如题,我一直没装 alsa 相应的 32 bit 的包,导致 skype 的音频输出没什么问题,但就是输入有问题。
在 “make a call test” 的时候,总是提示 “输入设备有问题”。
突然想起来 skype 在 openSUSE 的包是 32 bit, 于是昨天把 alsa 相应的 32 bit 的包装上了,在 skype 的音频设置了,就可以选择 “PulseAudio server (local)" 了,再进行 “make a call test” ,好了,可以输入了,但是感觉还是有些杂音!
反正是可以使用了,所以记得安装 32 bit 的包。
i | alsa | Advanced Linux Sound Architecture | package
| alsa-devel | Include Files and Libraries mandatory for Development | package
| alsa-devel-32bit | Include Files and Libraries mandatory for Development | package
| alsa-docs | Additional Package Documentation | package
i | alsa-firmware | Firmware Data Files for ALSA | package
i | alsa-oss | ALSA-OSS Wrapper | package
i | alsa-oss-32bit | ALSA-OSS Wrapper | package
i | alsa-plugins | Extra Plug-Ins for the ALSA Library | package
i | alsa-plugins-32bit | Extra Plug-Ins for the ALSA Library | package
| alsa-plugins-dca | DTS Encoding Library | package
| alsa-plugins-dca-debuginfo | Debug information for package alsa-plugins-dca | package
| alsa-plugins-jack | JACK I/O Plug-In for the ALSA Library | package
| alsa-plugins-jack-32bit | JACK I/O Plug-In for the ALSA Library | package
| alsa-plugins-maemo | Maemo Plug-Ins for the ALSA Library | package
| alsa-plugins-maemo-32bit | Maemo Plug-Ins for the ALSA Library | package
i | alsa-plugins-pulse | Pulseaudio Plug-In for the ALSA Library | package
i | alsa-plugins-pulse-32bit | Pulseaudio Plug-In for the ALSA Library | package
