[ 已解决 ]wps 安装过程中断后重新安装出错
刚刚我用
http://download.openSUSE.org/repositories/home:/MargueriteSu/openSUSE_12.3/
这个源安装wps-office,安装程序在自动下载100多MB的rpm包时网不小心断了,然后进度条就不动了,我就按Ctrl+C结束了。
然后再次用
sudo zypper in wps-office
安装时,就会出错。我把终端的输出贴出来:
正在加载软件源数据...
正在读取已安装的软件包...
正在解决软件包依赖关系...
将安装以下新软件包:
  wps-office
1 个软件包将新装.
总下载大小:221.8 KiB 。 操作完成后,将占用额外的 119.1 KiB 空间。
继续吗? [y/n/?] (y): y
正在撷取 软件包 wps-office-9.1.0.4032.a10-4.4.x86_64        (1/1), 221.8 KiB (解压后 119.1 KiB)
正在撷取: wps-office-9.1.0.4032.a10-4.4.x86_64.rpm ..................................................................................................完毕 (234.7 KiB/s)]
(1/1) 正在安装:wps-office-9.1.0.4032.a10-4.4 ......................................................................................................................完毕]
额外的 RPM 输出:
Unknown media type in type 'all/all'
Unknown media type in type 'all/allfiles'
Unknown media type in type 'uri/mms'
Unknown media type in type 'uri/mmst'
Unknown media type in type 'uri/mmsu'
Unknown media type in type 'uri/pnm'
Unknown media type in type 'uri/rtspt'
Unknown media type in type 'uri/rtspu'
正在运行:wps-office-9.1.0.4032.a10-4.4-wps_install.sh.txt  (wps-office, /var/adm/update-scripts)
xz: (stdin): Unexpected end of input
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
cp: cannot stat 'office6': No such file or directory
cp: cannot stat 'utility': No such file or directory
sed: can't read ./et: No such file or directory
sed: can't read ./wps: No such file or directory
sed: can't read ./wpp: No such file or directory
cp: cannot stat './et': No such file or directory
cp: cannot stat './wps': No such file or directory
cp: cannot stat './wpp': No such file or directory
cp: cannot stat './wps_error_check.sh': No such file or directory
cp: cannot stat 'fonts/*.TTF': No such file or directory
Fontconfig warning: "/etc/fonts/infinality/conf.d/41-repl-os-osx.conf", line 15: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/etc/fonts/infinality/conf.d/41-repl-os-osx.conf", line 27: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/etc/fonts/infinality/conf.d/41-repl-os-osx.conf", line 38: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/etc/fonts/infinality/conf.d/41-repl-os-osx.conf", line 48: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/etc/fonts/infinality/conf.d/41-repl-os-osx.conf", line 61: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/etc/fonts/infinality/conf.d/41-repl-os-osx.conf", line 73: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/etc/fonts/infinality/conf.d/41-repl-os-osx.conf", line 100: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/etc/fonts/infinality/conf.d/41-repl-os-osx.conf", line 109: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/etc/fonts/infinality/conf.d/60-group-non-tt-fonts.conf", line 483: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/etc/fonts/infinality/conf.d/60-group-tt-fonts.conf", line 262: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/etc/fonts/infinality/conf.d/62-tt-monospace-rendering.conf", line 27: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/etc/fonts/infinality/conf.d/62-tt-traced-bitmap-rendering.conf", line 21: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/etc/fonts/infinality/conf.d/62-tt-traced-bitmap-rendering.conf", line 50: Having multiple values in <test> isn't supported and may not work as expected
命令退出,状态 1。
中止、重试、忽略? [a/r/i] (a): a
安装/移除以下软件包时或以下软件包在安装后/移除后出现问题:
Installation aborted by user
请参见以上错误信息汲取灵感。
sudo zypper rm wps-office
卸载再安装,还是出现上面的错误。
求助大家,看有没有什么办法解决。
已解决。
把苏姐的那个 wps installer 的 rpm 包下载下来,看了里面的脚本,会检测 /tmp 下的文件名是否存在并进行解压。因为我没下载全,自然就出错了。然后手动把 /tmp 下的 kingsoft* 文件删除掉,再安装就正常了。
