- Add Windows CI. Commit.
- Disable decoration on Windows and mac. Commit.
- Add missing kcoreaddons dep. Commit.
- Flatpak: Fix state change emits. Commit. Fixes bug #451111
- Flatpak: Improve stability of different sources integration. Commit.
- Flatpak: Centralise remote integration in FlatpakBackend. Commit. Fixes bug #443745
- Pk: Consider multiple package ids for one upgradeable resource. Commit. Fixes bug #444600
- Don’t use the appdata version in the installed version string if empty. Commit.
- Libdiscover: Fix Discover doesn’t show license or description of local package. Commit. Fixes bug #452150
- Fix processor invocation. Commit.
- Fix the instance filter. Commit.
- Instance ids have 2 hyphens not 3. Commit.
- Outputconfigurationinterface: don’t crash if mode is invalid. Commit. Fixes bug #453042
- Fix race in wp_drm_lease_v1. Commit. See bug #452435
- Simplify code that announces available modes and current mode. Commit. Fixes bug #452318
- Guard subsurface parent access. Commit. Fixes bug #452044
- Fix layer shell reset. Commit.
- Backends/drm: reduce “max bpc” to what is actually used. Commit. Fixes bug #449906
- Fix unlocking wayland sessions. Commit. Fixes bug #447705
- Effects/kscreen: don’t use xcb on Wayland. Commit. Fixes bug #450564
- AbstractClient: Fix the current VD being always added to the plasma interface. Commit. Fixes bug #452171
- Do not send overlay geometry to text input. Commit.
- Backends/drm: don’t permanently disable VRR when the test commit fails. Commit.
- Backends/drm: fetch immutable blobs in DrmProperty. Commit. See bug #449285
- Waylandserver: move LockScreenPresentationWatcher to the correct place. Commit. See bug #452334
- Xdgactivation: Demand attention when a process fails to resolve its token. Commit.
- Waylandserver: only signal lockScreenShown once it has actually been shown. Commit.
- Add a way to ignore devices for tablet mode. Commit.
- Applets/taskmanager: Disable
reuseItemsto avoid a crash. Commit. See bug #452660 - Containments/desktop/folder: remove stray qDebugs. Commit.
- Folder View: save desktop containment icon positions on a per-resolution basis. Commit. Fixes bug #360478. Fixes bug #354802
- Applets/taskmanager: Update tooltip bindings when activating from keyboard. Commit. Fixes bug #452187
- Applets/taskmanager: manually set hover: true on the tooltip highlight. Commit.
- Folder View: Make popup dialog wide enough for one more grid cell. Commit. Fixes bug #417539
Plasma Networkmanager (plasma-nm)
- Don’t use forceActiveFocus to focus the applet toolbar. Commit.
- Revert “[Global Menu] Respect toplevel menu action visibility”. Commit.
- [lookandfeel] Fix collapsed width of a volume/brightness OSD on a lock screen. Commit. Fixes bug #446185
- Xdgactivation: Make sure we don’t call setStartupId with an x11 token. Commit.
- Convert old-style Favorites resources in KActivities DB. Commit. Fixes bug #385814
- [Global Menu] Respect toplevel menu action visibility. Commit. Fixes bug #443505
- Revert “widgetexplorer: Delete newStuffDialog on closed”. Commit. See bug #452865
- Revert “widgetexplorer: Replace
d->newStuffDialogwithWidgetExplorerPrivate::newStuffDialog”. Commit. - Widgetexplorer: Replace
d->newStuffDialogwithWidgetExplorerPrivate::newStuffDialog. Commit. - Widgetexplorer: Delete newStuffDialog on closed. Commit. Fixes bug #452865
- Runners/baloo: Add missing category “text” to file search results. Commit.
- Applets/digital-clock: Fix date drift. Commit. Fixes bug #452554
- Systemtray: Fix race in DBusServiceObserver. Commit. Fixes bug #422111
- Systemdialog: also consider buttonbox for dimensions. Commit.
- Fix not working applet with same compact/full representation when hiding. Commit.
- Shell/scripting: Consider current activity in
desktopForScreen. Commit. Fixes bug #452561 - Set a sane minimum size. Commit.
- SystemDialog: re-add removed public properties. Commit.
- Kcm/colors: don’t dull accent colour on dark themes in colorsapplicator. Commit. Fixes bug #442820
- Wallpapers/image: Use onActivated instead of onCurrentIndexChanged. Commit.
- Appmenu: Use existing menu in compact represenation. Commit. Fixes bug #438467
- Change the text color when appmenu is selected or hovered. Commit.
- Don’t use forceActiveFocus to set search field focus. Commit.
- Applets/clipboard: Don’t forward input to filter if it’s disabled. Commit. See bug #450989
- Klipper/autotests: Add SPDX header. Commit.
- Avoid memory leaks by misusing HistoryItem::mimeData(). Commit.
- A better fix for BUG 431673. Commit.
- Revert “Trim very long text strings in Klipper history view”. Commit.
- Revert “[klipper] Use full text for DBus return values”. Commit.
- Revert “Fix Klipper Actions content truncation”. Commit.
- Revert “klipper: Add FullTextRole to get untruncated text”. Commit.
testTrimmedText”. Commit. - Revert “applets/clipboard: Use FullTextRole in EditPage”. Commit.
- Revert “applets/clipboard: Use FullTextRole in SortFilterModel”. Commit.
- Revert “applets/clipboard: Generate QR code from full text”. Commit.
- Fix saving file dialog view options. Commit
