苏姐 小子受教了
照片真没必要发。屏幕全黑,只有鼠标指针,指针可以随意移动,移到屏幕左上角会有一点绿色的悬停特效,除此之外什么也没有。不过我还是把照片的截图贴上来了。
我的本确实是双显卡 intel+NVIDIA optimus技术
以下是kdm.log
X.Org X Server 1.14.3
Release Date: 2013-09-12
X Protocol Version 11, Revision 0
Build Operating System: openSUSE SUSE LINUX
Current Operating System: Linux KamiCom 3.11.6-3-desktop #1 SMP PREEMPT Thu Oct 24 16:23:02 UTC 2013 (0ba01b7) x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.11.6-3-desktop root=UUID=0028e7e2-357c-49a5-b1ce-b56387891839 resume=/dev/disk/by-uuid/167efd8e-2ea2-4f1b-b5de-e3dfca2fec81 splash=silent quiet showopts
Build Date: 18 October 2013 06:58:38AM
Current version of pixman: 0.30.2
Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 6 01:29:24 2013
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Initializing built-in extension Generic Event Extension
Initializing built-in extension SHAPE
Initializing built-in extension MIT-SHM
Initializing built-in extension XInputExtension
Initializing built-in extension XTEST
Initializing built-in extension BIG-REQUESTS
Initializing built-in extension SYNC
Initializing built-in extension XKEYBOARD
Initializing built-in extension XC-MISC
Initializing built-in extension SECURITY
Initializing built-in extension XINERAMA
Initializing built-in extension XFIXES
Initializing built-in extension RENDER
Initializing built-in extension RANDR
Initializing built-in extension COMPOSITE
Initializing built-in extension DAMAGE
Initializing built-in extension MIT-SCREEN-SAVER
Initializing built-in extension DOUBLE-BUFFER
Initializing built-in extension RECORD
Initializing built-in extension DPMS
Initializing built-in extension X-Resource
Initializing built-in extension XVideo
Initializing built-in extension XVideo-MotionCompensation
Initializing built-in extension XFree86-VidModeExtension
Initializing built-in extension XFree86-DGA
Initializing built-in extension XFree86-DRI
Initializing built-in extension DRI2
Loading extension GLX
klauncher(1062) kdemain: No DBUS session-bus found. Check if you have started the DBUS server.
kdeinit4: Communication error with launcher. Exiting!
kdmgreet(1055)/kdecore (K*TimeZone*): KSystemTimeZones: ktimezoned initialize() D-Bus call failed: "Not connected to D-Bus server"
kdmgreet(1055)/kdecore (K*TimeZone*): No time zone information obtained from ktimezoned
(II) AIGLX: Suspending AIGLX clients for VT switch
(EE) Server terminated successfully (0). Closing log file.
以下是Xorg.0.log
10.101]
10.101] X Protocol Version 11, Revision 0
10.101] Build Operating System: openSUSE SUSE LINUX
10.101] Current Operating System: Linux KamiCom 3.11.6-3-desktop #1 SMP PREEMPT Thu Oct 24 16:23:02 UTC 2013 (0ba01b7) x86_64
10.101] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.11.6-3-desktop root=UUID=0028e7e2-357c-49a5-b1ce-b56387891839 resume=/dev/disk/by-uuid/167efd8e-2ea2-4f1b-b5de-e3dfca2fec81 splash=silent quiet showopts
10.101] Build Date: 18 October 2013 06:58:38AM
10.101]
10.101] Current version of pixman: 0.30.2
10.101] Before reporting problems, check http://wiki.x.org
10.101] Markers: (--) probed, (**) from config file, (==) default setting,
10.101] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 6 01:29:24 2013
10.103] (==) Using config directory: "/etc/X11/xorg.conf.d"
10.103] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
10.104] (==) No Layout section. Using the first Screen section.
10.104] (==) No screen section available. Using defaults.
10.104] (**) |-->Screen "Default Screen Section" (0)
10.104] (**) | |-->Monitor "<default monitor>"
10.104] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
10.104] (==) Automatically adding devices
10.104] (==) Automatically enabling devices
10.104] (==) Automatically adding GPU devices
10.108] (WW) The directory "/usr/share/fonts/misc/sgi" does not exist.
10.108] Entry deleted from font path.
10.108] (==) FontPath set to:
/usr/share/fonts/Type1/,
/usr/share/fonts/truetype/,
built-ins
10.108] (==) ModulePath set to "/usr/lib64/xorg/modules/updates,/usr/lib64/xorg/modules"
10.108] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
10.108] (II) Loader magic: 0x802c20
10.108] (II) Module ABI versions:
10.108] X.Org ANSI C Emulation: 0.4
10.108] X.Org Video Driver: 14.1
10.109] X.Org XInput driver : 19.1
10.109] X.Org Server Extension : 7.0
10.109] (II) xfree86: Adding drm device (/dev/dri/card1)
10.109] (II) xfree86: Adding drm device (/dev/dri/card0)
10.110] (--) PCI:*(0:0:2:0) 8086:0116:1043:2051 rev 9, Mem @ 0xdc400000/4194304, 0xb0000000/268435456, I/O @ 0x0000e000/64
10.110] (--) PCI: (0:1:0:0) 10de:1247:1043:2051 rev 161, Mem @ 0xda000000/33554432, 0xc0000000/268435456, 0xd0000000/67108864, I/O @ 0x0000d000/128, BIOS @ 0x????????/524288
10.110] Initializing built-in extension Generic Event Extension
10.110] Initializing built-in extension SHAPE
10.110] Initializing built-in extension MIT-SHM
10.110] Initializing built-in extension XInputExtension
10.110] Initializing built-in extension XTEST
10.110] Initializing built-in extension BIG-REQUESTS
10.110] Initializing built-in extension SYNC
10.110] Initializing built-in extension XKEYBOARD
10.110] Initializing built-in extension XC-MISC
10.110] Initializing built-in extension SECURITY
10.110] Initializing built-in extension XINERAMA
10.110] Initializing built-in extension XFIXES
10.110] Initializing built-in extension RENDER
10.110] Initializing built-in extension RANDR
10.110] Initializing built-in extension COMPOSITE
10.110] Initializing built-in extension DAMAGE
10.110] Initializing built-in extension MIT-SCREEN-SAVER
10.110] Initializing built-in extension DOUBLE-BUFFER
10.110] Initializing built-in extension RECORD
10.110] Initializing built-in extension DPMS
10.110] Initializing built-in extension X-Resource
10.110] Initializing built-in extension XVideo
10.110] Initializing built-in extension XVideo-MotionCompensation
10.110] Initializing built-in extension XFree86-VidModeExtension
10.110] Initializing built-in extension XFree86-DGA
10.110] Initializing built-in extension XFree86-DRI
10.110] Initializing built-in extension DRI2
10.110] (II) "glx" will be loaded by default.
10.110] (II) LoadModule: "dri2"
10.110] (II) Module "dri2" already built-in
10.110] (II) LoadModule: "glamoregl"
10.114] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
10.136] (II) Module glamoregl: vendor="X.Org Foundation"
10.136] compiled for 1.14.3, module version = 0.5.1
10.136] ABI class: X.Org ANSI C Emulation, version 0.4
10.136] (II) LoadModule: "glx"
10.136] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
10.138] (II) Module glx: vendor="X.Org Foundation"
10.138] compiled for 1.14.3, module version = 1.0.0
10.138] ABI class: X.Org Server Extension, version 7.0
10.138] (==) AIGLX enabled
10.138] Loading extension GLX
10.138] (==) Matched intel as autoconfigured driver 0
10.138] (==) Matched nvidia as autoconfigured driver 1
10.138] (==) Matched nouveau as autoconfigured driver 2
10.138] (==) Matched nv as autoconfigured driver 3
10.138] (==) Matched intel as autoconfigured driver 4
10.138] (==) Matched modesetting as autoconfigured driver 5
10.138] (==) Matched fbdev as autoconfigured driver 6
10.138] (==) Matched vesa as autoconfigured driver 7
10.138] (==) Assigned the driver to the xf86ConfigLayout
10.138] (II) LoadModule: "intel"
10.138] (II) Loading /usr/lib64/xorg/modules/drivers/intel_drv.so
10.144] (II) Module intel: vendor="X.Org Foundation"
10.144] compiled for 1.14.3, module version = 2.99.905
10.144] Module class: X.Org Video Driver
10.144] ABI class: X.Org Video Driver, version 14.1
10.144] (II) LoadModule: "nvidia"
10.145] (WW) Warning, couldn't open module nvidia
10.145] (II) UnloadModule: "nvidia"
10.145] (II) Unloading nvidia
10.145] (EE) Failed to load module "nvidia" (module does not exist, 0)
10.145] (II) LoadModule: "nouveau"
10.145] (II) Loading /usr/lib64/xorg/modules/drivers/nouveau_drv.so
10.148] (II) Module nouveau: vendor="X.Org Foundation"
10.148] compiled for 1.14.3, module version = 1.0.9
10.148] Module class: X.Org Video Driver
10.149] ABI class: X.Org Video Driver, version 14.1
10.149] (II) LoadModule: "nv"
10.149] (II) Loading /usr/lib64/xorg/modules/drivers/nv_drv.so
10.152] (II) Module nv: vendor="X.Org Foundation"
10.152] compiled for 1.14.3, module version = 2.1.20
10.152] Module class: X.Org Video Driver
10.152] ABI class: X.Org Video Driver, version 14.1
10.152] (II) LoadModule: "modesetting"
10.152] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
10.152] (II) Module modesetting: vendor="X.Org Foundation"
10.153] compiled for 1.14.3, module version = 0.8.0
10.153] Module class: X.Org Video Driver
10.153] ABI class: X.Org Video Driver, version 14.1
10.153] (II) LoadModule: "fbdev"
10.153] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
10.153] (II) Module fbdev: vendor="X.Org Foundation"
10.153] compiled for 1.14.3, module version = 0.4.3
10.153] (II) LoadModule: "vesa"
10.153] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
10.154] (II) Module vesa: vendor="X.Org Foundation"
10.154] compiled for 1.14.3, module version = 2.3.3
10.154] Module class: X.Org Video Driver
10.154] ABI class: X.Org Video Driver, version 14.1
10.154] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43, HD Graphics,
HD Graphics 2000, HD Graphics 3000, HD Graphics 2500,
HD Graphics 4000, HD Graphics P4000, HD Graphics 4600,
HD Graphics 5000, HD Graphics P4600/P4700, Iris(TM) Graphics 5100,
HD Graphics 4400, HD Graphics 4200, Iris(TM) Pro Graphics 5200
10.154] (II) NOUVEAU driver
10.154] (II) NOUVEAU driver for NVIDIA chipset families :
10.154] RIVA TNT (NV04)
10.154] RIVA TNT2 (NV05)
10.154] GeForce 256 (NV10)
10.154] GeForce 2 (NV11, NV15)
10.154] GeForce 4MX (NV17, NV18)
10.154] GeForce 3 (NV20)
10.154] GeForce 4Ti (NV25, NV28)
10.154] GeForce FX (NV3x)
10.154] GeForce 6 (NV4x)
10.154] GeForce 7 (G7x)
10.154] GeForce 8 (G8x)
10.154] GeForce GTX 200 (NVA0)
10.154] GeForce GTX 400 (NVC0)
10.155] GeForce GTX 400 (NVC0)
10.155] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
10.155] (II) FBDEV: driver for framebuffer: fbdev
10.155] (II) VESA: driver for VESA chipsets: vesa
10.155] (++) using VT number 7
10.155] (II) [drm] nouveau interface version: 1.1.1
10.155] (WW) Falling back to old probe method for modesetting
10.155] (WW) Falling back to old probe method for fbdev
10.155] (II) Loading sub module "fbdevhw"
10.155] (II) LoadModule: "fbdevhw"
10.155] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
10.156] (II) Module fbdevhw: vendor="X.Org Foundation"
10.156] compiled for 1.14.3, module version = 0.0.2
10.156] ABI class: X.Org Video Driver, version 14.1
10.156] (WW) Falling back to old probe method for vesa
10.156] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
10.156] (==) intel(0): Depth 24, (--) framebuffer bpp 32
10.156] (==) intel(0): RGB weight 888
10.156] (==) intel(0): Default visual is TrueColor
10.156] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 3000
10.156] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx
10.156] (**) intel(0): Framebuffer tiled
10.156] (**) intel(0): Pixmaps tiled
10.156] (**) intel(0): "Tear free" disabled
10.156] (**) intel(0): Forcing per-crtc-pixmaps? no
10.156] (II) intel(0): Output LVDS1 has no monitor section
10.156] (--) intel(0): found backlight control interface acpi_video1 (type 'firmware')
10.156] (II) intel(0): Output VGA1 has no monitor section
10.156] (II) intel(0): Output VIRTUAL1 has no monitor section
10.156] (--) intel(0): Output LVDS1 using initial mode 1920x1080 on pipe 0
10.156] (==) intel(0): DPI set to (96, 96)
10.156] (II) Loading sub module "dri2"
10.156] (II) LoadModule: "dri2"
10.156] (II) Module "dri2" already built-in
10.157] (--) NOUVEAU(G0): Chipset: "NVIDIA NVCF"
10.157] (==) NOUVEAU(G0): Depth 24, (--) framebuffer bpp 32
10.157] (==) NOUVEAU(G0): RGB weight 888
10.157] (==) NOUVEAU(G0): Default visual is TrueColor
10.157] (==) NOUVEAU(G0): Using HW cursor
10.157] (==) NOUVEAU(G0): GLX sync to VBlank disabled.
10.157] (==) NOUVEAU(G0): Page flipping enabled
10.157] (==) NOUVEAU(G0): Swap limit set to 2 [Max allowed 2]
10.162] (II) NOUVEAU(G0): Output HDMI-1-1 has no monitor section
10.164] (II) NOUVEAU(G0): EDID for output HDMI-1-1
10.164] (II) NOUVEAU(G0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
10.164] (--) NOUVEAU(G0): Virtual size is 1024x768 (pitch 0)
10.164] (**) NOUVEAU(G0): Mode "1920x1080": 173.0 MHz (scaled from 0.0 MHz), 67.2 kHz, 60.0 Hz
10.164] (II) NOUVEAU(G0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz)
10.164] (==) NOUVEAU(G0): DPI set to (96, 96)
10.164] (II) Loading sub module "fb"
10.164] (II) LoadModule: "fb"
10.165] (II) Loading /usr/lib64/xorg/modules/libfb.so
10.166] (II) Module fb: vendor="X.Org Foundation"
10.166] compiled for 1.14.3, module version = 1.0.0
10.166] ABI class: X.Org ANSI C Emulation, version 0.4
10.166] (II) Loading sub module "exa"
10.166] (II) LoadModule: "exa"
10.166] (II) Loading /usr/lib64/xorg/modules/libexa.so
10.166] (II) Module exa: vendor="X.Org Foundation"
10.166] compiled for 1.14.3, module version = 2.6.0
10.166] ABI class: X.Org Video Driver, version 14.1
10.166] (II) Loading sub module "shadowfb"
10.166] (II) LoadModule: "shadowfb"
10.167] (II) Loading /usr/lib64/xorg/modules/libshadowfb.so
10.167] (II) Module shadowfb: vendor="X.Org Foundation"
10.167] compiled for 1.14.3, module version = 1.0.0
10.167] ABI class: X.Org ANSI C Emulation, version 0.4
10.167] (II) UnloadModule: "nv"
10.167] (II) Unloading nv
10.167] (II) UnloadModule: "modesetting"
10.167] (II) Unloading modesetting
10.167] (II) UnloadModule: "fbdev"
10.167] (II) Unloading fbdev
10.167] (II) UnloadSubModule: "fbdevhw"
10.167] (II) Unloading fbdevhw
10.167] (II) UnloadModule: "vesa"
10.167] (II) Unloading vesa
10.167] (==) Depth 24 pixmap format is 32 bpp
10.169] (II) NOUVEAU(G0): Opened GPU channel 0
10.172] (II) NOUVEAU(G0): [DRI2] Setup complete
10.172] (II) NOUVEAU(G0): [DRI2] DRI driver: nouveau
10.172] (II) NOUVEAU(G0): [DRI2] VDPAU driver: nouveau
10.172] (II) EXA(256): Driver allocated offscreen pixmaps
10.172] (II) EXA(256): Driver registered support for the following operations:
10.172] (II) Solid
10.172] (II) Copy
10.173] (II) Composite (RENDER acceleration)
10.173] (II) UploadToScreen
10.173] (II) DownloadFromScreen
10.173] (==) NOUVEAU(G0): Backing store disabled
10.173] (==) NOUVEAU(G0): Silken mouse enabled
10.173] (II) NOUVEAU(G0): [XvMC] Associated with Nouveau GeForce 8/9 Textured Video.
10.173] (II) NOUVEAU(G0): [XvMC] Extension initialized.
10.173] (==) NOUVEAU(G0): DPMS enabled
10.173] (II) NOUVEAU(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
10.173] (II) intel(0): SNA initialized with Sandybridge (gen6, gt2) backend
10.173] (==) intel(0): Backing store disabled
10.173] (==) intel(0): Silken mouse enabled
10.173] (II) intel(0): HW Cursor enabled
10.173] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
10.173] (==) intel(0): DPMS enabled
10.173] (II) intel(0): [DRI2] Setup complete
10.173] (II) intel(0): [DRI2] DRI driver: i965
10.173] (II) intel(0): direct rendering: DRI2 Enabled
10.173] (==) intel(0): hotplug detection: "enabled"
10.173] (--) RandR disabled
10.199] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
10.199] (II) AIGLX: enabled GLX_INTEL_swap_event
10.199] (II) AIGLX: enabled GLX_ARB_create_context
10.199] (II) AIGLX: enabled GLX_ARB_create_context_profile
10.199] (II) AIGLX: enabled GLX_EXT_create_context_es2_profile
10.199] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
10.199] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
10.199] (II) AIGLX: Loaded and initialized i965
10.199] (II) GLX: Initialized DRI2 GL provider for screen 0
10.201] (II) NOUVEAU(G0): NVEnterVT is called.
10.203] (II) intel(0): switch to mode 1920x1080@60.0 on pipe 0 using LVDS1, position (0, 0), rotation normal
10.211] (II) intel(0): Setting screen physical size to 508 x 285
(中间是鼠标键盘检测)
478.256] (EE) Server terminated successfully (0). Closing log file.
以防万一我把整个/var/log目录都上传上来了。
log.tar.zip.002.zip (459 KB)
log.tar.zip.001.zip (684 KB)
