[ 已解决 ] 我的 opensuse12.3 有线总是隔一段时间会断网, 需要重新连接才有用
大家好, 我是 opensuse12.3 用户, 系统一直到现在使用有线上网时会断, 需要重新连接, 无线不会出现这种现象, 不知道是不是网卡驱动有问题, 希望朋友们能帮个忙, 谢谢了!!! 另外,opensuse 的论坛不是很活跃, 贴吧也是, 希望本论坛能越做越好!!!
请阅读置顶帖说明网卡型号。
请给出你有线断网那个时间点上的日志,在 /var/log/NetworkManager (root 权限打开) 里,里面有显示时间,找到断网那个时间附近的日志贴上来,用 code 代码块。
2013-05-23T19:42:34.227139+08:00 linux-vs1h NetworkManager[565]: <info> Activation (eth0) Beginning DHCPv4 transaction (timeout in 45 seconds)
2013-05-23T19:42:34.227357+08:00 linux-vs1h NetworkManager[565]: <info> dhclient started with pid 1361
2013-05-23T19:42:34.227568+08:00 linux-vs1h NetworkManager[565]: <info> Activation (eth0) Stage 3 of 5 (IP Configure Start) complete.
2013-05-23T19:42:34.237571+08:00 linux-vs1h NetworkManager[565]: <info> (eth0): DHCPv4 state changed nbi -> preinit
2013-05-23T19:42:39.741191+08:00 linux-vs1h NetworkManager[565]: <info> (eth0): DHCPv4 state changed preinit -> bound
2013-05-23T19:42:39.741427+08:00 linux-vs1h NetworkManager[565]: <info>   address 192.168.2.101
2013-05-23T19:42:39.741645+08:00 linux-vs1h NetworkManager[565]: <info>   prefix 24 (255.255.255.0)
2013-05-23T19:42:39.741878+08:00 linux-vs1h NetworkManager[565]: <info>   gateway 192.168.2.1
2013-05-23T19:42:39.742091+08:00 linux-vs1h NetworkManager[565]: <info>   nameserver '202.101.224.69'
2013-05-23T19:42:39.742334+08:00 linux-vs1h NetworkManager[565]: <info>   nameserver '202.101.226.69'
2013-05-23T19:42:39.742548+08:00 linux-vs1h NetworkManager[565]: <info>   domain name 'domain'
2013-05-23T19:42:39.742776+08:00 linux-vs1h NetworkManager[565]: <info> Activation (eth0) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
2013-05-23T19:42:39.742997+08:00 linux-vs1h NetworkManager[565]: <info> Activation (eth0) Stage 5 of 5 (IPv4 Commit) started...
2013-05-23T19:42:40.744411+08:00 linux-vs1h NetworkManager[565]: <info> (eth0): device state change: ip-config -> activated (reason 'none') [70 100 0]
2013-05-23T19:42:40.823353+08:00 linux-vs1h NetworkManager[565]: <info> Clearing nscd hosts cache.
2013-05-23T19:42:40.829267+08:00 linux-vs1h NetworkManager[565]: <info> Policy set 'New Wired Connection' (eth0) as default for IPv4 routing and DNS.
2013-05-23T19:42:40.830095+08:00 linux-vs1h NetworkManager[565]: <info> Activation (eth0) successful, device activated.
2013-05-23T19:42:40.830467+08:00 linux-vs1h NetworkManager[565]: <info> Activation (eth0) Stage 5 of 5 (IPv4 Commit) complete.
2013-05-23T19:42:40.870195+08:00 linux-vs1h nm-dispatcher.action: Script '/etc/NetworkManager/dispatcher.d/nfs' exited with error status 2.
                                                              2274,1
错误位置不对,你这信息告诉我的是你在联网,但是你断网是怎么断没有,还在前面。
谢谢 marguerite ,我之后看了下错误信息,好像是因为无线网卡与有线有冲突,用有线的时候禁用无线就不会断网了。因为我这的网速好慢,一直都打开不了网站了,呵呵,再次谢谢 marguerite 了
不客气。问题标记为已解决
