[已解决]tumbleweed大更新以后无法正常启动
在更新了一千五百多个包后,下次开机写着
[FAILED]Failed to start File System Check on /dev/disk/by-uuid/fc04afab-d617-4854-a521-c3df2842b089.
See "systemctl status 'systemd-fsck@dev-disk-by\x2duuid-fc04afab\x2dd617\x2da521\x2dc3df289.service" for details.
[DEPEND] Denpendency failed /sysroot.
[DEPEND] Dependency failed for Initrd Root File System
[DEPEND] Dependency failed for Reload Configuration from the Real Root.
Generating "/run/initramfs/rdsosreport.txt"
并进入了 emergency mode。怎么解决?
手动 fsck 后重启就行,应该是你的 root 自检失败没挂上
非常感谢,按照您说的用 fsck 去修复一下重启就能解决。
