报错信息
./nx085/ug_install
initializing ...
NX V8.5 Installation 2013年 11月 03日 星期日 15:13:29 CST
Enter '?' for help, '!' for shell, or 'q' to quit at any prompt.
Main Menu. 'n/a' indicates item is not applicable
1. UG Installation type. ______________________ [load+configure]
2. SOURCE directory. ____________________________________ [help]
3. BASE directory. _______________________________ [/usr/ugs085]
4. O.K. to MODIFY system files. __________________________ [yes]
5. License server(s) or a filename. ____ [28000@linux-012e.site]
* Enter item(s) to query or change: [continue]
Checking source directory help ...
WARNING: source directory required for 'load+configure'.
Checking base directory /usr/ugs085 ...
Checking ok to modify system files ...
Checking user supplied server name(s) ...
WARNING: could not ping linux-012e.site This node may not be up.
WARNING: one or more servers failed validation tests
ERROR: no useable servers were entered. all failed validation tests.
The servers entered were not valid or not up and running.
The environment variable UGS_LICENSE_SERVER must be set to
valid server(s) OR a license filename before running NX.
* Enter CR after reading errors.
我的许可安装
linux-012e:/mnt # hostname
linux-012e.site
linux-012e:/mnt # vim /usr/Siemens/PLMLicenseServer/splm5.lic
SERVER linux-012e.site ID=201105555 28000
uglsmd也启动了
linux-012e:/mnt # ps ax | grep ugslmd
16748 pts/1 D+ 0:00 grep --color=auto ugslmd
我的安装步骤
1. Red Hat 6.0 or SuSe Linux Enterprise Desktop 11sp1 or higher is required - no free linuxes!
2. Install the ksh and lsb packages with your package manager
3. Copy license file from _SolidSQUAD_ folder to /root/splm5.lic
4. Insert dvd or mount iso
5. Go to terminal, change working dir to dvd root, then type
sudo ./SPLM*
the license server setup starts. Select server directory and point to licfile /root/splm5.lic you created
6. After server setup is complete, type
sudo ./nx085/ug_install
and follow on screen instructions to setup NX software itself
7. Change folder to _SolidSQUAD_ in terminal and type
sudo ./SIEMENS*
to start the crack installer
Answer Y twice if you left your license server folder to Siemens default or answer Y then N and type the absolute folder path to your ugslmd and lmgrd executables
On a client prompt answer Y too
When crack finishes installation, reboot your PC
8. To run NX GUI, define two exports in .bash_profile
export UGII_ROOT_DIR=<NX install folder>/ugii
export UGS_LICENSE_SERVER=28000@localhost
and create a shortcut to $UGII_ROOT_DIR/ugmenu
9. Enjoy :-)
Cracked by Team-SolidSQUAD
我的UG8.5安装问题出在哪里?
