这个是什么情况 第一次用 Linux 系统 基本都不懂 大家帮忙看看
把 /var/log/YaST2/y2log 贴出来看看,用 livecd 启动应该可以打开这个目录
2013-12-29 03:27:41 <1> linux.site(2960) [liby2] genericfrontend.cc(main):575 Launched YaST2 component 'y2base' 'menu' 'ncurses'
2013-12-29 03:27:41 <1> linux.site(2960) [ui-component] YUIComponentCreator.cc(createInternal):124 Creating UI component for ""
2013-12-29 03:27:41 <1> linux.site(2960) [liby2] genericfrontend.cc(main):764 YAST_IS_RUNNING is yes
2013-12-29 03:27:41 <1> linux.site(2960) [Ruby] yast/wfm.rb:81 Call client /usr/share/YaST2/clients/menu.rb
2013-12-29 03:27:42 <1> linux.site(2960) [ui] YPath.cc(YPath):49 Given filename: libyui-ncurses.so.5
2013-12-29 03:27:42 <1> linux.site(2960) [ui] YSettings.cc(progDir):73 progDir: ""
2013-12-29 03:27:42 <1> linux.site(2960) [ui] YPath.cc(YPath):65 Preferring subdir:
2013-12-29 03:27:42 <1> linux.site(2960) [ui] YPath.cc(YPath):66 Subdir given with filename:
2013-12-29 03:27:42 <1> linux.site(2960) [ui] YPath.cc(YPath):67 Looking for: libyui-ncurses.so.5
2013-12-29 03:27:42 <1> linux.site(2960) [ui] YPath.cc(lsDir):138 Looking in /usr/lib/yui
2013-12-29 03:27:42 <1> linux.site(2960) [ui] YPath.cc(YPath):118 Found libyui-ncurses.so.5 in /usr/lib/yui
2013-12-29 03:27:42 <1> linux.site(2960) [ui] YUI.cc(YUI):76 This is libyui 3.0.10
2013-12-29 03:27:42 <1> linux.site(2960) [ui] YUI.cc(YUI):77 Creating UI with threads
2013-12-29 03:27:42 <1> linux.site(2960) [ncurses] YNCursesUI.cc(YNCursesUI):63 Start YNCursesUI
2013-12-29 03:27:42 <1> linux.site(2960) [ncurses] YNCursesUI.cc(YNCursesUI):71 getenv LANG: POSIX encoding: UTF-8
2013-12-29 03:27:42 <1> linux.site(2960) [ncurses] YNCursesUI.cc(YNCursesUI):77 setenv LC_CTYPE: en_US.UTF-8 encoding: UTF-8
2013-12-29 03:27:42 <1> linux.site(2960) [ncurses] NCurses.cc(init):193 Launch NCurses...(ui-ncurses-2.44.1)
2013-12-29 03:27:42 <1> linux.site(2960) [ncurses] NCurses.cc(init):198 TERM=xterm
2013-12-29 03:27:42 <1> linux.site(2960) [ncurses] NCurses.cc(init):211 isatty(stdin)yes
2013-12-29 03:27:42 <1> linux.site(2960) [ncurses] NCurses.cc(init):219 mytty: /dev/pts/0
2013-12-29 03:27:42 <1> linux.site(2960) [ncurses] NCurses.cc(RedirectToLog):576 isatty(stderr)yes
2013-12-29 03:27:42 <1> linux.site(2960) [ncurses] NCurses.cc(RedirectToLog):585 isatty(stdout)yes
2013-12-29 03:27:42 <1> linux.site(2960) [ncurses] NCurses.cc(init):289 have color = 1
2013-12-29 03:27:42 <1> linux.site(2960) [ncurses] NCurses.cc(init):314 screen size 22 x 80
2013-12-29 03:27:42 <1> linux.site(2960) [ncurses] NCstyle.cc(NCstyle):315 Init xterm using color => 4 styles in xterm
2013-12-29 03:27:42 <1> linux.site(2960) [ncurses] NCurses.cc(SetTitle):481 Draw title called
2013-12-29 03:27:42 <1> linux.site(2960) [ncurses] NCurses.cc(init):326 NCurses ready
2013-12-29 03:27:42 <1> linux.site(2960) [ui] YSettings.cc(setProgDir):60 Set progDir to "/usr/share/YaST2"
2013-12-29 03:27:42 <1> linux.site(2960) [ui] YSettings.cc(setProgDir):61 progDir is now locked.
2013-12-29 03:27:42 <2> linux.site(2960) [ui-shortcuts] YShortcutManager.cc(checkShortcuts):85 Not enough widgets with valid shortcut characters - no check
2013-12-29 03:27:42 <1> linux.site(2960) [ui] YPushButton.cc(setRole):156 Guessing function key F1 for YPushButton "Help" at 0xb6002e40 from button role YHelpButton
2013-12-29 03:27:42 <3> linux.site(2960) [libycp] clients/menu.rb:214 Unknown option `defaultButton in PushButton widget
2013-12-29 03:27:42 <1> linux.site(2960) [ui] YPushButton.cc(setRole):156 Guessing function key F9 for YPushButton "Quit" at 0xb60035c8 from button role YCancelButton
2013-12-29 03:32:09 <1> linux.site(2960) [ncurses] YNCursesUI.cc(~YNCursesUI):113 Stop YNCursesUI
2013-12-29 03:32:09 <1> linux.site(2960) [ncurses] NCurses.cc(~NCurses):150 Shutdown NCurses...
2013-12-29 03:32:09 <1> linux.site(2960) [ncurses] NCurses.cc(~NCurses):169 NCurses down
2013-12-29 03:32:09 <1> linux.site(2960) [liby2] genericfrontend.cc(main):778 Finished YaST2 component 'y2base'
2013-12-29 03:32:09 <1> linux.site(2960) [liby2] genericfrontend.cc(main):783 Exiting with client return value 'nil'
2013-12-29 03:32:09 <1> linux.site(2960) [Y2Ruby] binary/YRuby.cc(~YRuby):107 Shutting down ruby interpreter.
2013-12-29 03:34:23 <1> linux.site(3036) [liby2] genericfrontend.cc(main):575 Launched YaST2 component 'y2base' 'menu' 'ncurses'
2013-12-29 03:34:23 <1> linux.site(3036) [ui-component] YUIComponentCreator.cc(createInternal):124 Creating UI component for ""
2013-12-29 03:34:23 <1> linux.site(3036) [liby2] genericfrontend.cc(main):764 YAST_IS_RUNNING is yes
2013-12-29 03:34:23 <1> linux.site(3036) [Ruby] yast/wfm.rb:81 Call client /usr/share/YaST2/clients/menu.rb
2013-12-29 03:34:24 <1> linux.site(3036) [ui] YPath.cc(YPath):49 Given filename: libyui-ncurses.so.5
2013-12-29 03:34:24 <1> linux.site(3036) [ui] YSettings.cc(progDir):73 progDir: ""
2013-12-29 03:34:24 <1> linux.site(3036) [ui] YPath.cc(YPath):65 Preferring subdir:
2013-12-29 03:34:24 <1> linux.site(3036) [ui] YPath.cc(YPath):66 Subdir given with filename:
2013-12-29 03:34:24 <1> linux.site(3036) [ui] YPath.cc(YPath):67 Looking for: libyui-ncurses.so.5
2013-12-29 03:34:24 <1> linux.site(3036) [ui] YPath.cc(lsDir):138 Looking in /usr/lib/yui
2013-12-29 03:34:24 <1> linux.site(3036) [ui] YPath.cc(YPath):118 Found libyui-ncurses.so.5 in /usr/lib/yui
2013-12-29 03:34:24 <1> linux.site(3036) [ui] YUI.cc(YUI):76 This is libyui 3.0.10
2013-12-29 03:34:24 <1> linux.site(3036) [ui] YUI.cc(YUI):77 Creating UI with threads
2013-12-29 03:34:24 <1> linux.site(3036) [ncurses] YNCursesUI.cc(YNCursesUI):63 Start YNCursesUI
2013-12-29 03:34:24 <1> linux.site(3036) [ncurses] YNCursesUI.cc(YNCursesUI):71 getenv LANG: POSIX encoding: UTF-8
2013-12-29 03:34:24 <1> linux.site(3036) [ncurses] YNCursesUI.cc(YNCursesUI):77 setenv LC_CTYPE: en_US.UTF-8 encoding: UTF-8
2013-12-29 03:34:24 <1> linux.site(3036) [ncurses] NCurses.cc(init):193 Launch NCurses...(ui-ncurses-2.44.1)
2013-12-29 03:34:24 <1> linux.site(3036) [ncurses] NCurses.cc(init):198 TERM=xterm
2013-12-29 03:34:24 <1> linux.site(3036) [ncurses] NCurses.cc(init):211 isatty(stdin)yes
2013-12-29 03:34:24 <1> linux.site(3036) [ncurses] NCurses.cc(init):219 mytty: /dev/pts/0
2013-12-29 03:34:24 <1> linux.site(3036) [ncurses] NCurses.cc(RedirectToLog):576 isatty(stderr)yes
2013-12-29 03:34:24 <1> linux.site(3036) [ncurses] NCurses.cc(RedirectToLog):585 isatty(stdout)yes
2013-12-29 03:34:24 <1> linux.site(3036) [ncurses] NCurses.cc(init):289 have color = 1
2013-12-29 03:34:24 <1> linux.site(3036) [ncurses] NCurses.cc(init):314 screen size 35 x 150
2013-12-29 03:34:24 <1> linux.site(3036) [ncurses] NCstyle.cc(NCstyle):315 Init xterm using color => 4 styles in xterm
2013-12-29 03:34:24 <1> linux.site(3036) [ncurses] NCurses.cc(SetTitle):481 Draw title called
2013-12-29 03:34:24 <1> linux.site(3036) [ncurses] NCurses.cc(init):326 NCurses ready
2013-12-29 03:34:24 <1> linux.site(3036) [ui] YSettings.cc(setProgDir):60 Set progDir to "/usr/share/YaST2"
2013-12-29 03:34:24 <1> linux.site(3036) [ui] YSettings.cc(setProgDir):61 progDir is now locked.
2013-12-29 03:34:24 <2> linux.site(3036) [ui-shortcuts] YShortcutManager.cc(checkShortcuts):85 Not enough widgets with valid shortcut characters - no check
2013-12-29 03:34:24 <1> linux.site(3036) [ui] YPushButton.cc(setRole):156 Guessing function key F1 for YPushButton "Help" at 0xb6002be8 from button role YHelpButton
2013-12-29 03:34:24 <3> linux.site(3036) [libycp] clients/menu.rb:214 Unknown option `defaultButton in PushButton widget
2013-12-29 03:34:24 <1> linux.site(3036) [ui] YPushButton.cc(setRole):156 Guessing function key F9 for YPushButton "Quit" at 0xb6003200 from button role YCancelButton
2013-12-29 03:34:50 <1> linux.site(3036) [ncurses] YNCursesUI.cc(~YNCursesUI):113 Stop YNCursesUI
2013-12-29 03:34:50 <1> linux.site(3036) [ncurses] NCurses.cc(~NCurses):150 Shutdown NCurses...
2013-12-29 03:34:50 <1> linux.site(3036) [ncurses] NCurses.cc(~NCurses):169 NCurses down
2013-12-29 03:34:50 <1> linux.site(3036) [liby2] genericfrontend.cc(main):778 Finished YaST2 component 'y2base'
2013-12-29 03:34:50 <1> linux.site(3036) [liby2] genericfrontend.cc(main):783 Exiting with client return value 'nil'
2013-12-29 03:34:50 <1> linux.site(3036) [Y2Ruby] binary/YRuby.cc(~YRuby):107 Shutting down ruby interpreter.
不懂是出了什么问题了 感觉好像时间不对啊
装好了.
安装的时候 VM 指定 OS 类型为其他 linux 3.x 就安装成功了
呃楼主能不能说一下是怎么解决的?
难道因为表情太大被忽略了吗…
捂脸… 我的错…
