-0xbb153fff] page 4k
2 月 21 10:21:54 linux-50zl kernel: init_memory_mapping: [mem 0xbb15b000-0xbc169fff]
2 月 21 10:21:54 linux-50zl kernel: [mem 0xbb15b000-0xbb1fffff] page 4k
2 月 21 10:21:54 linux-50zl kernel: [mem 0xbb200000-0xbbffffff] page 2M
2 月 21 10:21:54 linux-50zl kernel: [mem 0xbc000000-0xbc169fff] page 4k
2 月 21 10:21:54 linux-50zl kernel: BRK [0x0220f000, 0x0220ffff] PGTABLE
2 月 21 10:21:54 linux-50zl kernel: init_memory_mapping: [mem 0xbc670000-0xce792fff]
2 月 21 10:21:54 linux-50zl kernel: [mem 0xbc670000-0xbc7fffff] page 4k
2 月 21 10:21:54 linux-50zl kernel: [mem 0xbc800000-0xce5fffff] page 2M
2 月 21 10:21:54 linux-50zl kernel: [mem 0xce600000-0xce792fff] page 4k
2 月 21 10:21:54 linux-50zl kernel: BRK [0x02210000, 0x02210fff] PGTABLE
2 月 21 10:21:54 linux-50zl kernel: init_memory_mapping: [mem 0xcf7ff000-0xcf7fffff]
2 月 21 10:21:54 linux-50zl kernel: [mem 0xcf7ff000-0xcf7fffff] page 4k
2 月 21 10:21:54 linux-50zl kernel: init_memory_mapping: [mem 0x100000000-0x1ffffffff]
2 月 21 10:21:54 linux-50zl kernel: [mem 0x100000000-0x1ffffffff] page 1G
2 月 21 10:21:54 linux-50zl kernel: RAMDISK: [mem 0x3f86b000-0x3fffafff]
2 月 21 10:21:54 linux-50zl kernel: ACPI: Early table checksum verification disabled
2 月 21 10:21:54 linux-50zl kernel: ACPI: RSDP 0x00000000CEA6B000 000024 (v02 ALASKA)
2 月 21 10:21:54 linux-50zl kernel: ACPI: XSDT 0x00000000CEA6B078 000074 (v01 ALASKA A M I 01072009 AMI 00010013)
2 月 21 10:21:54 linux-50zl kernel: ACPI: FACP 0x00000000CEA76460 00010C (v05 ALASKA A M I 01072009 AMI 00010013)
2 月 21 10:21:54 linux-50zl kernel: ACPI: DSDT 0x00000000CEA6B188 00B2D7 (v02 ALASKA A M I 000000F5 INTL 20091112)
2 月 21 10:21:54 linux-50zl kernel: ACPI: FACS 0x00000000CEA91080 000040
2 月 21 10:21:54 linux-50zl kernel: ACPI: APIC 0x00000000CEA76570 000092 (v03 ALASKA A M I 01072009 AMI 00010013)
2 月 21 10:21:54 linux-50zl kernel: ACPI: FPDT 0x00000000CEA76608 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
2 月 21 10:21:54 linux-50zl kernel: ACPI: SSDT 0x00000000CEA76650 000AD8 (v01 PmRef CpuPm 00003000 INTL 20051117)
2 月 21 10:21:54 linux-50zl kernel: ACPI: MCFG 0x00000000CEA77128 00003C (v01 01072009 MSFT 00000097)
2 月 21 10:21:54 linux-50zl kernel: ACPI: HPET 0x00000000CEA77168 000038 (v01 ALASKA A M I 01072009 AMI. 00000005)
2 月 21 10:21:54 linux-50zl kernel: ACPI: SSDT 0x00000000CEA771A0 00036D (v01 SataRe SataTabl 00001000 INTL 20091112)
2 月 21 10:21:54 linux-50zl kernel: ACPI: SSDT 0x00000000CEA77510 003299 (v01 SaSsdt SaSsdt 00003000 INTL 20091112)
2 月 21 10:21:54 linux-50zl kernel: ACPI: BGRT 0x00000000CEA7A7B0 000038 (v00 ALASKA A M I 01072009 AMI 00010013)
2 月 21 10:21:54 linux-50zl kernel: ACPI: DMAR 0x00000000CEA7A7E8 000080 (v01 INTEL HSW 00000001 INTL 00000001)
2 月 21 10:21:54 linux-50zl kernel: ACPI: Local APIC address 0xfee00000
2 月 21 10:21:54 linux-50zl kernel: No NUMA configuration found
2 月 21 10:21:54 linux-50zl kernel: Faking a node at [mem 0x0000000000000000-0x000000022dffffff]
2 月 21 10:21:54 linux-50zl kernel: Initmem setup node 0 [mem 0x00000000-0x22dffffff]
2 月 21 10:21:54 linux-50zl kernel: NODE_DATA [mem 0x22dfe7000-0x22dffafff]
2 月 21 10:21:54 linux-50zl kernel: [ffffea0000000000-ffffea0007bfffff] PMD -> [ffff880225600000-ffff88022c7fffff] on node 0
2 月 21 10:21:54 linux-50zl kernel: Zone ranges:
2 月 21 10:21:54 linux-50zl kernel: DMA [mem 0x00001000-0x00ffffff]
2 月 21 10:21:54 linux-50zl kernel: DMA32 [mem 0x01000000-0xffffffff]
2 月 21 10:21:54 linux-50zl kernel: Normal [mem 0x100000000-0x22dffffff]
2 月 21 10:21:54 linux-50zl kernel: Movable zone start for each node
2 月 21 10:21:54 linux-50zl kernel: Early memory node ranges
2 月 21 10:21:54 linux-50zl kernel: node 0: [mem 0x00001000-0x00057fff]
2 月 21 10:21:54 linux-50zl kernel: node 0: [mem 0x00059000-0x0009efff]
2 月 21 10:21:54 linux-50zl kernel: node 0: [mem 0x00100000-0xbb153fff]
2 月 21 10:21:55 linux-50zl kernel: nouveau DRM] MM: using COPY for buffer copies
2 月 21 10:21:55 linux-50zl kernel: nouveau DRM] allocated 1920x1080 fb: 0x80000, bo ffff880220d0e400
2 月 21 10:21:55 linux-50zl kernel: fbcon: nouveaufb (fb0) is primary device
2 月 21 10:21:55 linux-50zl kernel: usb 3-10: new high-speed USB device number 2 using xhci_hcd
2 月 21 10:21:55 linux-50zl kernel: tsc: Refined TSC clocksource calibration: 3292.374 MHz
2 月 21 10:21:55 linux-50zl kernel: Console: switching to colour frame buffer device 240x67
2 月 21 10:21:55 linux-50zl kernel: nouveau 0000:01:00.0: fb0: nouveaufb frame buffer device
2 月 21 10:21:55 linux-50zl kernel: nouveau 0000:01:00.0: registered panic notifier
2 月 21 10:21:55 linux-50zl kernel: [drm] Initialized nouveau 1.1.2 20120801 for 0000:01:00.0 on minor 0
2 月 21 10:21:55 linux-50zl kernel: PM: Marking nosave pages: [mem 0x00058000-0x00058fff]
2 月 21 10:21:55 linux-50zl kernel: PM: Marking nosave pages: [mem 0x0009f000-0x000fffff]
2 月 21 10:21:55 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbae3d000-0xbae3dfff]
2 月 21 10:21:55 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbae4d000-0xbae4efff]
2 月 21 10:21:55 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbae6d000-0xbae6dfff]
2 月 21 10:21:55 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbb154000-0xbb15afff]
2 月 21 10:21:55 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbc16a000-0xbc66ffff]
2 月 21 10:21:55 linux-50zl kernel: PM: Marking nosave pages: [mem 0xce793000-0xcf7fefff]
2 月 21 10:21:55 linux-50zl kernel: PM: Marking nosave pages: [mem 0xcf800000-0xffffffff]
2 月 21 10:21:55 linux-50zl kernel: PM: Basic memory bitmaps created
2 月 21 10:21:55 linux-50zl kernel: usb 3-10: New USB device found, idVendor=2109, idProduct=2812
2 月 21 10:21:55 linux-50zl kernel: usb 3-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
2 月 21 10:21:55 linux-50zl kernel: usb 3-10: Product: USB2.0 Hub
2 月 21 10:21:55 linux-50zl kernel: usb 3-10: Manufacturer: VIA Labs, Inc.
2 月 21 10:21:55 linux-50zl kernel: hub 3-10:1.0: USB hub found
2 月 21 10:21:55 linux-50zl kernel: hub 3-10:1.0: 4 ports detected
2 月 21 10:21:55 linux-50zl kernel: PM: Basic memory bitmaps freed
2 月 21 10:21:55 linux-50zl kernel: PM: Starting manual resume from disk
2 月 21 10:21:55 linux-50zl kernel: PM: Hibernation image partition 8:6 present
2 月 21 10:21:55 linux-50zl kernel: PM: Looking for hibernation image.
2 月 21 10:21:55 linux-50zl kernel: PM: Image not found (code -22)
2 月 21 10:21:55 linux-50zl kernel: PM: Hibernation image not present or could not be loaded.
2 月 21 10:21:55 linux-50zl systemd-fsck[328]: /dev/sda7: clean, 294171/1474560 files, 2428452/5890304 blocks
2 月 21 10:21:55 linux-50zl kernel: EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)
2 月 21 10:21:55 linux-50zl kernel: usb 4-6: new SuperSpeed USB device number 2 using xhci_hcd
新年快乐!
我也是啊,我才发现,我这刚刚关机就完全没问题,上次也是大半夜关不上电脑,出这个情况我只能去 Win8 关机才行。。。。
这是刚才一次正常关机之后又正常开机的记录。。。原来已为和 Win8 快速启动有关,之前关了之后试了试发现没问题了,但是昨晚又出问题,现在发现,似乎是只有凌晨出现过这种问题。
2 月 21 10:50:09 linux-50zl systemd-journal[426]: Journal stopped
-- Reboot --
2 月 21 10:51:13 linux-50zl systemd-journal[176]: Runtime journal is using 8.0M (max allowed 396.8M, trying to leave 595.2M free of 3.8G
2 月 21 10:51:13 linux-50zl kernel: CPU0 microcode updated early to revision 0x1c, date = 2014-07-03
2 月 21 10:51:13 linux-50zl kernel: Initializing cgroup subsys cpuset
2 月 21 10:51:13 linux-50zl kernel: Initializing cgroup subsys cpuacct
2 月 21 10:51:13 linux-50zl kernel: Linux version 3.16.7-7-desktop (geeko@buildhost) (gcc version 4.8.3 20140627 [gcc-4_8-branch revisio
2 月 21 10:51:13 linux-50zl kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-3.16.7-7-desktop root=UUID=da625858-43b9-413a-b151-943cfc1640
2 月 21 10:51:13 linux-50zl kernel: e820: BIOS-provided physical RAM map:
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x0000000000059000-0x000000000009efff] usable
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000bb158fff] usable
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x00000000bb159000-0x00000000bb15ffff] ACPI NVS
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x00000000bb160000-0x00000000bc16efff] usable
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x00000000bc16f000-0x00000000bc674fff] reserved
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x00000000bc675000-0x00000000ce792fff] usable
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x00000000ce793000-0x00000000ce9a6fff] reserved
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x00000000ce9a7000-0x00000000cea92fff] ACPI NVS
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x00000000cea93000-0x00000000cf7fefff] reserved
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x00000000cf7ff000-0x00000000cf7fffff] usable
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
2 月 21 10:51:13 linux-50zl kernel: BIOS-e820: [mem 0x0000000100000000-0x000000022dffffff] usable
2 月 21 10:51:13 linux-50zl kernel: NX (Execute Disable) protection: active
2 月 21 10:51:13 linux-50zl kernel: e820: update [mem 0xbae53018-0xbae72a57] usable ==> usable
2 月 21 10:51:13 linux-50zl kernel: e820: update [mem 0xbae42018-0xbae52457] usable ==> usable
2 月 21 10:51:13 linux-50zl kernel: extended physical RAM map:
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x0000000000000000-0x0000000000057fff] usable
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x0000000000058000-0x0000000000058fff] reserved
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x0000000000059000-0x000000000009efff] usable
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x000000000009f000-0x000000000009ffff] reserved
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x0000000000100000-0x00000000bae42017] usable
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000bae42018-0x00000000bae52457] usable
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000bae52458-0x00000000bae53017] usable
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000bae53018-0x00000000bae72a57] usable
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000bae72a58-0x00000000bb158fff] usable
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000bb159000-0x00000000bb15ffff] ACPI NVS
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000bb160000-0x00000000bc16efff] usable
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000bc16f000-0x00000000bc674fff] reserved
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000bc675000-0x00000000ce792fff] usable
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000ce793000-0x00000000ce9a6fff] reserved
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000ce9a7000-0x00000000cea92fff] ACPI NVS
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000cea93000-0x00000000cf7fefff] reserved
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000cf7ff000-0x00000000cf7fffff] usable
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
2 月 21 10:51:13 linux-50zl kernel: reserve setup_data: [mem 0x0000000100000000-0x000000022dffffff] usable
2 月 21 10:51:13 linux-50zl kernel: efi: EFI v2.31 by American Megatrends
2 月 21 10:51:13 linux-50zl kernel: efi: ACPI=0xcea6b000 ACPI 2.0=0xcea6b000 SMBIOS=0xf04c0 MPS=0xfd450
2 月 21 10:51:13 linux-50zl kernel: efi: mem00: type=3, attr=0xf, range=[0x0000000000000000-0x0000000000008000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem01: type=2, attr=0xf, range=[0x0000000000008000-0x0000000000009000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem02: type=7, attr=0xf, range=[0x0000000000009000-0x0000000000058000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem03: type=0, attr=0xf, range=[0x0000000000058000-0x0000000000059000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem04: type=7, attr=0xf, range=[0x0000000000059000-0x000000000005f000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem05: type=4, attr=0xf, range=[0x000000000005f000-0x0000000000060000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem06: type=3, attr=0xf, range=[0x0000000000060000-0x000000000009f000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem07: type=6, attr=0x800000000000000f, range=[0x000000000009f000-0x00000000000a0000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem08: type=7, attr=0xf, range=[0x0000000000100000-0x0000000001000000) (15MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem09: type=2, attr=0xf, range=[0x0000000001000000-0x00000000024b9000) (20MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem10: type=7, attr=0xf, range=[0x00000000024b9000-0x000000003f86b000) (979MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem11: type=2, attr=0xf, range=[0x000000003f86b000-0x0000000040000000) (7MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem12: type=7, attr=0xf, range=[0x0000000040000000-0x000000008890d000) (1161MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem13: type=2, attr=0xf, range=[0x000000008890d000-0x00000000b87c0000) (766MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem14: type=7, attr=0xf, range=[0x00000000b87c0000-0x00000000bae42000) (38MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem15: type=2, attr=0xf, range=[0x00000000bae42000-0x00000000bb034000) (1MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem16: type=1, attr=0xf, range=[0x00000000bb034000-0x00000000bb159000) (1MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem17: type=10, attr=0xf, range=[0x00000000bb159000-0x00000000bb160000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem18: type=4, attr=0xf, range=[0x00000000bb160000-0x00000000bb2f0000) (1MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem19: type=3, attr=0xf, range=[0x00000000bb2f0000-0x00000000bc140000) (14MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem20: type=4, attr=0xf, range=[0x00000000bc140000-0x00000000bc151000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem21: type=3, attr=0xf, range=[0x00000000bc151000-0x00000000bc163000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem22: type=4, attr=0xf, range=[0x00000000bc163000-0x00000000bc16d000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem23: type=3, attr=0xf, range=[0x00000000bc16d000-0x00000000bc16f000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem24: type=6, attr=0x800000000000000f, range=[0x00000000bc16f000-0x00000000bc675000) (5MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem25: type=4, attr=0xf, range=[0x00000000bc675000-0x00000000bc6b0000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem26: type=7, attr=0xf, range=[0x00000000bc6b0000-0x00000000bc6bb000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem27: type=2, attr=0xf, range=[0x00000000bc6bb000-0x00000000bc6bf000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem28: type=7, attr=0xf, range=[0x00000000bc6bf000-0x00000000bfad2000) (52MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem29: type=4, attr=0xf, range=[0x00000000bfad2000-0x00000000bfae6000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem30: type=7, attr=0xf, range=[0x00000000bfae6000-0x00000000bfaeb000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem31: type=4, attr=0xf, range=[0x00000000bfaeb000-0x00000000bfafe000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem32: type=7, attr=0xf, range=[0x00000000bfafe000-0x00000000bfb03000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem33: type=4, attr=0xf, range=[0x00000000bfb03000-0x00000000bfb17000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem34: type=7, attr=0xf, range=[0x00000000bfb17000-0x00000000bfb1d000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem35: type=4, attr=0xf, range=[0x00000000bfb1d000-0x00000000bfb2a000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem36: type=7, attr=0xf, range=[0x00000000bfb2a000-0x00000000bfb2e000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem37: type=4, attr=0xf, range=[0x00000000bfb2e000-0x00000000bfb41000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem38: type=7, attr=0xf, range=[0x00000000bfb41000-0x00000000bfb4c000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem39: type=4, attr=0xf, range=[0x00000000bfb4c000-0x00000000bfb72000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem40: type=7, attr=0xf, range=[0x00000000bfb72000-0x00000000bfb7d000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem41: type=4, attr=0xf, range=[0x00000000bfb7d000-0x00000000bfc15000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem42: type=7, attr=0xf, range=[0x00000000bfc15000-0x00000000bfc7f000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem43: type=4, attr=0xf, range=[0x00000000bfc7f000-0x00000000bfc82000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem44: type=7, attr=0xf, range=[0x00000000bfc82000-0x00000000bfc87000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem45: type=4, attr=0xf, range=[0x00000000bfc87000-0x00000000bfc88000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem46: type=7, attr=0xf, range=[0x00000000bfc88000-0x00000000bfcdf000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem47: type=4, attr=0xf, range=[0x00000000bfcdf000-0x00000000bfce0000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem48: type=7, attr=0xf, range=[0x00000000bfce0000-0x00000000bfce3000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem49: type=4, attr=0xf, range=[0x00000000bfce3000-0x00000000bfce5000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem50: type=7, attr=0xf, range=[0x00000000bfce5000-0x00000000bfcfe000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem51: type=4, attr=0xf, range=[0x00000000bfcfe000-0x00000000bfd13000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem52: type=7, attr=0xf, range=[0x00000000bfd13000-0x00000000bfd7e000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem53: type=4, attr=0xf, range=[0x00000000bfd7e000-0x00000000bfde9000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem54: type=7, attr=0xf, range=[0x00000000bfde9000-0x00000000bfe2e000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem55: type=4, attr=0xf, range=[0x00000000bfe2e000-0x00000000bfe32000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem56: type=7, attr=0xf, range=[0x00000000bfe32000-0x00000000bfe67000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem57: type=4, attr=0xf, range=[0x00000000bfe67000-0x00000000bfec1000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem58: type=7, attr=0xf, range=[0x00000000bfec1000-0x00000000bfefd000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem59: type=4, attr=0xf, range=[0x00000000bfefd000-0x00000000bff47000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem60: type=7, attr=0xf, range=[0x00000000bff47000-0x00000000bff68000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem61: type=4, attr=0xf, range=[0x00000000bff68000-0x00000000bfff5000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem62: type=7, attr=0xf, range=[0x00000000bfff5000-0x00000000bfffa000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem63: type=4, attr=0xf, range=[0x00000000bfffa000-0x00000000c000e000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem64: type=7, attr=0xf, range=[0x00000000c000e000-0x00000000c0013000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem65: type=4, attr=0xf, range=[0x00000000c0013000-0x00000000c0027000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem66: type=7, attr=0xf, range=[0x00000000c0027000-0x00000000c002d000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem67: type=4, attr=0xf, range=[0x00000000c002d000-0x00000000c003b000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem68: type=7, attr=0xf, range=[0x00000000c003b000-0x00000000c003f000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem69: type=4, attr=0xf, range=[0x00000000c003f000-0x00000000c0052000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem70: type=7, attr=0xf, range=[0x00000000c0052000-0x00000000c005d000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem71: type=4, attr=0xf, range=[0x00000000c005d000-0x00000000c0082000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem72: type=7, attr=0xf, range=[0x00000000c0082000-0x00000000c008d000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem73: type=4, attr=0xf, range=[0x00000000c008d000-0x00000000c0127000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem74: type=7, attr=0xf, range=[0x00000000c0127000-0x00000000c0129000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem75: type=4, attr=0xf, range=[0x00000000c0129000-0x00000000c01ab000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem76: type=7, attr=0xf, range=[0x00000000c01ab000-0x00000000c01b0000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem77: type=4, attr=0xf, range=[0x00000000c01b0000-0x00000000c01c3000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem78: type=7, attr=0xf, range=[0x00000000c01c3000-0x00000000c01c8000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem79: type=4, attr=0xf, range=[0x00000000c01c8000-0x00000000c01dc000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem80: type=7, attr=0xf, range=[0x00000000c01dc000-0x00000000c01e2000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem81: type=4, attr=0xf, range=[0x00000000c01e2000-0x00000000c01ef000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem82: type=7, attr=0xf, range=[0x00000000c01ef000-0x00000000c01f3000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem83: type=4, attr=0xf, range=[0x00000000c01f3000-0x00000000c0209000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem84: type=7, attr=0xf, range=[0x00000000c0209000-0x00000000c0214000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem85: type=4, attr=0xf, range=[0x00000000c0214000-0x00000000c0239000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem86: type=7, attr=0xf, range=[0x00000000c0239000-0x00000000c0244000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem87: type=4, attr=0xf, range=[0x00000000c0244000-0x00000000c02fc000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem88: type=7, attr=0xf, range=[0x00000000c02fc000-0x00000000c0305000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem89: type=4, attr=0xf, range=[0x00000000c0305000-0x00000000c035f000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem90: type=7, attr=0xf, range=[0x00000000c035f000-0x00000000c0364000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem91: type=4, attr=0xf, range=[0x00000000c0364000-0x00000000c0377000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem92: type=7, attr=0xf, range=[0x00000000c0377000-0x00000000c037c000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem93: type=4, attr=0xf, range=[0x00000000c037c000-0x00000000c0390000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem94: type=7, attr=0xf, range=[0x00000000c0390000-0x00000000c0396000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem95: type=4, attr=0xf, range=[0x00000000c0396000-0x00000000c03bc000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem96: type=7, attr=0xf, range=[0x00000000c03bc000-0x00000000c03c7000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem97: type=4, attr=0xf, range=[0x00000000c03c7000-0x00000000c03ed000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem98: type=7, attr=0xf, range=[0x00000000c03ed000-0x00000000c03f8000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem99: type=4, attr=0xf, range=[0x00000000c03f8000-0x00000000c0512000) (1MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem100: type=7, attr=0xf, range=[0x00000000c0512000-0x00000000c0517000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem101: type=4, attr=0xf, range=[0x00000000c0517000-0x00000000c052b000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem102: type=7, attr=0xf, range=[0x00000000c052b000-0x00000000c0530000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem103: type=4, attr=0xf, range=[0x00000000c0530000-0x00000000c0545000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem104: type=7, attr=0xf, range=[0x00000000c0545000-0x00000000c054b000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem105: type=4, attr=0xf, range=[0x00000000c054b000-0x00000000c0558000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem106: type=7, attr=0xf, range=[0x00000000c0558000-0x00000000c055c000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem107: type=4, attr=0xf, range=[0x00000000c055c000-0x00000000c0570000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem108: type=7, attr=0xf, range=[0x00000000c0570000-0x00000000c057b000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem109: type=4, attr=0xf, range=[0x00000000c057b000-0x00000000c05a1000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem110: type=7, attr=0xf, range=[0x00000000c05a1000-0x00000000c05ac000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem111: type=4, attr=0xf, range=[0x00000000c05ac000-0x00000000c0646000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem112: type=7, attr=0xf, range=[0x00000000c0646000-0x00000000c0649000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem113: type=4, attr=0xf, range=[0x00000000c0649000-0x00000000c0750000) (1MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem114: type=7, attr=0xf, range=[0x00000000c0750000-0x00000000c0751000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem115: type=4, attr=0xf, range=[0x00000000c0751000-0x00000000c07ac000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem116: type=7, attr=0xf, range=[0x00000000c07ac000-0x00000000c07ad000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem117: type=4, attr=0xf, range=[0x00000000c07ad000-0x00000000c0c48000) (4MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem118: type=7, attr=0xf, range=[0x00000000c0c48000-0x00000000c0c4a000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem119: type=4, attr=0xf, range=[0x00000000c0c4a000-0x00000000c0ca9000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem120: type=7, attr=0xf, range=[0x00000000c0ca9000-0x00000000c0cb7000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem121: type=4, attr=0xf, range=[0x00000000c0cb7000-0x00000000c0ce2000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem122: type=7, attr=0xf, range=[0x00000000c0ce2000-0x00000000c0ce4000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem123: type=4, attr=0xf, range=[0x00000000c0ce4000-0x00000000c0e52000) (1MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem124: type=7, attr=0xf, range=[0x00000000c0e52000-0x00000000c0e53000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem125: type=4, attr=0xf, range=[0x00000000c0e53000-0x00000000c0e5b000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem126: type=7, attr=0xf, range=[0x00000000c0e5b000-0x00000000c0e5d000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem127: type=4, attr=0xf, range=[0x00000000c0e5d000-0x00000000c0e6b000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem128: type=7, attr=0xf, range=[0x00000000c0e6b000-0x00000000c0e6e000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem129: type=4, attr=0xf, range=[0x00000000c0e6e000-0x00000000c0e79000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem130: type=7, attr=0xf, range=[0x00000000c0e79000-0x00000000c0e7b000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem131: type=4, attr=0xf, range=[0x00000000c0e7b000-0x00000000c0fba000) (1MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem132: type=7, attr=0xf, range=[0x00000000c0fba000-0x00000000c0fbc000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem133: type=4, attr=0xf, range=[0x00000000c0fbc000-0x00000000cab04000) (155MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem134: type=7, attr=0xf, range=[0x00000000cab04000-0x00000000cab05000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem135: type=4, attr=0xf, range=[0x00000000cab05000-0x00000000cd14c000) (38MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem136: type=7, attr=0xf, range=[0x00000000cd14c000-0x00000000ce46b000) (19MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem137: type=3, attr=0xf, range=[0x00000000ce46b000-0x00000000ce793000) (3MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem138: type=0, attr=0xf, range=[0x00000000ce793000-0x00000000ce7fe000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem139: type=0, attr=0xf, range=[0x00000000ce7fe000-0x00000000ce9a7000) (1MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem140: type=10, attr=0xf, range=[0x00000000ce9a7000-0x00000000ce9d8000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem141: type=10, attr=0xf, range=[0x00000000ce9d8000-0x00000000cea83000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem142: type=10, attr=0xf, range=[0x00000000cea83000-0x00000000cea88000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem143: type=10, attr=0xf, range=[0x00000000cea88000-0x00000000cea93000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem144: type=6, attr=0x800000000000000f, range=[0x00000000cea93000-0x00000000cf21d000) (7MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem145: type=6, attr=0x800000000000000f, range=[0x00000000cf21d000-0x00000000cf50f000) (2MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem146: type=6, attr=0x800000000000000f, range=[0x00000000cf50f000-0x00000000cf512000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem147: type=6, attr=0x800000000000000f, range=[0x00000000cf512000-0x00000000cf732000) (2MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem148: type=5, attr=0x800000000000000f, range=[0x00000000cf732000-0x00000000cf75b000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem149: type=5, attr=0x800000000000000f, range=[0x00000000cf75b000-0x00000000cf7ff000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem150: type=4, attr=0xf, range=[0x00000000cf7ff000-0x00000000cf800000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem151: type=7, attr=0xf, range=[0x0000000100000000-0x000000022e000000) (4832MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem152: type=11, attr=0x8000000000000001, range=[0x00000000f8000000-0x00000000fc000000) (64MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem153: type=11, attr=0x8000000000000001, range=[0x00000000fec00000-0x00000000fec01000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem154: type=11, attr=0x8000000000000001, range=[0x00000000fed00000-0x00000000fed04000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem155: type=11, attr=0x8000000000000001, range=[0x00000000fed1c000-0x00000000fed20000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem156: type=11, attr=0x8000000000000001, range=[0x00000000fee00000-0x00000000fee01000) (0MB)
2 月 21 10:51:13 linux-50zl kernel: efi: mem157: type=11, attr=0x8000000000000001, range=[0x00000000ff000000-0x0000000100000000) (16MB)
2 月 21 10:51:13 linux-50zl kernel: SMBIOS 2.7 present.
2 月 21 10:51:13 linux-50zl kernel: DMI: Gigabyte Technology Co., Ltd. G1.Sniper B5/G1.Sniper B5-CF, BIOS F5 08/03/2013
2 月 21 10:51:13 linux-50zl kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
2 月 21 10:51:13 linux-50zl kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
2 月 21 10:51:13 linux-50zl kernel: AGP: No AGP bridge found
2 月 21 10:51:13 linux-50zl kernel: e820: last_pfn = 0x22e000 max_arch_pfn = 0x400000000
2 月 21 10:51:13 linux-50zl kernel: MTRR default type: uncachable
2 月 21 10:51:13 linux-50zl kernel: MTRR fixed ranges enabled:
2 月 21 10:51:13 linux-50zl kernel: 00000-9FFFF write-back
2 月 21 10:51:13 linux-50zl kernel: A0000-BFFFF uncachable
2 月 21 10:51:13 linux-50zl kernel: C0000-CFFFF write-protect
2 月 21 10:51:13 linux-50zl kernel: D0000-DFFFF uncachable
2 月 21 10:51:13 linux-50zl kernel: E0000-FFFFF write-protect
2 月 21 10:51:13 linux-50zl kernel: MTRR variable ranges enabled:
2 月 21 10:51:13 linux-50zl kernel: 0 base 0000000000 mask 7E00000000 write-back
2 月 21 10:51:13 linux-50zl kernel: 1 base 0200000000 mask 7FE0000000 write-back
2 月 21 10:51:13 linux-50zl kernel: 2 base 0220000000 mask 7FF8000000 write-back
2 月 21 10:51:13 linux-50zl kernel: 3 base 0228000000 mask 7FFC000000 write-back
2 月 21 10:51:13 linux-50zl kernel: 4 base 022C000000 mask 7FFE000000 write-back
2 月 21 10:51:13 linux-50zl kernel: 5 base 00E0000000 mask 7FE0000000 uncachable
2 月 21 10:51:13 linux-50zl kernel: 6 base 00D0000000 mask 7FF0000000 uncachable
2 月 21 10:51:13 linux-50zl kernel: 7 disabled
2 月 21 10:51:13 linux-50zl kernel: 8 disabled
2 月 21 10:51:13 linux-50zl kernel: 9 disabled
2 月 21 10:51:13 linux-50zl kernel: x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
2 月 21 10:51:13 linux-50zl kernel: e820: update [mem 0xd0000000-0xffffffff] usable ==> reserved
2 月 21 10:51:13 linux-50zl kernel: e820: last_pfn = 0xcf800 max_arch_pfn = 0x400000000
2 月 21 10:51:13 linux-50zl kernel: found SMP MP-table at [mem 0x000fd710-0x000fd71f] mapped at [ffff8800000fd710]
2 月 21 10:51:13 linux-50zl kernel: Scanning 1 areas for low memory corruption
2 月 21 10:51:13 linux-50zl kernel: Base memory trampoline at [ffff880000097000] 97000 size 24576
2 月 21 10:51:13 linux-50zl kernel: Using GB pages for direct mapping
2 月 21 10:51:13 linux-50zl kernel: init_memory_mapping: [mem 0x00000000-0x000fffff]
2 月 21 10:51:13 linux-50zl kernel: [mem 0x00000000-0x000fffff] page 4k
2 月 21 10:51:13 linux-50zl kernel: BRK [0x0220b000, 0x0220bfff] PGTABLE
2 月 21 10:51:13 linux-50zl kernel: BRK [0x0220c000, 0x0220cfff] PGTABLE
2 月 21 10:51:13 linux-50zl kernel: BRK [0x0220d000, 0x0220dfff] PGTABLE
2 月 21 10:51:13 linux-50zl kernel: init_memory_mapping: [mem 0x22de00000-0x22dffffff]
2 月 21 10:51:13 linux-50zl kernel: [mem 0x22de00000-0x22dffffff] page 2M
2 月 21 10:51:13 linux-50zl kernel: BRK [0x0220e000, 0x0220efff] PGTABLE
2 月 21 10:51:13 linux-50zl kernel: init_memory_mapping: [mem 0x22c000000-0x22ddfffff]
2 月 21 10:51:13 linux-50zl kernel: [mem 0x22c000000-0x22ddfffff] page 2M
2 月 21 10:51:13 linux-50zl kernel: init_memory_mapping: [mem 0x200000000-0x22bffffff]
2 月 21 10:51:13 linux-50zl kernel: [mem 0x200000000-0x22bffffff] page 2M
2 月 21 10:51:13 linux-50zl kernel: init_memory_mapping: [mem 0x00100000-0xbb158fff]
2 月 21 10:51:13 linux-50zl kernel: [mem 0x00100000-0x001fffff] page 4k
2 月 21 10:51:13 linux-50zl kernel: [mem 0x00200000-0x3fffffff] page 2M
2 月 21 10:51:13 linux-50zl kernel: [mem 0x40000000-0x7fffffff] page 1G
2 月 21 10:51:13 linux-50zl kernel: [mem 0x80000000-0xbaffffff] page 2M
2 月 21 10:51:13 linux-50zl kernel: [mem 0xbb000000-0xbb158fff] page 4k
2 月 21 10:51:13 linux-50zl kernel: init_memory_mapping: [mem 0xbb160000-0xbc16efff]
2 月 21 10:51:13 linux-50zl kernel: [mem 0xbb160000-0xbb1fffff] page 4k
2 月 21 10:51:13 linux-50zl kernel: [mem 0xbb200000-0xbbffffff] page 2M
2 月 21 10:51:13 linux-50zl kernel: [mem 0xbc000000-0xbc16efff] page 4k
2 月 21 10:51:13 linux-50zl kernel: BRK [0x0220f000, 0x0220ffff] PGTABLE
2 月 21 10:51:13 linux-50zl kernel: init_memory_mapping: [mem 0xbc675000-0xce792fff]
2 月 21 10:51:13 linux-50zl kernel: [mem 0xbc675000-0xbc7fffff] page 4k
2 月 21 10:51:13 linux-50zl kernel: [mem 0xbc800000-0xce5fffff] page 2M
2 月 21 10:51:13 linux-50zl kernel: [mem 0xce600000-0xce792fff] page 4k
2 月 21 10:51:13 linux-50zl kernel: BRK [0x02210000, 0x02210fff] PGTABLE
2 月 21 10:51:13 linux-50zl kernel: init_memory_mapping: [mem 0xcf7ff000-0xcf7fffff]
2 月 21 10:51:13 linux-50zl kernel: [mem 0xcf7ff000-0xcf7fffff] page 4k
2 月 21 10:51:13 linux-50zl kernel: init_memory_mapping: [mem 0x100000000-0x1ffffffff]
2 月 21 10:51:13 linux-50zl kernel: [mem 0x100000000-0x1ffffffff] page 1G
2 月 21 10:51:13 linux-50zl kernel: RAMDISK: [mem 0x3f86b000-0x3fffafff]
2 月 21 10:51:13 linux-50zl kernel: ACPI: Early table checksum verification disabled
2 月 21 10:51:13 linux-50zl kernel: ACPI: RSDP 0x00000000CEA6B000 000024 (v02 ALASKA)
2 月 21 10:51:13 linux-50zl kernel: ACPI: XSDT 0x00000000CEA6B078 000074 (v01 ALASKA A M I 01072009 AMI 00010013)
2 月 21 10:51:13 linux-50zl kernel: ACPI: FACP 0x00000000CEA76460 00010C (v05 ALASKA A M I 01072009 AMI 00010013)
2 月 21 10:51:13 linux-50zl kernel: ACPI: DSDT 0x00000000CEA6B188 00B2D7 (v02 ALASKA A M I 000000F5 INTL 20091112)
2 月 21 10:51:13 linux-50zl kernel: ACPI: FACS 0x00000000CEA91080 000040
2 月 21 10:51:13 linux-50zl kernel: ACPI: APIC 0x00000000CEA76570 000092 (v03 ALASKA A M I 01072009 AMI 00010013)
2 月 21 10:51:13 linux-50zl kernel: ACPI: FPDT 0x00000000CEA76608 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
2 月 21 10:51:13 linux-50zl kernel: ACPI: SSDT 0x00000000CEA76650 000AD8 (v01 PmRef CpuPm 00003000 INTL 20051117)
2 月 21 10:51:13 linux-50zl kernel: ACPI: MCFG 0x00000000CEA77128 00003C (v01 01072009 MSFT 00000097)
2 月 21 10:51:13 linux-50zl kernel: ACPI: HPET 0x00000000CEA77168 000038 (v01 ALASKA A M I 01072009 AMI. 00000005)
2 月 21 10:51:13 linux-50zl kernel: ACPI: SSDT 0x00000000CEA771A0 00036D (v01 SataRe SataTabl 00001000 INTL 20091112)
2 月 21 10:51:13 linux-50zl kernel: ACPI: SSDT 0x00000000CEA77510 003299 (v01 SaSsdt SaSsdt 00003000 INTL 20091112)
2 月 21 10:51:13 linux-50zl kernel: ACPI: BGRT 0x00000000CEA7A7B0 000038 (v00 ALASKA A M I 01072009 AMI 00010013)
2 月 21 10:51:13 linux-50zl kernel: ACPI: DMAR 0x00000000CEA7A7E8 000080 (v01 INTEL HSW 00000001 INTL 00000001)
2 月 21 10:51:13 linux-50zl kernel: ACPI: Local APIC address 0xfee00000
2 月 21 10:51:13 linux-50zl kernel: No NUMA configuration found
2 月 21 10:51:13 linux-50zl kernel: Faking a node at [mem 0x0000000000000000-0x000000022dffffff]
2 月 21 10:51:13 linux-50zl kernel: Initmem setup node 0 [mem 0x00000000-0x22dffffff]
2 月 21 10:51:13 linux-50zl kernel: NODE_DATA [mem 0x22dfe7000-0x22dffafff]
2 月 21 10:51:13 linux-50zl kernel: [ffffea0000000000-ffffea0007bfffff] PMD -> [ffff880225600000-ffff88022c7fffff] on node 0
2 月 21 10:51:13 linux-50zl kernel: Zone ranges:
2 月 21 10:51:13 linux-50zl kernel: DMA [mem 0x00001000-0x00ffffff]
2 月 21 10:51:13 linux-50zl kernel: DMA32 [mem 0x01000000-0xffffffff]
2 月 21 10:51:13 linux-50zl kernel: Normal [mem 0x100000000-0x22dffffff]
2 月 21 10:51:13 linux-50zl kernel: Movable zone start for each node
2 月 21 10:51:13 linux-50zl kernel: Early memory node ranges
2 月 21 10:51:13 linux-50zl kernel: node 0: [mem 0x00001000-0x00057fff]
2 月 21 10:51:13 linux-50zl kernel: node 0: [mem 0x00059000-0x0009efff]
2 月 21 10:51:13 linux-50zl kernel: node 0: [mem 0x00100000-0xbb158fff]
2 月 21 10:51:13 linux-50zl kernel: node 0: [mem 0xbb160000-0xbc16efff]
2 月 21 10:51:13 linux-50zl kernel: node 0: [mem 0xbc675000-0xce792fff]
2 月 21 10:51:13 linux-50zl kernel: node 0: [mem 0xcf7ff000-0xcf7fffff]
2 月 21 10:51:13 linux-50zl kernel: node 0: [mem 0x100000000-0x22dffffff]
2 月 21 10:51:13 linux-50zl kernel: On node 0 totalpages: 2081316
2 月 21 10:51:13 linux-50zl kernel: DMA zone: 56 pages used for memmap
2 月 21 10:51:13 linux-50zl kernel: DMA zone: 24 pages reserved
2 月 21 10:51:13 linux-50zl kernel: DMA zone: 3997 pages, LIFO batch:0
2 月 21 10:51:13 linux-50zl kernel: DMA32 zone: 11489 pages used for memmap
2 月 21 10:51:13 linux-50zl kernel: DMA32 zone: 840327 pages, LIFO batch:31
2 月 21 10:51:13 linux-50zl kernel: Normal zone: 16912 pages used for memmap
2 月 21 10:51:13 linux-50zl kernel: Normal zone: 1236992 pages, LIFO batch:31
2 月 21 10:51:13 linux-50zl kernel: tboot: non-0 tboot_addr but it is not of type E820_RESERVED
2 月 21 10:51:13 linux-50zl kernel: ACPI: PM-Timer IO Port: 0x1808
2 月 21 10:51:13 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
2 月 21 10:51:13 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
2 月 21 10:51:13 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled)
2 月 21 10:51:13 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled)
2 月 21 10:51:13 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x05] lapic_id[0x01] enabled)
2 月 21 10:51:13 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x06] lapic_id[0x03] enabled)
2 月 21 10:51:13 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x07] lapic_id[0x05] enabled)
2 月 21 10:51:13 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x08] lapic_id[0x07] enabled)
2 月 21 10:51:13 linux-50zl kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
2 月 21 10:51:13 linux-50zl kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
2 月 21 10:51:13 linux-50zl kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
2 月 21 10:51:13 linux-50zl kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
2 月 21 10:51:13 linux-50zl kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
2 月 21 10:51:13 linux-50zl kernel: ACPI: IRQ0 used by override.
2 月 21 10:51:13 linux-50zl kernel: ACPI: IRQ2 used by override.
2 月 21 10:51:13 linux-50zl kernel: ACPI: IRQ9 used by override.
2 月 21 10:51:13 linux-50zl kernel: Using ACPI (MADT) for SMP configuration information
2 月 21 10:51:13 linux-50zl kernel: ACPI: HPET id: 0x8086a701 base: 0xfed00000
2 月 21 10:51:13 linux-50zl kernel: smpboot: Allowing 8 CPUs, 0 hotplug CPUs
2 月 21 10:51:13 linux-50zl kernel: nr_irqs_gsi: 40
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xbae42000-0xbae42fff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xbae52000-0xbae52fff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xbae53000-0xbae53fff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xbae72000-0xbae72fff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xbb159000-0xbb15ffff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xbc16f000-0xbc674fff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xce793000-0xce9a6fff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xce9a7000-0xcea92fff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xcea93000-0xcf7fefff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xcf800000-0xf7ffffff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
2 月 21 10:51:13 linux-50zl kernel: PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
2 月 21 10:51:13 linux-50zl kernel: e820: [mem 0xcf800000-0xf7ffffff] available for PCI devices
2 月 21 10:51:13 linux-50zl kernel: Booting paravirtualized kernel on bare hardware
2 月 21 10:51:13 linux-50zl kernel: setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:8 nr_node_ids:1
2 月 21 10:51:13 linux-50zl kernel: PERCPU: Embedded 27 pages/cpu @ffff88022dc00000 s79104 r8192 d23296 u262144
2 月 21 10:51:13 linux-50zl kernel: pcpu-alloc: s79104 r8192 d23296 u262144 alloc=1*2097152
2 月 21 10:51:13 linux-50zl kernel: pcpu-alloc: [0] 0 1 2 3 4 5 6 7
2 月 21 10:51:13 linux-50zl kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2052835
2 月 21 10:51:13 linux-50zl kernel: Policy zone: Normal
2 月 21 10:51:13 linux-50zl kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.16.7-7-desktop root=UUID=da625858-43b9-413a-b151-943
2 月 21 10:51:13 linux-50zl kernel: PID hash table entries: 4096 (order: 3, 32768 bytes)
2 月 21 10:51:13 linux-50zl kernel: xsave: enabled xstate_bv 0x7, cntxt size 0x340
2 月 21 10:51:13 linux-50zl kernel: AGP: Checking aperture...
2 月 21 10:51:13 linux-50zl kernel: Memory: 7878372K/8325264K available (6302K kernel code, 1009K rwdata, 4708K rodata, 1560K init, 1532
2 月 21 10:51:13 linux-50zl kernel: Preemptible hierarchical RCU implementation.
2 月 21 10:51:13 linux-50zl kernel: RCU dyntick-idle grace-period acceleration is enabled.
2 月 21 10:51:13 linux-50zl kernel: RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
2 月 21 10:51:13 linux-50zl kernel: Offload RCU callbacks from all CPUs
2 月 21 10:51:13 linux-50zl kernel: Offload RCU callbacks from CPUs: 0-7.
2 月 21 10:51:13 linux-50zl kernel: RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
2 月 21 10:51:13 linux-50zl kernel: NR_IRQS:33024 nr_irqs:744 16
2 月 21 10:51:13 linux-50zl kernel: Console: colour dummy device 80x25
2 月 21 10:51:13 linux-50zl kernel: console [tty0] enabled
2 月 21 10:51:13 linux-50zl kernel: allocated 33554432 bytes of page_cgroup
2 月 21 10:51:13 linux-50zl kernel: please try 'cgroup_disable=memory' option if you don't want memory cgroups
2 月 21 10:51:13 linux-50zl kernel: hpet clockevent registered
2 月 21 10:51:13 linux-50zl kernel: tsc: Fast TSC calibration using PIT
2 月 21 10:51:13 linux-50zl kernel: tsc: Detected 3292.263 MHz processor
2 月 21 10:51:13 linux-50zl kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 6584.52 BogoMIPS (lpj=329
2 月 21 10:51:13 linux-50zl kernel: pid_max: default: 32768 minimum: 301
2 月 21 10:51:13 linux-50zl kernel: ACPI: Core revision 20140424
2 月 21 10:51:13 linux-50zl kernel: ACPI: All ACPI Tables successfully acquired
2 月 21 10:51:13 linux-50zl kernel: Security Framework initialized
2 月 21 10:51:13 linux-50zl kernel: AppArmor: AppArmor initialized
2 月 21 10:51:13 linux-50zl kernel: Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
2 月 21 10:51:13 linux-50zl kernel: Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
2 月 21 10:51:13 linux-50zl kernel: Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
2 月 21 10:51:13 linux-50zl kernel: Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
2 月 21 10:51:13 linux-50zl kernel: Initializing cgroup subsys memory
2 月 21 10:51:13 linux-50zl kernel: Initializing cgroup subsys devices
2 月 21 10:51:13 linux-50zl kernel: Initializing cgroup subsys freezer
2 月 21 10:51:13 linux-50zl kernel: Initializing cgroup subsys net_cls
2 月 21 10:51:13 linux-50zl kernel: Initializing cgroup subsys blkio
2 月 21 10:51:13 linux-50zl kernel: Initializing cgroup subsys perf_event
2 月 21 10:51:13 linux-50zl kernel: Initializing cgroup subsys net_prio
2 月 21 10:51:13 linux-50zl kernel: Initializing cgroup subsys hugetlb
2 月 21 10:51:13 linux-50zl kernel: CPU: Physical Processor ID: 0
2 月 21 10:51:13 linux-50zl kernel: CPU: Processor Core ID: 0
2 月 21 10:51:13 linux-50zl kernel: mce: CPU supports 9 MCE banks
2 月 21 10:51:13 linux-50zl kernel: CPU0: Thermal monitoring enabled (TM1)
2 月 21 10:51:13 linux-50zl kernel: Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
tlb_flushall_shift: 6
2 月 21 10:51:13 linux-50zl kernel: Freeing SMP alternatives memory: 24K (ffffffff82084000 - ffffffff8208a000)
2 月 21 10:51:13 linux-50zl kernel: ftrace: allocating 24400 entries in 96 pages
2 月 21 10:51:13 linux-50zl kernel: dmar: Host address width 39
2 月 21 10:51:13 linux-50zl kernel: dmar: DRHD base: 0x000000fed90000 flags: 0x1
2 月 21 10:51:13 linux-50zl kernel: dmar: IOMMU 0: reg_base_addr fed90000 ver 1:0 cap d2008c20660462 ecap f010da
2 月 21 10:51:13 linux-50zl kernel: dmar: RMRR base: 0x000000ce925000 end: 0x000000ce931fff
2 月 21 10:51:13 linux-50zl kernel: IOAPIC id 2 under DRHD base 0xfed90000 IOMMU 0
2 月 21 10:51:13 linux-50zl kernel: HPET id 0 under DRHD base 0xfed90000
2 月 21 10:51:13 linux-50zl kernel: Queued invalidation will be enabled to support x2apic and Intr-remapping.
2 月 21 10:51:13 linux-50zl kernel: Enabled IRQ remapping in x2apic mode
2 月 21 10:51:13 linux-50zl kernel: Enabling x2apic
2 月 21 10:51:13 linux-50zl kernel: Enabled x2apic
2 月 21 10:51:13 linux-50zl kernel: Switched APIC routing to cluster x2apic.
2 月 21 10:51:13 linux-50zl kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
2 月 21 10:51:13 linux-50zl kernel: smpboot: CPU0: Intel(R) Xeon(R) CPU E3-1230 v3 @ 3.30GHz (fam: 06, model: 3c, stepping: 03)
2 月 21 10:51:13 linux-50zl kernel: TSC deadline timer enabled
2 月 21 10:51:13 linux-50zl kernel: Performance Events: PEBS fmt2+, 16-deep LBR, Haswell events, full-width counters, Intel PMU driver.
2 月 21 10:51:13 linux-50zl kernel: ... version: 3
2 月 21 10:51:13 linux-50zl kernel: ... bit width: 48
2 月 21 10:51:13 linux-50zl kernel: ... generic registers: 4
2 月 21 10:51:13 linux-50zl kernel: ... value mask: 0000ffffffffffff
2 月 21 10:51:13 linux-50zl kernel: ... max period: 0000ffffffffffff
2 月 21 10:51:13 linux-50zl kernel: ... fixed-purpose events: 3
2 月 21 10:51:13 linux-50zl kernel: ... event mask: 000000070000000f
2 月 21 10:51:13 linux-50zl kernel: x86: Booting SMP configuration:
2 月 21 10:51:13 linux-50zl kernel: .... node #0, CPUs: #1
2 月 21 10:51:13 linux-50zl kernel: CPU1 microcode updated early to revision 0x1c, date = 2014-07-03
2 月 21 10:51:13 linux-50zl kernel: NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
2 月 21 10:51:13 linux-50zl kernel: #2
2 月 21 10:51:13 linux-50zl kernel: CPU2 microcode updated early to revision 0x1c, date = 2014-07-03
2 月 21 10:51:13 linux-50zl kernel: #3
2 月 21 10:51:13 linux-50zl kernel: CPU3 microcode updated early to revision 0x1c, date = 2014-07-03
2 月 21 10:51:13 linux-50zl kernel: #4 #5 #6 #7
2 月 21 10:51:13 linux-50zl kernel: x86: Booted up 1 node, 8 CPUs
2 月 21 10:51:13 linux-50zl kernel: smpboot: Total of 8 processors activated (52676.20 BogoMIPS)
2 月 21 10:51:13 linux-50zl kernel: devtmpfs: initialized
2 月 21 10:51:13 linux-50zl kernel: PM: Registering ACPI NVS region [mem 0xbb159000-0xbb15ffff] (28672 bytes)
2 月 21 10:51:13 linux-50zl kernel: PM: Registering ACPI NVS region [mem 0xce9a7000-0xcea92fff] (966656 bytes)
2 月 21 10:51:13 linux-50zl kernel: pinctrl core: initialized pinctrl subsystem
2 月 21 10:51:13 linux-50zl kernel: RTC time: 10:51:12, date: 02/21/15
2 月 21 10:51:13 linux-50zl kernel: NET: Registered protocol family 16
2 月 21 10:51:13 linux-50zl kernel: cpuidle: using governor ladder
2 月 21 10:51:13 linux-50zl kernel: cpuidle: using governor menu
2 月 21 10:51:13 linux-50zl kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
2 月 21 10:51:13 linux-50zl kernel: ACPI: bus type PCI registered
2 月 21 10:51:13 linux-50zl kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
2 月 21 10:51:13 linux-50zl kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
2 月 21 10:51:13 linux-50zl kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
2 月 21 10:51:13 linux-50zl kernel: PCI: Using configuration type 1 for base access
2 月 21 10:51:13 linux-50zl kernel: ACPI: Added _OSI(Module Device)
2 月 21 10:51:13 linux-50zl kernel: ACPI: Added _OSI(Processor Device)
2 月 21 10:51:13 linux-50zl kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
2 月 21 10:51:13 linux-50zl kernel: ACPI: Added _OSI(Processor Aggregator Device)
2 月 21 10:51:13 linux-50zl kernel: ACPI: Executed 1 blocks of module-level executable AML code
2 月 21 10:51:13 linux-50zl kernel: [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
2 月 21 10:51:13 linux-50zl kernel: ACPI: Dynamic OEM Table Load:
2 月 21 10:51:13 linux-50zl kernel: ACPI: SSDT 0xFFFF8802225EC800 0003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
2 月 21 10:51:13 linux-50zl kernel: ACPI: SSDT 0xFFFF8802225E2000 000119 (v01 PmRef ApCst 00003000 INTL 20051117)
2 月 21 10:51:13 linux-50zl kernel: ACPI: Interpreter enabled
2 月 21 10:51:13 linux-50zl kernel: ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State \_S1_] (20140424/hwxface-580)
2 月 21 10:51:13 linux-50zl kernel: ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State \_S2_] (20140424/hwxface-580)
2 月 21 10:51:13 linux-50zl kernel: ACPI: (supports S0 S3 S4 S5)
2 月 21 10:51:13 linux-50zl kernel: ACPI: Using IOAPIC for interrupt routing
2 月 21 10:51:13 linux-50zl kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
2 月 21 10:51:13 linux-50zl kernel: ACPI: Power Resource [FN00] (off)
2 月 21 10:51:13 linux-50zl kernel: ACPI: Power Resource [FN01] (off)
2 月 21 10:51:13 linux-50zl kernel: ACPI: Power Resource [FN02] (off)
2 月 21 10:51:13 linux-50zl kernel: ACPI: Power Resource [FN03] (off)
2 月 21 10:51:13 linux-50zl kernel: ACPI: Power Resource [FN04] (off)
2 月 21 10:51:13 linux-50zl kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
2 月 21 10:51:13 linux-50zl kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
2 月 21 10:51:13 linux-50zl kernel: acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME]
2 月 21 10:51:13 linux-50zl kernel: acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
2 月 21 10:51:13 linux-50zl kernel: PCI host bridge to bus 0000:00
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: root bus resource [bus 00-3e]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: root bus resource [mem 0xd0000000-0xfeafffff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:00.0: [8086:0c08] type 00 class 0x060000
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:01.0: [8086:0c01] type 01 class 0x060400
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:01.0: System wakeup disabled by ACPI
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:14.0: reg 0x10: [mem 0xf3220000-0xf322ffff 64bit]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:14.0: System wakeup disabled by ACPI
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:16.0: reg 0x10: [mem 0xf323c000-0xf323c00f 64bit]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:16.3: [8086:8c3d] type 00 class 0x070002
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:16.3: reg 0x10: [io 0xf0a0-0xf0a7]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:16.3: reg 0x14: [mem 0xf323a000-0xf323afff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:19.0: [8086:153b] type 00 class 0x020000
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:19.0: reg 0x10: [mem 0xf3200000-0xf321ffff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:19.0: reg 0x14: [mem 0xf3239000-0xf3239fff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:19.0: reg 0x18: [io 0xf040-0xf05f]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:19.0: System wakeup disabled by ACPI
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1a.0: reg 0x10: [mem 0xf3238000-0xf32383ff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1a.0: System wakeup disabled by ACPI
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1b.0: reg 0x10: [mem 0xf3230000-0xf3233fff 64bit]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1b.0: System wakeup disabled by ACPI
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.0: System wakeup disabled by ACPI
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.3: [8086:244e] type 01 class 0x060401
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.3: System wakeup disabled by ACPI
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1d.0: reg 0x10: [mem 0xf3237000-0xf32373ff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1d.0: System wakeup disabled by ACPI
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1f.0: [8086:8c50] type 00 class 0x060100
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1f.2: reg 0x10: [io 0xf090-0xf097]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1f.2: reg 0x14: [io 0xf080-0xf083]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1f.2: reg 0x18: [io 0xf070-0xf077]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1f.2: reg 0x1c: [io 0xf060-0xf063]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1f.2: reg 0x20: [io 0xf020-0xf03f]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1f.2: reg 0x24: [mem 0xf3236000-0xf32367ff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1f.2: PME# supported from D3hot
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xf3235000-0xf32350ff 64bit]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1f.3: reg 0x20: [io 0xf000-0xf01f]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:01:00.0: [10de:1187] type 00 class 0x030000
2 月 21 10:51:13 linux-50zl kernel: pci 0000:01:00.0: reg 0x10: [mem 0xf2000000-0xf2ffffff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:01:00.0: reg 0x14: [mem 0xe8000000-0xefffffff 64bit pref]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:01:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:01:00.0: reg 0x24: [io 0xe000-0xe07f]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:01:00.0: reg 0x30: [mem 0xf3000000-0xf307ffff pref]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:01:00.0: System wakeup disabled by ACPI
2 月 21 10:51:13 linux-50zl kernel: pci 0000:01:00.1: [10de:0e0a] type 00 class 0x040300
2 月 21 10:51:13 linux-50zl kernel: pci 0000:01:00.1: reg 0x10: [mem 0xf3080000-0xf3083fff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:01.0: PCI bridge to [bus 01]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:01.0: bridge window [mem 0xe8000000-0xf30fffff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.0: PCI bridge to [bus 02]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: [8086:244e] type 01 class 0x060401
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: supports D1 D2
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: System wakeup disabled by ACPI
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.3: PCI bridge to [bus 03-04] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.3: bridge window [mem 0xf3100000-0xf31fffff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.3: bridge window [io 0x0000-0x0cf7] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.3: bridge window [io 0x0d00-0xffff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.3: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.3: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.3: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.3: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.3: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:00:1c.3: bridge window [mem 0xd0000000-0xfeafffff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:04:00.0: [10ec:8139] type 00 class 0x020000
2 月 21 10:51:13 linux-50zl kernel: pci 0000:04:00.0: reg 0x10: [io 0xd000-0xd0ff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:04:00.0: reg 0x14: [mem 0xf3120000-0xf31200ff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:04:00.0: reg 0x30: [mem 0xf3100000-0xf311ffff pref]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:04:00.0: supports D1 D2
2 月 21 10:51:13 linux-50zl kernel: pci 0000:04:00.0: PME# supported from D1 D2 D3hot
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: PCI bridge to [bus 04] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: bridge window [io 0xd000-0xdfff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0xf3100000-0xf31fffff]
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: bridge window [io 0xd000-0xdfff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0xf3100000-0xf31fffff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0xd0000000-0xfeafffff] (subtractive decode)
2 月 21 10:51:13 linux-50zl kernel: acpi PNP0A08:00: Disabling ASPM (FADT indicates it is unsupported)
2 月 21 10:51:13 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
2 月 21 10:51:13 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
2 月 21 10:51:13 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
2 月 21 10:51:13 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 5 6 10 11 12 14 15)
2 月 21 10:51:13 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
2 月 21 10:51:13 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
2 月 21 10:51:13 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 *10 11 12 14 15)
2 月 21 10:51:13 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 5 6 10 11 12 14 15)
2 月 21 10:51:13 linux-50zl kernel: ACPI: Enabled 4 GPEs in block 00 to 3F
2 月 21 10:51:13 linux-50zl kernel: vgaarb: setting as boot device: PCI:0000:01:00.0
2 月 21 10:51:13 linux-50zl kernel: vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
2 月 21 10:51:13 linux-50zl kernel: vgaarb: loaded
2 月 21 10:51:13 linux-50zl kernel: vgaarb: bridge control possible 0000:01:00.0
2 月 21 10:51:13 linux-50zl kernel: SCSI subsystem initialized
2 月 21 10:51:13 linux-50zl kernel: libata version 3.00 loaded.
2 月 21 10:51:13 linux-50zl kernel: ACPI: bus type USB registered
2 月 21 10:51:13 linux-50zl kernel: usbcore: registered new interface driver usbfs
2 月 21 10:51:13 linux-50zl kernel: usbcore: registered new interface driver hub
2 月 21 10:51:13 linux-50zl kernel: usbcore: registered new device driver usb
2 月 21 10:51:13 linux-50zl kernel: PCI: Using ACPI for IRQ routing
2 月 21 10:51:13 linux-50zl kernel: PCI: pci_cache_line_size set to 64 bytes
2 月 21 10:51:13 linux-50zl kernel: e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
2 月 21 10:51:13 linux-50zl kernel: e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
2 月 21 10:51:13 linux-50zl kernel: e820: reserve RAM buffer [mem 0xbae42018-0xbbffffff]
2 月 21 10:51:13 linux-50zl kernel: e820: reserve RAM buffer [mem 0xbae53018-0xbbffffff]
2 月 21 10:51:13 linux-50zl kernel: e820: reserve RAM buffer [mem 0xbb159000-0xbbffffff]
2 月 21 10:51:13 linux-50zl kernel: e820: reserve RAM buffer [mem 0xbc16f000-0xbfffffff]
2 月 21 10:51:13 linux-50zl kernel: e820: reserve RAM buffer [mem 0xce793000-0xcfffffff]
2 月 21 10:51:13 linux-50zl kernel: e820: reserve RAM buffer [mem 0xcf800000-0xcfffffff]
2 月 21 10:51:13 linux-50zl kernel: e820: reserve RAM buffer [mem 0x22e000000-0x22fffffff]
2 月 21 10:51:13 linux-50zl kernel: NetLabel: Initializing
2 月 21 10:51:13 linux-50zl kernel: NetLabel: domain hash size = 128
2 月 21 10:51:13 linux-50zl kernel: NetLabel: protocols = UNLABELED CIPSOv4
2 月 21 10:51:13 linux-50zl kernel: NetLabel: unlabeled traffic allowed by default
2 月 21 10:51:13 linux-50zl kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
2 月 21 10:51:13 linux-50zl kernel: hpet0: 8 comparators, 64-bit 14.318180 MHz counter
2 月 21 10:51:13 linux-50zl kernel: Switched to clocksource hpet
2 月 21 10:51:13 linux-50zl kernel: AppArmor: AppArmor Filesystem Enabled
2 月 21 10:51:13 linux-50zl kernel: pnp: PnP ACPI init
2 月 21 10:51:13 linux-50zl kernel: ACPI: bus type PNP registered
2 月 21 10:51:13 linux-50zl kernel: system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
2 月 21 10:51:13 linux-50zl kernel: system 00:01: [io 0x0680-0x069f] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:01: [io 0xffff] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:01: [io 0x1c00-0x1cfe] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:01: [io 0x1d00-0x1dfe] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:01: [io 0x1e00-0x1efe] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:01: [io 0x1f00-0x1ffe] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:01: [io 0x1800-0x18fe] could not be reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:01: [io 0x164e-0x164f] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
2 月 21 10:51:13 linux-50zl kernel: pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
2 月 21 10:51:13 linux-50zl kernel: system 00:03: [io 0x1854-0x1857] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
2 月 21 10:51:13 linux-50zl kernel: system 00:04: [io 0x0a00-0x0a0f] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:04: [io 0x0a30-0x0a3f] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:04: [io 0x0a20-0x0a2f] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
2 月 21 10:51:13 linux-50zl kernel: pnp 00:05: [dma 0 disabled]
2 月 21 10:51:13 linux-50zl kernel: pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
2 月 21 10:51:13 linux-50zl kernel: pnp 00:06: [dma 0 disabled]
2 月 21 10:51:13 linux-50zl kernel: pnp 00:06: Plug and Play ACPI device, IDs PNP0400 (active)
2 月 21 10:51:13 linux-50zl kernel: system 00:07: [io 0x04d0-0x04d1] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
2 月 21 10:51:13 linux-50zl kernel: system 00:08: [mem 0xfed1c000-0xfed1ffff] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:08: [mem 0xfed10000-0xfed17fff] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:08: [mem 0xfed18000-0xfed18fff] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:08: [mem 0xfed19000-0xfed19fff] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:08: [mem 0xf8000000-0xfbffffff] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:08: [mem 0xfed20000-0xfed3ffff] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:08: [mem 0xfed90000-0xfed93fff] could not be reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:08: [mem 0xfed45000-0xfed8ffff] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:08: [mem 0xff000000-0xffffffff] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:08: [mem 0xfee00000-0xfeefffff] could not be reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:08: [mem 0xf7fef000-0xf7feffff] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:08: [mem 0xf7ff0000-0xf7ff0fff] has been reserved
2 月 21 10:51:13 linux-50zl kernel: system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
2 月 21 10:51:13 linux-50zl kernel: pnp: PnP ACPI: found 9 devices
2 月 21 10:51:13 linux-50zl kernel: ACPI: bus type PNP unregistered
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:00: resource 11 [mem 0xd0000000-0xfeafffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:01: resource 1 [mem 0xe8000000-0xf30fffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:03: resource 1 [mem 0xf3100000-0xf31fffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:03: resource 5 [io 0x0d00-0xffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:03: resource 7 [mem 0x000d0000-0x000d3fff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:03: resource 8 [mem 0x000d4000-0x000d7fff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:03: resource 9 [mem 0x000d8000-0x000dbfff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:03: resource 10 [mem 0x000dc000-0x000dffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:03: resource 11 [mem 0xd0000000-0xfeafffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:04: resource 0 [io 0xd000-0xdfff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:04: resource 1 [mem 0xf3100000-0xf31fffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:04: resource 4 [io 0xd000-0xdfff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:04: resource 5 [mem 0xf3100000-0xf31fffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:04: resource 6 [io 0x0000-0x0cf7]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:04: resource 7 [io 0x0d00-0xffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:04: resource 8 [mem 0x000a0000-0x000bffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:04: resource 9 [mem 0x000d0000-0x000d3fff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:04: resource 10 [mem 0x000d4000-0x000d7fff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:04: resource 11 [mem 0x000d8000-0x000dbfff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:04: resource 12 [mem 0x000dc000-0x000dffff]
2 月 21 10:51:13 linux-50zl kernel: pci_bus 0000:04: resource 13 [mem 0xd0000000-0xfeafffff]
2 月 21 10:51:13 linux-50zl kernel: NET: Registered protocol family 2
2 月 21 10:51:13 linux-50zl kernel: TCP established hash table entries: 65536 (order: 7, 524288 bytes)
2 月 21 10:51:13 linux-50zl kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
2 月 21 10:51:13 linux-50zl kernel: TCP: Hash tables configured (established 65536 bind 65536)
2 月 21 10:51:13 linux-50zl kernel: TCP: reno registered
2 月 21 10:51:13 linux-50zl kernel: UDP hash table entries: 4096 (order: 5, 131072 bytes)
2 月 21 10:51:13 linux-50zl kernel: UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
2 月 21 10:51:13 linux-50zl kernel: pci 0000:01:00.0: Video device with shadowed ROM
2 月 21 10:51:13 linux-50zl kernel: PCI: CLS 64 bytes, default 64
2 月 21 10:51:13 linux-50zl kernel: Unpacking initramfs...
2 月 21 10:51:13 linux-50zl kernel: Freeing initrd memory: 7744K (ffff88003f86b000 - ffff88003fffb000)
2 月 21 10:51:13 linux-50zl kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
2 月 21 10:51:13 linux-50zl kernel: software IO TLB [mem 0xb6e42000-0xbae42000] (64MB) mapped at [ffff8800b6e42000-ffff8800bae41fff]
2 月 21 10:51:13 linux-50zl kernel: RAPL PMU detected, hw unit 2^-14 Joules, API unit is 2^-32 Joules, 4 fixed counters 655360 ms ovfl timer
2 月 21 10:51:13 linux-50zl kernel: microcode: CPU0 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 10:51:13 linux-50zl kernel: microcode: CPU1 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 10:51:13 linux-50zl kernel: microcode: CPU2 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 10:51:13 linux-50zl kernel: microcode: CPU3 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 10:51:13 linux-50zl kernel: microcode: CPU4 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 10:51:13 linux-50zl kernel: microcode: CPU5 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 10:51:13 linux-50zl kernel: microcode: CPU6 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 10:51:13 linux-50zl kernel: microcode: CPU7 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 10:51:13 linux-50zl kernel: microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
2 月 21 10:51:13 linux-50zl kernel: Scanning for low memory corruption every 60 seconds
2 月 21 10:51:13 linux-50zl kernel: futex hash table entries: 2048 (order: 5, 131072 bytes)
2 月 21 10:51:13 linux-50zl kernel: Initialise system trusted keyring
2 月 21 10:51:13 linux-50zl kernel: audit: initializing netlink subsys (disabled)
2 月 21 10:51:13 linux-50zl kernel: audit: type=2000 audit(1424515872.709:1): initialized
2 月 21 10:51:13 linux-50zl kernel: HugeTLB registered 2 MB page size, pre-allocated 0 pages
2 月 21 10:51:13 linux-50zl kernel: zbud: loaded
2 月 21 10:51:13 linux-50zl kernel: VFS: Disk quotas dquot_6.5.2
2 月 21 10:51:13 linux-50zl kernel: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
2 月 21 10:51:13 linux-50zl kernel: msgmni has been set to 15864
2 月 21 10:51:13 linux-50zl kernel: Key type big_key registered
2 月 21 10:51:13 linux-50zl kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
2 月 21 10:51:13 linux-50zl kernel: io scheduler noop registered
2 月 21 10:51:13 linux-50zl kernel: io scheduler deadline registered
2 月 21 10:51:13 linux-50zl kernel: io scheduler cfq registered (default)
2 月 21 10:51:13 linux-50zl kernel: pcieport 0000:00:01.0: irq 41 for MSI/MSI-X
2 月 21 10:51:13 linux-50zl kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
2 月 21 10:51:13 linux-50zl kernel: pciehp: PCI Express Hot Plug Controller Driver version: 0.4
2 月 21 10:51:13 linux-50zl kernel: efifb: probing for efifb
2 月 21 10:51:13 linux-50zl kernel: efifb: framebuffer at 0xf1000000, mapped to 0xffffc90004f00000, using 3072k, total 3072k
2 月 21 10:51:13 linux-50zl kernel: efifb: mode is 1024x768x32, linelength=4096, pages=1
2 月 21 10:51:13 linux-50zl kernel: efifb: scrolling: redraw
2 月 21 10:51:13 linux-50zl kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
2 月 21 10:51:13 linux-50zl kernel: Console: switching to colour frame buffer device 128x48
2 月 21 10:51:13 linux-50zl kernel: fb0: EFI VGA frame buffer device
2 月 21 10:51:13 linux-50zl kernel: intel_idle: MWAIT substates: 0x42120
2 月 21 10:51:13 linux-50zl kernel: intel_idle: v0.4 model 0x3C
2 月 21 10:51:13 linux-50zl kernel: intel_idle: lapic_timer_reliable_states 0xffffffff
2 月 21 10:51:13 linux-50zl kernel: GHES: HEST is not enabled!
2 月 21 10:51:13 linux-50zl kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing disabled
2 月 21 10:51:13 linux-50zl kernel: 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
2 月 21 10:51:13 linux-50zl kernel: serial 0000:00:16.3: enabling device (0000 -> 0003)
2 月 21 10:51:13 linux-50zl kernel: 0000:00:16.3: ttyS4 at I/O 0xf0a0 (irq = 19, base_baud = 115200) is a 16550A
2 月 21 10:51:13 linux-50zl kernel: Non-volatile memory driver v1.3
2 月 21 10:51:13 linux-50zl kernel: Linux agpgart interface v0.103
2 月 21 10:51:13 linux-50zl kernel: ahci 0000:00:1f.2: version 3.0
2 月 21 10:51:13 linux-50zl kernel: ahci 0000:00:1f.2: irq 42 for MSI/MSI-X
2 月 21 10:51:13 linux-50zl kernel: ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0xf impl SATA mode
2 月 21 10:51:13 linux-50zl kernel: ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
2 月 21 10:51:13 linux-50zl kernel: scsi0 : ahci
2 月 21 10:51:13 linux-50zl kernel: scsi1 : ahci
2 月 21 10:51:13 linux-50zl kernel: scsi2 : ahci
2 月 21 10:51:13 linux-50zl kernel: scsi3 : ahci
2 月 21 10:51:13 linux-50zl kernel: scsi4 : ahci
2 月 21 10:51:13 linux-50zl kernel: scsi5 : ahci
2 月 21 10:51:13 linux-50zl kernel: ata1: SATA max UDMA/133 abar m2048@0xf3236000 port 0xf3236100 irq 42
2 月 21 10:51:13 linux-50zl kernel: ata2: SATA max UDMA/133 abar m2048@0xf3236000 port 0xf3236180 irq 42
2 月 21 10:51:13 linux-50zl kernel: ata3: SATA max UDMA/133 abar m2048@0xf3236000 port 0xf3236200 irq 42
2 月 21 10:51:13 linux-50zl kernel: ata4: SATA max UDMA/133 abar m2048@0xf3236000 port 0xf3236280 irq 42
2 月 21 10:51:13 linux-50zl kernel: ata5: DUMMY
2 月 21 10:51:13 linux-50zl kernel: ata6: DUMMY
2 月 21 10:51:13 linux-50zl kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
2 月 21 10:51:13 linux-50zl kernel: ehci-pci: EHCI PCI platform driver
2 月 21 10:51:13 linux-50zl kernel: ehci-pci 0000:00:1a.0: EHCI Host Controller
2 月 21 10:51:13 linux-50zl kernel: ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
2 月 21 10:51:13 linux-50zl kernel: ehci-pci 0000:00:1a.0: debug port 2
2 月 21 10:51:13 linux-50zl kernel: ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
2 月 21 10:51:13 linux-50zl kernel: ehci-pci 0000:00:1a.0: irq 16, io mem 0xf3238000
2 月 21 10:51:13 linux-50zl kernel: ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
2 月 21 10:51:13 linux-50zl kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
2 月 21 10:51:13 linux-50zl kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2 月 21 10:51:13 linux-50zl kernel: usb usb1: Product: EHCI Host Controller
2 月 21 10:51:13 linux-50zl kernel: usb usb1: Manufacturer: Linux 3.16.7-7-desktop ehci_hcd
2 月 21 10:51:13 linux-50zl kernel: usb usb1: SerialNumber: 0000:00:1a.0
2 月 21 10:51:13 linux-50zl kernel: hub 1-0:1.0: USB hub found
2 月 21 10:51:13 linux-50zl kernel: hub 1-0:1.0: 2 ports detected
2 月 21 10:51:13 linux-50zl kernel: ehci-pci 0000:00:1d.0: EHCI Host Controller
2 月 21 10:51:13 linux-50zl kernel: ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
2 月 21 10:51:13 linux-50zl kernel: ehci-pci 0000:00:1d.0: debug port 2
2 月 21 10:51:13 linux-50zl kernel: ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
2 月 21 10:51:13 linux-50zl kernel: ehci-pci 0000:00:1d.0: irq 23, io mem 0xf3237000
2 月 21 10:51:13 linux-50zl kernel: ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
2 月 21 10:51:13 linux-50zl kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
2 月 21 10:51:13 linux-50zl kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2 月 21 10:51:13 linux-50zl kernel: usb usb2: Product: EHCI Host Controller
2 月 21 10:51:13 linux-50zl kernel: usb usb2: Manufacturer: Linux 3.16.7-7-desktop ehci_hcd
2 月 21 10:51:13 linux-50zl kernel: usb usb2: SerialNumber: 0000:00:1d.0
2 月 21 10:51:13 linux-50zl kernel: hub 2-0:1.0: USB hub found
2 月 21 10:51:13 linux-50zl kernel: hub 2-0:1.0: 2 ports detected
2 月 21 10:51:13 linux-50zl kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
2 月 21 10:51:13 linux-50zl kernel: uhci_hcd: USB Universal Host Controller Interface driver
2 月 21 10:51:13 linux-50zl kernel: i8042: PNP: No PS/2 controller found. Probing ports directly.
2 月 21 10:51:13 linux-50zl kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
2 月 21 10:51:13 linux-50zl kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
2 月 21 10:51:13 linux-50zl kernel: mousedev: PS/2 mouse device common for all mice
2 月 21 10:51:13 linux-50zl kernel: rtc_cmos 00:02: RTC can wake from S4
2 月 21 10:51:13 linux-50zl kernel: rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
2 月 21 10:51:13 linux-50zl kernel: rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
2 月 21 10:51:13 linux-50zl kernel: Intel P-state driver initializing.
2 月 21 10:51:13 linux-50zl kernel: Intel pstate controlling: cpu 0
2 月 21 10:51:13 linux-50zl kernel: Intel pstate controlling: cpu 1
2 月 21 10:51:13 linux-50zl kernel: Intel pstate controlling: cpu 2
2 月 21 10:51:13 linux-50zl kernel: Intel pstate controlling: cpu 3
2 月 21 10:51:13 linux-50zl kernel: Intel pstate controlling: cpu 4
2 月 21 10:51:13 linux-50zl kernel: Intel pstate controlling: cpu 5
2 月 21 10:51:13 linux-50zl kernel: Intel pstate controlling: cpu 6
2 月 21 10:51:13 linux-50zl kernel: Intel pstate controlling: cpu 7
2 月 21 10:51:13 linux-50zl kernel: ledtrig-cpu: registered to indicate activity on CPUs
2 月 21 10:51:13 linux-50zl kernel: EFI Variables Facility v0.08 2004-May-17
2 月 21 10:51:13 linux-50zl kernel: hidraw: raw HID events driver (C) Jiri Kosina
2 月 21 10:51:13 linux-50zl kernel: usbcore: registered new interface driver usbhid
2 月 21 10:51:13 linux-50zl kernel: usbhid: USB HID core driver
2 月 21 10:51:13 linux-50zl kernel: TCP: cubic registered
2 月 21 10:51:13 linux-50zl kernel: NET: Registered protocol family 10
2 月 21 10:51:13 linux-50zl kernel: Loading compiled-in X.509 certificates
2 月 21 10:51:13 linux-50zl kernel: registered taskstats version 1
2 月 21 10:51:13 linux-50zl kernel: AppArmor: AppArmor sha1 policy hashing enabled
2 月 21 10:51:13 linux-50zl kernel: Magic number: 3:950:881
2 月 21 10:51:13 linux-50zl kernel: rtc_cmos 00:02: setting system clock to 2015-02-21 10:51:13 UTC (1424515873)
2 月 21 10:51:13 linux-50zl kernel: PM: Checking hibernation image partition /dev/sda6
2 月 21 10:51:13 linux-50zl kernel: ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
2 月 21 10:51:13 linux-50zl kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
2 月 21 10:51:13 linux-50zl kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
2 月 21 10:51:13 linux-50zl kernel: ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
2 月 21 10:51:13 linux-50zl kernel: ata3.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
2 月 21 10:51:13 linux-50zl kernel: ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
2 月 21 10:51:13 linux-50zl kernel: ata3.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
2 月 21 10:51:13 linux-50zl kernel: ata2.00: ATA-8: WDC WD1002FAEX-00Y9A0, 05.01D05, max UDMA/133
2 月 21 10:51:13 linux-50zl kernel: ata2.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
2 月 21 10:51:13 linux-50zl kernel: ata2.00: configured for UDMA/133
2 月 21 10:51:13 linux-50zl kernel: usb 1-1: new high-speed USB device number 2 using ehci-pci
2 月 21 10:51:13 linux-50zl kernel: ata1.00: ATA-9: INTEL SSDSC2BW120A4, DC32, max UDMA/133
2 月 21 10:51:13 linux-50zl kernel: ata1.00: 234441648 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
2 月 21 10:51:13 linux-50zl kernel: ata3.00: HPA detected: current 156299375, native 156301488
2 月 21 10:51:13 linux-50zl kernel: ata3.00: ATA-7: ST380815AS, 3.AAC, max UDMA/133
2 月 21 10:51:13 linux-50zl kernel: ata3.00: 156299375 sectors, multi 16: LBA48 NCQ (depth 31/32)
2 月 21 10:51:13 linux-50zl kernel: ata1.00: configured for UDMA/133
2 月 21 10:51:13 linux-50zl kernel: scsi 0:0:0:0: Direct-Access ATA INTEL SSDSC2BW12 DC32 PQ: 0 ANSI: 5
2 月 21 10:51:13 linux-50zl kernel: sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
2 月 21 10:51:13 linux-50zl kernel: scsi 1:0:0:0: Direct-Access ATA WDC WD1002FAEX-0 1D05 PQ: 0 ANSI: 5
2 月 21 10:51:13 linux-50zl kernel: sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
2 月 21 10:51:13 linux-50zl kernel: sd 0:0:0:0: [sda] Write Protect is off
2 月 21 10:51:13 linux-50zl kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
2 月 21 10:51:13 linux-50zl kernel: sd 1:0:0:0: [sdb] Write Protect is off
2 月 21 10:51:13 linux-50zl kernel: sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
2 月 21 10:51:13 linux-50zl kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
2 月 21 10:51:13 linux-50zl kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
2 月 21 10:51:13 linux-50zl kernel: sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7
2 月 21 10:51:13 linux-50zl kernel: sd 0:0:0:0: [sda] Attached SCSI disk
2 月 21 10:51:13 linux-50zl kernel: ata4.00: ATA-7: ST380815AS, 3.AAD, max UDMA/133
2 月 21 10:51:13 linux-50zl kernel: ata4.00: 156301488 sectors, multi 16: LBA48 NCQ (depth 31/32)
2 月 21 10:51:13 linux-50zl kernel: sdb: sdb1 sdb2
2 月 21 10:51:13 linux-50zl kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
2 月 21 10:51:13 linux-50zl kernel: ata3.00: configured for UDMA/133
2 月 21 10:51:13 linux-50zl kernel: scsi 2:0:0:0: Direct-Access ATA ST380815AS C PQ: 0 ANSI: 5
2 月 21 10:51:13 linux-50zl kernel: sd 2:0:0:0: [sdc] 156299375 512-byte logical blocks: (80.0 GB/74.5 GiB)
2 月 21 10:51:13 linux-50zl kernel: sd 2:0:0:0: [sdc] Write Protect is off
2 月 21 10:51:13 linux-50zl kernel: sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
2 月 21 10:51:13 linux-50zl kernel: sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
2 月 21 10:51:13 linux-50zl kernel: ata4.00: configured for UDMA/133
2 月 21 10:51:13 linux-50zl kernel: scsi 3:0:0:0: Direct-Access ATA ST380815AS D PQ: 0 ANSI: 5
2 月 21 10:51:13 linux-50zl kernel: sd 3:0:0:0: [sdd] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
2 月 21 10:51:13 linux-50zl kernel: sd 3:0:0:0: [sdd] Write Protect is off
2 月 21 10:51:13 linux-50zl kernel: sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
2 月 21 10:51:13 linux-50zl kernel: sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
2 月 21 10:51:13 linux-50zl kernel: usb 1-1: New USB device found, idVendor=8087, idProduct=8008
2 月 21 10:51:13 linux-50zl kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
2 月 21 10:51:13 linux-50zl kernel: hub 1-1:1.0: USB hub found
2 月 21 10:51:13 linux-50zl kernel: hub 1-1:1.0: 6 ports detected
2 月 21 10:51:13 linux-50zl kernel: sdc: sdc1 sdc2
2 月 21 10:51:13 linux-50zl kernel: sd 2:0:0:0: [sdc] Attached SCSI disk
2 月 21 10:51:13 linux-50zl kernel: sdd: sdd1
2 月 21 10:51:13 linux-50zl kernel: sd 3:0:0:0: [sdd] Attached SCSI disk
2 月 21 10:51:13 linux-50zl kernel: PM: Hibernation image partition 8:6 present
2 月 21 10:51:13 linux-50zl kernel: PM: Looking for hibernation image.
2 月 21 10:51:13 linux-50zl kernel: PM: Image not found (code -22)
2 月 21 10:51:13 linux-50zl kernel: PM: Hibernation image not present or could not be loaded.
2 月 21 10:51:13 linux-50zl kernel: Freeing unused kernel memory: 1560K (ffffffff81efe000 - ffffffff82084000)
2 月 21 10:51:13 linux-50zl kernel: Write protecting the kernel read-only data: 14336k
2 月 21 10:51:13 linux-50zl kernel: Freeing unused kernel memory: 1880K (ffff88000162a000 - ffff880001800000)
2 月 21 10:51:13 linux-50zl kernel: Freeing unused kernel memory: 1436K (ffff880001c99000 - ffff880001e00000)
2 月 21 10:51:13 linux-50zl systemd[1]: RTC configured in localtime, applying delta of 480 minutes to system time.
2 月 21 10:51:13 linux-50zl kernel: random: systemd urandom read with 49 bits of entropy available
2 月 21 10:51:13 linux-50zl kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
2 月 21 10:51:13 linux-50zl kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
2 月 21 10:51:13 linux-50zl kernel: sd 2:0:0:0: Attached scsi generic sg2 type 0
2 月 21 10:51:13 linux-50zl kernel: sd 3:0:0:0: Attached scsi generic sg3 type 0
2 月 21 10:51:13 linux-50zl systemd-journal[176]: Journal started
2 月 21 10:51:13 linux-50zl systemd-vconsole-setup[177]: /usr/bin/setfont failed with error code 1.
2 月 21 10:51:13 linux-50zl dracut-cmdline[174]: dracut-13.2 (Harlequin) dracut-037-17.9.1
2 月 21 10:51:13 linux-50zl systemd-vconsole-setup[177]: mapscrn: cannot open map file _trivial_
2 月 21 10:51:13 linux-50zl kernel: usb 2-1: new high-speed USB device number 2 using ehci-pci
2 月 21 10:51:14 linux-50zl kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
2 月 21 10:51:14 linux-50zl kernel: ACPI: Power Button [PWRB]
2 月 21 10:51:14 linux-50zl kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
2 月 21 10:51:14 linux-50zl kernel: ACPI: Power Button [PWRF]
2 月 21 10:51:14 linux-50zl kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
2 月 21 10:51:14 linux-50zl kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
2 月 21 10:51:14 linux-50zl kernel: xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
2 月 21 10:51:14 linux-50zl kernel: xhci_hcd 0000:00:14.0: irq 43 for MSI/MSI-X
2 月 21 10:51:14 linux-50zl kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
2 月 21 10:51:14 linux-50zl kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2 月 21 10:51:14 linux-50zl kernel: usb usb3: Product: xHCI Host Controller
2 月 21 10:51:14 linux-50zl kernel: usb usb3: Manufacturer: Linux 3.16.7-7-desktop xhci_hcd
2 月 21 10:51:14 linux-50zl kernel: usb usb3: SerialNumber: 0000:00:14.0
2 月 21 10:51:14 linux-50zl kernel: hub 3-0:1.0: USB hub found
2 月 21 10:51:14 linux-50zl kernel: hub 3-0:1.0: 12 ports detected
2 月 21 10:51:14 linux-50zl kernel: [drm] Initialized drm 1.1.0 20060810
2 月 21 10:51:14 linux-50zl kernel: wmi: Mapper loaded
2 月 21 10:51:14 linux-50zl kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
2 月 21 10:51:14 linux-50zl kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
2 月 21 10:51:14 linux-50zl kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2 月 21 10:51:14 linux-50zl kernel: usb usb4: Product: xHCI Host Controller
2 月 21 10:51:14 linux-50zl kernel: usb usb4: Manufacturer: Linux 3.16.7-7-desktop xhci_hcd
2 月 21 10:51:14 linux-50zl kernel: usb usb4: SerialNumber: 0000:00:14.0
2 月 21 10:51:14 linux-50zl kernel: hub 4-0:1.0: USB hub found
2 月 21 10:51:14 linux-50zl kernel: hub 4-0:1.0: 6 ports detected
2 月 21 10:51:14 linux-50zl kernel: checking generic (f1000000 300000) vs hw (e8000000 8000000)
2 月 21 10:51:14 linux-50zl kernel: checking generic (f1000000 300000) vs hw (f0000000 2000000)
2 月 21 10:51:14 linux-50zl kernel: fb: switching to nouveaufb from EFI VGA
2 月 21 10:51:14 linux-50zl kernel: Console: switching to colour dummy device 80x25
2 月 21 10:51:14 linux-50zl kernel: nouveau DEVICE][0000:01:00.0] BOOT0 : 0x0e4070a2
2 月 21 10:51:14 linux-50zl kernel: nouveau DEVICE][0000:01:00.0] Chipset: GK104 (NVE4)
2 月 21 10:51:14 linux-50zl kernel: nouveau DEVICE][0000:01:00.0] Family : NVE0
2 月 21 10:51:14 linux-50zl kernel: nouveau VBIOS][0000:01:00.0] checking PRAMIN for image...
2 月 21 10:51:14 linux-50zl kernel: nouveau VBIOS][0000:01:00.0] ... signature not found
2 月 21 10:51:14 linux-50zl kernel: nouveau VBIOS][0000:01:00.0] checking PROM for image...
2 月 21 10:51:14 linux-50zl kernel: nouveau VBIOS][0000:01:00.0] ... appears to be valid
2 月 21 10:51:14 linux-50zl kernel: nouveau VBIOS][0000:01:00.0] using image from PROM
2 月 21 10:51:14 linux-50zl kernel: nouveau VBIOS][0000:01:00.0] BIT signature found
2 月 21 10:51:14 linux-50zl kernel: nouveau VBIOS][0000:01:00.0] version 80.04.bf.00.63
2 月 21 10:51:14 linux-50zl kernel: nouveau 0000:01:00.0: irq 44 for MSI/MSI-X
2 月 21 10:51:14 linux-50zl kernel: nouveau PMC][0000:01:00.0] MSI interrupts enabled
2 月 21 10:51:14 linux-50zl kernel: nouveau PFB][0000:01:00.0] RAM type: GDDR5
2 月 21 10:51:14 linux-50zl kernel: nouveau PFB][0000:01:00.0] RAM size: 2048 MiB
2 月 21 10:51:14 linux-50zl kernel: nouveau PFB][0000:01:00.0] ZCOMP: 0 tags
2 月 21 10:51:14 linux-50zl kernel: nouveau VOLT][0000:01:00.0] GPU voltage: 862500uv
2 月 21 10:51:14 linux-50zl kernel: nouveau PTHERM][0000:01:00.0] FAN control: PWM
2 月 21 10:51:14 linux-50zl kernel: nouveau PTHERM][0000:01:00.0] fan management: automatic
2 月 21 10:51:14 linux-50zl kernel: nouveau PTHERM][0000:01:00.0] internal sensor: yes
2 月 21 10:51:14 linux-50zl kernel: nouveau CLK][0000:01:00.0] 07: core 405 MHz memory 648 MHz
2 月 21 10:51:14 linux-50zl kernel: nouveau CLK][0000:01:00.0] 0a: core 405-967 MHz memory 1620 MHz
2 月 21 10:51:14 linux-50zl kernel: nouveau CLK][0000:01:00.0] 0e: core 405-1306 MHz memory 6008 MHz
2 月 21 10:51:14 linux-50zl kernel: nouveau CLK][0000:01:00.0] 0f: core 405-1306 MHz memory 6008 MHz
2 月 21 10:51:14 linux-50zl kernel: nouveau CLK][0000:01:00.0] --: core 405 MHz memory 648 MHz
2 月 21 10:51:14 linux-50zl kernel: usb 2-1: New USB device found, idVendor=8087, idProduct=8000
2 月 21 10:51:14 linux-50zl kernel: usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
2 月 21 10:51:14 linux-50zl kernel: hub 2-1:1.0: USB hub found
2 月 21 10:51:14 linux-50zl kernel: hub 2-1:1.0: 6 ports detected
2 月 21 10:51:14 linux-50zl kernel: random: nonblocking pool is initialized
2 月 21 10:51:14 linux-50zl kernel: [TTM] Zone kernel: Available graphics memory: 4063682 kiB
2 月 21 10:51:14 linux-50zl kernel: [TTM] Zone dma32: Available graphics memory: 2097152 kiB
2 月 21 10:51:14 linux-50zl kernel: [TTM] Initializing pool allocator
2 月 21 10:51:14 linux-50zl kernel: [TTM] Initializing DMA pool allocator
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] VRAM: 2048 MiB
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] GART: 1048576 MiB
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] TMDS table version 2.0
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] DCB version 4.0
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] DCB outp 00: 01000f02 00020030
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] DCB outp 01: 02000f00 00000000
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] DCB outp 02: 08011f82 00020030
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] DCB outp 03: 02022f62 00020010
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] DCB outp 04: 04833fb6 0f420010
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] DCB outp 05: 04033f72 00020010
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] DCB conn 00: 00001030
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] DCB conn 01: 00020131
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] DCB conn 02: 00010261
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] DCB conn 03: 00002346
2 月 21 10:51:14 linux-50zl kernel: [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
2 月 21 10:51:14 linux-50zl kernel: [drm] Driver supports precise vblank timestamp query.
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] MM: using COPY for buffer copies
2 月 21 10:51:14 linux-50zl kernel: nouveau DRM] allocated 1920x1080 fb: 0x80000, bo ffff880220c5a000
2 月 21 10:51:14 linux-50zl kernel: fbcon: nouveaufb (fb0) is primary device
2 月 21 10:51:14 linux-50zl kernel: usb 3-10: new high-speed USB device number 2 using xhci_hcd
2 月 21 10:51:14 linux-50zl kernel: tsc: Refined TSC clocksource calibration: 3292.375 MHz
2 月 21 10:51:14 linux-50zl kernel: Console: switching to colour frame buffer device 240x67
2 月 21 10:51:14 linux-50zl kernel: nouveau 0000:01:00.0: fb0: nouveaufb frame buffer device
2 月 21 10:51:14 linux-50zl kernel: nouveau 0000:01:00.0: registered panic notifier
2 月 21 10:51:14 linux-50zl kernel: [drm] Initialized nouveau 1.1.2 20120801 for 0000:01:00.0 on minor 0
2 月 21 10:51:14 linux-50zl kernel: PM: Marking nosave pages: [mem 0x00058000-0x00058fff]
2 月 21 10:51:14 linux-50zl kernel: PM: Marking nosave pages: [mem 0x0009f000-0x000fffff]
2 月 21 10:51:14 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbae42000-0xbae42fff]
2 月 21 10:51:14 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbae52000-0xbae53fff]
2 月 21 10:51:14 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbae72000-0xbae72fff]
2 月 21 10:51:14 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbb159000-0xbb15ffff]
2 月 21 10:51:14 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbc16f000-0xbc674fff]
2 月 21 10:51:14 linux-50zl kernel: PM: Marking nosave pages: [mem 0xce793000-0xcf7fefff]
2 月 21 10:51:14 linux-50zl kernel: PM: Marking nosave pages: [mem 0xcf800000-0xffffffff]
2 月 21 10:51:14 linux-50zl kernel: PM: Basic memory bitmaps created
2 月 21 10:51:14 linux-50zl kernel: usb 3-10: New USB device found, idVendor=2109, idProduct=2812
2 月 21 10:51:14 linux-50zl kernel: usb 3-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
2 月 21 10:51:14 linux-50zl kernel: usb 3-10: Product: USB2.0 Hub
2 月 21 10:51:14 linux-50zl kernel: usb 3-10: Manufacturer: VIA Labs, Inc.
2 月 21 10:51:14 linux-50zl kernel: hub 3-10:1.0: USB hub found
2 月 21 10:51:14 linux-50zl kernel: hub 3-10:1.0: 4 ports detected
2 月 21 10:51:14 linux-50zl kernel: PM: Basic memory bitmaps freed
2 月 21 10:51:14 linux-50zl kernel: PM: Starting manual resume from disk
2 月 21 10:51:14 linux-50zl kernel: PM: Hibernation image partition 8:6 present
2 月 21 10:51:14 linux-50zl kernel: PM: Looking for hibernation image.
2 月 21 10:51:14 linux-50zl kernel: PM: Image not found (code -22)
2 月 21 10:51:14 linux-50zl kernel: PM: Hibernation image not present or could not be loaded.
2 月 21 10:51:14 linux-50zl systemd-fsck[332]: /dev/sda7: clean, 294188/1474560 files, 2425194/5890304 blocks
2 月 21 10:51:14 linux-50zl kernel: EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)
2 月 21 10:51:14 linux-50zl kernel: usb 4-6: new SuperSpeed USB device number 2 using xhci_hcd
2 月 21 10:51:14 linux-50zl systemd-journal[176]: Journal stopped
2 月 21 10:51:14 linux-50zl systemd-journal[432]: Runtime journal is using 8.0M (max allowed 396.8M, trying to leave 595.2M free of 3.8G available → current limit 396.8M).
2 月 21 10:51:14 linux-50zl systemd[1]: RTC configured in localtime, applying delta of 480 minutes to system time.
2 月 21 10:51:14 linux-50zl kernel: device-mapper: uevent: version 1.0.3
2 月 21 10:51:14 linux-50zl kernel: device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: dm-devel@redhat.com
2 月 21 10:51:14 linux-50zl systemd-journal[432]: Journal started
2 月 21 10:51:14 linux-50zl dmeventd[438]: dmeventd ready for processing.
2 月 21 10:51:14 linux-50zl systemd-fsck[442]: /dev/sda7: clean, 294188/1474560 files, 2425194/5890304 blocks
2 月 21 10:51:14 linux-50zl kernel: EXT4-fs (sda7): re-mounted. Opts: acl,user_xattr
2 月 21 10:51:14 linux-50zl kernel: usb 4-6: New USB device found, idVendor=2109, idProduct=0812
2 月 21 10:51:14 linux-50zl kernel: usb 4-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
2 月 21 10:51:14 linux-50zl kernel: usb 4-6: Product: USB3.0 Hub
2 月 21 10:51:14 linux-50zl kernel: usb 4-6: Manufacturer: VIA Labs, Inc.
2 月 21 10:51:14 linux-50zl kernel: hub 4-6:1.0: USB hub found
2 月 21 10:51:14 linux-50zl kernel: hub 4-6:1.0: 4 ports detected
2 月 21 10:51:14 linux-50zl kernel: parport_pc 00:06: reported by Plug and Play ACPI
2 月 21 10:51:14 linux-50zl kernel: parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
2 月 21 10:51:14 linux-50zl kernel: ACPI: Fan [FAN0] (off)
2 月 21 10:51:14 linux-50zl kernel: ACPI: Fan [FAN1] (off)
2 月 21 10:51:14 linux-50zl kernel: ACPI: Fan [FAN2] (off)
2 月 21 10:51:14 linux-50zl kernel: ACPI: Fan [FAN3] (off)
2 月 21 10:51:14 linux-50zl kernel: ACPI: Fan [FAN4] (off)
2 月 21 10:51:14 linux-50zl kernel: thermal LNXTHERM:00: registered as thermal_zone0
2 月 21 10:51:14 linux-50zl kernel: ACPI: Thermal Zone [TZ00] (28 C)
2 月 21 10:51:14 linux-50zl kernel: thermal LNXTHERM:01: registered as thermal_zone1
2 月 21 10:51:14 linux-50zl kernel: ACPI: Thermal Zone [TZ01] (30 C)
2 月 21 10:51:14 linux-50zl kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
2 月 21 10:51:14 linux-50zl kernel: mei_me 0000:00:16.0: irq 45 for MSI/MSI-X
2 月 21 10:51:14 linux-50zl kernel: pps_core: LinuxPPS API ver. 1 registered
2 月 21 10:51:14 linux-50zl kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
2 月 21 10:51:14 linux-50zl kernel: PTP clock support registered
2 月 21 10:51:14 linux-50zl kernel: e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
2 月 21 10:51:14 linux-50zl kernel: e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
2 月 21 10:51:14 linux-50zl kernel: e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
2 月 21 10:51:14 linux-50zl kernel: e1000e 0000:00:19.0: irq 46 for MSI/MSI-X
2 月 21 10:51:14 linux-50zl kernel: 8139cp: 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
2 月 21 10:51:14 linux-50zl kernel: 8139cp 0000:04:00.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip, use 8139too
2 月 21 10:51:14 linux-50zl kernel: 8139too: 8139too Fast Ethernet driver 0.9.28
2 月 21 10:51:14 linux-50zl kernel: 8139too 0000:04:00.0: enabling device (0000 -> 0003)
2 月 21 10:51:14 linux-50zl kernel: 8139too 0000:04:00.0 eth0: RealTek RTL8139 at 0xffffc90004cb8000, 00:e0:09:06:2e:0c, IRQ 19
2 月 21 10:51:14 linux-50zl kernel: input: PC Speaker as /devices/platform/pcspkr/input/input5
2 月 21 10:51:14 linux-50zl kernel: AVX2 version of gcm_enc/dec engaged.
2 月 21 10:51:14 linux-50zl kernel: usb 3-10.4: new full-speed USB device number 3 using xhci_hcd
2 月 21 10:51:15 linux-50zl kernel: ppdev: user-space parallel port driver
2 月 21 10:51:15 linux-50zl kernel: usb 3-10.4: New USB device found, idVendor=046d, idProduct=c52b
2 月 21 10:51:15 linux-50zl kernel: usb 3-10.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
2 月 21 10:51:15 linux-50zl kernel: usb 3-10.4: Product: USB Receiver
2 月 21 10:51:15 linux-50zl kernel: usb 3-10.4: Manufacturer: Logitech
2 月 21 10:51:15 linux-50zl mtp-probe[763]: checking bus 3, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10.4"
2 月 21 10:51:15 linux-50zl mtp-probe[763]: bus: 3, device: 3 was not an MTP device
2 月 21 10:51:15 linux-50zl kernel: logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-10.4/input2
2 月 21 10:51:15 linux-50zl kernel: Adding 515068k swap on /dev/sda6. Priority:-1 extents:1 across:515068k SSFS
2 月 21 10:51:15 linux-50zl kernel: input: Logitech Unifying Device. Wireless PID:1024 as /devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10.4/3-10.4:1.2/0003:046D:C52B.0003/0003:046D:C52B.0004/input/input6
2 月 21 10:51:15 linux-50zl kernel: logitech-djdevice 0003:046D:C52B.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech Unifying Device. Wireless PID:1024] on usb-0000:00:14.0-10.4:1
2 月 21 10:51:15 linux-50zl kernel: input: Logitech Unifying Device. Wireless PID:2011 as /devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10.4/3-10.4:1.2/0003:046D:C52B.0003/0003:046D:C52B.0005/input/input7
2 月 21 10:51:15 linux-50zl kernel: logitech-djdevice 0003:046D:C52B.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:2011] on usb-0000:00:14.0-10.4:2
2 月 21 10:51:15 linux-50zl kernel: e1000e 0000:00:19.0 eth0: registered PHC clock
2 月 21 10:51:15 linux-50zl kernel: e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 74:d4:35:1a:e9:a3
2 月 21 10:51:15 linux-50zl kernel: e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
2 月 21 10:51:15 linux-50zl kernel: e1000e 0000:00:19.0 eth0: MAC: 11, PHY: 12, PBA No: FFFFFF-0FF
2 月 21 10:51:15 linux-50zl kernel: snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
2 月 21 10:51:15 linux-50zl kernel: snd_hda_intel 0000:00:1b.0: irq 47 for MSI/MSI-X
2 月 21 10:51:15 linux-50zl kernel: i801_smbus 0000:00:1f.3: enabling device (0001 -> 0003)
2 月 21 10:51:15 linux-50zl kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
2 月 21 10:51:15 linux-50zl kernel: snd_hda_intel 0000:01:00.1: Handle VGA-switcheroo audio client
2 月 21 10:51:15 linux-50zl kernel: ACPI Warning: SystemIO range 0x000000000000f000-0x000000000000f01f conflicts with OpRegion 0x000000000000f000-0x000000000000f00f (\_SB_.PCI0.SBUS.SMBI) (20140424/utaddress-258)
2 月 21 10:51:15 linux-50zl kernel: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
2 月 21 10:51:15 linux-50zl kernel: iTCO_vendor_support: vendor-support=0
2 月 21 10:51:15 linux-50zl kernel: iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
2 月 21 10:51:15 linux-50zl kernel: iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
2 月 21 10:51:15 linux-50zl kernel: sound hdaudioC0D2: autoconfig: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
2 月 21 10:51:15 linux-50zl kernel: sound hdaudioC0D2: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
2 月 21 10:51:15 linux-50zl kernel: sound hdaudioC0D2: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
2 月 21 10:51:15 linux-50zl kernel: sound hdaudioC0D2: mono: mono_out=0x0
2 月 21 10:51:15 linux-50zl kernel: sound hdaudioC0D2: dig-out=0x11/0x1e
2 月 21 10:51:15 linux-50zl kernel: sound hdaudioC0D2: inputs:
2 月 21 10:51:15 linux-50zl kernel: sound hdaudioC0D2: Rear Mic=0x18
2 月 21 10:51:15 linux-50zl kernel: sound hdaudioC0D2: Front Mic=0x19
2 月 21 10:51:15 linux-50zl kernel: sound hdaudioC0D2: Line=0x1a
2 月 21 10:51:15 linux-50zl kernel: sound hdaudioC0D2: CD=0x1c
2 月 21 10:51:15 linux-50zl kernel: sound hdaudioC0D2: dig-in=0x1f
2 月 21 10:51:15 linux-50zl kernel: input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/hdaudioC0D2/input8
2 月 21 10:51:15 linux-50zl kernel: input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
2 月 21 10:51:15 linux-50zl kernel: input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
2 月 21 10:51:15 linux-50zl kernel: input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
2 月 21 10:51:15 linux-50zl kernel: input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
2 月 21 10:51:15 linux-50zl kernel: input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
2 月 21 10:51:15 linux-50zl kernel: input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
2 月 21 10:51:15 linux-50zl lvm[790]: WARNING: lvmetad is running but disabled. Restart lvmetad before enabling it!
2 月 21 10:51:15 linux-50zl lvm[790]: No volume groups found
2 月 21 10:51:15 linux-50zl lvm[796]: WARNING: lvmetad is running but disabled. Restart lvmetad before enabling it!
2 月 21 10:51:15 linux-50zl systemd-fsck[783]: /dev/sdc2: clean, 30846/1281120 files, 654289/5120256 blocks
2 月 21 10:51:15 linux-50zl kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
2 月 21 10:51:15 linux-50zl kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
2 月 21 10:51:15 linux-50zl kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
2 月 21 10:51:15 linux-50zl kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
2 月 21 10:51:15 linux-50zl kernel: Switched to clocksource tsc
2 月 21 10:51:15 linux-50zl lvm[796]: No volume groups found
2 月 21 10:51:15 linux-50zl kernel: EXT4-fs (sdc2): mounted filesystem with ordered data mode. Opts: (null)
2 月 21 10:51:15 linux-50zl systemd-journal[432]: Permanent journal is using 24.0M (max allowed 2.1G, trying to leave 3.2G free of 12.1G available → current limit 2.1G).
2 月 21 10:51:15 linux-50zl systemd-journal[432]: Time spent on flushing to /var is 277.287ms for 1149 entries.
2 月 21 10:51:15 linux-50zl kernel: audit: type=1305 audit(1424487075.580:2): audit_pid=825 old=0 auid=4294967295 ses=4294967295 res=1
2 月 21 10:51:15 linux-50zl auditd[825]: Started dispatcher: /sbin/audispd pid: 836
2 月 21 10:51:15 linux-50zl audispd[836]: priority_boost_parser called with: 4
2 月 21 10:51:15 linux-50zl audispd[836]: max_restarts_parser called with: 10
2 月 21 10:51:15 linux-50zl audispd[836]: No plugins found, exiting
2 月 21 10:51:15 linux-50zl auditd[825]: Init complete, auditd 2.4 listening for events (startup state enable)
2 月 21 10:51:15 linux-50zl avahi-daemon[1015]: Found user 'avahi' (UID 486) and group 'avahi' (GID 485).
2 月 21 10:51:15 linux-50zl avahi-daemon[1015]: Successfully dropped root privileges.
2 月 21 10:51:15 linux-50zl avahi-daemon[1015]: avahi-daemon 0.6.31 starting up.
2 月 21 10:51:15 linux-50zl ModemManager[1017]: <info> ModemManager (version 1.0.0) starting...
2 月 21 10:51:15 linux-50zl avahi-daemon[1015]: Loading service file /etc/avahi/services/sftp-ssh.service.
2 月 21 10:51:15 linux-50zl avahi-daemon[1015]: Loading service file /etc/avahi/services/ssh.service.
2 月 21 10:51:15 linux-50zl avahi-daemon[1015]: Network interface enumeration completed.
2 月 21 10:51:15 linux-50zl dbus[1024]: [system] Activating systemd to hand-off: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
2 月 21 10:51:15 linux-50zl avahi-daemon[1015]: Registering HINFO record with values 'X86_64'/'LINUX'.
2 月 21 10:51:15 linux-50zl avahi-daemon[1015]: Server startup complete. Host name is linux-50zl.local. Local service cookie is 2162636936.
2 月 21 10:51:15 linux-50zl avahi-daemon[1015]: Service "linux-50zl" (/etc/avahi/services/ssh.service) successfully established.
2 月 21 10:51:15 linux-50zl dbus[1024]: [system] Successfully activated service 'org.freedesktop.systemd1'
2 月 21 10:51:15 linux-50zl avahi-daemon[1015]: Service "linux-50zl" (/etc/avahi/services/sftp-ssh.service) successfully established.
2 月 21 10:51:15 linux-50zl boot.apparmor[824]: Starting AppArmor ..done
2 月 21 10:51:15 linux-50zl auditctl[826]: No rules
2 月 21 10:51:15 linux-50zl auditctl[826]: enabled 0
2 月 21 10:51:15 linux-50zl auditctl[826]: flag 1
2 月 21 10:51:15 linux-50zl auditctl[826]: pid 0
2 月 21 10:51:15 linux-50zl auditctl[826]: rate_limit 0
2 月 21 10:51:15 linux-50zl auditctl[826]: backlog_limit 320
2 月 21 10:51:15 linux-50zl auditctl[826]: lost 0
2 月 21 10:51:15 linux-50zl auditctl[826]: backlog 0
2 月 21 10:51:15 linux-50zl polkitd[1043]: Started polkitd version 0.112
2 月 21 10:51:15 linux-50zl polkitd[1043]: Loading rules from directory /etc/polkit-1/rules.d
2 月 21 10:51:15 linux-50zl polkitd[1043]: Loading rules from directory /usr/share/polkit-1/rules.d
2 月 21 10:51:15 linux-50zl polkitd[1043]: Finished loading, compiling and executing 3 rules
2 月 21 10:51:15 linux-50zl dbus[1024]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
2 月 21 10:51:15 linux-50zl polkitd[1043]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
2 月 21 10:51:15 linux-50zl display-manager[1047]: /etc/vconsole.conf available
2 月 21 10:51:15 linux-50zl display-manager[1047]: KEYMAP: chinese
2 月 21 10:51:15 linux-50zl display-manager[1047]: Command: localectl set-keymap chinese
2 月 21 10:51:15 linux-50zl display-manager[1047]: W: Can not found mapping for chinese in /usr/share/systemd/kbd-model-map
2 月 21 10:51:15 linux-50zl display-manager[1047]: W: Please report bug of systemd.
2 月 21 10:51:15 linux-50zl dbus[1024]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service'
2 月 21 10:51:15 linux-50zl dbus[1024]: [system] Successfully activated service 'org.freedesktop.locale1'
2 月 21 10:51:15 linux-50zl kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
2 月 21 10:51:15 linux-50zl kernel: nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
2 月 21 10:51:15 linux-50zl kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
2 月 21 10:51:15 linux-50zl kdm_config[1101]: Multiple occurrences of section [General] in /usr/share/kde4/config/kdm/kdmrc. Consider merging them.
2 月 21 10:51:15 linux-50zl kdm_config[1101]: Multiple occurrences of section [Xdmcp] in /usr/share/kde4/config/kdm/kdmrc. Consider merging them.
2 月 21 10:51:15 linux-50zl kdm_config[1101]: Multiple occurrences of section [X-*-Core] in /usr/share/kde4/config/kdm/kdmrc. Consider merging them.
2 月 21 10:51:15 linux-50zl kdm_config[1101]: Multiple occurrences of section [X-*-Greeter] in /usr/share/kde4/config/kdm/kdmrc. Consider merging them.
2 月 21 10:51:15 linux-50zl kdm_config[1101]: Multiple occurrences of section [X-:*-Core] in /usr/share/kde4/config/kdm/kdmrc. Consider merging them.
2 月 21 10:51:15 linux-50zl kdm_config[1101]: Multiple occurrences of section [X-:0-Core] in /usr/share/kde4/config/kdm/kdmrc. Consider merging them.
2 月 21 10:51:15 linux-50zl display-manager[1047]: Starting service kdm..done
2 月 21 10:51:15 linux-50zl kdm[1100]: plymouth is running
2 月 21 10:51:16 linux-50zl kdm[1100]: plymouth is running
2 月 21 10:51:16 linux-50zl SuSEfirewall2[1130]: Firewall rules set to CLOSE.
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> NetworkManager (version 0.9.10.0) is starting...
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Read config: /etc/NetworkManager/NetworkManager.conf
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> WEXT support is enabled
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> VPN: loaded org.freedesktop.NetworkManager.openvpn
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> VPN: loaded org.freedesktop.NetworkManager.pptp
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> VPN: loaded org.freedesktop.NetworkManager.vpnc
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> VPN: loaded org.freedesktop.NetworkManager.openconnect
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Loaded plugin ifcfg-suse: (C) 2008 Novell, Inc. To report bugs please use the NetworkManager mailing list.
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Loaded plugin keyfile: (c) 2007 - 2013 Red Hat, Inc. To report bugs please use the NetworkManager mailing list.
2 月 21 10:51:16 linux-50zl kernel: cfg80211: Calling CRDA to update world regulatory domain
2 月 21 10:51:16 linux-50zl kernel: cfg80211: World regulatory domain updated:
2 月 21 10:51:16 linux-50zl kernel: cfg80211: DFS Master region: unset
2 月 21 10:51:16 linux-50zl kernel: cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
2 月 21 10:51:16 linux-50zl kernel: cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
2 月 21 10:51:16 linux-50zl kernel: cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
2 月 21 10:51:16 linux-50zl kernel: cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
2 月 21 10:51:16 linux-50zl kernel: cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
2 月 21 10:51:16 linux-50zl kernel: cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
2 月 21 10:51:16 linux-50zl kernel: cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
2 月 21 10:51:16 linux-50zl kernel: cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
2 月 21 10:51:16 linux-50zl kernel: cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> monitoring kernel firmware directory '/lib/firmware'.
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> WiFi hardware radio set enabled
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> WWAN hardware radio set enabled
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Loaded device plugin: /usr/lib64/NetworkManager/libnm-device-plugin-wifi.so
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Loaded device plugin: /usr/lib64/NetworkManager/libnm-device-plugin-adsl.so
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Loaded device plugin: /usr/lib64/NetworkManager/libnm-device-plugin-wwan.so
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Loaded device plugin: /usr/lib64/NetworkManager/libnm-device-plugin-bluetooth.so
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> WiFi enabled by radio killswitch; enabled by state file
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> WWAN enabled by radio killswitch; enabled by state file
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> WiMAX enabled by radio killswitch; enabled by state file
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Networking is enabled by state file
2 月 21 10:51:16 linux-50zl kdm[1100]: plymouth is NOT running
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (lo): link connected
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (lo): carrier is ON
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (lo): new Generic device (driver: 'unknown' ifindex: 1)
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (lo): exported as /org/freedesktop/NetworkManager/Devices/0
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (enp4s0): carrier is OFF
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (enp4s0): new Ethernet device (driver: '8139too' ifindex: 2)
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (enp4s0): exported as /org/freedesktop/NetworkManager/Devices/1
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (enp4s0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (enp4s0): link connected
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (enp4s0): preparing device
2 月 21 10:51:16 linux-50zl kernel: 8139too 0000:04:00.0 enp4s0: link up, 100Mbps, full-duplex, lpa 0xC5E1
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (enp4s0): created default wired connection 'Wired connection 1'
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (eno1): carrier is OFF
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (eno1): new Ethernet device (driver: 'e1000e' ifindex: 3)
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (eno1): exported as /org/freedesktop/NetworkManager/Devices/2
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (eno1): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
2 月 21 10:51:16 linux-50zl iscsiadm[1144]: iscsiadm: No records found
2 月 21 10:51:16 linux-50zl echo[1149]: Starting mail service (Postfix)
2 月 21 10:51:16 linux-50zl ntpd[1168]: ntpd 4.2.6p5@1.2349-o Fri Dec 19 19:15:02 UTC 2014 (1)
2 月 21 10:51:16 linux-50zl start-ntpd[1145]: Starting network time protocol daemon (NTPD)
2 月 21 10:51:16 linux-50zl ntpd[1169]: proto: precision = 0.168 usec
2 月 21 10:51:16 linux-50zl ntpd[1169]: ntp_io: estimated max descriptors: 1024, initial socket boundary: 16
2 月 21 10:51:16 linux-50zl ntpd[1169]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
2 月 21 10:51:16 linux-50zl SuSEfirewall2[1171]: Setting up rules from /etc/sysconfig/SuSEfirewall2 ...
2 月 21 10:51:16 linux-50zl ntpd[1169]: Listen and drop on 1 v6wildcard :: UDP 123
2 月 21 10:51:16 linux-50zl SuSEfirewall2[1180]: using default zone 'ext' for interface eno1
2 月 21 10:51:16 linux-50zl SuSEfirewall2[1183]: using default zone 'ext' for interface enp4s0
2 月 21 10:51:16 linux-50zl kernel: e1000e 0000:00:19.0: irq 46 for MSI/MSI-X
2 月 21 10:51:16 linux-50zl ntpd[1169]: Listen normally on 2 lo 127.0.0.1 UDP 123
2 月 21 10:51:16 linux-50zl ntpd[1169]: peers refreshed
2 月 21 10:51:16 linux-50zl ntpd[1169]: Listening on routing socket on fd #19 for interface updates
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (eno1): preparing device
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (eno1): created default wired connection 'Wired connection 2'
2 月 21 10:51:16 linux-50zl kernel: IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (enp4s0): device state change: unavailable -> disconnected (reason 'none') [20 30 0]
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Auto-activating connection 'Wired connection 1'.
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) starting connection 'Wired connection 1'
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) Stage 1 of 5 (Device Prepare) scheduled...
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) Stage 1 of 5 (Device Prepare) started...
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (enp4s0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> NetworkManager state is now CONNECTING
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) Stage 2 of 5 (Device Configure) scheduled...
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) Stage 1 of 5 (Device Prepare) complete.
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) Stage 2 of 5 (Device Configure) starting...
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (enp4s0): device state change: prepare -> config (reason 'none') [40 50 0]
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) Stage 2 of 5 (Device Configure) successful.
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) Stage 3 of 5 (IP Configure Start) scheduled.
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) Stage 2 of 5 (Device Configure) complete.
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) Stage 3 of 5 (IP Configure Start) started...
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (enp4s0): device state change: config -> ip-config (reason 'none') [50 70 0]
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) Beginning DHCPv4 transaction (timeout in 45 seconds)
2 月 21 10:51:16 linux-50zl SuSEfirewall2[1254]: Firewall rules successfully set
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> dhclient started with pid 1279
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <warn> Unable to detect kernel support for extended IFA_FLAGS. Assume no kernel support.
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) Stage 3 of 5 (IP Configure Start) complete.
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> ModemManager available in the bus
2 月 21 10:51:16 linux-50zl dhclient[1279]: Internet Systems Consortium DHCP Client 4.2.6
2 月 21 10:51:16 linux-50zl dhclient[1279]: Copyright 2004-2014 Internet Systems Consortium.
2 月 21 10:51:16 linux-50zl dhclient[1279]: All rights reserved.
2 月 21 10:51:16 linux-50zl dhclient[1279]: For info, please visit https://www.isc.org/software/dhcp/
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: Internet Systems Consortium DHCP Client 4.2.6
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: Copyright 2004-2014 Internet Systems Consortium.
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: All rights reserved.
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: For info, please visit https://www.isc.org/software/dhcp/
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: <info> (enp4s0): DHCPv4 state changed nbi -> preinit
2 月 21 10:51:16 linux-50zl kernel: NET: Registered protocol family 17
2 月 21 10:51:16 linux-50zl dhclient[1279]: Listening on LPF/enp4s0/00:e0:09:06:2e:0c
2 月 21 10:51:16 linux-50zl dhclient[1279]: Sending on LPF/enp4s0/00:e0:09:06:2e:0c
2 月 21 10:51:16 linux-50zl dhclient[1279]: Sending on Socket/fallback
2 月 21 10:51:16 linux-50zl dhclient[1279]: DHCPDISCOVER on enp4s0 to 255.255.255.255 port 67 interval 3 (xid=0x3d91acf7)
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: Listening on LPF/enp4s0/00:e0:09:06:2e:0c
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: Sending on LPF/enp4s0/00:e0:09:06:2e:0c
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: Sending on Socket/fallback
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: DHCPDISCOVER on enp4s0 to 255.255.255.255 port 67 interval 3 (xid=0x3d91acf7)
2 月 21 10:51:16 linux-50zl postfix/postfix-script[1325]: starting the Postfix mail system
2 月 21 10:51:16 linux-50zl postfix/master[1327]: daemon started -- version 2.11.3, configuration /etc/postfix
2 月 21 10:51:16 linux-50zl cron[1344]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 66% if used.)
2 月 21 10:51:16 linux-50zl cron[1344]: (CRON) INFO (running with inotify support)
2 月 21 10:51:16 linux-50zl dhclient[1279]: DHCPOFFER from 192.168.3.1
2 月 21 10:51:16 linux-50zl NetworkManager[1132]: DHCPOFFER from 192.168.3.1
2 月 21 10:51:16 linux-50zl kernel: IPv4: martian source 255.255.255.255 from 192.168.3.1, on dev enp4s0
2 月 21 10:51:16 linux-50zl kernel: ll header: 00000000: 00 e0 09 06 2e 0c 88 e3 ab 32 42 63 08 00 .........2Bc..
2 月 21 10:51:16 linux-50zl kdm_greet[1352]: Cannot load /usr/share/kde4/apps/kdm/faces/.default.face: 没有那个文件或目录
2 月 21 10:51:17 linux-50zl avahi-daemon[1015]: Joining mDNS multicast group on interface enp4s0.IPv6 with address fe80::2e0:9ff:fe06:2e0c.
2 月 21 10:51:17 linux-50zl avahi-daemon[1015]: New relevant interface enp4s0.IPv6 for mDNS.
2 月 21 10:51:17 linux-50zl avahi-daemon[1015]: Registering new address record for fe80::2e0:9ff:fe06:2e0c on enp4s0.*.
2 月 21 10:51:18 linux-50zl kernel: SFW2-INext-DROP-DEFLT IN=enp4s0 OUT= MAC= SRC=fe80:0000:0000:0000:02e0:09ff:fe06:2e0c DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=430 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=5353 DPT=5353 LEN=390
2 月 21 10:51:18 linux-50zl kernel: SFW2-INext-DROP-DEFLT IN=enp4s0 OUT= MAC= SRC=fe80:0000:0000:0000:02e0:09ff:fe06:2e0c DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=258 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=5353 DPT=5353 LEN=218
2 月 21 10:51:18 linux-50zl ModemManager[1017]: <warn> Couldn't find support for device at '/sys/devices/pci0000:00/0000:00:19.0': not supported by any plugin
2 月 21 10:51:18 linux-50zl ModemManager[1017]: <warn> Couldn't find support for device at '/sys/devices/pci0000:00/0000:00:1c.3/0000:03:00.0/0000:04:00.0': not supported by any plugin
2 月 21 10:51:18 linux-50zl kernel: SFW2-INext-DROP-DEFLT IN=enp4s0 OUT= MAC= SRC=fe80:0000:0000:0000:02e0:09ff:fe06:2e0c DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=400 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=5353 DPT=5353 LEN=360
2 月 21 10:51:21 linux-50zl dhclient[1279]: DHCPREQUEST on enp4s0 to 255.255.255.255 port 67 (xid=0x3d91acf7)
2 月 21 10:51:21 linux-50zl dhclient[1279]: DHCPACK from 192.168.3.1 (xid=0x3d91acf7)
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> (enp4s0): DHCPv4 state changed preinit -> bound
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> address 192.168.3.5
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> plen 24 (255.255.255.0)
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> gateway 192.168.3.1
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> server identifier 192.168.3.1
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> lease time 86400
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> nameserver '180.76.76.76'
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> nameserver '114.114.114.114'
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> domain name 'home'
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) Stage 5 of 5 (IPv4 Commit) started...
2 月 21 10:51:21 linux-50zl dhclient[1279]: bound to 192.168.3.5 -- renewal in 35685 seconds.
2 月 21 10:51:21 linux-50zl avahi-daemon[1015]: Joining mDNS multicast group on interface enp4s0.IPv4 with address 192.168.3.5.
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> (enp4s0): device state change: ip-config -> ip-check (reason 'none') [70 80 0]
2 月 21 10:51:21 linux-50zl avahi-daemon[1015]: New relevant interface enp4s0.IPv4 for mDNS.
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) Stage 5 of 5 (IPv4 Commit) complete.
2 月 21 10:51:21 linux-50zl avahi-daemon[1015]: Registering new address record for 192.168.3.5 on enp4s0.IPv4.
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> (enp4s0): device state change: ip-check -> secondaries (reason 'none') [80 90 0]
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> (enp4s0): device state change: secondaries -> activated (reason 'none') [90 100 0]
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> NetworkManager state is now CONNECTED_LOCAL
2 月 21 10:51:21 linux-50zl kernel: IPv4: martian source 255.255.255.255 from 192.168.3.1, on dev enp4s0
2 月 21 10:51:21 linux-50zl kernel: ll header: 00000000: 00 e0 09 06 2e 0c 88 e3 ab 32 42 63 08 00 .........2Bc..
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: DHCPREQUEST on enp4s0 to 255.255.255.255 port 67 (xid=0x3d91acf7)
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: DHCPACK from 192.168.3.1 (xid=0x3d91acf7)
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: bound to 192.168.3.5 -- renewal in 35685 seconds.
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> NetworkManager state is now CONNECTED_GLOBAL
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> Policy set 'Wired connection 1' (enp4s0) as default for IPv4 routing and DNS.
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> Activation (enp4s0) successful, device activated.
2 月 21 10:51:21 linux-50zl dbus[1024]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
2 月 21 10:51:21 linux-50zl dbus[1024]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
2 月 21 10:51:21 linux-50zl nm-dispatcher[1374]: Dispatching action 'up' for enp4s0
2 月 21 10:51:21 linux-50zl NetworkManager[1132]: <info> startup complete
2 月 21 10:51:26 linux-50zl kdm[1351]: :0[1351]: pam_unix(xdm:session): session opened for user R6l by (uid=0)
2 月 21 10:51:26 linux-50zl systemd[1484]: pam_unix(systemd-user:session): session opened for user R6l by (uid=0)
2 月 21 10:51:27 linux-50zl dbus[1024]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service'
2 月 21 10:51:27 linux-50zl dbus[1024]: [system] Successfully activated service 'org.freedesktop.UPower'
2 月 21 10:51:29 linux-50zl dbus[1024]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
2 月 21 10:51:29 linux-50zl udisksd[1695]: udisks daemon version 2.1.3 starting
2 月 21 10:51:29 linux-50zl dbus[1024]: [system] Successfully activated service 'org.freedesktop.UDisks2'
2 月 21 10:51:29 linux-50zl udisksd[1695]: Acquired the name org.freedesktop.UDisks2 on the system message bus
2 月 21 10:51:29 linux-50zl dbus[1024]: [system] Activating service name='org.kde.powerdevil.backlighthelper' (using servicehelper)
2 月 21 10:51:29 linux-50zl org.kde.powerdevil.backlighthelper[1024]: no kernel backlight interface found
2 月 21 10:51:29 linux-50zl dbus[1024]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
2 月 21 10:51:31 linux-50zl dbus[1024]: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service'
2 月 21 10:51:31 linux-50zl PackageKit[1722]: daemon start
2 月 21 10:51:31 linux-50zl dbus[1024]: [system] Successfully activated service 'org.freedesktop.PackageKit'
2 月 21 10:51:31 linux-50zl dbus[1024]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service'
2 月 21 10:51:31 linux-50zl bluetoothd[1730]: Bluetooth daemon 5.23
2 月 21 10:51:31 linux-50zl dbus[1024]: [system] Successfully activated service 'org.bluez'
2 月 21 10:51:31 linux-50zl kernel: Bluetooth: Core ver 2.19
2 月 21 10:51:31 linux-50zl kernel: NET: Registered protocol family 31
2 月 21 10:51:31 linux-50zl kernel: Bluetooth: HCI device and connection manager initialized
2 月 21 10:51:31 linux-50zl kernel: Bluetooth: HCI socket layer initialized
2 月 21 10:51:31 linux-50zl kernel: Bluetooth: L2CAP socket layer initialized
2 月 21 10:51:31 linux-50zl kernel: Bluetooth: SCO socket layer initialized
2 月 21 10:51:31 linux-50zl bluetoothd[1730]: Starting SDP server
2 月 21 10:51:31 linux-50zl kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
2 月 21 10:51:31 linux-50zl kernel: Bluetooth: BNEP filters: protocol multicast
2 月 21 10:51:31 linux-50zl kernel: Bluetooth: BNEP socket layer initialized
2 月 21 10:51:31 linux-50zl dbus[1024]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
2 月 21 10:51:31 linux-50zl bluetoothd[1730]: Bluetooth management interface 1.6 initialized
2 月 21 10:51:31 linux-50zl NetworkManager[1132]: <info> use BlueZ version 5
2 月 21 10:51:31 linux-50zl dbus[1024]: [system] Successfully activated service 'org.freedesktop.hostname1'
2 月 21 10:51:31 linux-50zl ModemManager[1017]: <info> Creating modem with plugin 'Generic' and '1' ports
2 月 21 10:51:31 linux-50zl ModemManager[1017]: <warn> Could not grab port (tty/ttyS4): 'Cannot add port 'tty/ttyS4', unhandled serial type'
2 月 21 10:51:31 linux-50zl ModemManager[1017]: <warn> Couldn't create modem for device at '/sys/devices/pci0000:00/0000:00:16.3': Failed to find primary AT port
2 月 21 10:51:32 linux-50zl dbus[1024]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service'
2 月 21 10:51:32 linux-50zl dbus[1024]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
2 月 21 10:51:32 linux-50zl rtkit-daemon[1792]: Successfully called chroot.
2 月 21 10:51:32 linux-50zl rtkit-daemon[1792]: Successfully dropped privileges.
2 月 21 10:51:32 linux-50zl rtkit-daemon[1792]: Successfully limited resources.
2 月 21 10:51:32 linux-50zl rtkit-daemon[1792]: Running.
2 月 21 10:51:32 linux-50zl rtkit-daemon[1792]: Watchdog thread running.
2 月 21 10:51:32 linux-50zl rtkit-daemon[1792]: Canary thread running.
2 月 21 10:51:32 linux-50zl rtkit-daemon[1792]: Successfully made thread 1791 of process 1791 (/usr/bin/pulseaudio) owned by 'R6l' high priority at nice level -11.
2 月 21 10:51:32 linux-50zl rtkit-daemon[1792]: Supervising 1 threads of 1 processes of 1 users.
2 月 21 10:51:32 linux-50zl kernel: fuse init (API version 7.23)
2 月 21 10:51:33 linux-50zl org.gnome.OnlineAccounts[1547]: goa-daemon-Message: goa-daemon version 3.14.2 starting
2 月 21 10:51:33 linux-50zl polkitd[1043]: Registered Authentication Agent for unix-session:1 (system bus name :1.28 [/usr/lib64/kde4/libexec/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale zh_CN.UTF-8)
2 月 21 10:51:33 linux-50zl org.gtk.Private.AfcVolumeMonitor[1547]: Volume monitor alive
2 月 21 10:51:33 linux-50zl hp-upgrade[1922]: hp-upgrade[1922]: error: HPLIP upgrade is disabled by openSUSE for security reasons, see https://bugzilla.novell.com/show_bug.cgi?id=853405 - if you like to upgrade HPLIP, use an openSUSE software package manager like YaST or
2 月 21 10:51:33 linux-50zl rtkit-daemon[1792]: Supervising 1 threads of 1 processes of 1 users.
2 月 21 10:51:33 linux-50zl rtkit-daemon[1792]: Successfully made thread 1924 of process 1791 (/usr/bin/pulseaudio) owned by 'R6l' RT at priority 5.
2 月 21 10:51:33 linux-50zl rtkit-daemon[1792]: Supervising 2 threads of 1 processes of 1 users.
2 月 21 10:51:33 linux-50zl rtkit-daemon[1792]: Successfully made thread 1926 of process 1791 (/usr/bin/pulseaudio) owned by 'R6l' RT at priority 5.
2 月 21 10:51:33 linux-50zl rtkit-daemon[1792]: Supervising 3 threads of 1 processes of 1 users.
2 月 21 10:51:33 linux-50zl rtkit-daemon[1792]: Successfully made thread 1927 of process 1791 (/usr/bin/pulseaudio) owned by 'R6l' RT at priority 5.
2 月 21 10:51:33 linux-50zl rtkit-daemon[1792]: Supervising 4 threads of 1 processes of 1 users.
2 月 21 10:51:33 linux-50zl rtkit-daemon[1792]: Successfully made thread 1933 of process 1933 (/usr/bin/pulseaudio) owned by 'R6l' high priority at nice level -11.
2 月 21 10:51:33 linux-50zl rtkit-daemon[1792]: Supervising 5 threads of 2 processes of 1 users.
2 月 21 10:51:33 linux-50zl pulseaudio[1933]: [pulseaudio] pid.c: Daemon already running.
2 月 21 10:51:33 linux-50zl rtkit-daemon[1792]: Successfully made thread 1936 of process 1936 (/usr/bin/pulseaudio) owned by 'R6l' high priority at nice level -11.
2 月 21 10:51:33 linux-50zl rtkit-daemon[1792]: Successfully made thread 1938 of process 1938 (/usr/bin/pulseaudio) owned by 'R6l' high priority at nice level -11.
2 月 21 10:51:33 linux-50zl pulseaudio[1938]: [pulseaudio] pid.c: Daemon already running.
2 月 21 10:51:45 linux-50zl kernel: SFW2-INext-DROP-DEFLT IN=enp4s0 OUT= MAC= SRC=fe80:0000:0000:0000:02e0:09ff:fe06:2e0c DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=84 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=5353 DPT=5353 LEN=44
2 月 21 10:51:48 linux-50zl PackageKit[1722]: get-updates transaction /1_ddbbbdeb from uid 1000 finished with success after 15612ms
2 月 21 10:51:48 linux-50zl PackageKit[1722]: get-distro-upgrades transaction /2_abdeceec from uid 1000 finished with success after 11ms
2 月 21 10:52:01 linux-50zl kernel: SFW2-INext-DROP-DEFLT IN=enp4s0 OUT= MAC= SRC=fe80:0000:0000:0000:02e0:09ff:fe06:2e0c DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=84 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=5353 DPT=5353 LEN=44
2 月 21 10:52:06 linux-50zl PackageKit[1722]: daemon quit
2 月 21 10:52:33 linux-50zl kernel: SFW2-INext-DROP-DEFLT IN=enp4s0 OUT= MAC= SRC=fe80:0000:0000:0000:02e0:09ff:fe06:2e0c DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=84 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=5353 DPT=5353 LEN=44
2 月 21 10:53:37 linux-50zl kernel: SFW2-INext-DROP-DEFLT IN=enp4s0 OUT= MAC= SRC=fe80:0000:0000:0000:02e0:09ff:fe06:2e0c DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=84 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=5353 DPT=5353 LEN=44
2 月 21 10:55:25 linux-50zl su[2228]: (to root) R6l on pts/2
2 月 21 10:55:25 linux-50zl su[2228]: pam_unix(su:session): session opened for user root by R6l(uid=1000)
2 月 21 10:55:26 linux-50zl sudo[2262]: root : TTY=pts/2 ; PWD=/home/R6l ; USER=root ; COMMAND=/usr/bin/journalctl
2 月 21 10:55:26 linux-50zl sudo[2262]: pam_unix(sudo:session): session opened for user root by R6l(uid=0)
刚关机想要出门,结果又不行了。。。。
2 月 21 14:27:48 linux-50zl kernel: audit: type=1305 audit(1424500068.966:367): audit_pid=0 old=825 auid=4294967295 ses=4294967295 res=1
2 月 21 14:27:48 linux-50zl kernel: audit: type=1131 audit(1424500068.967:368): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=' comm="auditd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2 月 21 14:27:48 linux-50zl kernel: audit: type=1131 audit(1424500068.967:369): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-tmpfiles-setup" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2 月 21 14:27:49 linux-50zl kernel: audit: type=1131 audit(1424500069.067:370): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-remount-fs" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2 月 21 14:27:49 linux-50zl kernel: audit: type=1131 audit(1424500069.067:371): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-readahead-replay" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2 月 21 14:27:49 linux-50zl kernel: audit: type=1131 audit(1424500069.067:372): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-readahead-collect" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2 月 21 14:27:49 linux-50zl kernel: audit: type=1130 audit(1424500069.070:373): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=' comm="halt-local" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2 月 21 14:27:49 linux-50zl kernel: audit: type=1130 audit(1424500069.072:374): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=' comm="plymouth-poweroff" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2 月 21 14:27:49 linux-50zl systemd-journal[432]: Journal stopped
-- Reboot --
2 月 21 14:28:11 linux-50zl systemd-journal[177]: Runtime journal is using 8.0M (max allowed 396.8M, trying to leave 595.2M free of 3.8G available → current limit 396.8M).
2 月 21 14:28:11 linux-50zl kernel: CPU0 microcode updated early to revision 0x1c, date = 2014-07-03
2 月 21 14:28:11 linux-50zl kernel: Initializing cgroup subsys cpuset
2 月 21 14:28:11 linux-50zl kernel: Initializing cgroup subsys cpuacct
2 月 21 14:28:11 linux-50zl kernel: Linux version 3.16.7-7-desktop (geeko@buildhost) (gcc version 4.8.3 20140627 [gcc-4_8-branch revision 212064] (SUSE Linux) ) #1 SMP PREEMPT Wed Dec 17 18:00:44 UTC 2014 (762f27a)
2 月 21 14:28:11 linux-50zl kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-3.16.7-7-desktop root=UUID=da625858-43b9-413a-b151-943cfc16403b ro resume=/dev/sda6 splash=silent quiet showopts
2 月 21 14:28:11 linux-50zl kernel: e820: BIOS-provided physical RAM map:
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x0000000000059000-0x000000000009efff] usable
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000bb153fff] usable
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x00000000bb154000-0x00000000bb15afff] ACPI NVS
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x00000000bb15b000-0x00000000bc169fff] usable
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x00000000bc16a000-0x00000000bc66ffff] reserved
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x00000000bc670000-0x00000000ce792fff] usable
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x00000000ce793000-0x00000000ce9a6fff] reserved
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x00000000ce9a7000-0x00000000cea92fff] ACPI NVS
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x00000000cea93000-0x00000000cf7fefff] reserved
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x00000000cf7ff000-0x00000000cf7fffff] usable
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
2 月 21 14:28:11 linux-50zl kernel: BIOS-e820: [mem 0x0000000100000000-0x000000022dffffff] usable
2 月 21 14:28:11 linux-50zl kernel: NX (Execute Disable) protection: active
2 月 21 14:28:11 linux-50zl kernel: e820: update [mem 0xbae4e018-0xbae6da57] usable ==> usable
2 月 21 14:28:11 linux-50zl kernel: e820: update [mem 0xbae3d018-0xbae4d457] usable ==> usable
2 月 21 14:28:11 linux-50zl kernel: extended physical RAM map:
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x0000000000000000-0x0000000000057fff] usable
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x0000000000058000-0x0000000000058fff] reserved
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x0000000000059000-0x000000000009efff] usable
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x000000000009f000-0x000000000009ffff] reserved
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x0000000000100000-0x00000000bae3d017] usable
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000bae3d018-0x00000000bae4d457] usable
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000bae4d458-0x00000000bae4e017] usable
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000bae4e018-0x00000000bae6da57] usable
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000bae6da58-0x00000000bb153fff] usable
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000bb154000-0x00000000bb15afff] ACPI NVS
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000bb15b000-0x00000000bc169fff] usable
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000bc16a000-0x00000000bc66ffff] reserved
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000bc670000-0x00000000ce792fff] usable
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000ce793000-0x00000000ce9a6fff] reserved
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000ce9a7000-0x00000000cea92fff] ACPI NVS
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000cea93000-0x00000000cf7fefff] reserved
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000cf7ff000-0x00000000cf7fffff] usable
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
2 月 21 14:28:11 linux-50zl kernel: reserve setup_data: [mem 0x0000000100000000-0x000000022dffffff] usable
2 月 21 14:28:11 linux-50zl kernel: efi: EFI v2.31 by American Megatrends
2 月 21 14:28:11 linux-50zl kernel: efi: ACPI=0xcea6b000 ACPI 2.0=0xcea6b000 SMBIOS=0xf04c0 MPS=0xfd450
2 月 21 14:28:11 linux-50zl kernel: efi: mem00: type=3, attr=0xf, range=[0x0000000000000000-0x0000000000008000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem01: type=2, attr=0xf, range=[0x0000000000008000-0x0000000000009000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem02: type=7, attr=0xf, range=[0x0000000000009000-0x0000000000058000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem03: type=0, attr=0xf, range=[0x0000000000058000-0x0000000000059000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem04: type=7, attr=0xf, range=[0x0000000000059000-0x000000000005f000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem05: type=4, attr=0xf, range=[0x000000000005f000-0x0000000000060000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem06: type=3, attr=0xf, range=[0x0000000000060000-0x000000000009f000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem07: type=6, attr=0x800000000000000f, range=[0x000000000009f000-0x00000000000a0000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem08: type=7, attr=0xf, range=[0x0000000000100000-0x0000000001000000) (15MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem09: type=2, attr=0xf, range=[0x0000000001000000-0x00000000024b9000) (20MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem10: type=7, attr=0xf, range=[0x00000000024b9000-0x000000003f86b000) (979MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem11: type=2, attr=0xf, range=[0x000000003f86b000-0x0000000040000000) (7MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem12: type=7, attr=0xf, range=[0x0000000040000000-0x0000000088908000) (1161MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem13: type=2, attr=0xf, range=[0x0000000088908000-0x00000000b87bb000) (766MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem14: type=7, attr=0xf, range=[0x00000000b87bb000-0x00000000bae3d000) (38MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem15: type=2, attr=0xf, range=[0x00000000bae3d000-0x00000000bb02f000) (1MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem16: type=1, attr=0xf, range=[0x00000000bb02f000-0x00000000bb154000) (1MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem17: type=10, attr=0xf, range=[0x00000000bb154000-0x00000000bb15b000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem18: type=4, attr=0xf, range=[0x00000000bb15b000-0x00000000bb2eb000) (1MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem19: type=3, attr=0xf, range=[0x00000000bb2eb000-0x00000000bc13b000) (14MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem20: type=4, attr=0xf, range=[0x00000000bc13b000-0x00000000bc14c000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem21: type=3, attr=0xf, range=[0x00000000bc14c000-0x00000000bc15e000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem22: type=4, attr=0xf, range=[0x00000000bc15e000-0x00000000bc168000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem23: type=3, attr=0xf, range=[0x00000000bc168000-0x00000000bc16a000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem24: type=6, attr=0x800000000000000f, range=[0x00000000bc16a000-0x00000000bc670000) (5MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem25: type=4, attr=0xf, range=[0x00000000bc670000-0x00000000bc6ab000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem26: type=7, attr=0xf, range=[0x00000000bc6ab000-0x00000000bc6b6000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem27: type=2, attr=0xf, range=[0x00000000bc6b6000-0x00000000bc6ba000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem28: type=7, attr=0xf, range=[0x00000000bc6ba000-0x00000000bfad2000) (52MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem29: type=4, attr=0xf, range=[0x00000000bfad2000-0x00000000bfae6000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem30: type=7, attr=0xf, range=[0x00000000bfae6000-0x00000000bfaeb000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem31: type=4, attr=0xf, range=[0x00000000bfaeb000-0x00000000bfafe000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem32: type=7, attr=0xf, range=[0x00000000bfafe000-0x00000000bfb03000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem33: type=4, attr=0xf, range=[0x00000000bfb03000-0x00000000bfb17000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem34: type=7, attr=0xf, range=[0x00000000bfb17000-0x00000000bfb1d000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem35: type=4, attr=0xf, range=[0x00000000bfb1d000-0x00000000bfb2a000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem36: type=7, attr=0xf, range=[0x00000000bfb2a000-0x00000000bfb2e000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem37: type=4, attr=0xf, range=[0x00000000bfb2e000-0x00000000bfb41000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem38: type=7, attr=0xf, range=[0x00000000bfb41000-0x00000000bfb4c000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem39: type=4, attr=0xf, range=[0x00000000bfb4c000-0x00000000bfb72000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem40: type=7, attr=0xf, range=[0x00000000bfb72000-0x00000000bfb7d000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem41: type=4, attr=0xf, range=[0x00000000bfb7d000-0x00000000bfc15000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem42: type=7, attr=0xf, range=[0x00000000bfc15000-0x00000000bfc7f000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem43: type=4, attr=0xf, range=[0x00000000bfc7f000-0x00000000bfc82000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem44: type=7, attr=0xf, range=[0x00000000bfc82000-0x00000000bfc87000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem45: type=4, attr=0xf, range=[0x00000000bfc87000-0x00000000bfc88000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem46: type=7, attr=0xf, range=[0x00000000bfc88000-0x00000000bfcdf000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem47: type=4, attr=0xf, range=[0x00000000bfcdf000-0x00000000bfce0000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem48: type=7, attr=0xf, range=[0x00000000bfce0000-0x00000000bfce3000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem49: type=4, attr=0xf, range=[0x00000000bfce3000-0x00000000bfce5000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem50: type=7, attr=0xf, range=[0x00000000bfce5000-0x00000000bfcfe000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem51: type=4, attr=0xf, range=[0x00000000bfcfe000-0x00000000bfd13000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem52: type=7, attr=0xf, range=[0x00000000bfd13000-0x00000000bfd7e000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem53: type=4, attr=0xf, range=[0x00000000bfd7e000-0x00000000bfde9000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem54: type=7, attr=0xf, range=[0x00000000bfde9000-0x00000000bfe2e000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem55: type=4, attr=0xf, range=[0x00000000bfe2e000-0x00000000bfe32000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem56: type=7, attr=0xf, range=[0x00000000bfe32000-0x00000000bfe67000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem57: type=4, attr=0xf, range=[0x00000000bfe67000-0x00000000bfec1000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem58: type=7, attr=0xf, range=[0x00000000bfec1000-0x00000000bfefd000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem59: type=4, attr=0xf, range=[0x00000000bfefd000-0x00000000bff47000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem60: type=7, attr=0xf, range=[0x00000000bff47000-0x00000000bff68000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem61: type=4, attr=0xf, range=[0x00000000bff68000-0x00000000bfff5000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem62: type=7, attr=0xf, range=[0x00000000bfff5000-0x00000000bfffa000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem63: type=4, attr=0xf, range=[0x00000000bfffa000-0x00000000c000e000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem64: type=7, attr=0xf, range=[0x00000000c000e000-0x00000000c0013000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem65: type=4, attr=0xf, range=[0x00000000c0013000-0x00000000c0027000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem66: type=7, attr=0xf, range=[0x00000000c0027000-0x00000000c002d000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem67: type=4, attr=0xf, range=[0x00000000c002d000-0x00000000c003b000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem68: type=7, attr=0xf, range=[0x00000000c003b000-0x00000000c003f000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem69: type=4, attr=0xf, range=[0x00000000c003f000-0x00000000c0052000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem70: type=7, attr=0xf, range=[0x00000000c0052000-0x00000000c005d000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem71: type=4, attr=0xf, range=[0x00000000c005d000-0x00000000c0082000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem72: type=7, attr=0xf, range=[0x00000000c0082000-0x00000000c008d000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem73: type=4, attr=0xf, range=[0x00000000c008d000-0x00000000c0127000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem74: type=7, attr=0xf, range=[0x00000000c0127000-0x00000000c0129000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem75: type=4, attr=0xf, range=[0x00000000c0129000-0x00000000c01ab000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem76: type=7, attr=0xf, range=[0x00000000c01ab000-0x00000000c01b0000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem77: type=4, attr=0xf, range=[0x00000000c01b0000-0x00000000c01c3000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem78: type=7, attr=0xf, range=[0x00000000c01c3000-0x00000000c01c8000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem79: type=4, attr=0xf, range=[0x00000000c01c8000-0x00000000c01dc000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem80: type=7, attr=0xf, range=[0x00000000c01dc000-0x00000000c01e2000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem81: type=4, attr=0xf, range=[0x00000000c01e2000-0x00000000c01ef000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem82: type=7, attr=0xf, range=[0x00000000c01ef000-0x00000000c01f3000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem83: type=4, attr=0xf, range=[0x00000000c01f3000-0x00000000c0209000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem84: type=7, attr=0xf, range=[0x00000000c0209000-0x00000000c0214000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem85: type=4, attr=0xf, range=[0x00000000c0214000-0x00000000c0239000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem86: type=7, attr=0xf, range=[0x00000000c0239000-0x00000000c0244000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem87: type=4, attr=0xf, range=[0x00000000c0244000-0x00000000c02fc000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem88: type=7, attr=0xf, range=[0x00000000c02fc000-0x00000000c0305000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem89: type=4, attr=0xf, range=[0x00000000c0305000-0x00000000c035f000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem90: type=7, attr=0xf, range=[0x00000000c035f000-0x00000000c0364000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem91: type=4, attr=0xf, range=[0x00000000c0364000-0x00000000c0377000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem92: type=7, attr=0xf, range=[0x00000000c0377000-0x00000000c037c000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem93: type=4, attr=0xf, range=[0x00000000c037c000-0x00000000c0390000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem94: type=7, attr=0xf, range=[0x00000000c0390000-0x00000000c0396000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem95: type=4, attr=0xf, range=[0x00000000c0396000-0x00000000c03bc000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem96: type=7, attr=0xf, range=[0x00000000c03bc000-0x00000000c03c7000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem97: type=4, attr=0xf, range=[0x00000000c03c7000-0x00000000c03ed000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem98: type=7, attr=0xf, range=[0x00000000c03ed000-0x00000000c03f8000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem99: type=4, attr=0xf, range=[0x00000000c03f8000-0x00000000c0512000) (1MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem100: type=7, attr=0xf, range=[0x00000000c0512000-0x00000000c0517000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem101: type=4, attr=0xf, range=[0x00000000c0517000-0x00000000c052b000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem102: type=7, attr=0xf, range=[0x00000000c052b000-0x00000000c0530000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem103: type=4, attr=0xf, range=[0x00000000c0530000-0x00000000c0545000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem104: type=7, attr=0xf, range=[0x00000000c0545000-0x00000000c054b000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem105: type=4, attr=0xf, range=[0x00000000c054b000-0x00000000c0558000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem106: type=7, attr=0xf, range=[0x00000000c0558000-0x00000000c055c000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem107: type=4, attr=0xf, range=[0x00000000c055c000-0x00000000c0570000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem108: type=7, attr=0xf, range=[0x00000000c0570000-0x00000000c057b000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem109: type=4, attr=0xf, range=[0x00000000c057b000-0x00000000c05a1000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem110: type=7, attr=0xf, range=[0x00000000c05a1000-0x00000000c05ac000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem111: type=4, attr=0xf, range=[0x00000000c05ac000-0x00000000c0646000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem112: type=7, attr=0xf, range=[0x00000000c0646000-0x00000000c0649000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem113: type=4, attr=0xf, range=[0x00000000c0649000-0x00000000c0750000) (1MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem114: type=7, attr=0xf, range=[0x00000000c0750000-0x00000000c0751000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem115: type=4, attr=0xf, range=[0x00000000c0751000-0x00000000c07ac000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem116: type=7, attr=0xf, range=[0x00000000c07ac000-0x00000000c07ad000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem117: type=4, attr=0xf, range=[0x00000000c07ad000-0x00000000c0c48000) (4MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem118: type=7, attr=0xf, range=[0x00000000c0c48000-0x00000000c0c4a000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem119: type=4, attr=0xf, range=[0x00000000c0c4a000-0x00000000c0ca9000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem120: type=7, attr=0xf, range=[0x00000000c0ca9000-0x00000000c0cb7000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem121: type=4, attr=0xf, range=[0x00000000c0cb7000-0x00000000c0ce2000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem122: type=7, attr=0xf, range=[0x00000000c0ce2000-0x00000000c0ce4000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem123: type=4, attr=0xf, range=[0x00000000c0ce4000-0x00000000c0e52000) (1MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem124: type=7, attr=0xf, range=[0x00000000c0e52000-0x00000000c0e53000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem125: type=4, attr=0xf, range=[0x00000000c0e53000-0x00000000c0e5b000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem126: type=7, attr=0xf, range=[0x00000000c0e5b000-0x00000000c0e5d000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem127: type=4, attr=0xf, range=[0x00000000c0e5d000-0x00000000c0e6b000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem128: type=7, attr=0xf, range=[0x00000000c0e6b000-0x00000000c0e6e000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem129: type=4, attr=0xf, range=[0x00000000c0e6e000-0x00000000c0e79000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem130: type=7, attr=0xf, range=[0x00000000c0e79000-0x00000000c0e7b000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem131: type=4, attr=0xf, range=[0x00000000c0e7b000-0x00000000c0fba000) (1MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem132: type=7, attr=0xf, range=[0x00000000c0fba000-0x00000000c0fbc000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem133: type=4, attr=0xf, range=[0x00000000c0fbc000-0x00000000cab04000) (155MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem134: type=7, attr=0xf, range=[0x00000000cab04000-0x00000000cab05000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem135: type=4, attr=0xf, range=[0x00000000cab05000-0x00000000cd14c000) (38MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem136: type=7, attr=0xf, range=[0x00000000cd14c000-0x00000000ce46b000) (19MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem137: type=3, attr=0xf, range=[0x00000000ce46b000-0x00000000ce793000) (3MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem138: type=0, attr=0xf, range=[0x00000000ce793000-0x00000000ce7fe000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem139: type=0, attr=0xf, range=[0x00000000ce7fe000-0x00000000ce9a7000) (1MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem140: type=10, attr=0xf, range=[0x00000000ce9a7000-0x00000000ce9d8000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem141: type=10, attr=0xf, range=[0x00000000ce9d8000-0x00000000cea83000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem142: type=10, attr=0xf, range=[0x00000000cea83000-0x00000000cea88000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem143: type=10, attr=0xf, range=[0x00000000cea88000-0x00000000cea93000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem144: type=6, attr=0x800000000000000f, range=[0x00000000cea93000-0x00000000cf21d000) (7MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem145: type=6, attr=0x800000000000000f, range=[0x00000000cf21d000-0x00000000cf50f000) (2MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem146: type=6, attr=0x800000000000000f, range=[0x00000000cf50f000-0x00000000cf512000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem147: type=6, attr=0x800000000000000f, range=[0x00000000cf512000-0x00000000cf732000) (2MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem148: type=5, attr=0x800000000000000f, range=[0x00000000cf732000-0x00000000cf75b000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem149: type=5, attr=0x800000000000000f, range=[0x00000000cf75b000-0x00000000cf7ff000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem150: type=4, attr=0xf, range=[0x00000000cf7ff000-0x00000000cf800000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem151: type=7, attr=0xf, range=[0x0000000100000000-0x000000022e000000) (4832MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem152: type=11, attr=0x8000000000000001, range=[0x00000000f8000000-0x00000000fc000000) (64MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem153: type=11, attr=0x8000000000000001, range=[0x00000000fec00000-0x00000000fec01000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem154: type=11, attr=0x8000000000000001, range=[0x00000000fed00000-0x00000000fed04000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem155: type=11, attr=0x8000000000000001, range=[0x00000000fed1c000-0x00000000fed20000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem156: type=11, attr=0x8000000000000001, range=[0x00000000fee00000-0x00000000fee01000) (0MB)
2 月 21 14:28:11 linux-50zl kernel: efi: mem157: type=11, attr=0x8000000000000001, range=[0x00000000ff000000-0x0000000100000000) (16MB)
2 月 21 14:28:11 linux-50zl kernel: SMBIOS 2.7 present.
2 月 21 14:28:11 linux-50zl kernel: DMI: Gigabyte Technology Co., Ltd. G1.Sniper B5/G1.Sniper B5-CF, BIOS F5 08/03/2013
2 月 21 14:28:11 linux-50zl kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
2 月 21 14:28:11 linux-50zl kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
2 月 21 14:28:11 linux-50zl kernel: AGP: No AGP bridge found
2 月 21 14:28:11 linux-50zl kernel: e820: last_pfn = 0x22e000 max_arch_pfn = 0x400000000
2 月 21 14:28:11 linux-50zl kernel: MTRR default type: uncachable
2 月 21 14:28:11 linux-50zl kernel: MTRR fixed ranges enabled:
2 月 21 14:28:11 linux-50zl kernel: 00000-9FFFF write-back
2 月 21 14:28:11 linux-50zl kernel: A0000-BFFFF uncachable
2 月 21 14:28:11 linux-50zl kernel: C0000-CFFFF write-protect
2 月 21 14:28:11 linux-50zl kernel: D0000-DFFFF uncachable
2 月 21 14:28:11 linux-50zl kernel: E0000-FFFFF write-protect
2 月 21 14:28:11 linux-50zl kernel: MTRR variable ranges enabled:
2 月 21 14:28:11 linux-50zl kernel: 0 base 0000000000 mask 7E00000000 write-back
2 月 21 14:28:11 linux-50zl kernel: 1 base 0200000000 mask 7FE0000000 write-back
2 月 21 14:28:11 linux-50zl kernel: 2 base 0220000000 mask 7FF8000000 write-back
2 月 21 14:28:11 linux-50zl kernel: 3 base 0228000000 mask 7FFC000000 write-back
2 月 21 14:28:11 linux-50zl kernel: 4 base 022C000000 mask 7FFE000000 write-back
2 月 21 14:28:11 linux-50zl kernel: 5 base 00E0000000 mask 7FE0000000 uncachable
2 月 21 14:28:11 linux-50zl kernel: 6 base 00D0000000 mask 7FF0000000 uncachable
2 月 21 14:28:11 linux-50zl kernel: 7 disabled
2 月 21 14:28:11 linux-50zl kernel: 8 disabled
2 月 21 14:28:11 linux-50zl kernel: 9 disabled
2 月 21 14:28:11 linux-50zl kernel: x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
2 月 21 14:28:11 linux-50zl kernel: e820: update [mem 0xd0000000-0xffffffff] usable ==> reserved
2 月 21 14:28:11 linux-50zl kernel: e820: last_pfn = 0xcf800 max_arch_pfn = 0x400000000
2 月 21 14:28:11 linux-50zl kernel: found SMP MP-table at [mem 0x000fd710-0x000fd71f] mapped at [ffff8800000fd710]
2 月 21 14:28:11 linux-50zl kernel: Scanning 1 areas for low memory corruption
2 月 21 14:28:11 linux-50zl kernel: Base memory trampoline at [ffff880000097000] 97000 size 24576
2 月 21 14:28:11 linux-50zl kernel: Using GB pages for direct mapping
2 月 21 14:28:11 linux-50zl kernel: init_memory_mapping: [mem 0x00000000-0x000fffff]
2 月 21 14:28:11 linux-50zl kernel: [mem 0x00000000-0x000fffff] page 4k
2 月 21 14:28:11 linux-50zl kernel: BRK [0x0220b000, 0x0220bfff] PGTABLE
2 月 21 14:28:11 linux-50zl kernel: BRK [0x0220c000, 0x0220cfff] PGTABLE
2 月 21 14:28:11 linux-50zl kernel: BRK [0x0220d000, 0x0220dfff] PGTABLE
2 月 21 14:28:11 linux-50zl kernel: init_memory_mapping: [mem 0x22de00000-0x22dffffff]
2 月 21 14:28:11 linux-50zl kernel: [mem 0x22de00000-0x22dffffff] page 2M
2 月 21 14:28:11 linux-50zl kernel: BRK [0x0220e000, 0x0220efff] PGTABLE
2 月 21 14:28:11 linux-50zl kernel: init_memory_mapping: [mem 0x22c000000-0x22ddfffff]
2 月 21 14:28:11 linux-50zl kernel: [mem 0x22c000000-0x22ddfffff] page 2M
2 月 21 14:28:11 linux-50zl kernel: init_memory_mapping: [mem 0x200000000-0x22bffffff]
2 月 21 14:28:11 linux-50zl kernel: [mem 0x200000000-0x22bffffff] page 2M
2 月 21 14:28:11 linux-50zl kernel: init_memory_mapping: [mem 0x00100000-0xbb153fff]
2 月 21 14:28:11 linux-50zl kernel: [mem 0x00100000-0x001fffff] page 4k
2 月 21 14:28:11 linux-50zl kernel: [mem 0x00200000-0x3fffffff] page 2M
2 月 21 14:28:11 linux-50zl kernel: [mem 0x40000000-0x7fffffff] page 1G
2 月 21 14:28:11 linux-50zl kernel: [mem 0x80000000-0xbaffffff] page 2M
2 月 21 14:28:11 linux-50zl kernel: [mem 0xbb000000-0xbb153fff] page 4k
2 月 21 14:28:11 linux-50zl kernel: init_memory_mapping: [mem 0xbb15b000-0xbc169fff]
2 月 21 14:28:11 linux-50zl kernel: [mem 0xbb15b000-0xbb1fffff] page 4k
2 月 21 14:28:11 linux-50zl kernel: [mem 0xbb200000-0xbbffffff] page 2M
2 月 21 14:28:11 linux-50zl kernel: [mem 0xbc000000-0xbc169fff] page 4k
2 月 21 14:28:11 linux-50zl kernel: BRK [0x0220f000, 0x0220ffff] PGTABLE
2 月 21 14:28:11 linux-50zl kernel: init_memory_mapping: [mem 0xbc670000-0xce792fff]
2 月 21 14:28:11 linux-50zl kernel: [mem 0xbc670000-0xbc7fffff] page 4k
2 月 21 14:28:11 linux-50zl kernel: [mem 0xbc800000-0xce5fffff] page 2M
2 月 21 14:28:11 linux-50zl kernel: [mem 0xce600000-0xce792fff] page 4k
2 月 21 14:28:11 linux-50zl kernel: BRK [0x02210000, 0x02210fff] PGTABLE
2 月 21 14:28:11 linux-50zl kernel: init_memory_mapping: [mem 0xcf7ff000-0xcf7fffff]
2 月 21 14:28:11 linux-50zl kernel: [mem 0xcf7ff000-0xcf7fffff] page 4k
2 月 21 14:28:11 linux-50zl kernel: init_memory_mapping: [mem 0x100000000-0x1ffffffff]
2 月 21 14:28:11 linux-50zl kernel: [mem 0x100000000-0x1ffffffff] page 1G
2 月 21 14:28:11 linux-50zl kernel: RAMDISK: [mem 0x3f86b000-0x3fffafff]
2 月 21 14:28:11 linux-50zl kernel: ACPI: Early table checksum verification disabled
2 月 21 14:28:11 linux-50zl kernel: ACPI: RSDP 0x00000000CEA6B000 000024 (v02 ALASKA)
2 月 21 14:28:11 linux-50zl kernel: ACPI: XSDT 0x00000000CEA6B078 000074 (v01 ALASKA A M I 01072009 AMI 00010013)
2 月 21 14:28:11 linux-50zl kernel: ACPI: FACP 0x00000000CEA76460 00010C (v05 ALASKA A M I 01072009 AMI 00010013)
2 月 21 14:28:11 linux-50zl kernel: ACPI: DSDT 0x00000000CEA6B188 00B2D7 (v02 ALASKA A M I 000000F5 INTL 20091112)
2 月 21 14:28:11 linux-50zl kernel: ACPI: FACS 0x00000000CEA91080 000040
2 月 21 14:28:11 linux-50zl kernel: ACPI: APIC 0x00000000CEA76570 000092 (v03 ALASKA A M I 01072009 AMI 00010013)
2 月 21 14:28:11 linux-50zl kernel: ACPI: FPDT 0x00000000CEA76608 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
2 月 21 14:28:11 linux-50zl kernel: ACPI: SSDT 0x00000000CEA76650 000AD8 (v01 PmRef CpuPm 00003000 INTL 20051117)
2 月 21 14:28:11 linux-50zl kernel: ACPI: MCFG 0x00000000CEA77128 00003C (v01 01072009 MSFT 00000097)
2 月 21 14:28:11 linux-50zl kernel: ACPI: HPET 0x00000000CEA77168 000038 (v01 ALASKA A M I 01072009 AMI. 00000005)
2 月 21 14:28:11 linux-50zl kernel: ACPI: SSDT 0x00000000CEA771A0 00036D (v01 SataRe SataTabl 00001000 INTL 20091112)
2 月 21 14:28:11 linux-50zl kernel: ACPI: SSDT 0x00000000CEA77510 003299 (v01 SaSsdt SaSsdt 00003000 INTL 20091112)
2 月 21 14:28:11 linux-50zl kernel: ACPI: BGRT 0x00000000CEA7A7B0 000038 (v00 ALASKA A M I 01072009 AMI 00010013)
2 月 21 14:28:11 linux-50zl kernel: ACPI: DMAR 0x00000000CEA7A7E8 000080 (v01 INTEL HSW 00000001 INTL 00000001)
2 月 21 14:28:11 linux-50zl kernel: ACPI: Local APIC address 0xfee00000
2 月 21 14:28:11 linux-50zl kernel: No NUMA configuration found
2 月 21 14:28:11 linux-50zl kernel: Faking a node at [mem 0x0000000000000000-0x000000022dffffff]
2 月 21 14:28:11 linux-50zl kernel: Initmem setup node 0 [mem 0x00000000-0x22dffffff]
2 月 21 14:28:11 linux-50zl kernel: NODE_DATA [mem 0x22dfe7000-0x22dffafff]
2 月 21 14:28:11 linux-50zl kernel: [ffffea0000000000-ffffea0007bfffff] PMD -> [ffff880225600000-ffff88022c7fffff] on node 0
2 月 21 14:28:11 linux-50zl kernel: Zone ranges:
2 月 21 14:28:11 linux-50zl kernel: DMA [mem 0x00001000-0x00ffffff]
2 月 21 14:28:11 linux-50zl kernel: DMA32 [mem 0x01000000-0xffffffff]
2 月 21 14:28:11 linux-50zl kernel: Normal [mem 0x100000000-0x22dffffff]
2 月 21 14:28:11 linux-50zl kernel: Movable zone start for each node
2 月 21 14:28:11 linux-50zl kernel: Early memory node ranges
2 月 21 14:28:11 linux-50zl kernel: node 0: [mem 0x00001000-0x00057fff]
2 月 21 14:28:11 linux-50zl kernel: node 0: [mem 0x00059000-0x0009efff]
2 月 21 14:28:11 linux-50zl kernel: node 0: [mem 0x00100000-0xbb153fff]
2 月 21 14:28:11 linux-50zl kernel: node 0: [mem 0xbb15b000-0xbc169fff]
2 月 21 14:28:11 linux-50zl kernel: node 0: [mem 0xbc670000-0xce792fff]
2 月 21 14:28:11 linux-50zl kernel: node 0: [mem 0xcf7ff000-0xcf7fffff]
2 月 21 14:28:11 linux-50zl kernel: node 0: [mem 0x100000000-0x22dffffff]
2 月 21 14:28:11 linux-50zl kernel: On node 0 totalpages: 2081316
2 月 21 14:28:11 linux-50zl kernel: DMA zone: 56 pages used for memmap
2 月 21 14:28:11 linux-50zl kernel: DMA zone: 24 pages reserved
2 月 21 14:28:11 linux-50zl kernel: DMA zone: 3997 pages, LIFO batch:0
2 月 21 14:28:11 linux-50zl kernel: DMA32 zone: 11489 pages used for memmap
2 月 21 14:28:11 linux-50zl kernel: DMA32 zone: 840327 pages, LIFO batch:31
2 月 21 14:28:11 linux-50zl kernel: Normal zone: 16912 pages used for memmap
2 月 21 14:28:11 linux-50zl kernel: Normal zone: 1236992 pages, LIFO batch:31
2 月 21 14:28:11 linux-50zl kernel: tboot: non-0 tboot_addr but it is not of type E820_RESERVED
2 月 21 14:28:11 linux-50zl kernel: ACPI: PM-Timer IO Port: 0x1808
2 月 21 14:28:11 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
2 月 21 14:28:11 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
2 月 21 14:28:11 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled)
2 月 21 14:28:11 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled)
2 月 21 14:28:11 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x05] lapic_id[0x01] enabled)
2 月 21 14:28:11 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x06] lapic_id[0x03] enabled)
2 月 21 14:28:11 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x07] lapic_id[0x05] enabled)
2 月 21 14:28:11 linux-50zl kernel: ACPI: LAPIC (acpi_id[0x08] lapic_id[0x07] enabled)
2 月 21 14:28:11 linux-50zl kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
2 月 21 14:28:11 linux-50zl kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
2 月 21 14:28:11 linux-50zl kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
2 月 21 14:28:11 linux-50zl kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
2 月 21 14:28:11 linux-50zl kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
2 月 21 14:28:11 linux-50zl kernel: ACPI: IRQ0 used by override.
2 月 21 14:28:11 linux-50zl kernel: ACPI: IRQ2 used by override.
2 月 21 14:28:11 linux-50zl kernel: ACPI: IRQ9 used by override.
2 月 21 14:28:11 linux-50zl kernel: Using ACPI (MADT) for SMP configuration information
2 月 21 14:28:11 linux-50zl kernel: ACPI: HPET id: 0x8086a701 base: 0xfed00000
2 月 21 14:28:11 linux-50zl kernel: smpboot: Allowing 8 CPUs, 0 hotplug CPUs
2 月 21 14:28:11 linux-50zl kernel: nr_irqs_gsi: 40
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xbae3d000-0xbae3dfff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xbae4d000-0xbae4dfff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xbae4e000-0xbae4efff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xbae6d000-0xbae6dfff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xbb154000-0xbb15afff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xbc16a000-0xbc66ffff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xce793000-0xce9a6fff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xce9a7000-0xcea92fff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xcea93000-0xcf7fefff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xcf800000-0xf7ffffff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
2 月 21 14:28:11 linux-50zl kernel: PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
2 月 21 14:28:11 linux-50zl kernel: e820: [mem 0xcf800000-0xf7ffffff] available for PCI devices
2 月 21 14:28:11 linux-50zl kernel: Booting paravirtualized kernel on bare hardware
2 月 21 14:28:11 linux-50zl kernel: setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:8 nr_node_ids:1
2 月 21 14:28:11 linux-50zl kernel: PERCPU: Embedded 27 pages/cpu @ffff88022dc00000 s79104 r8192 d23296 u262144
2 月 21 14:28:11 linux-50zl kernel: pcpu-alloc: s79104 r8192 d23296 u262144 alloc=1*2097152
2 月 21 14:28:11 linux-50zl kernel: pcpu-alloc: [0] 0 1 2 3 4 5 6 7
2 月 21 14:28:11 linux-50zl kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2052835
2 月 21 14:28:11 linux-50zl kernel: Policy zone: Normal
2 月 21 14:28:11 linux-50zl kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.16.7-7-desktop root=UUID=da625858-43b9-413a-b151-943cfc16403b ro resume=/dev/sda6 splash=silent quiet showopts
2 月 21 14:28:11 linux-50zl kernel: PID hash table entries: 4096 (order: 3, 32768 bytes)
2 月 21 14:28:11 linux-50zl kernel: xsave: enabled xstate_bv 0x7, cntxt size 0x340
2 月 21 14:28:11 linux-50zl kernel: AGP: Checking aperture...
2 月 21 14:28:11 linux-50zl kernel: Memory: 7878372K/8325264K available (6302K kernel code, 1009K rwdata, 4708K rodata, 1560K init, 1532K bss, 446892K reserved)
2 月 21 14:28:11 linux-50zl kernel: Preemptible hierarchical RCU implementation.
2 月 21 14:28:11 linux-50zl kernel: RCU dyntick-idle grace-period acceleration is enabled.
2 月 21 14:28:11 linux-50zl kernel: RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
2 月 21 14:28:11 linux-50zl kernel: Offload RCU callbacks from all CPUs
2 月 21 14:28:11 linux-50zl kernel: Offload RCU callbacks from CPUs: 0-7.
2 月 21 14:28:11 linux-50zl kernel: RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
2 月 21 14:28:11 linux-50zl kernel: NR_IRQS:33024 nr_irqs:744 16
2 月 21 14:28:11 linux-50zl kernel: Console: colour dummy device 80x25
2 月 21 14:28:11 linux-50zl kernel: console [tty0] enabled
2 月 21 14:28:11 linux-50zl kernel: allocated 33554432 bytes of page_cgroup
2 月 21 14:28:11 linux-50zl kernel: please try 'cgroup_disable=memory' option if you don't want memory cgroups
2 月 21 14:28:11 linux-50zl kernel: hpet clockevent registered
2 月 21 14:28:11 linux-50zl kernel: tsc: Fast TSC calibration using PIT
2 月 21 14:28:11 linux-50zl kernel: tsc: Detected 3292.656 MHz processor
2 月 21 14:28:11 linux-50zl kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 6585.31 BogoMIPS (lpj=3292656)
2 月 21 14:28:11 linux-50zl kernel: pid_max: default: 32768 minimum: 301
2 月 21 14:28:11 linux-50zl kernel: ACPI: Core revision 20140424
2 月 21 14:28:11 linux-50zl kernel: ACPI: All ACPI Tables successfully acquired
2 月 21 14:28:11 linux-50zl kernel: Security Framework initialized
2 月 21 14:28:11 linux-50zl kernel: AppArmor: AppArmor initialized
2 月 21 14:28:11 linux-50zl kernel: Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
2 月 21 14:28:11 linux-50zl kernel: Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
2 月 21 14:28:11 linux-50zl kernel: Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
2 月 21 14:28:11 linux-50zl kernel: Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
2 月 21 14:28:11 linux-50zl kernel: Initializing cgroup subsys memory
2 月 21 14:28:11 linux-50zl kernel: Initializing cgroup subsys devices
2 月 21 14:28:11 linux-50zl kernel: Initializing cgroup subsys freezer
2 月 21 14:28:11 linux-50zl kernel: Initializing cgroup subsys net_cls
2 月 21 14:28:11 linux-50zl kernel: Initializing cgroup subsys blkio
2 月 21 14:28:11 linux-50zl kernel: Initializing cgroup subsys perf_event
2 月 21 14:28:11 linux-50zl kernel: Initializing cgroup subsys net_prio
2 月 21 14:28:11 linux-50zl kernel: Initializing cgroup subsys hugetlb
2 月 21 14:28:11 linux-50zl kernel: CPU: Physical Processor ID: 0
2 月 21 14:28:11 linux-50zl kernel: CPU: Processor Core ID: 0
2 月 21 14:28:11 linux-50zl kernel: mce: CPU supports 9 MCE banks
2 月 21 14:28:11 linux-50zl kernel: CPU0: Thermal monitoring enabled (TM1)
2 月 21 14:28:11 linux-50zl kernel: Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
tlb_flushall_shift: 6
2 月 21 14:28:11 linux-50zl kernel: Freeing SMP alternatives memory: 24K (ffffffff82084000 - ffffffff8208a000)
2 月 21 14:28:11 linux-50zl kernel: ftrace: allocating 24400 entries in 96 pages
2 月 21 14:28:11 linux-50zl kernel: dmar: Host address width 39
2 月 21 14:28:11 linux-50zl kernel: dmar: DRHD base: 0x000000fed90000 flags: 0x1
2 月 21 14:28:11 linux-50zl kernel: dmar: IOMMU 0: reg_base_addr fed90000 ver 1:0 cap d2008c20660462 ecap f010da
2 月 21 14:28:11 linux-50zl kernel: dmar: RMRR base: 0x000000ce925000 end: 0x000000ce931fff
2 月 21 14:28:11 linux-50zl kernel: IOAPIC id 2 under DRHD base 0xfed90000 IOMMU 0
2 月 21 14:28:11 linux-50zl kernel: HPET id 0 under DRHD base 0xfed90000
2 月 21 14:28:11 linux-50zl kernel: Queued invalidation will be enabled to support x2apic and Intr-remapping.
2 月 21 14:28:11 linux-50zl kernel: Enabled IRQ remapping in x2apic mode
2 月 21 14:28:11 linux-50zl kernel: Enabling x2apic
2 月 21 14:28:11 linux-50zl kernel: Enabled x2apic
2 月 21 14:28:11 linux-50zl kernel: Switched APIC routing to cluster x2apic.
2 月 21 14:28:11 linux-50zl kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
2 月 21 14:28:11 linux-50zl kernel: smpboot: CPU0: Intel(R) Xeon(R) CPU E3-1230 v3 @ 3.30GHz (fam: 06, model: 3c, stepping: 03)
2 月 21 14:28:11 linux-50zl kernel: TSC deadline timer enabled
2 月 21 14:28:11 linux-50zl kernel: Performance Events: PEBS fmt2+, 16-deep LBR, Haswell events, full-width counters, Intel PMU driver.
2 月 21 14:28:11 linux-50zl kernel: ... version: 3
2 月 21 14:28:11 linux-50zl kernel: ... bit width: 48
2 月 21 14:28:11 linux-50zl kernel: ... generic registers: 4
2 月 21 14:28:11 linux-50zl kernel: ... value mask: 0000ffffffffffff
2 月 21 14:28:11 linux-50zl kernel: ... max period: 0000ffffffffffff
2 月 21 14:28:11 linux-50zl kernel: ... fixed-purpose events: 3
2 月 21 14:28:11 linux-50zl kernel: ... event mask: 000000070000000f
2 月 21 14:28:11 linux-50zl kernel: x86: Booting SMP configuration:
2 月 21 14:28:11 linux-50zl kernel: .... node #0, CPUs: #1
2 月 21 14:28:11 linux-50zl kernel: CPU1 microcode updated early to revision 0x1c, date = 2014-07-03
2 月 21 14:28:11 linux-50zl kernel: NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
2 月 21 14:28:11 linux-50zl kernel: #2
2 月 21 14:28:11 linux-50zl kernel: CPU2 microcode updated early to revision 0x1c, date = 2014-07-03
2 月 21 14:28:11 linux-50zl kernel: #3
2 月 21 14:28:11 linux-50zl kernel: CPU3 microcode updated early to revision 0x1c, date = 2014-07-03
2 月 21 14:28:11 linux-50zl kernel: #4 #5 #6 #7
2 月 21 14:28:11 linux-50zl kernel: x86: Booted up 1 node, 8 CPUs
2 月 21 14:28:11 linux-50zl kernel: smpboot: Total of 8 processors activated (52682.49 BogoMIPS)
2 月 21 14:28:11 linux-50zl kernel: devtmpfs: initialized
2 月 21 14:28:11 linux-50zl kernel: PM: Registering ACPI NVS region [mem 0xbb154000-0xbb15afff] (28672 bytes)
2 月 21 14:28:11 linux-50zl kernel: PM: Registering ACPI NVS region [mem 0xce9a7000-0xcea92fff] (966656 bytes)
2 月 21 14:28:11 linux-50zl kernel: pinctrl core: initialized pinctrl subsystem
2 月 21 14:28:11 linux-50zl kernel: RTC time: 14:28:11, date: 02/21/15
2 月 21 14:28:11 linux-50zl kernel: NET: Registered protocol family 16
2 月 21 14:28:11 linux-50zl kernel: cpuidle: using governor ladder
2 月 21 14:28:11 linux-50zl kernel: cpuidle: using governor menu
2 月 21 14:28:11 linux-50zl kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
2 月 21 14:28:11 linux-50zl kernel: ACPI: bus type PCI registered
2 月 21 14:28:11 linux-50zl kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
2 月 21 14:28:11 linux-50zl kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
2 月 21 14:28:11 linux-50zl kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
2 月 21 14:28:11 linux-50zl kernel: PCI: Using configuration type 1 for base access
2 月 21 14:28:11 linux-50zl kernel: ACPI: Added _OSI(Module Device)
2 月 21 14:28:11 linux-50zl kernel: ACPI: Added _OSI(Processor Device)
2 月 21 14:28:11 linux-50zl kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
2 月 21 14:28:11 linux-50zl kernel: ACPI: Added _OSI(Processor Aggregator Device)
2 月 21 14:28:11 linux-50zl kernel: ACPI: Executed 1 blocks of module-level executable AML code
2 月 21 14:28:11 linux-50zl kernel: [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
2 月 21 14:28:11 linux-50zl kernel: ACPI: Dynamic OEM Table Load:
2 月 21 14:28:11 linux-50zl kernel: ACPI: SSDT 0xFFFF8802225EC800 0003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
2 月 21 14:28:11 linux-50zl kernel: ACPI: SSDT 0xFFFF8802225E2000 000119 (v01 PmRef ApCst 00003000 INTL 20051117)
2 月 21 14:28:11 linux-50zl kernel: ACPI: Interpreter enabled
2 月 21 14:28:11 linux-50zl kernel: ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State \_S1_] (20140424/hwxface-580)
2 月 21 14:28:11 linux-50zl kernel: ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State \_S2_] (20140424/hwxface-580)
2 月 21 14:28:11 linux-50zl kernel: ACPI: (supports S0 S3 S4 S5)
2 月 21 14:28:11 linux-50zl kernel: ACPI: Using IOAPIC for interrupt routing
2 月 21 14:28:11 linux-50zl kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
2 月 21 14:28:11 linux-50zl kernel: ACPI: Power Resource [FN00] (off)
2 月 21 14:28:11 linux-50zl kernel: ACPI: Power Resource [FN01] (off)
2 月 21 14:28:11 linux-50zl kernel: ACPI: Power Resource [FN02] (off)
2 月 21 14:28:11 linux-50zl kernel: ACPI: Power Resource [FN03] (off)
2 月 21 14:28:11 linux-50zl kernel: ACPI: Power Resource [FN04] (off)
2 月 21 14:28:11 linux-50zl kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
2 月 21 14:28:11 linux-50zl kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
2 月 21 14:28:11 linux-50zl kernel: acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME]
2 月 21 14:28:11 linux-50zl kernel: acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
2 月 21 14:28:11 linux-50zl kernel: PCI host bridge to bus 0000:00
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: root bus resource [bus 00-3e]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: root bus resource [mem 0xd0000000-0xfeafffff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:00.0: [8086:0c08] type 00 class 0x060000
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:01.0: [8086:0c01] type 01 class 0x060400
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:01.0: System wakeup disabled by ACPI
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:14.0: reg 0x10: [mem 0xf3220000-0xf322ffff 64bit]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:14.0: System wakeup disabled by ACPI
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:16.0: reg 0x10: [mem 0xf323c000-0xf323c00f 64bit]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:16.3: [8086:8c3d] type 00 class 0x070002
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:16.3: reg 0x10: [io 0xf0a0-0xf0a7]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:16.3: reg 0x14: [mem 0xf323a000-0xf323afff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:19.0: [8086:153b] type 00 class 0x020000
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:19.0: reg 0x10: [mem 0xf3200000-0xf321ffff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:19.0: reg 0x14: [mem 0xf3239000-0xf3239fff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:19.0: reg 0x18: [io 0xf040-0xf05f]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:19.0: System wakeup disabled by ACPI
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1a.0: reg 0x10: [mem 0xf3238000-0xf32383ff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1a.0: System wakeup disabled by ACPI
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1b.0: reg 0x10: [mem 0xf3230000-0xf3233fff 64bit]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1b.0: System wakeup disabled by ACPI
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.0: System wakeup disabled by ACPI
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.3: [8086:244e] type 01 class 0x060401
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.3: System wakeup disabled by ACPI
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1d.0: reg 0x10: [mem 0xf3237000-0xf32373ff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1d.0: System wakeup disabled by ACPI
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1f.0: [8086:8c50] type 00 class 0x060100
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1f.2: reg 0x10: [io 0xf090-0xf097]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1f.2: reg 0x14: [io 0xf080-0xf083]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1f.2: reg 0x18: [io 0xf070-0xf077]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1f.2: reg 0x1c: [io 0xf060-0xf063]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1f.2: reg 0x20: [io 0xf020-0xf03f]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1f.2: reg 0x24: [mem 0xf3236000-0xf32367ff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1f.2: PME# supported from D3hot
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xf3235000-0xf32350ff 64bit]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1f.3: reg 0x20: [io 0xf000-0xf01f]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:01:00.0: [10de:1187] type 00 class 0x030000
2 月 21 14:28:11 linux-50zl kernel: pci 0000:01:00.0: reg 0x10: [mem 0xf2000000-0xf2ffffff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:01:00.0: reg 0x14: [mem 0xe8000000-0xefffffff 64bit pref]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:01:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:01:00.0: reg 0x24: [io 0xe000-0xe07f]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:01:00.0: reg 0x30: [mem 0xf3000000-0xf307ffff pref]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:01:00.0: System wakeup disabled by ACPI
2 月 21 14:28:11 linux-50zl kernel: pci 0000:01:00.1: [10de:0e0a] type 00 class 0x040300
2 月 21 14:28:11 linux-50zl kernel: pci 0000:01:00.1: reg 0x10: [mem 0xf3080000-0xf3083fff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:01.0: PCI bridge to [bus 01]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:01.0: bridge window [mem 0xe8000000-0xf30fffff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.0: PCI bridge to [bus 02]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: [8086:244e] type 01 class 0x060401
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: supports D1 D2
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: System wakeup disabled by ACPI
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.3: PCI bridge to [bus 03-04] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.3: bridge window [mem 0xf3100000-0xf31fffff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.3: bridge window [io 0x0000-0x0cf7] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.3: bridge window [io 0x0d00-0xffff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.3: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.3: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.3: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.3: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.3: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:00:1c.3: bridge window [mem 0xd0000000-0xfeafffff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:04:00.0: [10ec:8139] type 00 class 0x020000
2 月 21 14:28:11 linux-50zl kernel: pci 0000:04:00.0: reg 0x10: [io 0xd000-0xd0ff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:04:00.0: reg 0x14: [mem 0xf3120000-0xf31200ff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:04:00.0: reg 0x30: [mem 0xf3100000-0xf311ffff pref]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:04:00.0: supports D1 D2
2 月 21 14:28:11 linux-50zl kernel: pci 0000:04:00.0: PME# supported from D1 D2 D3hot
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: PCI bridge to [bus 04] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: bridge window [io 0xd000-0xdfff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0xf3100000-0xf31fffff]
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: bridge window [io 0xd000-0xdfff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0xf3100000-0xf31fffff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:03:00.0: bridge window [mem 0xd0000000-0xfeafffff] (subtractive decode)
2 月 21 14:28:11 linux-50zl kernel: acpi PNP0A08:00: Disabling ASPM (FADT indicates it is unsupported)
2 月 21 14:28:11 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
2 月 21 14:28:11 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
2 月 21 14:28:11 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
2 月 21 14:28:11 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 5 6 10 11 12 14 15)
2 月 21 14:28:11 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
2 月 21 14:28:11 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
2 月 21 14:28:11 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 *10 11 12 14 15)
2 月 21 14:28:11 linux-50zl kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 5 6 10 11 12 14 15)
2 月 21 14:28:11 linux-50zl kernel: ACPI: Enabled 4 GPEs in block 00 to 3F
2 月 21 14:28:11 linux-50zl kernel: vgaarb: setting as boot device: PCI:0000:01:00.0
2 月 21 14:28:11 linux-50zl kernel: vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
2 月 21 14:28:11 linux-50zl kernel: vgaarb: loaded
2 月 21 14:28:11 linux-50zl kernel: vgaarb: bridge control possible 0000:01:00.0
2 月 21 14:28:11 linux-50zl kernel: SCSI subsystem initialized
2 月 21 14:28:11 linux-50zl kernel: libata version 3.00 loaded.
2 月 21 14:28:11 linux-50zl kernel: ACPI: bus type USB registered
2 月 21 14:28:11 linux-50zl kernel: usbcore: registered new interface driver usbfs
2 月 21 14:28:11 linux-50zl kernel: usbcore: registered new interface driver hub
2 月 21 14:28:11 linux-50zl kernel: usbcore: registered new device driver usb
2 月 21 14:28:11 linux-50zl kernel: PCI: Using ACPI for IRQ routing
2 月 21 14:28:11 linux-50zl kernel: PCI: pci_cache_line_size set to 64 bytes
2 月 21 14:28:11 linux-50zl kernel: e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
2 月 21 14:28:11 linux-50zl kernel: e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
2 月 21 14:28:11 linux-50zl kernel: e820: reserve RAM buffer [mem 0xbae3d018-0xbbffffff]
2 月 21 14:28:11 linux-50zl kernel: e820: reserve RAM buffer [mem 0xbae4e018-0xbbffffff]
2 月 21 14:28:11 linux-50zl kernel: e820: reserve RAM buffer [mem 0xbb154000-0xbbffffff]
2 月 21 14:28:11 linux-50zl kernel: e820: reserve RAM buffer [mem 0xbc16a000-0xbfffffff]
2 月 21 14:28:11 linux-50zl kernel: e820: reserve RAM buffer [mem 0xce793000-0xcfffffff]
2 月 21 14:28:11 linux-50zl kernel: e820: reserve RAM buffer [mem 0xcf800000-0xcfffffff]
2 月 21 14:28:11 linux-50zl kernel: e820: reserve RAM buffer [mem 0x22e000000-0x22fffffff]
2 月 21 14:28:11 linux-50zl kernel: NetLabel: Initializing
2 月 21 14:28:11 linux-50zl kernel: NetLabel: domain hash size = 128
2 月 21 14:28:11 linux-50zl kernel: NetLabel: protocols = UNLABELED CIPSOv4
2 月 21 14:28:11 linux-50zl kernel: NetLabel: unlabeled traffic allowed by default
2 月 21 14:28:11 linux-50zl kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
2 月 21 14:28:11 linux-50zl kernel: hpet0: 8 comparators, 64-bit 14.318180 MHz counter
2 月 21 14:28:11 linux-50zl kernel: Switched to clocksource hpet
2 月 21 14:28:11 linux-50zl kernel: AppArmor: AppArmor Filesystem Enabled
2 月 21 14:28:11 linux-50zl kernel: pnp: PnP ACPI init
2 月 21 14:28:11 linux-50zl kernel: ACPI: bus type PNP registered
2 月 21 14:28:11 linux-50zl kernel: system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
2 月 21 14:28:11 linux-50zl kernel: system 00:01: [io 0x0680-0x069f] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:01: [io 0xffff] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:01: [io 0x1c00-0x1cfe] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:01: [io 0x1d00-0x1dfe] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:01: [io 0x1e00-0x1efe] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:01: [io 0x1f00-0x1ffe] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:01: [io 0x1800-0x18fe] could not be reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:01: [io 0x164e-0x164f] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
2 月 21 14:28:11 linux-50zl kernel: pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
2 月 21 14:28:11 linux-50zl kernel: system 00:03: [io 0x1854-0x1857] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
2 月 21 14:28:11 linux-50zl kernel: system 00:04: [io 0x0a00-0x0a0f] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:04: [io 0x0a30-0x0a3f] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:04: [io 0x0a20-0x0a2f] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
2 月 21 14:28:11 linux-50zl kernel: pnp 00:05: [dma 0 disabled]
2 月 21 14:28:11 linux-50zl kernel: pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
2 月 21 14:28:11 linux-50zl kernel: pnp 00:06: [dma 0 disabled]
2 月 21 14:28:11 linux-50zl kernel: pnp 00:06: Plug and Play ACPI device, IDs PNP0400 (active)
2 月 21 14:28:11 linux-50zl kernel: system 00:07: [io 0x04d0-0x04d1] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
2 月 21 14:28:11 linux-50zl kernel: system 00:08: [mem 0xfed1c000-0xfed1ffff] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:08: [mem 0xfed10000-0xfed17fff] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:08: [mem 0xfed18000-0xfed18fff] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:08: [mem 0xfed19000-0xfed19fff] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:08: [mem 0xf8000000-0xfbffffff] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:08: [mem 0xfed20000-0xfed3ffff] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:08: [mem 0xfed90000-0xfed93fff] could not be reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:08: [mem 0xfed45000-0xfed8ffff] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:08: [mem 0xff000000-0xffffffff] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:08: [mem 0xfee00000-0xfeefffff] could not be reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:08: [mem 0xf7fef000-0xf7feffff] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:08: [mem 0xf7ff0000-0xf7ff0fff] has been reserved
2 月 21 14:28:11 linux-50zl kernel: system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
2 月 21 14:28:11 linux-50zl kernel: pnp: PnP ACPI: found 9 devices
2 月 21 14:28:11 linux-50zl kernel: ACPI: bus type PNP unregistered
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:00: resource 11 [mem 0xd0000000-0xfeafffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:01: resource 1 [mem 0xe8000000-0xf30fffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:03: resource 1 [mem 0xf3100000-0xf31fffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:03: resource 5 [io 0x0d00-0xffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:03: resource 7 [mem 0x000d0000-0x000d3fff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:03: resource 8 [mem 0x000d4000-0x000d7fff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:03: resource 9 [mem 0x000d8000-0x000dbfff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:03: resource 10 [mem 0x000dc000-0x000dffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:03: resource 11 [mem 0xd0000000-0xfeafffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:04: resource 0 [io 0xd000-0xdfff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:04: resource 1 [mem 0xf3100000-0xf31fffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:04: resource 4 [io 0xd000-0xdfff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:04: resource 5 [mem 0xf3100000-0xf31fffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:04: resource 6 [io 0x0000-0x0cf7]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:04: resource 7 [io 0x0d00-0xffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:04: resource 8 [mem 0x000a0000-0x000bffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:04: resource 9 [mem 0x000d0000-0x000d3fff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:04: resource 10 [mem 0x000d4000-0x000d7fff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:04: resource 11 [mem 0x000d8000-0x000dbfff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:04: resource 12 [mem 0x000dc000-0x000dffff]
2 月 21 14:28:11 linux-50zl kernel: pci_bus 0000:04: resource 13 [mem 0xd0000000-0xfeafffff]
2 月 21 14:28:11 linux-50zl kernel: NET: Registered protocol family 2
2 月 21 14:28:11 linux-50zl kernel: TCP established hash table entries: 65536 (order: 7, 524288 bytes)
2 月 21 14:28:11 linux-50zl kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
2 月 21 14:28:11 linux-50zl kernel: TCP: Hash tables configured (established 65536 bind 65536)
2 月 21 14:28:11 linux-50zl kernel: TCP: reno registered
2 月 21 14:28:11 linux-50zl kernel: UDP hash table entries: 4096 (order: 5, 131072 bytes)
2 月 21 14:28:11 linux-50zl kernel: UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
2 月 21 14:28:11 linux-50zl kernel: pci 0000:01:00.0: Video device with shadowed ROM
2 月 21 14:28:11 linux-50zl kernel: PCI: CLS 64 bytes, default 64
2 月 21 14:28:11 linux-50zl kernel: Unpacking initramfs...
2 月 21 14:28:11 linux-50zl kernel: Freeing initrd memory: 7744K (ffff88003f86b000 - ffff88003fffb000)
2 月 21 14:28:11 linux-50zl kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
2 月 21 14:28:11 linux-50zl kernel: software IO TLB [mem 0xb6e3d000-0xbae3d000] (64MB) mapped at [ffff8800b6e3d000-ffff8800bae3cfff]
2 月 21 14:28:11 linux-50zl kernel: RAPL PMU detected, hw unit 2^-14 Joules, API unit is 2^-32 Joules, 4 fixed counters 655360 ms ovfl timer
2 月 21 14:28:11 linux-50zl kernel: microcode: CPU0 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 14:28:11 linux-50zl kernel: microcode: CPU1 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 14:28:11 linux-50zl kernel: microcode: CPU2 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 14:28:11 linux-50zl kernel: microcode: CPU3 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 14:28:11 linux-50zl kernel: microcode: CPU4 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 14:28:11 linux-50zl kernel: microcode: CPU5 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 14:28:11 linux-50zl kernel: microcode: CPU6 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 14:28:11 linux-50zl kernel: microcode: CPU7 sig=0x306c3, pf=0x2, revision=0x1c
2 月 21 14:28:11 linux-50zl kernel: microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
2 月 21 14:28:11 linux-50zl kernel: Scanning for low memory corruption every 60 seconds
2 月 21 14:28:11 linux-50zl kernel: futex hash table entries: 2048 (order: 5, 131072 bytes)
2 月 21 14:28:11 linux-50zl kernel: Initialise system trusted keyring
2 月 21 14:28:11 linux-50zl kernel: audit: initializing netlink subsys (disabled)
2 月 21 14:28:11 linux-50zl kernel: audit: type=2000 audit(1424528891.709:1): initialized
2 月 21 14:28:11 linux-50zl kernel: HugeTLB registered 2 MB page size, pre-allocated 0 pages
2 月 21 14:28:11 linux-50zl kernel: zbud: loaded
2 月 21 14:28:11 linux-50zl kernel: VFS: Disk quotas dquot_6.5.2
2 月 21 14:28:11 linux-50zl kernel: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
2 月 21 14:28:11 linux-50zl kernel: msgmni has been set to 15864
2 月 21 14:28:11 linux-50zl kernel: Key type big_key registered
2 月 21 14:28:11 linux-50zl kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
2 月 21 14:28:11 linux-50zl kernel: io scheduler noop registered
2 月 21 14:28:11 linux-50zl kernel: io scheduler deadline registered
2 月 21 14:28:11 linux-50zl kernel: io scheduler cfq registered (default)
2 月 21 14:28:11 linux-50zl kernel: pcieport 0000:00:01.0: irq 41 for MSI/MSI-X
2 月 21 14:28:11 linux-50zl kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
2 月 21 14:28:11 linux-50zl kernel: pciehp: PCI Express Hot Plug Controller Driver version: 0.4
2 月 21 14:28:11 linux-50zl kernel: efifb: probing for efifb
2 月 21 14:28:11 linux-50zl kernel: efifb: framebuffer at 0xf1000000, mapped to 0xffffc90004f00000, using 3072k, total 3072k
2 月 21 14:28:11 linux-50zl kernel: efifb: mode is 1024x768x32, linelength=4096, pages=1
2 月 21 14:28:11 linux-50zl kernel: efifb: scrolling: redraw
2 月 21 14:28:11 linux-50zl kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
2 月 21 14:28:11 linux-50zl kernel: Console: switching to colour frame buffer device 128x48
2 月 21 14:28:11 linux-50zl kernel: fb0: EFI VGA frame buffer device
2 月 21 14:28:11 linux-50zl kernel: intel_idle: MWAIT substates: 0x42120
2 月 21 14:28:11 linux-50zl kernel: intel_idle: v0.4 model 0x3C
2 月 21 14:28:11 linux-50zl kernel: intel_idle: lapic_timer_reliable_states 0xffffffff
2 月 21 14:28:11 linux-50zl kernel: GHES: HEST is not enabled!
2 月 21 14:28:11 linux-50zl kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing disabled
2 月 21 14:28:11 linux-50zl kernel: 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
2 月 21 14:28:11 linux-50zl kernel: serial 0000:00:16.3: enabling device (0000 -> 0003)
2 月 21 14:28:11 linux-50zl kernel: 0000:00:16.3: ttyS4 at I/O 0xf0a0 (irq = 19, base_baud = 115200) is a 16550A
2 月 21 14:28:11 linux-50zl kernel: Non-volatile memory driver v1.3
2 月 21 14:28:11 linux-50zl kernel: Linux agpgart interface v0.103
2 月 21 14:28:11 linux-50zl kernel: ahci 0000:00:1f.2: version 3.0
2 月 21 14:28:11 linux-50zl kernel: ahci 0000:00:1f.2: irq 42 for MSI/MSI-X
2 月 21 14:28:11 linux-50zl kernel: ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0xf impl SATA mode
2 月 21 14:28:11 linux-50zl kernel: ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
2 月 21 14:28:11 linux-50zl kernel: scsi0 : ahci
2 月 21 14:28:11 linux-50zl kernel: scsi1 : ahci
2 月 21 14:28:11 linux-50zl kernel: scsi2 : ahci
2 月 21 14:28:11 linux-50zl kernel: scsi3 : ahci
2 月 21 14:28:11 linux-50zl kernel: scsi4 : ahci
2 月 21 14:28:11 linux-50zl kernel: scsi5 : ahci
2 月 21 14:28:11 linux-50zl kernel: ata1: SATA max UDMA/133 abar m2048@0xf3236000 port 0xf3236100 irq 42
2 月 21 14:28:11 linux-50zl kernel: ata2: SATA max UDMA/133 abar m2048@0xf3236000 port 0xf3236180 irq 42
2 月 21 14:28:11 linux-50zl kernel: ata3: SATA max UDMA/133 abar m2048@0xf3236000 port 0xf3236200 irq 42
2 月 21 14:28:11 linux-50zl kernel: ata4: SATA max UDMA/133 abar m2048@0xf3236000 port 0xf3236280 irq 42
2 月 21 14:28:11 linux-50zl kernel: ata5: DUMMY
2 月 21 14:28:11 linux-50zl kernel: ata6: DUMMY
2 月 21 14:28:11 linux-50zl kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
2 月 21 14:28:11 linux-50zl kernel: ehci-pci: EHCI PCI platform driver
2 月 21 14:28:11 linux-50zl kernel: ehci-pci 0000:00:1a.0: EHCI Host Controller
2 月 21 14:28:11 linux-50zl kernel: ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
2 月 21 14:28:11 linux-50zl kernel: ehci-pci 0000:00:1a.0: debug port 2
2 月 21 14:28:11 linux-50zl kernel: ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
2 月 21 14:28:11 linux-50zl kernel: ehci-pci 0000:00:1a.0: irq 16, io mem 0xf3238000
2 月 21 14:28:11 linux-50zl kernel: ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
2 月 21 14:28:11 linux-50zl kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
2 月 21 14:28:11 linux-50zl kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2 月 21 14:28:11 linux-50zl kernel: usb usb1: Product: EHCI Host Controller
2 月 21 14:28:11 linux-50zl kernel: usb usb1: Manufacturer: Linux 3.16.7-7-desktop ehci_hcd
2 月 21 14:28:11 linux-50zl kernel: usb usb1: SerialNumber: 0000:00:1a.0
2 月 21 14:28:11 linux-50zl kernel: hub 1-0:1.0: USB hub found
2 月 21 14:28:11 linux-50zl kernel: hub 1-0:1.0: 2 ports detected
2 月 21 14:28:11 linux-50zl kernel: ehci-pci 0000:00:1d.0: EHCI Host Controller
2 月 21 14:28:11 linux-50zl kernel: ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
2 月 21 14:28:11 linux-50zl kernel: ehci-pci 0000:00:1d.0: debug port 2
2 月 21 14:28:11 linux-50zl kernel: ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
2 月 21 14:28:11 linux-50zl kernel: ehci-pci 0000:00:1d.0: irq 23, io mem 0xf3237000
2 月 21 14:28:11 linux-50zl kernel: ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
2 月 21 14:28:11 linux-50zl kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
2 月 21 14:28:11 linux-50zl kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2 月 21 14:28:11 linux-50zl kernel: usb usb2: Product: EHCI Host Controller
2 月 21 14:28:11 linux-50zl kernel: usb usb2: Manufacturer: Linux 3.16.7-7-desktop ehci_hcd
2 月 21 14:28:11 linux-50zl kernel: usb usb2: SerialNumber: 0000:00:1d.0
2 月 21 14:28:11 linux-50zl kernel: hub 2-0:1.0: USB hub found
2 月 21 14:28:11 linux-50zl kernel: hub 2-0:1.0: 2 ports detected
2 月 21 14:28:11 linux-50zl kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
2 月 21 14:28:11 linux-50zl kernel: uhci_hcd: USB Universal Host Controller Interface driver
2 月 21 14:28:11 linux-50zl kernel: i8042: PNP: No PS/2 controller found. Probing ports directly.
2 月 21 14:28:11 linux-50zl kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
2 月 21 14:28:11 linux-50zl kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
2 月 21 14:28:11 linux-50zl kernel: mousedev: PS/2 mouse device common for all mice
2 月 21 14:28:11 linux-50zl kernel: rtc_cmos 00:02: RTC can wake from S4
2 月 21 14:28:11 linux-50zl kernel: rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
2 月 21 14:28:11 linux-50zl kernel: rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
2 月 21 14:28:11 linux-50zl kernel: Intel P-state driver initializing.
2 月 21 14:28:11 linux-50zl kernel: Intel pstate controlling: cpu 0
2 月 21 14:28:11 linux-50zl kernel: Intel pstate controlling: cpu 1
2 月 21 14:28:11 linux-50zl kernel: Intel pstate controlling: cpu 2
2 月 21 14:28:11 linux-50zl kernel: Intel pstate controlling: cpu 3
2 月 21 14:28:11 linux-50zl kernel: Intel pstate controlling: cpu 4
2 月 21 14:28:11 linux-50zl kernel: Intel pstate controlling: cpu 5
2 月 21 14:28:11 linux-50zl kernel: Intel pstate controlling: cpu 6
2 月 21 14:28:11 linux-50zl kernel: Intel pstate controlling: cpu 7
2 月 21 14:28:11 linux-50zl kernel: ledtrig-cpu: registered to indicate activity on CPUs
2 月 21 14:28:11 linux-50zl kernel: EFI Variables Facility v0.08 2004-May-17
2 月 21 14:28:11 linux-50zl kernel: hidraw: raw HID events driver (C) Jiri Kosina
2 月 21 14:28:11 linux-50zl kernel: usbcore: registered new interface driver usbhid
2 月 21 14:28:11 linux-50zl kernel: usbhid: USB HID core driver
2 月 21 14:28:11 linux-50zl kernel: TCP: cubic registered
2 月 21 14:28:11 linux-50zl kernel: NET: Registered protocol family 10
2 月 21 14:28:11 linux-50zl kernel: Loading compiled-in X.509 certificates
2 月 21 14:28:11 linux-50zl kernel: registered taskstats version 1
2 月 21 14:28:11 linux-50zl kernel: AppArmor: AppArmor sha1 policy hashing enabled
2 月 21 14:28:11 linux-50zl kernel: Magic number: 3:962:485
2 月 21 14:28:11 linux-50zl kernel: rtc_cmos 00:02: setting system clock to 2015-02-21 14:28:11 UTC (1424528891)
2 月 21 14:28:11 linux-50zl kernel: PM: Checking hibernation image partition /dev/sda6
2 月 21 14:28:11 linux-50zl kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
2 月 21 14:28:11 linux-50zl kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
2 月 21 14:28:11 linux-50zl kernel: ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
2 月 21 14:28:11 linux-50zl kernel: ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
2 月 21 14:28:11 linux-50zl kernel: ata3.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
2 月 21 14:28:11 linux-50zl kernel: ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
2 月 21 14:28:11 linux-50zl kernel: ata3.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
2 月 21 14:28:11 linux-50zl kernel: ata2.00: ATA-8: WDC WD1002FAEX-00Y9A0, 05.01D05, max UDMA/133
2 月 21 14:28:11 linux-50zl kernel: ata2.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
2 月 21 14:28:11 linux-50zl kernel: ata2.00: configured for UDMA/133
2 月 21 14:28:11 linux-50zl kernel: usb 1-1: new high-speed USB device number 2 using ehci-pci
2 月 21 14:28:11 linux-50zl kernel: ata1.00: ATA-9: INTEL SSDSC2BW120A4, DC32, max UDMA/133
2 月 21 14:28:11 linux-50zl kernel: ata1.00: 234441648 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
2 月 21 14:28:11 linux-50zl kernel: ata3.00: HPA detected: current 156299375, native 156301488
2 月 21 14:28:11 linux-50zl kernel: ata3.00: ATA-7: ST380815AS, 3.AAC, max UDMA/133
2 月 21 14:28:11 linux-50zl kernel: ata3.00: 156299375 sectors, multi 16: LBA48 NCQ (depth 31/32)
2 月 21 14:28:11 linux-50zl kernel: ata1.00: configured for UDMA/133
2 月 21 14:28:11 linux-50zl kernel: scsi 0:0:0:0: Direct-Access ATA INTEL SSDSC2BW12 DC32 PQ: 0 ANSI: 5
2 月 21 14:28:11 linux-50zl kernel: sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
2 月 21 14:28:11 linux-50zl kernel: sd 0:0:0:0: [sda] Write Protect is off
2 月 21 14:28:11 linux-50zl kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
2 月 21 14:28:11 linux-50zl kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
2 月 21 14:28:11 linux-50zl kernel: scsi 1:0:0:0: Direct-Access ATA WDC WD1002FAEX-0 1D05 PQ: 0 ANSI: 5
2 月 21 14:28:11 linux-50zl kernel: sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
2 月 21 14:28:11 linux-50zl kernel: sd 1:0:0:0: [sdb] Write Protect is off
2 月 21 14:28:11 linux-50zl kernel: sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
2 月 21 14:28:11 linux-50zl kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
2 月 21 14:28:11 linux-50zl kernel: sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7
2 月 21 14:28:11 linux-50zl kernel: sd 0:0:0:0: [sda] Attached SCSI disk
2 月 21 14:28:11 linux-50zl kernel: ata4.00: ATA-7: ST380815AS, 3.AAD, max UDMA/133
2 月 21 14:28:11 linux-50zl kernel: ata4.00: 156301488 sectors, multi 16: LBA48 NCQ (depth 31/32)
2 月 21 14:28:11 linux-50zl kernel: sdb: sdb1 sdb2
2 月 21 14:28:11 linux-50zl kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
2 月 21 14:28:11 linux-50zl kernel: ata3.00: configured for UDMA/133
2 月 21 14:28:11 linux-50zl kernel: scsi 2:0:0:0: Direct-Access ATA ST380815AS C PQ: 0 ANSI: 5
2 月 21 14:28:11 linux-50zl kernel: sd 2:0:0:0: [sdc] 156299375 512-byte logical blocks: (80.0 GB/74.5 GiB)
2 月 21 14:28:11 linux-50zl kernel: sd 2:0:0:0: [sdc] Write Protect is off
2 月 21 14:28:11 linux-50zl kernel: sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
2 月 21 14:28:11 linux-50zl kernel: sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
2 月 21 14:28:11 linux-50zl kernel: ata4.00: configured for UDMA/133
2 月 21 14:28:11 linux-50zl kernel: scsi 3:0:0:0: Direct-Access ATA ST380815AS D PQ: 0 ANSI: 5
2 月 21 14:28:11 linux-50zl kernel: sd 3:0:0:0: [sdd] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
2 月 21 14:28:11 linux-50zl kernel: sd 3:0:0:0: [sdd] Write Protect is off
2 月 21 14:28:11 linux-50zl kernel: sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
2 月 21 14:28:11 linux-50zl kernel: sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
2 月 21 14:28:11 linux-50zl kernel: usb 1-1: New USB device found, idVendor=8087, idProduct=8008
2 月 21 14:28:11 linux-50zl kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
2 月 21 14:28:11 linux-50zl kernel: hub 1-1:1.0: USB hub found
2 月 21 14:28:11 linux-50zl kernel: hub 1-1:1.0: 6 ports detected
2 月 21 14:28:11 linux-50zl kernel: sdc: sdc1 sdc2
2 月 21 14:28:11 linux-50zl kernel: sd 2:0:0:0: [sdc] Attached SCSI disk
2 月 21 14:28:11 linux-50zl kernel: sdd: sdd1
2 月 21 14:28:11 linux-50zl kernel: sd 3:0:0:0: [sdd] Attached SCSI disk
2 月 21 14:28:11 linux-50zl kernel: PM: Hibernation image partition 8:6 present
2 月 21 14:28:11 linux-50zl kernel: PM: Looking for hibernation image.
2 月 21 14:28:11 linux-50zl kernel: PM: Image not found (code -22)
2 月 21 14:28:11 linux-50zl kernel: PM: Hibernation image not present or could not be loaded.
2 月 21 14:28:11 linux-50zl kernel: Freeing unused kernel memory: 1560K (ffffffff81efe000 - ffffffff82084000)
2 月 21 14:28:11 linux-50zl kernel: Write protecting the kernel read-only data: 14336k
2 月 21 14:28:11 linux-50zl kernel: Freeing unused kernel memory: 1880K (ffff88000162a000 - ffff880001800000)
2 月 21 14:28:11 linux-50zl kernel: Freeing unused kernel memory: 1436K (ffff880001c99000 - ffff880001e00000)
2 月 21 14:28:11 linux-50zl systemd[1]: RTC configured in localtime, applying delta of 480 minutes to system time.
2 月 21 14:28:11 linux-50zl kernel: random: systemd urandom read with 49 bits of entropy available
2 月 21 14:28:11 linux-50zl kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
2 月 21 14:28:11 linux-50zl kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
2 月 21 14:28:11 linux-50zl kernel: sd 2:0:0:0: Attached scsi generic sg2 type 0
2 月 21 14:28:11 linux-50zl kernel: sd 3:0:0:0: Attached scsi generic sg3 type 0
2 月 21 14:28:11 linux-50zl systemd-journal[177]: Journal started
2 月 21 14:28:11 linux-50zl systemd-vconsole-setup[178]: /usr/bin/setfont failed with error code 1.
2 月 21 14:28:11 linux-50zl dracut-cmdline[175]: dracut-13.2 (Harlequin) dracut-037-17.9.1
2 月 21 14:28:11 linux-50zl systemd-vconsole-setup[178]: mapscrn: cannot open map file _trivial_
2 月 21 14:28:12 linux-50zl kernel: usb 2-1: new high-speed USB device number 2 using ehci-pci
2 月 21 14:28:12 linux-50zl kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
2 月 21 14:28:12 linux-50zl kernel: ACPI: Power Button [PWRB]
2 月 21 14:28:12 linux-50zl kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
2 月 21 14:28:12 linux-50zl kernel: ACPI: Power Button [PWRF]
2 月 21 14:28:12 linux-50zl kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
2 月 21 14:28:12 linux-50zl kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
2 月 21 14:28:12 linux-50zl kernel: xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
2 月 21 14:28:12 linux-50zl kernel: xhci_hcd 0000:00:14.0: irq 43 for MSI/MSI-X
2 月 21 14:28:12 linux-50zl kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
2 月 21 14:28:12 linux-50zl kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2 月 21 14:28:12 linux-50zl kernel: usb usb3: Product: xHCI Host Controller
2 月 21 14:28:12 linux-50zl kernel: usb usb3: Manufacturer: Linux 3.16.7-7-desktop xhci_hcd
2 月 21 14:28:12 linux-50zl kernel: usb usb3: SerialNumber: 0000:00:14.0
2 月 21 14:28:12 linux-50zl kernel: hub 3-0:1.0: USB hub found
2 月 21 14:28:12 linux-50zl kernel: hub 3-0:1.0: 12 ports detected
2 月 21 14:28:12 linux-50zl kernel: [drm] Initialized drm 1.1.0 20060810
2 月 21 14:28:12 linux-50zl kernel: wmi: Mapper loaded
2 月 21 14:28:12 linux-50zl kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
2 月 21 14:28:12 linux-50zl kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
2 月 21 14:28:12 linux-50zl kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2 月 21 14:28:12 linux-50zl kernel: usb usb4: Product: xHCI Host Controller
2 月 21 14:28:12 linux-50zl kernel: usb usb4: Manufacturer: Linux 3.16.7-7-desktop xhci_hcd
2 月 21 14:28:12 linux-50zl kernel: usb usb4: SerialNumber: 0000:00:14.0
2 月 21 14:28:12 linux-50zl kernel: hub 4-0:1.0: USB hub found
2 月 21 14:28:12 linux-50zl kernel: hub 4-0:1.0: 6 ports detected
2 月 21 14:28:12 linux-50zl kernel: checking generic (f1000000 300000) vs hw (e8000000 8000000)
2 月 21 14:28:12 linux-50zl kernel: checking generic (f1000000 300000) vs hw (f0000000 2000000)
2 月 21 14:28:12 linux-50zl kernel: fb: switching to nouveaufb from EFI VGA
2 月 21 14:28:12 linux-50zl kernel: Console: switching to colour dummy device 80x25
2 月 21 14:28:12 linux-50zl kernel: nouveau DEVICE][0000:01:00.0] BOOT0 : 0x0e4070a2
2 月 21 14:28:12 linux-50zl kernel: nouveau DEVICE][0000:01:00.0] Chipset: GK104 (NVE4)
2 月 21 14:28:12 linux-50zl kernel: nouveau DEVICE][0000:01:00.0] Family : NVE0
2 月 21 14:28:12 linux-50zl kernel: nouveau VBIOS][0000:01:00.0] checking PRAMIN for image...
2 月 21 14:28:12 linux-50zl kernel: nouveau VBIOS][0000:01:00.0] ... signature not found
2 月 21 14:28:12 linux-50zl kernel: nouveau VBIOS][0000:01:00.0] checking PROM for image...
2 月 21 14:28:12 linux-50zl kernel: nouveau VBIOS][0000:01:00.0] ... appears to be valid
2 月 21 14:28:12 linux-50zl kernel: nouveau VBIOS][0000:01:00.0] using image from PROM
2 月 21 14:28:12 linux-50zl kernel: nouveau VBIOS][0000:01:00.0] BIT signature found
2 月 21 14:28:12 linux-50zl kernel: nouveau VBIOS][0000:01:00.0] version 80.04.bf.00.63
2 月 21 14:28:12 linux-50zl kernel: nouveau 0000:01:00.0: irq 44 for MSI/MSI-X
2 月 21 14:28:12 linux-50zl kernel: nouveau PMC][0000:01:00.0] MSI interrupts enabled
2 月 21 14:28:12 linux-50zl kernel: nouveau PFB][0000:01:00.0] RAM type: GDDR5
2 月 21 14:28:12 linux-50zl kernel: nouveau PFB][0000:01:00.0] RAM size: 2048 MiB
2 月 21 14:28:12 linux-50zl kernel: nouveau PFB][0000:01:00.0] ZCOMP: 0 tags
2 月 21 14:28:12 linux-50zl kernel: nouveau VOLT][0000:01:00.0] GPU voltage: 862500uv
2 月 21 14:28:12 linux-50zl kernel: nouveau PTHERM][0000:01:00.0] FAN control: PWM
2 月 21 14:28:12 linux-50zl kernel: nouveau PTHERM][0000:01:00.0] fan management: automatic
2 月 21 14:28:12 linux-50zl kernel: nouveau PTHERM][0000:01:00.0] internal sensor: yes
2 月 21 14:28:12 linux-50zl kernel: nouveau CLK][0000:01:00.0] 07: core 405 MHz memory 648 MHz
2 月 21 14:28:12 linux-50zl kernel: nouveau CLK][0000:01:00.0] 0a: core 405-967 MHz memory 1620 MHz
2 月 21 14:28:12 linux-50zl kernel: nouveau CLK][0000:01:00.0] 0e: core 405-1306 MHz memory 6008 MHz
2 月 21 14:28:12 linux-50zl kernel: nouveau CLK][0000:01:00.0] 0f: core 405-1306 MHz memory 6008 MHz
2 月 21 14:28:12 linux-50zl kernel: nouveau CLK][0000:01:00.0] --: core 405 MHz memory 648 MHz
2 月 21 14:28:12 linux-50zl kernel: usb 2-1: New USB device found, idVendor=8087, idProduct=8000
2 月 21 14:28:12 linux-50zl kernel: usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
2 月 21 14:28:12 linux-50zl kernel: hub 2-1:1.0: USB hub found
2 月 21 14:28:12 linux-50zl kernel: hub 2-1:1.0: 6 ports detected
2 月 21 14:28:12 linux-50zl kernel: random: nonblocking pool is initialized
2 月 21 14:28:12 linux-50zl kernel: [TTM] Zone kernel: Available graphics memory: 4063682 kiB
2 月 21 14:28:12 linux-50zl kernel: [TTM] Zone dma32: Available graphics memory: 2097152 kiB
2 月 21 14:28:12 linux-50zl kernel: [TTM] Initializing pool allocator
2 月 21 14:28:12 linux-50zl kernel: [TTM] Initializing DMA pool allocator
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] VRAM: 2048 MiB
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] GART: 1048576 MiB
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] TMDS table version 2.0
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] DCB version 4.0
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] DCB outp 00: 01000f02 00020030
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] DCB outp 01: 02000f00 00000000
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] DCB outp 02: 08011f82 00020030
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] DCB outp 03: 02022f62 00020010
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] DCB outp 04: 04833fb6 0f420010
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] DCB outp 05: 04033f72 00020010
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] DCB conn 00: 00001030
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] DCB conn 01: 00020131
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] DCB conn 02: 00010261
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] DCB conn 03: 00002346
2 月 21 14:28:12 linux-50zl kernel: [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
2 月 21 14:28:12 linux-50zl kernel: [drm] Driver supports precise vblank timestamp query.
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] MM: using COPY for buffer copies
2 月 21 14:28:12 linux-50zl kernel: nouveau DRM] allocated 1920x1080 fb: 0x80000, bo ffff880220f6d400
2 月 21 14:28:12 linux-50zl kernel: fbcon: nouveaufb (fb0) is primary device
2 月 21 14:28:12 linux-50zl kernel: usb 3-10: new high-speed USB device number 2 using xhci_hcd
2 月 21 14:28:12 linux-50zl kernel: tsc: Refined TSC clocksource calibration: 3292.376 MHz
2 月 21 14:28:12 linux-50zl kernel: Console: switching to colour frame buffer device 240x67
2 月 21 14:28:12 linux-50zl kernel: nouveau 0000:01:00.0: fb0: nouveaufb frame buffer device
2 月 21 14:28:12 linux-50zl kernel: nouveau 0000:01:00.0: registered panic notifier
2 月 21 14:28:12 linux-50zl kernel: [drm] Initialized nouveau 1.1.2 20120801 for 0000:01:00.0 on minor 0
2 月 21 14:28:12 linux-50zl kernel: PM: Marking nosave pages: [mem 0x00058000-0x00058fff]
2 月 21 14:28:12 linux-50zl kernel: PM: Marking nosave pages: [mem 0x0009f000-0x000fffff]
2 月 21 14:28:12 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbae3d000-0xbae3dfff]
2 月 21 14:28:12 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbae4d000-0xbae4efff]
2 月 21 14:28:12 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbae6d000-0xbae6dfff]
2 月 21 14:28:12 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbb154000-0xbb15afff]
2 月 21 14:28:12 linux-50zl kernel: PM: Marking nosave pages: [mem 0xbc16a000-0xbc66ffff]
2 月 21 14:28:12 linux-50zl kernel: PM: Marking nosave pages: [mem 0xce793000-0xcf7fefff]
2 月 21 14:28:12 linux-50zl kernel: PM: Marking nosave pages: [mem 0xcf800000-0xffffffff]
2 月 21 14:28:12 linux-50zl kernel: PM: Basic memory bitmaps created
2 月 21 14:28:12 linux-50zl kernel: usb 3-10: New USB device found, idVendor=2109, idProduct=2812
2 月 21 14:28:12 linux-50zl kernel: usb 3-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
2 月 21 14:28:12 linux-50zl kernel: usb 3-10: Product: USB2.0 Hub
2 月 21 14:28:12 linux-50zl kernel: usb 3-10: Manufacturer: VIA Labs, Inc.
2 月 21 14:28:12 linux-50zl kernel: hub 3-10:1.0: USB hub found
2 月 21 14:28:12 linux-50zl kernel: hub 3-10:1.0: 4 ports detected
2 月 21 14:28:12 linux-50zl kernel: PM: Basic memory bitmaps freed
2 月 21 14:28:12 linux-50zl kernel: PM: Starting manual resume from disk
2 月 21 14:28:12 linux-50zl kernel: PM: Hibernation image partition 8:6 present
2 月 21 14:28:12 linux-50zl kernel: PM: Looking for hibernation image.
2 月 21 14:28:12 linux-50zl kernel: PM: Image not found (code -22)
2 月 21 14:28:12 linux-50zl kernel: PM: Hibernation image not present or could not be loaded.
2 月 21 14:28:12 linux-50zl systemd-fsck[328]: /dev/sda7: clean, 294205/1474560 files, 2425949/5890304 blocks
2 月 21 14:28:12 linux-50zl kernel: EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)
2 月 21 14:28:12 linux-50zl kernel: usb 4-6: new SuperSpeed USB device number 2 using xhci_hcd
2 月 21 14:28:12 linux-50zl systemd-journal[177]: Journal stopped
2 月 21 14:28:12 linux-50zl systemd-journal[426]: Runtime journal is using 8.0M (max allowed 396.8M, trying to leave 595.2M free of 3.8G available → current limit 396.8M).
2 月 21 14:28:12 linux-50zl systemd[1]: RTC configured in localtime, applying delta of 480 minutes to system time.
2 月 21 14:28:12 linux-50zl kernel: device-mapper: uevent: version 1.0.3
2 月 21 14:28:12 linux-50zl kernel: device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: dm-devel@redhat.com
2 月 21 14:28:12 linux-50zl systemd-journal[426]: Journal started
2 月 21 14:28:12 linux-50zl dmeventd[435]: dmeventd ready for processing.
2 月 21 14:28:12 linux-50zl systemd-fsck[437]: /dev/sda7: clean, 294205/1474560 files, 2425949/5890304 blocks
2 月 21 14:28:12 linux-50zl kernel: EXT4-fs (sda7): re-mounted. Opts: acl,user_xattr
2 月 21 14:28:12 linux-50zl kernel: usb 4-6: New USB device found, idVendor=2109, idProduct=0812
2 月 21 14:28:12 linux-50zl kernel: usb 4-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
2 月 21 14:28:12 linux-50zl kernel: usb 4-6: Product: USB3.0 Hub
2 月 21 14:28:12 linux-50zl kernel: usb 4-6: Manufacturer: VIA Labs, Inc.
2 月 21 14:28:12 linux-50zl kernel: hub 4-6:1.0: USB hub found
2 月 21 14:28:12 linux-50zl kernel: hub 4-6:1.0: 4 ports detected
2 月 21 14:28:12 linux-50zl kernel: parport_pc 00:06: reported by Plug and Play ACPI
2 月 21 14:28:12 linux-50zl kernel: parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
2 月 21 14:28:12 linux-50zl kernel: ACPI: Fan [FAN0] (off)
2 月 21 14:28:12 linux-50zl kernel: ACPI: Fan [FAN1] (off)
2 月 21 14:28:12 linux-50zl kernel: thermal LNXTHERM:00: registered as thermal_zone0
2 月 21 14:28:12 linux-50zl kernel: ACPI: Thermal Zone [TZ00] (28 C)
2 月 21 14:28:12 linux-50zl kernel: ACPI: Fan [FAN2] (off)
2 月 21 14:28:12 linux-50zl kernel: thermal LNXTHERM:01: registered as thermal_zone1
2 月 21 14:28:12 linux-50zl kernel: ACPI: Thermal Zone [TZ01] (30 C)
2 月 21 14:28:12 linux-50zl kernel: ACPI: Fan [FAN3] (off)
2 月 21 14:28:12 linux-50zl kernel: ACPI: Fan [FAN4] (off)
2 月 21 14:28:12 linux-50zl kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
2 月 21 14:28:12 linux-50zl kernel: mei_me 0000:00:16.0: irq 45 for MSI/MSI-X
2 月 21 14:28:12 linux-50zl kernel: pps_core: LinuxPPS API ver. 1 registered
2 月 21 14:28:12 linux-50zl kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
2 月 21 14:28:12 linux-50zl kernel: PTP clock support registered
2 月 21 14:28:12 linux-50zl kernel: e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
2 月 21 14:28:12 linux-50zl kernel: e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
2 月 21 14:28:12 linux-50zl kernel: e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
2 月 21 14:28:12 linux-50zl kernel: e1000e 0000:00:19.0: irq 46 for MSI/MSI-X
2 月 21 14:28:12 linux-50zl kernel: 8139cp: 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
2 月 21 14:28:12 linux-50zl kernel: 8139cp 0000:04:00.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip, use 8139too
2 月 21 14:28:12 linux-50zl kernel: 8139too: 8139too Fast Ethernet driver 0.9.28
2 月 21 14:28:12 linux-50zl kernel: 8139too 0000:04:00.0: enabling device (0000 -> 0003)
2 月 21 14:28:12 linux-50zl kernel: 8139too 0000:04:00.0 eth0: RealTek RTL8139 at 0xffffc90004cb8000, 00:e0:09:06:2e:0c, IRQ 19
2 月 21 14:28:12 linux-50zl kernel: input: PC Speaker as /devices/platform/pcspkr/input/input5
2 月 21 14:28:12 linux-50zl kernel: AVX2 version of gcm_enc/dec engaged.
2 月 21 14:28:12 linux-50zl kernel: usb 3-10.4: new full-speed USB device number 3 using xhci_hcd
2 月 21 14:28:13 linux-50zl kernel: ppdev: user-space parallel port driver
2 月 21 14:28:13 linux-50zl kernel: usb 3-10.4: New USB device found, idVendor=046d, idProduct=c52b
2 月 21 14:28:13 linux-50zl kernel: usb 3-10.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
2 月 21 14:28:13 linux-50zl kernel: usb 3-10.4: Product: USB Receiver
2 月 21 14:28:13 linux-50zl kernel: usb 3-10.4: Manufacturer: Logitech
2 月 21 14:28:13 linux-50zl mtp-probe[777]: checking bus 3, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10.4"
2 月 21 14:28:13 linux-50zl mtp-probe[777]: bus: 3, device: 3 was not an MTP device
2 月 21 14:28:13 linux-50zl kernel: logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-10.4/input2
2 月 21 14:28:13 linux-50zl kernel: Adding 515068k swap on /dev/sda6. Priority:-1 extents:1 across:515068k SSFS
2 月 21 14:28:13 linux-50zl kernel: input: Logitech Unifying Device. Wireless PID:1024 as /devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10.4/3-10.4:1.2/0003:046D:C52B.0003/0003:046D:C52B.0004/input/input6
2 月 21 14:28:13 linux-50zl kernel: logitech-djdevice 0003:046D:C52B.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech Unifying Device. Wireless PID:1024] on usb-0000:00:14.0-10.4:1
2 月 21 14:28:13 linux-50zl kernel: input: Logitech Unifying Device. Wireless PID:2011 as /devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10.4/3-10.4:1.2/0003:046D:C52B.0003/0003:046D:C52B.0005/input/input7
2 月 21 14:28:13 linux-50zl kernel: logitech-djdevice 0003:046D:C52B.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:2011] on usb-0000:00:14.0-10.4:2
2 月 21 14:28:13 linux-50zl systemd-fsck[789]: /dev/sdc2: clean, 32601/1281120 files, 654865/5120256 blocks
2 月 21 14:28:13 linux-50zl kernel: e1000e 0000:00:19.0 eth0: registered PHC clock
2 月 21 14:28:13 linux-50zl kernel: e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 74:d4:35:1a:e9:a3
2 月 21 14:28:13 linux-50zl kernel: e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
2 月 21 14:28:13 linux-50zl kernel: e1000e 0000:00:19.0 eth0: MAC: 11, PHY: 12, PBA No: FFFFFF-0FF
2 月 21 14:28:13 linux-50zl kernel: snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
2 月 21 14:28:13 linux-50zl kernel: snd_hda_intel 0000:00:1b.0: irq 47 for MSI/MSI-X
2 月 21 14:28:13 linux-50zl kernel: i801_smbus 0000:00:1f.3: enabling device (0001 -> 0003)
2 月 21 14:28:13 linux-50zl kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
2 月 21 14:28:13 linux-50zl kernel: snd_hda_intel 0000:01:00.1: Handle VGA-switcheroo audio client
2 月 21 14:28:13 linux-50zl kernel: ACPI Warning: SystemIO range 0x000000000000f000-0x000000000000f01f conflicts with OpRegion 0x000000000000f000-0x000000000000f00f (\_SB_.PCI0.SBUS.SMBI) (20140424/utaddress-258)
2 月 21 14:28:13 linux-50zl kernel: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
2 月 21 14:28:13 linux-50zl kernel: iTCO_vendor_support: vendor-support=0
2 月 21 14:28:13 linux-50zl kernel: iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
2 月 21 14:28:13 linux-50zl kernel: iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
2 月 21 14:28:13 linux-50zl kernel: sound hdaudioC0D2: autoconfig: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
2 月 21 14:28:13 linux-50zl kernel: sound hdaudioC0D2: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
2 月 21 14:28:13 linux-50zl kernel: sound hdaudioC0D2: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
2 月 21 14:28:13 linux-50zl kernel: sound hdaudioC0D2: mono: mono_out=0x0
2 月 21 14:28:13 linux-50zl kernel: sound hdaudioC0D2: dig-out=0x11/0x1e
2 月 21 14:28:13 linux-50zl kernel: sound hdaudioC0D2: inputs:
2 月 21 14:28:13 linux-50zl kernel: sound hdaudioC0D2: Rear Mic=0x18
2 月 21 14:28:13 linux-50zl kernel: sound hdaudioC0D2: Front Mic=0x19
2 月 21 14:28:13 linux-50zl kernel: sound hdaudioC0D2: Line=0x1a
2 月 21 14:28:13 linux-50zl kernel: sound hdaudioC0D2: CD=0x1c
2 月 21 14:28:13 linux-50zl kernel: sound hdaudioC0D2: dig-in=0x1f
2 月 21 14:28:13 linux-50zl kernel: input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/hdaudioC0D2/input8
2 月 21 14:28:13 linux-50zl kernel: input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
2 月 21 14:28:13 linux-50zl kernel: input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
2 月 21 14:28:13 linux-50zl kernel: input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
2 月 21 14:28:13 linux-50zl kernel: input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
2 月 21 14:28:13 linux-50zl kernel: input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
2 月 21 14:28:13 linux-50zl kernel: input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
2 月 21 14:28:13 linux-50zl kernel: EXT4-fs (sdc2): mounted filesystem with ordered data mode. Opts: (null)
2 月 21 14:28:13 linux-50zl kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
2 月 21 14:28:13 linux-50zl kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
2 月 21 14:28:13 linux-50zl kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
2 月 21 14:28:13 linux-50zl kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
2 月 21 14:28:13 linux-50zl kernel: Switched to clocksource tsc
2 月 21 14:28:13 linux-50zl lvm[811]: WARNING: lvmetad is running but disabled. Restart lvmetad before enabling it!
2 月 21 14:28:13 linux-50zl lvm[811]: No volume groups found
2 月 21 14:28:13 linux-50zl lvm[813]: WARNING: lvmetad is running but disabled. Restart lvmetad before enabling it!
2 月 21 14:28:13 linux-50zl lvm[813]: No volume groups found
2 月 21 14:28:13 linux-50zl systemd-journal[426]: Permanent journal is using 24.0M (max allowed 2.1G, trying to leave 3.2G free of 12.1G available → current limit 2.1G).
2 月 21 14:28:13 linux-50zl systemd-journal[426]: Time spent on flushing to /var is 278.498ms for 1149 entries.
2 月 21 14:28:13 linux-50zl kernel: audit: type=1305 audit(1424500093.622:2): audit_pid=831 old=0 auid=4294967295 ses=4294967295 res=1
2 月 21 14:28:13 linux-50zl auditd[831]: Started dispatcher: /sbin/audispd pid: 841
2 月 21 14:28:13 linux-50zl audispd[841]: priority_boost_parser called with: 4
2 月 21 14:28:13 linux-50zl audispd[841]: max_restarts_parser called with: 10
2 月 21 14:28:13 linux-50zl audispd[841]: No plugins found, exiting
2 月 21 14:28:13 linux-50zl auditd[831]: Init complete, auditd 2.4 listening for events (startup state enable)
2 月 21 14:28:13 linux-50zl avahi-daemon[1023]: Found user 'avahi' (UID 486) and group 'avahi' (GID 485).
2 月 21 14:28:13 linux-50zl avahi-daemon[1023]: Successfully dropped root privileges.
2 月 21 14:28:13 linux-50zl avahi-daemon[1023]: avahi-daemon 0.6.31 starting up.
2 月 21 14:28:13 linux-50zl ModemManager[1025]: <info> ModemManager (version 1.0.0) starting...
2 月 21 14:28:13 linux-50zl avahi-daemon[1023]: Loading service file /etc/avahi/services/sftp-ssh.service.
2 月 21 14:28:13 linux-50zl avahi-daemon[1023]: Loading service file /etc/avahi/services/ssh.service.
2 月 21 14:28:13 linux-50zl avahi-daemon[1023]: Network interface enumeration completed.
2 月 21 14:28:13 linux-50zl dbus[1031]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
2 月 21 14:28:13 linux-50zl avahi-daemon[1023]: Registering HINFO record with values 'X86_64'/'LINUX'.
2 月 21 14:28:13 linux-50zl avahi-daemon[1023]: Server startup complete. Host name is linux-50zl.local. Local service cookie is 4044384049.
2 月 21 14:28:13 linux-50zl avahi-daemon[1023]: Service "linux-50zl" (/etc/avahi/services/ssh.service) successfully established.
2 月 21 14:28:13 linux-50zl avahi-daemon[1023]: Service "linux-50zl" (/etc/avahi/services/sftp-ssh.service) successfully established.
2 月 21 14:28:14 linux-50zl polkitd[1051]: Started polkitd version 0.112
2 月 21 14:28:14 linux-50zl polkitd[1051]: Loading rules from directory /etc/polkit-1/rules.d
2 月 21 14:28:14 linux-50zl polkitd[1051]: Loading rules from directory /usr/share/polkit-1/rules.d
2 月 21 14:28:14 linux-50zl polkitd[1051]: Finished loading, compiling and executing 3 rules
2 月 21 14:28:14 linux-50zl dbus[1031]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service'
2 月 21 14:28:14 linux-50zl dbus[1031]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
2 月 21 14:28:14 linux-50zl polkitd[1051]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
2 月 21 14:28:14 linux-50zl dbus[1031]: [system] Successfully activated service 'org.freedesktop.locale1'
2 月 21 14:28:14 linux-50zl kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
2 月 21 14:28:14 linux-50zl kernel: nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
2 月 21 14:28:14 linux-50zl boot.apparmor[830]: Starting AppArmor ..done
2 月 21 14:28:14 linux-50zl auditctl[832]: No rules
2 月 21 14:28:14 linux-50zl auditctl[832]: enabled 0
2 月 21 14:28:14 linux-50zl auditctl[832]: flag 1
2 月 21 14:28:14 linux-50zl auditctl[832]: pid 0
2 月 21 14:28:14 linux-50zl auditctl[832]: rate_limit 0
2 月 21 14:28:14 linux-50zl auditctl[832]: backlog_limit 320
2 月 21 14:28:14 linux-50zl auditctl[832]: lost 0
2 月 21 14:28:14 linux-50zl auditctl[832]: backlog 0
2 月 21 14:28:14 linux-50zl display-manager[1055]: /etc/vconsole.conf available
2 月 21 14:28:14 linux-50zl display-manager[1055]: KEYMAP: chinese
2 月 21 14:28:14 linux-50zl display-manager[1055]: Command: localectl set-keymap chinese
2 月 21 14:28:14 linux-50zl display-manager[1055]: W: Can not found mapping for chinese in /usr/share/systemd/kbd-model-map
2 月 21 14:28:14 linux-50zl display-manager[1055]: W: Please report bug of systemd.
2 月 21 14:28:14 linux-50zl kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
2 月 21 14:28:14 linux-50zl kdm_config[1111]: Multiple occurrences of section [General] in /usr/share/kde4/config/kdm/kdmrc. Consider merging them.
2 月 21 14:28:14 linux-50zl kdm_config[1111]: Multiple occurrences of section [Xdmcp] in /usr/share/kde4/config/kdm/kdmrc. Consider merging them.
2 月 21 14:28:14 linux-50zl kdm_config[1111]: Multiple occurrences of section [X-*-Core] in /usr/share/kde4/config/kdm/kdmrc. Consider merging them.
2 月 21 14:28:14 linux-50zl kdm_config[1111]: Multiple occurrences of section [X-*-Greeter] in /usr/share/kde4/config/kdm/kdmrc. Consider merging them.
2 月 21 14:28:14 linux-50zl kdm_config[1111]: Multiple occurrences of section [X-:*-Core] in /usr/share/kde4/config/kdm/kdmrc. Consider merging them.
2 月 21 14:28:14 linux-50zl kdm_config[1111]: Multiple occurrences of section [X-:0-Core] in /usr/share/kde4/config/kdm/kdmrc. Consider merging them.
2 月 21 14:28:14 linux-50zl kdm[1110]: plymouth is running
2 月 21 14:28:14 linux-50zl display-manager[1055]: Starting service kdm..done
2 月 21 14:28:14 linux-50zl SuSEfirewall2[1138]: Firewall rules set to CLOSE.
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> NetworkManager (version 0.9.10.0) is starting...
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Read config: /etc/NetworkManager/NetworkManager.conf
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> WEXT support is enabled
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> VPN: loaded org.freedesktop.NetworkManager.openvpn
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> VPN: loaded org.freedesktop.NetworkManager.pptp
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> VPN: loaded org.freedesktop.NetworkManager.vpnc
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> VPN: loaded org.freedesktop.NetworkManager.openconnect
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Loaded plugin ifcfg-suse: (C) 2008 Novell, Inc. To report bugs please use the NetworkManager mailing list.
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Loaded plugin keyfile: (c) 2007 - 2013 Red Hat, Inc. To report bugs please use the NetworkManager mailing list.
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> monitoring kernel firmware directory '/lib/firmware'.
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> WiFi hardware radio set enabled
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> WWAN hardware radio set enabled
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Loaded device plugin: /usr/lib64/NetworkManager/libnm-device-plugin-wifi.so
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Loaded device plugin: /usr/lib64/NetworkManager/libnm-device-plugin-adsl.so
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Loaded device plugin: /usr/lib64/NetworkManager/libnm-device-plugin-wwan.so
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Loaded device plugin: /usr/lib64/NetworkManager/libnm-device-plugin-bluetooth.so
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> WiFi enabled by radio killswitch; enabled by state file
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> WWAN enabled by radio killswitch; enabled by state file
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> WiMAX enabled by radio killswitch; enabled by state file
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Networking is enabled by state file
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (lo): link connected
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (lo): carrier is ON
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (lo): new Generic device (driver: 'unknown' ifindex: 1)
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (lo): exported as /org/freedesktop/NetworkManager/Devices/0
2 月 21 14:28:14 linux-50zl kernel: cfg80211: Calling CRDA to update world regulatory domain
2 月 21 14:28:14 linux-50zl kernel: cfg80211: World regulatory domain updated:
2 月 21 14:28:14 linux-50zl kernel: cfg80211: DFS Master region: unset
2 月 21 14:28:14 linux-50zl kernel: cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
2 月 21 14:28:14 linux-50zl kernel: cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
2 月 21 14:28:14 linux-50zl kernel: cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
2 月 21 14:28:14 linux-50zl kernel: cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
2 月 21 14:28:14 linux-50zl kernel: cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
2 月 21 14:28:14 linux-50zl kernel: cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
2 月 21 14:28:14 linux-50zl kernel: cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
2 月 21 14:28:14 linux-50zl kernel: cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
2 月 21 14:28:14 linux-50zl kernel: cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (enp4s0): carrier is OFF
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (enp4s0): new Ethernet device (driver: '8139too' ifindex: 2)
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (enp4s0): exported as /org/freedesktop/NetworkManager/Devices/1
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (enp4s0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (enp4s0): link connected
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (enp4s0): preparing device
2 月 21 14:28:14 linux-50zl kernel: 8139too 0000:04:00.0 enp4s0: link up, 100Mbps, full-duplex, lpa 0xC5E1
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (enp4s0): created default wired connection 'Wired connection 1'
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (eno1): carrier is OFF
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (eno1): new Ethernet device (driver: 'e1000e' ifindex: 3)
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (eno1): exported as /org/freedesktop/NetworkManager/Devices/2
2 月 21 14:28:14 linux-50zl kdm[1110]: plymouth is NOT running
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (eno1): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
2 月 21 14:28:14 linux-50zl iscsiadm[1153]: iscsiadm: No records found
2 月 21 14:28:14 linux-50zl echo[1157]: Starting mail service (Postfix)
2 月 21 14:28:14 linux-50zl ntpd[1171]: ntpd 4.2.6p5@1.2349-o Fri Dec 19 19:15:02 UTC 2014 (1)
2 月 21 14:28:14 linux-50zl start-ntpd[1154]: Starting network time protocol daemon (NTPD)
2 月 21 14:28:14 linux-50zl ntpd[1174]: proto: precision = 0.165 usec
2 月 21 14:28:14 linux-50zl ntpd[1174]: ntp_io: estimated max descriptors: 1024, initial socket boundary: 16
2 月 21 14:28:14 linux-50zl ntpd[1174]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
2 月 21 14:28:14 linux-50zl ntpd[1174]: Listen and drop on 1 v6wildcard :: UDP 123
2 月 21 14:28:14 linux-50zl SuSEfirewall2[1180]: Setting up rules from /etc/sysconfig/SuSEfirewall2 ...
2 月 21 14:28:14 linux-50zl SuSEfirewall2[1186]: using default zone 'ext' for interface eno1
2 月 21 14:28:14 linux-50zl SuSEfirewall2[1189]: using default zone 'ext' for interface enp4s0
2 月 21 14:28:14 linux-50zl kernel: e1000e 0000:00:19.0: irq 46 for MSI/MSI-X
2 月 21 14:28:14 linux-50zl ntpd[1174]: Listen normally on 2 lo 127.0.0.1 UDP 123
2 月 21 14:28:14 linux-50zl ntpd[1174]: peers refreshed
2 月 21 14:28:14 linux-50zl ntpd[1174]: Listening on routing socket on fd #19 for interface updates
2 月 21 14:28:14 linux-50zl kernel: IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (eno1): preparing device
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (eno1): created default wired connection 'Wired connection 2'
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (enp4s0): device state change: unavailable -> disconnected (reason 'none') [20 30 0]
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Auto-activating connection 'Wired connection 1'.
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) starting connection 'Wired connection 1'
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) Stage 1 of 5 (Device Prepare) scheduled...
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) Stage 1 of 5 (Device Prepare) started...
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (enp4s0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> NetworkManager state is now CONNECTING
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) Stage 2 of 5 (Device Configure) scheduled...
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) Stage 1 of 5 (Device Prepare) complete.
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) Stage 2 of 5 (Device Configure) starting...
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (enp4s0): device state change: prepare -> config (reason 'none') [40 50 0]
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) Stage 2 of 5 (Device Configure) successful.
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) Stage 3 of 5 (IP Configure Start) scheduled.
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) Stage 2 of 5 (Device Configure) complete.
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) Stage 3 of 5 (IP Configure Start) started...
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (enp4s0): device state change: config -> ip-config (reason 'none') [50 70 0]
2 月 21 14:28:14 linux-50zl SuSEfirewall2[1259]: Firewall rules successfully set
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) Beginning DHCPv4 transaction (timeout in 45 seconds)
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> dhclient started with pid 1289
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <warn> Unable to detect kernel support for extended IFA_FLAGS. Assume no kernel support.
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) Stage 3 of 5 (IP Configure Start) complete.
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> ModemManager available in the bus
2 月 21 14:28:14 linux-50zl dhclient[1289]: Internet Systems Consortium DHCP Client 4.2.6
2 月 21 14:28:14 linux-50zl dhclient[1289]: Copyright 2004-2014 Internet Systems Consortium.
2 月 21 14:28:14 linux-50zl dhclient[1289]: All rights reserved.
2 月 21 14:28:14 linux-50zl dhclient[1289]: For info, please visit https://www.isc.org/software/dhcp/
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: Internet Systems Consortium DHCP Client 4.2.6
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: Copyright 2004-2014 Internet Systems Consortium.
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: All rights reserved.
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: For info, please visit https://www.isc.org/software/dhcp/
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: <info> (enp4s0): DHCPv4 state changed nbi -> preinit
2 月 21 14:28:14 linux-50zl kernel: NET: Registered protocol family 17
2 月 21 14:28:14 linux-50zl dhclient[1289]: Listening on LPF/enp4s0/00:e0:09:06:2e:0c
2 月 21 14:28:14 linux-50zl dhclient[1289]: Sending on LPF/enp4s0/00:e0:09:06:2e:0c
2 月 21 14:28:14 linux-50zl dhclient[1289]: Sending on Socket/fallback
2 月 21 14:28:14 linux-50zl dhclient[1289]: DHCPDISCOVER on enp4s0 to 255.255.255.255 port 67 interval 4 (xid=0x79f44e19)
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: Listening on LPF/enp4s0/00:e0:09:06:2e:0c
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: Sending on LPF/enp4s0/00:e0:09:06:2e:0c
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: Sending on Socket/fallback
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: DHCPDISCOVER on enp4s0 to 255.255.255.255 port 67 interval 4 (xid=0x79f44e19)
2 月 21 14:28:14 linux-50zl postfix/postfix-script[1330]: starting the Postfix mail system
2 月 21 14:28:14 linux-50zl postfix/master[1332]: daemon started -- version 2.11.3, configuration /etc/postfix
2 月 21 14:28:14 linux-50zl cron[1349]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 30% if used.)
2 月 21 14:28:14 linux-50zl cron[1349]: (CRON) INFO (running with inotify support)
2 月 21 14:28:14 linux-50zl kernel: IPv4: martian source 255.255.255.255 from 192.168.3.1, on dev enp4s0
2 月 21 14:28:14 linux-50zl kernel: ll header: 00000000: 00 e0 09 06 2e 0c 88 e3 ab 32 42 63 08 00 .........2Bc..
2 月 21 14:28:14 linux-50zl dhclient[1289]: DHCPOFFER from 192.168.3.1
2 月 21 14:28:14 linux-50zl NetworkManager[1140]: DHCPOFFER from 192.168.3.1
2 月 21 14:28:14 linux-50zl kdm_greet[1357]: Cannot load /usr/share/kde4/apps/kdm/faces/.default.face: 没有那个文件或目录
2 月 21 14:28:16 linux-50zl avahi-daemon[1023]: Joining mDNS multicast group on interface enp4s0.IPv6 with address fe80::2e0:9ff:fe06:2e0c.
2 月 21 14:28:16 linux-50zl avahi-daemon[1023]: New relevant interface enp4s0.IPv6 for mDNS.
2 月 21 14:28:16 linux-50zl avahi-daemon[1023]: Registering new address record for fe80::2e0:9ff:fe06:2e0c on enp4s0.*.
2 月 21 14:28:16 linux-50zl kernel: SFW2-INext-DROP-DEFLT IN=enp4s0 OUT= MAC= SRC=fe80:0000:0000:0000:02e0:09ff:fe06:2e0c DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=430 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=5353 DPT=5353 LEN=390
2 月 21 14:28:16 linux-50zl kernel: SFW2-INext-DROP-DEFLT IN=enp4s0 OUT= MAC= SRC=fe80:0000:0000:0000:02e0:09ff:fe06:2e0c DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=258 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=5353 DPT=5353 LEN=218
2 月 21 14:28:16 linux-50zl ModemManager[1025]: <warn> Couldn't find support for device at '/sys/devices/pci0000:00/0000:00:19.0': not supported by any plugin
2 月 21 14:28:16 linux-50zl ModemManager[1025]: <warn> Couldn't find support for device at '/sys/devices/pci0000:00/0000:00:1c.3/0000:03:00.0/0000:04:00.0': not supported by any plugin
2 月 21 14:28:17 linux-50zl kernel: SFW2-INext-DROP-DEFLT IN=enp4s0 OUT= MAC= SRC=fe80:0000:0000:0000:02e0:09ff:fe06:2e0c DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=400 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=5353 DPT=5353 LEN=360
2 月 21 14:28:19 linux-50zl dhclient[1289]: DHCPREQUEST on enp4s0 to 255.255.255.255 port 67 (xid=0x79f44e19)
2 月 21 14:28:19 linux-50zl dhclient[1289]: DHCPACK from 192.168.3.1 (xid=0x79f44e19)
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> (enp4s0): DHCPv4 state changed preinit -> bound
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> address 192.168.3.5
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> plen 24 (255.255.255.0)
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> gateway 192.168.3.1
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> server identifier 192.168.3.1
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> lease time 86400
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> nameserver '180.76.76.76'
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> nameserver '114.114.114.114'
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> domain name 'home'
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) Stage 5 of 5 (IPv4 Commit) started...
2 月 21 14:28:19 linux-50zl dhclient[1289]: bound to 192.168.3.5 -- renewal in 37413 seconds.
2 月 21 14:28:19 linux-50zl avahi-daemon[1023]: Joining mDNS multicast group on interface enp4s0.IPv4 with address 192.168.3.5.
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> (enp4s0): device state change: ip-config -> ip-check (reason 'none') [70 80 0]
2 月 21 14:28:19 linux-50zl avahi-daemon[1023]: New relevant interface enp4s0.IPv4 for mDNS.
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) Stage 5 of 5 (IPv4 Commit) complete.
2 月 21 14:28:19 linux-50zl avahi-daemon[1023]: Registering new address record for 192.168.3.5 on enp4s0.IPv4.
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> (enp4s0): device state change: ip-check -> secondaries (reason 'none') [80 90 0]
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> (enp4s0): device state change: secondaries -> activated (reason 'none') [90 100 0]
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> NetworkManager state is now CONNECTED_LOCAL
2 月 21 14:28:19 linux-50zl kernel: IPv4: martian source 255.255.255.255 from 192.168.3.1, on dev enp4s0
2 月 21 14:28:19 linux-50zl kernel: ll header: 00000000: 00 e0 09 06 2e 0c 88 e3 ab 32 42 63 08 00 .........2Bc..
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: DHCPREQUEST on enp4s0 to 255.255.255.255 port 67 (xid=0x79f44e19)
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: DHCPACK from 192.168.3.1 (xid=0x79f44e19)
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: bound to 192.168.3.5 -- renewal in 37413 seconds.
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> NetworkManager state is now CONNECTED_GLOBAL
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> Policy set 'Wired connection 1' (enp4s0) as default for IPv4 routing and DNS.
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> Activation (enp4s0) successful, device activated.
2 月 21 14:28:19 linux-50zl dbus[1031]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
2 月 21 14:28:19 linux-50zl dbus[1031]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
2 月 21 14:28:19 linux-50zl nm-dispatcher[1379]: Dispatching action 'up' for enp4s0
2 月 21 14:28:19 linux-50zl NetworkManager[1140]: <info> startup complete
2 月 21 14:28:30 linux-50zl ModemManager[1025]: <info> Creating modem with plugin 'Generic' and '1' ports
2 月 21 14:28:30 linux-50zl ModemManager[1025]: <warn> Could not grab port (tty/ttyS4): 'Cannot add port 'tty/ttyS4', unhandled serial type'
2 月 21 14:28:30 linux-50zl ModemManager[1025]: <warn> Couldn't create modem for device at '/sys/devices/pci0000:00/0000:00:16.3': Failed to find primary AT port
2 月 21 14:28:36 linux-50zl kdm[1356]: :0[1356]: pam_unix(xdm:session): session opened for user B6l by (uid=0)
2 月 21 14:28:36 linux-50zl systemd[1491]: pam_unix(systemd-user:session): session opened for user B6l by (uid=0)
2 月 21 14:28:37 linux-50zl dbus[1031]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service'
2 月 21 14:28:37 linux-50zl dbus[1031]: [system] Successfully activated service 'org.freedesktop.UPower'
2 月 21 14:28:39 linux-50zl dbus[1031]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
2 月 21 14:28:39 linux-50zl udisksd[1700]: udisks daemon version 2.1.3 starting
2 月 21 14:28:39 linux-50zl dbus[1031]: [system] Successfully activated service 'org.freedesktop.UDisks2'
2 月 21 14:28:39 linux-50zl udisksd[1700]: Acquired the name org.freedesktop.UDisks2 on the system message bus
2 月 21 14:28:40 linux-50zl dbus[1031]: [system] Activating service name='org.kde.powerdevil.backlighthelper' (using servicehelper)
2 月 21 14:28:40 linux-50zl org.kde.powerdevil.backlighthelper[1031]: no kernel backlight interface found
2 月 21 14:28:40 linux-50zl dbus[1031]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
2 月 21 14:28:40 linux-50zl kernel: SFW2-INext-DROP-DEFLT IN=enp4s0 OUT= MAC= SRC=fe80:0000:0000:0000:02e0:09ff:fe06:2e0c DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=84 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=5353 DPT=5353 LEN=44
2 月 21 14:28:41 linux-50zl dbus[1031]: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service'
2 月 21 14:28:41 linux-50zl PackageKit[1730]: daemon start
2 月 21 14:28:41 linux-50zl dbus[1031]: [system] Successfully activated service 'org.freedesktop.PackageKit'
2 月 21 14:28:42 linux-50zl dbus[1031]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service'
2 月 21 14:28:42 linux-50zl bluetoothd[1737]: Bluetooth daemon 5.23
2 月 21 14:28:42 linux-50zl dbus[1031]: [system] Successfully activated service 'org.bluez'
2 月 21 14:28:42 linux-50zl bluetoothd[1737]: Starting SDP server
2 月 21 14:28:42 linux-50zl kernel: Bluetooth: Core ver 2.19
2 月 21 14:28:42 linux-50zl kernel: NET: Registered protocol family 31
2 月 21 14:28:42 linux-50zl kernel: Bluetooth: HCI device and connection manager initialized
2 月 21 14:28:42 linux-50zl kernel: Bluetooth: HCI socket layer initialized
2 月 21 14:28:42 linux-50zl kernel: Bluetooth: L2CAP socket layer initialized
2 月 21 14:28:42 linux-50zl kernel: Bluetooth: SCO socket layer initialized
2 月 21 14:28:42 linux-50zl kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
2 月 21 14:28:42 linux-50zl kernel: Bluetooth: BNEP filters: protocol multicast
2 月 21 14:28:42 linux-50zl kernel: Bluetooth: BNEP socket layer initialized
2 月 21 14:28:42 linux-50zl dbus[1031]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
2 月 21 14:28:42 linux-50zl bluetoothd[1737]: Bluetooth management interface 1.6 initialized
2 月 21 14:28:42 linux-50zl NetworkManager[1140]: <info> use BlueZ version 5
2 月 21 14:28:42 linux-50zl dbus[1031]: [system] Successfully activated service 'org.freedesktop.hostname1'
2 月 21 14:28:43 linux-50zl kernel: fuse init (API version 7.23)
2 月 21 14:28:43 linux-50zl dbus[1031]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service'
2 月 21 14:28:43 linux-50zl dbus[1031]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
2 月 21 14:28:43 linux-50zl rtkit-daemon[1835]: Successfully called chroot.
2 月 21 14:28:43 linux-50zl rtkit-daemon[1835]: Successfully dropped privileges.
2 月 21 14:28:43 linux-50zl rtkit-daemon[1835]: Successfully limited resources.
2 月 21 14:28:43 linux-50zl rtkit-daemon[1835]: Running.
2 月 21 14:28:43 linux-50zl rtkit-daemon[1835]: Watchdog thread running.
2 月 21 14:28:43 linux-50zl rtkit-daemon[1835]: Canary thread running.
2 月 21 14:28:43 linux-50zl rtkit-daemon[1835]: Successfully made thread 1831 of process 1831 (/usr/bin/pulseaudio) owned by 'B6l' high priority at nice level -11.
2 月 21 14:28:43 linux-50zl rtkit-daemon[1835]: Supervising 1 threads of 1 processes of 1 users.
2 月 21 14:28:43 linux-50zl org.gnome.OnlineAccounts[1553]: goa-daemon-Message: goa-daemon version 3.14.2 starting
2 月 21 14:28:43 linux-50zl polkitd[1051]: Registered Authentication Agent for unix-session:1 (system bus name :1.30 [/usr/lib64/kde4/libexec/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale zh_CN.UTF-8)
2 月 21 14:28:43 linux-50zl org.gtk.Private.AfcVolumeMonitor[1553]: Volume monitor alive
2 月 21 14:28:43 linux-50zl hp-upgrade[1920]: hp-upgrade[1920]: error: HPLIP upgrade is disabled by openSUSE for security reasons, see https://bugzilla.novell.com/show_bug.cgi?id=853405 - if you like to upgrade HPLIP, use an openSUSE software package manager like YaST or zypper.
2 月 21 14:28:44 linux-50zl rtkit-daemon[1835]: Supervising 1 threads of 1 processes of 1 users.
2 月 21 14:28:44 linux-50zl rtkit-daemon[1835]: Successfully made thread 1933 of process 1831 (/usr/bin/pulseaudio) owned by 'B6l' RT at priority 5.
2 月 21 14:28:44 linux-50zl rtkit-daemon[1835]: Supervising 2 threads of 1 processes of 1 users.
2 月 21 14:28:44 linux-50zl rtkit-daemon[1835]: Successfully made thread 1936 of process 1831 (/usr/bin/pulseaudio) owned by 'B6l' RT at priority 5.
2 月 21 14:28:44 linux-50zl rtkit-daemon[1835]: Supervising 3 threads of 1 processes of 1 users.
2 月 21 14:28:44 linux-50zl rtkit-daemon[1835]: Successfully made thread 1937 of process 1831 (/usr/bin/pulseaudio) owned by 'B6l' RT at priority 5.
2 月 21 14:28:44 linux-50zl rtkit-daemon[1835]: Supervising 4 threads of 1 processes of 1 users.
2 月 21 14:28:44 linux-50zl rtkit-daemon[1835]: Successfully made thread 1948 of process 1948 (/usr/bin/pulseaudio) owned by 'B6l' high priority at nice level -11.
2 月 21 14:28:44 linux-50zl rtkit-daemon[1835]: Supervising 5 threads of 2 processes of 1 users.
2 月 21 14:28:44 linux-50zl rtkit-daemon[1835]: Successfully made thread 1954 of process 1954 (/usr/bin/pulseaudio) owned by 'B6l' high priority at nice level -11.
2 月 21 14:28:44 linux-50zl pulseaudio[1954]: [pulseaudio] pid.c: Daemon already running.
2 月 21 14:28:44 linux-50zl rtkit-daemon[1835]: Successfully made thread 1957 of process 1957 (/usr/bin/pulseaudio) owned by 'B6l' high priority at nice level -11.
2 月 21 14:28:44 linux-50zl pulseaudio[1957]: [pulseaudio] pid.c: Daemon already running.
2 月 21 14:29:11 linux-50zl kernel: SFW2-INext-DROP-DEFLT IN=enp4s0 OUT= MAC= SRC=fe80:0000:0000:0000:02e0:09ff:fe06:2e0c DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=84 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=5353 DPT=5353 LEN=44
2 月 21 14:29:26 linux-50zl su[2222]: (to root) B6l on pts/2
2 月 21 14:29:26 linux-50zl su[2222]: pam_unix(su:session): session opened for user root by B6l(uid=1000)
2 月 21 14:29:28 linux-50zl sudo[2259]: root : TTY=pts/2 ; PWD=/home/B6l ; USER=root ; COMMAND=/usr/bin/journalctl
2 月 21 14:29:28 linux-50zl sudo[2259]: pam_unix(sudo:session): session opened for user root by B6l(uid=0)
这个问题我也遇到,无论怎么弄都无法关机。现在没办法只能 su----》halt----》关机时卡住然后长按电源键实现不再重启的关机。
我也遇到过,我一般是切换到 tty1,root 登入然后 shutdown -hP now 关机 shutdown -r now 重启。命令行是每次都好使的,所以应该是 KDE 那个关机按钮的 bug。
额。。。我试了貌似无法关机
看了官方社区的这个帖子
forums.opensuse.org/showthread.php/493563-openSUSE-13-1-does-not-shut-down-reboot
我是技嘉主板,关掉 Lan Boot 貌似问题就解决了~
